[ Upstream commit c0c0c50ff7c3e331c90bab316d21f724fb9e1994 ]
When dealing with icmp messages, the skb->data points the
ip header that triggered the sending of the icmp message.
In gre_cisco_err(), the parse_gre_header() is called, and the
iptunnel_pull_header() is called to pull the skb at the end of
the parse_gre_header(), so the skb->data doesn't point the
inner ip header.
Unfortunately, the ipgre_err still needs those ip addresses in
inner ip header to look up tunnel by ip_tunnel_lookup().
So just use icmp_hdr() to get inner ip header instead of skb->data.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
[ Upstream commit a452ce345d63ddf92cd101e4196569f8718ad319 ]
I see a memory leak when using a transparent HTTP proxy using TPROXY
together with TCP early demux and Kernel v3.8.13.15 (Ubuntu stable):
unreferenced object 0xffff88008cba4a40 (size 1696):
comm "softirq", pid 0, jiffies 4294944115 (age 8907.520s)
hex dump (first 32 bytes):
0a e0 20 6a 40 04 1b 37 92 be 32 e2 e8 b4 00 00 .. j@..7..2.....
02 00 07 01 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff810b710a>] kmem_cache_alloc+0xad/0xb9
[<ffffffff81270185>] sk_prot_alloc+0x29/0xc5
[<ffffffff812702cf>] sk_clone_lock+0x14/0x283
[<ffffffff812aaf3a>] inet_csk_clone_lock+0xf/0x7b
[<ffffffff8129a893>] netlink_broadcast+0x14/0x16
[<ffffffff812c1573>] tcp_create_openreq_child+0x1b/0x4c3
[<ffffffff812c033e>] tcp_v4_syn_recv_sock+0x38/0x25d
[<ffffffff812c13e4>] tcp_check_req+0x25c/0x3d0
[<ffffffff812bf87a>] tcp_v4_do_rcv+0x287/0x40e
[<ffffffff812a08a7>] ip_route_input_noref+0x843/0xa55
[<ffffffff812bfeca>] tcp_v4_rcv+0x4c9/0x725
[<ffffffff812a26f4>] ip_local_deliver_finish+0xe9/0x154
[<ffffffff8127a927>] __netif_receive_skb+0x4b2/0x514
[<ffffffff8127aa77>] process_backlog+0xee/0x1c5
[<ffffffff8127c949>] net_rx_action+0xa7/0x200
[<ffffffff81209d86>] add_interrupt_randomness+0x39/0x157
But there are many more, resulting in the machine going OOM after some
days.
From looking at the TPROXY code, and with help from Florian, I see
that the memory leak is introduced in tcp_v4_early_demux():
void tcp_v4_early_demux(struct sk_buff *skb)
iph = ip_hdr(skb);
th = tcp_hdr(skb);
if (th->doff < sizeof(struct tcphdr) / 4)
return;
sk = __inet_lookup_established(dev_net(skb->dev), &tcp_hashinfo,
iph->saddr, th->source,
iph->daddr, ntohs(th->dest),
skb->skb_iif);
if (sk) {
skb->sk = sk;
where the socket is assigned unconditionally to skb->sk, also bumping
the refcnt on it. This is problematic, because in our case the skb
has already a socket assigned in the TPROXY target. This then results
in the leak I see.
The very same issue seems to be with IPv6, but haven't tested.
Reviewed-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
[ Upstream commit a0065f266a9b5d51575535a25c15ccbeed9a9966 ]
The two commits 0115e8e30d (net: remove delay at device dismantle) and
748e2d9396a (net: reinstate rtnl in call_netdevice_notifiers()) silently
removed a NULL pointer check for in_dev since Linux 3.7.
This patch re-introduces this check as it causes crashing the kernel when
setting small mtu values on non-ip capable netdevices.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
[ Upstream commit 11c21a307d79ea5f6b6fc0d3dfdeda271e5e65f6 ]
commit a622260254ee48("ip_tunnel: fix kernel panic with icmp_dest_unreach")
clear IPCB in ip_tunnel_xmit() , or else skb->cb[] may contain garbage from
GSO segmentation layer.
But commit 0e6fbc5b6c621("ip_tunnels: extend iptunnel_xmit()") refactor codes,
and it clear IPCB behind the dst_link_failure().
So clear IPCB in ip_tunnel_xmit() just like commti a622260254ee48("ip_tunnel:
fix kernel panic with icmp_dest_unreach").
commit 2def2ef2ae5f3990aabdbe8a755911902707d268 upstream.
