path: root/net
2018-05-30netlabel: If PF_INET6, check sk_buff ip header versionRichard Haines
[ Upstream commit 213d7f94775322ba44e0bbb55ec6946e9de88cea ] When resolving a fallback label, check the sk_buff version as it is possible (e.g. SCTP) to have family = PF_INET6 while receiving ip_hdr(skb)->version = 4. Signed-off-by: Richard Haines <richard_c_haines@btinternet.com> Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30rxrpc: Don't treat call aborts as conn abortsDavid Howells
[ Upstream commit 57b0c9d49b94bbeb53649b7fbd264603c1ebd585 ] If a call-level abort is received for the previous call to complete on a connection channel, then that abort is queued for the connection processor to handle. Unfortunately, the connection processor then assumes without checking that the abort is connection-level (ie. callNumber is 0) and distributes it over all active calls on that connection, thereby incorrectly aborting them. Fix this by discarding aborts aimed at a completed call. Further, discard all packets aimed at a call that's complete if there's currently an active call on a channel, since the DATA packets associated with the new call automatically terminate the old call. Fixes: 18bfeba50dfd ("rxrpc: Perform terminal call ACK/ABORT retransmission from conn processor") Reported-by: Marc Dionne <marc.dionne@auristor.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30rxrpc: Fix Tx ring annotation after initial Tx failureDavid Howells
[ Upstream commit 03877bf6a30cca7d4bc3ffabd3c3e9464a7a1a19 ] rxrpc calls have a ring of packets that are awaiting ACK or retransmission and a parallel ring of annotations that tracks the state of those packets. If the initial transmission of a packet on the underlying UDP socket fails then the packet annotation is marked for resend - but the setting of this mark accidentally erases the last-packet mark also stored in the same annotation slot. If this happens, a call won't switch out of the Tx phase when all the packets have been transmitted. Fix this by retaining the last-packet mark and only altering the packet state. Fixes: 248f219cb8bc ("rxrpc: Rewrite the data and ack handling code") Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30net: Fix untag for vlan packets without ethernet headerToshiaki Makita
[ Upstream commit ae4745730cf8e693d354ccd4dbaf59ea440c09a9 ] In some situation vlan packets do not have ethernet headers. One example is packets from tun devices. Users can specify vlan protocol in tun_pi field instead of IP protocol, and skb_vlan_untag() attempts to untag such packets. skb_vlan_untag() (more precisely, skb_reorder_vlan_header() called by it) however did not expect packets without ethernet headers, so in such a case size argument for memmove() underflowed and triggered crash. ==== BUG: unable to handle kernel paging request at ffff8801cccb8000 IP: __memmove+0x24/0x1a0 arch/x86/lib/memmove_64.S:43 PGD 9cee067 P4D 9cee067 PUD 1d9401063 PMD 1cccb7063 PTE 2810100028101 Oops: 000b [#1] SMP KASAN Dumping ftrace buffer: (ftrace buffer empty) Modules linked in: CPU: 1 PID: 17663 Comm: syz-executor2 Not tainted 4.16.0-rc7+ #368 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 RIP: 0010:__memmove+0x24/0x1a0 arch/x86/lib/memmove_64.S:43 RSP: 0018:ffff8801cc046e28 EFLAGS: 00010287 RAX: ffff8801ccc244c4 RBX: fffffffffffffffe RCX: fffffffffff6c4c2 RDX: fffffffffffffffe RSI: ffff8801cccb7ffc RDI: ffff8801cccb8000 RBP: ffff8801cc046e48 R08: ffff8801ccc244be R09: ffffed0039984899 R10: 0000000000000001 R11: ffffed0039984898 R12: ffff8801ccc244c4 R13: ffff8801ccc244c0 R14: ffff8801d96b7c06 R15: ffff8801d96b7b40 FS: 00007febd562d700(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffff8801cccb8000 CR3: 00000001ccb2f006 CR4: 00000000001606e0 DR0: 0000000020000000 DR1: 0000000020000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600 Call Trace: memmove include/linux/string.h:360 [inline] skb_reorder_vlan_header net/core/skbuff.c:5031 [inline] skb_vlan_untag+0x470/0xc40 net/core/skbuff.c:5061 __netif_receive_skb_core+0x119c/0x3460 net/core/dev.c:4460 __netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4627 netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4701 netif_receive_skb+0xae/0x390 net/core/dev.c:4725 tun_rx_batched.isra.50+0x5ee/0x870 drivers/net/tun.c:1555 tun_get_user+0x299e/0x3c20 drivers/net/tun.c:1962 tun_chr_write_iter+0xb9/0x160 drivers/net/tun.c:1990 call_write_iter include/linux/fs.h:1782 [inline] new_sync_write fs/read_write.c:469 [inline] __vfs_write+0x684/0x970 fs/read_write.c:482 vfs_write+0x189/0x510 fs/read_write.c:544 SYSC_write fs/read_write.c:589 [inline] SyS_write+0xef/0x220 fs/read_write.c:581 do_syscall_64+0x281/0x940 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x42/0xb7 RIP: 0033:0x454879 RSP: 002b:00007febd562cc68 EFLAGS: 00000246 ORIG_RAX: 0000000000000001 RAX: ffffffffffffffda RBX: 00007febd562d6d4 RCX: 0000000000454879 RDX: 0000000000000157 RSI: 0000000020000180 RDI: 0000000000000014 RBP: 000000000072bea0 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff R13: 00000000000006b0 R14: 00000000006fc120 R15: 0000000000000000 Code: 90 90 90 90 90 90 90 48 89 f8 48 83 fa 20 0f 82 03 01 00 00 48 39 fe 7d 0f 49 89 f0 49 01 d0 49 39 f8 0f 8f 9f 00 00 00 48 89 d1 <f3> a4 c3 48 81 fa a8 02 00 00 72 05 40 38 fe 74 3b 48 83 ea 20 RIP: __memmove+0x24/0x1a0 arch/x86/lib/memmove_64.S:43 RSP: ffff8801cc046e28 CR2: ffff8801cccb8000 ==== We don't need to copy headers for packets which do not have preceding headers of vlan headers, so skip memmove() in that case. Fixes: 4bbb3e0e8239 ("net: Fix vlan untag for bridge and vlan_dev with reorder_hdr off") Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30llc: properly handle dev_queue_xmit() return valueCong Wang
[ Upstream commit b85ab56c3f81c5a24b5a5213374f549df06430da ] llc_conn_send_pdu() pushes the skb into write queue and calls llc_conn_send_pdus() to flush them out. However, the status of dev_queue_xmit() is not returned to caller, in this case, llc_conn_state_process(). llc_conn_state_process() needs hold the skb no matter success or failure, because it still uses it after that, therefore we should hold skb before dev_queue_xmit() when that skb is the one being processed by llc_conn_state_process(). For other callers, they can just pass NULL and ignore the return value as they are. Reported-by: Noam Rathaus <noamr@beyondsecurity.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: fix packet loss for broadcasted DHCP packets to a serverLinus Lüssing
