commit 7992c18810e568b95c869b227137a2215702a805 upstream.
CVE-2018-9363
The buffer length is unsigned at all layers, but gets cast to int and
checked in hidp_process_report and can lead to a buffer overflow.
Switch len parameter to unsigned int to resolve issue.
This affects 3.18 and newer kernels.
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Fixes: a4b1b5877b514b276f0f31efe02388a9c2836728 ("HID: Bluetooth: hidp: make sure input buffers are big enough")
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: security@kernel.org
Cc: kernel-team@android.com
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 58152ecbbcc6a0ce7fddd5bf5f6ee535834ece0c upstream.
In case skb in out_or_order_queue is the result of
multiple skbs coalescing, we would like to get a proper gso_segs
counter tracking, so that future tcp_drop() can report an accurate
number.
I chose to not implement this tracking for skbs in receive queue,
since they are not dropped, unless socket is disconnected.
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 91874ecf32e41b5d86a4cb9d60e0bee50d828058 upstream.
It's legal to have 64 groups for netlink_sock.
As user-supplied nladdr->nl_groups is __u32, it's possible to subscribe
only to first 32 groups.
The check for correctness of .bind() userspace supplied parameter
is done by applying mask made from ngroups shift. Which broke Android
as they have 64 groups and the shift for mask resulted in an overflow.
Fixes: 61f4b23769f0 ("netlink: Don't shift with UB on nlk->ngroups")
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: stable@vger.kernel.org
Reported-and-Tested-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Dmitry Safonov <dima@arista.com>
[ Upstream commit 61f4b23769f0cc72ae62c9a81cf08f0397d40da8 ]
On i386 nlk->ngroups might be 32 or 0. Which leads to UB, resulting in
hang during boot.
Check for 0 ngroups and use (unsigned long long) as a type to shift.
Fixes: 7acf9d4237c4 ("netlink: Do not subscribe to non-existent groups").
Reported-by: kernel test robot <rong.a.chen@intel.com>
[ Upstream commit 7acf9d4237c46894e0fa0492dd96314a41742e84 ]
Make ABI more strict about subscribing to group > ngroups.
Code doesn't check for that and it looks bogus.
(one can subscribe to non-existing group)
Still, it's possible to bind() to all possible groups with (-1)
commit c8e8cd579bb4265651df8223730105341e61a2d1 upstream.
'call' is a user-controlled value, so sanitize the array index after the
bounds check to avoid speculating past the bounds of the 'nargs' array.
Found with the help of Smatch:
net/socket.c:2508 __do_sys_socketcall() warn: potential spectre issue
'nargs' [r] (local cap)
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Jeremy Cline <jcline@redhat.com>
[ Upstream commit bc5b6c0b62b932626a135f516a41838c510c6eba ]
'protocol' is a user-controlled value, so sanitize it after the bounds
check to avoid using it for speculative out-of-bounds access to arrays
indexed by it.
This addresses the following accesses detected with the help of smatch:
* net/netlink/af_netlink.c:654 __netlink_create() warn: potential
spectre issue 'nlk_cb_mutex_keys' [w]
spectre issue 'nlk_cb_mutex_key_strings' [w]
* net/netlink/af_netlink.c:685 netlink_create() warn: potential spectre
issue 'nl_table' [w] (local cap)
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
[ Upstream commit a94c689e6c9e72e722f28339e12dff191ee5a265 ]
If a DSA slave network device was previously disabled, there is no need
to suspend or resume it.
Fixes: 2446254915a7 ("net: dsa: allow switch drivers to implement suspend/resume hooks")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit 4672694bd4f1aebdab0ad763ae4716e89cb15221 ]
ip_frag_queue() might call pskb_pull() on one skb that
is already in the fragment queue.
We need to take care of possible truesize change, or we
might have an imbalance of the netns frags memory usage.
IPv6 is immune to this bug, because RFC5722, Section 4,
amended by Errata ID 3089 states :
When reassembling an IPv6 datagram, if
one or more its constituent fragments is determined to be an
overlapping fragment, the entire datagram (and any constituent
fragments) MUST be silently discarded.
Fixes: 158f323b9868 ("net: adjust skb->truesize in pskb_expand_head()")
[ Upstream commit 56e2c94f055d328f5f6b0a5c1721cca2f2d4e0a1 ]
We currently check current frags memory usage only when
a new frag queue is created. This allows attackers to first
consume the memory budget (default : 4 MB) creating thousands
of frag queues, then sending tiny skbs to exceed high_thresh
limit by 2 to 3 order of magnitude.
Note that before commit 648700f76b03 ("inet: frags: use rhashtables
for reassembly units"), work queue could be starved under DOS,
getting no cpu cycles.
After commit 648700f76b03, only the per frag queue timer can eventually
remove an incomplete frag queue and its skbs.
Fixes: b13d3cbfb8e8 ("inet: frag: move eviction of queues to work queue")
Reported-by: Jann Horn <jannh@google.com>
Cc: Florian Westphal <fw@strlen.de>
Cc: Peter Oskolkov <posk@google.com>
Cc: Paolo Abeni <pabeni@redhat.com>
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit 15ecbe94a45ef88491ca459b26efdd02f91edb6d ]
Larry Brakmo proposal ( https://patchwork.ozlabs.org/patch/935233/
tcp: force cwnd at least 2 in tcp_cwnd_reduction) made us rethink
about our recent patch removing ~16 quick acks after ECN events.
tcp_enter_quickack_mode(sk, 1) makes sure one immediate ack is sent,
but in the case the sender cwnd was lowered to 1, we do not want
to have a delayed ack for the next packet we will receive.
Fixes: 522040ea5fdd ("tcp: do not aggressively quick ack after ECN events")
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Lawrence Brakmo <brakmo@fb.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit f4c9f85f3b2cb7669830cd04d0be61192a4d2436 ]
Refactor tcp_ecn_check_ce and __tcp_ecn_check_ce to accept struct sock*
instead of tcp_sock* to clean up type casts. This is a pure refactor
patch.
Signed-off-by: Yousuk Seung <ysseung@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 522040ea5fdd1c33bbf75e1d7c7c0422b96a94ef ]
ECN signals currently forces TCP to enter quickack mode for
up to 16 (TCP_MAX_QUICKACKS) following incoming packets.
We believe this is not needed, and only sending one immediate ack
for the current packet should be enough.
This should reduce the extra load noticed in DCTCP environments,
after congestion events.
This is part 2 of our effort to reduce pure ACK packets.
[ Upstream commit 9a9c9b51e54618861420093ae6e9b50a961914c5 ]
We want to add finer control of the number of ACK packets sent after
ECN events.
This patch is not changing current behavior, it only enables following
change.
[ Upstream commit a3893637e1eb0ef5eb1bbc52b3a8d2dfa317a35d ]
As explained in commit 9f9843a751d0 ("tcp: properly handle stretch
acks in slow start"), TCP stacks have to consider how many packets
are acknowledged in one single ACK, because of GRO, but also
because of ACK compression or losses.