The x32 case for the recvmsg() timout handling is broken:
asmlinkage long compat_sys_recvmmsg(int fd, struct compat_mmsghdr __user *mmsg,
unsigned int vlen, unsigned int flags,
struct compat_timespec __user *timeout)
int datagrams;
struct timespec ktspec;
if (flags & MSG_CMSG_COMPAT)
return -EINVAL;
if (COMPAT_USE_64BIT_TIME)
return __sys_recvmmsg(fd, (struct mmsghdr __user *)mmsg, vlen,
flags | MSG_CMSG_COMPAT,
(struct timespec *) timeout);
The timeout pointer parameter is provided by userland (hence the __user
annotation) but for x32 syscalls it's simply cast to a kernel pointer
and is passed to __sys_recvmmsg which will eventually directly
dereference it for both reading and writing. Other callers to
__sys_recvmmsg properly copy from userland to the kernel first.
The bug was introduced by commit ee4fa23c4bfc ("compat: Use
COMPAT_USE_64BIT_TIME in net/compat.c") and should affect all kernels
since 3.4 (and perhaps vendor kernels if they backported x32 support
along with this code).
Note that CONFIG_X86_X32_ABI gets enabled at build time and only if
CONFIG_X86_X32 is enabled and ld can build x32 executables.
Other uses of COMPAT_USE_64BIT_TIME seem fine.
This addresses CVE-2014-0038.
Signed-off-by: PaX Team <pageexec@freemail.hu>
In commit 1ec047eb4751e3 ("ipv6: introduce per-interface counter for
dad-completed ipv6 addresses") I build the detection of the first
operational link-local address much to complex. Additionally this code
now has a race condition.
Replace it with a much simpler variant, which just scans the address
list when duplicate address detection completes, to check if this is
the first valid link local address and send RS and MLD reports then.
Fixes: 1ec047eb4751e3 ("ipv6: introduce per-interface counter for dad-completed ipv6 addresses")
Reported-by: Jiri Pirko <jiri@resnulli.us>
Cc: Flavio Leitner <fbl@redhat.com>
Acked-by: Flavio Leitner <fbl@redhat.com>
Acked-by: Jiri Pirko <jiri@resnulli.us>
Because the tcp-metrics is an RCU-list, it may be that two
soft-interrupts are inside __tcp_get_metrics() for the same
destination-IP at the same time. If this destination-IP is not yet part of
the tcp-metrics, both soft-interrupts will end up in tcpm_new and create
a new entry for this IP.
So, we will have two tcp-metrics with the same destination-IP in the list.
This patch checks twice __tcp_get_metrics(). First without holding the
lock, then while holding the lock. The second one is there to confirm
that the entry has not been added by another soft-irq while waiting for
the spin-lock.
Fixes: 51c5d0c4b169b (tcp: Maintain dynamic metrics in local cache.)
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit ae4b46e9d "net: rds: use this_cpu_* per-cpu helper" broke per-cpu
handling for rds. chpfirst is the result of __this_cpu_read(), so it is
an absolute pointer and not __percpu. Therefore, __this_cpu_write()
should not operate on chpfirst, but rather on cache->percpu->first, just
like __this_cpu_read() did before.
Cc: <stable@vger.kernel.org> # 3.8+
Signed-off-byd Gerald Schaefer <gerald.schaefer@de.ibm.com>
Included change:
- properly compute the batman-adv header overhead. Such
result is later used to initialize the hard_header_len
member of the soft-interface netdev object
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
Batman-adv prepends a full ethernet header in addition to its own
header. This has to be reflected in the MTU calculation, especially
since the value is used to set dev->hard_header_len.
Introduced by 411d6ed93a5d0601980d3e5ce75de07c98e3a7de
("batman-adv: consider network coding overhead when calculating required mtu")
Reported-by: cmsv <cmsv@wirelesspt.net>
Reported-by: Martin Hundebøll <martin@hundeboll.net>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
Bob Falken reported that after 4G packets, multicast forwarding stopped
working. This was because of a rule reference counter overflow which
freed the rule as soon as the overflow happend.
This patch solves this by adding the FIB_LOOKUP_NOREF flag to
fib_rules_lookup calls. This is safe even from non-rcu locked sections
as in this case the flag only implies not taking a reference to the rule,
which we don't need at all.
Rules only hold references to the namespace, which are guaranteed to be
available during the call of the non-rcu protected function reg_vif_xmit
because of the interface reference which itself holds a reference to
the net namespace.
