commit 9507271d960a1911a51683888837d75c171cd91f upstream.
In an environment where the KDC is running Active Directory, the
exported composite name field returned in the context could be large
enough to span a page boundary. Attaching a scratch buffer to the
decoding xdr_stream helps deal with those cases.
The case where we saw this was actually due to behavior that's been
fixed in newer gss-proxy versions, but we're fixing it here too.
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
Reviewed-by: Simo Sorce <simo@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 22d3a3c829fa9ecdb493d1f1f2838d543f8d86a3 upstream.
No matter how the driver manages its NAPI context, there's no way
sending frames to it from a timer can be correct, since it would
corrupt the internal GRO lists.
To avoid that, always use the non-NAPI path when releasing frames
from the timer.
Reported-by: Jean Trivelly <jean.trivelly@intel.com>
commit 47b4e1fc4972cc43a19121bc2608a60aef3bf216 upstream.
Remove checking tailroom when adding IV as it uses only
headroom, and move the check to the ICV generation that
actually needs the tailroom.
In other case I hit such warning and datapath don't work,
when testing:
- IBSS + WEP
- ath9k with hw crypt enabled
- IPv6 data (ping6)
WARNING: CPU: 3 PID: 13301 at net/mac80211/wep.c:102 ieee80211_wep_add_iv+0x129/0x190 [mac80211]()
Call Trace:
[<ffffffff817bf491>] dump_stack+0x45/0x57
[<ffffffff8107746a>] warn_slowpath_common+0x8a/0xc0
[<ffffffff8107755a>] warn_slowpath_null+0x1a/0x20
[<ffffffffc09ae109>] ieee80211_wep_add_iv+0x129/0x190 [mac80211]
[<ffffffffc09ae7ab>] ieee80211_crypto_wep_encrypt+0x6b/0xd0 [mac80211]
[<ffffffffc09d3fb1>] invoke_tx_handlers+0xc51/0xf30 [mac80211]
Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com>
commit 521a04d06a729e5971cdee7f84080387ed320527 upstream.
This reverts commit ba9d114ec5578e6e99a4dfa37ff8ae688040fd64.
.. which introduced a regression that prevented all lingering requests
requeued in kick_requests() from ever being sent to the OSDs, resulting
in a lot of missed notifies. In retrospect it's pretty obvious that
r_req_lru_item item in the case of lingering requests can be used not
only for notarget, but also for unsent linkage due to how tightly
actual map and enqueue operations are coupled in __map_request().
The assertion that was being silenced is taken care of in the previous
("libceph: request a new osdmap if lingering request maps to no osd")
commit: by always kicking homeless lingering requests we ensure that
none of them ends up on the notarget list outside of the critical
section guarded by request_mutex.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Sage Weil <sage@redhat.com>
commit b0494532214bdfbf241e94fabab5dd46f7b82631 upstream.
This commit does two things. First, if there are any homeless
lingering requests, we now request a new osdmap even if the osdmap that
is being processed brought no changes, i.e. if a given lingering
request turned homeless in one of the previous epochs and remained
homeless in the current epoch. Not doing so leaves us with a stale
osdmap and as a result we may miss our window for reestablishing the
watch and lose notifies.
MON=1 OSD=1:
# cat linger-needmap.sh
#!/bin/bash
rbd create --size 1 test
DEV=$(rbd map test)
ceph osd out 0
rbd map dne/dne # obtain a new osdmap as a side effect (!)
sleep 1
ceph osd in 0
rbd resize --size 2 test
# rbd info test | grep size -> 2M
# blockdev --getsize $DEV -> 1M
N.B.: Not obtaining a new osdmap in between "osd out" and "osd in"
above is enough to make it miss that resize notify, but that is a
bug^Wlimitation of ceph watch/notify v1.
Second, homeless lingering requests are now kicked just like those
lingering requests whose mapping has changed. This is mainly to
recognize that a homeless lingering request makes no sense and to
preserve the invariant that a registered lingering request is not
sitting on any of r_req_lru_item lists. This spares us a WARN_ON,
which commit ba9d114ec557 ("libceph: clear r_req_lru_item in
__unregister_linger_request()") tried to fix the _wrong_ way.
[ Upstream commit a134f083e79fb4c3d0a925691e732c56911b4326 ]
If we don't do that, then the poison value is left in the ->pprev
backlink.
This can cause crashes if we do a disconnect, followed by a connect().
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Reported-by: Wen Xu <hotdog3645@gmail.com>
[ Upstream commit cb6ccf09d6b94bec4def1ac5cf4678d12b216474 ]
The commit 3cdaa5be9e81a914e633a6be7b7d2ef75b528562 ("ipv4: Don't
increase PMTU with Datagram Too Big message") broke PMTU in cases
where the rt_pmtu value has expired but is smaller than the new
PMTU value.
This obsolete rt_pmtu then prevents the new PMTU value from being
installed.
Fixes: 3cdaa5be9e81 ("ipv4: Don't increase PMTU with Datagram Too Big message")
Reported-by: Gerd v. Egidy <gerd.von.egidy@intra2net.com>
commit 0b67c43ce36a9964f1d5e3f973ee19eefd3f9f8f upstream.