[ Upstream commit a752c0a4524889cdc0765925258fd1fd72344100 ] DHCP connectivity issues can currently occur if the following conditions are met: 1) A DHCP packet from a client to a server 2) This packet has a multicast destination 3) This destination has a matching entry in the translation table (FF:FF:FF:FF:FF:FF for IPv4, 33:33:00:01:00:02/33:33:00:01:00:03 for IPv6) 4) The orig-node determined by TT for the multicast destination does not match the orig-node determined by best-gateway-selection In this case the DHCP packet will be dropped. The "gateway-out-of-range" check is supposed to only be applied to unicasted DHCP packets to a specific DHCP server. In that case dropping the the unicasted frame forces the client to retry via a broadcasted one, but now directed to the new best gateway. A DHCP packet with broadcast/multicast destination is already ensured to always be delivered to the best gateway. Dropping a multicasted DHCP packet here will only prevent completing DHCP as there is no other fallback. So far, it seems the unicast check was implicitly performed by expecting the batadv_transtable_search() to return NULL for multicast destinations. However, a multicast address could have always ended up in the translation table and in fact is now common. To fix this potential loss of a DHCP client-to-server packet to a multicast address this patch adds an explicit multicast destination check to reliably bail out of the gateway-out-of-range check for such destinations. The issue and fix were tested in the following three node setup: - Line topology, A-B-C - A: gateway client, DHCP client - B: gateway server, hop-penalty increased: 30->60, DHCP server - C: gateway server, code modifications to announce FF:FF:FF:FF:FF:FF Without this patch, A would never transmit its DHCP Discover packet due to an always "out-of-range" condition. With this patch, a full DHCP handshake between A and B was possible again. Fixes: be7af5cf9cae ("batman-adv: refactoring gateway handling code") Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: fix multicast-via-unicast transmission with AP isolationLinus Lüssing
[ Upstream commit f8fb3419ead44f9a3136995acd24e35da4525177 ] For multicast frames AP isolation is only supposed to be checked on the receiving nodes and never on the originating one. Furthermore, the isolation or wifi flag bits should only be intepreted as such for unicast and never multicast TT entries. By injecting flags to the multicast TT entry claimed by a single target node it was verified in tests that this multicast address becomes unreachable, leading to packet loss. Omitting the "src" parameter to the batadv_transtable_search() call successfully skipped the AP isolation check and made the target reachable again. Fixes: 1d8ab8d3c176 ("batman-adv: Modified forwarding behaviour for multicast packets") Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30vti4: Don't override MTU passed on link creation via IFLA_MTUStefano Brivio
[ Upstream commit 03080e5ec72740c1a62e6730f2a5f3f114f11b19 ] Don't hardcode a MTU value on vti tunnel initialization, ip_tunnel_newlink() is able to deal with this already. See also commit ffc2b6ee4174 ("ip_gre: fix IFLA_MTU ignored on NEWLINK"). Fixes: 1181412c1a67 ("net/ipv4: VTI support new module for ip_vti.") Signed-off-by: Stefano Brivio <sbrivio@redhat.com> Acked-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30vti4: Don't count header length twice on tunnel setupStefano Brivio
[ Upstream commit dd1df24737727e119c263acf1be2a92763938297 ] This re-introduces the effect of commit a32452366b72 ("vti4: Don't count header length twice.") which was accidentally reverted by merge commit f895f0cfbb77 ("Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec"). The commit message from Steffen Klassert said: We currently count the size of LL_MAX_HEADER and struct iphdr twice for vti4 devices, this leads to a wrong device mtu. The size of LL_MAX_HEADER and struct iphdr is already counted in ip_tunnel_bind_dev(), so don't do it again in vti_tunnel_init(). And this is still the case now: ip_tunnel_bind_dev() already accounts for the header length of the link layer (not necessarily LL_MAX_HEADER, if the output device is found), plus one IP header. For example, with a vti device on top of veth, with MTU of 1500, the existing implementation would set the initial vti MTU to 1332, accounting once for LL_MAX_HEADER (128, included in hard_header_len by vti) and twice for the same IP header (once from hard_header_len, once from ip_tunnel_bind_dev()). It should instead be 1480, because ip_tunnel_bind_dev() is able to figure out that the output device is veth, so no additional link layer header is attached, and will properly count one single IP header. The existing issue had the side effect of avoiding PMTUD for most xfrm policies, by arbitrarily lowering the initial MTU. However, the only way to get a consistent PMTU value is to let the xfrm PMTU discovery do its course, and commit d6af1a31cc72 ("vti: Add pmtu handling to vti_xmit.") now takes care of local delivery cases where the application ignores local socket notifications. Fixes: b9959fd3b0fa ("vti: switch to new ip tunnel code") Fixes: f895f0cfbb77 ("Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec") Signed-off-by: Stefano Brivio <sbrivio@redhat.com> Acked-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: Fix skbuff rcsum on packet rerouteSven Eckelmann
[ Upstream commit fc04fdb2c8a894283259f5621d31d75610701091 ] batadv_check_unicast_ttvn may redirect a packet to itself or another originator. This involves rewriting the ttvn and the destination address in the batadv unicast header. These field were not yet pulled (with skb rcsum update) and thus any change to them also requires a change in the receive checksum. Reported-by: Matthias Schiffer <mschiffer@universe-factory.net> Fixes: a73105b8d4c7 ("batman-adv: improved client announcement mechanism") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: fix header size check in batadv_dbg_arp()Matthias Schiffer
[ Upstream commit 6f27d2c2a8c236d296201c19abb8533ec20d212b ] Checking for 0 is insufficient: when an SKB without a batadv header, but with a VLAN header is received, hdr_size will be 4, making the following code interpret the Ethernet header as a batadv header. Fixes: be1db4f6615b ("batman-adv: make the Distributed ARP Table vlan aware") Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30net: Fix vlan untag for bridge and vlan_dev with reorder_hdr offToshiaki Makita