Fixes: f0ad0860d01e47 ("ipv4: ipmr: support multiple tables")
Fixes: d1db275dd3f6e4 ("ipv6: ip6mr: support multiple tables")
Reported-by: Bob Falken <NetFestivalHaveFun@gmx.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Julian Anastasov <ja@ssi.bg>
Fix a memory leak in the ieee802154_add_iface() error handling path.
Detected by Coverity: CID 710490.
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
Fix inet_diag_dump_icsk() to reflect the fact that both TCP_TIME_WAIT
and TCP_FIN_WAIT2 connections are represented by inet_timewait_sock
(not just TIME_WAIT), and for such sockets the tw_substate field holds
the real state, which can be either TCP_TIME_WAIT or TCP_FIN_WAIT2.
This brings the inet_diag state-matching code in line with the field
it uses to populate idiag_state. This is also analogous to the info
exported in /proc/net/tcp, where get_tcp4_sock() exports sk->sk_state
and get_timewait4_sock() exports tw->tw_substate.
Before fixing this, (a) neither "ss -nemoi" nor "ss -nemoi state
fin-wait-2" would return a socket in TCP_FIN_WAIT2; and (b) "ss -nemoi
state time-wait" would also return sockets in state TCP_FIN_WAIT2.
This is an old bug that predates 05dbc7b ("tcp/dccp: remove twchain").
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Eric Dumazet <edumazet@google.com>
Currently, the tx queue were selected implicitly in ndo_dfwd_start_xmit(). The
will cause several issues:
- NETIF_F_LLTX were removed for macvlan, so txq lock were done for macvlan
instead of lower device which misses the necessary txq synchronization for
lower device such as txq stopping or frozen required by dev watchdog or
control path.
- dev_hard_start_xmit() was called with NULL txq which bypasses the net device
watchdog.
- dev_hard_start_xmit() does not check txq everywhere which will lead a crash
when tso is disabled for lower device.
Fix this by explicitly introducing a new param for .ndo_select_queue() for just
selecting queues in the case of l2 forwarding offload. netdev_pick_tx() was also
extended to accept this parameter and dev_queue_xmit_accel() was used to do l2
forwarding transmission.
With this fixes, NETIF_F_LLTX could be preserved for macvlan and there's no need
to check txq against NULL in dev_hard_start_xmit(). Also there's no need to keep
a dedicated ndo_dfwd_start_xmit() and we can just reuse the code of
dev_queue_xmit() to do the transmission.
In the future, it was also required for macvtap l2 forwarding support since it
provides a necessary synchronization method.
Cc: John Fastabend <john.r.fastabend@intel.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: e1000-devel@lists.sourceforge.net
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: John Fastabend <john.r.fastabend@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
For the mac80211 bits, Johannes says:
"I have a fix from Javier for mac80211_hwsim when used with wmediumd
userspace, and a fix from Felix for buffering in AP mode."
For the NFC bits, Samuel says:
"This pull request only contains one fix for a regression introduced with
commit e29a9e2ae165620d. Without this fix, we can not establish a p2p link
in target mode. Only initiator mode works."
For the iwlwifi bits, Emmanuel says:
"It only includes new device IDs so it's not vital. If you have a pull
request to net.git anyway, I'd happy to have this in."
In the past the IFA_PERMANENT flag indicated, that the valid and preferred
lifetime where ignored. Since change fad8da3e085ddf ("ipv6 addrconf: fix
preferred lifetime state-changing behavior while valid_lft is infinity")
we honour at least the preferred lifetime on those addresses. As such
the valid lifetime gets recalculated and updated to 0.
If loopback address is added manually this problem does not occur.
Also if NetworkManager manages IPv6, those addresses will get added via
inet6_rtm_newaddr and thus will have a correct lifetime, too.
Reported-by: François-Xavier Le Bail <fx.lebail@yahoo.com>
Reported-by: Damien Wyart <damien.wyart@gmail.com>
Fixes: fad8da3e085ddf ("ipv6 addrconf: fix preferred lifetime state-changing behavior while valid_lft is infinity")
Cc: Yasushi Asano <yasushi.asano@jp.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/nfc-fixes
Samuel Ortiz <sameo@linux.intel.com> says:
"This is the first NFC fixes pull request for 3.13.
It only contains one fix for a regression introduced with commit
e29a9e2ae165620d. Without this fix, we can not establish a p2p link in
Pablo Neira Ayuso says:
The following patchset contains two patches:
* fix the IRC NAT helper which was broken when adding (incomplete) IPv6
support, from Daniel Borkmann.
