commit 4576cd469d980317c4edd9173f8b694aa71ea3a3 upstream.
TPACKET_V3 stores variable length frames in fixed length blocks.
Blocks must be able to store a block header, optional private space
and at least one minimum sized frame.
Frames, even for a zero snaplen packet, store metadata headers and
optional reserved space.
In the block size bounds check, ensure that the frame of the
chosen configuration fits. This includes sockaddr_ll and optional
tp_reserve.
Syzbot was able to construct a ring with insuffient room for the
sockaddr_ll in the header of a zero-length frame, triggering an
out-of-bounds write in dev_parse_header.
Convert the comparison to less than, as zero is a valid snap len.
This matches the test for minimum tp_frame_size immediately below.
Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.")
Fixes: eb73190f4fbe ("net/packet: refine check for priv area size")
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
commit 6613b6173dee098997229caf1f3b961c49da75e6 upstream.
When first DCCP packet is SYNC or SYNCACK, we insert a new conntrack
that has an un-initialized timeout value, i.e. such entry could be
reaped at any time.
Mark them as INVALID and only ignore SYNC/SYNCACK when connection had
an old state.
Reported-by: syzbot+6f18401420df260e37ed@syzkaller.appspotmail.com
commit 45c180bc29babbedd6b8c01b975780ef44d9d09c upstream.
struct xfrm_userpolicy_type has two holes, so we should not
use C99 style initializer.
KMSAN report:
BUG: KMSAN: kernel-infoleak in copyout lib/iov_iter.c:140 [inline]
BUG: KMSAN: kernel-infoleak in _copy_to_iter+0x1b14/0x2800 lib/iov_iter.c:571
CPU: 1 PID: 4520 Comm: syz-executor841 Not tainted 4.17.0+ #5
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:113
kmsan_report+0x188/0x2a0 mm/kmsan/kmsan.c:1117
kmsan_internal_check_memory+0x138/0x1f0 mm/kmsan/kmsan.c:1211
kmsan_copy_to_user+0x7a/0x160 mm/kmsan/kmsan.c:1253
copy_to_iter include/linux/uio.h:106 [inline]
skb_copy_datagram_iter+0x422/0xfa0 net/core/datagram.c:431
skb_copy_datagram_msg include/linux/skbuff.h:3268 [inline]
netlink_recvmsg+0x6f1/0x1900 net/netlink/af_netlink.c:1959
sock_recvmsg_nosec net/socket.c:802 [inline]
sock_recvmsg+0x1d6/0x230 net/socket.c:809
___sys_recvmsg+0x3fe/0x810 net/socket.c:2279
__sys_recvmmsg+0x58e/0xe30 net/socket.c:2391
do_sys_recvmmsg+0x2a6/0x3e0 net/socket.c:2472
__do_sys_recvmmsg net/socket.c:2485 [inline]
__se_sys_recvmmsg net/socket.c:2481 [inline]
__x64_sys_recvmmsg+0x15d/0x1c0 net/socket.c:2481
do_syscall_64+0x15b/0x230 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x446ce9
RSP: 002b:00007fc307918db8 EFLAGS: 00000293 ORIG_RAX: 000000000000012b
RAX: ffffffffffffffda RBX: 00000000006dbc24 RCX: 0000000000446ce9
RDX: 000000000000000a RSI: 0000000020005040 RDI: 0000000000000003
RBP: 00000000006dbc20 R08: 0000000020004e40 R09: 0000000000000000
R10: 0000000040000000 R11: 0000000000000293 R12: 0000000000000000
R13: 00007ffc8d2df32f R14: 00007fc3079199c0 R15: 0000000000000001
Uninit was stored to memory at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline]
kmsan_save_stack mm/kmsan/kmsan.c:294 [inline]
kmsan_internal_chain_origin+0x12b/0x210 mm/kmsan/kmsan.c:685
kmsan_memcpy_origins+0x11d/0x170 mm/kmsan/kmsan.c:527
__msan_memcpy+0x109/0x160 mm/kmsan/kmsan_instr.c:413
__nla_put lib/nlattr.c:569 [inline]
nla_put+0x276/0x340 lib/nlattr.c:627
copy_to_user_policy_type net/xfrm/xfrm_user.c:1678 [inline]
dump_one_policy+0xbe1/0x1090 net/xfrm/xfrm_user.c:1708
xfrm_policy_walk+0x45a/0xd00 net/xfrm/xfrm_policy.c:1013
xfrm_dump_policy+0x1c0/0x2a0 net/xfrm/xfrm_user.c:1749
netlink_dump+0x9b5/0x1550 net/netlink/af_netlink.c:2226
__netlink_dump_start+0x1131/0x1270 net/netlink/af_netlink.c:2323
netlink_dump_start include/linux/netlink.h:214 [inline]
xfrm_user_rcv_msg+0x8a3/0x9b0 net/xfrm/xfrm_user.c:2577
netlink_rcv_skb+0x37e/0x600 net/netlink/af_netlink.c:2448
xfrm_netlink_rcv+0xb2/0xf0 net/xfrm/xfrm_user.c:2598
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0x1680/0x1750 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901
sock_sendmsg_nosec net/socket.c:629 [inline]
sock_sendmsg net/socket.c:639 [inline]
___sys_sendmsg+0xec8/0x1320 net/socket.c:2117
__sys_sendmsg net/socket.c:2155 [inline]
__do_sys_sendmsg net/socket.c:2164 [inline]
__se_sys_sendmsg net/socket.c:2162 [inline]
__x64_sys_sendmsg+0x331/0x460 net/socket.c:2162
Local variable description: ----upt.i@dump_one_policy
Variable was created at:
dump_one_policy+0x78/0x1090 net/xfrm/xfrm_user.c:1689
Byte 130 of 137 is uninitialized
Memory access starts at ffff88019550407f
Fixes: c0144beaeca42 ("[XFRM] netlink: Use nla_put()/NLA_PUT() variantes")
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit e56b8ce363a36fb7b74b80aaa5cc9084f2c908b4 ]
Attempt to make cryptic TCP seq number error messages clearer by
(1) identifying the source of the message as "TCP", (2) identifying the
errors as "seq # bug", and (3) grouping the field identifiers and values
by separating them with commas.
E.g., the following message is changed from:
recvmsg bug 2: copied 73BCB6CD seq 70F17CBE rcvnxt 73BCB9AA fl 0
WARNING: CPU: 2 PID: 1501 at /linux/net/ipv4/tcp.c:1881 tcp_recvmsg+0x649/0xb90
to:
TCP recvmsg seq # bug 2: copied 73BCB6CD, seq 70F17CBE, rcvnxt 73BCB9AA, fl 0
WARNING: CPU: 2 PID: 1501 at /linux/net/ipv4/tcp.c:2011 tcp_recvmsg+0x694/0xba0
Suggested-by: 積丹尼 Dan Jacobson <jidanni@jidanni.org>
[ Upstream commit a69258f7aa2623e0930212f09c586fd06674ad79 ]
After fixing the way DCTCP tracking delayed ACKs, the delayed-ACK
related callbacks are no longer needed
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Lawrence Brakmo <brakmo@fb.com>
[ Upstream commit 993675a3100b16a4c80dfd70cbcde8ea7127b31d ]
If variable length link layer headers result in a packet shorter
than dev->hard_header_len, reset the network header offset. Else
skb->mac_len may exceed skb->len after skb_mac_reset_len.
packet_sendmsg_spkt already has similar logic.
Fixes: b84bbaf7a6c8 ("packet: in packet_snd start writing at link layer allocation")
[ Upstream commit 2045cdfa1b40d66f126f3fd05604fc7c754f0022 ]
Loading the nf_conntrack module with doubled hashsize parameter, i.e.
modprobe nf_conntrack hashsize=12345 hashsize=12345
causes NULL-ptr deref.
If 'hashsize' specified twice, the nf_conntrack_set_hashsize() function
will be called also twice.
The first nf_conntrack_set_hashsize() call will set the
'nf_conntrack_htable_size' variable:
/* On boot, we can set this without any fancy locking. */
if (!nf_conntrack_htable_size)
return param_set_uint(val, kp);
But on the second invocation, the nf_conntrack_htable_size is already set,
so the nf_conntrack_set_hashsize() will take a different path and call
the nf_conntrack_hash_resize() function. Which will crash on the attempt
to dereference 'nf_conntrack_hash' pointer:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
RIP: 0010:nf_conntrack_hash_resize+0x255/0x490 [nf_conntrack]
Call Trace:
nf_conntrack_set_hashsize+0xcd/0x100 [nf_conntrack]
parse_args+0x1f9/0x5a0
load_module+0x1281/0x1a50
__se_sys_finit_module+0xbe/0xf0
do_syscall_64+0x7c/0x390
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fix this, by checking !nf_conntrack_hash instead of
!nf_conntrack_htable_size. nf_conntrack_hash will be initialized only
after the module loaded, so the second invocation of the
nf_conntrack_set_hashsize() won't crash, it will just reinitialize
nf_conntrack_htable_size again.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
[ Upstream commit 38230a3e0e0933bbcf5df6fa469ba0667f667568 ]
the control action in the common member of struct tcf_tunnel_key must be a
valid value, as it can contain the chain index when 'goto chain' is used.
