path: root/net
2014-06-08Merge tag 'llvmlinux-for-v3.16' of ↵Linus Torvalds
git://git.linuxfoundation.org/llvmlinux/kernel Pull LLVM patches from Behan Webster: "Next set of patches to support compiling the kernel with clang. They've been soaking in linux-next since the last merge window. More still in the works for the next merge window..." * tag 'llvmlinux-for-v3.16' of git://git.linuxfoundation.org/llvmlinux/kernel: arm, unwind, LLVMLinux: Enable clang to be used for unwinding the stack ARM: LLVMLinux: Change "extern inline" to "static inline" in glue-cache.h all: LLVMLinux: Change DWARF flag to support gcc and clang net: netfilter: LLVMLinux: vlais-netfilter crypto: LLVMLinux: aligned-attribute.patch
2014-06-08Merge branch 'next' (accumulated 3.16 merge window patches) into masterLinus Torvalds
Now that 3.15 is released, this merges the 'next' branch into 'master', bringing us to the normal situation where my 'master' branch is the merge window. * accumulated work in next: (6809 commits) ufs: sb mutex merge + mutex_destroy powerpc: update comments for generic idle conversion cris: update comments for generic idle conversion idle: remove cpu_idle() forward declarations nbd: zero from and len fields in NBD_CMD_DISCONNECT. mm: convert some level-less printks to pr_* MAINTAINERS: adi-buildroot-devel is moderated MAINTAINERS: add linux-api for review of API/ABI changes mm/kmemleak-test.c: use pr_fmt for logging fs/dlm/debug_fs.c: replace seq_printf by seq_puts fs/dlm/lockspace.c: convert simple_str to kstr fs/dlm/config.c: convert simple_str to kstr mm: mark remap_file_pages() syscall as deprecated mm: memcontrol: remove unnecessary memcg argument from soft limit functions mm: memcontrol: clean up memcg zoneinfo lookup mm/memblock.c: call kmemleak directly from memblock_(alloc|free) mm/mempool.c: update the kmemleak stack trace for mempool allocations lib/radix-tree.c: update the kmemleak stack trace for radix tree allocations mm: introduce kmemleak_update_trace() mm/kmemleak.c: use %u to print ->checksum ...
2014-06-07net: netfilter: LLVMLinux: vlais-netfilterMark Charlebois
Replaced non-standard C use of Variable Length Arrays In Structs (VLAIS) in xt_repldata.h with a C99 compliant flexible array member and then calculated offsets to the other struct members. These other members aren't referenced by name in this code, however this patch maintains the same memory layout and padding as was previously accomplished using VLAIS. Had the original structure been ordered differently, with the entries VLA at the end, then it could have been a flexible member, and this patch would have been a lot simpler. However since the data stored in this structure is ultimately exported to userspace, the order of this structure can't be changed. This patch makes no attempt to change the existing behavior, merely the way in which the current layout is accomplished using standard C99 constructs. As such the code can now be compiled with either gcc or clang. This version of the patch removes the trailing alignment that the VLAIS structure would allocate in order to simplify the patch. Author: Mark Charlebois <charlebm@gmail.com> Signed-off-by: Mark Charlebois <charlebm@gmail.com> Signed-off-by: Behan Webster <behanw@converseincode.com> Signed-off-by: Vinícius Tinti <viniciustinti@gmail.com>
2014-06-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core locking updates from Ingo Molnar: "The main changes in this cycle were: - reduced/streamlined smp_mb__*() interface that allows more usecases and makes the existing ones less buggy, especially in rarer architectures - add rwsem implementation comments - bump up lockdep limits" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) rwsem: Add comments to explain the meaning of the rwsem's count field lockdep: Increase static allocations arch: Mass conversion of smp_mb__*() arch,doc: Convert smp_mb__*() arch,xtensa: Convert smp_mb__*() arch,x86: Convert smp_mb__*() arch,tile: Convert smp_mb__*() arch,sparc: Convert smp_mb__*() arch,sh: Convert smp_mb__*() arch,score: Convert smp_mb__*() arch,s390: Convert smp_mb__*() arch,powerpc: Convert smp_mb__*() arch,parisc: Convert smp_mb__*() arch,openrisc: Convert smp_mb__*() arch,mn10300: Convert smp_mb__*() arch,mips: Convert smp_mb__*() arch,metag: Convert smp_mb__*() arch,m68k: Convert smp_mb__*() arch,m32r: Convert smp_mb__*() arch,ia64: Convert smp_mb__*() ...