* Refine the previous bugtrap that Jesper added to catch problems for the
usage of the sequence adjustment extension in IPVs in Dec 16th, it may
spam messages in case of finding a real bug.
When we pull a received packet from a link's 'deferred packets' queue
for processing, its 'next' pointer is not cleared, and still refers to
the next packet in that queue, if any. This is incorrect, but caused
no harm before commit 40ba3cdf542a469aaa9083fa041656e59b109b90 ("tipc:
message reassembly using fragment chain") was introduced. After that
commit, it may sometimes lead to the following oops:
general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: tipc
CPU: 4 PID: 0 Comm: swapper/4 Tainted: G W 3.13.0-rc2+ #6
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
task: ffff880017af4880 ti: ffff880017aee000 task.ti: ffff880017aee000
RIP: 0010:[<ffffffff81710694>] [<ffffffff81710694>] skb_try_coalesce+0x44/0x3d0
RSP: 0018:ffff880016603a78 EFLAGS: 00010212
RAX: 6b6b6b6bd6d6d6d6 RBX: ffff880013106ac0 RCX: ffff880016603ad0
RDX: ffff880016603ad7 RSI: ffff88001223ed00 RDI: ffff880013106ac0
RBP: ffff880016603ab8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffff88001223ed00
R13: ffff880016603ad0 R14: 000000000000058c R15: ffff880012297650
FS: 0000000000000000(0000) GS:ffff880016600000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000805b000 CR3: 0000000011f5d000 CR4: 00000000000006e0
Stack:
ffff880016603a88 ffffffff810a38ed ffff880016603aa8 ffff88001223ed00
0000000000000001 ffff880012297648 ffff880016603b68 ffff880012297650
ffff880016603b08 ffffffffa0006c51 ffff880016603b08 00ffffffa00005fc
Call Trace:
<IRQ>
[<ffffffff810a38ed>] ? trace_hardirqs_on+0xd/0x10
[<ffffffffa0006c51>] tipc_link_recv_fragment+0xd1/0x1b0 [tipc]
[<ffffffffa0007214>] tipc_recv_msg+0x4e4/0x920 [tipc]
[<ffffffffa00016f0>] ? tipc_l2_rcv_msg+0x40/0x250 [tipc]
[<ffffffffa000177c>] tipc_l2_rcv_msg+0xcc/0x250 [tipc]
[<ffffffff8171e65b>] __netif_receive_skb_core+0x80b/0xd00
[<ffffffff8171df94>] ? __netif_receive_skb_core+0x144/0xd00
[<ffffffff8171eb76>] __netif_receive_skb+0x26/0x70
[<ffffffff8171ed6d>] netif_receive_skb+0x2d/0x200
[<ffffffff8171fe70>] napi_gro_receive+0xb0/0x130
[<ffffffff815647c2>] e1000_clean_rx_irq+0x2c2/0x530
[<ffffffff81565986>] e1000_clean+0x266/0x9c0
[<ffffffff81985f7b>] ? notifier_call_chain+0x2b/0x160
[<ffffffff8171f971>] net_rx_action+0x141/0x310
[<ffffffff81051c1b>] __do_softirq+0xeb/0x480
[<ffffffff819817bb>] ? _raw_spin_unlock+0x2b/0x40
[<ffffffff810b8c42>] ? handle_fasteoi_irq+0x72/0x100
[<ffffffff81052346>] irq_exit+0x96/0xc0
[<ffffffff8198cbc3>] do_IRQ+0x63/0xe0
[<ffffffff81981def>] common_interrupt+0x6f/0x6f
<EOI>
This happens when the last fragment of a message has passed through the
the receiving link's 'deferred packets' queue, and at least one other
packet was added to that queue while it was there. After the fragment
chain with the complete message has been successfully delivered to the
receiving socket, it is released. Since 'next' pointer of the last
fragment in the released chain now is non-NULL, we get the crash shown
above.
We fix this by clearing the 'next' pointer of all received packets,
including those being pulled from the 'deferred' queue, before they
undergo any further processing.