We also need to save/store in forward, else br_parse_ip_options call
will zero frag_max_size as well.
Fixes: 93fdd47e5 ('bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING')
commit a73f8e21f3f93159bc19e154e8f50891c22c11db upstream.
Louis reported that a static checker was complaining that
the 'dst' variable was set (multiple times) but not used.
This is due to a previous commit having removed the usage
(apparently erroneously), so add it back.
Fixes: a344d6778a98 ("mac80211: allow drivers to support NL80211_SCAN_FLAG_RANDOM_ADDR")
Reported-by: Louis Langholtz <lou_langholtz@me.com>
[ Upstream commit a31196b07f8034eba6a3487a1ad1bb5ec5cd58a5 ]
Commit 567e4b79731c ("net: rfs: add hash collision detection") had one
mistake :
RPS_NO_CPU is no longer the marker for invalid cpu in set_rps_cpu()
and get_rps_cpu(), as @next_cpu was the result of an AND with
rps_cpu_mask
This bug showed up on a host with 72 cpus :
next_cpu was 0x7f, and the code was trying to access percpu data of an
non existent cpu.
In a follow up patch, we might get rid of compares against nr_cpu_ids,
if we init the tables with 0. This is silly to test for a very unlikely
condition that exists only shortly after table initialization, as
we got rid of rps_reset_sock_flow() and similar functions that were
writing this RPS_NO_CPU magic value at flow dismantle : When table is
old enough, it never contains this value anymore.
Fixes: 567e4b79731c ("net: rfs: add hash collision detection")
Cc: Tom Herbert <tom@herbertland.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
[ Upstream commit 2ea2f62c8bda242433809c7f4e9eae1c52c40bbe ]
When I added pfmemalloc support in build_skb(), I forgot netlink
was using build_skb() with a vmalloc() area.
In this patch I introduce __build_skb() for netlink use,
and build_skb() is a wrapper handling both skb->head_frag and
skb->pfmemalloc
This means netlink no longer has to hack skb->head_frag
[ 1567.700067] kernel BUG at arch/x86/mm/physaddr.c:26!
[ 1567.700067] invalid opcode: 0000 [#1] PREEMPT SMP KASAN
[ 1567.700067] Dumping ftrace buffer:
[ 1567.700067] (ftrace buffer empty)
[ 1567.700067] Modules linked in:
[ 1567.700067] CPU: 9 PID: 16186 Comm: trinity-c182 Not tainted 4.0.0-next-20150424-sasha-00037-g4796e21 #2167
[ 1567.700067] task: ffff880127efb000 ti: ffff880246770000 task.ti: ffff880246770000
[ 1567.700067] RIP: __phys_addr (arch/x86/mm/physaddr.c:26 (discriminator 3))
[ 1567.700067] RSP: 0018:ffff8802467779d8 EFLAGS: 00010202
[ 1567.700067] RAX: 000041000ed8e000 RBX: ffffc9008ed8e000 RCX: 000000000000002c
[ 1567.700067] RDX: 0000000000000004 RSI: 0000000000000000 RDI: ffffffffb3fd6049
[ 1567.700067] RBP: ffff8802467779f8 R08: 0000000000000019 R09: ffff8801d0168000
[ 1567.700067] R10: ffff8801d01680c7 R11: ffffed003a02d019 R12: ffffc9000ed8e000
[ 1567.700067] R13: 0000000000000f40 R14: 0000000000001180 R15: ffffc9000ed8e000
[ 1567.700067] FS: 00007f2a7da3f700(0000) GS:ffff8801d1000000(0000) knlGS:0000000000000000
[ 1567.700067] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1567.700067] CR2: 0000000000738308 CR3: 000000022e329000 CR4: 00000000000007e0
[ 1567.700067] Stack:
[ 1567.700067] ffffc9000ed8e000 ffff8801d0168000 ffffc9000ed8e000 ffff8801d0168000
[ 1567.700067] ffff880246777a28 ffffffffad7c0a21 0000000000001080 ffff880246777c08
[ 1567.700067] ffff88060d302e68 ffff880246777b58 ffff880246777b88 ffffffffad9a6821
[ 1567.700067] Call Trace:
[ 1567.700067] build_skb (include/linux/mm.h:508 net/core/skbuff.c:316)
[ 1567.700067] netlink_sendmsg (net/netlink/af_netlink.c:1633 net/netlink/af_netlink.c:2329)
[ 1567.774369] ? sched_clock_cpu (kernel/sched/clock.c:311)
[ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273)
[ 1567.774369] sock_sendmsg (net/socket.c:614 net/socket.c:623)
[ 1567.774369] sock_write_iter (net/socket.c:823)
[ 1567.774369] ? sock_sendmsg (net/socket.c:806)
[ 1567.774369] __vfs_write (fs/read_write.c:479 fs/read_write.c:491)
[ 1567.774369] ? get_lock_stats (kernel/locking/lockdep.c:249)
[ 1567.774369] ? default_llseek (fs/read_write.c:487)
[ 1567.774369] ? vtime_account_user (kernel/sched/cputime.c:701)
[ 1567.774369] ? rw_verify_area (fs/read_write.c:406 (discriminator 4))
[ 1567.774369] vfs_write (fs/read_write.c:539)
[ 1567.774369] SyS_write (fs/read_write.c:586 fs/read_write.c:577)
[ 1567.774369] ? SyS_read (fs/read_write.c:577)
[ 1567.774369] ? __this_cpu_preempt_check (lib/smp_processor_id.c:63)
[ 1567.774369] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2594 kernel/locking/lockdep.c:2636)
[ 1567.774369] ? trace_hardirqs_on_thunk (arch/x86/lib/thunk_64.S:42)
[ 1567.774369] system_call_fastpath (arch/x86/kernel/entry_64.S:261)
Fixes: 79930f5892e ("net: do not deplete pfmemalloc reserve")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
[ Upstream commit 79930f5892e134c6da1254389577fffb8bd72c66 ]
build_skb() should look at the page pfmemalloc status.
