path: root/net
2019-05-25mac80211: Fix kernel panic due to use of txq after freeBhagavathi Perumal S
[ Upstream commit f1267cf3c01b12e0f843fb6a7450a7f0b2efab8a ] The txq of vif is added to active_txqs list for ATF TXQ scheduling in the function ieee80211_queue_skb(), but it was not properly removed before freeing the txq object. It was causing use after free of the txq objects from the active_txqs list, result was kernel panic due to invalid memory access. Fix kernel invalid memory access by properly removing txq object from active_txqs list before free the object. Signed-off-by: Bhagavathi Perumal S <bperumal@codeaurora.org> Acked-by: Toke Høiland-Jørgensen <toke@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25xfrm4: Fix uninitialized memory read in _decode_session4Steffen Klassert
[ Upstream commit 8742dc86d0c7a9628117a989c11f04a9b6b898f3 ] We currently don't reload pointers pointing into skb header after doing pskb_may_pull() in _decode_session4(). So in case pskb_may_pull() changed the pointers, we read from random memory. Fix this by putting all the needed infos on the stack, so that we don't need to access the header pointers after doing pskb_may_pull(). Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25xfrm: Honor original L3 slave device in xfrmi policy lookupMartin Willi
[ Upstream commit 025c65e119bf58b610549ca359c9ecc5dee6a8d2 ] If an xfrmi is associated to a vrf layer 3 master device, xfrm_policy_check() fails after traffic decapsulation. The input interface is replaced by the layer 3 master device, and hence xfrmi_decode_session() can't match the xfrmi anymore to satisfy policy checking. Extend ingress xfrmi lookup to honor the original layer 3 slave device, allowing xfrm interfaces to operate within a vrf domain. Fixes: f203b76d7809 ("xfrm: Add virtual xfrm interfaces") Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25esp4: add length check for UDP encapsulationSabrina Dubroca
[ Upstream commit 8dfb4eba4100e7cdd161a8baef2d8d61b7a7e62e ] esp_output_udp_encap can produce a length that doesn't fit in the 16 bits of a UDP header's length field. In that case, we'll send a fragmented packet whose length is larger than IP_MAX_MTU (resulting in "Oversized IP packet" warnings on receive) and with a bogus UDP length. To prevent this, add a length check to esp_output_udp_encap and return -EMSGSIZE on failure. This seems to be older than git history. Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25xfrm: clean up xfrm protocol checksCong Wang
[ Upstream commit dbb2483b2a46fbaf833cfb5deb5ed9cace9c7399 ] In commit 6a53b7593233 ("xfrm: check id proto in validate_tmpl()") I introduced a check for xfrm protocol, but according to Herbert IPSEC_PROTO_ANY should only be used as a wildcard for lookup, so it should be removed from validate_tmpl(). And, IPSEC_PROTO_ANY is expected to only match 3 IPSec-specific protocols, this is why xfrm_state_flush() could still miss IPPROTO_ROUTING, which leads that those entries are left in net->xfrm.state_all before exit net. Fix this by replacing IPSEC_PROTO_ANY with zero. This patch also extracts the check from validate_tmpl() to xfrm_id_proto_valid() and uses it in parse_ipsecrequest(). With this, no other protocols should be added into xfrm. Fixes: 6a53b7593233 ("xfrm: check id proto in validate_tmpl()") Reported-by: syzbot+0bf0519d6e0de15914fe@syzkaller.appspotmail.com Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25vti4: ipip tunnel deregistration fixes.Jeremy Sowden
[ Upstream commit 5483844c3fc18474de29f5d6733003526e0a9f78 ] If tunnel registration failed during module initialization, the module would fail to deregister the IPPROTO_COMP protocol and would attempt to deregister the tunnel. The tunnel was not deregistered during module-exit. Fixes: dd9ee3444014e ("vti4: Fix a ipip packet processing bug in 'IPCOMP' virtual tunnel") Signed-off-by: Jeremy Sowden <jeremy@azazel.net> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25xfrm6_tunnel: Fix potential panic when unloading xfrm6_tunnel moduleSu Yanjun
[ Upstream commit 6ee02a54ef990a71bf542b6f0a4e3321de9d9c66 ] When unloading xfrm6_tunnel module, xfrm6_tunnel_fini directly frees the xfrm6_tunnel_spi_kmem. Maybe someone has gotten the xfrm6_tunnel_spi, so need to wait it. Fixes: 91cc3bb0b04ff("xfrm6_tunnel: RCU conversion") Signed-off-by: Su Yanjun <suyj.fnst@cn.fujitsu.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25xfrm: Reset secpath in xfrm failureMyungho Jung
[ Upstream commit 6ed69184ed9c43873b8a1ee721e3bf3c08c2c6be ] In esp4_gro_receive() and esp6_gro_receive(), secpath can be allocated without adding xfrm state to xvec. Then, sp->xvec[sp->len - 1] would fail and result in dereferencing invalid pointer in esp4_gso_segment() and esp6_gso_segment(). Reset secpath if xfrm function returns error. Fixes: 7785bba299a8 ("esp: Add a software GRO codepath") Reported-by: syzbot+b69368fd933c6c592f4c@syzkaller.appspotmail.com Signed-off-by: Myungho Jung <mhjungk@gmail.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25xfrm: policy: Fix out-of-bound array accesses in __xfrm_policy_unlinkYueHaibing