[ Upstream commit 4bbb3e0e8239f9079bf1fe20b3c0cb598714ae61 ] When we have a bridge with vlan_filtering on and a vlan device on top of it, packets would be corrupted in skb_vlan_untag() called from br_dev_xmit(). The problem sits in skb_reorder_vlan_header() used in skb_vlan_untag(), which makes use of skb->mac_len. In this function mac_len is meant for handling rx path with vlan devices with reorder_header disabled, but in tx path mac_len is typically 0 and cannot be used, which is the problem in this case. The current code even does not properly handle rx path (skb_vlan_untag() called from __netif_receive_skb_core()) with reorder_header off actually. In rx path single tag case, it works as follows: - Before skb_reorder_vlan_header() mac_header data v v +-------------------+-------------+------+---- | ETH | VLAN | ETH | | ADDRS | TPID | TCI | TYPE | +-------------------+-------------+------+---- <-------- mac_len ---------> <-------------> to be removed - After skb_reorder_vlan_header() mac_header data v v +-------------------+------+---- | ETH | ETH | | ADDRS | TYPE | +-------------------+------+---- <-------- mac_len ---------> This is ok, but in rx double tag case, it corrupts packets: - Before skb_reorder_vlan_header() mac_header data v v +-------------------+-------------+-------------+------+---- | ETH | VLAN | VLAN | ETH | | ADDRS | TPID | TCI | TPID | TCI | TYPE | +-------------------+-------------+-------------+------+---- <--------------- mac_len ----------------> <-------------> should be removed <---------------------------> actually will be removed - After skb_reorder_vlan_header() mac_header data v v +-------------------+------+---- | ETH | ETH | | ADDRS | TYPE | +-------------------+------+---- <--------------- mac_len ----------------> So, two of vlan tags are both removed while only inner one should be removed and mac_header (and mac_len) is broken. skb_vlan_untag() is meant for removing the vlan header at (skb->data - 2), so use skb->data and skb->mac_header to calculate the right offset. Reported-by: Brandon Carpenter <brandon.carpenter@cypherpath.com> Fixes: a6e18ff11170 ("vlan: Fix untag operations of stacked vlans with REORDER_HEADER off") Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30ipv4: lock mtu in fnhe when received PMTU < net.ipv4.route.min_pmtuSabrina Dubroca
[ Upstream commit d52e5a7e7ca49457dd31fc8b42fb7c0d58a31221 ] Prior to the rework of PMTU information storage in commit 2c8cec5c10bc ("ipv4: Cache learned PMTU information in inetpeer."), when a PMTU event advertising a PMTU smaller than net.ipv4.route.min_pmtu was received, we would disable setting the DF flag on packets by locking the MTU metric, and set the PMTU to net.ipv4.route.min_pmtu. Since then, we don't disable DF, and set PMTU to net.ipv4.route.min_pmtu, so the intermediate router that has this link with a small MTU will have to drop the packets. This patch reestablishes pre-2.6.39 behavior by splitting rtable->rt_pmtu into a bitfield with rt_mtu_locked and rt_pmtu. rt_mtu_locked indicates that we shouldn't set the DF bit on that path, and is checked in ip_dont_fragment(). One possible workaround is to set net.ipv4.route.min_pmtu to a value low enough to accommodate the lowest MTU encountered. Fixes: 2c8cec5c10bc ("ipv4: Cache learned PMTU information in inetpeer.") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Reviewed-by: Stefano Brivio <sbrivio@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30netfilter: ebtables: fix erroneous reject of last ruleFlorian Westphal
[ Upstream commit 932909d9b28d27e807ff8eecb68c7748f6701628 ] The last rule in the blob has next_entry offset that is same as total size. This made "ebtables32 -A OUTPUT -d de:ad:be:ef:01:02" fail on 64 bit kernel. Fixes: b71812168571fa ("netfilter: ebtables: CONFIG_COMPAT: don't trust userland offsets") Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: Fix multicast packet loss with a single WANT_ALL_IPV4/6 flagLinus Lüssing
[ Upstream commit 74c12c630fe310eb7fcae1b292257d47781fff0a ] As the kernel doc describes too the code is supposed to skip adding multicast TT entries if both the WANT_ALL_IPV4 and WANT_ALL_IPV6 flags are present. Unfortunately, the current code even skips adding multicast TT entries if only either the WANT_ALL_IPV4 or WANT_ALL_IPV6 is present. This could lead to IPv6 multicast packet loss if only an IGMP but not an MLD querier is present for instance or vice versa. Fixes: 687937ab3489 ("batman-adv: Add multicast optimization support for bridged setups") Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30net/tcp/illinois: replace broken algorithm reference linkJoey Pabalinas
[ Upstream commit ecc832758a654e375924ebf06a4ac971acb5ce60 ] The link to the pdf containing the algorithm description is now a dead link; it seems http://www.ifp.illinois.edu/~srikant/ has been moved to https://sites.google.com/a/illinois.edu/srikant/ and none of the original papers can be found there... I have replaced it with the only working copy I was able to find. n.b. there is also a copy available at: http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.296.6350&rep=rep1&type=pdf However, this seems to only be a *cached* version, so I am unsure exactly how reliable that link can be expected to remain over time and have decided against using that one. Signed-off-by: Joey Pabalinas <joeypabalinas@gmail.com> net/ipv4/tcp_illinois.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30sit: fix IFLA_MTU ignored on NEWLINKXin Long
[ Upstream commit 2b3957c34b6d7f03544b12ebbf875eee430745db ] Commit 128bb975dc3c ("ip6_gre: init dev->mtu and dev->hard_header_len correctly") fixed IFLA_MTU ignored on NEWLINK for ip6_gre. The same mtu fix is also needed for sit. Note that dev->hard_header_len setting for sit works fine, no need to fix it. sit is actually ipv4 tunnel, it can't call ip6_tnl_change_mtu to set mtu. Reported-by: Jianlin Shi <jishi@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30ip6_tunnel: fix IFLA_MTU ignored on NEWLINKXin Long
[ Upstream commit a6aa80446234ec0ad38eecdb8efc59e91daae565 ] Commit 128bb975dc3c ("ip6_gre: init dev->mtu and dev->hard_header_len correctly") fixed IFLA_MTU ignored on NEWLINK for ip6_gre. The same mtu fix is also needed for ip6_tunnel. Note that dev->hard_header_len setting for ip6_tunnel works fine, no need to fix it. Reported-by: Jianlin Shi <jishi@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30qrtr: add MODULE_ALIAS macro to smdRamon Fried
[ Upstream commit c77f5fbbefc04612755117775e8555c2a7006cac ] Added MODULE_ALIAS("rpmsg:IPCRTR") to ensure qrtr-smd and qrtr will load when IPCRTR channel is detected. Signed-off-by: Ramon Fried <rfried@codeaurora.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: Fix netlink dumping of BLA backbonesSven Eckelmann
