path: root/net
2014-11-14mac80211: fix typo in starting baserate for rts_cts_rate_idxKarl Beldan
commit c7abf25af0f41be4b50d44c5b185d52eea360cb8 upstream. It affects non-(V)HT rates and can lead to selecting an rts_cts rate that is not a basic rate or way superior to the reference rate (ATM rates[0] used for the 1st attempt of the protected frame data). E.g, assuming drivers register growing (bitrate) sorted tables of ieee80211_rate-s, having : - rates[0].idx == d'2 and basic_rates == b'10100 will select rts_cts idx b'10011 & ~d'(BIT(2)-1), i.e. 1, likewise - rates[0].idx == d'2 and basic_rates == b'10001 will select rts_cts idx b'10000 The first is not a basic rate and the second is > rates[0]. Also, wrt severity of the addressed misbehavior, ATM we only have one rts_cts_rate_idx rather than one per rate table entry, so this idx might still point to bitrates > rates[1..MAX_RATES]. Fixes: 5253ffb8c9e1 ("mac80211: always pick a basic rate to tx RTS/CTS for pre-HT rates") Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14libceph: ceph-msgr workqueue needs a resque workerIlya Dryomov
commit f9865f06f7f18c6661c88d0511f05c48612319cc upstream. Commit f363e45fd118 ("net/ceph: make ceph_msgr_wq non-reentrant") effectively removed WQ_MEM_RECLAIM flag from ceph_msgr_wq. This is wrong - libceph is very much a memory reclaim path, so restore it. Signed-off-by: Ilya Dryomov <idryomov@redhat.com> Tested-by: Micha Krause <micha@krausam.de> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14fix misuses of f_count() in ppp and netlinkAl Viro
commit 24dff96a37a2ca319e75a74d3929b2de22447ca6 upstream. we used to check for "nobody else could start doing anything with that opened file" by checking that refcount was 2 or less - one for descriptor table and one we'd acquired in fget() on the way to wherever we are. That was race-prone (somebody else might have had a reference to descriptor table and do fget() just as we'd been checking) and it had become flat-out incorrect back when we switched to fget_light() on those codepaths - unlike fget(), it doesn't grab an extra reference unless the descriptor table is shared. The same change allowed a race-free check, though - we are safe exactly when refcount is less than 2. It was a long time ago; pre-2.6.12 for ioctl() (the codepath leading to ppp one) and 2.6.17 for sendmsg() (netlink one). OTOH, netlink hadn't grown that check until 3.9 and ppp used to live in drivers/net, not drivers/net/ppp until 3.1. The bug existed well before that, though, and the same fix used to apply in old location of file. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14SUNRPC: Add missing support for RPC_CLNT_CREATE_NO_RETRANS_TIMEOUTTrond Myklebust
commit 2aca5b869ace67a63aab895659e5dc14c33a4d6e upstream. The flag RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT was intended introduced in order to allow NFSv4 clients to disable resend timeouts. Since those cause the RPC layer to break the connection, they mess up the duplicate reply caches that remain indexed on the port number in NFSv4.. This patch includes the code that was missing in the original to set the appropriate flag in struct rpc_clnt, when the caller of rpc_create() sets RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT. Fixes: 8a19a0b6cb2e (SUNRPC: Add RPC task and client level options to...) Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14SUNRPC: Don't wake tasks during connection abortBenjamin Coddington
commit a743419f420a64d442280845c0377a915b76644f upstream. When aborting a connection to preserve source ports, don't wake the task in xs_error_report. This allows tasks with RPC_TASK_SOFTCONN to succeed if the connection needs to be re-established since it preserves the task's status instead of setting it to the status of the aborting kernel_connect(). This may also avoid a potential conflict on the socket's lock. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14drivers/net, ipv6: Select IPv6 fragment idents for virtio UFO packetsBen Hutchings
[ Upstream commit 5188cd44c55db3e92cd9e77a40b5baa7ed4340f7 ] UFO is now disabled on all drivers that work with virtio net headers, but userland may try to send UFO/IPv6 packets anyway. Instead of sending with ID=0, we should select identifiers on their behalf (as we used to). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Fixes: 916e4cf46d02 ("ipv6: reuse ip6_frag_id from ip6_ufo_append_data") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14ipv4: dst_entry leak in ip_send_unicast_reply()Vasily Averin
[ Upstream commit 4062090e3e5caaf55bed4523a69f26c3265cc1d2 ] ip_setup_cork() called inside ip_append_data() steals dst entry from rt to cork and in case errors in __ip_append_data() nobody frees stolen dst entry Fixes: 2e77d89b2fa8 ("net: avoid a pair of dst_hold()/dst_release() in ip_append_data()") Signed-off-by: Vasily Averin <vvs@parallels.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14gre: Use inner mac length when computing tunnel lengthTom Herbert
[ Upstream commit 14051f0452a2c26a3f4791e6ad6a435e8f1945ff ] Currently, skb_inner_network_header is used but this does not account for Ethernet header for ETH_P_TEB. Use skb_inner_mac_header which handles TEB and also should work with IP encapsulation in which case inner mac and inner network headers are the same. Tested: Ran TCP_STREAM over GRE, worked as expected. Signed-off-by: Tom Herbert <therbert@google.com> Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14tcp: md5: do not use alloc_percpu()Eric Dumazet