[ Upstream commit b805d78d300bcf2c83d6df7da0c818b0fee41427 ] UBSAN report this: UBSAN: Undefined behaviour in net/xfrm/xfrm_policy.c:1289:24 index 6 is out of range for type 'unsigned int [6]' CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.162-514.55.6.9.x86_64+ #13 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 0000000000000000 1466cf39b41b23c9 ffff8801f6b07a58 ffffffff81cb35f4 0000000041b58ab3 ffffffff83230f9c ffffffff81cb34e0 ffff8801f6b07a80 ffff8801f6b07a20 1466cf39b41b23c9 ffffffff851706e0 ffff8801f6b07ae8 Call Trace: <IRQ> [<ffffffff81cb35f4>] __dump_stack lib/dump_stack.c:15 [inline] <IRQ> [<ffffffff81cb35f4>] dump_stack+0x114/0x1a0 lib/dump_stack.c:51 [<ffffffff81d94225>] ubsan_epilogue+0x12/0x8f lib/ubsan.c:164 [<ffffffff81d954db>] __ubsan_handle_out_of_bounds+0x16e/0x1b2 lib/ubsan.c:382 [<ffffffff82a25acd>] __xfrm_policy_unlink+0x3dd/0x5b0 net/xfrm/xfrm_policy.c:1289 [<ffffffff82a2e572>] xfrm_policy_delete+0x52/0xb0 net/xfrm/xfrm_policy.c:1309 [<ffffffff82a3319b>] xfrm_policy_timer+0x30b/0x590 net/xfrm/xfrm_policy.c:243 [<ffffffff813d3927>] call_timer_fn+0x237/0x990 kernel/time/timer.c:1144 [<ffffffff813d8e7e>] __run_timers kernel/time/timer.c:1218 [inline] [<ffffffff813d8e7e>] run_timer_softirq+0x6ce/0xb80 kernel/time/timer.c:1401 [<ffffffff8120d6f9>] __do_softirq+0x299/0xe10 kernel/softirq.c:273 [<ffffffff8120e676>] invoke_softirq kernel/softirq.c:350 [inline] [<ffffffff8120e676>] irq_exit+0x216/0x2c0 kernel/softirq.c:391 [<ffffffff82c5edab>] exiting_irq arch/x86/include/asm/apic.h:652 [inline] [<ffffffff82c5edab>] smp_apic_timer_interrupt+0x8b/0xc0 arch/x86/kernel/apic/apic.c:926 [<ffffffff82c5c985>] apic_timer_interrupt+0xa5/0xb0 arch/x86/entry/entry_64.S:735 <EOI> [<ffffffff81188096>] ? native_safe_halt+0x6/0x10 arch/x86/include/asm/irqflags.h:52 [<ffffffff810834d7>] arch_safe_halt arch/x86/include/asm/paravirt.h:111 [inline] [<ffffffff810834d7>] default_idle+0x27/0x430 arch/x86/kernel/process.c:446 [<ffffffff81085f05>] arch_cpu_idle+0x15/0x20 arch/x86/kernel/process.c:437 [<ffffffff8132abc3>] default_idle_call+0x53/0x90 kernel/sched/idle.c:92 [<ffffffff8132b32d>] cpuidle_idle_call kernel/sched/idle.c:156 [inline] [<ffffffff8132b32d>] cpu_idle_loop kernel/sched/idle.c:251 [inline] [<ffffffff8132b32d>] cpu_startup_entry+0x60d/0x9a0 kernel/sched/idle.c:299 [<ffffffff8113e119>] start_secondary+0x3c9/0x560 arch/x86/kernel/smpboot.c:245 The issue is triggered as this: xfrm_add_policy -->verify_newpolicy_info //check the index provided by user with XFRM_POLICY_MAX //In my case, the index is 0x6E6BB6, so it pass the check. -->xfrm_policy_construct //copy the user's policy and set xfrm_policy_timer -->xfrm_policy_insert --> __xfrm_policy_link //use the orgin dir, in my case is 2 --> xfrm_gen_index //generate policy index, there is 0x6E6BB6 then xfrm_policy_timer be fired xfrm_policy_timer --> xfrm_policy_id2dir //get dir from (policy index & 7), in my case is 6 --> xfrm_policy_delete --> __xfrm_policy_unlink //access policy_count[dir], trigger out of range access Add xfrm_policy_id2dir check in verify_newpolicy_info, make sure the computed dir is valid, to fix the issue. Reported-by: Hulk Robot <hulkci@huawei.com> Fixes: e682adf021be ("xfrm: Try to honor policy index if it's supplied by user") Signed-off-by: YueHaibing <yuehaibing@huawei.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-25vsock/virtio: Initialize core virtio vsock before registering the driverJorge E. Moreira
[ Upstream commit ba95e5dfd36647622d8897a2a0470dde60e59ffd ] Avoid a race in which static variables in net/vmw_vsock/af_vsock.c are accessed (while handling interrupts) before they are initialized. [ 4.201410] BUG: unable to handle kernel paging request at ffffffffffffffe8 [ 4.207829] IP: vsock_addr_equals_addr+0x3/0x20 [ 4.211379] PGD 28210067 P4D 28210067 PUD 28212067 PMD 0 [ 4.211379] Oops: 0000 [#1] PREEMPT SMP PTI [ 4.211379] Modules linked in: [ 4.211379] CPU: 1 PID: 30 Comm: kworker/1:1 Not tainted 4.14.106-419297-gd7e28cc1f241 #1 [ 4.211379] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014 [ 4.211379] Workqueue: virtio_vsock virtio_transport_rx_work [ 4.211379] task: ffffa3273d175280 task.stack: ffffaea1800e8000 [ 4.211379] RIP: 0010:vsock_addr_equals_addr+0x3/0x20 [ 4.211379] RSP: 0000:ffffaea1800ebd28 EFLAGS: 00010286 [ 4.211379] RAX: 0000000000000002 RBX: 0000000000000000 RCX: ffffffffb94e42f0 [ 4.211379] RDX: 0000000000000400 RSI: ffffffffffffffe0 RDI: ffffaea1800ebdd0 [ 4.211379] RBP: ffffaea1800ebd58 R08: 0000000000000001 R09: 0000000000000001 [ 4.211379] R10: 0000000000000000 R11: ffffffffb89d5d60 R12: ffffaea1800ebdd0 [ 4.211379] R13: 00000000828cbfbf R14: 0000000000000000 R15: ffffaea1800ebdc0 [ 4.211379] FS: 0000000000000000(0000) GS:ffffa3273fd00000(0000) knlGS:0000000000000000 [ 4.211379] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 4.211379] CR2: ffffffffffffffe8 CR3: 000000002820e001 CR4: 00000000001606e0 [ 4.211379] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 4.211379] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 [ 4.211379] Call Trace: [ 4.211379] ? vsock_find_connected_socket+0x6c/0xe0 [ 4.211379] virtio_transport_recv_pkt+0x15f/0x740 [ 4.211379] ? detach_buf+0x1b5/0x210 [ 4.211379] virtio_transport_rx_work+0xb7/0x140 [ 4.211379] process_one_work+0x1ef/0x480 [ 4.211379] worker_thread+0x312/0x460 [ 4.211379] kthread+0x132/0x140 [ 4.211379] ? process_one_work+0x480/0x480 [ 4.211379] ? kthread_destroy_worker+0xd0/0xd0 [ 4.211379] ret_from_fork+0x35/0x40 [ 4.211379] Code: c7 47 08 00 00 00 00 66 c7 07 28 00 c7 47 08 ff ff ff ff c7 47 04 ff ff ff ff c3 0f 1f 00 66 2e 0f 1f 84 00 00 00 00 00 8b 47 08 <3b> 46 08 75 0a 8b 47 04 3b 46 04 0f 94 c0 c3 31 c0 c3 90 66 2e [ 4.211379] RIP: vsock_addr_equals_addr+0x3/0x20 RSP: ffffaea1800ebd28 [ 4.211379] CR2: ffffffffffffffe8 [ 4.211379] ---[ end trace f31cc4a2e6df3689 ]--- [ 4.211379] Kernel panic - not syncing: Fatal exception in interrupt [ 4.211379] Kernel Offset: 0x37000000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff) [ 4.211379] Rebooting in 5 seconds.. Fixes: 22b5c0b63f32 ("vsock/virtio: fix kernel panic after device hot-unplug") Cc: Stefan Hajnoczi <stefanha@redhat.com> Cc: Stefano Garzarella <sgarzare@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: kvm@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Cc: netdev@vger.kernel.org Cc: kernel-team@android.com Cc: stable@vger.kernel.org [4.9+] Signed-off-by: Jorge E. Moreira <jemoreira@google.com> Reviewed-by: Stefano Garzarella <sgarzare@redhat.com> Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com> Acked-by: Stefan Hajnoczi <stefanha@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-25tipc: fix modprobe tipc failed after switch order of device registrationJunwei Hu