[ Upstream commit fce672db548ff19e76a08a32a829544617229bc2 ] The function batadv_bla_backbone_dump_bucket must be able to handle non-complete dumps of a single bucket. It tries to do that by saving the latest dumped index in *idx_skip to inform the caller about the current state. But the caller only assumes that buckets were not completely dumped when the return code is non-zero. This function must therefore also return a non-zero index when the dumping of an entry failed. Otherwise the caller will just skip all remaining buckets. And the function must also reset *idx_skip back to zero when it finished a bucket. Otherwise it will skip the same number of entries in the next bucket as the previous one had. Fixes: ea4152e11716 ("batman-adv: add backbone table netlink support") Reported-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: Fix netlink dumping of BLA claimsSven Eckelmann
[ Upstream commit b0264ecdfeab5f889b02ec54af7ca8cc1c245e2f ] The function batadv_bla_claim_dump_bucket must be able to handle non-complete dumps of a single bucket. It tries to do that by saving the latest dumped index in *idx_skip to inform the caller about the current state. But the caller only assumes that buckets were not completely dumped when the return code is non-zero. This function must therefore also return a non-zero index when the dumping of an entry failed. Otherwise the caller will just skip all remaining buckets. And the function must also reset *idx_skip back to zero when it finished a bucket. Otherwise it will skip the same number of entries in the next bucket as the previous one had. Fixes: 04f3f5bf1883 ("batman-adv: add B.A.T.M.A.N. Dump BLA claims via netlink") Reported-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: Ignore invalid batadv_v_gw during netlink sendSven Eckelmann
[ Upstream commit 011c935fceae5252619ef730baa610c655281dda ] The function batadv_v_gw_dump stops the processing loop when batadv_v_gw_dump_entry returns a non-0 return code. This should only happen when the buffer is full. Otherwise, an empty message may be returned by batadv_gw_dump. This empty message will then stop the netlink dumping of gateway entries. At worst, not a single entry is returned to userspace even when plenty of possible gateways exist. Fixes: b71bb6f924fe ("batman-adv: add B.A.T.M.A.N. V bat_gw_dump implementations") Signed-off-by: Sven Eckelmann <sven.eckelmann@openmesh.com> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: Ignore invalid batadv_iv_gw during netlink sendSven Eckelmann
[ Upstream commit 10d570284258a30dc104c50787c5289ec49f3d23 ] The function batadv_iv_gw_dump stops the processing loop when batadv_iv_gw_dump_entry returns a non-0 return code. This should only happen when the buffer is full. Otherwise, an empty message may be returned by batadv_gw_dump. This empty message will then stop the netlink dumping of gateway entries. At worst, not a single entry is returned to userspace even when plenty of possible gateways exist. Fixes: efb766af06e3 ("batman-adv: add B.A.T.M.A.N. IV bat_gw_dump implementations") Signed-off-by: Sven Eckelmann <sven.eckelmann@openmesh.com> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30netfilter: ebtables: convert BUG_ONs to WARN_ONsFlorian Westphal
[ Upstream commit fc6a5d0601c5ac1d02f283a46f60b87b2033e5ca ] All of these conditions are not fatal and should have been WARN_ONs from the get-go. Convert them to WARN_ONs and bail out. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: invalidate checksum on fragment reassemblyMatthias Schiffer
[ Upstream commit 3bf2a09da956b43ecfaa630a2ef9a477f991a46a ] A more sophisticated implementation could try to combine fragment checksums when all fragments have CHECKSUM_COMPLETE and are split at even offsets. For now, we just set ip_summed to CHECKSUM_NONE to avoid "hw csum failure" warnings in the kernel log when fragmented frames are received. In consequence, skb_pull_rcsum() can be replaced with skb_pull(). Note that in usual setups, packets don't reach batman-adv with CHECKSUM_COMPLETE (I assume NICs bail out of checksumming when they see batadv's ethtype?), which is why the log messages do not occur on every system using batman-adv. I could reproduce this issue by stacking batman-adv on top of a VXLAN interface. Fixes: 610bfc6bc99b ("batman-adv: Receive fragmented packets and merge") Tested-by: Maximilian Wilhelm <max@sdn.clinic> Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30batman-adv: fix packet checksum in receive pathMatthias Schiffer
[ Upstream commit abd6360591d3f8259f41c34e31ac4826dfe621b8 ] eth_type_trans() internally calls skb_pull(), which does not adjust the skb checksum; skb_postpull_rcsum() is necessary to avoid log spam of the form "bat0: hw csum failure" when packets with CHECKSUM_COMPLETE are received. Note that in usual setups, packets don't reach batman-adv with CHECKSUM_COMPLETE (I assume NICs bail out of checksumming when they see batadv's ethtype?), which is why the log messages do not occur on every system using batman-adv. I could reproduce this issue by stacking batman-adv on top of a VXLAN interface. Fixes: c6c8fea29769 ("net: Add batman-adv meshing protocol") Tested-by: Maximilian Wilhelm <max@sdn.clinic> Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mac80211: drop frames with unexpected DS bits from fast-rx to slow pathFelix Fietkau
[ Upstream commit b323ac19b7734a1c464b2785a082ee50bccd3b91 ] Fixes rx for 4-addr packets in AP mode. These may be used for setting up a 4-addr link for stations that are allowed to do so. Signed-off-by: Felix Fietkau <nbd@nbd.name> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mac80211: Do not disconnect on invalid operating classIlan Peer
[ Upstream commit 191da271ac260700db3e5b4bb982a17ca78769d6 ] Some APs include a non global operating class in their extended channel switch information element. In such a case, as the operating class is not known, mac80211 would decide to disconnect. However the specification states that the operating class needs to be taken from Annex E, but it does not specify from which table it should be taken, so it is valid for an AP to use a non global operating class. To avoid possibly unneeded disconnection, in such a case ignore the operating class and assume that the current band is used, and if the resulting channel and band configuration is invalid disconnect. Signed-off-by: Ilan Peer <ilan.peer@intel.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mac80211: fix calling sleeping function in atomic contextSara Sharon
[ Upstream commit 95f3ce6a77893ac828ba841df44421620de4314b ] sta_info_alloc can be called from atomic paths (such as RX path) so we need to call pcpu_alloc with the correct gfp. Fixes: c9c5962b56c1 ("mac80211: enable collecting station statistics per-CPU") Signed-off-by: Sara Sharon <sara.sharon@intel.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mac80211: fix a possible leak of station statsSara Sharon