If set, this means page allocator allocated this page in the
expectation it would help to free other pages. Networking
stack can do that only if skb->pfmemalloc is also set.
Also, we must refrain using high order pages from the pfmemalloc
reserve, so __page_frag_refill() must also use __GFP_NOMEMALLOC for
them. Under memory pressure, using order-0 pages is probably the best
strategy.
[ Upstream commit 845704a535e9b3c76448f52af1b70e4422ea03fd ]
Presence of an unbound loop in tcp_send_fin() had always been hard
to explain when analyzing crash dumps involving gigantic dying processes
with millions of sockets.
Lets try a different strategy :
In case of memory pressure, try to add the FIN flag to last packet
in write queue, even if packet was already sent. TCP stack will
be able to deliver this FIN after a timeout event. Note that this
FIN being delivered by a retransmit, it also carries a Push flag
given our current implementation.
By checking sk_under_memory_pressure(), we anticipate that cooking
many FIN packets might deplete tcp memory.
In the case we could not allocate a packet, even with __GFP_WAIT
allocation, then not sending a FIN seems quite reasonable if it allows
to get rid of this socket, free memory, and not block the process from
eventually doing other useful work.
[ Upstream commit d83769a580f1132ac26439f50068a29b02be535e ]
Using sk_stream_alloc_skb() in tcp_send_fin() is dangerous in
case a huge process is killed by OOM, and tcp_mem[2] is hit.
To be able to free memory we need to make progress, so this
patch allows FIN packets to not care about tcp_mem[2], if
skb allocation succeeded.
In a follow-up patch, we might abort tcp_send_fin() infinite loop
in case TIF_MEMDIE is set on this thread, as memory allocator
did its best getting extra memory already.
This patch reverts d22e15371811 ("tcp: fix tcp fin memory accounting")
Fixes: d22e15371811 ("tcp: fix tcp fin memory accounting")
[ Upstream commit 2ab957492d13bb819400ac29ae55911d50a82a13 ]
Initial discussion was:
[FYI] xfrm: Don't lookup sk_policy for timewait sockets
Forwarded frames should not have a socket attached. Especially
tw sockets will lead to panics later-on in the stack.
This was observed with TPROXY assigning a tw socket and broken
policy routing (misconfigured). As a result frame enters
forwarding path instead of input. We cannot solve this in
TPROXY as it cannot know that policy routing is broken.
v2:
Remove useless comment
Signed-off-by: Sebastian Poehn <sebastian.poehn@gmail.com>
[ Upstream commit 213dd74aee765d4e5f3f4b9607fef0cf97faa2af ]
On Wed, Apr 15, 2015 at 05:41:26PM +0200, Nicolas Dichtel wrote:
> Le 15/04/2015 15:57, Herbert Xu a écrit :
> >On Wed, Apr 15, 2015 at 06:22:29PM +0800, Herbert Xu wrote:
> [snip]
> >Subject: skbuff: Do not scrub skb mark within the same name space
> >The commit ea23192e8e577dfc51e0f4fc5ca113af334edff9 ("tunnels:
> Maybe add a Fixes tag?
> Fixes: ea23192e8e57 ("tunnels: harmonize cleanup done on skb on rx path")
> >harmonize cleanup done on skb on rx path") broke anyone trying to
> >use netfilter marking across IPv4 tunnels. While most of the
> >fields that are cleared by skb_scrub_packet don't matter, the
> >netfilter mark must be preserved.
> >This patch rearranges skb_scurb_packet to preserve the mark field.
> nit: s/scurb/scrub
> Else it's fine for me.
Sure.
PS I used the wrong email for James the first time around. So
let me repeat the question here. Should secmark be preserved
or cleared across tunnels within the same name space? In fact,
do our security models even support name spaces?
---8<---
This patch rearranges skb_scrub_packet to preserve the mark field.