[ Upstream commit 532b0f7ece4cb2ffd24dc723ddf55242d1188e5e ] Error message printed: modprobe: ERROR: could not insert 'tipc': Address family not supported by protocol. when modprobe tipc after the following patch: switch order of device registration, commit 7e27e8d6130c ("tipc: switch order of device registration to fix a crash") Because sock_create_kern(net, AF_TIPC, ...) is called by tipc_topsrv_create_listener() in the initialization process of tipc_net_ops, tipc_socket_init() must be execute before that. I move tipc_socket_init() into function tipc_init_net(). Fixes: 7e27e8d6130c ("tipc: switch order of device registration to fix a crash") Signed-off-by: Junwei Hu <hujunwei4@huawei.com> Reported-by: Wang Wang <wangwang2@huawei.com> Reviewed-by: Kang Zhou <zhoukang7@huawei.com> Reviewed-by: Suanming Mou <mousuanming@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-25vsock/virtio: free packets during the socket releaseStefano Garzarella
[ Upstream commit ac03046ece2b158ebd204dfc4896fd9f39f0e6c8 ] When the socket is released, we should free all packets queued in the per-socket list in order to avoid a memory leak. Signed-off-by: Stefano Garzarella <sgarzare@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-25tipc: switch order of device registration to fix a crashJunwei Hu
[ Upstream commit 7e27e8d6130c5e88fac9ddec4249f7f2337fe7f8 ] When tipc is loaded while many processes try to create a TIPC socket, a crash occurs: PANIC: Unable to handle kernel paging request at virtual address "dfff20000000021d" pc : tipc_sk_create+0x374/0x1180 [tipc] lr : tipc_sk_create+0x374/0x1180 [tipc] Exception class = DABT (current EL), IL = 32 bits Call trace: tipc_sk_create+0x374/0x1180 [tipc] __sock_create+0x1cc/0x408 __sys_socket+0xec/0x1f0 __arm64_sys_socket+0x74/0xa8 ... This is due to race between sock_create and unfinished register_pernet_device. tipc_sk_insert tries to do "net_generic(net, tipc_net_id)". but tipc_net_id is not initialized yet. So switch the order of the two to close the race. This can be reproduced with multiple processes doing socket(AF_TIPC, ...) and one process doing module removal. Fixes: a62fbccecd62 ("tipc: make subscriber server support net namespace") Signed-off-by: Junwei Hu <hujunwei4@huawei.com> Reported-by: Wang Wang <wangwang2@huawei.com> Reviewed-by: Xiaogang Wang <wangxiaogang3@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-25rtnetlink: always put IFLA_LINK for links with a link-netnsidSabrina Dubroca
[ Upstream commit feadc4b6cf42a53a8a93c918a569a0b7e62bd350 ] Currently, nla_put_iflink() doesn't put the IFLA_LINK attribute when iflink == ifindex. In some cases, a device can be created in a different netns with the same ifindex as its parent. That device will not dump its IFLA_LINK attribute, which can confuse some userspace software that expects it. For example, if the last ifindex created in init_net and foo are both 8, these commands will trigger the issue: ip link add parent type dummy # ifindex 9 ip link add link parent netns foo type macvlan # ifindex 9 in ns foo So, in case a device puts the IFLA_LINK_NETNSID attribute in a dump, always put the IFLA_LINK attribute as well. Thanks to Dan Winship for analyzing the original OpenShift bug down to the missing netlink attribute. v2: change Fixes tag, it's been here forever, as Nicolas Dichtel said add Nicolas' ack v3: change Fixes tag fix subject typo, spotted by Edward Cree Analyzed-by: Dan Winship <danw@redhat.com> Fixes: d8a5ec672768 ("[NET]: netlink support for moving devices between network namespaces.") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-25net: avoid weird emergency messageEric Dumazet
[ Upstream commit d7c04b05c9ca14c55309eb139430283a45c4c25f ] When host is under high stress, it is very possible thread running netdev_wait_allrefs() returns from msleep(250) 10 seconds late. This leads to these messages in the syslog : [...] unregister_netdevice: waiting for syz_tun to become free. Usage count = 0 If the device refcount is zero, the wait is over. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-25ipv6: prevent possible fib6 leaksEric Dumazet
[ Upstream commit 61fb0d01680771f72cc9d39783fb2c122aaad51e ] At ipv6 route dismantle, fib6_drop_pcpu_from() is responsible for finding all percpu routes and set their ->from pointer to NULL, so that fib6_ref can reach its expected value (1). The problem right now is that other cpus can still catch the route being deleted, since there is no rcu grace period between the route deletion and call to fib6_drop_pcpu_from() This can leak the fib6 and associated resources, since no notifier will take care of removing the last reference(s). I decided to add another boolean (fib6_destroying) instead of reusing/renaming exception_bucket_flushed to ease stable backports, and properly document the memory barriers used to implement this fix. This patch has been co-developped with Wei Wang. Fixes: 93531c674315 ("net/ipv6: separate handling of FIB entries from dst based routes") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Cc: Wei Wang <weiwan@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Martin Lau <kafai@fb.com> Acked-by: Wei Wang <weiwan@google.com> Acked-by: Martin KaFai Lau <kafai@fb.com> Reviewed-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-25ipv6: fix src addr routing with the exception tableWei Wang
