path: root/net
2014-06-05Merge branch 'linux-3.10.40' into rel-21Ishan Mittal
Bug 200004122 Conflicts: drivers/cpufreq/cpufreq.c drivers/regulator/core.c sound/soc/codecs/max98090.c Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-05-29Merge branch 'android-3.10' into rel-21Ishan Mittal
Bug 200004122 Bug 1511804 This merge takes AOSP commits from android-3.10 branch Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-05-13mac80211: exclude AP_VLAN interfaces from tx power calculationFelix Fietkau
commit 764152ff66f4a8be1f9d7981e542ffdaa5bd7aff upstream. Their power value is initialized to zero. This patch fixes an issue where the configured power drops to the minimum value when AP_VLAN interfaces are created/removed. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13mac80211: fix software remain-on-channel implementationJohannes Berg
commit 115b943a6ea12656088fa1ff6634c0d30815e55b upstream. Jouni reported that when doing off-channel transmissions mixed with on-channel transmissions, the on-channel ones ended up on the off-channel in some cases. The reason for that is that during the refactoring of the off- channel code, I lost the part that stopped all activity and as a consequence the on-channel frames (including data frames) were no longer queued but would be transmitted on the temporary channel. Fix this by simply restoring the lost activity stop call. Fixes: 2eb278e083549 ("mac80211: unify SW/offload remain-on-channel") Reported-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13mac80211: fix WPA with VLAN on AP side with ps-sta againMichael Braun
commit 112c44b2df0984121a52fbda89425843b8e1a457 upstream. commit de74a1d9032f4d37ea453ad2a647e1aff4cd2591 "mac80211: fix WPA with VLAN on AP side with ps-sta" fixed an issue where queued multicast packets would be sent out encrypted with the key of an other bss. commit "7cbf9d017dbb5e3276de7d527925d42d4c11e732" "mac80211: fix oops on mesh PS broadcast forwarding" essentially reverted it, because vif.type cannot be AP_VLAN due to the check to vif.type in ieee80211_get_buffered_bc before. As the later commit intended to fix the MESH case, fix it by checking for IFTYPE_AP instead of IFTYPE_AP_VLAN. Fixes: 7cbf9d017dbb ("mac80211: fix oops on mesh PS broadcast forwarding") Signed-off-by: Michael Braun <michael-dev@fami-braun.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06nfsd: check passed socket's net matches NFSd superblock's oneStanislav Kinsbursky
commit 3064639423c48d6e0eb9ecc27c512a58e38c6c57 upstream. There could be a case, when NFSd file system is mounted in network, different to socket's one, like below: "ip netns exec" creates new network and mount namespace, which duplicates NFSd mount point, created in init_net context. And thus NFS server stop in nested network context leads to RPCBIND client destruction in init_net. Then, on NFSd start in nested network context, rpc.nfsd process creates socket in nested net and passes it into "write_ports", which leads to RPCBIND sockets creation in init_net context because of the same reason (NFSd monut point was created in init_net context). An attempt to register passed socket in nested net leads to panic, because no RPCBIND client present in nexted network namespace. This patch add check that passed socket's net matches NFSd superblock's one. And returns -EINVAL error to user psace otherwise. v2: Put socket on exit. Reported-by: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26Bluetooth: Fix removing Long Term KeyClaudio Takahasi
commit 5981a8821b774ada0be512fd9bad7c241e17657e upstream. This patch fixes authentication failure on LE link re-connection when BlueZ acts as slave (peripheral). LTK is removed from the internal list after its first use causing PIN or Key missing reply when re-connecting the link. The LE Long Term Key Request event indicates that the master is attempting to encrypt or re-encrypt the link. Pre-condition: BlueZ host paired and running as slave. How to reproduce(master): 1) Establish an ACL LE encrypted link 2) Disconnect the link 3) Try to re-establish the ACL LE encrypted link (fails) > HCI Event: LE Meta Event (0x3e) plen 19 LE Connection Complete (0x01) Status: Success (0x00) Handle: 64 Role: Slave (0x01) ... @ Device Connected: 00:02:72:DC:29:C9 (1) flags 0x0000 > HCI Event: LE Meta Event (0x3e) plen 13 LE Long Term Key Request (0x05) Handle: 64 Random number: 875be18439d9aa37 Encryption diversifier: 0x76ed < HCI Command: LE Long Term Key Request Reply (0x08|0x001a) plen 18 Handle: 64 Long term key: 2aa531db2fce9f00a0569c7d23d17409 > HCI Event: Command Complete (0x0e) plen 6 LE Long Term Key Request Reply (0x08|0x001a) ncmd 1 Status: Success (0x00) Handle: 64 > HCI Event: Encryption Change (0x08) plen 4 Status: Success (0x00) Handle: 64 Encryption: Enabled with AES-CCM (0x01) ... @ Device Disconnected: 00:02:72:DC:29:C9 (1) reason 3 < HCI Command: LE Set Advertise Enable (0x08|0x000a) plen 1 Advertising: Enabled (0x01) > HCI Event: Command Complete (0x0e) plen 4 LE Set Advertise Enable (0x08|0x000a) ncmd 1 Status: Success (0x00) > HCI Event: LE Meta Event (0x3e) plen 19 LE Connection Complete (0x01) Status: Success (0x00) Handle: 64 Role: Slave (0x01) ... @ Device Connected: 00:02:72:DC:29:C9 (1) flags 0x0000 > HCI Event: LE Meta Event (0x3e) plen 13 LE Long Term Key Request (0x05) Handle: 64 Random number: 875be18439d9aa37 Encryption diversifier: 0x76ed < HCI Command: LE Long Term Key Request Neg Reply (0x08|0x001b) plen 2 Handle: 64 > HCI Event: Command Complete (0x0e) plen 6 LE Long Term Key Request Neg Reply (0x08|0x001b) ncmd 1 Status: Success (0x00) Handle: 64 > HCI Event: Disconnect Complete (0x05) plen 4 Status: Success (0x00) Handle: 64 Reason: Authentication Failure (0x05) @ Device Disconnected: 00:02:72:DC:29:C9 (1) reason 0 Signed-off-by: Claudio Takahasi <claudio.takahasi@openbossa.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-24net: ipv4: current group_info should be put after using.Wang, Xiaoming
Plug a group_info refcount leak in ping_init. group_info is only needed during initialization and the code failed to release the reference on exit. While here move grabbing the reference to a place where it is actually needed. Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com> Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com> Signed-off-by: xiaoming wang <xiaoming.wang@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-24nf: Remove compilation error caused byRuchi Kandoi