[ Upstream commit 349ce993ac706869d553a1816426d3a4bfda02b1 ] percpu tcp_md5sig_pool contains memory blobs that ultimately go through sg_set_buf(). -> sg_set_page(sg, virt_to_page(buf), buflen, offset_in_page(buf)); This requires that whole area is in a physically contiguous portion of memory. And that @buf is not backed by vmalloc(). Given that alloc_percpu() can use vmalloc() areas, this does not fit the requirements. Replace alloc_percpu() by a static DEFINE_PER_CPU() as tcp_md5sig_pool is small anyway, there is no gain to dynamically allocate it. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 765cf9976e93 ("tcp: md5: remove one indirection level in tcp_md5sig_pool") Reported-by: Crestez Dan Leonard <cdleonard@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14ipv4: fix a potential use after free in ip_tunnel_core.cLi RongQing
[ Upstream commit 1245dfc8cadb258386fcd27df38215a0eccb1f17 ] pskb_may_pull() maybe change skb->data and make eth pointer oboslete, so set eth after pskb_may_pull() Fixes:3d7b46cd("ip_tunnel: push generic protocol handling to ip_tunnel module") Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14ipv4: fix nexthop attlen check in fib_nh_matchJiri Pirko
[ Upstream commit f76936d07c4eeb36d8dbb64ebd30ab46ff85d9f7 ] fib_nh_match does not match nexthops correctly. Example: ip route add 172.16.10/24 nexthop via 192.168.122.12 dev eth0 \ nexthop via 192.168.122.13 dev eth0 ip route del 172.16.10/24 nexthop via 192.168.122.14 dev eth0 \ nexthop via 192.168.122.15 dev eth0 Del command is successful and route is removed. After this patch applied, the route is correctly matched and result is: RTNETLINK answers: No such process Please consider this for stable trees as well. Fixes: 4e902c57417c4 ("[IPv4]: FIB configuration using struct fib_config") Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30Bluetooth: Fix incorrect LE CoC PDU length restriction based on HCI MTUJohan Hedberg
commit 72c6fb915ff2d30ae14053edee4f0d30019bad76 upstream. The l2cap_create_le_flowctl_pdu() function that l2cap_segment_le_sdu() calls is perfectly capable of doing packet fragmentation if given bigger PDUs than the HCI buffers allow. Forcing the PDU length based on the HCI MTU (conn->mtu) would therefore needlessly strict operation on hardware with limited LE buffers (e.g. both Intel and Broadcom seem to have this set to just 27 bytes). This patch removes the restriction and makes it possible to send PDUs of the full length that the remote MPS value allows. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15tcp: fixing TLP's FIN recoveryPer Hurtig
[ Upstream commit bef1909ee3ed1ca39231b260a8d3b4544ecd0c8f ] Fix to a problem observed when losing a FIN segment that does not contain data. In such situations, TLP is unable to recover from *any* tail loss and instead adds at least PTO ms to the retransmission process, i.e., RTO = RTO + PTO. Signed-off-by: Per Hurtig <per.hurtig@kau.se> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Nandita Dukkipati <nanditad@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15sctp: handle association restarts when the socket is closed.Vlad Yasevich
[ Upstream commit bdf6fa52f01b941d4a80372d56de465bdbbd1d23 ] Currently association restarts do not take into consideration the state of the socket. When a restart happens, the current assocation simply transitions into established state. This creates a condition where a remote system, through a the restart procedure, may create a local association that is no way reachable by user. The conditions to trigger this are as follows: 1) Remote does not acknoledge some data causing data to remain outstanding. 2) Local application calls close() on the socket. Since data is still outstanding, the association is placed in SHUTDOWN_PENDING state. However, the socket is closed. 3) The remote tries to create a new association, triggering a restart on the local system. The association moves from SHUTDOWN_PENDING to ESTABLISHED. At this point, it is no longer reachable by any socket on the local system. This patch addresses the above situation by moving the newly ESTABLISHED association into SHUTDOWN-SENT state and bundling a SHUTDOWN after the COOKIE-ACK chunk. This way, the restarted associate immidiately enters the shutdown procedure and forces the termination of the unreachable association. Reported-by: David Laight <David.Laight@aculab.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15ip6_gre: fix flowi6_proto value in xmit pathNicolas Dichtel
[ Upstream commit 3be07244b7337760a3269d56b2f4a63e72218648 ] In xmit path, we build a flowi6 which will be used for the output route lookup. We are sending a GRE packet, neither IPv4 nor IPv6 encapsulated packet, thus the protocol should be IPPROTO_GRE. Fixes: c12b395a4664 ("gre: Support GRE over IPv6") Reported-by: Matthieu Ternisien d'Ouville <matthieu.tdo@6wind.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15gro: fix aggregation for skb using frag_listEric Dumazet
[ Upstream commit 73d3fe6d1c6d840763ceafa9afae0aaafa18c4b5 ] In commit 8a29111c7ca6 ("net: gro: allow to build full sized skb") I added a regression for linear skb that traditionally force GRO to use the frag_list fallback. Erez Shitrit found that at most two segments were aggregated and the "if (skb_gro_len(p) != pinfo->gso_size)" test was failing. This is because pinfo at this spot still points to the last skb in the chain, instead of the first one, where we find the correct gso_size information. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 8a29111c7ca6 ("net: gro: allow to build full sized skb") Reported-by: Erez Shitrit <erezsh@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15xfrm: Generate queueing routes only from route lookup functionsSteffen Klassert