[ Upstream commit d78d9ee9d40aca4781d2c5334972544601a4c3a2 ] If sta_info_alloc fails after allocating the per CPU statistics, they are not properly freed. Fixes: c9c5962b56c1 ("mac80211: enable collecting station statistics per-CPU") Signed-off-by: Sara Sharon <sara.sharon@intel.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30rxrpc: Work around usercopy checkDavid Howells
[ Upstream commit a16b8d0cf2ec1e626d24bc2a7b9e64ace6f7501d ] Due to a check recently added to copy_to_user(), it's now not permitted to copy from slab-held data to userspace unless the slab is whitelisted. This affects rxrpc_recvmsg() when it attempts to place an RXRPC_USER_CALL_ID control message in the userspace control message buffer. A warning is generated by usercopy_warn() because the source is the copy of the user_call_ID retained in the rxrpc_call struct. Work around the issue by copying the user_call_ID to a variable on the stack and passing that to put_cmsg(). The warning generated looks like: Bad or missing usercopy whitelist? Kernel memory exposure attempt detected from SLUB object 'dmaengine-unmap-128' (offset 680, size 8)! WARNING: CPU: 0 PID: 1401 at mm/usercopy.c:81 usercopy_warn+0x7e/0xa0 ... RIP: 0010:usercopy_warn+0x7e/0xa0 ... Call Trace: __check_object_size+0x9c/0x1a0 put_cmsg+0x98/0x120 rxrpc_recvmsg+0x6fc/0x1010 [rxrpc] ? finish_wait+0x80/0x80 ___sys_recvmsg+0xf8/0x240 ? __clear_rsb+0x25/0x3d ? __clear_rsb+0x15/0x3d ? __clear_rsb+0x25/0x3d ? __clear_rsb+0x15/0x3d ? __clear_rsb+0x25/0x3d ? __clear_rsb+0x15/0x3d ? __clear_rsb+0x25/0x3d ? __clear_rsb+0x15/0x3d ? finish_task_switch+0xa6/0x2b0 ? trace_hardirqs_on_caller+0xed/0x180 ? _raw_spin_unlock_irq+0x29/0x40 ? __sys_recvmsg+0x4e/0x90 __sys_recvmsg+0x4e/0x90 do_syscall_64+0x7a/0x220 entry_SYSCALL_64_after_hwframe+0x26/0x9b Reported-by: Jonathan Billings <jsbillings@jsbillings.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Kees Cook <keescook@chromium.org> Tested-by: Jonathan Billings <jsbillings@jsbillings.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30NFC: llcp: Limit size of SDP URIKees Cook
[ Upstream commit fe9c842695e26d8116b61b80bfb905356f07834b ] The tlv_len is u8, so we need to limit the size of the SDP URI. Enforce this both in the NLA policy and in the code that performs the allocation and copy, to avoid writing past the end of the allocated buffer. Fixes: d9b8d8e19b073 ("NFC: llcp: Service Name Lookup netlink interface") Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30RDS: IB: Fix null pointer issueGuanglei Li
[ Upstream commit 2c0aa08631b86a4678dbc93b9caa5248014b4458 ] Scenario: 1. Port down and do fail over 2. Ap do rds_bind syscall PID: 47039 TASK: ffff89887e2fe640 CPU: 47 COMMAND: "kworker/u:6" #0 [ffff898e35f159f0] machine_kexec at ffffffff8103abf9 #1 [ffff898e35f15a60] crash_kexec at ffffffff810b96e3 #2 [ffff898e35f15b30] oops_end at ffffffff8150f518 #3 [ffff898e35f15b60] no_context at ffffffff8104854c #4 [ffff898e35f15ba0] __bad_area_nosemaphore at ffffffff81048675 #5 [ffff898e35f15bf0] bad_area_nosemaphore at ffffffff810487d3 #6 [ffff898e35f15c00] do_page_fault at ffffffff815120b8 #7 [ffff898e35f15d10] page_fault at ffffffff8150ea95 [exception RIP: unknown or invalid address] RIP: 0000000000000000 RSP: ffff898e35f15dc8 RFLAGS: 00010282 RAX: 00000000fffffffe RBX: ffff889b77f6fc00 RCX:ffffffff81c99d88 RDX: 0000000000000000 RSI: ffff896019ee08e8 RDI:ffff889b77f6fc00 RBP: ffff898e35f15df0 R8: ffff896019ee08c8 R9:0000000000000000 R10: 0000000000000400 R11: 0000000000000000 R12:ffff896019ee08c0 R13: ffff889b77f6fe68 R14: ffffffff81c99d80 R15: ffffffffa022a1e0 ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018 #8 [ffff898e35f15dc8] cma_ndev_work_handler at ffffffffa022a228 [rdma_cm] #9 [ffff898e35f15df8] process_one_work at ffffffff8108a7c6 #10 [ffff898e35f15e58] worker_thread at ffffffff8108bda0 #11 [ffff898e35f15ee8] kthread at ffffffff81090fe6 PID: 45659 TASK: ffff880d313d2500 CPU: 31 COMMAND: "oracle_45659_ap" #0 [ffff881024ccfc98] __schedule at ffffffff8150bac4 #1 [ffff881024ccfd40] schedule at ffffffff8150c2cf #2 [ffff881024ccfd50] __mutex_lock_slowpath at ffffffff8150cee7 #3 [ffff881024ccfdc0] mutex_lock at ffffffff8150cdeb #4 [ffff881024ccfde0] rdma_destroy_id at ffffffffa022a027 [rdma_cm] #5 [ffff881024ccfe10] rds_ib_laddr_check at ffffffffa0357857 [rds_rdma] #6 [ffff881024ccfe50] rds_trans_get_preferred at ffffffffa0324c2a [rds] #7 [ffff881024ccfe80] rds_bind at ffffffffa031d690 [rds] #8 [ffff881024ccfeb0] sys_bind at ffffffff8142a670 PID: 45659 PID: 47039 rds_ib_laddr_check /* create id_priv with a null event_handler */ rdma_create_id rdma_bind_addr cma_acquire_dev /* add id_priv to cma_dev->id_list */ cma_attach_to_dev cma_ndev_work_handler /* event_hanlder is null */ id_priv->id.event_handler Signed-off-by: Guanglei Li <guanglei.li@oracle.com> Signed-off-by: Honglei Wang <honglei.wang@oracle.com> Reviewed-by: Junxiao Bi <junxiao.bi@oracle.com> Reviewed-by: Yanjun Zhu <yanjun.zhu@oracle.com> Reviewed-by: Leon Romanovsky <leonro@mellanox.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Acked-by: Doug Ledford <dledford@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30netfilter: ipv6: nf_defrag: Kill frag queue on RFC2460 failureSubash Abhinov Kasiviswanathan
[ Upstream commit ea23d5e3bf340e413b8e05c13da233c99c64142b ] Failures were seen in ICMPv6 fragmentation timeout tests if they were run after the RFC2460 failure tests. Kernel was not sending out the ICMPv6 fragment reassembly time exceeded packet after the fragmentation reassembly timeout of 1 minute had elapsed. This happened because the frag queue was not released if an error in IPv6 fragmentation header was detected by RFC2460. Fixes: 83f1999caeb1 ("netfilter: ipv6: nf_defrag: Pass on packets to stack per RFC2460") Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30openvswitch: Remove padding from packet before L3+ conntrack processingEd Swierk