2014-06-02net: filter: fix possible memory leak in __sk_prepare_filter()Leon Yu
__sk_prepare_filter() was reworked in commit bd4cf0ed3 (net: filter: rework/optimize internal BPF interpreter's instruction set) so that it should have uncharged memory once things went wrong. However that work isn't complete. Error is handled only in __sk_migrate_filter() while memory can still leak in the error path right after sk_chk_filter(). Fixes: bd4cf0ed331a ("net: filter: rework/optimize internal BPF interpreter's instruction set") Signed-off-by: Leon Yu <chianglungyu@gmail.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Tested-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-02tcp: fix cwnd undo on DSACK in F-RTOYuchung Cheng
This bug is discovered by an recent F-RTO issue on tcpm list https://www.ietf.org/mail-archive/web/tcpm/current/msg08794.html The bug is that currently F-RTO does not use DSACK to undo cwnd in certain cases: upon receiving an ACK after the RTO retransmission in F-RTO, and the ACK has DSACK indicating the retransmission is spurious, the sender only calls tcp_try_undo_loss() if some never retransmisted data is sacked (FLAG_ORIG_DATA_SACKED). The correct behavior is to unconditionally call tcp_try_undo_loss so the DSACK information is used properly to undo the cwnd reduction. Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-02netlink: Only check file credentials for implicit destinationsEric W. Biederman
It was possible to get a setuid root or setcap executable to write to it's stdout or stderr (which has been set made a netlink socket) and inadvertently reconfigure the networking stack. To prevent this we check that both the creator of the socket and the currentl applications has permission to reconfigure the network stack. Unfortunately this breaks Zebra which always uses sendto/sendmsg and creates it's socket without any privileges. To keep Zebra working don't bother checking if the creator of the socket has privilege when a destination address is specified. Instead rely exclusively on the privileges of the sender of the socket. Note from Andy: This is exactly Eric's code except for some comment clarifications and formatting fixes. Neither I nor, I think, anyone else is thrilled with this approach, but I'm hesitant to wait on a better fix since 3.15 is almost here. Note to stable maintainers: This is a mess. An earlier series of patches in 3.15 fix a rather serious security issue (CVE-2014-0181), but they did so in a way that breaks Zebra. The offending series includes: commit aa4cf9452f469f16cea8c96283b641b4576d4a7b Author: Eric W. Biederman <ebiederm@xmission.com> Date: Wed Apr 23 14:28:03 2014 -0700 net: Add variants of capable for use on netlink messages If a given kernel version is missing that series of fixes, it's probably worth backporting it and this patch. if that series is present, then this fix is critical if you care about Zebra. Cc: stable@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-02net: fix inet_getid() and ipv6_select_ident() bugsEric Dumazet
I noticed we were sending wrong IPv4 ID in TCP flows when MTU discovery is disabled. Note how GSO/TSO packets do not have monotonically incrementing ID. 06:37:41.575531 IP (id 14227, proto: TCP (6), length: 4396) 06:37:41.575534 IP (id 14272, proto: TCP (6), length: 65212) 06:37:41.575544 IP (id 14312, proto: TCP (6), length: 57972) 06:37:41.575678 IP (id 14317, proto: TCP (6), length: 7292) 06:37:41.575683 IP (id 14361, proto: TCP (6), length: 63764) It appears I introduced this bug in linux-3.1. inet_getid() must return the old value of peer->ip_id_count, not the new one. Lets revert this part, and remove the prevention of a null identification field in IPv6 Fragment Extension Header, which is dubious and not even done properly. Fixes: 87c48fa3b463 ("ipv6: make fragment identifications less predictable") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-02bridge: Prevent insertion of FDB entry with disallowed vlanToshiaki Makita
br_handle_local_finish() is allowing us to insert an FDB entry with disallowed vlan. For example, when port 1 and 2 are communicating in vlan 10, and even if vlan 10 is disallowed on port 3, port 3 can interfere with their communication by spoofed src mac address with vlan id 10. Note: Even if it is judged that a frame should not be learned, it should not be dropped because it is destined for not forwarding layer but higher layer. See IEEE 802.1Q-2011 8.13.10. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-01bridge: notify user space after fdb updateJon Maxwell
There has been a number incidents recently where customers running KVM have reported that VM hosts on different Hypervisors are unreachable. Based on pcap traces we found that the bridge was broadcasting the ARP request out onto the network. However some NICs have an inbuilt switch which on occasions were broadcasting the VMs ARP request back through the physical NIC on the Hypervisor. This resulted in the bridge changing ports and incorrectly learning that the VMs mac address was external. As a result the ARP reply was directed back onto the external network and VM never updated it's ARP cache. This patch will notify the bridge command, after a fdb has been updated to identify such port toggling. Signed-off-by: Jon Maxwell <jmaxwell37@gmail.com> Reviewed-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-01net: fix wrong mac_len calculation for vlansNikolay Aleksandrov