e8430cbed3ef15fdb1ac26cfd020e010aa5f1c35 Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
2014-04-22nf: IDLETIMER: time-stamp and suspend/resume handling.Ruchi Kandoi
Message notifications contains an additional timestamp field in nano seconds. The expiry time for the timers are modified during suspend/resume. If timer was supposed to expire while the system is suspended then a notification is sent when it resumes with the timestamp of the scheduled expiry. Removes the race condition for multiple work scheduled. Bug: 13247811 Change-Id: I752c5b00225fe7085482819f975cc0eb5af89bff Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
2014-04-14rds: prevent dereference of a NULL device in rds_iw_laddr_checkSasha Levin
[ Upstream commit bf39b4247b8799935ea91d90db250ab608a58e50 ] Binding might result in a NULL device which is later dereferenced without checking. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14ipv6: some ipv6 statistic counters failed to disable bhHannes Frederic Sowa
[ Upstream commit 43a43b6040165f7b40b5b489fe61a4cb7f8c4980 ] After commit c15b1ccadb323ea ("ipv6: move DAD and addrconf_verify processing to workqueue") some counters are now updated in process context and thus need to disable bh before doing so, otherwise deadlocks can happen on 32-bit archs. Fabio Estevam noticed this while while mounting a NFS volume on an ARM board. As a compensation for missing this I looked after the other *_STATS_BH and found three other calls which need updating: 1) icmp6_send: ip6_fragment -> icmpv6_send -> icmp6_send (error handling) 2) ip6_push_pending_frames: rawv6_sendmsg -> rawv6_push_pending_frames -> ... (only in case of icmp protocol with raw sockets in error handling) 3) ping6_v6_sendmsg (error handling) Fixes: c15b1ccadb323ea ("ipv6: move DAD and addrconf_verify processing to workqueue") Reported-by: Fabio Estevam <festevam@gmail.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14vlan: Set hard_header_len according to available accelerationVlad Yasevich
[ Upstream commit fc0d48b8fb449ca007b2057328abf736cb516168 ] Currently, if the card supports CTAG acceleration we do not account for the vlan header even if we are configuring an 8021AD vlan. This may not be best since we'll do software tagging for 8021AD which will cause data copy on skb head expansion Configure the length based on available hw offload capabilities and vlan protocol. CC: Patrick McHardy <kaber@trash.net> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14netpoll: fix the skb check in pkt_is_nsLi RongQing
[ Not applicable upstream commit, the code here has been removed upstream. ] Neighbor Solicitation is ipv6 protocol, so we should check skb->protocol with ETH_P_IPV6 Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Cc: WANG Cong <amwang@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14ip6mr: fix mfc notification flagsNicolas Dichtel
[ Upstream commit f518338b16038beeb73e155e60d0f70beb9379f4 ] Commit 812e44dd1829 ("ip6mr: advertise new mfc entries via rtnl") reuses the function ip6mr_fill_mroute() to notify mfc events. But this function was used only for dump and thus was always setting the flag NLM_F_MULTI, which is wrong in case of a single notification. Libraries like libnl will wait forever for NLMSG_DONE. CC: Thomas Graf <tgraf@suug.ch> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14ipmr: fix mfc notification flagsNicolas Dichtel
[ Upstream commit 65886f439ab0fdc2dff20d1fa87afb98c6717472 ] Commit 8cd3ac9f9b7b ("ipmr: advertise new mfc entries via rtnl") reuses the function ipmr_fill_mroute() to notify mfc events. But this function was used only for dump and thus was always setting the flag NLM_F_MULTI, which is wrong in case of a single notification. Libraries like libnl will wait forever for NLMSG_DONE. CC: Thomas Graf <tgraf@suug.ch> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14rtnetlink: fix fdb notification flagsNicolas Dichtel
[ Upstream commit 1c104a6bebf3c16b6248408b84f91d09ac8a26b6 ] Commit 3ff661c38c84 ("net: rtnetlink notify events for FDB NTF_SELF adds and deletes") reuses the function nlmsg_populate_fdb_fill() to notify fdb events. But this function was used only for dump and thus was always setting the flag NLM_F_MULTI, which is wrong in case of a single notification. Libraries like libnl will wait forever for NLMSG_DONE. CC: Thomas Graf <tgraf@suug.ch> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14ipv6: ip6_append_data_mtu do not handle the mtu of the second fragment properlylucien
[ Upstream commit e367c2d03dba4c9bcafad24688fadb79dd95b218 ] In ip6_append_data_mtu(), when the xfrm mode is not tunnel(such as transport),the ipsec header need to be added in the first fragment, so the mtu will decrease to reserve space for it, then the second fragment come, the mtu should be turn back, as the commit 0c1833797a5a6ec23ea9261d979aa18078720b74 said. however, in the commit a493e60ac4bbe2e977e7129d6d8cbb0dd236be, it use *mtu = min(*mtu, ...) to change the mtu, which lead to the new mtu is alway equal with the first fragment's. and cannot turn back. when I test through ping6 -c1 -s5000 $ip (mtu=1280): ...frag (0|1232) ESP(spi=0x00002000,seq=0xb), length 1232 ...frag (1232|1216) ...frag (2448|1216) ...frag (3664|1216) ...frag (4880|164) which should be: ...frag (0|1232) ESP(spi=0x00001000,seq=0x1), length 1232 ...frag (1232|1232) ...frag (2464|1232) ...frag (3696|1232) ...frag (4928|116) so delete the min() when change back the mtu. Signed-off-by: Xin Long <lucien.xin@gmail.com> Fixes: 75a493e60ac4bb ("ipv6: ip6_append_data_mtu did not care about pmtudisc and frag_size") Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14ipv6: Avoid unnecessary temporary addresses being generatedHeiner Kallweit
[ Upstream commit ecab67015ef6e3f3635551dcc9971cf363cc1cd5 ] tmp_prefered_lft is an offset to ifp->tstamp, not now. Therefore age needs to be added to the condition. Age calculation in ipv6_create_tempaddr is different from the one in addrconf_verify and doesn't consider ADDRCONF_TIMER_FUZZ_MINUS. This can cause age in ipv6_create_tempaddr to be less than the one in addrconf_verify and therefore unnecessary temporary address to be generated. Use age calculation as in addrconf_modify to avoid this. Signed-off-by: Heiner Kallweit <heiner.kallweit@web.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14net: socket: error on a negative msg_namelenMatthew Leach