[ Upstream commit b8c203b2d2fc961bafd53b41d5396bbcdec55998 ] Currently we genarate a queueing route if we have matching policies but can not resolve the states and the sysctl xfrm_larval_drop is disabled. Here we assume that dst_output() is called to kill the queued packets. Unfortunately this assumption is not true in all cases, so it is possible that these packets leave the system unwanted. We fix this by generating queueing routes only from the route lookup functions, here we can guarantee a call to dst_output() afterwards. Fixes: a0073fe18e71 ("xfrm: Add a state resolution packet queue") Reported-by: Konstantinos Kolelis <k.kolelis@sirrix.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15xfrm: Generate blackhole routes only from route lookup functionsSteffen Klassert
[ Upstream commit f92ee61982d6da15a9e49664ecd6405a15a2ee56 ] Currently we genarate a blackhole route route whenever we have matching policies but can not resolve the states. Here we assume that dst_output() is called to kill the balckholed packets. Unfortunately this assumption is not true in all cases, so it is possible that these packets leave the system unwanted. We fix this by generating blackhole routes only from the route lookup functions, here we can guarantee a call to dst_output() afterwards. Fixes: 2774c131b1d ("xfrm: Handle blackhole route creation via afinfo.") Reported-by: Konstantinos Kolelis <k.kolelis@sirrix.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15bridge: Fix br_should_learn to check vlan_enabledVlad Yasevich
[ Upstream commit c095f248e63ada504dd90c90baae673ae10ee3fe ] As Toshiaki Makita pointed out, the BRIDGE_INPUT_SKB_CB will not be initialized in br_should_learn() as that function is called only from br_handle_local_finish(). That is an input handler for link-local ethernet traffic so it perfectly correct to check br->vlan_enabled here. Reported-by: Toshiaki Makita<toshiaki.makita1@gmail.com> Fixes: 20adfa1 bridge: Check if vlan filtering is enabled only once. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15bridge: Check if vlan filtering is enabled only once.Vlad Yasevich
[ Upstream commit 20adfa1a81af00bf2027644507ad4fa9cd2849cf ] The bridge code checks if vlan filtering is enabled on both ingress and egress. When the state flip happens, it is possible for the bridge to currently be forwarding packets and forwarding behavior becomes non-deterministic. Bridge may drop packets on some interfaces, but not others. This patch solves this by caching the filtered state of the packet into skb_cb on ingress. The skb_cb is guaranteed to not be over-written between the time packet entres bridge forwarding path and the time it leaves it. On egress, we can then check the cached state to see if we need to apply filtering information. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15ipv6: restore the behavior of ipv6_sock_ac_drop()WANG Cong
[ Upstream commit de185ab46cb02df9738b0d898b0c3a89181c5526 ] It is possible that the interface is already gone after joining the list of anycast on this interface as we don't hold a refcount for the device, in this case we are safe to ignore the error. What's more important, for API compatibility we should not change this behavior for applications even if it were correct. Fixes: commit a9ed4a2986e13011 ("ipv6: fix rtnl locking in setsockopt for anycast and multicast") Cc: Sabrina Dubroca <sd@queasysnail.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15ipv6: fix rtnl locking in setsockopt for anycast and multicastSabrina Dubroca
[ Upstream commit a9ed4a2986e13011fcf4ed2d1a1647c53112f55b ] Calling setsockopt with IPV6_JOIN_ANYCAST or IPV6_LEAVE_ANYCAST triggers the assertion in addrconf_join_solict()/addrconf_leave_solict() ipv6_sock_ac_join(), ipv6_sock_ac_drop(), ipv6_sock_ac_close() need to take RTNL before calling ipv6_dev_ac_inc/dec. Same thing with ipv6_sock_mc_join(), ipv6_sock_mc_drop(), ipv6_sock_mc_close() before calling ipv6_dev_mc_inc/dec. This patch moves ASSERT_RTNL() up a level in the call stack. Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Reported-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15l2tp: fix race while getting PMTU on PPP pseudo-wireGuillaume Nault
[ Upstream commit eed4d839b0cdf9d84b0a9bc63de90fd5e1e886fb ] Use dst_entry held by sk_dst_get() to retrieve tunnel's PMTU. The dst_mtu(__sk_dst_get(tunnel->sock)) call was racy. __sk_dst_get() could return NULL if tunnel->sock->sk_dst_cache was reset just before the call, thus making dst_mtu() dereference a NULL pointer: [ 1937.661598] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 [ 1937.664005] IP: [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] PGD daf0c067 PUD d9f93067 PMD 0 [ 1937.664005] Oops: 0000 [#1] SMP [ 1937.664005] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6table_filter ip6_tables iptable_filter ip_tables ebtable_nat ebtables x_tables udp_tunnel pppoe pppox ppp_generic slhc deflate ctr twofish_generic twofish_x86_64_3way xts lrw gf128mul glue_helper twofish_x86_64 twofish_common blowfish_generic blowfish_x86_64 blowfish_common des_generic cbc xcbc rmd160 sha512_generic hmac crypto_null af_key xfrm_algo 8021q garp bridge stp llc tun atmtcp clip atm ext3 mbcache jbd iTCO_wdt coretemp kvm_intel iTCO_vendor_support kvm pcspkr evdev ehci_pci lpc_ich mfd_core i5400_edac edac_core i5k_amb shpchp button processor thermal_sys xfs crc32c_generic libcrc32c dm_mod usbhid sg hid sr_mod sd_mod cdrom crc_t10dif crct10dif_common ata_generic ahci ata_piix tg3 libahci libata uhci_hcd ptp ehci_hcd pps_core usbcore scsi_mod libphy usb_common [last unloaded: l2tp_core] [ 1937.664005] CPU: 0 PID: 10022 Comm: l2tpstress