We plan to add SACK compression in the following patch, we
must therefore not call tcp_enter_quickack_mode()
[ Upstream commit 383d470936c05554219094a4d364d964cb324827 ]
For some very small BDPs (with just a few packets) there was a
quantization effect where the target number of packets in flight
during the super-unity-gain (1.25x) phase of gain cycling was
implicitly truncated to a number of packets no larger than the normal
unity-gain (1.0x) phase of gain cycling. This meant that in multi-flow
scenarios some flows could get stuck with a lower bandwidth, because
they did not push enough packets inflight to discover that there was
more bandwidth available. This was really only an issue in multi-flow
LAN scenarios, where RTTs and BDPs are low enough for this to be an
issue.
This fix ensures that gain cycling can raise inflight for small BDPs
by ensuring that in PROBE_BW mode target inflight values with a
super-unity gain are always greater than inflight values with a gain
<= 1. Importantly, this applies whether the inflight value is
calculated for use as a cwnd value, or as a target inflight value for
the end of the super-unity phase in bbr_is_next_cycle_phase() (both
need to be bigger to ensure we can probe with more packets in flight
reliably).
This is a candidate fix for stable releases.
Fixes: 0f8782ea1497 ("tcp_bbr: add BBR congestion control")
Acked-by: Priyaranjan Jha <priyarjha@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 9fc12023d6f51551d6ca9ed7e02ecc19d79caf17 ]
Remove BUG_ON() from fib_compute_spec_dst routine and check
in_dev pointer during flowi4 data structure initialization.
fib_compute_spec_dst routine can be run concurrently with device removal
where ip_ptr net_device pointer is set to NULL. This can happen
if userspace enables pkt info on UDP rx socket and the device
is removed while traffic is flowing
Fixes: 35ebf65e851c ("ipv4: Create and use fib_compute_spec_dst() helper")
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 300eec7c0a2495f771709c7642aa15f7cc148b83 ]
ic_nameservers, which stores the list of name servers discovered by
ipconfig, is initialised (i.e. has all of its elements set to NONE, or
0xffffffff) by ic_nameservers_predef() in the following scenarios:
- before the "ip=" and "nfsaddrs=" kernel command line parameters are
parsed (in ip_auto_config_setup());
- before autoconfiguring via DHCP or BOOTP (in ic_bootp_init()), in
order to clear any values that may have been set after parsing "ip="
or "nfsaddrs=" and are no longer needed.
This means that ic_nameservers_predef() is not called when neither "ip="
nor "nfsaddrs=" is specified on the kernel command line. In this
scenario, every element in ic_nameservers remains set to 0x00000000,
which is indistinguishable from ANY and causes pnp_seq_show() to write
the following (bogus) information to /proc/net/pnp:
#MANUAL
nameserver 0.0.0.0
nameserver 0.0.0.0
nameserver 0.0.0.0
This is potentially problematic for systems that blindly link
/etc/resolv.conf to /proc/net/pnp.
Ensure that ic_nameservers is also initialised when neither "ip=" nor
"nfsaddrs=" are specified by calling ic_nameservers_predef() in
ip_auto_config(), but only when ip_auto_config_setup() was not called
earlier. This causes the following to be written to /proc/net/pnp, and
is consistent with what gets written when ipconfig is configured
manually but no name servers are specified on the kernel command line:
#MANUAL
Signed-off-by: Chris Novakovic <chris@chrisn.me.uk>
[ Upstream commit 9c7f96fd77b0dbe1fe7ed1f9c462c45dc48a1076 ]
The patch moves the "trans->msg_type == NFT_MSG_NEWSET" check before
using nft_trans_set(trans). Otherwise we can get out of bounds read.
For example, KASAN reported the one when running 0001_cache_handling_0 nft
test. In this case "trans->msg_type" was NFT_MSG_NEWTABLE:
[75517.177808] BUG: KASAN: slab-out-of-bounds in nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75517.279094] Read of size 8 at addr ffff881bdb643fc8 by task nft/7356
[75517.375605] CPU: 26 PID: 7356 Comm: nft Tainted: G E 4.17.0-rc7.1.x86_64 #1
[75517.489587] Hardware name: Oracle Corporation SUN SERVER X4-2
[75517.618129] Call Trace:
[75517.648821] dump_stack+0xd1/0x13b
[75517.691040] ? show_regs_print_info+0x5/0x5
[75517.742519] ? kmsg_dump_rewind_nolock+0xf5/0xf5
[75517.799300] ? lock_acquire+0x143/0x310
[75517.846738] print_address_description+0x85/0x3a0
[75517.904547] kasan_report+0x18d/0x4b0
[75517.949892] ? nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75518.019153] ? nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75518.088420] ? nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75518.157689] nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75518.224869] nf_tables_newsetelem+0x1a5/0x5d0 [nf_tables]
[75518.291024] ? nft_add_set_elem+0x2280/0x2280 [nf_tables]
[75518.357154] ? nla_parse+0x1a5/0x300
[75518.401455] ? kasan_kmalloc+0xa6/0xd0
[75518.447842] nfnetlink_rcv+0xc43/0x1bdf [nfnetlink]
[75518.507743] ? nfnetlink_rcv+0x7a5/0x1bdf [nfnetlink]
[75518.569745] ? nfnl_err_reset+0x3c0/0x3c0 [nfnetlink]
[75518.631711] ? lock_acquire+0x143/0x310
[75518.679133] ? netlink_deliver_tap+0x9b/0x1070
[75518.733840] ? kasan_unpoison_shadow+0x31/0x40
[75518.788542] netlink_unicast+0x45d/0x680
[75518.837111] ? __isolate_free_page+0x890/0x890
[75518.891913] ? netlink_attachskb+0x6b0/0x6b0
[75518.944542] netlink_sendmsg+0x6fa/0xd30
[75518.993107] ? netlink_unicast+0x680/0x680
[75519.043758] ? netlink_unicast+0x680/0x680
[75519.094402] sock_sendmsg+0xd9/0x160
[75519.138810] ___sys_sendmsg+0x64d/0x980
[75519.186234] ? copy_msghdr_from_user+0x350/0x350
[75519.243118] ? lock_downgrade+0x650/0x650
[75519.292738] ? do_raw_spin_unlock+0x5d/0x250
[75519.345456] ? _raw_spin_unlock+0x24/0x30
[75519.395065] ? __handle_mm_fault+0xbde/0x3410
[75519.448830] ? sock_setsockopt+0x3d2/0x1940
[75519.500516] ? __lock_acquire.isra.25+0xdc/0x19d0