[ Upstream commit dbb490b96584d4e958533fb637f08b557f505657 ] When copying in a struct msghdr from the user, if the user has set the msg_namelen parameter to a negative value it gets clamped to a valid size due to a comparison between signed and unsigned values. Ensure the syscall errors when the user passes in a negative value. Signed-off-by: Matthew Leach <matthew.leach@arm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14tcp: tcp_release_cb() should release socket ownershipEric Dumazet
[ Upstream commit c3f9b01849ef3bc69024990092b9f42e20df7797 ] Lars Persson reported following deadlock : -000 |M:0x0:0x802B6AF8(asm) <-- arch_spin_lock -001 |tcp_v4_rcv(skb = 0x8BD527A0) <-- sk = 0x8BE6B2A0 -002 |ip_local_deliver_finish(skb = 0x8BD527A0) -003 |__netif_receive_skb_core(skb = 0x8BD527A0, ?) -004 |netif_receive_skb(skb = 0x8BD527A0) -005 |elk_poll(napi = 0x8C770500, budget = 64) -006 |net_rx_action(?) -007 |__do_softirq() -008 |do_softirq() -009 |local_bh_enable() -010 |tcp_rcv_established(sk = 0x8BE6B2A0, skb = 0x87D3A9E0, th = 0x814EBE14, ?) -011 |tcp_v4_do_rcv(sk = 0x8BE6B2A0, skb = 0x87D3A9E0) -012 |tcp_delack_timer_handler(sk = 0x8BE6B2A0) -013 |tcp_release_cb(sk = 0x8BE6B2A0) -014 |release_sock(sk = 0x8BE6B2A0) -015 |tcp_sendmsg(?, sk = 0x8BE6B2A0, ?, ?) -016 |sock_sendmsg(sock = 0x8518C4C0, msg = 0x87D8DAA8, size = 4096) -017 |kernel_sendmsg(?, ?, ?, ?, size = 4096) -018 |smb_send_kvec() -019 |smb_send_rqst(server = 0x87C4D400, rqst = 0x87D8DBA0) -020 |cifs_call_async() -021 |cifs_async_writev(wdata = 0x87FD6580) -022 |cifs_writepages(mapping = 0x852096E4, wbc = 0x87D8DC88) -023 |__writeback_single_inode(inode = 0x852095D0, wbc = 0x87D8DC88) -024 |writeback_sb_inodes(sb = 0x87D6D800, wb = 0x87E4A9C0, work = 0x87D8DD88) -025 |__writeback_inodes_wb(wb = 0x87E4A9C0, work = 0x87D8DD88) -026 |wb_writeback(wb = 0x87E4A9C0, work = 0x87D8DD88) -027 |wb_do_writeback(wb = 0x87E4A9C0, force_wait = 0) -028 |bdi_writeback_workfn(work = 0x87E4A9CC) -029 |process_one_work(worker = 0x8B045880, work = 0x87E4A9CC) -030 |worker_thread(__worker = 0x8B045880) -031 |kthread(_create = 0x87CADD90) -032 |ret_from_kernel_thread(asm) Bug occurs because __tcp_checksum_complete_user() enables BH, assuming it is running from softirq context. Lars trace involved a NIC without RX checksum support but other points are problematic as well, like the prequeue stuff. Problem is triggered by a timer, that found socket being owned by user. tcp_release_cb() should call tcp_write_timer_handler() or tcp_delack_timer_handler() in the appropriate context : BH disabled and socket lock held, but 'owned' field cleared, as if they were running from timer handlers. Fixes: 6f458dfb4092 ("tcp: improve latencies of timer triggered events") Reported-by: Lars Persson <lars.persson@axis.com> Tested-by: Lars Persson <lars.persson@axis.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14vlan: Set correct source MAC address with TX VLAN offload enabledPeter Boström
[ Upstream commit dd38743b4cc2f86be250eaf156cf113ba3dd531a ] With TX VLAN offload enabled the source MAC address for frames sent using the VLAN interface is currently set to the address of the real interface. This is wrong since the VLAN interface may be configured with a different address. The bug was introduced in commit 2205369a314e12fcec4781cc73ac9c08fc2b47de ("vlan: Fix header ops passthru when doing TX VLAN offload."). This patch sets the source address before calling the create function of the real interface. Signed-off-by: Peter Boström <peter.bostrom@netrounds.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14ipv6: don't set DST_NOCOUNT for remotely added routesSabrina Dubroca
[ Upstream commit c88507fbad8055297c1d1e21e599f46960cbee39 ] DST_NOCOUNT should only be used if an authorized user adds routes locally. In case of routes which are added on behalf of router advertisments this flag must not get used as it allows an unlimited number of routes getting added remotely. Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14ipv6: Fix exthdrs offload registration.Anton Nayshtut
[ Upstream commit d2d273ffabd315eecefce21a4391d44b6e156b73 ] Without this fix, ipv6_exthdrs_offload_init doesn't register IPPROTO_DSTOPTS offload, but returns 0 (as the IPPROTO_ROUTING registration actually succeeds). This then causes the ipv6_gso_segment to drop IPv6 packets with IPPROTO_DSTOPTS header. The issue detected and the fix verified by running MS HCK Offload LSO test on top of QEMU Windows guests, as this test sends IPv6 packets with IPPROTO_DSTOPTS. Signed-off-by: Anton Nayshtut <anton@swortex.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14net: unix: non blocking recvmsg() should not return -EINTREric Dumazet
[ Upstream commit de1443916791d75fdd26becb116898277bb0273f ] Some applications didn't expect recvmsg() on a non blocking socket could return -EINTR. This possibility was added as a side effect of commit b3ca9b02b00704 ("net: fix multithreaded signal handling in unix recv routines"). To hit this bug, you need to be a bit unlucky, as the u->readlock mutex is usually held for very small periods. Fixes: b3ca9b02b00704 ("net: fix multithreaded signal handling in unix recv routines") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Rainer Weikusat <rweikusat@mobileactivedefense.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14inet: frag: make sure forced eviction removes all fragsFlorian Westphal
[ Upstream commit e588e2f286ed7da011ed357c24c5b9a554e26595 ] Quoting Alexander Aring: While fragmentation and unloading of 6lowpan module I got this kernel Oops after few seconds: BUG: unable to handle kernel paging request at f88bbc30 [..] Modules linked in: ipv6 [last unloaded: 6lowpan] Call Trace: [<c012af4c>] ? call_timer_fn+0x54/0xb3 [<c012aef8>] ? process_timeout+0xa/0xa [<c012b66b>] run_timer_softirq+0x140/0x15f Problem is that incomplete frags are still around after unload; when their frag expire timer fires, we get crash. When a netns is removed (also done when unloading module), inet_frag calls the evictor with 'force' argument to purge remaining frags. The evictor loop terminates when accounted memory ('work') drops to 0 or the lru-list becomes empty. However, the mem accounting is done via percpu counters and may not be accurate, i.e. loop may terminate prematurely. Alter evictor to only stop once the lru list is empty when force is requested. Reported-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Reported-by: Alexander Aring <alex.aring@gmail.com> Tested-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14bridge: multicast: add sanity check for query source addressesLinus Lüssing