[ Upstream commit 9382fe71c0058465e942a633869629929102843d ] IPv4 and IPv6 packets may arrive with lower-layer padding that is not included in the L3 length. For example, a short IPv4 packet may have up to 6 bytes of padding following the IP payload when received on an Ethernet device with a minimum packet length of 64 bytes. Higher-layer processing functions in netfilter (e.g. nf_ip_checksum(), and help() in nf_conntrack_ftp) assume skb->len reflects the length of the L3 header and payload, rather than referring back to ip_hdr->tot_len or ipv6_hdr->payload_len, and get confused by lower-layer padding. In the normal IPv4 receive path, ip_rcv() trims the packet to ip_hdr->tot_len before invoking netfilter hooks. In the IPv6 receive path, ip6_rcv() does the same using ipv6_hdr->payload_len. Similarly in the br_netfilter receive path, br_validate_ipv4() and br_validate_ipv6() trim the packet to the L3 length before invoking netfilter hooks. Currently in the OVS conntrack receive path, ovs_ct_execute() pulls the skb to the L3 header but does not trim it to the L3 length before calling nf_conntrack_in(NF_INET_PRE_ROUTING). When nf_conntrack_proto_tcp encounters a packet with lower-layer padding, nf_ip_checksum() fails causing a "nf_ct_tcp: bad TCP checksum" log message. While extra zero bytes don't affect the checksum, the length in the IP pseudoheader does. That length is based on skb->len, and without trimming, it doesn't match the length the sender used when computing the checksum. In ovs_ct_execute(), trim the skb to the L3 length before higher-layer processing. Signed-off-by: Ed Swierk <eswierk@skyportsystems.com> Acked-by: Pravin B Shelar <pshelar@ovn.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30tcp_nv: fix potential integer overflow in tcpnv_ackedGustavo A. R. Silva
[ Upstream commit e4823fbd229bfbba368b40cdadb8f4eeb20604cc ] Add suffix ULL to constant 80000 in order to avoid a potential integer overflow and give the compiler complete information about the proper arithmetic to use. Notice that this constant is used in a context that expects an expression of type u64. The current cast to u64 effectively applies to the whole expression as an argument of type u64 to be passed to div64_u64, but it does not prevent it from being evaluated using 32-bit arithmetic instead of 64-bit arithmetic. Also, once the expression is properly evaluated using 64-bit arithmentic, there is no need for the parentheses and the external cast to u64. Addresses-Coverity-ID: 1357588 ("Unintentional integer overflow") Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30netfilter: ipv6: nf_defrag: Pass on packets to stack per RFC2460Subash Abhinov Kasiviswanathan
[ Upstream commit 83f1999caeb14e15df205e80d210699951733287 ] ipv6_defrag pulls network headers before fragment header. In case of an error, the netfilter layer is currently dropping these packets. This results in failure of some IPv6 standards tests which passed on older kernels due to the netfilter framework using cloning. The test case run here is a check for ICMPv6 error message replies when some invalid IPv6 fragments are sent. This specific test case is listed in https://www.ipv6ready.org/docs/Core_Conformance_Latest.pdf in the Extension Header Processing Order section. A packet with unrecognized option Type 11 is sent and the test expects an ICMP error in line with RFC2460 section 4.2 - 11 - discard the packet and, only if the packet's Destination Address was not a multicast address, send an ICMP Parameter Problem, Code 2, message to the packet's Source Address, pointing to the unrecognized Option Type. Since netfilter layer now drops all invalid IPv6 frag packets, we no longer see the ICMP error message and fail the test case. To fix this, save the transport header. If defrag is unable to process the packet due to RFC2460, restore the transport header and allow packet to be processed by stack. There is no change for other packet processing paths. Tested by confirming that stack sends an ICMP error when it receives these packets. Also tested that fragmented ICMP pings succeed. v1->v2: Instead of cloning always, save the transport_header and restore it in case of this specific error. Update the title and commit message accordingly. Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-25cfg80211: limit wiphy names to 128 bytesJohannes Berg
commit a7cfebcb7594a24609268f91299ab85ba064bf82 upstream. There's currently no limit on wiphy names, other than netlink message size and memory limitations, but that causes issues when, for example, the wiphy name is used in a uevent, e.g. in rfkill where we use the same name for the rfkill instance, and then the buffer there is "only" 2k for the environment variables. This was reported by syzkaller, which used a 4k name. Limit the name to something reasonable, I randomly picked 128. Reported-by: syzbot+230d9e642a85d3fec29c@syzkaller.appspotmail.com Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-25tcp: purge write queue in tcp_connect_init()Eric Dumazet
[ Upstream commit 7f582b248d0a86bae5788c548d7bb5bca6f7691a ] syzkaller found a reliable way to crash the host, hitting a BUG() in __tcp_retransmit_skb() Malicous MSG_FASTOPEN is the root cause. We need to purge write queue in tcp_connect_init() at the point we init snd_una/write_seq. This patch also replaces the BUG() by a less intrusive WARN_ON_ONCE() kernel BUG at net/ipv4/tcp_output.c:2837! invalid opcode: 0000 [#1] SMP KASAN Dumping ftrace buffer: (ftrace buffer empty) Modules linked in: CPU: 0 PID: 5276 Comm: syz-executor0 Not tainted 4.17.0-rc3+ #51 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 RIP: 0010:__tcp_retransmit_skb+0x2992/0x2eb0 net/ipv4/tcp_output.c:2837 RSP: 0000:ffff8801dae06ff8 EFLAGS: 00010206 RAX: ffff8801b9fe61c0 RBX: 00000000ffc18a16 RCX: ffffffff864e1a49 RDX: 0000000000000100 RSI: ffffffff864e2e12 RDI: 0000000000000005 RBP: ffff8801dae073a0 R08: ffff8801b9fe61c0 R09: ffffed0039c40dd2 R10: ffffed0039c40dd2 R11: ffff8801ce206e93 R12: 00000000421eeaad R13: ffff8801ce206d4e R14: ffff8801ce206cc0 R15: ffff8801cd4f4a80 FS: 0000000000000000(0000) GS:ffff8801dae00000(0063) knlGS:00000000096bc900 CS: 0010 DS: 002b ES: 002b CR0: 0000000080050033 CR2: 0000000020000000 CR3: 00000001c47b6000 CR4: 00000000001406f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Call Trace: <IRQ> tcp_retransmit_skb+0x2e/0x250 net/ipv4/tcp_output.c:2923 tcp_retransmit_timer+0xc50/0x3060 net/ipv4/tcp_timer.c:488 tcp_write_timer_handler+0x339/0x960 net/ipv4/tcp_timer.c:573 tcp_write_timer+0x111/0x1d0 net/ipv4/tcp_timer.c:593 call_timer_fn+0x230/0x940 kernel/time/timer.c:1326 expire_timers kernel/time/timer.c:1363 [inline] __run_timers+0x79e/0xc50 kernel/time/timer.c:1666 run_timer_softirq+0x4c/0x70 kernel/time/timer.c:1692 __do_softirq+0x2e0/0xaf5 kernel/softirq.c:285 invoke_softirq kernel/softirq.c:365 [inline] irq_exit+0x1d1/0x200 kernel/softirq.c:405 exiting_irq arch/x86/include/asm/apic.h:525 [inline] smp_apic_timer_interrupt+0x17e/0x710 arch/x86/kernel/apic/apic.c:1052 apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:863 Fixes: cf60af03ca4e ("net-tcp: Fast Open client - sendmsg(MSG_FASTOPEN)") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-25sock_diag: fix use-after-free read in __sk_freeEric Dumazet