After 1e785f48d29a ("net: Start with correct mac_len in skb_network_protocol") skb->mac_len is used as a start of the calculation in skb_network_protocol() but that is not always correct. If skb->protocol == 8021Q/AD, usually the vlan header is already inserted in the skb (i.e. vlan reorder hdr == 0). Usually when the packet enters dev_hard_xmit it has mac_len == 0 so we take 2 bytes from the destination mac address (skb->data + VLAN_HLEN) as a type in skb_network_protocol() and return vlan_depth == 4. In the case where TSO is off, then the mac_len is set but it's == 18 (ETH_HLEN + VLAN_HLEN), so skb_network_protocol() returns a type from inside the packet and offset == 22. Also make vlan_depth unsigned as suggested before. As suggested by Eric Dumazet, move the while() loop in the if() so we can avoid additional testing in fast path. Here are few netperf tests + debug printk's to illustrate: cat netperf.tso-on.reorder-on.bugged - Vlan -> device (reorder on, default, this case is okay) MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 192.168.3.1 () port 0 AF_INET Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 10.00 7111.54 [ 81.605435] skb->len 65226 skb->gso_size 1448 skb->proto 0x800 skb->mac_len 0 vlan_depth 0 type 0x800 - Vlan -> device (reorder off, bad) cat netperf.tso-on.reorder-off.bugged MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 192.168.3.1 () port 0 AF_INET Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 10.00 241.35 [ 204.578332] skb->len 1518 skb->gso_size 0 skb->proto 0x8100 skb->mac_len 0 vlan_depth 4 type 0x5301 0x5301 are the last two bytes of the destination mac. And if we stop TSO, we may get even the following: [ 83.343156] skb->len 2966 skb->gso_size 1448 skb->proto 0x8100 skb->mac_len 18 vlan_depth 22 type 0xb84 Because mac_len already accounts for VLAN_HLEN. After the fix: cat netperf.tso-on.reorder-off.fixed MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 192.168.3.1 () port 0 AF_INET Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec 87380 16384 16384 10.01 5001.46 [ 81.888489] skb->len 65230 skb->gso_size 1448 skb->proto 0x8100 skb->mac_len 0 vlan_depth 18 type 0x800 CC: Vlad Yasevich <vyasevic@redhat.com> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: Daniel Borkman <dborkman@redhat.com> CC: David S. Miller <davem@davemloft.net> Fixes:1e785f48d29a ("net: Start with correct mac_len in skb_network_protocol") Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-31Merge tag 'batman-adv-fix-for-davem' of git://git.open-mesh.org/linux-mergeDavid S. Miller
Included changes: - prevent NULL dereference in multicast code Antonion Quartulli says: ==================== pull request net: batman-adv 20140527 here you have another very small fix intended for net/linux-3.15. It prevents some multicast functions from dereferencing a NULL pointer. (Actually it was nothing more than a typo) I hope it is not too late for such a small patch. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-31batman-adv: fix NULL pointer dereferencesMarek Lindner
Was introduced with 4c8755d69cbde2ec464a39c932aed0a83f9ff89f ("batman-adv: Send multicast packets to nodes with a WANT_ALL flag") Reported-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Acked-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-05-30Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contains a late fix for IPVS: * Fix crash when trying to remove the transport header with non-linear skbuffs, this was introduced in 3.6-rc. Patch from Peter Christensen via the IPVS folks. I'll pass this to -stable once this hits mainstream. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-26ipvs: Fix panic due to non-linear skbPeter Christensen
Receiving a ICMP response to an IPIP packet in a non-linear skb could cause a kernel panic in __skb_pull. The problem was introduced in commit f2edb9f7706dcb2c0d9a362b2ba849efe3a97f5e ("ipvs: implement passive PMTUD for IPIP packets"). Signed-off-by: Peter Christensen <pch@ordbogen.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au>
2014-05-24Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-05-23 I have two more fixes intended for the 3.15 stream... For the iwlwifi one, Emmanuel says: "A race has been discovered in the beacon filtering code. Since the fix is too big for 3.15, I disable here the feature." For the bluetooth one, Gustavo says: "This pull request contains a very important fix for 3.15. Here we fix the permissions of a debugfs file that would otherwise allow unauthorized users to write content to it." Please let me know if there are problems! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "It looks like a sizeble collection but this is nearly 3 weeks of bug fixing while you were away. 1) Fix crashes over IPSEC tunnels with NAT, the latter can reroute the packet through a non-IPSEC protected path and the code has to be able to handle SKBs attached to routes lacking an attached xfrm state. From Steffen Klassert. 