[ Upstream commit 510e2ceda031eed97a7a0f9aad65d271a58b460d ] When inserting route cache into the exception table, the key is generated with both src_addr and dest_addr with src addr routing. However, current logic always assumes the src_addr used to generate the key is a /128 host address. This is not true in the following scenarios: 1. When the route is a gateway route or does not have next hop. (rt6_is_gw_or_nonexthop() == false) 2. When calling ip6_rt_cache_alloc(), saddr is passed in as NULL. This means, when looking for a route cache in the exception table, we have to do the lookup twice: first time with the passed in /128 host address, second time with the src_addr stored in fib6_info. This solves the pmtu discovery issue reported by Mikael Magnusson where a route cache with a lower mtu info is created for a gateway route with src addr. However, the lookup code is not able to find this route cache. Fixes: 2b760fcf5cfb ("ipv6: hook up exception table to store dst cache") Reported-by: Mikael Magnusson <mikael.kernel@lists.m7n.se> Bisected-by: David Ahern <dsahern@gmail.com> Signed-off-by: Wei Wang <weiwan@google.com> Cc: Martin Lau <kafai@fb.com> Cc: Eric Dumazet <edumazet@google.com> Acked-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16flow_dissector: disable preemption around BPF callsEric Dumazet
[ Upstream commit b1c17a9a353878602fd5bfe9103e4afe5e9a3f96 ] Various things in eBPF really require us to disable preemption before running an eBPF program. syzbot reported : BUG: assuming atomic context at net/core/flow_dissector.c:737 in_atomic(): 0, irqs_disabled(): 0, pid: 24710, name: syz-executor.3 2 locks held by syz-executor.3/24710: #0: 00000000e81a4bf1 (&tfile->napi_mutex){+.+.}, at: tun_get_user+0x168e/0x3ff0 drivers/net/tun.c:1850 #1: 00000000254afebd (rcu_read_lock){....}, at: __skb_flow_dissect+0x1e1/0x4bb0 net/core/flow_dissector.c:822 CPU: 1 PID: 24710 Comm: syz-executor.3 Not tainted 5.1.0+ #6 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x172/0x1f0 lib/dump_stack.c:113 __cant_sleep kernel/sched/core.c:6165 [inline] __cant_sleep.cold+0xa3/0xbb kernel/sched/core.c:6142 bpf_flow_dissect+0xfe/0x390 net/core/flow_dissector.c:737 __skb_flow_dissect+0x362/0x4bb0 net/core/flow_dissector.c:853 skb_flow_dissect_flow_keys_basic include/linux/skbuff.h:1322 [inline] skb_probe_transport_header include/linux/skbuff.h:2500 [inline] skb_probe_transport_header include/linux/skbuff.h:2493 [inline] tun_get_user+0x2cfe/0x3ff0 drivers/net/tun.c:1940 tun_chr_write_iter+0xbd/0x156 drivers/net/tun.c:2037 call_write_iter include/linux/fs.h:1872 [inline] do_iter_readv_writev+0x5fd/0x900 fs/read_write.c:693 do_iter_write fs/read_write.c:970 [inline] do_iter_write+0x184/0x610 fs/read_write.c:951 vfs_writev+0x1b3/0x2f0 fs/read_write.c:1015 do_writev+0x15b/0x330 fs/read_write.c:1058 __do_sys_writev fs/read_write.c:1131 [inline] __se_sys_writev fs/read_write.c:1128 [inline] __x64_sys_writev+0x75/0xb0 fs/read_write.c:1128 do_syscall_64+0x103/0x670 arch/x86/entry/common.c:298 entry_SYSCALL_64_after_hwframe+0x49/0xbe Fixes: d58e468b1112 ("flow_dissector: implements flow dissector BPF hook") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Cc: Petar Penkov <ppenkov@google.com> Cc: Stanislav Fomichev <sdf@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16vrf: sit mtu should not be updated when vrf netdev is the linkStephen Suryaputra
[ Upstream commit ff6ab32bd4e073976e4d8797b4d514a172cfe6cb ] VRF netdev mtu isn't typically set and have an mtu of 65536. When the link of a tunnel is set, the tunnel mtu is changed from 1480 to the link mtu minus tunnel header. In the case of VRF netdev is the link, then the tunnel mtu becomes 65516. So, fix it by not setting the tunnel mtu in this case. Signed-off-by: Stephen Suryaputra <ssuryaextr@gmail.com> Reviewed-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16vlan: disable SIOCSHWTSTAMP in containerHangbin Liu
[ Upstream commit 873017af778439f2f8e3d87f28ddb1fcaf244a76 ] With NET_ADMIN enabled in container, a normal user could be mapped to root and is able to change the real device's rx filter via ioctl on vlan, which would affect the other ptp process on host. Fix it by disabling SIOCSHWTSTAMP in container. Fixes: a6111d3c93d0 ("vlan: Pass SIOC[SG]HWTSTAMP ioctls to real device") Signed-off-by: Hangbin Liu <liuhangbin@gmail.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16tipc: fix hanging clients using poll with EPOLLOUT flagParthasarathy Bhuvaragan
[ Upstream commit ff946833b70e0c7f93de9a3f5b329b5ae2287b38 ] commit 517d7c79bdb398 ("tipc: fix hanging poll() for stream sockets") introduced a regression for clients using non-blocking sockets. After the commit, we send EPOLLOUT event to the client even in TIPC_CONNECTING state. This causes the subsequent send() to fail with ENOTCONN, as the socket is still not in TIPC_ESTABLISHED state. In this commit, we: - improve the fix for hanging poll() by replacing sk_data_ready() with sk_state_change() to wake up all clients. - revert the faulty updates introduced by commit 517d7c79bdb398 ("tipc: fix hanging poll() for stream sockets"). Fixes: 517d7c79bdb398 ("tipc: fix hanging poll() for stream sockets") Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@gmail.com> Acked-by: Jon Maloy <jon.maloy@ericsson.se> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16packet: Fix error path in packet_initYueHaibing
[ Upstream commit 36096f2f4fa05f7678bc87397665491700bae757 ] kernel BUG at lib/list_debug.c:47! invalid opcode: 0000 [#1 CPU: 0 PID: 12914 Comm: rmmod Tainted: G W 5.1.0+ #47 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014 RIP: 0010:__list_del_entry_valid+0x53/0x90 Code: 48 8b 32 48 39 fe 75 35 48 8b 50 08 48 39 f2 75 40 b8 01 00 00 00 5d c3 48 89 fe 48 89 c2 48 c7 c7 18 75 fe 82 e8 cb 34 78 ff <0f> 0b 48 89 fe 48 c7 c7 50 75 fe 82 e8 ba 34 78 ff 0f 0b 48 89 f2 RSP: 0018:ffffc90001c2fe40 EFLAGS: 00010286 RAX: 000000000000004e RBX: ffffffffa0184000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: ffff888237a17788 RDI: 00000000ffffffff RBP: ffffc90001c2fe40 R08: 0000000000000000 R09: 0000000000000000 R10: ffffc90001c2fe10 R11: 0000000000000000 R12: 0000000000000000 R13: ffffc90001c2fe50 R14: ffffffffa0184000 R15: 0000000000000000 FS: 00007f3d83634540(0000) GS:ffff888237a00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000555c350ea818 CR3: 0000000231677000 CR4: 00000000000006f0 Call Trace: unregister_pernet_operations+0x34/0x120 unregister_pernet_subsys+0x1c/0x30 packet_exit+0x1c/0x369 [af_packet __x64_sys_delete_module+0x156/0x260 ? lockdep_hardirqs_on+0x133/0x1b0 ? do_syscall_64+0x12/0x1f0 do_syscall_64+0x6e/0x1f0 entry_SYSCALL_64_after_hwframe+0x49/0xbe When modprobe af_packet, register_pernet_subsys fails and does a cleanup, ops->list is set to LIST_POISON1, but the module init is considered to success, then while rmmod it, BUG() is triggered in __list_del_entry_valid which is called from unregister_pernet_subsys. This patch fix error handing path in packet_init to avoid possilbe issue if some error occur. Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: YueHaibing <yuehaibing@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16net: dsa: Fix error cleanup path in dsa_init_moduleYueHaibing