Fixes: 40ba3cdf542a4 ("tipc: message reassembly using fragment chain")
Signed-off-by: Erik Hugne <erik.hugne@ericsson.com>
Reported-by: Ying Xue <ying.xue@windriver.com>
Reviewed-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
initialise pcpu_tstats.syncp to kill the calltrace
[ 11.973950] Call Trace:
[ 11.973950] [<819bbaff>] dump_stack+0x48/0x60
[ 11.973950] [<81078dcf>] __lock_acquire.isra.22+0x1bf/0xc10
[ 11.973950] [<81079fa7>] lock_acquire+0x77/0xa0
[ 11.973950] [<817ca7ab>] ? dev_get_stats+0xcb/0x130
[ 11.973950] [<8183862d>] ip_tunnel_get_stats64+0x6d/0x230
[ 11.973950] [<811cf8c1>] ? __nla_reserve+0x21/0xd0
[ 11.973950] [<817ca7ab>] dev_get_stats+0xcb/0x130
[ 11.973950] [<817d5409>] rtnl_fill_ifinfo+0x569/0xe20
[ 11.973950] [<810352e0>] ? kvm_clock_read+0x20/0x30
[ 11.973950] [<81008e38>] ? sched_clock+0x8/0x10
[ 11.973950] [<8106ba45>] ? sched_clock_local+0x25/0x170
[ 11.973950] [<810da6bd>] ? __kmalloc+0x3d/0x90
[ 11.973950] [<817b8c10>] ? __kmalloc_reserve.isra.41+0x20/0x70
[ 11.973950] [<810da81a>] ? slob_alloc_node+0x2a/0x60
[ 11.973950] [<817b919a>] ? __alloc_skb+0x6a/0x2b0
[ 11.973950] [<817d8795>] rtmsg_ifinfo+0x65/0xe0
[ 11.973950] [<817cbd31>] register_netdevice+0x531/0x5a0
[ 11.973950] [<81892b87>] ? ip6_tnl_get_cap+0x27/0x90
[ 11.973950] [<817cbdb6>] register_netdev+0x16/0x30
[ 11.973950] [<81f574a6>] vti6_init_net+0x1c4/0x1d4
[ 11.973950] [<81f573af>] ? vti6_init_net+0xcd/0x1d4
[ 11.973950] [<817c16df>] ops_init.constprop.11+0x17f/0x1c0
[ 11.973950] [<817c1779>] register_pernet_operations.isra.9+0x59/0x90
[ 11.973950] [<817c18d1>] register_pernet_device+0x21/0x60
[ 11.973950] [<81f574b6>] ? vti6_init_net+0x1d4/0x1d4
[ 11.973950] [<81f574c7>] vti6_tunnel_init+0x11/0x68
[ 11.973950] [<81f572a1>] ? mip6_init+0x73/0xb4
[ 11.973950] [<81f0cba4>] do_one_initcall+0xbb/0x15b
[ 11.973950] [<811a00d8>] ? sha_transform+0x528/0x1150
[ 11.973950] [<81f0c544>] ? repair_env_string+0x12/0x51
[ 11.973950] [<8105c30d>] ? parse_args+0x2ad/0x440
[ 11.973950] [<810546be>] ? __usermodehelper_set_disable_depth+0x3e/0x50
[ 11.973950] [<81f0cd27>] kernel_init_freeable+0xe3/0x182
[ 11.973950] [<81f0c532>] ? do_early_param+0x7a/0x7a
[ 11.973950] [<819b5b1b>] kernel_init+0xb/0x100
[ 11.973950] [<819cebf7>] ret_from_kernel_thread+0x1b/0x28
[ 11.973950] [<819b5b10>] ? rest_init+0xc0/0xc0
Before 469bdcefdc ("ipv6: fix the use of pcpu_tstats in ip6_vti.c"),
the pcpu_tstats.syncp is not used to pretect the 64bit elements of
pcpu_tstats, so not appear this calltrace.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
br_multicast_set_hash_max() is called from process context in
net/bridge/br_sysfs_br.c by the sysfs store_hash_max() function.
br_multicast_set_hash_max() calls spin_lock(&br->multicast_lock),
which can deadlock the CPU if a softirq that also tries to take the
same lock interrupts br_multicast_set_hash_max() while the lock is
held . This can happen quite easily when any of the bridge multicast
timers expire, which try to take the same lock.
The fix here is to use spin_lock_bh(), preventing other softirqs from
executing on this CPU.
Steps to reproduce:
1. Create a bridge with several interfaces (I used 4).
2. Set the "multicast query interval" to a low number, like 2.
3. Enable the bridge as a multicast querier.
4. Repeatedly set the bridge hash_max parameter via sysfs.
# brctl addbr br0
# brctl addif br0 eth1 eth2 eth3 eth4
# brctl setmcqi br0 2
# brctl setmcquerier br0 1
# while true ; do echo 4096 > /sys/class/net/br0/bridge/hash_max; done
Signed-off-by: Curt Brune <curt@cumulusnetworks.com>
Signed-off-by: Scott Feldman <sfeldma@cumulusnetworks.com>
It does not make sense to create an anycast address for an /128-prefix.