Acked-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit 4c0ee414e877b899f7fc80aafb98d9425c02797f ]
This patch reverts commit b8fb4e0648a2ab3734140342002f68fb0c7d1602
because the secmark must be preserved even when a packet crosses
namespace boundaries. The reason is that security labels apply to
the system as a whole and is not per-namespace.
[ Upstream commit b50edd7812852d989f2ef09dcfc729690f54a42d ]
I noticed tcpdump was giving funky timestamps for locally
generated SYNACK messages on loopback interface.
11:42:46.938990 IP 127.0.0.1.48245 > 127.0.0.2.23850: S
945476042:945476042(0) win 43690 <mss 65495,nop,nop,sackOK,nop,wscale 7>
20:28:58.502209 IP 127.0.0.2.23850 > 127.0.0.1.48245: S
3160535375:3160535375(0) ack 945476043 win 43690 <mss
This is because we need to clear skb->tstamp before
entering lower stack, otherwise net_timestamp_check()
does not set skb->tstamp.
Fixes: 7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when")
[ Upstream commit b736a623bd099cdf5521ca9bd03559f3bc7fa31c ]
handle_offloads() calls skb_reset_inner_headers() to store
the layer pointers to the encapsulated packet. However, we
currently push the vlag tag (if there is one) onto the packet
afterwards. This changes the MAC header for the encapsulated
packet but it is not reflected in skb->inner_mac_header, which
breaks GSO and drivers which attempt to use this for encapsulation
offloads.
Fixes: 1eaa8178 ("vxlan: Add tx-vlan offload support.")
Signed-off-by: Jesse Gross <jesse@nicira.com>
This reverts commit 89baaa570ab0b476db09408d209578cfed700e9f.
Dirty page throttling should be sufficient for us in the general case
so there is no need to use __GFP_MEMALLOC - it would be needed only in
the swap-over-rbd case, which we currently don't support. (It would
probably take approximately the commit that is being reverted to add
that support, but we would also need the "swap" option to distinguish
from the general case and make sure swap ceph_client-s aren't shared
with anything else.) See ceph-devel threads [1] and [2] for the
details of why enabling pfmemalloc reserves for all cases is a bad
thing.
On top of potential system lockups related to drained emergency
reserves, this turned out to cause ceph lockups in case peers are on
the same host and communicating via loopback due to sk_filter()
dropping pfmemalloc skbs on the receiving side because the receiving
loopback socket is not tagged with SOCK_MEMALLOC.
[1] "SOCK_MEMALLOC vs loopback"
http://www.spinics.net/lists/ceph-devel/msg22998.html
[2] "[PATCH] libceph: don't set memalloc flags in loopback case"
http://www.spinics.net/lists/ceph-devel/msg23392.html
net/ceph/messenger.c [ context: tcp_nodelay option ]
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Sage Weil <sage@redhat.com>
Cc: stable@vger.kernel.org # 3.18+, needs backporting
Acked-by: Mike Christie <michaelc@cs.wisc.edu>
According to description in 'include/net/dsa.h', in cascade switches
configurations where there are more than one interconnected devices,
'rtable' array in 'dsa_chip_data' structure is used to indicate which
port on this switch should be used to send packets to that are destined
for corresponding switch.
However, dsa_of_setup_routing_table() fills 'rtable' with port numbers
of the _target_ switch, but not current one.
This commit removes redundant devicetree parsing and adds needed port
number as a function argument. So dsa_of_setup_routing_table() now just
looks for target switch number by parsing parent of 'link' device node.
To remove possible misunderstandings with the way of determining target
switch number, a corresponding comment was added to the source code and
to the DSA device tree bindings documentation file.
This was tested on a custom board with two Marvell 88E6095 switches with
following corresponding routing tables: { -1, 10 } and { 8, -1 }.
Signed-off-by: Pavel Nakonechny <pavel.nakonechny@skitlab.ru>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
We should not consult skb->sk for output decisions in xmit recursion
levels > 0 in the stack. Otherwise local socket settings could influence
the result of e.g. tunnel encapsulation process.
ipv6 does not conform with this in three places:
1) ip6_fragment: we do consult ipv6_npinfo for frag_size
2) sk_mc_loop in ipv6 uses skb->sk and checks if we should
loop the packet back to the local socket
3) ip6_skb_dst_mtu could query the settings from the user socket and
force a wrong MTU
Furthermore:
In sk_mc_loop we could potentially land in WARN_ON(1) if we use a
PF_PACKET socket ontop of an IPv6-backed vxlan device.
Reuse xmit_recursion as we are currently only interested in protecting
tunnel devices.
Cc: Jiri Pirko <jiri@resnulli.us>
First, let's explain the problem.
Suppose you have an ipip interface that stands in the netns foo and its link
part in the netns bar (so the netns bar has an nsid into the netns foo).
Now, you remove the netns bar:
- the bar nsid into the netns foo is removed
- the netns exit method of ipip is called, thus our ipip iface is removed:
=> a netlink message is built in the netns foo to advertise this deletion
=> this netlink message requests an nsid for bar, thus a new nsid is
allocated for bar and never removed.