[75519.558448] ? lock_downgrade+0x650/0x650
[75519.608057] ? __audit_syscall_entry+0x317/0x720
[75519.664960] ? __fget_light+0x58/0x250
[75519.711325] ? __sys_sendmsg+0xde/0x170
[75519.758850] __sys_sendmsg+0xde/0x170
[75519.804193] ? __ia32_sys_shutdown+0x90/0x90
[75519.856725] ? syscall_trace_enter+0x897/0x10e0
[75519.912354] ? trace_event_raw_event_sys_enter+0x920/0x920
[75519.979432] ? __audit_syscall_entry+0x720/0x720
[75520.036118] do_syscall_64+0xa3/0x3d0
[75520.081248] ? prepare_exit_to_usermode+0x47/0x1d0
[75520.139904] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[75520.201680] RIP: 0033:0x7fc153320ba0
[75520.245772] RSP: 002b:00007ffe294c3638 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[75520.337708] RAX: ffffffffffffffda RBX: 00007ffe294c4820 RCX: 00007fc153320ba0
[75520.424547] RDX: 0000000000000000 RSI: 00007ffe294c46b0 RDI: 0000000000000003
[75520.511386] RBP: 00007ffe294c47b0 R08: 0000000000000004 R09: 0000000002114090
[75520.598225] R10: 00007ffe294c30a0 R11: 0000000000000246 R12: 00007ffe294c3660
[75520.684961] R13: 0000000000000001 R14: 00007ffe294c3650 R15: 0000000000000001
[75520.790946] Allocated by task 7356:
[75520.833994] kasan_kmalloc+0xa6/0xd0
[75520.878088] __kmalloc+0x189/0x450
[75520.920107] nft_trans_alloc_gfp+0x20/0x190 [nf_tables]
[75520.983961] nf_tables_newtable+0xcd0/0x1bd0 [nf_tables]
[75521.048857] nfnetlink_rcv+0xc43/0x1bdf [nfnetlink]
[75521.108655] netlink_unicast+0x45d/0x680
[75521.157013] netlink_sendmsg+0x6fa/0xd30
[75521.205271] sock_sendmsg+0xd9/0x160
[75521.249365] ___sys_sendmsg+0x64d/0x980
[75521.296686] __sys_sendmsg+0xde/0x170
[75521.341822] do_syscall_64+0xa3/0x3d0
[75521.386957] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[75521.467867] Freed by task 23454:
[75521.507804] __kasan_slab_free+0x132/0x180
[75521.558137] kfree+0x14d/0x4d0
[75521.596005] free_rt_sched_group+0x153/0x280
[75521.648410] sched_autogroup_create_attach+0x19a/0x520
[75521.711330] ksys_setsid+0x2ba/0x400
[75521.755529] __ia32_sys_setsid+0xa/0x10
[75521.802850] do_syscall_64+0xa3/0x3d0
[75521.848090] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[75521.929000] The buggy address belongs to the object at ffff881bdb643f80
which belongs to the cache kmalloc-96 of size 96
[75522.079797] The buggy address is located 72 bytes inside of
96-byte region [ffff881bdb643f80, ffff881bdb643fe0)
[75522.221234] The buggy address belongs to the page:
[75522.280100] page:ffffea006f6d90c0 count:1 mapcount:0 mapping:0000000000000000 index:0x0
[75522.377443] flags: 0x2fffff80000100(slab)
[75522.426956] raw: 002fffff80000100 0000000000000000 0000000000000000 0000000180200020
[75522.521275] raw: ffffea006e6fafc0 0000000c0000000c ffff881bf180f400 0000000000000000
[75522.615601] page dumped because: kasan: bad access detected
Fixes: 37a9cc525525 ("netfilter: nf_tables: add generation mask to sets")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
[ Upstream commit 8541b21e781a22dce52a74fef0b9bed00404a1cd ]
In order to be able to give better diagnostics and detect
malicious traffic, we need to have better sk->sk_drops tracking.
Fixes: 9f5afeae5152 ("tcp: use an RB tree for ooo receive queue")
[ Upstream commit 3d4bf93ac12003f9b8e1e2de37fe27983deebdcf ]
In case an attacker feeds tiny packets completely out of order,
tcp_collapse_ofo_queue() might scan the whole rb-tree, performing
expensive copies, but not changing socket memory usage at all.
1) Do not attempt to collapse tiny skbs.
2) Add logic to exit early when too many tiny skbs are detected.
We prefer not doing aggressive collapsing (which copies packets)
for pathological flows, and revert to tcp_prune_ofo_queue() which
will be less expensive.
In the future, we might add the possibility of terminating flows
that are proven to be malicious.
[ Upstream commit f4a3313d8e2ca9fd8d8f45e40a2903ba782607e7 ]
Right after a TCP flow is created, receiving tiny out of order
packets allways hit the condition :
if (atomic_read(&sk->sk_rmem_alloc) >= sk->sk_rcvbuf)
tcp_clamp_window(sk);
tcp_clamp_window() increases sk_rcvbuf to match sk_rmem_alloc
(guarded by tcp_rmem[2])
Calling tcp_collapse_ofo_queue() in this case is not useful,
and offers a O(N^2) surface attack to malicious peers.
Better not attempt anything before full queue capacity is reached,
forcing attacker to spend lots of resource and allow us to more
easily detect the abuse.
[ Upstream commit 72cd43ba64fc172a443410ce01645895850844c8 ]
Juha-Matti Tilli reported that malicious peers could inject tiny
packets in out_of_order_queue, forcing very expensive calls
to tcp_collapse_ofo_queue() and tcp_prune_ofo_queue() for
every incoming packet. out_of_order_queue rb-tree can contain
thousands of nodes, iterating over all of them is not nice.
Before linux-4.9, we would have pruned all packets in ofo_queue
in one go, every XXXX packets. XXXX depends on sk_rcvbuf and skbs
truesize, but is about 7000 packets with tcp_rmem[2] default of 6 MB.
Since we plan to increase tcp_rmem[2] in the future to cope with
modern BDP, can not revert to the old behavior, without great pain.
Strategy taken in this patch is to purge ~12.5 % of the queue capacity.
Fixes: 36a6503fedda ("tcp: refine tcp_prune_ofo_queue() to not drop all packets")
Reported-by: Juha-Matti Tilli <juha-matti.tilli@iki.fi>
[ Upstream commit a0496ef2c23b3b180902dd185d0d63ccbc624cf8 ]
Per DCTCP RFC8257 (Section 3.2) the ACK reflecting the CE status change
has to be sent immediately so the sender can respond quickly:
""" When receiving packets, the CE codepoint MUST be processed as follows:
1. If the CE codepoint is set and DCTCP.CE is false, set DCTCP.CE to
true and send an immediate ACK.
2. If the CE codepoint is not set and DCTCP.CE is true, set DCTCP.CE
to false and send an immediate ACK.
Previously DCTCP implementation may continue to delay the ACK. This
patch fixes that to implement the RFC by forcing an immediate ACK.