Ensure that the control action can be read as x->tcfa_action, when x is a
pointer to struct tc_action and x->ops->type is TCA_ACT_TUNNEL_KEY, to
prevent the following command:
# tc filter add dev $h2 ingress protocol ip pref 1 handle 101 flower \
> $tcflags dst_mac $h2mac action tunnel_key unset goto chain 1
from causing a NULL dereference when a matching packet is received:
PGD 80000001097ac067 P4D 80000001097ac067 PUD 103b0a067 PMD 0
Oops: 0000 [#1] SMP PTI
CPU: 0 PID: 3491 Comm: mausezahn Tainted: G E 4.18.0-rc2.auguri+ #421
Hardware name: Hewlett-Packard HP Z220 CMT Workstation/1790, BIOS K51 v01.58 02/07/2013
RIP: 0010:tcf_action_exec+0xb8/0x100
Code: 00 00 00 20 74 1d 83 f8 03 75 09 49 83 c4 08 4d 39 ec 75 bc 48 83 c4 10 5b 5d 41 5c 41 5d 41 5e 41 5f c3 49 8b 97 a8 00 00 00 <48> 8b 12 48 89 55 00 48 83 c4 10 5b 5d 41 5c 41 5d 41 5e 41 5f c3
RSP: 0018:ffff95145ea03c40 EFLAGS: 00010246
RAX: 0000000020000001 RBX: ffff9514499e5800 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000002 RDI: 0000000000000000
RBP: ffff95145ea03e60 R08: 0000000000000000 R09: ffff95145ea03c9c
R10: ffff95145ea03c78 R11: 0000000000000008 R12: ffff951456a69800
R13: ffff951456a69808 R14: 0000000000000001 R15: ffff95144965ee40
FS: 00007fd67ee11740(0000) GS:ffff95145ea00000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 00000001038a2006 CR4: 00000000001606f0
Call Trace:
<IRQ>
fl_classify+0x1ad/0x1c0 [cls_flower]
? __update_load_avg_se.isra.47+0x1ca/0x1d0
? update_load_avg+0x665/0x690
? kmem_cache_alloc+0x38/0x1c0
tcf_classify+0x89/0x140
__netif_receive_skb_core+0x5ea/0xb70
? enqueue_entity+0xd0/0x270
? process_backlog+0x97/0x150
net_rx_action+0x14b/0x3e0
__do_softirq+0xde/0x2b4
do_softirq_own_stack+0x2a/0x40
</IRQ>
do_softirq.part.18+0x49/0x50
__local_bh_enable_ip+0x49/0x50
__dev_queue_xmit+0x4ab/0x8a0
? wait_woken+0x80/0x80
? packet_sendmsg+0x38f/0x810
? __dev_queue_xmit+0x8a0/0x8a0
sock_sendmsg+0x36/0x40
__sys_sendto+0x10e/0x140
? do_vfs_ioctl+0xa4/0x630
? syscall_trace_enter+0x1df/0x2e0
? __audit_syscall_exit+0x22a/0x290
__x64_sys_sendto+0x24/0x30
do_syscall_64+0x5b/0x180
RIP: 0033:0x7fd67e18dc93
Code: 48 8b 0d 18 83 20 00 f7 d8 64 89 01 48 83 c8 ff c3 66 0f 1f 44 00 00 83 3d 59 c7 20 00 00 75 13 49 89 ca b8 2c 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 34 c3 48 83 ec 08 e8 2b f7 ff ff 48 89 04 24
RSP: 002b:00007ffe0189b748 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000020ca010 RCX: 00007fd67e18dc93
RDX: 0000000000000062 RSI: 00000000020ca322 RDI: 0000000000000003
RBP: 00007ffe0189b780 R08: 00007ffe0189b760 R09: 0000000000000014
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000062
R13: 00000000020ca322 R14: 00007ffe0189b760 R15: 0000000000000003
Modules linked in: act_tunnel_key act_gact cls_flower sch_ingress vrf veth act_csum(E) xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ipt_REJECT nf_reject_ipv4 tun bridge stp llc ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter intel_rapl snd_hda_codec_hdmi x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_realtek coretemp snd_hda_codec_generic kvm_intel kvm irqbypass snd_hda_intel crct10dif_pclmul crc32_pclmul hp_wmi ghash_clmulni_intel pcbc snd_hda_codec aesni_intel sparse_keymap rfkill snd_hda_core snd_hwdep snd_seq crypto_simd iTCO_wdt gpio_ich iTCO_vendor_support wmi_bmof cryptd mei_wdt glue_helper snd_seq_device snd_pcm pcspkr snd_timer snd i2c_i801 lpc_ich sg soundcore wmi mei_me
mei ie31200_edac nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c sd_mod sr_mod cdrom i915 video i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci crc32c_intel libahci serio_raw sfc libata mtd drm ixgbe mdio i2c_core e1000e dca
---[ end trace 1ab8b5b5d4639dfc ]---
Kernel panic - not syncing: Fatal exception in interrupt
Kernel Offset: 0x11400000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff)
---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
Fixes: d0f6dd8a914f ("net/sched: Introduce act_tunnel_key")
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
[ Upstream commit fdf5fd3975666804118e62c69de25dc85cc0909c ]
The broadcast node id should only be sent with the control port id.
Signed-off-by: Arun Kumar Neelakantam <aneela@codeaurora.org>
[ Upstream commit a9ba23d48dbc6ffd08426bb10f05720e0b9f5c14 ]
At present the ipv6_renew_options_kern() function ends up calling into
access_ok() which is problematic if done from inside an interrupt as
access_ok() calls WARN_ON_IN_IRQ() on some (all?) architectures
(x86-64 is affected). Example warning/backtrace is shown below:
WARNING: CPU: 1 PID: 3144 at lib/usercopy.c:11 _copy_from_user+0x85/0x90
Call Trace:
<IRQ>
ipv6_renew_option+0xb2/0xf0
ipv6_renew_options+0x26a/0x340
ipv6_renew_options_kern+0x2c/0x40
calipso_req_setattr+0x72/0xe0
netlbl_req_setattr+0x126/0x1b0
selinux_netlbl_inet_conn_request+0x80/0x100
selinux_inet_conn_request+0x6d/0xb0
security_inet_conn_request+0x32/0x50
tcp_conn_request+0x35f/0xe00
? __lock_acquire+0x250/0x16c0
? selinux_socket_sock_rcv_skb+0x1ae/0x210
? tcp_rcv_state_process+0x289/0x106b
? tcp_v6_do_rcv+0x1a7/0x3c0
tcp_v6_rcv+0xc82/0xcf0
ip6_input_finish+0x10d/0x690
ip6_input+0x45/0x1e0
? ip6_rcv_finish+0x1d0/0x1d0
ipv6_rcv+0x32b/0x880
? ip6_make_skb+0x1e0/0x1e0
__netif_receive_skb_core+0x6f2/0xdf0
? process_backlog+0x85/0x250
? process_backlog+0xec/0x250
net_rx_action+0x153/0x480
__do_softirq+0xd9/0x4f7
</IRQ>
While not present in the backtrace, ipv6_renew_option() ends up calling
access_ok() via the following chain:
access_ok()
_copy_from_user()
copy_from_user()
ipv6_renew_option()
The fix presented in this patch is to perform the userspace copy
earlier in the call chain such that it is only called when the option
data is actually coming from userspace; that place is
do_ipv6_setsockopt(). Not only does this solve the problem seen in
the backtrace above, it also allows us to simplify the code quite a
bit by removing ipv6_renew_options_kern() completely. We also take
this opportunity to cleanup ipv6_renew_options()/ipv6_renew_option()
a small amount as well.
This patch is heavily based on a rough patch by Al Viro. I've taken
his original patch, converted a kmemdup() call in do_ipv6_setsockopt()
to a memdup_user() call, made better use of the e_inval jump target in
the same function, and cleaned up the use ipv6_renew_option() by
ipv6_renew_options().
CC: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit d376bef9c29b3c65aeee4e785fffcd97ef0a9a81 ]
nft_compat relies on xt_request_find_match to increment
refcount of the module that provides the match/target.
The (builtin) icmp matches did't set the module owner so it
was possible to rmmod ip(6)tables while icmp extensions were still in use.
[ Upstream commit b30c122c0bbb0a1dc413085e177ea09467e65fdb ]
Otherwise NetworkManager (and iproute alike) is not able to identify the
parent IEEE 802.15.4 interface of a 6LoWPAN link.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Acked-by: Alexander Aring <aring@mojatatu.com>
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
[ Upstream commit 188f60ab8e787fcbb5ac9d64ede23a0070231f09 ]
Commit 9757235f451c, "nl80211: correct checks for
NL80211_MESHCONF_HT_OPMODE value") relaxed the range for the HT
operation field in meshconf, while also adding checks requiring
the non-greenfield and non-ht-sta bits to be set in certain
circumstances. The latter bit is actually reserved for mesh BSSes
according to Table 9-168 in 802.11-2016, so in fact it should not
be set.
wpa_supplicant sets these bits because the mesh and AP code share
the same implementation, but authsae does not. As a result, some
meshconf updates from authsae which set only the NONHT_MIXED
protection bits were being rejected.