Tainted: G O 3.17.0-rc1 #1 [ 1937.664005] Hardware name: HP ProLiant DL160 G5, BIOS O12 08/22/2008 [ 1937.664005] task: ffff8800d8fda790 ti: ffff8800c43c4000 task.ti: ffff8800c43c4000 [ 1937.664005] RIP: 0010:[<ffffffffa049db88>] [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] RSP: 0018:ffff8800c43c7de8 EFLAGS: 00010282 [ 1937.664005] RAX: ffff8800da8a7240 RBX: ffff8800d8c64600 RCX: 000001c325a137b5 [ 1937.664005] RDX: 8c6318c6318c6320 RSI: 000000000000010c RDI: 0000000000000000 [ 1937.664005] RBP: ffff8800c43c7ea8 R08: 0000000000000000 R09: 0000000000000000 [ 1937.664005] R10: ffffffffa048e2c0 R11: ffff8800d8c64600 R12: ffff8800ca7a5000 [ 1937.664005] R13: ffff8800c439bf40 R14: 000000000000000c R15: 0000000000000009 [ 1937.664005] FS: 00007fd7f610f700(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000 [ 1937.664005] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1937.664005] CR2: 0000000000000020 CR3: 00000000d9d75000 CR4: 00000000000027e0 [ 1937.664005] Stack: [ 1937.664005] ffffffffa049da80 ffff8800d8fda790 000000000000005b ffff880000000009 [ 1937.664005] ffff8800daf3f200 0000000000000003 ffff8800c43c7e48 ffffffff81109b57 [ 1937.664005] ffffffff81109b0e ffffffff8114c566 0000000000000000 0000000000000000 [ 1937.664005] Call Trace: [ 1937.664005] [<ffffffffa049da80>] ? pppol2tp_connect+0x235/0x41e [l2tp_ppp] [ 1937.664005] [<ffffffff81109b57>] ? might_fault+0x9e/0xa5 [ 1937.664005] [<ffffffff81109b0e>] ? might_fault+0x55/0xa5 [ 1937.664005] [<ffffffff8114c566>] ? rcu_read_unlock+0x1c/0x26 [ 1937.664005] [<ffffffff81309196>] SYSC_connect+0x87/0xb1 [ 1937.664005] [<ffffffff813e56f7>] ? sysret_check+0x1b/0x56 [ 1937.664005] [<ffffffff8107590d>] ? trace_hardirqs_on_caller+0x145/0x1a1 [ 1937.664005] [<ffffffff81213dee>] ? trace_hardirqs_on_thunk+0x3a/0x3f [ 1937.664005] [<ffffffff8114c262>] ? spin_lock+0x9/0xb [ 1937.664005] [<ffffffff813092b4>] SyS_connect+0x9/0xb [ 1937.664005] [<ffffffff813e56d2>] system_call_fastpath+0x16/0x1b [ 1937.664005] Code: 10 2a 84 81 e8 65 76 bd e0 65 ff 0c 25 10 bb 00 00 4d 85 ed 74 37 48 8b 85 60 ff ff ff 48 8b 80 88 01 00 00 48 8b b8 10 02 00 00 <48> 8b 47 20 ff 50 20 85 c0 74 0f 83 e8 28 89 83 10 01 00 00 89 [ 1937.664005] RIP [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] RSP <ffff8800c43c7de8> [ 1937.664005] CR2: 0000000000000020 [ 1939.559375] ---[ end trace 82d44500f28f8708 ]--- Fixes: f34c4a35d879 ("l2tp: take PMTU from tunnel UDP socket") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15openvswitch: fix panic with multiple vlan headersJiri Benc
[ Upstream commit 2ba5af42a7b59ef01f9081234d8855140738defd ] When there are multiple vlan headers present in a received frame, the first one is put into vlan_tci and protocol is set to ETH_P_8021Q. Anything in the skb beyond the VLAN TPID may be still non-linear, including the inner TCI and ethertype. While ovs_flow_extract takes care of IP and IPv6 headers, it does nothing with ETH_P_8021Q. Later, if OVS_ACTION_ATTR_POP_VLAN is executed, __pop_vlan_tci pulls the next vlan header into vlan_tci. This leads to two things: 1. Part of the resulting ethernet header is in the non-linear part of the skb. When eth_type_trans is called later as the result of OVS_ACTION_ATTR_OUTPUT, kernel BUGs in __skb_pull. Also, __pop_vlan_tci is in fact accessing random data when it reads past the TPID. 2. network_header points into the ethernet header instead of behind it. mac_len is set to a wrong value (10), too. Reported-by: Yulong Pei <ypei@redhat.com> Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15packet: handle too big packets for PACKET_V3Eric Dumazet
[ Upstream commit dc808110bb62b64a448696ecac3938902c92e1ab ] af_packet can currently overwrite kernel memory by out of bound accesses, because it assumed a [new] block can always hold one frame. This is not generally the case, even if most existing tools do it right. This patch clamps too long frames as API permits, and issue a one time error on syslog. [ 394.357639] tpacket_rcv: packet too big, clamped from 5042 to 3966. macoff=82 In this example, packet header tp_snaplen was set to 3966, and tp_len was set to 5042 (skb->len) Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.") Acked-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15tcp: fix ssthresh and undo for consecutive short FRTO episodesNeal Cardwell
[ Upstream commit 0c9ab09223fe9922baeb22546c9a90d774a4bde6 ] Fix TCP FRTO logic so that it always notices when snd_una advances, indicating that any RTO after that point will be a new and distinct loss episode. Previously there was a very specific sequence that could cause FRTO to fail to notice a new loss episode had started: (1) RTO timer fires, enter FRTO and retransmit packet 1 in write queue (2) receiver ACKs packet 1 (3) FRTO sends 2 more packets (4) RTO timer fires again (should start a new loss episode) The problem was in step (3) above, where tcp_process_loss() returned early (in the spot marked "Step 2.b"), so that it never got to the logic to clear icsk_retransmits. Thus icsk_retransmits stayed non-zero. Thus in step (4) tcp_enter_loss() would see the non-zero icsk_retransmits, decide that this RTO is not a new episode, and decide not to cut ssthresh and remember the current cwnd and ssthresh for undo. There were two main consequences to the bug that we have observed. First, ssthresh was not decreased in step (4). Second, when there was a series of such FRTO (1-4) sequences that happened to be followed by an FRTO undo, we would restore the cwnd and ssthresh from before the entire series started (instead of the cwnd and ssthresh from before the most recent RTO). This could result in cwnd and ssthresh being restored to values much bigger than the proper values. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Fixes: e33099f96d99c ("tcp: implement RFC5682 F-RTO") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15tcp: fix tcp_release_cb() to dispatch via address family for mtu_reduced()Neal Cardwell