Tested with this packetdrill script provided by Larry Brakmo
0.000 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
0.000 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
0.000 setsockopt(3, SOL_TCP, TCP_CONGESTION, "dctcp", 5) = 0
0.000 bind(3, ..., ...) = 0
0.000 listen(3, 1) = 0
0.100 < [ect0] SEW 0:0(0) win 32792 <mss 1000,sackOK,nop,nop,nop,wscale 7>
0.100 > SE. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK,nop,wscale 8>
0.110 < [ect0] . 1:1(0) ack 1 win 257
0.200 accept(3, ..., ...) = 4
+0 setsockopt(4, SOL_SOCKET, SO_DEBUG, [1], 4) = 0
0.200 < [ect0] . 1:1001(1000) ack 1 win 257
0.200 > [ect01] . 1:1(0) ack 1001
0.200 write(4, ..., 1) = 1
0.200 > [ect01] P. 1:2(1) ack 1001
0.200 < [ect0] . 1001:2001(1000) ack 2 win 257
+0.005 < [ce] . 2001:3001(1000) ack 2 win 257
+0.000 > [ect01] . 2:2(0) ack 2001
// Previously the ACK below would be delayed by 40ms
+0.000 > [ect01] E. 2:2(0) ack 3001
+0.500 < F. 9501:9501(0) ack 4 win 257
[ Upstream commit 27cde44a259c380a3c09066fc4b42de7dde9b1ad ]
Currently when a DCTCP receiver delays an ACK and receive a
data packet with a different CE mark from the previous one's, it
sends two immediate ACKs acking previous and latest sequences
respectly (for ECN accounting).
Previously sending the first ACK may mark off the delayed ACK timer
(tcp_event_ack_sent). This may subsequently prevent sending the
second ACK to acknowledge the latest sequence (tcp_ack_snd_check).
The culprit is that tcp_send_ack() assumes it always acknowleges
the latest sequence, which is not true for the first special ACK.
The fix is to not make the assumption in tcp_send_ack and check the
actual ack sequence before cancelling the delayed ACK. Further it's
safer to pass the ack sequence number as a local variable into
tcp_send_ack routine, instead of intercepting tp->rcv_nxt to avoid
future bugs like this.
[ Upstream commit 2987babb6982306509380fc11b450227a844493b ]
Refactor and create helpers to send the special ACK in DCTCP.
[ Upstream commit b0c05d0e99d98d7f0cd41efc1eeec94efdc3325d ]
Previously, when a data segment was sent an ACK was piggybacked
on the data segment without generating a CA_EVENT_NON_DELAYED_ACK
event to notify congestion control modules. So the DCTCP
ca->delayed_ack_reserved flag could incorrectly stay set when
in fact there were no delayed ACKs being reserved. This could result
in sending a special ECN notification ACK that carries an older
ACK sequence, when in fact there was no need for such an ACK.
DCTCP keeps track of the delayed ACK status with its own separate
state ca->delayed_ack_reserved. Previously it may accidentally cancel
the delayed ACK without updating this field upon sending a special
ACK that carries a older ACK sequence. This inconsistency would
lead to DCTCP receiver never acknowledging the latest data until the
sender times out and retry in some cases.
Packetdrill script (provided by Larry Brakmo)
0.200 > [ect01] P. 2:3(1) ack 2001
0.200 < [ect0] . 2001:3001(1000) ack 3 win 257
0.200 < [ect0] . 3001:4001(1000) ack 3 win 257
0.200 > [ect01] . 3:3(0) ack 4001
0.210 < [ce] P. 4001:4501(500) ack 3 win 257
+0.001 read(4, ..., 4500) = 4500
+0 write(4, ..., 1) = 1
+0 > [ect01] PE. 3:4(1) ack 4501
+0.010 < [ect0] W. 4501:5501(1000) ack 4 win 257
// Previously the ACK sequence below would be 4501, causing a long RTO
+0.040~+0.045 > [ect01] . 4:4(0) ack 5501 // delayed ack
+0.311 < [ect0] . 5501:6501(1000) ack 4 win 257 // More data
+0 > [ect01] . 4:4(0) ack 6501 // now acks everything
Reported-by: Larry Brakmo <brakmo@fb.com>
Acked-by: Lawrence Brakmo <brakmo@fb.com>
[ Upstream commit 5025f7f7d506fba9b39e7fe8ca10f6f34cb9bc2d ]
rtnl_configure_link sets dev->rtnl_link_state to
RTNL_LINK_INITIALIZED and unconditionally calls
__dev_notify_flags to notify user-space of dev flags.
current call sequence for rtnl_configure_link
rtnetlink_newlink
rtnl_link_ops->newlink
rtnl_configure_link (unconditionally notifies userspace of
default and new dev flags)
If a newlink handler wants to call rtnl_configure_link
early, we will end up with duplicate notifications to
user-space.
This patch fixes rtnl_configure_link to check rtnl_link_state
and call __dev_notify_flags with gchanges = 0 if already
RTNL_LINK_INITIALIZED.
Later in the series, this patch will help the following sequence
where a driver implementing newlink can call rtnl_configure_link
to initialize the link early.
makes the following call sequence work:
rtnetlink_newlink
rtnl_link_ops->newlink (vxlan) -> rtnl_configure_link (initializes
link and notifies
user-space of default
dev flags)
rtnl_configure_link (updates dev flags if requested by user ifm
and notifies user-space of new dev flags)
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
There are two scenarios that we will restore deleted records. The first is
when device down and up(or unmap/remap). In this scenario the new filter
mode is same with previous one. Because we get it from in_dev->mc_list and
we do not touch it during device down and up.
The other scenario is when a new socket join a group which was just delete
and not finish sending status reports. In this scenario, we should use the
current filter mode instead of restore old one. Here are 4 cases in total.
old_socket new_socket before_fix after_fix
IN(A) IN(A) ALLOW(A) ALLOW(A)
IN(A) EX( ) TO_IN( ) TO_EX( )
EX( ) IN(A) TO_EX( ) ALLOW(A)
EX( ) EX( ) TO_EX( ) TO_EX( )
Fixes: 24803f38a5c0b (igmp: do not remove igmp souce list info when set link down)
Fixes: 1666d49e1d416 (mld: do not remove mld souce list info when set link down)
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit ff907a11a0d68a749ce1a321f4505c03bf72190c ]
syzbot caught a NULL deref [1], caused by skb_segment()
skb_segment() has many "goto err;" that assume the @err variable
contains -ENOMEM.
A successful call to __skb_linearize() should not clear @err,
otherwise a subsequent memory allocation error could return NULL.
While we are at it, we might use -EINVAL instead of -ENOMEM when
MAX_SKB_FRAGS limit is reached.