In order to avoid breaking userspace by changing the rules again,
simply accept the values with or without the bits set, and mask
off the reserved bit to match the spec.
While in here, update the 802.11-2012 reference to 802.11-2016.
Fixes: 9757235f451c ("nl80211: correct checks for NL80211_MESHCONF_HT_OPMODE value")
Cc: Masashi Honma <masashi.honma@gmail.com>
Signed-off-by: Bob Copeland <bobcopeland@fb.com>
Reviewed-by: Masashi Honma <masashi.honma@gmail.com>
[ Upstream commit dffd22aed2aa1e804bccf19b30a421e89ee2ae61 ]
When proc_dostring() is called with a non-zero offset in strict mode, it
doesn't just write to the ->data buffer, it also reads. Make sure it
doesn't read uninitialized data.
Fixes: c6ac37d8d884 ("netfilter: nf_log: fix error on write NONE to [...]")
Signed-off-by: Jann Horn <jannh@google.com>
[ Upstream commit 9713cb0cf19f1cec6c007e3b37be0697042b6720 ]
A reference for the best gateway is taken when the list of gateways in the
mesh is sent via netlink. This is necessary to check whether the currently
dumped entry is the currently selected gateway or not. This information is
then transferred as flag BATADV_ATTR_FLAG_BEST.
After the comparison of the current entry is done,
batadv_v_gw_dump_entry() has to decrease the reference counter again.
Otherwise the reference will be held and thus prevents a proper shutdown of
the batman-adv interfaces (and some of the interfaces enslaved in it).
Fixes: b71bb6f924fe ("batman-adv: add B.A.T.M.A.N. V bat_gw_dump implementations")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Acked-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
[ Upstream commit b5685d2687d6612adf5eac519eb7008f74dfd1ec ]
batadv_iv_gw_dump_entry() has to decrease the reference counter again.
Fixes: efb766af06e3 ("batman-adv: add B.A.T.M.A.N. IV bat_gw_dump implementations")
Reported-by: Andreas Ziegler <dev@andreas-ziegler.de>
Tested-by: Andreas Ziegler <dev@andreas-ziegler.de>
[ Upstream commit 6c6da92808442908287fae8ebb0ca041a52469f4 ]
After recieving MLD querys, we update idev->mc_maxdelay with max_delay
from query header. This make the later unsolicited reports have the same
interval with mc_maxdelay, which means we may send unsolicited reports with
long interval time instead of default configured interval time.
Also as we will not call ipv6_mc_reset() after device up. This issue will
be there even after leave the group and join other groups.
Fixes: fc4eba58b4c14 ("ipv6: make unsolicited report intervals configurable for mld")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit 7892bd081045222b9e4027fec279a28d6fe7aa66 ]
if dev_get_valid_name failed, propagate its return code
and remove the setting err to ENODEV, it will be set to
0 again before dev_change_net_namespace exits.
Signed-off-by: Li RongQing <lirongqing@baidu.com>
[ Upstream commit 9ce7bc036ae4cfe3393232c86e9e1fea2153c237 ]
It is a waste of memory to use a full "struct netns_sysctl_ipv6"
while only one pointer is really used, considering netns_sysctl_ipv6
keeps growing.
Also, since "struct netns_frags" has cache line alignment,
it is better to move the frags_hdr pointer outside, otherwise
we spend a full cache line for this pointer.
This saves 192 bytes of memory per netns.
Fixes: c038a767cd69 ("ipv6: add a new namespace for nf_conntrack_reasm")
commit 4e1a720d0312fd510699032c7694a362a010170f upstream.
slub debug reported:
[ 440.648642] =============================================================================
[ 440.648649] BUG kmalloc-1024 (Tainted: G BU O ): Poison overwritten
[ 440.648651] -----------------------------------------------------------------------------
[ 440.648655] INFO: 0xe70f4bec-0xe70f4bec. First byte 0x6a instead of 0x6b
[ 440.648665] INFO: Allocated in sk_prot_alloc+0x6b/0xc6 age=33155 cpu=1 pid=1047
[ 440.648671] ___slab_alloc.constprop.24+0x1fc/0x292
[ 440.648675] __slab_alloc.isra.18.constprop.23+0x1c/0x25
[ 440.648677] __kmalloc+0xb6/0x17f
[ 440.648680] sk_prot_alloc+0x6b/0xc6
[ 440.648683] sk_alloc+0x1e/0xa1
[ 440.648700] sco_sock_alloc.constprop.6+0x26/0xaf [bluetooth]
[ 440.648716] sco_connect_cfm+0x166/0x281 [bluetooth]
[ 440.648731] hci_conn_request_evt.isra.53+0x258/0x281 [bluetooth]
[ 440.648746] hci_event_packet+0x28b/0x2326 [bluetooth]
[ 440.648759] hci_rx_work+0x161/0x291 [bluetooth]
[ 440.648764] process_one_work+0x163/0x2b2
[ 440.648767] worker_thread+0x1a9/0x25c
[ 440.648770] kthread+0xf8/0xfd
[ 440.648774] ret_from_fork+0x2e/0x38
[ 440.648779] INFO: Freed in __sk_destruct+0xd3/0xdf age=3815 cpu=1 pid=1047
[ 440.648782] __slab_free+0x4b/0x27a
[ 440.648784] kfree+0x12e/0x155
[ 440.648787] __sk_destruct+0xd3/0xdf
[ 440.648790] sk_destruct+0x27/0x29
[ 440.648793] __sk_free+0x75/0x91
[ 440.648795] sk_free+0x1c/0x1e
[ 440.648810] sco_sock_kill+0x5a/0x5f [bluetooth]
[ 440.648825] sco_conn_del+0x8e/0xba [bluetooth]
[ 440.648840] sco_disconn_cfm+0x3a/0x41 [bluetooth]
[ 440.648855] hci_event_packet+0x45e/0x2326 [bluetooth]
[ 440.648868] hci_rx_work+0x161/0x291 [bluetooth]
[ 440.648872] process_one_work+0x163/0x2b2
[ 440.648875] worker_thread+0x1a9/0x25c
[ 440.648877] kthread+0xf8/0xfd
[ 440.648880] ret_from_fork+0x2e/0x38
[ 440.648884] INFO: Slab 0xf4718580 objects=27 used=27 fp=0x (null) flags=0x40008100
[ 440.648886] INFO: Object 0xe70f4b88 @offset=19336 fp=0xe70f54f8
When KASAN was enabled, it reported:
[ 210.096613] ==================================================================
[ 210.096634] BUG: KASAN: use-after-free in ex_handler_refcount+0x5b/0x127
[ 210.096641] Write of size 4 at addr ffff880107e17160 by task kworker/u9:1/2040
[ 210.096651] CPU: 1 PID: 2040 Comm: kworker/u9:1 Tainted: G U O 4.14.47-20180606+ #2
[ 210.096654] Hardware name: , BIOS 2017.01-00087-g43e04de 08/30/2017
[ 210.096693] Workqueue: hci0 hci_rx_work [bluetooth]
[ 210.096698] Call Trace:
[ 210.096711] dump_stack+0x46/0x59
[ 210.096722] print_address_description+0x6b/0x23b
[ 210.096729] ? ex_handler_refcount+0x5b/0x127
[ 210.096736] kasan_report+0x220/0x246
[ 210.096744] ex_handler_refcount+0x5b/0x127
[ 210.096751] ? ex_handler_clear_fs+0x85/0x85
[ 210.096757] fixup_exception+0x8c/0x96
[ 210.096766] do_trap+0x66/0x2c1
[ 210.096773] do_error_trap+0x152/0x180
[ 210.096781] ? fixup_bug+0x78/0x78
[ 210.096817] ? hci_debugfs_create_conn+0x244/0x26a [bluetooth]
[ 210.096824] ? __schedule+0x113b/0x1453
[ 210.096830] ? sysctl_net_exit+0xe/0xe
[ 210.096837] ? __wake_up_common+0x343/0x343
[ 210.096843] ? insert_work+0x107/0x163
[ 210.096850] invalid_op+0x1b/0x40
[ 210.096888] RIP: 0010:hci_debugfs_create_conn+0x244/0x26a [bluetooth]
[ 210.096892] RSP: 0018:ffff880094a0f970 EFLAGS: 00010296
[ 210.096898] RAX: 0000000000000000 RBX: ffff880107e170e8 RCX: ffff880107e17160
[ 210.096902] RDX: 000000000000002f RSI: ffff88013b80ed40 RDI: ffffffffa058b940