[ Upstream commit 4fab9071950c2021d846e18351e0f46a1cffd67b ] Make sure we use the correct address-family-specific function for handling MTU reductions from within tcp_release_cb(). Previously AF_INET6 sockets were incorrectly always using the IPv6 code path when sometimes they were handling IPv4 traffic and thus had an IPv4 dst. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Diagnosed-by: Willem de Bruijn <willemb@google.com> Fixes: 563d34d057862 ("tcp: dont drop MTU reduction indications") Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15sit: Fix ipip6_tunnel_lookup device matching criteriaShmulik Ladkani
[ Upstream commit bc8fc7b8f825ef17a0fb9e68c18ce94fa66ab337 ] As of 4fddbf5d78 ("sit: strictly restrict incoming traffic to tunnel link device"), when looking up a tunnel, tunnel's underlying interface (t->parms.link) is verified to match incoming traffic's ingress device. However the comparison was incorrectly based on skb->dev->iflink. Instead, dev->ifindex should be used, which correctly represents the interface from which the IP stack hands the ipip6 packets. This allows setting up sit tunnels bound to vlan interfaces (otherwise incoming ipip6 traffic on the vlan interface was dropped due to ipip6_tunnel_lookup match failure). Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15tcp: don't use timestamp from repaired skb-s to calculate RTT (v2)Andrey Vagin
[ Upstream commit 9d186cac7ffb1831e9f34cb4a3a8b22abb9dd9d4 ] We don't know right timestamp for repaired skb-s. Wrong RTT estimations isn't good, because some congestion modules heavily depends on it. This patch adds the TCPCB_REPAIRED flag, which is included in TCPCB_RETRANS. Thanks to Eric for the advice how to fix this issue. This patch fixes the warning: [ 879.562947] WARNING: CPU: 0 PID: 2825 at net/ipv4/tcp_input.c:3078 tcp_ack+0x11f5/0x1380() [ 879.567253] CPU: 0 PID: 2825 Comm: socket-tcpbuf-l Not tainted 3.16.0-next-20140811 #1 [ 879.567829] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 879.568177] 0000000000000000 00000000c532680c ffff880039643d00 ffffffff817aa2d2 [ 879.568776] 0000000000000000 ffff880039643d38 ffffffff8109afbd ffff880039d6ba80 [ 879.569386] ffff88003a449800 000000002983d6bd 0000000000000000 000000002983d6bc [ 879.569982] Call Trace: [ 879.570264] [<ffffffff817aa2d2>] dump_stack+0x4d/0x66 [ 879.570599] [<ffffffff8109afbd>] warn_slowpath_common+0x7d/0xa0 [ 879.570935] [<ffffffff8109b0ea>] warn_slowpath_null+0x1a/0x20 [ 879.571292] [<ffffffff816d0a05>] tcp_ack+0x11f5/0x1380 [ 879.571614] [<ffffffff816d10bd>] tcp_rcv_established+0x1ed/0x710 [ 879.571958] [<ffffffff816dc9da>] tcp_v4_do_rcv+0x10a/0x370 [ 879.572315] [<ffffffff81657459>] release_sock+0x89/0x1d0 [ 879.572642] [<ffffffff816c81a0>] do_tcp_setsockopt.isra.36+0x120/0x860 [ 879.573000] [<ffffffff8110a52e>] ? rcu_read_lock_held+0x6e/0x80 [ 879.573352] [<ffffffff816c8912>] tcp_setsockopt+0x32/0x40 [ 879.573678] [<ffffffff81654ac4>] sock_common_setsockopt+0x14/0x20 [ 879.574031] [<ffffffff816537b0>] SyS_setsockopt+0x80/0xf0 [ 879.574393] [<ffffffff817b40a9>] system_call_fastpath+0x16/0x1b [ 879.574730] ---[ end trace a17cbc38eb8c5c00 ]--- v2: moving setting of skb->when for repaired skb-s in tcp_write_xmit, where it's set for other skb-s. Fixes: 431a91242d8d ("tcp: timestamp SYN+DATA messages") Fixes: 740b0f1841f6 ("tcp: switch rtt estimations to usec resolution") Cc: Eric Dumazet <edumazet@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15net: Always untag vlan-tagged traffic on input.Vlad Yasevich
[ Upstream commit 0d5501c1c828fb97d02af50aa9d2b1a5498b94e4 ] Currently the functionality to untag traffic on input resides as part of the vlan module and is build only when VLAN support is enabled in the kernel. When VLAN is disabled, the function vlan_untag() turns into a stub and doesn't really untag the packets. This seems to create an interesting interaction between VMs supporting checksum offloading and some network drivers. There are some drivers that do not allow the user to change tx-vlan-offload feature of the driver. These drivers also seem to assume that any VLAN-tagged traffic they transmit will have the vlan information in the vlan_tci and not in the vlan header already in the skb. When transmitting skbs that already have tagged data with partial checksum set, the checksum doesn't appear to be updated correctly by the card thus resulting in a failure to establish TCP connections. The following is a packet trace taken on the receiver where a sender is a VM with a VLAN configued. The host VM is running on doest not have VLAN support and the outging interface on the host is tg3: 10:12:43.503055 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q (0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27243, offset 0, flags [DF], proto TCP (6), length 60) 10.0.100.1.58545 > 10.0.100.10.ircu-2: Flags [S], cksum 0xdc39 (incorrect -> 0x48d9), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val 4294837885 ecr 0,nop,wscale 7], length 0 10:12:44.505556 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q (0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27244, offset 0, flags [DF], proto TCP (6), length 60) 10.0.100.1.58545 > 10.0.100.10.ircu-2: Flags [S], cksum 0xdc39 (incorrect -> 0x44ee), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val 4294838888 