[ Upstream commit 68be930249d051fd54d3d99156b3dcadcb2a1f9b ] BUG: unable to handle kernel paging request at ffffffffa01c5430 PGD 3270067 P4D 3270067 PUD 3271063 PMD 230bc5067 PTE 0 Oops: 0000 [#1 CPU: 0 PID: 6159 Comm: modprobe Not tainted 5.1.0+ #33 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014 RIP: 0010:raw_notifier_chain_register+0x16/0x40 Code: 63 f8 66 90 e9 5d ff ff ff 90 90 90 90 90 90 90 90 90 90 90 55 48 8b 07 48 89 e5 48 85 c0 74 1c 8b 56 10 3b 50 10 7e 07 eb 12 <39> 50 10 7c 0d 48 8d 78 08 48 8b 40 08 48 85 c0 75 ee 48 89 46 08 RSP: 0018:ffffc90001c33c08 EFLAGS: 00010282 RAX: ffffffffa01c5420 RBX: ffffffffa01db420 RCX: 4fcef45928070a8b RDX: 0000000000000000 RSI: ffffffffa01db420 RDI: ffffffffa01b0068 RBP: ffffc90001c33c08 R08: 000000003e0a33d0 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000094443661 R12: ffff88822c320700 R13: ffff88823109be80 R14: 0000000000000000 R15: ffffc90001c33e78 FS: 00007fab8bd08540(0000) GS:ffff888237a00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffffffffa01c5430 CR3: 00000002297ea000 CR4: 00000000000006f0 Call Trace: register_netdevice_notifier+0x43/0x250 ? 0xffffffffa01e0000 dsa_slave_register_notifier+0x13/0x70 [dsa_core ? 0xffffffffa01e0000 dsa_init_module+0x2e/0x1000 [dsa_core do_one_initcall+0x6c/0x3cc ? do_init_module+0x22/0x1f1 ? rcu_read_lock_sched_held+0x97/0xb0 ? kmem_cache_alloc_trace+0x325/0x3b0 do_init_module+0x5b/0x1f1 load_module+0x1db1/0x2690 ? m_show+0x1d0/0x1d0 __do_sys_finit_module+0xc5/0xd0 __x64_sys_finit_module+0x15/0x20 do_syscall_64+0x6b/0x1d0 entry_SYSCALL_64_after_hwframe+0x49/0xbe Cleanup allocated resourses if there are errors, otherwise it will trgger memleak. Fixes: c9eb3e0f8701 ("net: dsa: Add support for learning FDB through notification") Signed-off-by: YueHaibing <yuehaibing@huawei.com> Reviewed-by: Vivien Didelot <vivien.didelot@gmail.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16ipv4: Fix raw socket lookup for local trafficDavid Ahern
[ Upstream commit 19e4e768064a87b073a4b4c138b55db70e0cfb9f ] inet_iif should be used for the raw socket lookup. inet_iif considers rt_iif which handles the case of local traffic. As it stands, ping to a local address with the '-I <dev>' option fails ever since ping was changed to use SO_BINDTODEVICE instead of cmsg + IP_PKTINFO. IPv6 works fine. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16fib_rules: return 0 directly if an exactly same rule exists when NLM_F_EXCL ↵Hangbin Liu
not supplied [ Upstream commit e9919a24d3022f72bcadc407e73a6ef17093a849 ] With commit 153380ec4b9 ("fib_rules: Added NLM_F_EXCL support to fib_nl_newrule") we now able to check if a rule already exists. But this only works with iproute2. For other tools like libnl, NetworkManager, it still could add duplicate rules with only NLM_F_CREATE flag, like [localhost ~ ]# ip rule 0: from all lookup local 32766: from all lookup main 32767: from all lookup default 100000: from 192.168.7.5 lookup 5 100000: from 192.168.7.5 lookup 5 As it doesn't make sense to create two duplicate rules, let's just return 0 if the rule exists. Fixes: 153380ec4b9 ("fib_rules: Added NLM_F_EXCL support to fib_nl_newrule") Reported-by: Thomas Haller <thaller@redhat.com> Signed-off-by: Hangbin Liu <liuhangbin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16bridge: Fix error path for kobject_init_and_add()Tobin C. Harding
[ Upstream commit bdfad5aec1392b93495b77b864d58d7f101dc1c1 ] Currently error return from kobject_init_and_add() is not followed by a call to kobject_put(). This means there is a memory leak. We currently set p to NULL so that kfree() may be called on it as a noop, the code is arguably clearer if we move the kfree() up closer to where it is called (instead of after goto jump). Remove a goto label 'err1' and jump to call to kobject_put() in error return from kobject_init_and_add() fixing the memory leak. Re-name goto label 'put_back' to 'err1' now that we don't use err1, following current nomenclature (err1, err2 ...). Move call to kfree out of the error code at bottom of function up to closer to where memory was allocated. Add comment to clarify call to kfree(). Signed-off-by: Tobin C. Harding <tobin@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16net: sched: fix cleanup NULL pointer exception in act_mirrJohn Hurley