Suppress it.
As 32019e651c6fce ("ipv6: Do not leave router anycast address for /127
prefixes.") shows we also may not leave them, because we could accidentally
remove an anycast address the user has allocated or got added via another
prefix.
Cc: François-Xavier Le Bail <fx.lebail@yahoo.com>
Cc: Thomas Haller <thaller@redhat.com>
Cc: Jiri Pirko <jiri@resnulli.us>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Avoid potentially spamming the kernel log with WARN splash messages
when catching wrong usage of seqadj, by simply using WARN_ONCE.
This is a followup to commit db12cf274353 (netfilter: WARN about
wrong usage of sequence number adjustments)
Suggested-by: Flavio Leitner <fbl@redhat.com>
Suggested-by: Daniel Borkmann <dborkman@redhat.com>
Suggested-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Commit 5901b6be885e attempted to introduce IPv6 support into
IRC NAT helper. By doing so, the following code seemed to be removed
by accident:
ip = ntohl(exp->master->tuplehash[IP_CT_DIR_REPLY].tuple.dst.u3.ip);
sprintf(buffer, "%u %u", ip, port);
pr_debug("nf_nat_irc: inserting '%s' == %pI4, port %u\n", buffer, &ip, port);
This leads to the fact that buffer[] was left uninitialized and
contained some stack value. When we call nf_nat_mangle_tcp_packet(),
we call strlen(buffer) on excatly this uninitialized buffer. If we
are unlucky and the skb has enough tailroom, we overwrite resp. leak
contents with values that sit on our stack into the packet and send
that out to the receiver.
Since the rather informal DCC spec [1] does not seem to specify
IPv6 support right now, we log such occurences so that admins can
act accordingly, and drop the packet. I've looked into XChat source,
and IPv6 is not supported there: addresses are in u32 and print
via %u format string.
Therefore, restore old behaviour as in IPv4, use snprintf(). The
IRC helper does not support IPv6 by now. By this, we can safely use
strlen(buffer) in nf_nat_mangle_tcp_packet() and prevent a buffer
overflow. Also simplify some code as we now have ct variable anyway.
[1] http://www.irchelp.org/irchelp/rfc/ctcpspec.html
Fixes: 5901b6be885e ("netfilter: nf_nat: support IPv6 in IRC NAT helper")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Harald Welte <laforge@gnumonks.org>
In function lowpan_header_create(), we invoke the following code
construct:
struct ipv6hdr *hdr;
hdr = ipv6_hdr(skb);
if (...)
memcpy(hc06_ptr + 1, &hdr->flow_lbl[1], 2);
else
memcpy(hc06_ptr, &hdr, 4);
Where the else path of the condition, that is, non-compression
path, calls memcpy() with a pointer to struct ipv6hdr *hdr as
source, thus two levels of indirection. This cannot be correct,
and likely only one level of pointer was intended as source
buffer for memcpy() here.
Fixes: 44331fe2aa0d ("IEEE802.15.4: 6LoWPAN basic support")
Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Werner Almesberger <werner@almesberger.net>
With commit e29a9e2ae165620d, we set the active_target pointer from
nfc_dep_link_is_up() in order to support the case where the target
detection and the DEP link setting are done atomically by the driver.
That can only happen in initiator mode, so we need to check for that
otherwise we fail to bring a p2p link in target mode.
Signed-off-by: Arron Wang <arron.wang@intel.com>
The VLAN tag handling code in netpoll_send_skb_on_dev() has two problems.
1) It exits without unlocking the TXQ.
2) It then tries to queue a NULL skb to npinfo->txq.
Reported-by: Ahmed Tamrawi <atamrawi@iastate.edu>
when read/write the 64bit data, the correct lock should be hold.
and we can use the generic vti6_get_stats to return stats, and
not define a new one in ip6_vti.c
Fixes: 87b6d218f3adb ("tunnel: implement 64 bits statistics")
Cc: Stephen Hemminger <stephen@networkplumber.org>
Fixed a problem with setting the lifetime of an IPv6
address. When setting preferred_lft to a value not zero or
infinity, while valid_lft is infinity(0xffffffff) preferred
lifetime is set to forever and does not update. Therefore
preferred lifetime never becomes deprecated. valid lifetime
and preferred lifetime should be set independently, even if
valid lifetime is infinity, preferred lifetime must expire
correctly (meaning it must eventually become deprecated)
Signed-off-by: Yasushi Asano <yasushi.asano@jp.fujitsu.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
While commit 30a584d944fb fixes datagram interface in LLC, a use
after free bug has been introduced for SOCK_STREAM sockets that do
not make use of MSG_PEEK.