ecr 0,nop,wscale 7], length 0 This connection finally times out. I've only access to the TG3 hardware in this configuration thus have only tested this with TG3 driver. There are a lot of other drivers that do not permit user changes to vlan acceleration features, and I don't know if they all suffere from a similar issue. The patch attempt to fix this another way. It moves the vlan header stipping code out of the vlan module and always builds it into the kernel network core. This way, even if vlan is not supported on a virtualizatoin host, the virtual machines running on top of such host will still work with VLANs enabled. CC: Patrick McHardy <kaber@trash.net> CC: Nithin Nayak Sujir <nsujir@broadcom.com> CC: Michael Chan <mchan@broadcom.com> CC: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15rtnetlink: fix VF info sizeJiri Benc
[ Upstream commit 945a36761fd7877660f630bbdeb4ff9ff80d1935 ] Commit 1d8faf48c74b8 ("net/core: Add VF link state control") added new attribute to IFLA_VF_INFO group in rtnl_fill_ifinfo but did not adjust size of the allocated memory in if_nlmsg_size/rtnl_vfinfo_size. As the result, we may trigger warnings in rtnl_getlink and similar functions when many VF links are enabled, as the information does not fit into the allocated skb. Fixes: 1d8faf48c74b8 ("net/core: Add VF link state control") Reported-by: Yulong Pei <ypei@redhat.com> Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15netlink: reset network header before passing to tapsDaniel Borkmann
[ Upstream commit 4e48ed883c72e78c5a910f8831ffe90c9b18f0ec ] netlink doesn't set any network header offset thus when the skb is being passed to tap devices via dev_queue_xmit_nit(), it emits klog false positives due to it being unset like: ... [ 124.990397] protocol 0000 is buggy, dev nlmon0 [ 124.990411] protocol 0000 is buggy, dev nlmon0 ... So just reset the network header before passing to the device; for packet sockets that just means nothing will change - mac and net offset hold the same value just as before. Reported-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05ipvs: fix ipv6 hook registration for local repliesJulian Anastasov
commit eb90b0c734ad793d5f5bf230a9e9a4dcc48df8aa upstream. commit fc604767613b6d2036cdc35b660bc39451040a47 ("ipvs: changes for local real server") from 2.6.37 introduced DNAT support to local real server but the IPv6 LOCAL_OUT handler ip_vs_local_reply6() is registered incorrectly as IPv4 hook causing any outgoing IPv4 traffic to be dropped depending on the IP header values. Chris tracked down the problem to CONFIG_IP_VS_IPV6=y Bug report: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1349768 Reported-by: Chris J Arges <chris.j.arges@canonical.com> Tested-by: Chris J Arges <chris.j.arges@canonical.com> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05netfilter: x_tables: allow to use default cgroup matchDaniel Borkmann
commit caa8ad94edf686d02b555c65a6162c0d1b434958 upstream. There's actually no good reason why we cannot use cgroup id 0, so lets just remove this artificial barrier. Reported-by: Alexey Perevalov <a.perevalov@samsung.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Tested-by: Alexey Perevalov <a.perevalov@samsung.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05ipvs: Maintain all DSCP and ECN bits for ipv6 tun forwardingAlex Gartrell
commit 76f084bc10004b3050b2cff9cfac29148f1f6088 upstream. Previously, only the four high bits of the tclass were maintained in the ipv6 case. This matches the behavior of ipv4, though whether or not we should reflect ECN bits may be up for debate. Signed-off-by: Alex Gartrell <agartrell@fb.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05netfilter: xt_hashlimit: perform garbage collection from process contextEric Dumazet
commit 7bd8490eef9776ced7632345df5133384b6be0fe upstream. xt_hashlimit cannot be used with large hash tables, because garbage collector is run from a timer. If table is really big, its possible to hold cpu for more than 500 msec, which is unacceptable. Switch to a work queue, and use proper scheduling points to remove latencies spikes. Later, we also could switch to a smoother garbage collection done at lookup time, one bucket at a time... Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Florian Westphal <fw@strlen.de> Cc: Patrick McHardy <kaber@trash.net> Reviewed-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05ipvs: avoid netns exit crash on ip_vs_conn_drop_conntrackJulian Anastasov
commit 2627b7e15c5064ddd5e578e4efd948d48d531a3f upstream. commit 8f4e0a18682d91 ("IPVS netns exit causes crash in conntrack") added second ip_vs_conn_drop_conntrack call instead of just adding the needed check. As result, the first call still can cause crash on netns exit. Remove it. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Hans Schillstrom <hans@schillstrom.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05nl80211: clear skb cb before passing to netlinkJohannes Berg
commit bd8c78e78d5011d8111bc2533ee73b13a3bd6c42 upstream. In testmode and vendor command reply/event SKBs we use the skb cb data to store nl80211 parameters between allocation and sending. This causes the code for CONFIG_NETLINK_MMAP to get confused, because it takes ownership of the skb cb data when the SKB is handed off to netlink, and it doesn't explicitly clear it. Clear the skb cb explicitly when we're done and before it gets passed to netlink to avoid this issue. Reported-by: Assaf Azulay <assaf.azulay@intel.com> Reported-by: David Spinadel <david.spinadel@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05Revert "mac80211: disable uAPSD if all ACs are under ACM"Johannes Berg
