Based on suggestion from Masahide Nakamura <nakam@linux-ipv6.org>.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Chris Wright <chrisw@osdl.org>
Since we've converted the ftp/irc/tftp helpers to use the new
module_parm_array() some time ago, we ware accidentially using signed data
types - thus preventing those modules from being used on ports >= 32768.
This patch fixes it by using 'ushort' module parameters.
Thanks to Jan Nijs for reporting this bug.
Signed-off-by: Harald Welte <laforge@netfilter.org>
Some devices (e.g. Qlogic iSCSI HBA hardware like QLA4010 up to firmware
3.0.0.4) initiates TCP with SYN and PUSH flags set.
The Linux TCP/IP stack deals fine with that, but the connection tracking
code doesn't.
This patch alters TCP connection tracking to accept SYN+PUSH as a valid
flag combination.
Signed-off-by: Vlad Drukker <vlad@storewiz.com>
This patch fixes an userspace triggered oops. If there is no ICMP_ID
info the reference to attr will be NULL.
Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl>
The reply tuple of the PNS->PAC expectation was using the wrong call id.
So we had the following situation:
- PNS behind NAT firewall
- PNS call id requires NATing
- PNS->PAC gre packet arrives first
then the PNS->PAC expectation is matched, and the other expectation
is deleted, but the PAC->PNS gre packets do not match the gre conntrack
because the call id is wrong.
We also cannot use ip_nat_follow_master().
Signed-off-by: Philip Craig <philipc@snapgear.com>
This fixes an oops triggered from userspace. If we don't pass information
about the private protocol info, the reference to attr will be NULL. This is
likely to happen in update messages.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
With the new nf_queue generalization in 2.6.14, we've introduced a bug
that causes an oops as soon as a packet is queued but no queue handler
registered. This patch fixes it.
The unknown protocol is used as a fallback when a protocol isn't known.
Hence we cannot handle it failing, so don't set ".me". It's OK, since we
only grab a reference from within the same module (iptable_nat.ko), so we
never take the module refcount from 0 to 1.
Also, remove the "protocol is NULL" test: it's never NULL.
Signed-off-by: Rusty Rusty <rusty@rustcorp.com.au>
This endianness bug slipped through while changing the 'gre.key' field in
the conntrack tuple from 32bit to 16bit.
None of my tests caught the problem, since the linux pptp client always has
'0' as call id / gre key. Only windows clients actually trigger the bug.
There was a fix in 2.6.13 that changed the behaviour of
ip_vs_conn_expire_now function not to put reference to connection, its
callers should hold write lock or connection refcnt. But we forgot to
convert one caller, when the real server for connection is unavailable
caller should put the connection reference. It happens only when sysctl
var expire_nodest_conn is set to 1 and such connections never expire.
Thanks to Roberto Nibali who found the problem and tested a 2.4.32-rc2
patch, which is equal to this 2.6 version.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Roberto Nibali <ratz@drugphish.ch>
The recent rewrite of skb_copy_datagram_iovec broke the reception of
zero-size datagrams. This patch fixes it.
The max growth of BIC TCP is too large. Original code was based on
BIC 1.0 and the default there was 32. Later code (2.6.13) included
compensation for delayed acks, and should have reduced the default
value to 16; since normally TCP gets one ack for every two packets sent.
The current value of 32 makes BIC too aggressive and unfair to other
flows.
Submitted-by: Injong Rhee <rhee@eos.ncsu.edu>
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
This bug is responsible for causing the infamous "Treason uncloaked"
messages that's been popping up everywhere since the printk was added.
It has usually been blamed on foreign operating systems. However,
some of those reports implicate Linux as both systems are running
Linux or the TCP connection is going across the loopback interface.
In fact, there really is a bug in the Linux TCP header prediction code
that's been there since at least 2.1.8. This bug was tracked down with
help from Dale Blount.
The effect of this bug ranges from harmless "Treason uncloaked"
messages to hung/aborted TCP connections. The details of the bug
and fix is as follows.
