path: root/net
2005-10-27[TCP]: Clear stale pred_flags when snd_wnd changesHerbert Xu
This bug is responsible for causing the infamous "Treason uncloaked" messages that's been popping up everywhere since the printk was added. It has usually been blamed on foreign operating systems. However, some of those reports implicate Linux as both systems are running Linux or the TCP connection is going across the loopback interface. In fact, there really is a bug in the Linux TCP header prediction code that's been there since at least 2.1.8. This bug was tracked down with help from Dale Blount. The effect of this bug ranges from harmless "Treason uncloaked" messages to hung/aborted TCP connections. The details of the bug and fix is as follows. When snd_wnd is updated, we only update pred_flags if tcp_fast_path_check succeeds. When it fails (for example, when our rcvbuf is used up), we will leave pred_flags with an out-of-date snd_wnd value. When the out-of-date pred_flags happens to match the next incoming packet we will again hit the fast path and use the current snd_wnd which will be wrong. In the case of the treason messages, it just happens that the snd_wnd cached in pred_flags is zero while tp->snd_wnd is non-zero. Therefore when a zero-window packet comes in we incorrectly conclude that the window is non-zero. In fact if the peer continues to send us zero-window pure ACKs we will continue making the same mistake. It's only when the peer transmits a zero-window packet with data attached that we get a chance to snap out of it. This is what triggers the treason message at the next retransmit timeout. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[PATCH] svcsock timestamp fixAndrew Morton
Convert nanoseconds to microseconds correctly. Spotted by Steve Dickson <SteveD@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-26[PATCH] kill massive wireless-related log spamJeff Garzik
Although this message is having the intended effect of causing wireless driver maintainers to upgrade their code, I never should have merged this patch in its present form. Leading to tons of bug reports and unhappy users. Some wireless apps poll for statistics regularly, which leads to a printk() every single time they ask for stats. That's a little bit _too_ much of a reminder that the driver is using an old API. Change this to printing out the message once, per kernel boot. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-25[TR]: Preserve RIF flag even for 2 byte RIF fields.Jochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-25[IPV6]: Fix refcnt of struct ip6_flowlabelYan Zheng
Signed-off-by: Yan Zheng <yanzheng@21cn.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-23[NEIGH] Fix timer leak in neigh_changeaddrHerbert Xu
neigh_changeaddr attempts to delete neighbour timers without setting nud_state. This doesn't work because the timer may have already fired when we acquire the write lock in neigh_changeaddr. The result is that the timer may keep firing for quite a while until the entry reaches NEIGH_FAILED. It should be setting the nud_state straight away so that if the timer has already fired it can simply exit once we relinquish the lock. In fact, this whole function is simply duplicating the logic in neigh_ifdown which in turn is already doing the right thing when it comes to deleting timers and setting nud_state. So all we have to do is take that code out and put it into a common function and make both neigh_changeaddr and neigh_ifdown call it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-23[NEIGH] Fix add_timer race in neigh_add_timerHerbert Xu
neigh_add_timer cannot use add_timer unconditionally. The reason is that by the time it has obtained the write lock someone else (e.g., neigh_update) could have already added a new timer. So it should only use mod_timer and deal with its return value accordingly. This bug would have led to rare neighbour cache entry leaks. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-23[NEIGH] Print stack trace in neigh_add_timerHerbert Xu
Stack traces are very helpful in determining the exact nature of a bug. So let's print a stack trace when the timer is added twice. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-22[SK_BUFF]: ipvs_property field must be copiedJulian Anastasov
IPVS used flag NFC_IPVS_PROPERTY in nfcache but as now nfcache was removed the new flag 'ipvs_property' still needs to be copied. This patch should be included in 2.6.14. Further comments from Harald Welte: Sorry, seems like the bug was introduced by me. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-20[TCP] Allow len == skb->len in tcp_fragmentHerbert Xu
It is legitimate to call tcp_fragment with len == skb->len since that is done for FIN packets and the FIN flag counts as one byte. So we should only check for the len > skb->len case. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-20[DCCP]: Clear the IPCB areaHerbert Xu
Turns out the problem has nothing to do with use-after-free or double-free. It's just that we're not clearing the CB area and DCCP unlike TCP uses a CB format that's incompatible with IP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Ian McDonald <imcdnzl@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-20[DCCP]: Make dccp_write_xmit always free the packetHerbert Xu
icmp_send doesn't use skb->sk at all so even if skb->sk has already been freed it can't cause crash there (it would've crashed somewhere else first, e.g., ip_queue_xmit). I found a double-free on an skb that could explain this though. dccp_sendmsg and dccp_write_xmit are a little confused as to what should free the packet when something goes wrong. Sometimes they both go for the ball and end up in each other's way. This patch makes dccp_write_xmit always free the packet no matter what. This makes sense since dccp_transmit_skb which in turn comes from the fact that ip_queue_xmit always frees the packet. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-20[DCCP]: Use skb_set_owner_w in dccp_transmit_skb when skb->sk is NULLHerbert Xu