commit bb512ad0732232f1d2693bb68f31a76bed8f22ae upstream. This reverts commit 24aa11ab8ae03292d38ec0dbd9bc2ac49fe8a6dd. That commit was wrong since it uses data that hasn't even been set up yet, but might be a hold-over from a previous connection. Additionally, it seems like a driver-specific workaround that shouldn't have been in mac80211 to start with. Fixes: 24aa11ab8ae0 ("mac80211: disable uAPSD if all ACs are under ACM") Reviewed-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17libceph: gracefully handle large reply messages from the monSage Weil
commit 73c3d4812b4c755efeca0140f606f83772a39ce4 upstream. We preallocate a few of the message types we get back from the mon. If we get a larger message than we are expecting, fall back to trying to allocate a new one instead of blindly using the one we have. Signed-off-by: Sage Weil <sage@redhat.com> Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17libceph: do not hard code max auth ticket lenIlya Dryomov
commit c27a3e4d667fdcad3db7b104f75659478e0c68d8 upstream. We hard code cephx auth ticket buffer size to 256 bytes. This isn't enough for any moderate setups and, in case tickets themselves are not encrypted, leads to buffer overflows (ceph_x_decrypt() errors out, but ceph_decode_copy() doesn't - it's just a memcpy() wrapper). Since the buffer is allocated dynamically anyway, allocated it a bit later, at the point where we know how much is going to be needed. Fixes: http://tracker.ceph.com/issues/8979 Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17libceph: add process_one_ticket() helperIlya Dryomov
commit 597cda357716a3cf8d994cb11927af917c8d71fa upstream. Add a helper for processing individual cephx auth tickets. Needed for the next commit, which deals with allocating ticket buffers. (Most of the diff here is whitespace - view with git diff -b). Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17libceph: set last_piece in ceph_msg_data_pages_cursor_init() correctlyIlya Dryomov
commit 5f740d7e1531099b888410e6bab13f68da9b1a4d upstream. Determining ->last_piece based on the value of ->page_offset + length is incorrect because length here is the length of the entire message. ->last_piece set to false even if page array data item length is <= PAGE_SIZE, which results in invalid length passed to ceph_tcp_{send,recv}page() and causes various asserts to fire. # cat pages-cursor-init.sh #!/bin/bash rbd create --size 10 --image-format 2 foo FOO_DEV=$(rbd map foo) dd if=/dev/urandom of=$FOO_DEV bs=1M &>/dev/null rbd snap create foo@snap rbd snap protect foo@snap rbd clone foo@snap bar # rbd_resize calls librbd rbd_resize(), size is in bytes ./rbd_resize bar $(((4 << 20) + 512)) rbd resize --size 10 bar BAR_DEV=$(rbd map bar) # trigger a 512-byte copyup -- 512-byte page array data item dd if=/dev/urandom of=$BAR_DEV bs=1M count=1 seek=5 The problem exists only in ceph_msg_data_pages_cursor_init(), ceph_msg_data_pages_advance() does the right thing. The size_t cast is unnecessary. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@redhat.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17Bluetooth: Avoid use of session socket after the session gets freedVignesh Raman
commit 32333edb82fb2009980eefc5518100068147ab82 upstream. The commits 08c30aca9e698faddebd34f81e1196295f9dc063 "Bluetooth: Remove RFCOMM session refcnt" and 8ff52f7d04d9cc31f1e81dcf9a2ba6335ed34905 "Bluetooth: Return RFCOMM session ptrs to avoid freed session" allow rfcomm_recv_ua and rfcomm_session_close to delete the session (and free the corresponding socket) and propagate NULL session pointer to the upper callers. Additional fix is required to terminate the loop in rfcomm_process_rx function to avoid use of freed 'sk' memory. The issue is only reproducible with kernel option CONFIG_PAGE_POISONING enabled making freed memory being changed and filled up with fixed char value used to unmask use-after-free issues. Signed-off-by: Vignesh Raman <Vignesh_Raman@mentor.com> Signed-off-by: Vitaly Kuzmichev <Vitaly_Kuzmichev@mentor.com> Acked-by: Dean Jenkins <Dean_Jenkins@mentor.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17Bluetooth: never linger on process exitVladimir Davydov
commit 093facf3634da1b0c2cc7ed106f1983da901bbab upstream. If the current process is exiting, lingering on socket close will make it unkillable, so we should avoid it. Reproducer: #include <sys/types.h> #include <sys/socket.h> #define BTPROTO_L2CAP 0 #define BTPROTO_SCO 2 #define BTPROTO_RFCOMM 3 int main() { int fd; struct linger ling; fd = socket(PF_BLUETOOTH, SOCK_STREAM, BTPROTO_RFCOMM); //or: fd = socket(PF_BLUETOOTH, SOCK_DGRAM, BTPROTO_L2CAP); //or: fd = socket(PF_BLUETOOTH, SOCK_SEQPACKET, BTPROTO_SCO); ling.l_onoff = 1; ling.l_linger = 1000000000; setsockopt(fd, SOL_SOCKET, SO_LINGER, &ling, sizeof(ling)); return 0; } Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05svcrdma: Select NFSv4.1 backchannel transport based on forward channelChuck Lever
commit 3c45ddf823d679a820adddd53b52c6699c9a05ac upstream. The current code always selects XPRT_TRANSPORT_BC_TCP for the back channel, even when the forward channel was not TCP (eg, RDMA). When a 4.1 mount is attempted with RDMA, the server panics in the TCP BC code when trying to send CB_NULL. Instead, construct the transport protocol number from the forward channel transport or'd with XPRT_TRANSPORT_BC. Transports that do not support bi-directional RPC will not have registered a "BC" transport, causing create_backchannel_client() to fail immediately. Fixes: https://bugzilla.linux-nfs.org/show_bug.cgi?id=265 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-14sctp: fix possible seqlock seadlock in sctp_packet_transmit()Eric Dumazet