This patch adds a check in peernet2id() so that an id cannot be allocated for
a netns which is currently destroyed.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
This reverts
commit 4217291e592d ("netns: don't clear nsid too early on removal").
This is not the right fix, it introduces races.
We need to wait for the flying timers, since we
are going to free the mrtable right after it.
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
We have to hold rtnl lock for fib_rules_unregister()
otherwise the following race could happen:
fib_rules_unregister(): fib_nl_delrule():
... ops = lookup_rules_ops();
list_del_rcu(&ops->list);
list_for_each_entry(ops->rules) {
fib_rules_cleanup_ops(ops); ...
list_del_rcu(); list_del_rcu();
Note, net->rules_mod_lock is actually not needed at all,
either upper layer netns code or rtnl lock guarantees
we are safe.
Cc: Alexander Duyck <alexander.h.duyck@redhat.com>
Cc: Thomas Graf <tgraf@suug.ch>
This is the IPv4 part for commit 905a6f96a1b1
(ipv6: take rtnl_lock and mark mrt6 table as freed on namespace cleanup).
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
On processing cumulative ACKs, the FRTO code was not checking the
SACKed bit, meaning that there could be a spurious FRTO undo on a
cumulative ACK of a previously SACKed skb.
The FRTO code should only consider a cumulative ACK to indicate that
an original/unretransmitted skb is newly ACKed if the skb was not yet
SACKed.
The effect of the spurious FRTO undo would typically be to make the
connection think that all previously-sent packets were in flight when
they really weren't, leading to a stall and an RTO.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Fixes: e33099f96d99c ("tcp: implement RFC5682 F-RTO")
Pull networking fixes from David Miller:
1) Fix use-after-free with mac80211 RX A-MPDU reorder timer, from
Johannes Berg.
2) iwlwifi leaks memory every module load/unload cycles, fix from Larry
Finger.
3) Need to use for_each_netdev_safe() in rtnl_group_changelink()
otherwise we can crash, from WANG Cong.
4) mlx4 driver does register_netdev() too early in the probe sequence,
from Ido Shamay.
5) Don't allow router discovery hop limit to decrease the interface's
hop limit, from D.S. Ljungmark.
6) tx_packets and tx_bytes improperly accounted for certain classes of
USB network devices, fix from Ben Hutchings.
7) ip{6}mr_rules_init() mistakenly use plain kfree to release the ipmr
tables in the error path, they must instead use ip{6}mr_free_table().
Fix from WANG Cong.
8) cxgb4 doesn't properly quiesce all RX activity before unregistering
the netdevice. Fix from Hariprasad Shenai.
9) Fix hash corruptions in ipvlan driver, from Jiri Benc.
10) nla_memcpy(), like a real memcpy, should fully initialize the
destination buffer, even if the source attribute is smaller. Fix
from Jiri Benc.
11) Fix wrong error code returned from iucv_sock_sendmsg(). We should
use whatever sock_alloc_send_skb() put into 'err'. From Eugene
Crosser.
12) Fix slab object leak on module unload in TIPC, from Ying Xue.
13) Need a READ_ONCE() when reading the cached RX socket route in
tcp_v{4,6}_early_demux(). From Michal Kubecek.
14) Still too many problems with TPC support in the ath9k driver, so
disable it for now. From Felix Fietkau.
15) When in AP mode the rtlwifi driver can leak DMA mappings, fix from
Larry Finger.
16) Missing kzalloc() failure check in gs_usb CAN driver, from Colin Ian
King.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits)
cxgb4: Fix to dump devlog, even if FW is crashed
cxgb4: Firmware macro changes for fw verison 1.13.32.0
bnx2x: Fix kdump when iommu=on
bnx2x: Fix kdump on 4-port device
mac80211: fix RX A-MPDU session reorder timer deletion
MAINTAINERS: Update Intel Wired Ethernet Driver info
tipc: fix a slab object leak
net/usb/r8152: add device id for Lenovo TP USB 3.0 Ethernet
af_iucv: fix AF_IUCV sendmsg() errno
openvswitch: Return vport module ref before destruction
netlink: pad nla_memcpy dest buffer with zeroes
bonding: Bonding Overriding Configuration logic restored.
ipvlan: fix check for IP addresses in control path
ipvlan: do not use rcu operations for address list
ipvlan: protect against concurrent link removal
ipvlan: fix addr hash list corruption
net: fec: setup right value for mdio hold time
net: tcp6: fix double call of tcp_v6_fill_cb()
cxgb4vf: Fix sparse warnings
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Johannes Berg says:
This contains just a single fix for a crash I happened to randomly
run into today during testing. It's clearly been around for a while,
but is pretty hard to trigger, even when I tried explicitly (and
modified the code to make it more likely) it rarely did.
Pull nfsd fixes from Bruce Fields:
"Two main issues:
- We found that turning on pNFS by default (when it's configured at
build time) was too aggressive, so we want to switch the default
before the 4.0 release.
- Recent client changes to increase open parallelism uncovered a
serious bug lurking in the server's open code.
Also fix a krb5/selinux regression.