David S. Miller <davem@davemloft.net> wrote: > One thing you can probably do for this bug is to mark data packets > explicitly somehow, perhaps in the SKB control block DCCP already > uses for other data. Put some boolean in there, set it true for > data packets. Then change the test in dccp_transmit_skb() as > appropriate to test the boolean flag instead of "skb_cloned(skb)". I agree. In fact we already have that flag, it's called skb->sk. So here is patch to test that instead of skb_cloned(). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Ian McDonald <imcdnzl@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-15[NETFILTER]: Fix ip6_table.c build with NETFILTER_DEBUG enabled.Andrew Morton
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-13[TCP]: Ratelimit debugging warning.Herbert Xu
Better safe than sorry. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-13[NET]: Disable NET_SCH_CLK_CPU for SMP x86 hostsAndi Kleen
Opterons with frequency scaling have fully unsynchronized TSCs running at different frequencies, so using TSCs there is not a good idea. Also some other x86 boxes have this problem. gettimeofday should be good enough, so just disable it. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-13[NETFILTER]: Fix OOPSes on machines with discontiguous cpu numbering.David S. Miller
Original patch by Harald Welte, with feedback from Herbert Xu and testing by Sébastien Bernard. EBTABLES, ARP tables, and IP/IP6 tables all assume that cpus are numbered linearly. That is not necessarily true. This patch fixes that up by calculating the largest possible cpu number, and allocating enough per-cpu structure space given that. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-12[TCP]: Add code to help track down "BUG at net/ipv4/tcp_output.c:438!"Herbert Xu
This is the second report of this bug. Unfortunately the first reporter hasn't been able to reproduce it since to provide more debugging info. So let's apply this patch for 2.6.14 to 1) Make this non-fatal. 2) Provide the info we need to track it down. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-12[BRIDGE]: fix race on bridge del ifStephen Hemminger
This fixes the RCU race on bridge delete interface. Basically, the network device has to be detached from the bridge in the first step (pre-RCU), rather than later. At that point, no more bridge traffic will come in, and the other code will not think that network device is part of a bridge. This should also fix the XEN test problems. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[TWSK]: Grab the module refcount for timewait socketsArnaldo Carvalho de Melo
This is required to avoid unloading a module that has active timewait sockets, such as DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[DCCP]: Transition from PARTOPEN to OPEN when receiving DATA packetsArnaldo Carvalho de Melo
Noticed by Andrea Bittau, that provided a patch that was modified to not transition from RESPOND to OPEN when receiving DATA packets. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[CCID]: Check if ccid is NULL in the hc_[tr]x_exit functionsArnaldo Carvalho de Melo
For consistency with ccid_exit and to fix a bug when IP_DCCP_UNLOAD_HACK is enabled as the control sock is not associated to any CCID. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] ctnetlink: add support to change protocol infoPablo Neira Ayuso
This patch add support to change the state of the private protocol information via conntrack_netlink. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] ctnetlink: allow userspace to change TCP statePablo Neira Ayuso
This patch adds the ability of changing the state a TCP connection. I know that this must be used with care but it's required to provide a complete conntrack creation via conntrack_netlink. So I'll document this aspect on the upcoming docs. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER]: Use only 32bit counters for CONNTRACK_ACCTHarald Welte
Initially we used 64bit counters for conntrack-based accounting, since we had no event mechanism to tell userspace that our counters are about to overflow. With nfnetlink_conntrack, we now have such a event mechanism and thus can save 16bytes per connection. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[IPSEC] Fix block size/MTU bugs in ESPHerbert Xu
This patch fixes the following bugs in ESP: * Fix transport mode MTU overestimate. This means that the inner MTU is smaller than it needs be. Worse yet, given an input MTU which is a multiple of 4 it will always produce an estimate which is not a multiple of 4. For example, given a standard ESP/3DES/MD5 transform and an MTU of 1500, the resulting MTU for transport mode is 1462 when it should be 1464. The reason for this is because IP header lengths are always a multiple of 4 for IPv4 and 8 for IPv6. * Ensure that the block size is at least 4. This is required by RFC2406 and corresponds to what the esp_output function does. At the moment this only affects crypto_null as its block size is 1. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[IPSEC]: Use ALIGN macro in ESPHerbert Xu
This patch uses the macro ALIGN in all the applicable spots for ESP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] ctnetlink: add one nesting level for TCP statePablo Neira Ayuso