[ Upstream commit 9709020c86f6bf8439ca3effc58cfca49a5de192 ] We must not call sock_diag_has_destroy_listeners(sk) on a socket that has no reference on net structure. BUG: KASAN: use-after-free in sock_diag_has_destroy_listeners include/linux/sock_diag.h:75 [inline] BUG: KASAN: use-after-free in __sk_free+0x329/0x340 net/core/sock.c:1609 Read of size 8 at addr ffff88018a02e3a0 by task swapper/1/0 CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.17.0-rc5+ #54 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: <IRQ> __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x1b9/0x294 lib/dump_stack.c:113 print_address_description+0x6c/0x20b mm/kasan/report.c:256 kasan_report_error mm/kasan/report.c:354 [inline] kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412 __asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433 sock_diag_has_destroy_listeners include/linux/sock_diag.h:75 [inline] __sk_free+0x329/0x340 net/core/sock.c:1609 sk_free+0x42/0x50 net/core/sock.c:1623 sock_put include/net/sock.h:1664 [inline] reqsk_free include/net/request_sock.h:116 [inline] reqsk_put include/net/request_sock.h:124 [inline] inet_csk_reqsk_queue_drop_and_put net/ipv4/inet_connection_sock.c:672 [inline] reqsk_timer_handler+0xe27/0x10e0 net/ipv4/inet_connection_sock.c:739 call_timer_fn+0x230/0x940 kernel/time/timer.c:1326 expire_timers kernel/time/timer.c:1363 [inline] __run_timers+0x79e/0xc50 kernel/time/timer.c:1666 run_timer_softirq+0x4c/0x70 kernel/time/timer.c:1692 __do_softirq+0x2e0/0xaf5 kernel/softirq.c:285 invoke_softirq kernel/softirq.c:365 [inline] irq_exit+0x1d1/0x200 kernel/softirq.c:405 exiting_irq arch/x86/include/asm/apic.h:525 [inline] smp_apic_timer_interrupt+0x17e/0x710 arch/x86/kernel/apic/apic.c:1052 apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:863 </IRQ> RIP: 0010:native_safe_halt+0x6/0x10 arch/x86/include/asm/irqflags.h:54 RSP: 0018:ffff8801d9ae7c38 EFLAGS: 00000282 ORIG_RAX: ffffffffffffff13 RAX: dffffc0000000000 RBX: 1ffff1003b35cf8a RCX: 0000000000000000 RDX: 1ffffffff11a30d0 RSI: 0000000000000001 RDI: ffffffff88d18680 RBP: ffff8801d9ae7c38 R08: ffffed003b5e46c3 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001 R13: ffff8801d9ae7cf0 R14: ffffffff897bef20 R15: 0000000000000000 arch_safe_halt arch/x86/include/asm/paravirt.h:94 [inline] default_idle+0xc2/0x440 arch/x86/kernel/process.c:354 arch_cpu_idle+0x10/0x20 arch/x86/kernel/process.c:345 default_idle_call+0x6d/0x90 kernel/sched/idle.c:93 cpuidle_idle_call kernel/sched/idle.c:153 [inline] do_idle+0x395/0x560 kernel/sched/idle.c:262 cpu_startup_entry+0x104/0x120 kernel/sched/idle.c:368 start_secondary+0x426/0x5b0 arch/x86/kernel/smpboot.c:269 secondary_startup_64+0xa5/0xb0 arch/x86/kernel/head_64.S:242 Allocated by task 4557: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] kasan_kmalloc+0xc4/0xe0 mm/kasan/kasan.c:553 kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490 kmem_cache_alloc+0x12e/0x760 mm/slab.c:3554 kmem_cache_zalloc include/linux/slab.h:691 [inline] net_alloc net/core/net_namespace.c:383 [inline] copy_net_ns+0x159/0x4c0 net/core/net_namespace.c:423 create_new_namespaces+0x69d/0x8f0 kernel/nsproxy.c:107 unshare_nsproxy_namespaces+0xc3/0x1f0 kernel/nsproxy.c:206 ksys_unshare+0x708/0xf90 kernel/fork.c:2408 __do_sys_unshare kernel/fork.c:2476 [inline] __se_sys_unshare kernel/fork.c:2474 [inline] __x64_sys_unshare+0x31/0x40 kernel/fork.c:2474 do_syscall_64+0x1b1/0x800 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x49/0xbe Freed by task 69: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] __kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:521 kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528 __cache_free mm/slab.c:3498 [inline] kmem_cache_free+0x86/0x2d0 mm/slab.c:3756 net_free net/core/net_namespace.c:399 [inline] net_drop_ns.part.14+0x11a/0x130 net/core/net_namespace.c:406 net_drop_ns net/core/net_namespace.c:405 [inline] cleanup_net+0x6a1/0xb20 net/core/net_namespace.c:541 process_one_work+0xc1e/0x1b50 kernel/workqueue.c:2145 worker_thread+0x1cc/0x1440 kernel/workqueue.c:2279 kthread+0x345/0x410 kernel/kthread.c:240 ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412 The buggy address belongs to the object at ffff88018a02c140 which belongs to the cache net_namespace of size 8832 The buggy address is located 8800 bytes inside of 8832-byte region [ffff88018a02c140, ffff88018a02e3c0) The buggy address belongs to the page: page:ffffea0006280b00 count:1 mapcount:0 mapping:ffff88018a02c140 index:0x0 compound_mapcount: 0 flags: 0x2fffc0000008100(slab|head) raw: 02fffc0000008100 ffff88018a02c140 0000000000000000 0000000100000001 raw: ffffea00062a1320 ffffea0006268020 ffff8801d9bdde40 0000000000000000 page dumped because: kasan: bad access detected Fixes: b922622ec6ef ("sock_diag: don't broadcast kernel sockets") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Craig Gallek <kraig@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-25packet: in packet_snd start writing at link layer allocationWillem de Bruijn
[ Upstream commit b84bbaf7a6c8cca24f8acf25a2c8e46913a947ba ] Packet sockets allow construction of packets shorter than dev->hard_header_len to accommodate protocols with variable length link layer headers. These packets are padded to dev->hard_header_len, because some device drivers interpret that as a minimum packet size. packet_snd reserves dev->hard_header_len bytes on allocation. SOCK_DGRAM sockets call skb_push in dev_hard_header() to ensure that link layer headers are stored in the reserved range. SOCK_RAW sockets do the same in tpacket_snd, but not in packet_snd. Syzbot was able to send a zero byte packet to a device with massive 116B link layer header, causing padding to cross over into skb_shinfo. Fix this by writing from the start of the llheader reserved range also in the case of packet_snd/SOCK_RAW. Update skb_set_network_header to the new offset. This also corrects it for SOCK_DGRAM, where it incorrectly double counted reserve due to the skb_push in dev_hard_header. Fixes: 9ed988cd5915 ("packet: validate variable length ll headers") Reported-by: syzbot+71d74a5406d02057d559@syzkaller.appspotmail.com Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-25net: test tailroom before appending to linear skbWillem de Bruijn