When snd_wnd is updated, we only update pred_flags if
tcp_fast_path_check succeeds. When it fails (for example,
when our rcvbuf is used up), we will leave pred_flags with
an out-of-date snd_wnd value.
When the out-of-date pred_flags happens to match the next incoming
packet we will again hit the fast path and use the current snd_wnd
which will be wrong.
In the case of the treason messages, it just happens that the snd_wnd
cached in pred_flags is zero while tp->snd_wnd is non-zero. Therefore
when a zero-window packet comes in we incorrectly conclude that the
window is non-zero.
In fact if the peer continues to send us zero-window pure ACKs we
will continue making the same mistake. It's only when the peer
transmits a zero-window packet with data attached that we get a
chance to snap out of it. This is what triggers the treason
message at the next retransmit timeout.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Convert nanoseconds to microseconds correctly.
Spotted by Steve Dickson <SteveD@redhat.com>
Although this message is having the intended effect of causing wireless
driver maintainers to upgrade their code, I never should have merged this
patch in its present form. Leading to tons of bug reports and unhappy
users.
Some wireless apps poll for statistics regularly, which leads to a printk()
every single time they ask for stats. That's a little bit _too_ much of a
reminder that the driver is using an old API.
Change this to printing out the message once, per kernel boot.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
Signed-off-by: Yan Zheng <yanzheng@21cn.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
neigh_changeaddr attempts to delete neighbour timers without setting
nud_state. This doesn't work because the timer may have already fired
when we acquire the write lock in neigh_changeaddr. The result is that
the timer may keep firing for quite a while until the entry reaches
NEIGH_FAILED.
It should be setting the nud_state straight away so that if the timer
has already fired it can simply exit once we relinquish the lock.
In fact, this whole function is simply duplicating the logic in
neigh_ifdown which in turn is already doing the right thing when
it comes to deleting timers and setting nud_state.
So all we have to do is take that code out and put it into a common
function and make both neigh_changeaddr and neigh_ifdown call it.
neigh_add_timer cannot use add_timer unconditionally. The reason is that
by the time it has obtained the write lock someone else (e.g., neigh_update)
could have already added a new timer.
So it should only use mod_timer and deal with its return value accordingly.
This bug would have led to rare neighbour cache entry leaks.
Stack traces are very helpful in determining the exact nature of a bug.
So let's print a stack trace when the timer is added twice.
IPVS used flag NFC_IPVS_PROPERTY in nfcache but as now nfcache was removed the
new flag 'ipvs_property' still needs to be copied. This patch should be
included in 2.6.14.
Further comments from Harald Welte:
Sorry, seems like the bug was introduced by me.
It is legitimate to call tcp_fragment with len == skb->len since
that is done for FIN packets and the FIN flag counts as one byte.
So we should only check for the len > skb->len case.
Turns out the problem has nothing to do with use-after-free or double-free.
It's just that we're not clearing the CB area and DCCP unlike TCP uses a CB
format that's incompatible with IP.
Signed-off-by: Ian McDonald <imcdnzl@gmail.com>
icmp_send doesn't use skb->sk at all so even if skb->sk has already
been freed it can't cause crash there (it would've crashed somewhere
else first, e.g., ip_queue_xmit).
I found a double-free on an skb that could explain this though.
dccp_sendmsg and dccp_write_xmit are a little confused as to what
should free the packet when something goes wrong. Sometimes they
both go for the ball and end up in each other's way.
This patch makes dccp_write_xmit always free the packet no matter
what. This makes sense since dccp_transmit_skb which in turn comes
from the fact that ip_queue_xmit always frees the packet.
David S. Miller <davem@davemloft.net> wrote:
> One thing you can probably do for this bug is to mark data packets
> explicitly somehow, perhaps in the SKB control block DCCP already
> uses for other data. Put some boolean in there, set it true for
> data packets. Then change the test in dccp_transmit_skb() as
> appropriate to test the boolean flag instead of "skb_cloned(skb)".
I agree. In fact we already have that flag, it's called skb->sk.
So here is patch to test that instead of skb_cloned().