The rest is mainly smaller pNFS fixes"
* 'for-4.0' of git://linux-nfs.org/~bfields/linux:
sunrpc: make debugfs file creation failure non-fatal
nfsd: require an explicit option to enable pNFS
NFSD: Fix bad update of layout in nfsd4_return_file_layout
NFSD: Take care the return value from nfsd4_encode_stateid
NFSD: Printk blocklayout length and offset as format 0x%llx
nfsd: return correct lockowner when there is a race on hash insert
nfsd: return correct openowner when there is a race to put one in the hash
NFSD: Put exports after nfsd4_layout_verify fail
NFSD: Error out when register_shrinker() fail
NFSD: Take care the return value from nfsd4_decode_stateid
NFSD: Check layout type when returning client layouts
NFSD: restore trace event lost in mismerge
There's an issue with the way the RX A-MPDU reorder timer is
deleted that can cause a kernel crash like this:
* tid_rx is removed - call_rcu(ieee80211_free_tid_rx)
* station is destroyed
* reorder timer fires before ieee80211_free_tid_rx() runs,
accessing the station, thus potentially crashing due to
the use-after-free
The station deletion is protected by synchronize_net(), but
that isn't enough -- ieee80211_free_tid_rx() need not have
run when that returns (it deletes the timer.) We could use
rcu_barrier() instead of synchronize_net(), but that's much
more expensive.
Instead, to fix this, add a field tracking that the session
is being deleted. In this case, the only re-arming of the
timer happens with the reorder spinlock held, so make that
code not rearm it if the session is being deleted and also
delete the timer after setting that field. This ensures the
timer cannot fire after ___ieee80211_stop_rx_ba_session()
returns, which fixes the problem.
When remove TIPC module, there is a warning to remind us that a slab
object is leaked like:
root@localhost:~# rmmod tipc
[ 19.056226] =============================================================================
[ 19.057549] BUG TIPC (Not tainted): Objects remaining in TIPC on kmem_cache_close()
[ 19.058736] -----------------------------------------------------------------------------
[ 19.058736]
[ 19.060287] INFO: Slab 0xffffea0000519a00 objects=23 used=1 fp=0xffff880014668b00 flags=0x100000000004080
[ 19.061915] INFO: Object 0xffff880014668000 @offset=0
[ 19.062717] kmem_cache_destroy TIPC: Slab cache still has objects
This is because the listening socket of TIPC topology server is not
closed before TIPC proto handler is unregistered with proto_unregister().
However, as the socket is closed in tipc_exit_net() which is called by
unregister_pernet_subsys() during unregistering TIPC namespace operation,
the warning can be eliminated if calling unregister_pernet_subsys() is
moved before calling proto_unregister().
Fixes: e05b31f4bf89 ("tipc: make tipc socket support net namespace")
Reviewed-by: Erik Hugne <erik.hugne@ericsson.com>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
When sending over AF_IUCV socket, errno was incorrectly set to
ENOMEM even when other values where appropriate, notably EAGAIN.
With this patch, error indicator returned by sock_alloc_send_skb()
is passed to the caller, rather than being overwritten with ENOMEM.
Signed-off-by: Eugene Crosser <Eugene.Crosser@ru.ibm.com>
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Return module reference before invoking the respective vport
->destroy() function. This is needed as ovs_vport_del() is not
invoked inside an RCU read side critical section so the kfree
can occur immediately before returning to ovs_vport_del().
Returning the module reference before ->destroy() is safe because
the module unregistration is blocked on ovs_lock which we hold
while destroying the datapath.
Fixes: 62b9c8d0372d ("ovs: Turn vports with dependencies into separate modules")
Reported-by: Pravin Shelar <pshelar@nicira.com>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
We currently have a problem that SELinux policy is being enforced when
creating debugfs files. If a debugfs file is created as a side effect of
doing some syscall, then that creation can fail if the SELinux policy
for that process prevents it.
This seems wrong. We don't do that for files under /proc, for instance,
so Bruce has proposed a patch to fix that.
While discussing that patch however, Greg K.H. stated:
"No kernel code should care / fail if a debugfs function fails, so
please fix up the sunrpc code first."
This patch converts all of the sunrpc debugfs setup code to be void
return functins, and the callers to not look for errors from those
functions.
This should allow rpc_clnt and rpc_xprt creation to work, even if the
kernel fails to create debugfs files for some reason.
Symptoms were failing krb5 mounts on systems using gss-proxy and
selinux.
Fixes: 388f0c776781 "sunrpc: add a debugfs rpc_xprt directory..."
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
tcp_v6_fill_cb() will be called twice if socket's state changes from
TCP_TIME_WAIT to TCP_LISTEN. That can result in control buffer data
corruption because in the second tcp_v6_fill_cb() call it's not copying
IP6CB(skb) anymore, but 'seq', 'end_seq', etc., so we can get weird and
unpredictable results. Performance loss of up to 1200% has been observed
in LTP/vxlan03 test.
This can be fixed by copying inet6_skb_parm to the beginning of 'cb'
only if xfrm6_policy_check() and tcp_v6_fill_cb() are going to be
called again.