[ Upstream commit 064c5d6881e897077639e04973de26440ee205e6 ] A new mirred action is created by the tcf_mirred_init function. This contains a list head struct which is inserted into a global list on successful creation of a new action. However, after a creation, it is still possible to error out and call the tcf_idr_release function. This, in turn, calls the act_mirr cleanup function via __tcf_idr_release and __tcf_action_put. This cleanup function tries to delete the list entry which is as yet uninitialised, leading to a NULL pointer exception. Fix this by initialising the list entry on creation of a new action. Bug report: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 PGD 8000000840c73067 P4D 8000000840c73067 PUD 858dcc067 PMD 0 Oops: 0002 [#1] SMP PTI CPU: 32 PID: 5636 Comm: handler194 Tainted: G OE 5.0.0+ #186 Hardware name: Dell Inc. PowerEdge R730/0599V5, BIOS 1.3.6 06/03/2015 RIP: 0010:tcf_mirred_release+0x42/0xa7 [act_mirred] Code: f0 90 39 c0 e8 52 04 57 c8 48 c7 c7 b8 80 39 c0 e8 94 fa d4 c7 48 8b 93 d0 00 00 00 48 8b 83 d8 00 00 00 48 c7 c7 f0 90 39 c0 <48> 89 42 08 48 89 10 48 b8 00 01 00 00 00 00 ad de 48 89 83 d0 00 RSP: 0018:ffffac4aa059f688 EFLAGS: 00010282 RAX: 0000000000000000 RBX: ffff9dcd1b214d00 RCX: 0000000000000000 RDX: 0000000000000000 RSI: ffff9dcd1fa165f8 RDI: ffffffffc03990f0 RBP: ffff9dccf9c7af80 R08: 0000000000000a3b R09: 0000000000000000 R10: ffff9dccfa11f420 R11: 0000000000000000 R12: 0000000000000001 R13: ffff9dcd16b433c0 R14: ffff9dcd1b214d80 R15: 0000000000000000 FS: 00007f441bfff700(0000) GS:ffff9dcd1fa00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000008 CR3: 0000000839e64004 CR4: 00000000001606e0 Call Trace: tcf_action_cleanup+0x59/0xca __tcf_action_put+0x54/0x6b __tcf_idr_release.cold.33+0x9/0x12 tcf_mirred_init.cold.20+0x22e/0x3b0 [act_mirred] tcf_action_init_1+0x3d0/0x4c0 tcf_action_init+0x9c/0x130 tcf_exts_validate+0xab/0xc0 fl_change+0x1ca/0x982 [cls_flower] tc_new_tfilter+0x647/0x8d0 ? load_balance+0x14b/0x9e0 rtnetlink_rcv_msg+0xe3/0x370 ? __switch_to_asm+0x40/0x70 ? __switch_to_asm+0x34/0x70 ? _cond_resched+0x15/0x30 ? __kmalloc_node_track_caller+0x1d4/0x2b0 ? rtnl_calcit.isra.31+0xf0/0xf0 netlink_rcv_skb+0x49/0x110 netlink_unicast+0x16f/0x210 netlink_sendmsg+0x1df/0x390 sock_sendmsg+0x36/0x40 ___sys_sendmsg+0x27b/0x2c0 ? futex_wake+0x80/0x140 ? do_futex+0x2b9/0xac0 ? ep_scan_ready_list.constprop.22+0x1f2/0x210 ? ep_poll+0x7a/0x430 __sys_sendmsg+0x47/0x80 do_syscall_64+0x55/0x100 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Fixes: 4e232818bd32 ("net: sched: act_mirred: remove dependency on rtnl lock") Signed-off-by: John Hurley <john.hurley@netronome.com> Reviewed-by: Jakub Kicinski <jakub.kicinski@netronome.com> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com>
2019-05-16bpf: only test gso type on gso packetsWillem de Bruijn
[ Upstream commit 4c3024debf62de4c6ac6d3cb4c0063be21d4f652 ] BPF can adjust gso only for tcp bytestreams. Fail on other gso types. But only on gso packets. It does not touch this field if !gso_size. Fixes: b90efd225874 ("bpf: only adjust gso_size on bytestream protocols") Signed-off-by: Willem de Bruijn <willemb@google.com> Acked-by: Yonghong Song <yhs@fb.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com>
2019-05-16netfilter: fix nf_l4proto_log_invalid to log invalid packetsAndrei Vagin
[ Upstream commit d48668052b2603b6262459625c86108c493588dd ] It doesn't log a packet if sysctl_log_invalid isn't equal to protonum OR sysctl_log_invalid isn't equal to IPPROTO_RAW. This sentence is always true. I believe we need to replace OR to AND. Cc: Florian Westphal <fw@strlen.de> Fixes: c4f3db1595827 ("netfilter: conntrack: add and use nf_l4proto_log_invalid") Signed-off-by: Andrei Vagin <avagin@gmail.com> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16netfilter: never get/set skb->tstampFlorian Westphal
[ Upstream commit 916f6efae62305796e012e7c3a7884a267cbacbf ] setting net.netfilter.nf_conntrack_timestamp=1 breaks xmit with fq scheduler. skb->tstamp might be "refreshed" using ktime_get_real(), but fq expects CLOCK_MONOTONIC. This patch removes all places in netfilter that check/set skb->tstamp: 1. To fix the bogus "start" time seen with conntrack timestamping for outgoing packets, never use skb->tstamp and always use current time. 2. In nfqueue and nflog, only use skb->tstamp for incoming packets, as determined by current hook (prerouting, input, forward). 3. xt_time has to use system clock as well rather than skb->tstamp. We could still use skb->tstamp for prerouting/input/foward, but I see no advantage to make this conditional. Fixes: fb420d5d91c1 ("tcp/fq: move back to CLOCK_MONOTONIC") Cc: Eric Dumazet <edumazet@google.com> Reported-by: Michal Soltys <soltys@ziu.info> Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16netfilter: nat: fix icmp id randomizationFlorian Westphal
[ Upstream commit 5bdac418f33f60b07a34e01e722889140ee8fac9 ] Sven Auhagen reported that a 2nd ping request will fail if 'fully-random' mode is used. Reason is that if no proto information is given, min/max are both 0, so we set the icmp id to 0 instead of chosing a random value between 0 and 65535. Update test case as well to catch this, without fix this yields: [..] ERROR: cannot ping ns1 from ns2 with ip masquerade fully-random (attempt 2) ERROR: cannot ping ns1 from ns2 with ipv6 masquerade fully-random (attempt 2) ... becaus 2nd ping clashes with existing 'id 0' icmp conntrack and gets dropped. Fixes: 203f2e78200c27e ("netfilter: nat: remove l4proto->unique_tuple") Reported-by: Sven Auhagen <sven.auhagen@voleatech.de> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16netfilter: nf_tables: prevent shift wrap in nft_chain_parse_hook()Dan Carpenter
[ Upstream commit 33d1c018179d0a30c39cc5f1682b77867282694b ] I believe that "hook->num" can be up to UINT_MAX. Shifting more than 31 bits would is undefined in C but in practice it would lead to shift wrapping. That would lead to an array overflow in nf_tables_addchain(): ops->hook = hook.type->hooks[ops->hooknum]; Fixes: fe19c04ca137 ("netfilter: nf_tables: remove nhooks field from struct nft_af_info") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16netfilter: ctnetlink: don't use conntrack/expect object addresses as idFlorian Westphal
[ Upstream commit 3c79107631db1f7fd32cf3f7368e4672004a3010 ] else, we leak the addresses to userspace via ctnetlink events and dumps. Compute an ID on demand based on the immutable parts of nf_conn struct. Another advantage compared to using an address is that there is no immediate re-use of the same ID in case the conntrack entry is freed and reallocated again immediately. Fixes: 3583240249ef ("[NETFILTER]: nf_conntrack_expect: kill unique ID") Fixes: 7f85f914721f ("[NETFILTER]: nf_conntrack: kill unique ID") Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16ipvs: do not schedule icmp errors from tunnelsJulian Anastasov