[1]
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
CPU: 0 PID: 13285 Comm: syz-executor3 Not tainted 4.18.0-rc4+ #146
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:tcp_gso_segment+0x3dc/0x1780 net/ipv4/tcp_offload.c:106
Code: f0 ff ff 0f 87 1c fd ff ff e8 00 88 0b fb 48 8b 75 d0 48 b9 00 00 00 00 00 fc ff df 48 8d be 90 00 00 00 48 89 f8 48 c1 e8 03 <0f> b6 14 08 48 8d 86 94 00 00 00 48 89 c6 83 e0 07 48 c1 ee 03 0f
RSP: 0018:ffff88019b7fd060 EFLAGS: 00010206
RAX: 0000000000000012 RBX: 0000000000000020 RCX: dffffc0000000000
RDX: 0000000000040000 RSI: 0000000000000000 RDI: 0000000000000090
RBP: ffff88019b7fd0f0 R08: ffff88019510e0c0 R09: ffffed003b5c46d6
R10: ffffed003b5c46d6 R11: ffff8801dae236b3 R12: 0000000000000001
R13: ffff8801d6c581f4 R14: 0000000000000000 R15: ffff8801d6c58128
FS: 00007fcae64d6700(0000) GS:ffff8801dae00000(0000) knlGS:0000000000000000
CR2: 00000000004e8664 CR3: 00000001b669b000 CR4: 00000000001406f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
tcp4_gso_segment+0x1c3/0x440 net/ipv4/tcp_offload.c:54
inet_gso_segment+0x64e/0x12d0 net/ipv4/af_inet.c:1342
skb_mac_gso_segment+0x3b5/0x740 net/core/dev.c:2792
__skb_gso_segment+0x3c3/0x880 net/core/dev.c:2865
skb_gso_segment include/linux/netdevice.h:4099 [inline]
validate_xmit_skb+0x640/0xf30 net/core/dev.c:3104
__dev_queue_xmit+0xc14/0x3910 net/core/dev.c:3561
dev_queue_xmit+0x17/0x20 net/core/dev.c:3602
neigh_hh_output include/net/neighbour.h:473 [inline]
neigh_output include/net/neighbour.h:481 [inline]
ip_finish_output2+0x1063/0x1860 net/ipv4/ip_output.c:229
ip_finish_output+0x841/0xfa0 net/ipv4/ip_output.c:317
NF_HOOK_COND include/linux/netfilter.h:276 [inline]
ip_output+0x223/0x880 net/ipv4/ip_output.c:405
dst_output include/net/dst.h:444 [inline]
ip_local_out+0xc5/0x1b0 net/ipv4/ip_output.c:124
iptunnel_xmit+0x567/0x850 net/ipv4/ip_tunnel_core.c:91
ip_tunnel_xmit+0x1598/0x3af1 net/ipv4/ip_tunnel.c:778
ipip_tunnel_xmit+0x264/0x2c0 net/ipv4/ipip.c:308
__netdev_start_xmit include/linux/netdevice.h:4148 [inline]
netdev_start_xmit include/linux/netdevice.h:4157 [inline]
xmit_one net/core/dev.c:3034 [inline]
dev_hard_start_xmit+0x26c/0xc30 net/core/dev.c:3050
__dev_queue_xmit+0x29ef/0x3910 net/core/dev.c:3569
neigh_direct_output+0x15/0x20 net/core/neighbour.c:1403
neigh_output include/net/neighbour.h:483 [inline]
ip_finish_output2+0xa67/0x1860 net/ipv4/ip_output.c:229
ip_queue_xmit+0x9df/0x1f80 net/ipv4/ip_output.c:504
tcp_transmit_skb+0x1bf9/0x3f10 net/ipv4/tcp_output.c:1168
tcp_write_xmit+0x1641/0x5c20 net/ipv4/tcp_output.c:2363
__tcp_push_pending_frames+0xb2/0x290 net/ipv4/tcp_output.c:2536
tcp_push+0x638/0x8c0 net/ipv4/tcp.c:735
tcp_sendmsg_locked+0x2ec5/0x3f00 net/ipv4/tcp.c:1410
tcp_sendmsg+0x2f/0x50 net/ipv4/tcp.c:1447
inet_sendmsg+0x1a1/0x690 net/ipv4/af_inet.c:798
sock_sendmsg_nosec net/socket.c:641 [inline]
sock_sendmsg+0xd5/0x120 net/socket.c:651
__sys_sendto+0x3d7/0x670 net/socket.c:1797
__do_sys_sendto net/socket.c:1809 [inline]
__se_sys_sendto net/socket.c:1805 [inline]
__x64_sys_sendto+0xe1/0x1a0 net/socket.c:1805
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x455ab9
Code: 1d ba fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 eb b9 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fcae64d5c68 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00007fcae64d66d4 RCX: 0000000000455ab9
RDX: 0000000000000001 RSI: 0000000020000200 RDI: 0000000000000013
RBP: 000000000072bea0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000014
R13: 00000000004c1145 R14: 00000000004d1818 R15: 0000000000000006
Modules linked in:
Dumping ftrace buffer:
(ftrace buffer empty)
Fixes: ddff00d42043 ("net: Move skb_has_shared_frag check out of GRE code and into segmentation")
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Reported-by: syzbot <syzkaller@googlegroups.com>
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit 2efd4fca703a6707cad16ab486eaab8fc7f0fd49 ]
Syzbot reported a read beyond the end of the skb head when returning
IPV6_ORIGDSTADDR:
BUG: KMSAN: kernel-infoleak in put_cmsg+0x5ef/0x860 net/core/scm.c:242
CPU: 0 PID: 4501 Comm: syz-executor128 Not tainted 4.17.0+ #9
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:113
kmsan_report+0x188/0x2a0 mm/kmsan/kmsan.c:1125
kmsan_internal_check_memory+0x138/0x1f0 mm/kmsan/kmsan.c:1219
kmsan_copy_to_user+0x7a/0x160 mm/kmsan/kmsan.c:1261
copy_to_user include/linux/uaccess.h:184 [inline]
ip6_datagram_recv_specific_ctl+0x1cf3/0x1eb0 net/ipv6/datagram.c:719
ip6_datagram_recv_ctl+0x41c/0x450 net/ipv6/datagram.c:733
rawv6_recvmsg+0x10fb/0x1460 net/ipv6/raw.c:521
This logic and its ipv4 counterpart read the destination port from
the packet at skb_transport_offset(skb) + 4.
With MSG_MORE and a local SOCK_RAW sender, syzbot was able to cook a
packet that stores headers exactly up to skb_transport_offset(skb) in
the head and the remainder in a frag.
Call pskb_may_pull before accessing the pointer to ensure that it lies
in skb head.
Link: http://lkml.kernel.org/r/CAF=yD-LEJwZj5a1-bAAj2Oy_hKmGygV6rsJ_WOrAYnv-fnayiQ@mail.gmail.com
Reported-by: syzbot+9adb4b567003cac781f0@syzkaller.appspotmail.com
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 3dd1c9a1270736029ffca670e9bd0265f4120600 ]
The skb hash for locally generated ip[v6] fragments belonging
to the same datagram can vary in several circumstances:
* for connected UDP[v6] sockets, the first fragment get its hash
via set_owner_w()/skb_set_hash_from_sk()
* for unconnected IPv6 UDPv6 sockets, the first fragment can get
its hash via ip6_make_flowlabel()/skb_get_hash_flowi6(), if
auto_flowlabel is enabled
For the following frags the hash is usually computed via
skb_get_hash().
The above can cause OoO for unconnected IPv6 UDPv6 socket: in that
scenario the egress tx queue can be selected on a per packet basis
via the skb hash.
It may also fool flow-oriented schedulers to place fragments belonging
to the same datagram in different flows.
Fix the issue by copying the skb hash from the head frag into
the others at fragmentation time.