Fixes: 2dc49d1680b53 ("tcp6: don't move IP6CB before xfrm6_policy_check()")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
With the current code, ids are removed too early.
=> a netlink message is sent in the netns foo to advertise this deletion
We must remove nsids when we are sure that nobody will refer to netns currently
cleaned.
Fixes: 0c7aecd4bde4 ("netns: add rtnl cmd to add and get peer netns ids")
A local route may have a lower hop_limit set than global routes do.
RFC 3756, Section 4.2.7, "Parameter Spoofing"
> 1. The attacker includes a Current Hop Limit of one or another small
> number which the attacker knows will cause legitimate packets to
> be dropped before they reach their destination.
> As an example, one possible approach to mitigate this threat is to
> ignore very small hop limits. The nodes could implement a
> configurable minimum hop limit, and ignore attempts to set it below
> said limit.
Signed-off-by: D.S. Ljungmark <ljungmark@modio.se>
In case we move the whole dev group to another netns,
we should call for_each_netdev_safe(), otherwise we get
a soft lockup:
NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [ip:798]
irq event stamp: 255424
hardirqs last enabled at (255423): [<ffffffff81a2aa95>] restore_args+0x0/0x30
hardirqs last disabled at (255424): [<ffffffff81a2ad5a>] apic_timer_interrupt+0x6a/0x80
softirqs last enabled at (255422): [<ffffffff81079ebc>] __do_softirq+0x2c1/0x3a9
softirqs last disabled at (255417): [<ffffffff8107a190>] irq_exit+0x41/0x95
CPU: 0 PID: 798 Comm: ip Not tainted 4.0.0-rc4+ #881
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff8800d1b88000 ti: ffff880119530000 task.ti: ffff880119530000
RIP: 0010:[<ffffffff810cad11>] [<ffffffff810cad11>] debug_lockdep_rcu_enabled+0x28/0x30
RSP: 0018:ffff880119533778 EFLAGS: 00000246
RAX: ffff8800d1b88000 RBX: 0000000000000002 RCX: 0000000000000038
RDX: 0000000000000000 RSI: ffff8800d1b888c8 RDI: ffff8800d1b888c8
RBP: ffff880119533778 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 000000000000b5c2 R12: 0000000000000246
R13: ffff880119533708 R14: 00000000001d5a40 R15: ffff88011a7d5a40
FS: 00007fc01315f740(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007f367a120988 CR3: 000000011849c000 CR4: 00000000000007f0
Stack:
ffff880119533798 ffffffff811ac868 ffffffff811ac831 ffffffff811ac828
ffff8801195337c8 ffffffff811ac8c9 ffff8801195339b0 ffff8801197633e0
0000000000000000 ffff8801195339b0 ffff8801195337d8 ffffffff811ad2d7
Call Trace:
[<ffffffff811ac868>] rcu_read_lock+0x37/0x6e
[<ffffffff811ac831>] ? rcu_read_unlock+0x5f/0x5f
[<ffffffff811ac828>] ? rcu_read_unlock+0x56/0x5f
[<ffffffff811ac8c9>] __fget+0x2a/0x7a
[<ffffffff811ad2d7>] fget+0x13/0x15
[<ffffffff811be732>] proc_ns_fget+0xe/0x38
[<ffffffff817c7714>] get_net_ns_by_fd+0x11/0x59
[<ffffffff817df359>] rtnl_link_get_net+0x33/0x3e
[<ffffffff817df3d7>] do_setlink+0x73/0x87b
[<ffffffff810b28ce>] ? trace_hardirqs_off+0xd/0xf
[<ffffffff81a2aa95>] ? retint_restore_args+0xe/0xe
[<ffffffff817e0301>] rtnl_newlink+0x40c/0x699
[<ffffffff817dffe0>] ? rtnl_newlink+0xeb/0x699
[<ffffffff81a29246>] ? _raw_spin_unlock+0x28/0x33
[<ffffffff8143ed1e>] ? security_capable+0x18/0x1a
[<ffffffff8107da51>] ? ns_capable+0x4d/0x65
[<ffffffff817de5ce>] rtnetlink_rcv_msg+0x181/0x194
[<ffffffff817de407>] ? rtnl_lock+0x17/0x19
[<ffffffff817de44d>] ? __rtnl_unlock+0x17/0x17
[<ffffffff818327c6>] netlink_rcv_skb+0x4d/0x93
[<ffffffff817de42f>] rtnetlink_rcv+0x26/0x2d
[<ffffffff81830f18>] netlink_unicast+0xcb/0x150
[<ffffffff8183198e>] netlink_sendmsg+0x501/0x523
[<ffffffff8115cba9>] ? might_fault+0x59/0xa9
[<ffffffff817b5398>] ? copy_from_user+0x2a/0x2c
[<ffffffff817b7b74>] sock_sendmsg+0x34/0x3c
[<ffffffff817b7f6d>] ___sys_sendmsg+0x1b8/0x255
[<ffffffff8115c5eb>] ? handle_pte_fault+0xbd5/0xd4a
[<ffffffff8100a2b0>] ? native_sched_clock+0x35/0x37
[<ffffffff8109e94b>] ? sched_clock_local+0x12/0x72
[<ffffffff8109eb9c>] ? sched_clock_cpu+0x9e/0xb7
[<ffffffff810cadbf>] ? rcu_read_lock_held+0x3b/0x3d
[<ffffffff811ac1d8>] ? __fcheck_files+0x4c/0x58
[<ffffffff811ac946>] ? __fget_light+0x2d/0x52
[<ffffffff817b8adc>] __sys_sendmsg+0x42/0x60
[<ffffffff817b8b0c>] SyS_sendmsg+0x12/0x1c
[<ffffffff81a29e32>] system_call_fastpath+0x12/0x17
Fixes: e7ed828f10bd8 ("netlink: support setting devgroup parameters")
On s390x, gcc 4.8 compiles this part of tcp_v6_early_demux()
struct dst_entry *dst = sk->sk_rx_dst;
if (dst)
dst = dst_check(dst, inet6_sk(sk)->rx_dst_cookie);
to code reading sk->sk_rx_dst twice, once for the test and once for
the argument of ip6_dst_check() (dst_check() is inline). This allows
ip6_dst_check() to be called with null first argument, causing a crash.