[ 210.096906] RBP: ffff88011b2b0578 R08: 00000000852f0ec9 R09: ffffffff81cfcf9b
[ 210.096909] R10: 00000000d21bdad7 R11: 0000000000000001 R12: ffff8800967b0488
[ 210.096913] R13: ffff880107e17168 R14: 0000000000000068 R15: ffff8800949c0008
[ 210.096920] ? __sk_destruct+0x2c6/0x2d4
[ 210.096959] hci_event_packet+0xff5/0x7de2 [bluetooth]
[ 210.096969] ? __local_bh_enable_ip+0x43/0x5b
[ 210.097004] ? l2cap_sock_recv_cb+0x158/0x166 [bluetooth]
[ 210.097039] ? hci_le_meta_evt+0x2bb3/0x2bb3 [bluetooth]
[ 210.097075] ? l2cap_ertm_init+0x94e/0x94e [bluetooth]
[ 210.097093] ? xhci_urb_enqueue+0xbd8/0xcf5 [xhci_hcd]
[ 210.097102] ? __accumulate_pelt_segments+0x24/0x33
[ 210.097109] ? __accumulate_pelt_segments+0x24/0x33
[ 210.097115] ? __update_load_avg_se.isra.2+0x217/0x3a4
[ 210.097122] ? set_next_entity+0x7c3/0x12cd
[ 210.097128] ? pick_next_entity+0x25e/0x26c
[ 210.097135] ? pick_next_task_fair+0x2ca/0xc1a
[ 210.097141] ? switch_mm_irqs_off+0x346/0xb4f
[ 210.097147] ? __switch_to+0x769/0xbc4
[ 210.097153] ? compat_start_thread+0x66/0x66
[ 210.097188] ? hci_conn_check_link_mode+0x1cd/0x1cd [bluetooth]
[ 210.097195] ? finish_task_switch+0x392/0x431
[ 210.097228] ? hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097260] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097269] process_one_work+0x579/0x9e9
[ 210.097277] worker_thread+0x68f/0x804
[ 210.097285] kthread+0x31c/0x32b
[ 210.097292] ? rescuer_thread+0x70c/0x70c
[ 210.097299] ? kthread_create_on_node+0xa3/0xa3
[ 210.097306] ret_from_fork+0x35/0x40
[ 210.097314] Allocated by task 2040:
[ 210.097323] kasan_kmalloc.part.1+0x51/0xc7
[ 210.097328] __kmalloc+0x17f/0x1b6
[ 210.097335] sk_prot_alloc+0xf2/0x1a3
[ 210.097340] sk_alloc+0x22/0x297
[ 210.097375] sco_sock_alloc.constprop.7+0x23/0x202 [bluetooth]
[ 210.097410] sco_connect_cfm+0x2d0/0x566 [bluetooth]
[ 210.097443] hci_conn_request_evt.isra.53+0x6d3/0x762 [bluetooth]
[ 210.097476] hci_event_packet+0x85e/0x7de2 [bluetooth]
[ 210.097507] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097512] process_one_work+0x579/0x9e9
[ 210.097517] worker_thread+0x68f/0x804
[ 210.097523] kthread+0x31c/0x32b
[ 210.097529] ret_from_fork+0x35/0x40
[ 210.097533] Freed by task 2040:
[ 210.097539] kasan_slab_free+0xb3/0x15e
[ 210.097544] kfree+0x103/0x1a9
[ 210.097549] __sk_destruct+0x2c6/0x2d4
[ 210.097584] sco_conn_del.isra.1+0xba/0x10e [bluetooth]
[ 210.097617] hci_event_packet+0xff5/0x7de2 [bluetooth]
[ 210.097648] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097653] process_one_work+0x579/0x9e9
[ 210.097658] worker_thread+0x68f/0x804
[ 210.097663] kthread+0x31c/0x32b
[ 210.097670] ret_from_fork+0x35/0x40
[ 210.097676] The buggy address belongs to the object at ffff880107e170e8
which belongs to the cache kmalloc-1024 of size 1024
[ 210.097681] The buggy address is located 120 bytes inside of
1024-byte region [ffff880107e170e8, ffff880107e174e8)
[ 210.097683] The buggy address belongs to the page:
[ 210.097689] page:ffffea00041f8400 count:1 mapcount:0 mapping: (null) index:0xffff880107e15b68 compound_mapcount: 0
[ 210.110194] flags: 0x8000000000008100(slab|head)
[ 210.115441] raw: 8000000000008100 0000000000000000 ffff880107e15b68 0000000100170016
[ 210.115448] raw: ffffea0004a47620 ffffea0004b48e20 ffff88013b80ed40 0000000000000000
[ 210.115451] page dumped because: kasan: bad access detected
[ 210.115454] Memory state around the buggy address:
[ 210.115460] ffff880107e17000: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 210.115465] ffff880107e17080: fc fc fc fc fc fc fc fc fc fc fc fc fc fb fb fb
[ 210.115469] >ffff880107e17100: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115472] ^
[ 210.115477] ffff880107e17180: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115481] ffff880107e17200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115483] ==================================================================
And finally when BT_DBG() and ftrace was enabled it showed:
<...>-14979 [001] .... 186.104191: sco_sock_kill <-sco_sock_close
<...>-14979 [001] .... 186.104191: sco_sock_kill <-sco_sock_release
<...>-14979 [001] .... 186.104192: sco_sock_kill: sk ef0497a0 state 9
<...>-14979 [001] .... 186.104193: bt_sock_unlink <-sco_sock_kill
kworker/u9:2-792 [001] .... 186.104246: sco_sock_kill <-sco_conn_del
kworker/u9:2-792 [001] .... 186.104248: sco_sock_kill: sk ef0497a0 state 9
kworker/u9:2-792 [001] .... 186.104249: bt_sock_unlink <-sco_sock_kill
kworker/u9:2-792 [001] .... 186.104250: sco_sock_destruct <-__sk_destruct
kworker/u9:2-792 [001] .... 186.104250: sco_sock_destruct: sk ef0497a0
kworker/u9:2-792 [001] .... 186.104860: hci_conn_del <-hci_event_packet
kworker/u9:2-792 [001] .... 186.104864: hci_conn_del: hci0 hcon ef0484c0 handle 266
Only in the failed case, sco_sock_kill() gets called with the same sock
pointer two times. Add a check for SOCK_DEAD to avoid continue killing
a socket which has already been killed.
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
[ Upstream commit a51c76b4dfb30496dc65396a957ef0f06af7fb22 ]
Fix tcf_unbind_filter missing in cls_matchall as this will trigger
WARN_ON() in cbq_destroy_class().
Fixes: fd62d9f5c575f ("net/sched: matchall: Fix configuration race")
Reported-by: Li Shuang <shuali@redhat.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 2df8bee5654bb2b7312662ca6810d4dc16b0b67f ]
Li Shuang reported the following crash:
[ 71.267724] BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
[ 71.276456] PGD 800000085d9bd067 P4D 800000085d9bd067 PUD 859a0b067 PMD 0
[ 71.284127] Oops: 0000 [#1] SMP PTI
[ 71.288015] CPU: 12 PID: 2386 Comm: tc Not tainted 4.18.0-rc8.latest+ #131
[ 71.295686] Hardware name: Dell Inc. PowerEdge R730/0WCJNT, BIOS 2.1.5 04/11/2016
[ 71.304037] RIP: 0010:tcindex_delete+0x72/0x280 [cls_tcindex]
[ 71.310446] Code: 00 31 f6 48 87 75 20 48 85 f6 74 11 48 8b 47 18 48 8b 40 08 48 8b 40 50 e8 fb a6 f8 fc 48 85 db 0f 84 dc 00 00 00 48 8b 73 18 <8b> 56 04 48 8d 7e 04 85 d2 0f 84 7b 01 00
[ 71.331517] RSP: 0018:ffffb45207b3f898 EFLAGS: 00010282
[ 71.337345] RAX: ffff8ad3d72d6360 RBX: ffff8acc84393680 RCX: 000000000000002e
[ 71.345306] RDX: ffff8ad3d72c8570 RSI: 0000000000000000 RDI: ffff8ad847a45800
[ 71.353277] RBP: ffff8acc84393688 R08: ffff8ad3d72c8400 R09: 0000000000000000
[ 71.361238] R10: ffff8ad3de786e00 R11: 0000000000000000 R12: ffffb45207b3f8c7
[ 71.369199] R13: ffff8ad3d93bd2a0 R14: 000000000000002e R15: ffff8ad3d72c9600
[ 71.377161] FS: 00007f9d3ec3e740(0000) GS:ffff8ad3df980000(0000) knlGS:0000000000000000
[ 71.386188] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 71.392597] CR2: 0000000000000004 CR3: 0000000852f06003 CR4: 00000000001606e0
[ 71.400558] Call Trace:
[ 71.403299] tcindex_destroy_element+0x25/0x40 [cls_tcindex]
[ 71.409611] tcindex_walk+0xbb/0x110 [cls_tcindex]