Before this commit:
perf probe -a "dev_queue_xmit skb skb->hash skb->l4_hash:b1@0/8 skb->sw_hash:b1@1/8"
netperf -H $IPV4 -t UDP_STREAM -l 5 -- -m 2000 -n &
perf record -e probe:dev_queue_xmit -e probe:skb_set_owner_w -a sleep 0.1
perf script
probe:dev_queue_xmit: (ffffffff8c6b1b20) hash=3713014309 l4_hash=1 sw_hash=0
probe:dev_queue_xmit: (ffffffff8c6b1b20) hash=0 l4_hash=0 sw_hash=0
After this commit:
probe:dev_queue_xmit: (ffffffff8c6b1b20) hash=2171763177 l4_hash=1 sw_hash=0
Fixes: b73c3d0e4f0e ("net: Save TX flow hash in sock and set in skbuf on xmit")
Fixes: 67800f9b1f4e ("ipv6: Call skb_get_hash_flowi6 to get skb->hash in ip6_make_flowlabel")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
commit a8f688ec437dc2045cc8f0c89fe877d5803850da upstream.
The use of -EAGAIN in rpcrdma_convert_iovs() is a latent bug: the
transport never calls xprt_write_space() when more pages become
available. -ENOBUFS will trigger the correct "delay briefly and call
again" logic.
Fixes: 7a89f9c626e3 ("xprtrdma: Honor ->send_request API contract")
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Cc: stable@vger.kernel.org # 4.8+
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit e78bfb0751d4e312699106ba7efbed2bab1a53ca ]
Commit 8b7008620b84 ("net: Don't copy pfmemalloc flag in
__copy_skb_header()") introduced a different handling for the
pfmemalloc flag in copy and clone paths.
In __skb_clone(), now, the flag is set only if it was set in the
original skb, but not cleared if it wasn't. This is wrong and
might lead to socket buffers being flagged with pfmemalloc even
if the skb data wasn't allocated from pfmemalloc reserves. Copy
the flag instead of ORing it.
Reported-by: Sabrina Dubroca <sd@queasysnail.net>
Fixes: 8b7008620b84 ("net: Don't copy pfmemalloc flag in __copy_skb_header()")
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
Tested-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit 8b7008620b8452728cadead460a36f64ed78c460 ]
The pfmemalloc flag indicates that the skb was allocated from
the PFMEMALLOC reserves, and the flag is currently copied on skb
copy and clone.
However, an skb copied from an skb flagged with pfmemalloc
wasn't necessarily allocated from PFMEMALLOC reserves, and on
the other hand an skb allocated that way might be copied from an
skb that wasn't.
So we should not copy the flag on skb copy, and rather decide
whether to allow an skb to be associated with sockets unrelated
to page reclaim depending only on how it was allocated.
Move the pfmemalloc flag before headers_start[0] using an
existing 1-bit hole, so that __copy_skb_header() doesn't copy
it.
When cloning, we'll now take care of this flag explicitly,
contravening to the warning comment of __skb_clone().
While at it, restore the newline usage introduced by commit
b19372273164 ("net: reorganize sk_buff for faster
__copy_skb_header()") to visually separate bytes used in
bitfields after headers_start[0], that was gone after commit
a9e419dc7be6 ("netfilter: merge ctinfo into nfct pointer storage
area"), and describe the pfmemalloc flag in the kernel-doc
structure comment.
This doesn't change the size of sk_buff or cacheline boundaries,
but consolidates the 15 bits hole before tc_index into a 2 bytes
hole before csum, that could now be filled more easily.
Reported-by: Patrick Talbert <ptalbert@redhat.com>
Fixes: c93bdd0e03e8 ("netvm: allow skb allocation to use PFMEMALLOC reserves")
[ Upstream commit e7372197e15856ec4ee66b668020a662994db103 ]
Xin reported that icmp replies may not use the address on the device the
echo request is received if the destination address is broadcast. Instead
a route lookup is done without considering VRF context. Fix by setting
oif in flow struct to the master device if it is enslaved. That directs
the lookup to the VRF table. If the device is not enslaved, oif is still
0 so no affect.
Fixes: cd2fbe1b6b51 ("net: Use VRF device index for lookups on RX")
Reported-by: Xin Long <lucien.xin@gmail.com>
Signed-off-by: David Ahern <dsahern@gmail.com>
[ Upstream commit acc2cf4e37174646a24cba42fa53c668b2338d4e ]
When tcp_diag_destroy closes a TCP_NEW_SYN_RECV socket, it first
frees it by calling inet_csk_reqsk_queue_drop_and_and_put in
tcp_abort, and then frees it again by calling sock_gen_put.
Since tcp_abort only has one caller, and all the other codepaths
in tcp_abort don't free the socket, just remove the free in that
function.
Cc: David Ahern <dsa@cumulusnetworks.com>
Tested: passes Android sock_diag_test.py, which exercises this codepath
Fixes: d7226c7a4dd1 ("net: diag: Fix refcnt leak in error path destroying socket")
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Reviewed-by: David Ahern <dsa@cumulusnetworks.com>
Tested-by: David Ahern <dsa@cumulusnetworks.com>
[ Upstream commit 70ba5b6db96ff7324b8cfc87e0d0383cf59c9677 ]
The low and high values of the net.ipv4.ping_group_range sysctl were
being silently forced to the default disabled state when a write to the
sysctl contained GIDs that didn't map to the associated user namespace.
Confusingly, the sysctl's write operation would return success and then
a subsequent read of the sysctl would indicate that the low and high
values are the overflowgid.
This patch changes the behavior by clearly returning an error when the
sysctl write operation receives a GID range that doesn't map to the
associated user namespace. In such a situation, the previous value of
the sysctl is preserved and that range will be returned in a subsequent
read of the sysctl.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
[ Upstream commit d5a672ac9f48f81b20b1cad1d9ed7bbf4e418d4c ]
The gen_stats facility will add a header for the toplevel nlattr of type
TCA_STATS2 that contains all stats added by qdisc callbacks. A reference
to this header is stored in the gnet_dump struct, and when all the
per-qdisc callbacks have finished adding their stats, the length of the
containing header will be adjusted to the right value.
However, on architectures that need padding (i.e., that don't set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS), the padding nlattr is added
before the stats, which means that the stored pointer will point to the
padding, and so when the header is fixed up, the result is just a very
big padding nlattr. Because most qdiscs also supply the legacy TCA_STATS
struct, this problem has been mostly invisible, but we exposed it with
the netlink attribute-based statistics in CAKE.
Fix the issue by fixing up the stored pointer if it points to a padding
nlattr.
Tested-by: Pete Heist <pete@heistp.net>
Tested-by: Kevin Darbyshire-Bryant <kevin@darbyshire-bryant.me.uk>
Signed-off-by: Toke Høiland-Jørgensen <toke@toke.dk>
commit 3bc53be9db21040b5d2de4d455f023c8c494aa68 upstream.
syzbot is reporting stalls at nfc_llcp_send_ui_frame() [1]. This is
because nfc_llcp_send_ui_frame() is retrying the loop without any delay
when nonblocking nfc_alloc_send_skb() returned NULL.
Since there is no need to use MSG_DONTWAIT if we retry until
sock_alloc_send_pskb() succeeds, let's use blocking call.
Also, in case an unexpected error occurred, let's break the loop
if blocking nfc_alloc_send_skb() failed.
[1] https://syzkaller.appspot.com/bug?id=4a131cc571c3733e0eff6bc673f4e36ae48f19c6
Reported-by: syzbot <syzbot+d29d18215e477cfbfbdd@syzkaller.appspotmail.com>
commit f1693c63ab133d16994cc50f773982b5905af264 upstream.