Acked-by: Ian McDonald <imcdnzl@gmail.com>
Better safe than sorry.
Opterons with frequency scaling have fully unsynchronized TSCs
running at different frequencies, so using TSCs there is not a good idea.
Also some other x86 boxes have this problem. gettimeofday should be good
enough, so just disable it.
Signed-off-by: Andi Kleen <ak@suse.de>
Original patch by Harald Welte, with feedback from Herbert Xu
and testing by Sébastien Bernard.
EBTABLES, ARP tables, and IP/IP6 tables all assume that cpus
are numbered linearly. That is not necessarily true.
This patch fixes that up by calculating the largest possible
cpu number, and allocating enough per-cpu structure space given
that.
This is the second report of this bug. Unfortunately the first
reporter hasn't been able to reproduce it since to provide more
debugging info.
So let's apply this patch for 2.6.14 to
1) Make this non-fatal.
2) Provide the info we need to track it down.
This fixes the RCU race on bridge delete interface. Basically,
the network device has to be detached from the bridge in the first
step (pre-RCU), rather than later. At that point, no more bridge traffic
will come in, and the other code will not think that network device
is part of a bridge.
This should also fix the XEN test problems.
This is required to avoid unloading a module that has active timewait
sockets, such as DCCP.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Noticed by Andrea Bittau, that provided a patch that was modified to
not transition from RESPOND to OPEN when receiving DATA packets.
For consistency with ccid_exit and to fix a bug when
IP_DCCP_UNLOAD_HACK is enabled as the control sock is not associated
to any CCID.
This patch add support to change the state of the private protocol
information via conntrack_netlink.
This patch adds the ability of changing the state a TCP connection. I know
that this must be used with care but it's required to provide a complete
conntrack creation via conntrack_netlink. So I'll document this aspect on
the upcoming docs.
Initially we used 64bit counters for conntrack-based accounting, since we
had no event mechanism to tell userspace that our counters are about to
overflow. With nfnetlink_conntrack, we now have such a event mechanism and
thus can save 16bytes per connection.
This patch fixes the following bugs in ESP:
* Fix transport mode MTU overestimate. This means that the inner MTU
is smaller than it needs be. Worse yet, given an input MTU which
is a multiple of 4 it will always produce an estimate which is not
a multiple of 4.
For example, given a standard ESP/3DES/MD5 transform and an MTU of
1500, the resulting MTU for transport mode is 1462 when it should
be 1464.
The reason for this is because IP header lengths are always a multiple
of 4 for IPv4 and 8 for IPv6.
* Ensure that the block size is at least 4. This is required by RFC2406
and corresponds to what the esp_output function does. At the moment
this only affects crypto_null as its block size is 1.
This patch uses the macro ALIGN in all the applicable spots for ESP.
To keep consistency, the TCP private protocol information is nested
attributes under CTA_PROTOINFO_TCP. This way the sequence of attributes to
access the TCP state information looks like here below:
CTA_PROTOINFO
CTA_PROTOINFO_TCP
CTA_PROTOINFO_TCP_STATE
instead of:
CTA_PROTOINFO
The ID is only required by ICMP type 8 (echo), so it's not
mandatory for all sort of ICMP connections. This patch makes
mandatory only the type and the code for ICMP netlink messages.
When we send "status" from userspace, we forget to convert the endianness.
This patch adds the reqired conversion. Thanks to Pablo Neira for
discovering this.
As Henrik Nordstrom pointed out, all our efforts with "split endian" (i.e.
host byte order tags, net byte order values) are useless, unless a parser
can determine whether an attribute is nested or not.
This patch steals the highest bit of nfattr.nfa_type to indicate whether
the data payload contains a nested nfattr (1) or not (0).
This will break userspace compatibility, but luckily no kernel with
nfnetlink was released so far.
Similar to nfnetlink_queue and ip_queue, we mark ipt_ULOG as obsolete.
This should have been part of the original nfnetlink_log merge, but
I somehow missed it.
PPTP should not be selectable without conntrack enabled
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