[ Upstream commit 0261ea1bd1eb0da5c0792a9119b8655cf33c80a3 ] We can receive ICMP errors from client or from tunneling real server. While the former can be scheduled to real server, the latter should not be scheduled, they are decapsulated only when existing connection is found. Fixes: 6044eeffafbe ("ipvs: attempt to schedule icmp packets") Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16nl80211: Add NL80211_FLAG_CLEAR_SKB flag for other NL commandsSunil Dutt
[ Upstream commit d6db02a88a4aaa1cd7105137c67ddec7f3bdbc05 ] This commit adds NL80211_FLAG_CLEAR_SKB flag to other NL commands that carry key data to ensure they do not stick around on heap after the SKB is freed. Also introduced this flag for NL80211_CMD_VENDOR as there are sub commands which configure the keys. Signed-off-by: Sunil Dutt <usdutt@codeaurora.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16mac80211: fix memory accounting with A-MSDU aggregationFelix Fietkau
[ Upstream commit eb9b64e3a9f8483e6e54f4e03b2ae14ae5db2690 ] skb->truesize can change due to memory reallocation or when adding extra fragments. Adjust fq->memory_usage accordingly Signed-off-by: Felix Fietkau <nbd@nbd.name> Acked-by: Toke Høiland-Jørgensen <toke@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16cfg80211: Handle WMM rules in regulatory domain intersectionIlan Peer
[ Upstream commit 08a75a887ee46828b54600f4bb7068d872a5edd5 ] The support added for regulatory WMM rules did not handle the case of regulatory domain intersections. Fix it. Signed-off-by: Ilan Peer <ilan.peer@intel.com> Fixes: 230ebaa189af ("cfg80211: read wmm rules from regulatory database") Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16mac80211: Increase MAX_MSG_LENAndrei Otcheretianski
[ Upstream commit 78be2d21cc1cd3069c6138dcfecec62583130171 ] Looks that 100 chars isn't enough for messages, as we keep getting warnings popping from different places due to message shortening. Instead of trying to shorten the prints, just increase the buffer size. Signed-off-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16mac80211: fix unaligned access in mesh table hash functionFelix Fietkau
[ Upstream commit 40586e3fc400c00c11151804dcdc93f8c831c808 ] The pointer to the last four bytes of the address is not guaranteed to be aligned, so we need to use __get_unaligned_cpu32 here Signed-off-by: Felix Fietkau <nbd@nbd.name> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-10Bluetooth: Fix not initializing L2CAP tx_creditsLuiz Augusto von Dentz
commit ba8f5289f706aed94cc95b15cc5b89e22062f61f upstream. l2cap_le_flowctl_init was reseting the tx_credits which works only for outgoing connection since that set the tx_credits on the response, for incoming connections that was not the case which leaves the channel without any credits causing it to be suspended. Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Cc: stable@vger.kernel.org # 4.20+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-10Bluetooth: Align minimum encryption key size for LE and BR/EDR connectionsMarcel Holtmann
commit d5bb334a8e171b262e48f378bd2096c0ea458265 upstream. The minimum encryption key size for LE connections is 56 bits and to align LE with BR/EDR, enforce 56 bits of minimum encryption key size for BR/EDR connections as well. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-10Bluetooth: hidp: fix buffer overflowYoung Xiao
commit a1616a5ac99ede5d605047a9012481ce7ff18b16 upstream. Struct ca is copied from userspace. It is not checked whether the "name" field is NULL terminated, which allows local users to obtain potentially sensitive information from kernel stack memory, via a HIDPCONNADD command. This vulnerability is similar to CVE-2011-1079. Signed-off-by: Young Xiao <YangX92@hotmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-08mac80211: Honor SW_CRYPTO_CONTROL for unicast keys in AP VLAN modeAlexander Wetzel
commit 78ad2341521d5ea96cb936244ed4c4c4ef9ec13b upstream. Restore SW_CRYPTO_CONTROL operation on AP_VLAN interfaces for unicast keys, the original override was intended to be done for group keys as those are treated specially by mac80211 and would always have been rejected. Now the situation is that AP_VLAN support must be enabled by the driver if it can support it (meaning it can support software crypto GTK TX). Thus, also simplify the code - if we get here with AP_VLAN and non- pairwise key, software crypto must be used (driver doesn't know about the interface) and can be used (driver must've advertised AP_VLAN if it also uses SW_CRYPTO_CONTROL). Fixes: db3bdcb9c3ff ("mac80211: allow AP_VLAN operation on crypto controlled devices") Signed-off-by: Alexander Wetzel <alexander@wetzel-home.de> [rewrite commit message] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-08batman-adv: fix warning in function batadv_v_elp_get_throughputAnders Roxell
[ Upstream commit ca8c3b922e7032aff6cc3fd05548f4df1f3df90e ] When CONFIG_CFG80211 isn't enabled the compiler correcly warns about 'sinfo.pertid' may be unused. It can also happen for other error conditions that it not warn about. net/batman-adv/bat_v_elp.c: In function ‘batadv_v_elp_get_throughput.isra.0’: include/net/cfg80211.h:6370:13: warning: ‘sinfo.pertid’ may be used uninitialized in this function [-Wmaybe-uninitialized] kfree(sinfo->pertid); ~~~~~^~~~~~~~ Rework so that we only release '&sinfo' if cfg80211_get_station returns zero. Fixes: 7d652669b61d ("batman-adv: release station info tidstats") Signed-off-by: Anders Roxell <anders.roxell@linaro.org> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
2019-05-08batman-adv: Reduce tt_global hash refcnt only for removed entrySven Eckelmann