Loop transport which is self loopback, remote port congestion
update isn't relevant. Infact the xmit path already ignores it.
Receive path needs to do the same.
Reported-by: syzbot+4c20b3866171ce8441d2@syzkaller.appspotmail.com
Reviewed-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
commit 84379c9afe011020e797e3f50a662b08a6355dcf upstream.
Eric Dumazet reports:
Here is a reproducer of an annoying bug detected by syzkaller on our production kernel
./b78305423 enable_conntrack
Then :
sleep 60
dmesg | tail -10
[ 171.599093] unregister_netdevice: waiting for lo to become free. Usage count = 2
[ 181.631024] unregister_netdevice: waiting for lo to become free. Usage count = 2
[ 191.687076] unregister_netdevice: waiting for lo to become free. Usage count = 2
[ 201.703037] unregister_netdevice: waiting for lo to become free. Usage count = 2
[ 211.711072] unregister_netdevice: waiting for lo to become free. Usage count = 2
[ 221.959070] unregister_netdevice: waiting for lo to become free. Usage count = 2
Reproducer sends ipv6 fragment that hits nfct defrag via LOCAL_OUT hook.
skb gets queued until frag timer expiry -- 1 minute.
Normally nf_conntrack_reasm gets called during prerouting, so skb has
no dst yet which might explain why this wasn't spotted earlier.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Reported-by: John Sperbeck <jsperbeck@google.com>
Tested-by: Eric Dumazet <edumazet@google.com>
commit c604cb767049b78b3075497b80ebb8fd530ea2cc upstream.
My recent fix for dns_resolver_preparse() printing very long strings was
incomplete, as shown by syzbot which still managed to hit the
WARN_ONCE() in set_precision() by adding a crafted "dns_resolver" key:
precision 50001 too large
WARNING: CPU: 7 PID: 864 at lib/vsprintf.c:2164 vsnprintf+0x48a/0x5a0
The bug this time isn't just a printing bug, but also a logical error
when multiple options ("#"-separated strings) are given in the key
payload. Specifically, when separating an option string into name and
value, if there is no value then the name is incorrectly considered to
end at the end of the key payload, rather than the end of the current
option. This bypasses validation of the option length, and also means
that specifying multiple options is broken -- which presumably has gone
unnoticed as there is currently only one valid option anyway.
A similar problem also applied to option values, as the kstrtoul() when
parsing the "dnserror" option will read past the end of the current
option and into the next option.
Fix these bugs by correctly computing the length of the option name and
by copying the option value, null-terminated, into a temporary buffer.
Reproducer for the WARN_ONCE() that syzbot hit:
perl -e 'print "#A#", "\0" x 50000' | keyctl padd dns_resolver desc @s
Reproducer for "dnserror" option being parsed incorrectly (expected
behavior is to fail when seeing the unknown option "foo", actual
behavior was to read the dnserror value as "1#foo" and fail there):
perl -e 'print "#dnserror=1#foo\0"' | keyctl padd dns_resolver desc @s
Fixes: 4a2d789267e0 ("DNS: If the DNS server returns an error, allow that to be cached [ver #2]")
commit 11ff7288beb2b7da889a014aff0a7b80bf8efcf3 upstream.
the ebtables evaluation loop expects targets to return
positive values (jumps), or negative values (absolute verdicts).
This is completely different from what xtables does.
In xtables, targets are expected to return the standard netfilter
verdicts, i.e. NF_DROP, NF_ACCEPT, etc.
ebtables will consider these as jumps.
Therefore reject any target found due to unspec fallback.
v2: also reject watchers. ebtables ignores their return value, so
a target that assumes skb ownership (and returns NF_STOLEN) causes
use-after-free.
The only watchers in the 'ebtables' front-end are log and nflog;
both have AF_BRIDGE specific wrappers on kernel side.
Reported-by: syzbot+2b43f681169a2a0d306a@syzkaller.appspotmail.com
[ Upstream commit 945d015ee0c3095d2290e845565a23dedfd8027c ]
We should put copy_skb in receive_queue only after
a successful call to virtio_net_hdr_from_skb().
syzbot report :
BUG: KASAN: use-after-free in __skb_unlink include/linux/skbuff.h:1843 [inline]
BUG: KASAN: use-after-free in __skb_dequeue include/linux/skbuff.h:1863 [inline]
BUG: KASAN: use-after-free in skb_dequeue+0x16a/0x180 net/core/skbuff.c:2815
Read of size 8 at addr ffff8801b044ecc0 by task syz-executor217/4553
CPU: 0 PID: 4553 Comm: syz-executor217 Not tainted 4.18.0-rc1+ #111
Call Trace:
dump_stack+0x1c9/0x2b4 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433
skb_queue_purge+0x26/0x40 net/core/skbuff.c:2852
packet_set_ring+0x675/0x1da0 net/packet/af_packet.c:4331
packet_release+0x630/0xd90 net/packet/af_packet.c:2991
__sock_release+0xd7/0x260 net/socket.c:603
sock_close+0x19/0x20 net/socket.c:1186
__fput+0x35b/0x8b0 fs/file_table.c:209
____fput+0x15/0x20 fs/file_table.c:243
task_work_run+0x1ec/0x2a0 kernel/task_work.c:113
exit_task_work include/linux/task_work.h:22 [inline]
do_exit+0x1b08/0x2750 kernel/exit.c:865
do_group_exit+0x177/0x440 kernel/exit.c:968
__do_sys_exit_group kernel/exit.c:979 [inline]
__se_sys_exit_group kernel/exit.c:977 [inline]
__x64_sys_exit_group+0x3e/0x50 kernel/exit.c:977
RIP: 0033:0x4448e9
Code: Bad RIP value.