[ 71.414953] tcindex_destroy+0x44/0x90 [cls_tcindex]
[ 71.420492] ? tcindex_delete+0x280/0x280 [cls_tcindex]
[ 71.426323] tcf_proto_destroy+0x16/0x40
[ 71.430696] tcf_chain_flush+0x51/0x70
[ 71.434876] tcf_block_put_ext.part.30+0x8f/0x1b0
[ 71.440122] tcf_block_put+0x4d/0x70
[ 71.444108] cbq_destroy+0x4d/0xd0 [sch_cbq]
[ 71.448869] qdisc_destroy+0x62/0x130
[ 71.452951] dsmark_destroy+0x2a/0x70 [sch_dsmark]
[ 71.458300] qdisc_destroy+0x62/0x130
[ 71.462373] qdisc_graft+0x3ba/0x470
[ 71.466359] tc_get_qdisc+0x2a6/0x2c0
[ 71.470443] ? cred_has_capability+0x7d/0x130
[ 71.475307] rtnetlink_rcv_msg+0x263/0x2d0
[ 71.479875] ? rtnl_calcit.isra.30+0x110/0x110
[ 71.484832] netlink_rcv_skb+0x4d/0x130
[ 71.489109] netlink_unicast+0x1a3/0x250
[ 71.493482] netlink_sendmsg+0x2ae/0x3a0
[ 71.497859] sock_sendmsg+0x36/0x40
[ 71.501748] ___sys_sendmsg+0x26f/0x2d0
[ 71.506029] ? handle_pte_fault+0x586/0xdf0
[ 71.510694] ? __handle_mm_fault+0x389/0x500
[ 71.515457] ? __sys_sendmsg+0x5e/0xa0
[ 71.519636] __sys_sendmsg+0x5e/0xa0
[ 71.523626] do_syscall_64+0x5b/0x180
[ 71.527711] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 71.533345] RIP: 0033:0x7f9d3e257f10
[ 71.537331] Code: c3 48 8b 05 82 6f 2c 00 f7 db 64 89 18 48 83 cb ff eb dd 0f 1f 80 00 00 00 00 83 3d 8d d0 2c 00 00 75 10 b8 2e 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8
[ 71.558401] RSP: 002b:00007fff6f893398 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 71.566848] RAX: ffffffffffffffda RBX: 000000005b71274d RCX: 00007f9d3e257f10
[ 71.574810] RDX: 0000000000000000 RSI: 00007fff6f8933e0 RDI: 0000000000000003
[ 71.582770] RBP: 00007fff6f8933e0 R08: 000000000000ffff R09: 0000000000000003
[ 71.590729] R10: 00007fff6f892e20 R11: 0000000000000246 R12: 0000000000000000
[ 71.598689] R13: 0000000000662ee0 R14: 0000000000000000 R15: 0000000000000000
[ 71.606651] Modules linked in: sch_cbq cls_tcindex sch_dsmark xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_coni
[ 71.685425] libahci i2c_algo_bit i2c_core i40e libata dca mdio megaraid_sas dm_mirror dm_region_hash dm_log dm_mod
[ 71.697075] CR2: 0000000000000004
[ 71.700792] ---[ end trace f604eb1acacd978b ]---
Reproducer:
tc qdisc add dev lo handle 1:0 root dsmark indices 64 set_tc_index
tc filter add dev lo parent 1:0 protocol ip prio 1 tcindex mask 0xfc shift 2
tc qdisc add dev lo parent 1:0 handle 2:0 cbq bandwidth 10Mbit cell 8 avpkt 1000 mpu 64
tc class add dev lo parent 2:0 classid 2:1 cbq bandwidth 10Mbit rate 1500Kbit avpkt 1000 prio 1 bounded isolated allot 1514 weight 1 maxburst 10
tc filter add dev lo parent 2:0 protocol ip prio 1 handle 0x2e tcindex classid 2:1 pass_on
tc qdisc add dev lo parent 2:1 pfifo limit 5
tc qdisc del dev lo root
This is because in tcindex_set_parms, when there is no old_r, we set new
exts to cr.exts. And we didn't set it to filter when r == &new_filter_result.
Then in tcindex_delete() -> tcf_exts_get_net(), we will get NULL pointer
dereference as we didn't init exts.
Fix it by moving tcf_exts_change() after "if (old_r && old_r != r)" check.
Then we don't need "cr" as there is no errout after that.
Fixes: bf63ac73b3e13 ("net_sched: fix an oops in tcindex filter")
[ Upstream commit 008369dcc5f7bfba526c98054f8525322acf0ea3 ]
Li Shuang reported the following warn:
[ 733.484610] WARNING: CPU: 6 PID: 21123 at net/sched/sch_cbq.c:1418 cbq_destroy_class+0x5d/0x70 [sch_cbq]
[ 733.495190] Modules linked in: sch_cbq cls_tcindex sch_dsmark rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd grace fscache xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat l
[ 733.574155] syscopyarea sysfillrect sysimgblt fb_sys_fops ttm drm igb ixgbe ahci libahci i2c_algo_bit libata i40e i2c_core dca mdio megaraid_sas dm_mirror dm_region_hash dm_log dm_mod
[ 733.592500] CPU: 6 PID: 21123 Comm: tc Not tainted 4.18.0-rc8.latest+ #131
[ 733.600169] Hardware name: Dell Inc. PowerEdge R730/0WCJNT, BIOS 2.1.5 04/11/2016
[ 733.608518] RIP: 0010:cbq_destroy_class+0x5d/0x70 [sch_cbq]
[ 733.614734] Code: e7 d9 d2 48 8b 7b 48 e8 61 05 da d2 48 8d bb f8 00 00 00 e8 75 ae d5 d2 48 39 eb 74 0a 48 89 df 5b 5d e9 16 6c 94 d2 5b 5d c3 <0f> 0b eb b6 0f 1f 44 00 00 66 2e 0f 1f 84
[ 733.635798] RSP: 0018:ffffbfbb066bb9d8 EFLAGS: 00010202
[ 733.641627] RAX: 0000000000000001 RBX: ffff9cdd17392800 RCX: 000000008010000f
[ 733.649588] RDX: ffff9cdd1df547e0 RSI: ffff9cdd17392800 RDI: ffff9cdd0f84c800
[ 733.657547] RBP: ffff9cdd0f84c800 R08: 0000000000000001 R09: 0000000000000000
[ 733.665508] R10: ffff9cdd0f84d000 R11: 0000000000000001 R12: 0000000000000001
[ 733.673469] R13: 0000000000000000 R14: 0000000000000001 R15: ffff9cdd17392200
[ 733.681430] FS: 00007f911890a740(0000) GS:ffff9cdd1f8c0000(0000) knlGS:0000000000000000
[ 733.690456] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 733.696864] CR2: 0000000000b5544c CR3: 0000000859374002 CR4: 00000000001606e0
[ 733.704826] Call Trace:
[ 733.707554] cbq_destroy+0xa1/0xd0 [sch_cbq]
[ 733.712318] qdisc_destroy+0x62/0x130
[ 733.716401] dsmark_destroy+0x2a/0x70 [sch_dsmark]
[ 733.721745] qdisc_destroy+0x62/0x130
[ 733.725829] qdisc_graft+0x3ba/0x470
[ 733.729817] tc_get_qdisc+0x2a6/0x2c0
[ 733.733901] ? cred_has_capability+0x7d/0x130
[ 733.738761] rtnetlink_rcv_msg+0x263/0x2d0
[ 733.743330] ? rtnl_calcit.isra.30+0x110/0x110
[ 733.748287] netlink_rcv_skb+0x4d/0x130
[ 733.752576] netlink_unicast+0x1a3/0x250
[ 733.756949] netlink_sendmsg+0x2ae/0x3a0
[ 733.761324] sock_sendmsg+0x36/0x40
[ 733.765213] ___sys_sendmsg+0x26f/0x2d0
[ 733.769493] ? handle_pte_fault+0x586/0xdf0
[ 733.774158] ? __handle_mm_fault+0x389/0x500
[ 733.778919] ? __sys_sendmsg+0x5e/0xa0
[ 733.783099] __sys_sendmsg+0x5e/0xa0
[ 733.787087] do_syscall_64+0x5b/0x180
[ 733.791171] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 733.796805] RIP: 0033:0x7f9117f23f10
[ 733.800791] Code: c3 48 8b 05 82 6f 2c 00 f7 db 64 89 18 48 83 cb ff eb dd 0f 1f 80 00 00 00 00 83 3d 8d d0 2c 00 00 75 10 b8 2e 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8
[ 733.821873] RSP: 002b:00007ffe96818398 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 733.830319] RAX: ffffffffffffffda RBX: 000000005b71244c RCX: 00007f9117f23f10
[ 733.838280] RDX: 0000000000000000 RSI: 00007ffe968183e0 RDI: 0000000000000003
[ 733.846241] RBP: 00007ffe968183e0 R08: 000000000000ffff R09: 0000000000000003
[ 733.854202] R10: 00007ffe96817e20 R11: 0000000000000246 R12: 0000000000000000
[ 733.862161] R13: 0000000000662ee0 R14: 0000000000000000 R15: 0000000000000000
[ 733.870121] ---[ end trace 28edd4aad712ddca ]---
This is because we didn't update f->result.res when create new filter. Then in
tcindex_delete() -> tcf_unbind_filter(), we will failed to find out the res
and unbind filter, which will trigger the WARN_ON() in cbq_destroy_class().
Fix it by updating f->result.res when create new filter.