[ Upstream commit 6565b9eeef194afbb3beec80d6dd2447f4091f8c ] MLD queries are supposed to have an IPv6 link-local source address according to RFC2710, section 4 and RFC3810, section 5.1.14. This patch adds a sanity check to ignore such broken MLD queries. Without this check, such malformed MLD queries can result in a denial of service: The queries are ignored by any MLD listener therefore they will not respond with an MLD report. However, without this patch these malformed MLD queries would enable the snooping part in the bridge code, potentially shutting down the according ports towards these hosts for multicast traffic as the bridge did not learn about these listeners. Reported-by: Jan Stancek <jstancek@redhat.com> Signed-off-by: Linus Lüssing <linus.luessing@web.de> Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14net: sctp: fix skb leakage in COOKIE ECHO path of chunk->auth_chunkDaniel Borkmann
[ Upstream commit c485658bae87faccd7aed540fd2ca3ab37992310 ] While working on ec0223ec48a9 ("net: sctp: fix sctp_sf_do_5_1D_ce to verify if we/peer is AUTH capable"), we noticed that there's a skb memory leakage in the error path. Running the same reproducer as in ec0223ec48a9 and by unconditionally jumping to the error label (to simulate an error condition) in sctp_sf_do_5_1D_ce() receive path lets kmemleak detector bark about the unfreed chunk->auth_chunk skb clone: Unreferenced object 0xffff8800b8f3a000 (size 256): comm "softirq", pid 0, jiffies 4294769856 (age 110.757s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 89 ab 75 5e d4 01 58 13 00 00 00 00 00 00 00 00 ..u^..X......... backtrace: [<ffffffff816660be>] kmemleak_alloc+0x4e/0xb0 [<ffffffff8119f328>] kmem_cache_alloc+0xc8/0x210 [<ffffffff81566929>] skb_clone+0x49/0xb0 [<ffffffffa0467459>] sctp_endpoint_bh_rcv+0x1d9/0x230 [sctp] [<ffffffffa046fdbc>] sctp_inq_push+0x4c/0x70 [sctp] [<ffffffffa047e8de>] sctp_rcv+0x82e/0x9a0 [sctp] [<ffffffff815abd38>] ip_local_deliver_finish+0xa8/0x210 [<ffffffff815a64af>] nf_reinject+0xbf/0x180 [<ffffffffa04b4762>] nfqnl_recv_verdict+0x1d2/0x2b0 [nfnetlink_queue] [<ffffffffa04aa40b>] nfnetlink_rcv_msg+0x14b/0x250 [nfnetlink] [<ffffffff815a3269>] netlink_rcv_skb+0xa9/0xc0 [<ffffffffa04aa7cf>] nfnetlink_rcv+0x23f/0x408 [nfnetlink] [<ffffffff815a2bd8>] netlink_unicast+0x168/0x250 [<ffffffff815a2fa1>] netlink_sendmsg+0x2e1/0x3f0 [<ffffffff8155cc6b>] sock_sendmsg+0x8b/0xc0 [<ffffffff8155d449>] ___sys_sendmsg+0x369/0x380 What happens is that commit bbd0d59809f9 clones the skb containing the AUTH chunk in sctp_endpoint_bh_rcv() when having the edge case that an endpoint requires COOKIE-ECHO chunks to be authenticated: ---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ----------> <------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] --------- ------------------ AUTH; COOKIE-ECHO ----------------> <-------------------- COOKIE-ACK --------------------- When we enter sctp_sf_do_5_1D_ce() and before we actually get to the point where we process (and subsequently free) a non-NULL chunk->auth_chunk, we could hit the "goto nomem_init" path from an error condition and thus leave the cloned skb around w/o freeing it. The fix is to centrally free such clones in sctp_chunk_destroy() handler that is invoked from sctp_chunk_free() after all refs have dropped; and also move both kfree_skb(chunk->auth_chunk) there, so that chunk->auth_chunk is either NULL (since sctp_chunkify() allocs new chunks through kmem_cache_zalloc()) or non-NULL with a valid skb pointer. chunk->skb and chunk->auth_chunk are the only skbs in the sctp_chunk structure that need to be handeled. While at it, we should use consume_skb() for both. It is the same as dev_kfree_skb() but more appropriately named as we are not a device but a protocol. Also, this effectively replaces the kfree_skb() from both invocations into consume_skb(). Functions are the same only that kfree_skb() assumes that the frame was being dropped after a failure (e.g. for tools like drop monitor), usage of consume_skb() seems more appropriate in function sctp_chunk_destroy() though. Fixes: bbd0d59809f9 ("[SCTP]: Implement the receive and verification of AUTH chunk") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Vlad Yasevich <yasevich@gmail.com> Cc: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14net: fix for a race condition in the inet frag codeNikolay Aleksandrov
[ Upstream commit 24b9bf43e93e0edd89072da51cf1fab95fc69dec ] I stumbled upon this very serious bug while hunting for another one, it's a very subtle race condition between inet_frag_evictor, inet_frag_intern and the IPv4/6 frag_queue and expire functions (basically the users of inet_frag_kill/inet_frag_put). What happens is that after a fragment has been added to the hash chain but before it's been added to the lru_list (inet_frag_lru_add) in inet_frag_intern, it may get deleted (either by an expired timer if the system load is high or the timer sufficiently low, or by the fraq_queue function for different reasons) before it's added to the lru_list, then after it gets added it's a matter of time for the evictor to get to a piece of memory which has been freed leading to a number of different bugs depending on what's left there. I've been able to trigger this on both IPv4 and IPv6 (which is normal as the frag code is the same), but it's been much more difficult to trigger on IPv4 due to the protocol differences about how fragments are treated. The setup I used to reproduce this is: 2 machines with 4 x 10G bonded in a RR bond, so the same flow can be seen on multiple cards at the same time. Then I used multiple instances of ping/ping6 to generate fragmented packets and flood the machines with them while running other processes to load the attacked