The flow is as follow ...
if (!(flags & MSG_PEEK)) {
sk_eat_skb(sk, skb, false);
if (used + offset < skb->len)
continue;
... where sk_eat_skb() calls __kfree_skb(). Therefore, cache
original length and work on skb_len to check partial reads.
Fixes: 30a584d944fb ("[LLX]: SOCK_DGRAM interface fixes")
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
VM to VM GSO traffic is broken if it goes through VXLAN or GRE
tunnel and the physical NIC on the host supports hardware VXLAN/GRE
GSO offload (e.g. bnx2x and next-gen mlx4).
Two issues -
(VXLAN) VM traffic has SKB_GSO_DODGY and SKB_GSO_UDP_TUNNEL with
SKB_GSO_TCP/UDP set depending on the inner protocol. GSO header
integrity check fails in udp4_ufo_fragment if inner protocol is
TCP. Also gso_segs is calculated incorrectly using skb->len that
includes tunnel header. Fix: robust check should only be applied
to the inner packet.
(VXLAN & GRE) Once GSO header integrity check passes, NULL segs
is returned and the original skb is sent to hardware. However the
tunnel header is already pulled. Fix: tunnel header needs to be
restored so that hardware can perform GSO properly on the original
packet.
Signed-off-by: Wei-Chun Chao <weichunc@plumgrid.com>
The SCTP outqueue structure maintains a data chunks
that are pending transmission, the list of chunks that
are pending a retransmission and a length of data in
flight. It also tries to keep the emtpy state so that
it can performe shutdown sequence or notify user.
The problem is that the empy state is inconsistently
tracked. It is possible to completely drain the queue
without sending anything when using PR-SCTP. In this
case, the empty state will not be correctly state as
report by Jamal Hadi Salim <jhs@mojatatu.com>. This
can cause an association to be perminantly stuck in the
SHUTDOWN_PENDING state.
Additionally, SCTP is incredibly inefficient when setting
the empty state. Even though all the data is availaible
in the outqueue structure, we ignore it and walk a list
of trasnports.
In the end, we can completely remove the extra empty
state and figure out if the queue is empty by looking
at 3 things: length of pending data, length of in-flight
data, and exisiting of retransmit data. All of these
are already in the strucutre.
Reported-by: Jamal Hadi Salim <jhs@mojatatu.com>
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
Tested-by: Jamal Hadi Salim <jhs@mojatatu.com>
When the vlan code detects that the real device can do TX VLAN offloads
in hardware, it tries to arrange for the real device's header_ops to
be invoked directly.
But it does so illegally, by simply hooking the real device's
header_ops up to the VLAN device.
This doesn't work because we will end up invoking a set of header_ops
routines which expect a device type which matches the real device, but
will see a VLAN device instead.
Fix this by providing a pass-thru set of header_ops which will arrange
to pass the proper real device instead.
To facilitate this add a dev_rebuild_header(). There are
implementations which provide a ->cache and ->create but not a
->rebuild (f.e. PLIP). So we need a helper function just like
dev_hard_header() to avoid crashes.
Use this helper in the one existing place where the
header_ops->rebuild was being invoked, the neighbour code.
With lots of help from Florian Westphal.
recvmsg handler in net/rose/af_rose.c performs size-check ->msg_namelen.
After commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c
(net: rework recvmsg handler msg_name and msg_namelen logic), we now
always take the else branch due to namelen being initialized to 0.
Digging in netdev-vger-cvs git repo shows that msg_namelen was
initialized with a fixed-size since at least 1995, so the else branch
was never taken.
Compile tested only.
A deadlock might occur if name table is withdrawn in socket release
routine, and while packets are still being received from bearer.
CPU0 CPU1
T0: recv_msg() release()
T1: tipc_recv_msg() tipc_withdraw()
T2: [grab node lock] [grab port lock]
T3: tipc_link_wakeup_ports() tipc_nametbl_withdraw()
T4: [grab port lock]* named_cluster_distribute()
T5: wakeupdispatch() tipc_link_send()
T6: [grab node lock]*
The opposite order of holding port lock and node lock on above two
different paths may result in a deadlock. If socket lock instead of
port lock is used to protect port instance in tipc_withdraw(), the
reverse order of holding port lock and node lock will be eliminated,
as a result, the deadlock is killed as well.