Fixes: 6e0565697a106 ("net_sched: fix another crash in cls_tcindex")
[ Upstream commit 82a40777de12728dedf4075453b694f0d1baee80 ]
According to RFC791, 68 bytes is the minimum size of IPv4 datagram every
device must be able to forward without further fragmentation while 576
bytes is the minimum size of IPv4 datagram every device has to be able
to receive, so in ip6_tnl_xmit(), 68(IPV4_MIN_MTU) should be the right
value for the ipv4 min mtu check in ip6_tnl_xmit.
While at it, change to use max() instead of if statement.
Fixes: c9fefa08190f ("ip6_tunnel: get the min mtu properly in ip6_tnl_xmit")
Reported-by: Sabrina Dubroca <sd@queasysnail.net>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 455f05ecd2b219e9a216050796d30c830d9bc393 ]
syzbot reported that we reinitialize an active delayed
work in vsock_stream_connect():
ODEBUG: init active (active state 0) object type: timer_list hint:
delayed_work_timer_fn+0x0/0x90 kernel/workqueue.c:1414
WARNING: CPU: 1 PID: 11518 at lib/debugobjects.c:329
debug_print_object+0x16a/0x210 lib/debugobjects.c:326
The pattern is apparently wrong, we should only initialize
the dealyed work once and could repeatly schedule it. So we
have to move out the initializations to allocation side.
And to avoid confusion, we can split the shared dwork
into two, instead of re-using the same one.
Fixes: d021c344051a ("VSOCK: Introduce VM Sockets")
Reported-by: <syzbot+8a9b1bd330476a4f3db6@syzkaller.appspotmail.com>
Cc: Andy king <acking@vmware.com>
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
[ Upstream commit 0dcb82254d65f72333aa50ad626d1e9665ad093b ]
llc_sap_put() decreases the refcnt before deleting sap
from the global list. Therefore, there is a chance
llc_sap_find() could find a sap with zero refcnt
in this global list.
Close this race condition by checking if refcnt is zero
or not in llc_sap_find(), if it is zero then it is being
removed so we can just treat it as gone.
Reported-by: <syzbot+278893f3f7803871f7ce@syzkaller.appspotmail.com>
[ Upstream commit 6d37fa49da1e8db8fb1995be22ac837ca41ac8a8 ]
In l2tp code, if it is a L2TP_UDP_ENCAP tunnel, tunnel->sk points to a
UDP socket. User could call sendmsg() on both this tunnel and the UDP
socket itself concurrently. As l2tp_xmit_skb() holds socket lock and call
__sk_dst_check() to refresh sk->sk_dst_cache, while udpv6_sendmsg() is
lockless and call sk_dst_check() to refresh sk->sk_dst_cache, there
could be a race and cause the dst cache to be freed multiple times.
So we fix l2tp side code to always call sk_dst_check() to garantee
xchg() is called when refreshing sk->sk_dst_cache to avoid race
conditions.
Syzkaller reported stack trace:
BUG: KASAN: use-after-free in atomic_read include/asm-generic/atomic-instrumented.h:21 [inline]
BUG: KASAN: use-after-free in atomic_fetch_add_unless include/linux/atomic.h:575 [inline]
BUG: KASAN: use-after-free in atomic_add_unless include/linux/atomic.h:597 [inline]
BUG: KASAN: use-after-free in dst_hold_safe include/net/dst.h:308 [inline]
BUG: KASAN: use-after-free in ip6_hold_safe+0xe6/0x670 net/ipv6/route.c:1029
Read of size 4 at addr ffff8801aea9a880 by task syz-executor129/4829
CPU: 0 PID: 4829 Comm: syz-executor129 Not tainted 4.18.0-rc7-next-20180802+ #30
Call Trace:
dump_stack+0x1c9/0x2b4 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x30d mm/kasan/report.c:412
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x13e/0x1b0 mm/kasan/kasan.c:267
kasan_check_read+0x11/0x20 mm/kasan/kasan.c:272
rt6_get_pcpu_route net/ipv6/route.c:1249 [inline]
ip6_pol_route+0x354/0xd20 net/ipv6/route.c:1922
ip6_pol_route_output+0x54/0x70 net/ipv6/route.c:2098
fib6_rule_lookup+0x283/0x890 net/ipv6/fib6_rules.c:122
ip6_route_output_flags+0x2c5/0x350 net/ipv6/route.c:2126
ip6_dst_lookup_tail+0x1278/0x1da0 net/ipv6/ip6_output.c:978
ip6_dst_lookup_flow+0xc8/0x270 net/ipv6/ip6_output.c:1079
ip6_sk_dst_lookup_flow+0x5ed/0xc50 net/ipv6/ip6_output.c:1117
udpv6_sendmsg+0x2163/0x36b0 net/ipv6/udp.c:1354
inet_sendmsg+0x1a1/0x690 net/ipv4/af_inet.c:798
sock_sendmsg_nosec net/socket.c:622 [inline]
sock_sendmsg+0xd5/0x120 net/socket.c:632
___sys_sendmsg+0x51d/0x930 net/socket.c:2115
__sys_sendmmsg+0x240/0x6f0 net/socket.c:2210
__do_sys_sendmmsg net/socket.c:2239 [inline]
__se_sys_sendmmsg net/socket.c:2236 [inline]
__x64_sys_sendmmsg+0x9d/0x100 net/socket.c:2236
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
RIP: 0033:0x446a29
Code: e8 ac b8 02 00 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 eb 08 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f4de5532db8 EFLAGS: 00000246 ORIG_RAX: 0000000000000133
RAX: ffffffffffffffda RBX: 00000000006dcc38 RCX: 0000000000446a29
RDX: 00000000000000b8 RSI: 0000000020001b00 RDI: 0000000000000003
RBP: 00000000006dcc30 R08: 00007f4de5533700 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000006dcc3c
R13: 00007ffe2b830fdf R14: 00007f4de55339c0 R15: 0000000000000001
Fixes: 71b1391a4128 ("l2tp: ensure sk->dst is still valid")
Reported-by: syzbot+05f840f3b04f211bad55@syzkaller.appspotmail.com
Signed-off-by: Wei Wang <weiwan@google.com>
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Cc: Guillaume Nault <g.nault@alphalink.fr>
Cc: David Ahern <dsahern@gmail.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 61ef4b07fcdc30535889990cf4229766502561cf ]
The shift of 'cwnd' with '(now - hc->tx_lsndtime) / hc->tx_rto' value
can lead to undefined behavior [1].
In order to fix this use a gradual shift of the window with a 'while'
loop, similar to what tcp_cwnd_restart() is doing.
When comparing delta and RTO there is a minor difference between TCP
and DCCP, the last one also invokes dccp_cwnd_restart() and reduces
'cwnd' if delta equals RTO. That case is preserved in this change.
[1]:
[40850.963623] UBSAN: Undefined behaviour in net/dccp/ccids/ccid2.c:237:7
[40851.043858] shift exponent 67 is too large for 32-bit type 'unsigned int'
[40851.127163] CPU: 3 PID: 15940 Comm: netstress Tainted: G W E 4.18.0-rc7.x86_64 #1
[40851.377176] Call Trace:
[40851.408503] dump_stack+0xf1/0x17b
[40851.451331] ? show_regs_print_info+0x5/0x5
[40851.503555] ubsan_epilogue+0x9/0x7c
[40851.548363] __ubsan_handle_shift_out_of_bounds+0x25b/0x2b4
[40851.617109] ? __ubsan_handle_load_invalid_value+0x18f/0x18f
[40851.686796] ? xfrm4_output_finish+0x80/0x80
[40851.739827] ? lock_downgrade+0x6d0/0x6d0
[40851.789744] ? xfrm4_prepare_output+0x160/0x160
[40851.845912] ? ip_queue_xmit+0x810/0x1db0
[40851.895845] ? ccid2_hc_tx_packet_sent+0xd36/0x10a0 [dccp]
[40851.963530] ccid2_hc_tx_packet_sent+0xd36/0x10a0 [dccp]
[40852.029063] dccp_xmit_packet+0x1d3/0x720 [dccp]
[40852.086254] dccp_write_xmit+0x116/0x1d0 [dccp]
[40852.142412] dccp_sendmsg+0x428/0xb20 [dccp]
[40852.195454] ? inet_dccp_listen+0x200/0x200 [dccp]
[40852.254833] ? sched_clock+0x5/0x10
[40852.298508] ? sched_clock+0x5/0x10
[40852.342194] ? inet_create+0xdf0/0xdf0
[40852.388988] sock_sendmsg+0xd9/0x160
Fixes: 113ced1f52e5 ("dccp ccid-2: Perform congestion-window validation")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
commit 7992c18810e568b95c869b227137a2215702a805 upstream.
CVE-2018-9363
The buffer length is unsigned at all layers, but gets cast to int and
checked in hidp_process_report and can lead to a buffer overflow.
Switch len parameter to unsigned int to resolve issue.
This affects 3.18 and newer kernels.
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Fixes: a4b1b5877b514b276f0f31efe02388a9c2836728 ("HID: Bluetooth: hidp: make sure input buffers are big enough")
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: security@kernel.org
Cc: kernel-team@android.com
commit 58152ecbbcc6a0ce7fddd5bf5f6ee535834ece0c upstream.