machine. *It is very important to have the _same flow_ coming in on multiple CPUs concurrently. Usually the attacked machine would die in less than 30 minutes, if configured properly to have many evictor calls and timeouts it could happen in 10 minutes or so. An important point to make is that any caller (frag_queue or timer) of inet_frag_kill will remove both the timer refcount and the original/guarding refcount thus removing everything that's keeping the frag from being freed at the next inet_frag_put. All of this could happen before the frag was ever added to the LRU list, then it gets added and the evictor uses a freed fragment. An example for IPv6 would be if a fragment is being added and is at the stage of being inserted in the hash after the hash lock is released, but before inet_frag_lru_add executes (or is able to obtain the lru lock) another overlapping fragment for the same flow arrives at a different CPU which finds it in the hash, but since it's overlapping it drops it invoking inet_frag_kill and thus removing all guarding refcounts, and afterwards freeing it by invoking inet_frag_put which removes the last refcount added previously by inet_frag_find, then inet_frag_lru_add gets executed by inet_frag_intern and we have a freed fragment in the lru_list. The fix is simple, just move the lru_add under the hash chain locked region so when a removing function is called it'll have to wait for the fragment to be added to the lru_list, and then it'll remove it (it works because the hash chain removal is done before the lru_list one and there's no window between the two list adds when the frag can get dropped). With this fix applied I couldn't kill the same machine in 24 hours with the same setup. Fixes: 3ef0eb0db4bf ("net: frag, move LRU list maintenance outside of rwlock") CC: Florian Westphal <fw@strlen.de> CC: Jesper Dangaard Brouer <brouer@redhat.com> CC: David S. Miller <davem@davemloft.net> Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-03netfilter: nf_conntrack_dccp: fix skb_header_pointer API usagesDaniel Borkmann
commit b22f5126a24b3b2f15448c3f2a254fc10cbc2b92 upstream. Some occurences in the netfilter tree use skb_header_pointer() in the following way ... struct dccp_hdr _dh, *dh; ... skb_header_pointer(skb, dataoff, sizeof(_dh), &dh); ... where dh itself is a pointer that is being passed as the copy buffer. Instead, we need to use &_dh as the forth argument so that we're copying the data into an actual buffer that sits on the stack. Currently, we probably could overwrite memory on the stack (e.g. with a possibly mal-formed DCCP packet), but unintentionally, as we only want the buffer to be placed into _dh variable. Fixes: 2bc780499aa3 ("[NETFILTER]: nf_conntrack: add DCCP protocol support") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-31libceph: resend all writes after the osdmap loses the full flagJosh Durgin
commit 9a1ea2dbff11547a8e664f143c1ffefc586a577a upstream. With the current full handling, there is a race between osds and clients getting the first map marked full. If the osd wins, it will return -ENOSPC to any writes, but the client may already have writes in flight. This results in the client getting the error and propagating it up the stack. For rbd, the block layer turns this into EIO, which can cause corruption in filesystems above it. To avoid this race, osds are being changed to drop writes that came from clients with an osdmap older than the last osdmap marked full. In order for this to work, clients must resend all writes after they encounter a full -> not full transition in the osdmap. osds will wait for an updated map instead of processing a request from a client with a newer map, so resent writes will not be dropped by the osd unless there is another not full -> full transition. This approach requires both osds and clients to be fixed to avoid the race. Old clients talking to osds with this fix may hang instead of returning EIO and potentially corrupting an fs. New clients talking to old osds have the same behavior as before if they encounter this race. Fixes: http://tracker.ceph.com/issues/6938 Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-31libceph: block I/O when PAUSE or FULL osd map flags are setJosh Durgin
commit d29adb34a94715174c88ca93e8aba955850c9bde upstream. The PAUSEWR and PAUSERD flags are meant to stop the cluster from processing writes and reads, respectively. The FULL flag is set when the cluster determines that it is out of space, and will no longer process writes. PAUSEWR and PAUSERD are purely client-side settings already implemented in userspace clients. The osd does nothing special with these flags. When the FULL flag is set, however, the osd responds to all writes with -ENOSPC. For cephfs, this makes sense, but for rbd the block layer translates this into EIO. If a cluster goes from full to non-full quickly, a filesystem on top of rbd will not behave well, since some writes succeed while others get EIO. Fix this by blocking any writes when the FULL flag is set in the osd client. This is the same strategy used by userspace, so apply it by default. A follow-on patch makes this configurable. __map_request() is called to re-target osd requests in case the available osds changed. Add a paused field to a ceph_osd_request, and set it whenever an appropriate osd map flag is set. Avoid queueing paused requests in __map_request(), but force them to be resent if they become unpaused. Also subscribe to the next osd map from the monitor if any of these flags are set, so paused requests can be unblocked as soon as possible. Fixes: http://tracker.ceph.com/issues/6079 Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23net: unix socket code abuses csum_partialAnton Blanchard