Protect sk->sk_rx_dst access by READ_ONCE() both in IPv4 and IPv6
TCP early demux code.
Fixes: 41063e9dd119 ("ipv4: Early TCP socket demux.")
Fixes: c7109986db3c ("ipv6: Early TCP socket demux")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contains Netfilter fixes for your net tree,
they are:
1) Fix missing initialization of tuple structure in nfnetlink_cthelper
to avoid mismatches when looking up to attach userspace helpers to
flows, from Ian Wilson.
2) Fix potential crash in nft_hash when we hit -EAGAIN in
nft_hash_walk(), from Herbert Xu.
3) We don't need to indicate the hook information to update the
basechain default policy in nf_tables.
4) Restore tracing over nfnetlink_log due to recent rework to
accomodate logging infrastructure into nf_tables.
5) Fix wrong IP6T_INV_PROTO check in xt_TPROXY.
6) Set IP6T_F_PROTO flag in nft_compat so we can use SYNPROXY6 and
REJECT6 from xt over nftables.
ip6tables extensions check for this flag to restrict match/target to a
given protocol. Without this flag set, SYNPROXY6 returns an error.
Acked-by: Patrick McHardy <kaber@trash.net>
Cc: stable@vger.kernel.org # v3.19
behaviour
Commit db31c55a6fb2 (net: clamp ->msg_namelen instead of returning an
error) introduced the clamping of msg_namelen when the unsigned value
was larger than sizeof(struct sockaddr_storage). This caused a
msg_namelen of -1 to be valid. The native code was subsequently fixed by
commit dbb490b96584 (net: socket: error on a negative msg_namelen).
In addition, the native code sets msg_namelen to 0 when msg_name is
NULL. This was done in commit (6a2a2b3ae075 net:socket: set msg_namelen
to 0 if msg_name is passed as NULL in msghdr struct from userland) and
subsequently updated by 08adb7dabd48 (fold verify_iovec() into
copy_msghdr_from_user()).
This patch brings the get_compat_msghdr() in line with
copy_msghdr_from_user().
Fixes: db31c55a6fb2 (net: clamp ->msg_namelen instead of returning an error)
Cc: Dan Carpenter <dan.carpenter@oracle.com>
tcp_send_fin() does not account for the memory it allocates properly, so
sk_forward_alloc can be negative in cases where we've sent a FIN:
ss example output (ss -amn | grep -B1 f4294):
tcp FIN-WAIT-1 0 1 192.168.0.1:45520 192.0.2.1:8080
skmem:(r0,rb87380,t0,tb87380,f4294966016,w1280,o0,bl0)
for throw routes to trigger evaluation of other policy rules
EAGAIN needs to be propagated up to fib_rules_lookup
similar to how its done for IPv4
A simple testcase for verification is:
ip -6 rule add lookup 33333 priority 33333
ip -6 route add throw 2001:db8::1
ip -6 route add 2001:db8::1 via fe80::1 dev wlan0 table 33333
ip route get 2001:db8::1
Signed-off-by: Steven Barth <cyrus@openwrt.org>
udp6_ufo_fragment
Matt Grant reported frequent crashes in ipv6_select_ident when
udp6_ufo_fragment is called from openvswitch on a skb that doesn't
have a dst_entry set.
ipv6_proxy_select_ident generates the frag_id without using the dst
associated with the skb. This approach was suggested by Vladislav
Yasevich.
Fixes: 0508c07f5e0c ("ipv6: Select fragment id during UFO segmentation if not set.")
Cc: Vladislav Yasevich <vyasevic@redhat.com>
Reported-by: Matt Grant <matt@mattgrant.net.nz>
Tested-by: Matt Grant <matt@mattgrant.net.nz>
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Acked-by: Vladislav Yasevich <vyasevic@redhat.com>