To keep consistency, the TCP private protocol information is nested attributes under CTA_PROTOINFO_TCP. This way the sequence of attributes to access the TCP state information looks like here below: CTA_PROTOINFO CTA_PROTOINFO_TCP CTA_PROTOINFO_TCP_STATE instead of: CTA_PROTOINFO CTA_PROTOINFO_TCP_STATE Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] ctnetlink: ICMP ID is not mandatoryPablo Neira Ayuso
The ID is only required by ICMP type 8 (echo), so it's not mandatory for all sort of ICMP connections. This patch makes mandatory only the type and the code for ICMP netlink messages. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] conntrack_netlink: Fix endian issue with status from userspaceHarald Welte
When we send "status" from userspace, we forget to convert the endianness. This patch adds the reqired conversion. Thanks to Pablo Neira for discovering this. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] nfnetlink: use highest bit of nfa_type to indicate nested TLVHarald Welte
As Henrik Nordstrom pointed out, all our efforts with "split endian" (i.e. host byte order tags, net byte order values) are useless, unless a parser can determine whether an attribute is nested or not. This patch steals the highest bit of nfattr.nfa_type to indicate whether the data payload contains a nested nfattr (1) or not (0). This will break userspace compatibility, but luckily no kernel with nfnetlink was released so far. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] ipt_ULOG: Mark ipt_ULOG as OBSOLETEHarald Welte
Similar to nfnetlink_queue and ip_queue, we mark ipt_ULOG as obsolete. This should have been part of the original nfnetlink_log merge, but I somehow missed it. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] PPTP helper: Add missing Kconfig dependencyHarald Welte
PPTP should not be selectable without conntrack enabled Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-07[ATM]: [br2684] if we free the skb, we should return 0Jean-Denis Boyer
From: "Jean-Denis Boyer" <jdboyer@mediatrix.com> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-06[ATM]: add support for LECS addresses learned from networkEric Kinzie
From: Eric Kinzie <ekinzie@cmf.nrl.navy.mil> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-06[SCTP] Fix sctp_get{pl}addrs() API to work with 32-bit apps on 64-bit kernels.Ivan Skytte Jørgensen
The old socket options are marked with a _OLD suffix so that the existing 32-bit apps on 32-bit kernels do not break. Signed-off-by: Ivan Skytte Jørgensen <isj-sctp@i1.dk> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-05[AX.25]: Fix packet socket crashRalf Baechle
Since changeset 98a82febb6340466824c3a453738d4fbd05db81a AX.25 is passing received IP and ARP packets to the stack through netif_rx() but we don't set the skb->mac.raw to right value which may result in a crash with applications that use a packet socket. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-05[IPSEC]: Document that policy direction is derived from the index.Herbert Xu
Here is a patch that adds a helper called xfrm_policy_id2dir to document the fact that the policy direction can be and is derived from the index. This is based on a patch by YOSHIFUJI Hideaki and 210313105@suda.edu.cn. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-05[IPV6]: Fix NS handing for proxy/anycast addressYOSHIFUJI Hideaki
Timer set up by pneigh_enqueue() ended up calling ndisc_rcv() via pndisc_redo(), which clears LOCALLY_ENQUEUED flag in NEIGH_CB(skb) and NS was queued again. Let's call ndisc_recv_ns() directly to avoid the loop. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-05[TCP]: BIC coding bug in Linux 2.6.13Stephen Hemminger
Missing parenthesis in causes BIC to be slow in increasing congestion window. Spotted by Injong Rhee. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-05[MCAST] ipv6: Fix address size in grec_sizeYan Zheng
Signed-Off-By: Yan Zheng <yanzheng@21cn.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[XFRM]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in xfrm code: net/xfrm/xfrm_policy.c:232:47: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[RPC]: fix sparse gfp nocast warningsRandy Dunlap
Fix nocast sparse warnings: net/rxrpc/call.c:2013:25: warning: implicit cast to nocast type net/rxrpc/connection.c:538:46: warning: implicit cast to nocast type net/sunrpc/sched.c:730:36: warning: implicit cast to nocast type net/sunrpc/sched.c:734:56: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[AF_KEY]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in net/key code: net/key/af_key.c:195:27: warning: implicit cast to nocast type net/key/af_key.c:1439:28: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[NETFILTER]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in nfnetlink code: net/netfilter/nfnetlink.c:204:43: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[IPVS]: fix sparse gfp nocast warningsRandy Dunlap
From: Randy Dunlap <rdunlap@xenotime.net> Fix implicit nocast warnings in ip_vs code: net/ipv4/ipvs/ip_vs_app.c:631:54: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[DECNET]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in decnet code: net/decnet/af_decnet.c:458:40: warning: implicit cast to nocast type net/decnet/dn_nsp_out.c:125:35: warning: implicit cast to nocast type net/decnet/dn_nsp_out.c:219:29: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[ATM]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in atm code: net/atm/atm_misc.c:35:44: warning: implicit cast to nocast type drivers/atm/fore200e.c:183:33: warning: implicit cast to nocast type Also use kzalloc() instead of kmalloc(). Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-04[NETFILTER]: Fix Kconfig typoHorst H. von Brand
Signed-off-by: Horst H. von Brand <vonbrand@inf.utfsm.cl> Signed-off-by: David S. Miller <davem@davemloft.net>