Reported-by: Lars Everbrand <lars.everbrand@ericsson.com>
Reviewed-by: Erik Hugne <erik.hugne@ericsson.com>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Included changes:
- reset netfilter-bridge state when removing the batman-adv
header from an incoming packet. This prevents netfilter
bridge from being fooled when the same packet enters a
bridge twice (or more): the first time within the
batman-adv header and the second time without.
- adjust the packet layout to prevent any architecture from
adding padding bytes. All the structs sent over the wire
now have size multiple of 4bytes (unless pack(2) is used).
- fix access to the inner vlan_eth header when reading the
VID in the rx path.
Netfilter/IPVS fixes for net
This patchset contains four nf_tables fixes, one IPVS fix due to
missing updates in the interaction with the new sedadj conntrack
extension that was added to support the netfilter synproxy code,
and a couple of one-liners to fix netnamespace netfilter issues.
More specifically, they are:
* Fix ipv6_find_hdr() call without offset being explicitly initialized
in nft_exthdr, as required by that function, from Daniel Borkmann.
* Fix oops in nfnetlink_log when using netns and unloading the kernel
module, from Gao feng.
* Fix BUG_ON in nf_ct_timestamp extension after netns is destroyed,
from Helmut Schaa.
* Fix crash in IPVS due to missing sequence adjustment extension being
allocated in the conntrack, from Jesper Dangaard Brouer.
* Add bugtrap to spot a warning in case you deference sequence adjustment
conntrack area when not available, this should help to catch similar
invalid dereferences in the Netfilter tree, also from Jesper.
* Fix incomplete dumping of sets in nf_tables when retrieving by family,
from me.
* Fix oops when updating the table state (dormant <-> active) and having
user (not base ) chains, from me.
* Fix wrong validation in set element data that results in returning
-EINVAL when using the nf_tables dictionary feature with mappings,
also from me.
We don't usually have this amount of fixes by this time (as we're already
in -rc5 of the development cycle), although half of them are related to
nf_tables which is a relatively new thing, and I also believe that holidays
have also delayed the flight of bugfixes to mainstream a bit.
This patch fixes dictionary mappings, eg.
add rule ip filter input meta dnat set tcp dport map { 22 => 1.1.1.1, 23 => 2.2.2.2 }
The kernel was returning -EINVAL in nft_validate_data_load() since
the type of the set element data that is passed was the real userspace
datatype instead of NFT_DATA_VALUE.
When batadv_get_vid() is invoked in interface_rx() the
batman-adv header has already been removed, therefore
the header_len argument has to be 0.
Introduced by c018ad3de61a1dc4194879a53e5559e094aa7b1a
("batman-adv: add the VLAN ID attribute to the TT entry")
If an interface enslaved into batman-adv is a bridge (or a
virtual interface built on top of a bridge) the nf_bridge
member of the skbs reaching the soft-interface is filled
with the state about "netfilter bridge" operations.
Then, if one of such skbs is locally delivered, the nf_bridge
member should be cleaned up to avoid that the old state
could mess up with other "netfilter bridge" operations when
entering a second bridge.
This is needed because batman-adv is an encapsulation
protocol.
However at the moment skb->nf_bridge is not released at all
leading to bogus "netfilter bridge" behaviours.
Fix this by cleaning the netfilter state of the skb before
it gets delivered to the upper layer in interface_rx().
Make struct batadv_tvlv_tt_change a multiple 4 bytes long
to avoid padding on any architecture.
Since this is a mac address and always 48 bit, and we can assume that
it is always aligned to 2-byte boundaries, add a pack(2) pragma.
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
struct batadv_icmp_header currently has a size of 17, which
will be padded to 20 on some architectures. Fix this by
unrolling the header into the parent structures.
Moreover keep the ICMP parsing functions as generic as they
are now by using a stub icmp_header struct during packet
parsing.
The size of the batadv_header of 3 is problematic on some architectures
which automatically pad all structures to a 32 bit boundary. To not lose
performance by packing this struct, better embed it into the various
host structures.
Reported-by: Russell King <linux@arm.linux.org.uk>
The compiler may decide to pad the structure, and then it does not
have the expected size of 46 byte. Fix this by moving it in the
pragma pack(2) part of the code.