In case skb in out_or_order_queue is the result of
multiple skbs coalescing, we would like to get a proper gso_segs
counter tracking, so that future tcp_drop() can report an accurate
number.
I chose to not implement this tracking for skbs in receive queue,
since they are not dropped, unless socket is disconnected.
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 91874ecf32e41b5d86a4cb9d60e0bee50d828058 upstream.
It's legal to have 64 groups for netlink_sock.
As user-supplied nladdr->nl_groups is __u32, it's possible to subscribe
only to first 32 groups.
The check for correctness of .bind() userspace supplied parameter
is done by applying mask made from ngroups shift. Which broke Android
as they have 64 groups and the shift for mask resulted in an overflow.
Fixes: 61f4b23769f0 ("netlink: Don't shift with UB on nlk->ngroups")
Cc: stable@vger.kernel.org
Reported-and-Tested-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Dmitry Safonov <dima@arista.com>
[ Upstream commit 61f4b23769f0cc72ae62c9a81cf08f0397d40da8 ]
On i386 nlk->ngroups might be 32 or 0. Which leads to UB, resulting in
hang during boot.
Check for 0 ngroups and use (unsigned long long) as a type to shift.
Fixes: 7acf9d4237c4 ("netlink: Do not subscribe to non-existent groups").
Reported-by: kernel test robot <rong.a.chen@intel.com>
[ Upstream commit 7acf9d4237c46894e0fa0492dd96314a41742e84 ]
Make ABI more strict about subscribing to group > ngroups.
Code doesn't check for that and it looks bogus.
(one can subscribe to non-existing group)
Still, it's possible to bind() to all possible groups with (-1)
commit c8e8cd579bb4265651df8223730105341e61a2d1 upstream.
'call' is a user-controlled value, so sanitize the array index after the
bounds check to avoid speculating past the bounds of the 'nargs' array.
Found with the help of Smatch:
net/socket.c:2508 __do_sys_socketcall() warn: potential spectre issue
'nargs' [r] (local cap)
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Jeremy Cline <jcline@redhat.com>
[ Upstream commit bc5b6c0b62b932626a135f516a41838c510c6eba ]
'protocol' is a user-controlled value, so sanitize it after the bounds
check to avoid using it for speculative out-of-bounds access to arrays
indexed by it.
This addresses the following accesses detected with the help of smatch:
* net/netlink/af_netlink.c:654 __netlink_create() warn: potential
spectre issue 'nlk_cb_mutex_keys' [w]
spectre issue 'nlk_cb_mutex_key_strings' [w]
* net/netlink/af_netlink.c:685 netlink_create() warn: potential spectre
issue 'nl_table' [w] (local cap)
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
[ Upstream commit a94c689e6c9e72e722f28339e12dff191ee5a265 ]
If a DSA slave network device was previously disabled, there is no need
to suspend or resume it.
Fixes: 2446254915a7 ("net: dsa: allow switch drivers to implement suspend/resume hooks")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit 4672694bd4f1aebdab0ad763ae4716e89cb15221 ]
ip_frag_queue() might call pskb_pull() on one skb that
is already in the fragment queue.
We need to take care of possible truesize change, or we
might have an imbalance of the netns frags memory usage.
IPv6 is immune to this bug, because RFC5722, Section 4,
amended by Errata ID 3089 states :
When reassembling an IPv6 datagram, if
one or more its constituent fragments is determined to be an
overlapping fragment, the entire datagram (and any constituent
fragments) MUST be silently discarded.
Fixes: 158f323b9868 ("net: adjust skb->truesize in pskb_expand_head()")
[ Upstream commit 56e2c94f055d328f5f6b0a5c1721cca2f2d4e0a1 ]
We currently check current frags memory usage only when
a new frag queue is created. This allows attackers to first
consume the memory budget (default : 4 MB) creating thousands
of frag queues, then sending tiny skbs to exceed high_thresh
limit by 2 to 3 order of magnitude.
Note that before commit 648700f76b03 ("inet: frags: use rhashtables
for reassembly units"), work queue could be starved under DOS,
getting no cpu cycles.
After commit 648700f76b03, only the per frag queue timer can eventually
remove an incomplete frag queue and its skbs.
Fixes: b13d3cbfb8e8 ("inet: frag: move eviction of queues to work queue")
Reported-by: Jann Horn <jannh@google.com>
Cc: Florian Westphal <fw@strlen.de>
Cc: Peter Oskolkov <posk@google.com>
Cc: Paolo Abeni <pabeni@redhat.com>
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit 15ecbe94a45ef88491ca459b26efdd02f91edb6d ]
Larry Brakmo proposal ( https://patchwork.ozlabs.org/patch/935233/
tcp: force cwnd at least 2 in tcp_cwnd_reduction) made us rethink
about our recent patch removing ~16 quick acks after ECN events.
tcp_enter_quickack_mode(sk, 1) makes sure one immediate ack is sent,
but in the case the sender cwnd was lowered to 1, we do not want
to have a delayed ack for the next packet we will receive.
Fixes: 522040ea5fdd ("tcp: do not aggressively quick ack after ECN events")
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Lawrence Brakmo <brakmo@fb.com>
[ Upstream commit f4c9f85f3b2cb7669830cd04d0be61192a4d2436 ]
Refactor tcp_ecn_check_ce and __tcp_ecn_check_ce to accept struct sock*
instead of tcp_sock* to clean up type casts. This is a pure refactor
patch.
Signed-off-by: Yousuk Seung <ysseung@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 522040ea5fdd1c33bbf75e1d7c7c0422b96a94ef ]
ECN signals currently forces TCP to enter quickack mode for
up to 16 (TCP_MAX_QUICKACKS) following incoming packets.
We believe this is not needed, and only sending one immediate ack
for the current packet should be enough.
This should reduce the extra load noticed in DCTCP environments,
after congestion events.
This is part 2 of our effort to reduce pure ACK packets.
[ Upstream commit 9a9c9b51e54618861420093ae6e9b50a961914c5 ]
We want to add finer control of the number of ACK packets sent after
ECN events.
This patch is not changing current behavior, it only enables following
change.
[ Upstream commit a3893637e1eb0ef5eb1bbc52b3a8d2dfa317a35d ]
As explained in commit 9f9843a751d0 ("tcp: properly handle stretch
acks in slow start"), TCP stacks have to consider how many packets
are acknowledged in one single ACK, because of GRO, but also
because of ACK compression or losses.
We plan to add SACK compression in the following patch, we
must therefore not call tcp_enter_quickack_mode()
[ Upstream commit 383d470936c05554219094a4d364d964cb324827 ]
For some very small BDPs (with just a few packets) there was a
quantization effect where the target number of packets in flight
during the super-unity-gain (1.25x) phase of gain cycling was
implicitly truncated to a number of packets no larger than the normal
unity-gain (1.0x) phase of gain cycling. This meant that in multi-flow
scenarios some flows could get stuck with a lower bandwidth, because
they did not push enough packets inflight to discover that there was
more bandwidth available. This was really only an issue in multi-flow
LAN scenarios, where RTTs and BDPs are low enough for this to be an
issue.
This fix ensures that gain cycling can raise inflight for small BDPs
by ensuring that in PROBE_BW mode target inflight values with a
super-unity gain are always greater than inflight values with a gain
<= 1. Importantly, this applies whether the inflight value is
calculated for use as a cwnd value, or as a target inflight value for
the end of the super-unity phase in bbr_is_next_cycle_phase() (both
need to be bigger to ensure we can probe with more packets in flight
reliably).
This is a candidate fix for stable releases.
Fixes: 0f8782ea1497 ("tcp_bbr: add BBR congestion control")
Acked-by: Priyaranjan Jha <priyarjha@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 9fc12023d6f51551d6ca9ed7e02ecc19d79caf17 ]
Remove BUG_ON() from fib_compute_spec_dst routine and check
in_dev pointer during flowi4 data structure initialization.
fib_compute_spec_dst routine can be run concurrently with device removal
where ip_ptr net_device pointer is set to NULL. This can happen
if userspace enables pkt info on UDP rx socket and the device
is removed while traffic is flowing
Fixes: 35ebf65e851c ("ipv4: Create and use fib_compute_spec_dst() helper")
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 300eec7c0a2495f771709c7642aa15f7cc148b83 ]
ic_nameservers, which stores the list of name servers discovered by
ipconfig, is initialised (i.e. has all of its elements set to NONE, or
0xffffffff) by ic_nameservers_predef() in the following scenarios:
- before the "ip=" and "nfsaddrs=" kernel command line parameters are
parsed (in ip_auto_config_setup());
- before autoconfiguring via DHCP or BOOTP (in ic_bootp_init()), in
order to clear any values that may have been set after parsing "ip="
or "nfsaddrs=" and are no longer needed.
This means that ic_nameservers_predef() is not called when neither "ip="
nor "nfsaddrs=" is specified on the kernel command line. In this
scenario, every element in ic_nameservers remains set to 0x00000000,
which is indistinguishable from ANY and causes pnp_seq_show() to write
the following (bogus) information to /proc/net/pnp:
#MANUAL
nameserver 0.0.0.0
nameserver 0.0.0.0
nameserver 0.0.0.0
This is potentially problematic for systems that blindly link
/etc/resolv.conf to /proc/net/pnp.