commit 0a13404dd3bf4ea870e3d96270b5a382edca85c0 upstream. The unix socket code is using the result of csum_partial to hash into a lookup table: unix_hash_fold(csum_partial(sunaddr, len, 0)); csum_partial is only guaranteed to produce something that can be folded into a checksum, as its prototype explains: * returns a 32-bit number suitable for feeding into itself * or csum_tcpudp_magic The 32bit value should not be used directly. Depending on the alignment, the ppc64 csum_partial will return different 32bit partial checksums that will fold into the same 16bit checksum. This difference causes the following testcase (courtesy of Gustavo) to sometimes fail: #include <sys/socket.h> #include <stdio.h> int main() { int fd = socket(PF_LOCAL, SOCK_STREAM|SOCK_CLOEXEC, 0); int i = 1; setsockopt(fd, SOL_SOCKET, SO_REUSEADDR, &i, 4); struct sockaddr addr; addr.sa_family = AF_LOCAL; bind(fd, &addr, 2); listen(fd, 128); struct sockaddr_storage ss; socklen_t sslen = (socklen_t)sizeof(ss); getsockname(fd, (struct sockaddr*)&ss, &sslen); fd = socket(PF_LOCAL, SOCK_STREAM|SOCK_CLOEXEC, 0); if (connect(fd, (struct sockaddr*)&ss, sslen) == -1){ perror(NULL); return 1; } printf("OK\n"); return 0; } As suggested by davem, fix this by using csum_fold to fold the partial 32bit checksum into a 16bit checksum before using it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23mac80211: clear sequence/fragment number in QoS-null framesJohannes Berg
commit 864a6040f395464003af8dd0d8ca86fed19866d4 upstream. Avoid leaking data by sending uninitialized memory and setting an invalid (non-zero) fragment number (the sequence number is ignored anyway) by setting the seq_ctrl field to zero. Fixes: 3f52b7e328c5 ("mac80211: mesh power save basics") Fixes: ce662b44ce22 ("mac80211: send (QoS) Null if no buffered frames") Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23mac80211: fix association to 20/40 MHz VHT networksJohannes Berg
commit cb664981607a6b5b3d670ad57bbda893b2528d96 upstream. When a VHT network uses 20 or 40 MHz as per the HT operation information, the channel center frequency segment 0 field in the VHT operation information is reserved, so ignore it. This fixes association with such networks when the AP puts 0 into the field, previously we'd disconnect due to an invalid channel with the message wlan0: AP VHT information is invalid, disable VHT Fixes: f2d9d270c15ae ("mac80211: support VHT association") Reported-by: Tim Nelson <tim.l.nelson@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23mac80211: don't validate unchanged AP bandwidth while trackingJohannes Berg
commit 963a1852fbac4f75a2d938fa2e734ef1e6d4c044 upstream. The MLME code in mac80211 must track whether or not the AP changed bandwidth, but if there's no change while tracking it shouldn't do anything, otherwise regulatory updates can make it impossible to connect to certain APs if the regulatory database doesn't match the information from the AP. See the precise scenario described in the code. This still leaves some possible problems with CSA or if the AP actually changed bandwidth, but those cases are less common and won't completely prevent using it. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=70881 Reported-and-tested-by: Nate Carlson <kernel@natecarlson.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23mac80211: fix AP powersave TX vs. wakeup raceEmmanuel Grumbach
commit 1d147bfa64293b2723c4fec50922168658e613ba upstream. There is a race between the TX path and the STA wakeup: while a station is sleeping, mac80211 buffers frames until it wakes up, then the frames are transmitted. However, the RX and TX path are concurrent, so the packet indicating wakeup can be processed while a packet is being transmitted. This can lead to a situation where the buffered frames list is emptied on the one side, while a frame is being added on the other side, as the station is still seen as sleeping in the TX path. As a result, the newly added frame will not be send anytime soon. It might be sent much later (and out of order) when the station goes to sleep and wakes up the next time. Additionally, it can lead to the crash below. Fix all this by synchronising both paths with a new lock. Both path are not fastpath since they handle PS situations. In a later patch we'll remove the extra skb queue locks to reduce locking overhead. BUG: unable to handle kernel NULL pointer dereference at 000000b0 IP: [<ff6f1791>] ieee80211_report_used_skb+0x11/0x3e0 [mac80211] *pde = 00000000 Oops: 0000 [#1] SMP DEBUG_PAGEALLOC EIP: 0060:[<ff6f1791>] EFLAGS: 00210282 CPU: 1 EIP is at ieee80211_report_used_skb+0x11/0x3e0 [mac80211] EAX: e5900da0 EBX: 00000000 ECX: 00000001 EDX: 00000000 ESI: e41d00c0 EDI: e5900da0 EBP: ebe458e4 ESP: ebe458b0 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 CR0: 8005003b CR2: 000000b0 CR3: 25a78000 CR4: 000407d0 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 Process iperf (pid: 3934, ti=ebe44000 task=e757c0b0 task.ti=ebe44000) iwlwifi 0000:02:00.0: I iwl_pcie_enqueue_hcmd Sending command LQ_CMD (#4e), seq: 0x0903, 92 bytes at 3[3]:9 Stack: e403b32c ebe458c4 00200002 00200286 e403b338 ebe458cc c10960bb e5900da0 ff76a6ec ebe458d8 00000000 e41d00c0 e5900da0 ebe458f0 ff6f1b75 e403b210 ebe4598c ff723dc1 00000000 ff76a6ec e597c978 e403b758 00000002 00000002 Call Trace: [<ff6f1b75>] ieee80211_free_txskb+0x15/0x20 [mac80211] [<ff723dc1>] invoke_tx_handlers+0x1661/0x1780 [mac80211] [<ff7248a5>] ieee80211_tx+0x75/0x100 [mac80211] [<ff7249bf>] ieee80211_xmit+0x8f/0xc0 [mac80211] [<ff72550e>] ieee80211_subif_start_xmit+0x4fe/0xe20 [mac80211] [<c149ef70>] dev_hard_start_xmit+0x450/0x950 [<c14b9aa9>] sch_direct_xmit+0xa9/0x250 [<c14b9c9b>] __qdisc_run+0x4b/0x150 [<c149f732>] dev_queue_xmit+0x2c2/0xca0 Reported-by: Yaara Rozenblum <yaara.rozenblum@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> [reword commit log, use a separate lock] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23mac80211: send control port protocol frames to the VO queueFelix Fietkau
commit 1bf4bbb4024dcdab5e57634dd8ae1072d42a53ac upstream. Improves reliability of wifi connections with WPA, since authentication frames are prioritized over normal traffic and also typically exempt from aggregation. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23net: sctp: fix sctp_sf_do_5_1D_ce to verify if we/peer is AUTH capableDaniel Borkmann