[ Upstream commit 757efd32d5ce31f67193cc0e6a56e4dffcc42fb1 ] Dave reported following splat, caused by improper use of IP_INC_STATS_BH() in process context. BUG: using __this_cpu_add() in preemptible [00000000] code: trinity-c117/14551 caller is __this_cpu_preempt_check+0x13/0x20 CPU: 3 PID: 14551 Comm: trinity-c117 Not tainted 3.16.0+ #33 ffffffff9ec898f0 0000000047ea7e23 ffff88022d32f7f0 ffffffff9e7ee207 0000000000000003 ffff88022d32f818 ffffffff9e397eaa ffff88023ee70b40 ffff88022d32f970 ffff8801c026d580 ffff88022d32f828 ffffffff9e397ee3 Call Trace: [<ffffffff9e7ee207>] dump_stack+0x4e/0x7a [<ffffffff9e397eaa>] check_preemption_disabled+0xfa/0x100 [<ffffffff9e397ee3>] __this_cpu_preempt_check+0x13/0x20 [<ffffffffc0839872>] sctp_packet_transmit+0x692/0x710 [sctp] [<ffffffffc082a7f2>] sctp_outq_flush+0x2a2/0xc30 [sctp] [<ffffffff9e0d985c>] ? mark_held_locks+0x7c/0xb0 [<ffffffff9e7f8c6d>] ? _raw_spin_unlock_irqrestore+0x5d/0x80 [<ffffffffc082b99a>] sctp_outq_uncork+0x1a/0x20 [sctp] [<ffffffffc081e112>] sctp_cmd_interpreter.isra.23+0x1142/0x13f0 [sctp] [<ffffffffc081c86b>] sctp_do_sm+0xdb/0x330 [sctp] [<ffffffff9e0b8f1b>] ? preempt_count_sub+0xab/0x100 [<ffffffffc083b350>] ? sctp_cname+0x70/0x70 [sctp] [<ffffffffc08389ca>] sctp_primitive_ASSOCIATE+0x3a/0x50 [sctp] [<ffffffffc083358f>] sctp_sendmsg+0x88f/0xe30 [sctp] [<ffffffff9e0d673a>] ? lock_release_holdtime.part.28+0x9a/0x160 [<ffffffff9e0d62ce>] ? put_lock_stats.isra.27+0xe/0x30 [<ffffffff9e73b624>] inet_sendmsg+0x104/0x220 [<ffffffff9e73b525>] ? inet_sendmsg+0x5/0x220 [<ffffffff9e68ac4e>] sock_sendmsg+0x9e/0xe0 [<ffffffff9e1c0c09>] ? might_fault+0xb9/0xc0 [<ffffffff9e1c0bae>] ? might_fault+0x5e/0xc0 [<ffffffff9e68b234>] SYSC_sendto+0x124/0x1c0 [<ffffffff9e0136b0>] ? syscall_trace_enter+0x250/0x330 [<ffffffff9e68c3ce>] SyS_sendto+0xe/0x10 [<ffffffff9e7f9be4>] tracesys+0xdd/0xe2 This is a followup of commits f1d8cba61c3c4b ("inet: fix possible seqlock deadlocks") and 7f88c6b23afbd315 ("ipv6: fix possible seqlock deadlock in ip6_finish_output2") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Reported-by: Dave Jones <davej@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-14batman-adv: Fix out-of-order fragmentation supportSven Eckelmann
[ Upstream commit d9124268d84a836f14a6ead54ff9d8eee4c43be5 ] batadv_frag_insert_packet was unable to handle out-of-order packets because it dropped them directly. This is caused by the way the fragmentation lists is checked for the correct place to insert a fragmentation entry. The fragmentation code keeps the fragments in lists. The fragmentation entries are kept in descending order of sequence number. The list is traversed and each entry is compared with the new fragment. If the current entry has a smaller sequence number than the new fragment then the new one has to be inserted before the current entry. This ensures that the list is still in descending order. An out-of-order packet with a smaller sequence number than all entries in the list still has to be added to the end of the list. The used hlist has no information about the last entry in the list inside hlist_head and thus the last entry has to be calculated differently. Currently the code assumes that the iterator variable of hlist_for_each_entry can be used for this purpose after the hlist_for_each_entry finished. This is obviously wrong because the iterator variable is always NULL when the list was completely traversed. Instead the information about the last entry has to be stored in a different variable. This problem was introduced in 610bfc6bc99bc83680d190ebc69359a05fc7f605 ("batman-adv: Receive fragmented packets and merge"). Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-14iovec: make sure the caller actually wants anything in memcpy_fromiovecendSasha Levin
[ Upstream commit 06ebb06d49486676272a3c030bfeef4bd969a8e6 ] Check for cases when the caller requests 0 bytes instead of running off and dereferencing potentially invalid iovecs. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-14net: Correctly set segment mac_len in skb_segment().Vlad Yasevich
[ Upstream commit fcdfe3a7fa4cb74391d42b6a26dc07c20dab1d82 ] When performing segmentation, the mac_len value is copied right out of the original skb. However, this value is not always set correctly (like when the packet is VLAN-tagged) and we'll end up copying a bad value. One way to demonstrate this is to configure a VM which tags packets internally and turn off VLAN acceleration on the forwarding bridge port. The packets show up corrupt like this: 16:18:24.985548 52:54:00:ab:be:25 > 52:54:00:26:ce:a3, ethertype 802.1Q (0x8100), length 1518: vlan 100, p 0, ethertype 0x05e0, 0x0000: 8cdb 1c7c 8cdb 0064 4006 b59d 0a00 6402 ...|...d@.....d. 0x0010: 0a00 6401 9e0d b441 0a5e 64ec 0330 14fa ..d....A.^d..0.. 0x0020: 29e3 01c9 f871 0000 0101 080a 000a e833)....q.........3 0x0030: 000f 8c75 6e65 7470 6572 6600 6e65 7470 ...unetperf.netp 0x0040: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp 0x0050: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp 0x0060: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp ... This also leads to awful throughput as GSO packets are dropped and cause retransmissions. The solution is to set the mac_len using the values already available in then new skb. We've already adjusted all of the header offset, so we might as well correctly figure out the mac_len using skb_reset_mac_len(). After this change, packets are segmented correctly and performance is restored. CC: Eric Dumazet <edumazet@google.com> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