RSP: 002b:00007ffd5f777ca8 EFLAGS: 00000202 ORIG_RAX: 00000000000000e7
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00000000004448e9
RDX: 00000000004448e9 RSI: 000000000000fcfb RDI: 0000000000000001
RBP: 00000000006cf018 R08: 00007ffd0000a45b R09: 0000000000000000
R10: 00007ffd5f777e48 R11: 0000000000000202 R12: 00000000004021f0
R13: 0000000000402280 R14: 0000000000000000 R15: 0000000000000000
Allocated by task 4553:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc4/0xe0 mm/kasan/kasan.c:553
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490
kmem_cache_alloc+0x12e/0x760 mm/slab.c:3554
skb_clone+0x1f5/0x500 net/core/skbuff.c:1282
tpacket_rcv+0x28f7/0x3200 net/packet/af_packet.c:2221
deliver_skb net/core/dev.c:1925 [inline]
deliver_ptype_list_skb net/core/dev.c:1940 [inline]
__netif_receive_skb_core+0x1bfb/0x3680 net/core/dev.c:4611
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:4693
netif_receive_skb_internal+0x12e/0x7d0 net/core/dev.c:4767
netif_receive_skb+0xbf/0x420 net/core/dev.c:4791
tun_rx_batched.isra.55+0x4ba/0x8c0 drivers/net/tun.c:1571
tun_get_user+0x2af1/0x42f0 drivers/net/tun.c:1981
tun_chr_write_iter+0xb9/0x154 drivers/net/tun.c:2009
call_write_iter include/linux/fs.h:1795 [inline]
new_sync_write fs/read_write.c:474 [inline]
__vfs_write+0x6c6/0x9f0 fs/read_write.c:487
vfs_write+0x1f8/0x560 fs/read_write.c:549
ksys_write+0x101/0x260 fs/read_write.c:598
__do_sys_write fs/read_write.c:610 [inline]
__se_sys_write fs/read_write.c:607 [inline]
__x64_sys_write+0x73/0xb0 fs/read_write.c:607
Freed by task 4553:
__kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kmem_cache_free+0x86/0x2d0 mm/slab.c:3756
kfree_skbmem+0x154/0x230 net/core/skbuff.c:582
__kfree_skb net/core/skbuff.c:642 [inline]
kfree_skb+0x1a5/0x580 net/core/skbuff.c:659
tpacket_rcv+0x189e/0x3200 net/packet/af_packet.c:2385
The buggy address belongs to the object at ffff8801b044ecc0
which belongs to the cache skbuff_head_cache of size 232
The buggy address is located 0 bytes inside of
232-byte region [ffff8801b044ecc0, ffff8801b044eda8)
page:ffffea0006c11380 count:1 mapcount:0 mapping:ffff8801d9be96c0 index:0x0
flags: 0x2fffc0000000100(slab)
raw: 02fffc0000000100 ffffea0006c17988 ffff8801d9bec248 ffff8801d9be96c0
raw: 0000000000000000 ffff8801b044e040 000000010000000c 0000000000000000
Memory state around the buggy address:
ffff8801b044eb80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8801b044ec00: 00 00 00 00 00 00 00 00 00 00 00 00 00 fc fc fc
>ffff8801b044ec80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8801b044ed00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801b044ed80: fb fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc
Fixes: 58d19b19cd99 ("packet: vnet_hdr support for tpacket_rcv")
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit 1236f22fbae15df3736ab4a984c64c0c6ee6254c ]
If SACK is not enabled and the first cumulative ACK after the RTO
retransmission covers more than the retransmitted skb, a spurious
FRTO undo will trigger (assuming FRTO is enabled for that RTO).
The reason is that any non-retransmitted segment acknowledged will
set FLAG_ORIG_SACK_ACKED in tcp_clean_rtx_queue even if there is
no indication that it would have been delivered for real (the
scoreboard is not kept with TCPCB_SACKED_ACKED bits in the non-SACK
case so the check for that bit won't help like it does with SACK).
Having FLAG_ORIG_SACK_ACKED set results in the spurious FRTO undo
in tcp_process_loss.
We need to use more strict condition for non-SACK case and check
that none of the cumulatively ACKed segments were retransmitted
to prove that progress is due to original transmissions. Only then
keep FLAG_ORIG_SACK_ACKED set, allowing FRTO undo to proceed in
non-SACK case.
(FLAG_ORIG_SACK_ACKED is planned to be renamed to FLAG_ORIG_PROGRESS
to better indicate its purpose but to keep this change minimal, it
will be done in another patch).
Besides burstiness and congestion control violations, this problem
can result in RTO loop: When the loss recovery is prematurely
undoed, only new data will be transmitted (if available) and
the next retransmission can occur only after a new RTO which in case
of multiple losses (that are not for consecutive packets) requires
one RTO per loss to recover.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Tested-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit c860e997e9170a6d68f9d1e6e2cf61f572191aaf ]
Fast Open key could be stored in different endian based on the CPU.
Previously hosts in different endianness in a server farm using
the same key config (sysctl value) would produce different cookies.
This patch fixes it by always storing it as little endian to keep
same API for LE hosts.
Reported-by: Daniele Iamartino <danielei@google.com>
[ Upstream commit 7e85dc8cb35abf16455f1511f0670b57c1a84608 ]
When blackhole is used on top of classful qdisc like hfsc it breaks
qlen and backlog counters because packets are disappear without notice.
In HFSC non-zero qlen while all classes are inactive triggers warning:
WARNING: ... at net/sched/sch_hfsc.c:1393 hfsc_dequeue+0xba4/0xe90 [sch_hfsc]
and schedules watchdog work endlessly.
This patch return __NET_XMIT_BYPASS in addition to NET_XMIT_SUCCESS,
this flag tells upper layer: this packet is gone and isn't queued.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
[ Upstream commit 0ce4e70ff00662ad7490e545ba0cd8c1fa179fca ]
To compute delays, better not use time of the day which can
be changed by admins or malicious programs.
Also change ccid3_first_li() to use s64 type for delta variable
to avoid potential overflows.
Cc: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Cc: dccp@vger.kernel.org
[ Upstream commit 74174fe5634ffbf645a7ca5a261571f700b2f332 ]
On fast hosts or malicious bots, we trigger a DCCP_BUG() which
seems excessive.
syzbot reported :
BUG: delta (-6195) <= 0 at net/dccp/ccids/ccid3.c:628/ccid3_hc_rx_send_feedback()
CPU: 1 PID: 18 Comm: ksoftirqd/1 Not tainted 4.18.0-rc1+ #112
Call Trace:
ccid3_hc_rx_send_feedback net/dccp/ccids/ccid3.c:628 [inline]
ccid3_hc_rx_packet_recv.cold.16+0x38/0x71 net/dccp/ccids/ccid3.c:793
ccid_hc_rx_packet_recv net/dccp/ccid.h:185 [inline]
dccp_deliver_input_to_ccids+0xf0/0x280 net/dccp/input.c:180
dccp_rcv_established+0x87/0xb0 net/dccp/input.c:378
dccp_v4_do_rcv+0x153/0x180 net/dccp/ipv4.c:654
sk_backlog_rcv include/net/sock.h:914 [inline]
__sk_receive_skb+0x3ba/0xd80 net/core/sock.c:517
dccp_v4_rcv+0x10f9/0x1f58 net/dccp/ipv4.c:875
ip_local_deliver_finish+0x2eb/0xda0 net/ipv4/ip_input.c:215
NF_HOOK include/linux/netfilter.h:287 [inline]
ip_local_deliver+0x1e9/0x750 net/ipv4/ip_input.c:256
dst_input include/net/dst.h:450 [inline]
ip_rcv_finish+0x823/0x2220 net/ipv4/ip_input.c:396
ip_rcv+0xa18/0x1284 net/ipv4/ip_input.c:492
__netif_receive_skb_core+0x2488/0x3680 net/core/dev.c:4628
process_backlog+0x219/0x760 net/core/dev.c:5373
napi_poll net/core/dev.c:5771 [inline]
net_rx_action+0x7da/0x1980 net/core/dev.c:5837
__do_softirq+0x2e8/0xb17 kernel/softirq.c:284
run_ksoftirqd+0x86/0x100 kernel/softirq.c:645
smpboot_thread_fn+0x417/0x870 kernel/smpboot.c:164
kthread+0x345/0x410 kernel/kthread.c:240
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412