[ Upstream commit ec0223ec48a90cb605244b45f7c62de856403729 ] RFC4895 introduced AUTH chunks for SCTP; during the SCTP handshake RANDOM; CHUNKS; HMAC-ALGO are negotiated (CHUNKS being optional though): ---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ----------> <------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] --------- -------------------- COOKIE-ECHO --------------------> <-------------------- COOKIE-ACK --------------------- A special case is when an endpoint requires COOKIE-ECHO chunks to be authenticated: ---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ----------> <------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] --------- ------------------ AUTH; COOKIE-ECHO ----------------> <-------------------- COOKIE-ACK --------------------- RFC4895, section 6.3. Receiving Authenticated Chunks says: The receiver MUST use the HMAC algorithm indicated in the HMAC Identifier field. If this algorithm was not specified by the receiver in the HMAC-ALGO parameter in the INIT or INIT-ACK chunk during association setup, the AUTH chunk and all the chunks after it MUST be discarded and an ERROR chunk SHOULD be sent with the error cause defined in Section 4.1. [...] If no endpoint pair shared key has been configured for that Shared Key Identifier, all authenticated chunks MUST be silently discarded. [...] When an endpoint requires COOKIE-ECHO chunks to be authenticated, some special procedures have to be followed because the reception of a COOKIE-ECHO chunk might result in the creation of an SCTP association. If a packet arrives containing an AUTH chunk as a first chunk, a COOKIE-ECHO chunk as the second chunk, and possibly more chunks after them, and the receiver does not have an STCB for that packet, then authentication is based on the contents of the COOKIE-ECHO chunk. In this situation, the receiver MUST authenticate the chunks in the packet by using the RANDOM parameters, CHUNKS parameters and HMAC_ALGO parameters obtained from the COOKIE-ECHO chunk, and possibly a local shared secret as inputs to the authentication procedure specified in Section 6.3. If authentication fails, then the packet is discarded. If the authentication is successful, the COOKIE-ECHO and all the chunks after the COOKIE-ECHO MUST be processed. If the receiver has an STCB, it MUST process the AUTH chunk as described above using the STCB from the existing association to authenticate the COOKIE-ECHO chunk and all the chunks after it. [...] Commit bbd0d59809f9 introduced the possibility to receive and verification of AUTH chunk, including the edge case for authenticated COOKIE-ECHO. On reception of COOKIE-ECHO, the function sctp_sf_do_5_1D_ce() handles processing, unpacks and creates a new association if it passed sanity checks and also tests for authentication chunks being present. After a new association has been processed, it invokes sctp_process_init() on the new association and walks through the parameter list it received from the INIT chunk. It checks SCTP_PARAM_RANDOM, SCTP_PARAM_HMAC_ALGO and SCTP_PARAM_CHUNKS, and copies them into asoc->peer meta data (peer_random, peer_hmacs, peer_chunks) in case sysctl -w net.sctp.auth_enable=1 is set. If in INIT's SCTP_PARAM_SUPPORTED_EXT parameter SCTP_CID_AUTH is set, peer_random != NULL and peer_hmacs != NULL the peer is to be assumed asoc->peer.auth_capable=1, in any other case asoc->peer.auth_capable=0. Now, if in sctp_sf_do_5_1D_ce() chunk->auth_chunk is available, we set up a fake auth chunk and pass that on to sctp_sf_authenticate(), which at latest in sctp_auth_calculate_hmac() reliably dereferences a NULL pointer at position 0..0008 when setting up the crypto key in crypto_hash_setkey() by using asoc->asoc_shared_key that is NULL as condition key_id == asoc->active_key_id is true if the AUTH chunk was injected correctly from remote. This happens no matter what net.sctp.auth_enable sysctl says. The fix is to check for net->sctp.auth_enable and for asoc->peer.auth_capable before doing any operations like sctp_sf_authenticate() as no key is activated in sctp_auth_asoc_init_active_key() for each case. Now as RFC4895 section 6.3 states that if the used HMAC-ALGO passed from the INIT chunk was not used in the AUTH chunk, we SHOULD send an error; however in this case it would be better to just silently discard such a maliciously prepared handshake as we didn't even receive a parameter at all. Also, as our endpoint has no shared key configured, section 6.3 says that MUST silently discard, which we are doing from now onwards. Before calling sctp_sf_pdiscard(), we need not only to free the association, but also the chunk->auth_chunk skb, as commit bbd0d59809f9 created a skb clone in that case. I have tested this locally by using netfilter's nfqueue and re-injecting packets into the local stack after maliciously modifying the INIT chunk (removing RANDOM; HMAC-ALGO param) and the SCTP packet containing the COOKIE_ECHO (injecting AUTH chunk before COOKIE_ECHO). Fixed with this patch applied. Fixes: bbd0d59809f9 ("[SCTP]: Implement the receive and verification of AUTH chunk") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Vlad Yasevich <yasevich@gmail.com> Cc: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23ipv6: ipv6_find_hdr restore prev functionalityHans Schillstrom
[ Upstream commit accfe0e356327da5bd53da8852b93fc22de9b5fc ] The commit 9195bb8e381d81d5a315f911904cdf0cfcc919b8 ("ipv6: improve ipv6_find_hdr() to skip empty routing headers") broke ipv6_find_hdr(). When a target is specified like IPPROTO_ICMPV6 ipv6_find_hdr() returns -ENOENT when it's found, not the header as expected. A part of IPVS is broken and possible also nft_exthdr_eval(). When target is -1 which it is most cases, it works. This patch exits the do while loop if the specific header is found so the nexthdr could be returned as expected. Reported-by: Art -kwaak- van Breemen <ard@telegraafnet.nl> Signed-off-by: Hans Schillstrom <hans@schillstrom.com> CC:Ansis Atteka <aatteka@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23ipv6: reuse ip6_frag_id from ip6_ufo_append_dataHannes Frederic Sowa
[ Upstream commit 916e4cf46d0204806c062c8c6c4d1f633852c5b6 ] Currently we generate a new fragmentation id on UFO segmentation. It is pretty hairy to identify the correct net namespace and dst there. Especially tunnels use IFF_XMIT_DST_RELEASE and thus have no skb_dst available at all. This causes unreliable or very predictable ipv6 fragmentation id generation while segmentation. Luckily we already have pregenerated the ip6_frag_id in ip6_ufo_append_data and can use it here. Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23neigh: recompute reachabletime before returning from neigh_periodic_work()Duan Jiong