[ Upstream commit 113f99c3358564a0647d444c2ae34e8b1abfd5b9 ] Device features may change during transmission. In particular with corking, a device may toggle scatter-gather in between allocating and writing to an skb. Do not unconditionally assume that !NETIF_F_SG at write time implies that the same held at alloc time and thus the skb has sufficient tailroom. This issue predates git history. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Reported-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Willem de Bruijn <willemb@google.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22netfilter: nf_tables: can't fail after linking rule into active rule listFlorian Westphal
commit 569ccae68b38654f04b6842b034aa33857f605fe upstream. rules in nftables a free'd using kfree, but protected by rcu, i.e. we must wait for a grace period to elapse. Normal removal patch does this, but nf_tables_newrule() doesn't obey this rule during error handling. It calls nft_trans_rule_add() *after* linking rule, and, if that fails to allocate memory, it unlinks the rule and then kfree() it -- this is unsafe. Switch order -- first add rule to transaction list, THEN link it to public list. Note: nft_trans_rule_add() uses GFP_KERNEL; it will not fail so this is not a problem in practice (spotted only during code review). Fixes: 0628b123c96d12 ("netfilter: nfnetlink: add batch support and use it from nf_tables") Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19l2tp: revert "l2tp: fix missing print session offset info"James Chapman
commit de3b58bc359a861d5132300f53f95e83f71954b3 upstream. Revert commit 820da5357572 ("l2tp: fix missing print session offset info"). The peer_offset parameter is removed. Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19xfrm: fix xfrm_do_migrate() with AEAD e.g(AES-GCM)Antony Antony
commit 75bf50f4aaa1c78d769d854ab3d975884909e4fb upstream. copy geniv when cloning the xfrm state. x->geniv was not copied to the new state and migration would fail. xfrm_do_migrate .. xfrm_state_clone() .. .. esp_init_aead() crypto_alloc_aead() crypto_alloc_tfm() crypto_find_alg() return EAGAIN and failed Signed-off-by: Antony Antony <antony@phenome.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19sctp: delay the authentication for the duplicated cookie-echo chunkXin Long
[ Upstream commit 59d8d4434f429b4fa8a346fd889058bda427a837 ] Now sctp only delays the authentication for the normal cookie-echo chunk by setting chunk->auth_chunk in sctp_endpoint_bh_rcv(). But for the duplicated one with auth, in sctp_assoc_bh_rcv(), it does authentication first based on the old asoc, which will definitely fail due to the different auth info in the old asoc. The duplicated cookie-echo chunk will create a new asoc with the auth info from this chunk, and the authentication should also be done with the new asoc's auth info for all of the collision 'A', 'B' and 'D'. Otherwise, the duplicated cookie-echo chunk with auth will never pass the authentication and create the new connection. This issue exists since very beginning, and this fix is to make sctp_assoc_bh_rcv() follow the way sctp_endpoint_bh_rcv() does for the normal cookie-echo chunk to delay the authentication. While at it, remove the unused params from sctp_sf_authenticate() and define sctp_auth_chunk_verify() used for all the places that do the delayed authentication. v1->v2: fix the typo in changelog as Marcelo noticed. Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19sctp: fix the issue that the cookie-ack with auth can't get processedXin Long
[ Upstream commit ce402f044e4e432c296f90eaabb8dbe8f3624391 ] When auth is enabled for cookie-ack chunk, in sctp_inq_pop, sctp processes auth chunk first, then continues to the next chunk in this packet if chunk_end + chunk_hdr size < skb_tail_pointer(). Otherwise, it will go to the next packet or discard this chunk. However, it missed the fact that cookie-ack chunk's size is equal to chunk_hdr size, which couldn't match that check, and thus this chunk would not get processed. This patch fixes it by changing the check to chunk_end + chunk_hdr size <= skb_tail_pointer(). Fixes: 26b87c788100 ("net: sctp: fix remote memory pressure from excessive queueing") Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19tcp: ignore Fast Open on repair modeYuchung Cheng
[ Upstream commit 16ae6aa1705299789f71fdea59bfb119c1fbd9c0 ] The TCP repair sequence of operation is to first set the socket in repair mode, then inject the TCP stats into the socket with repair socket options, then call connect() to re-activate the socket. The connect syscall simply returns and set state to ESTABLISHED mode. As a result Fast Open is meaningless for TCP repair. However allowing sendto() system call with MSG_FASTOPEN flag half-way during the repair operation could unexpectedly cause data to be sent, before the operation finishes changing the internal TCP stats (e.g. MSS). This in turn triggers TCP warnings on inconsistent packet accounting. The fix is to simply disallow Fast Open operation once the socket is in the repair mode. Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Reviewed-by: Neal Cardwell <ncardwell@google.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19tcp_bbr: fix to zero idle_restart only upon S/ACKed dataNeal Cardwell
[ Upstream commit e6e6a278b1eaffa19d42186bfacd1ffc15a50b3f ] Previously the bbr->idle_restart tracking was zeroing out the bbr->idle_restart bit upon ACKs that did not SACK or ACK anything, e.g. receiving incoming data or receiver window updates. In such situations BBR would forget that this was a restart-from-idle situation, and if the min_rtt had expired it would unnecessarily enter PROBE_RTT (even though we were actually restarting from idle but had merely forgotten that fact). The fix is simple: we need to remember we are restarting from idle until we receive a S/ACK for some data (a S/ACK for the first flight of data we send as we are restarting). This commit is a stable candidate for kernels back as far as 4.9. Fixes: 0f8782ea1497 ("tcp_bbr: add BBR congestion control") Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com> Signed-off-by: Priyaranjan Jha <priyarjha@google.com> Signed-off-by: Yousuk Seung <ysseung@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19sctp: use the old asoc when making the cookie-ack chunk in dupcook_dXin Long
[ Upstream commit 46e16d4b956867013e0bbd7f2bad206f4aa55752 ] When processing a duplicate cookie-echo chunk, for case 'D', sctp will not process the param from this chunk. It means old asoc has nothing to be updated, and the new temp asoc doesn't have the complete info. So there's no reason to use the new asoc when creating the cookie-ack chunk. Otherwise, like when auth is enabled for cookie-ack, the chunk can not be set with auth, and it will definitely be dropped by peer. This issue is there since very beginning, and we fix it by using the old asoc instead. Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