Ensure that ic_nameservers is also initialised when neither "ip=" nor
"nfsaddrs=" are specified by calling ic_nameservers_predef() in
ip_auto_config(), but only when ip_auto_config_setup() was not called
earlier. This causes the following to be written to /proc/net/pnp, and
is consistent with what gets written when ipconfig is configured
manually but no name servers are specified on the kernel command line:
#MANUAL
Signed-off-by: Chris Novakovic <chris@chrisn.me.uk>
[ Upstream commit 9c7f96fd77b0dbe1fe7ed1f9c462c45dc48a1076 ]
The patch moves the "trans->msg_type == NFT_MSG_NEWSET" check before
using nft_trans_set(trans). Otherwise we can get out of bounds read.
For example, KASAN reported the one when running 0001_cache_handling_0 nft
test. In this case "trans->msg_type" was NFT_MSG_NEWTABLE:
[75517.177808] BUG: KASAN: slab-out-of-bounds in nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75517.279094] Read of size 8 at addr ffff881bdb643fc8 by task nft/7356
[75517.375605] CPU: 26 PID: 7356 Comm: nft Tainted: G E 4.17.0-rc7.1.x86_64 #1
[75517.489587] Hardware name: Oracle Corporation SUN SERVER X4-2
[75517.618129] Call Trace:
[75517.648821] dump_stack+0xd1/0x13b
[75517.691040] ? show_regs_print_info+0x5/0x5
[75517.742519] ? kmsg_dump_rewind_nolock+0xf5/0xf5
[75517.799300] ? lock_acquire+0x143/0x310
[75517.846738] print_address_description+0x85/0x3a0
[75517.904547] kasan_report+0x18d/0x4b0
[75517.949892] ? nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75518.019153] ? nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75518.088420] ? nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75518.157689] nft_set_lookup_global+0x22f/0x270 [nf_tables]
[75518.224869] nf_tables_newsetelem+0x1a5/0x5d0 [nf_tables]
[75518.291024] ? nft_add_set_elem+0x2280/0x2280 [nf_tables]
[75518.357154] ? nla_parse+0x1a5/0x300
[75518.401455] ? kasan_kmalloc+0xa6/0xd0
[75518.447842] nfnetlink_rcv+0xc43/0x1bdf [nfnetlink]
[75518.507743] ? nfnetlink_rcv+0x7a5/0x1bdf [nfnetlink]
[75518.569745] ? nfnl_err_reset+0x3c0/0x3c0 [nfnetlink]
[75518.631711] ? lock_acquire+0x143/0x310
[75518.679133] ? netlink_deliver_tap+0x9b/0x1070
[75518.733840] ? kasan_unpoison_shadow+0x31/0x40
[75518.788542] netlink_unicast+0x45d/0x680
[75518.837111] ? __isolate_free_page+0x890/0x890
[75518.891913] ? netlink_attachskb+0x6b0/0x6b0
[75518.944542] netlink_sendmsg+0x6fa/0xd30
[75518.993107] ? netlink_unicast+0x680/0x680
[75519.043758] ? netlink_unicast+0x680/0x680
[75519.094402] sock_sendmsg+0xd9/0x160
[75519.138810] ___sys_sendmsg+0x64d/0x980
[75519.186234] ? copy_msghdr_from_user+0x350/0x350
[75519.243118] ? lock_downgrade+0x650/0x650
[75519.292738] ? do_raw_spin_unlock+0x5d/0x250
[75519.345456] ? _raw_spin_unlock+0x24/0x30
[75519.395065] ? __handle_mm_fault+0xbde/0x3410
[75519.448830] ? sock_setsockopt+0x3d2/0x1940
[75519.500516] ? __lock_acquire.isra.25+0xdc/0x19d0
[75519.558448] ? lock_downgrade+0x650/0x650
[75519.608057] ? __audit_syscall_entry+0x317/0x720
[75519.664960] ? __fget_light+0x58/0x250
[75519.711325] ? __sys_sendmsg+0xde/0x170
[75519.758850] __sys_sendmsg+0xde/0x170
[75519.804193] ? __ia32_sys_shutdown+0x90/0x90
[75519.856725] ? syscall_trace_enter+0x897/0x10e0
[75519.912354] ? trace_event_raw_event_sys_enter+0x920/0x920
[75519.979432] ? __audit_syscall_entry+0x720/0x720
[75520.036118] do_syscall_64+0xa3/0x3d0
[75520.081248] ? prepare_exit_to_usermode+0x47/0x1d0
[75520.139904] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[75520.201680] RIP: 0033:0x7fc153320ba0
[75520.245772] RSP: 002b:00007ffe294c3638 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[75520.337708] RAX: ffffffffffffffda RBX: 00007ffe294c4820 RCX: 00007fc153320ba0
[75520.424547] RDX: 0000000000000000 RSI: 00007ffe294c46b0 RDI: 0000000000000003
[75520.511386] RBP: 00007ffe294c47b0 R08: 0000000000000004 R09: 0000000002114090
[75520.598225] R10: 00007ffe294c30a0 R11: 0000000000000246 R12: 00007ffe294c3660
[75520.684961] R13: 0000000000000001 R14: 00007ffe294c3650 R15: 0000000000000001
[75520.790946] Allocated by task 7356:
[75520.833994] kasan_kmalloc+0xa6/0xd0
[75520.878088] __kmalloc+0x189/0x450
[75520.920107] nft_trans_alloc_gfp+0x20/0x190 [nf_tables]
[75520.983961] nf_tables_newtable+0xcd0/0x1bd0 [nf_tables]
[75521.048857] nfnetlink_rcv+0xc43/0x1bdf [nfnetlink]
[75521.108655] netlink_unicast+0x45d/0x680
[75521.157013] netlink_sendmsg+0x6fa/0xd30
[75521.205271] sock_sendmsg+0xd9/0x160
[75521.249365] ___sys_sendmsg+0x64d/0x980
[75521.296686] __sys_sendmsg+0xde/0x170
[75521.341822] do_syscall_64+0xa3/0x3d0
[75521.386957] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[75521.467867] Freed by task 23454:
[75521.507804] __kasan_slab_free+0x132/0x180
[75521.558137] kfree+0x14d/0x4d0
[75521.596005] free_rt_sched_group+0x153/0x280
[75521.648410] sched_autogroup_create_attach+0x19a/0x520
[75521.711330] ksys_setsid+0x2ba/0x400
[75521.755529] __ia32_sys_setsid+0xa/0x10
[75521.802850] do_syscall_64+0xa3/0x3d0
[75521.848090] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[75521.929000] The buggy address belongs to the object at ffff881bdb643f80
which belongs to the cache kmalloc-96 of size 96
[75522.079797] The buggy address is located 72 bytes inside of
96-byte region [ffff881bdb643f80, ffff881bdb643fe0)
[75522.221234] The buggy address belongs to the page:
[75522.280100] page:ffffea006f6d90c0 count:1 mapcount:0 mapping:0000000000000000 index:0x0
[75522.377443] flags: 0x2fffff80000100(slab)
[75522.426956] raw: 002fffff80000100 0000000000000000 0000000000000000 0000000180200020
[75522.521275] raw: ffffea006e6fafc0 0000000c0000000c ffff881bf180f400 0000000000000000
[75522.615601] page dumped because: kasan: bad access detected
Fixes: 37a9cc525525 ("netfilter: nf_tables: add generation mask to sets")
[ Upstream commit 8541b21e781a22dce52a74fef0b9bed00404a1cd ]
In order to be able to give better diagnostics and detect
malicious traffic, we need to have better sk->sk_drops tracking.
Fixes: 9f5afeae5152 ("tcp: use an RB tree for ooo receive queue")
[ Upstream commit 3d4bf93ac12003f9b8e1e2de37fe27983deebdcf ]
In case an attacker feeds tiny packets completely out of order,
tcp_collapse_ofo_queue() might scan the whole rb-tree, performing
expensive copies, but not changing socket memory usage at all.
1) Do not attempt to collapse tiny skbs.
2) Add logic to exit early when too many tiny skbs are detected.
We prefer not doing aggressive collapsing (which copies packets)
for pathological flows, and revert to tcp_prune_ofo_queue() which
will be less expensive.
In the future, we might add the possibility of terminating flows
that are proven to be malicious.
[ Upstream commit f4a3313d8e2ca9fd8d8f45e40a2903ba782607e7 ]
Right after a TCP flow is created, receiving tiny out of order
packets allways hit the condition :
if (atomic_read(&sk->sk_rmem_alloc) >= sk->sk_rcvbuf)
tcp_clamp_window(sk);
tcp_clamp_window() increases sk_rcvbuf to match sk_rmem_alloc
(guarded by tcp_rmem[2])
Calling tcp_collapse_ofo_queue() in this case is not useful,
and offers a O(N^2) surface attack to malicious peers.
Better not attempt anything before full queue capacity is reached,
forcing attacker to spend lots of resource and allow us to more
easily detect the abuse.