[ Upstream commit feff9ab2e7fa773b6a3965f77375fe89f7fd85cf ] If the neigh table's entries is less than gc_thresh1, the function will return directly, and the reachabletime will not be recompute, so the reachabletime can be guessed. Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23net-tcp: fastopen: fix high order allocationsEric Dumazet
[ Upstream commit f5ddcbbb40aa0ba7fbfe22355d287603dbeeaaac ] This patch fixes two bugs in fastopen : 1) The tcp_sendmsg(..., @size) argument was ignored. Code was relying on user not fooling the kernel with iovec mismatches 2) When MTU is about 64KB, tcp_send_syn_data() attempts order-5 allocations, which are likely to fail when memory gets fragmented. Fixes: 783237e8daf13 ("net-tcp: Fast Open client - sending SYN-data") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Acked-by: Yuchung Cheng <ycheng@google.com> Tested-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-18Revert "Revert parts of "hlist: drop the node parameter from iterators""Seema Khowala
This reverts commit dc893e19b5800d7743fb58235877bfa9091805ff. Bug 1481993 Change-Id: I147913ac71e89cba13a5a99a751e142c1d3a61da Signed-off-by: Seema Khowala <seemaj@nvidia.com> Reviewed-on: http://git-master/r/382701 Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
2014-03-13Merge branch 'linux-3.10.33' into dev-kernel-3.10Deepak Nibade
Bug 1456092 Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
2014-03-10Merge branch 'android-3.10' into dev-kernel-3.10Deepak Nibade
Bug 1456092 Change-Id: I87b6b883c382000fc0dfee7c8d8f36269f504e46 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
2014-03-06SUNRPC: Fix races in xs_nospace()Trond Myklebust
commit 06ea0bfe6e6043cb56a78935a19f6f8ebc636226 upstream. When a send failure occurs due to the socket being out of buffer space, we call xs_nospace() in order to have the RPC task wait until the socket has drained enough to make it worth while trying again. The current patch fixes a race in which the socket is drained before we get round to setting up the machinery in xs_nospace(), and which is reported to cause hangs. Link: http://lkml.kernel.org/r/20140210170315.33dfc621@notabene.brown Fixes: a9a6b52ee1ba (SUNRPC: Don't start the retransmission timer...) Reported-by: Neil Brown <neilb@suse.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-06net: use __GFP_NORETRY for high order allocationsEric Dumazet
[ Upstream commit ed98df3361f059db42786c830ea96e2d18b8d4db ] sock_alloc_send_pskb() & sk_page_frag_refill() have a loop trying high order allocations to prepare skb with low number of fragments as this increases performance. Problem is that under memory pressure/fragmentation, this can trigger OOM while the intent was only to try the high order allocations, then fallback to order-0 allocations. We had various reports from unexpected regressions. According to David, setting __GFP_NORETRY should be fine, as the asynchronous compaction is still enabled, and this will prevent OOM from kicking as in : CFSClientEventm invoked oom-killer: gfp_mask=0x42d0, order=3, oom_adj=0, oom_score_adj=0, oom_score_badness=2 (enabled),memcg_scoring=disabled CFSClientEventm Call Trace: [<ffffffff8043766c>] dump_header+0xe1/0x23e [<ffffffff80437a02>] oom_kill_process+0x6a/0x323 [<ffffffff80438443>] out_of_memory+0x4b3/0x50d [<ffffffff8043a4a6>] __alloc_pages_may_oom+0xa2/0xc7 [<ffffffff80236f42>] __alloc_pages_nodemask+0x1002/0x17f0 [<ffffffff8024bd23>] alloc_pages_current+0x103/0x2b0 [<ffffffff8028567f>] sk_page_frag_refill+0x8f/0x160 [<ffffffff80295fa0>] tcp_sendmsg+0x560/0xee0 [<ffffffff802a5037>] inet_sendmsg+0x67/0x100 [<ffffffff80283c9c>] __sock_sendmsg_nosec+0x6c/0x90 [<ffffffff80283e85>] sock_sendmsg+0xc5/0xf0 [<ffffffff802847b6>] __sys_sendmsg+0x136/0x430 [<ffffffff80284ec8>] sys_sendmsg+0x88/0x110 [<ffffffff80711472>] system_call_fastpath+0x16/0x1b Out of Memory: Kill process 2856 (bash) score 9999 or sacrifice child Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-06net: ip, ipv6: handle gso skbs in forwarding pathFlorian Westphal
commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream. Marcelo Ricardo Leitner reported problems when the forwarding link path has a lower mtu than the incoming one if the inbound interface supports GRO. Given: Host <mtu1500> R1 <mtu1200> R2 Host sends tcp stream which is routed via R1 and R2. R1 performs GRO. In this case, the kernel will fail to send ICMP fragmentation needed messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu checks in forward path. Instead, Linux tries to send out packets exceeding the mtu. When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does not fragment the packets when forwarding, and again tries to send out packets exceeding R1-R2 link mtu. This alters the forwarding dstmtu checks to take the individual gso segment lengths into account. For ipv6, we send out pkt too big error for gso if the individual segments are too big. For ipv4, we either send icmp fragmentation needed, or, if the DF bit is not set, perform software segmentation and let the output path create fragments when the packet is leaving the machine. It is not 100% correct as the error message will contain the headers of the GRO skb instead of the original/segmented one, but it seems to work fine in my (limited) tests. Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid sofware segmentation. However it turns out that skb_segment() assumes skb nr_frags is related to mss size so we would BUG there. I don't want to mess with it considering Herbert and Eric disagree on what the correct behavior should be. Hannes Frederic Sowa notes that when we would shrink gso_size skb_segment would then also need to deal with the case where SKB_MAX_FRAGS would be exceeded. This uses sofware segmentation in the forward path when we hit ipv4 non-DF packets and the outgoing link mtu is too small. Its not perfect, but given the lack of bug reports wrt. GRO fwd being broken this is a rare case anyway. Also its not like this could not be improved later once the dust settles. Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-06net: core: introduce netif_skb_dev_featuresFlorian Westphal
commit d206940319c41df4299db75ed56142177bb2e5f6 upstream. Will be used by upcoming ipv4 forward path change that needs to determine feature mask using skb->dst->dev instead of skb->dev. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