[ Upstream commit f131a56880d10932931e74773fb8702894a94a75 ] The batadv_hash_remove is a function which searches the hashtable for an entry using a needle, a hashtable bucket selection function and a compare function. It will lock the bucket list and delete an entry when the compare function matches it with the needle. It returns the pointer to the hlist_node which matches or NULL when no entry matches the needle. The batadv_tt_global_free is not itself protected in anyway to avoid that any other function is modifying the hashtable between the search for the entry and the call to batadv_hash_remove. It can therefore happen that the entry either doesn't exist anymore or an entry was deleted which is not the same object as the needle. In such an situation, the reference counter (for the reference stored in the hashtable) must not be reduced for the needle. Instead the reference counter of the actually removed entry has to be reduced. Otherwise the reference counter will underflow and the object might be freed before all its references were dropped. The kref helpers reported this problem as: refcount_t: underflow; use-after-free. Fixes: 7683fdc1e886 ("batman-adv: protect the local and the global trans-tables with rcu") Reported-by: Martin Weinelt <martin@linuxlounge.net> Signed-off-by: Sven Eckelmann <sven@narfation.org> Acked-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
2019-05-08batman-adv: Reduce tt_local hash refcnt only for removed entrySven Eckelmann
[ Upstream commit 3d65b9accab4a7ed5038f6df403fbd5e298398c7 ] The batadv_hash_remove is a function which searches the hashtable for an entry using a needle, a hashtable bucket selection function and a compare function. It will lock the bucket list and delete an entry when the compare function matches it with the needle. It returns the pointer to the hlist_node which matches or NULL when no entry matches the needle. The batadv_tt_local_remove is not itself protected in anyway to avoid that any other function is modifying the hashtable between the search for the entry and the call to batadv_hash_remove. It can therefore happen that the entry either doesn't exist anymore or an entry was deleted which is not the same object as the needle. In such an situation, the reference counter (for the reference stored in the hashtable) must not be reduced for the needle. Instead the reference counter of the actually removed entry has to be reduced. Otherwise the reference counter will underflow and the object might be freed before all its references were dropped. The kref helpers reported this problem as: refcount_t: underflow; use-after-free. Fixes: ef72706a0543 ("batman-adv: protect tt_local_entry from concurrent delete events") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
2019-05-08batman-adv: Reduce claim hash refcnt only for removed entrySven Eckelmann
[ Upstream commit 4ba104f468bbfc27362c393815d03aa18fb7a20f ] The batadv_hash_remove is a function which searches the hashtable for an entry using a needle, a hashtable bucket selection function and a compare function. It will lock the bucket list and delete an entry when the compare function matches it with the needle. It returns the pointer to the hlist_node which matches or NULL when no entry matches the needle. The batadv_bla_del_claim is not itself protected in anyway to avoid that any other function is modifying the hashtable between the search for the entry and the call to batadv_hash_remove. It can therefore happen that the entry either doesn't exist anymore or an entry was deleted which is not the same object as the needle. In such an situation, the reference counter (for the reference stored in the hashtable) must not be reduced for the needle. Instead the reference counter of the actually removed entry has to be reduced. Otherwise the reference counter will underflow and the object might be freed before all its references were dropped. The kref helpers reported this problem as: refcount_t: underflow; use-after-free. Fixes: 23721387c409 ("batman-adv: add basic bridge loop avoidance code") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
2019-05-08mac80211: don't attempt to rename ERR_PTR() debugfs dirsJohannes Berg
commit 517879147493a5e1df6b89a50f708f1133fcaddb upstream. We need to dereference the directory to get its parent to be able to rename it, so it's clearly not safe to try to do this with ERR_PTR() pointers. Skip in this case. It seems that this is most likely what was causing the report by syzbot, but I'm not entirely sure as it didn't come with a reproducer this time. Cc: stable@vger.kernel.org Reported-by: syzbot+4ece1a28b8f4730547c9@syzkaller.appspotmail.com Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-05net/tls: fix copy to fragments in reencryptJakub Kicinski
[ Upstream commit eb3d38d5adb520435d4e4af32529ccb13ccc9935 ] Fragments may contain data from other records so we have to account for that when we calculate the destination and max length of copy we can perform. Note that 'offset' is the offset within the message, so it can't be passed as offset within the frag.. Here skb_store_bits() would have realised the call is wrong and simply not copy data. Fixes: 4799ac81e52a ("tls: Add rx inline crypto offload") Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com> Reviewed-by: John Hurley <john.hurley@netronome.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-05net/tls: don't copy negative amounts of data in reencryptJakub Kicinski
[ Upstream commit 97e1caa517e22d62a283b876fb8aa5f4672c83dd ] There is no guarantee the record starts before the skb frags. If we don't check for this condition copy amount will get negative, leading to reads and writes to random memory locations. Familiar hilarity ensues. Fixes: 4799ac81e52a ("tls: Add rx inline crypto offload") Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com> Reviewed-by: John Hurley <john.hurley@netronome.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