2) Fix OOPSs in ipv4 and ipv6 ipsec layers for unsupported sub-protocols, also from Steffen Klassert. 3) Set local_df on fragmented netfilter skbs otherwise we won't be able to forward successfully, from Florian Westphal. 4) cdc_mbim ipv6 neighbour code does __vlan_find_dev_deep without holding RCU lock, from Bjorn Mork. 5) local_df test in ip_may_fragment is inverted, from Florian Westphal. 6) jme driver doesn't check for DMA mapping failures, from Neil Horman. 7) qlogic driver doesn't calculate number of TX queues properly, from Shahed Shaikh. 8) fib_info_cnt can drift irreversibly positive if we fail to allocate the fi->fib_metrics array, from Sergey Popovich. 9) Fix use after free in ip6_route_me_harder(), also from Sergey Popovich. 10) When SYSCTL is disabled, we don't handle local_port_range and ping_group_range defaults properly at all, from Cong Wang. 11) Unaccelerated VLAN tagged frames improperly handled by cdc_mbim driver, fix from Bjorn Mork. 12) cassini driver needs nested lock annotations for TX locking, from Emil Goode. 13) On init error ipv6 VTI driver can unregister pernet ops twice, oops. Fix from Mahtias Krause. 14) If macvlan device is down, don't propagate IFF_ALLMULTI changes, from Peter Christensen. 15) Missing NULL pointer check while parsing netlink config options in ip6_tnl_validate(). From Susant Sahani. 16) Fix handling of neighbour entries during ipv6 router reachability probing, from Duan Jiong. 17) x86 and s390 JIT address randomization has some address calculation bugs leading to crashes, from Alexei Starovoitov and Heiko Carstens. 18) Clear up those uglies with nop patching and net_get_random_once(), from Hannes Frederic Sowa. 19) Option length miscalculated in ip6_append_data(), fix also from Hannes Frederic Sowa. 20) A while ago we fixed a race during device unregistry when a namespace went down, turns out there is a second place that needs similar protection. From Cong Wang. 21) In the new Altera TSE driver multicast filtering isn't working, disable it and just use promisc mode until the cause is found. From Vince Bridgers. 22) When we disable router enabling in ipv6 we have to flush the cached routes explicitly, from Duan Jiong. 23) NBMA tunnels should not cache routes on the tunnel object because the key is variable, from Timo Teräs. 24) With stacked devices GRO information in skb->cb[] can be not setup properly, make sure it is in all code paths. From Eric Dumazet. 25) Really fix stacked vlan locking, multiple levels of nesting with intervening non-vlan devices are possible. From Vlad Yasevich. 26) Fallback ipip tunnel device's mtu is not setup properly, from Steffen Klassert. 27) The packet scheduler's tcindex filter can crash because we structure copy objects with list_head's inside, oops. From Cong Wang. 28) Fix CHECKSUM_COMPLETE handling for ipv6 GRE tunnels, from Eric Dumazet. 29) In some configurations 'itag' in __mkroute_input() can end up being used uninitialized because of how fib_validate_source() works. Fix it by explitly initializing itag to zero like all the other fib_validate_source() callers do, from Li RongQing" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits) batman: fix a bogus warning from batadv_is_on_batman_iface() ipv4: initialise the itag variable in __mkroute_input bonding: Send ALB learning packets using the right source bonding: Don't assume 802.1Q when sending alb learning packets. net: doc: Update references to skb->rxhash stmmac: Remove unbalanced clk_disable call ipv6: gro: fix CHECKSUM_COMPLETE support net_sched: fix an oops in tcindex filter can: peak_pci: prevent use after free at netdev removal ip_tunnel: Initialize the fallback device properly vlan: Fix build error wth vlan_get_encap_level() can: c_can: remove obsolete STRICT_FRAME_ORDERING Kconfig option MAINTAINERS: Pravin Shelar is Open vSwitch maintainer. bnx2x: Convert return 0 to return rc bonding: Fix alb mode to only use first level vlans. bonding: Fix stacked device detection in arp monitoring macvlan: Fix lockdep warnings with stacked macvlan devices vlan: Fix lockdep warning with stacked vlan devices. net: Allow for more then a single subclass for netif_addr_lock net: Find the nesting level of a given device by type. ...
2014-05-23Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2014-05-22batman: fix a bogus warning from batadv_is_on_batman_iface()Cong Wang
batman tries to search dev->iflink to check if it's a batman interface, but ->iflink could be 0, which is not a valid ifindex. It should just avoid iflink == 0 case. Reported-by: Jet Chen <jet.chen@intel.com> Tested-by: Jet Chen <jet.chen@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Antonio Quartulli <antonio@open-mesh.com> Cc: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-22ipv4: initialise the itag variable in __mkroute_inputLi RongQing
the value of itag is a random value from stack, and may not be initiated by fib_validate_source, which called fib_combine_itag if CONFIG_IP_ROUTE_CLASSID is not set This will make the cached dst uncertainty Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-21ipv6: gro: fix CHECKSUM_COMPLETE supportEric Dumazet
When GRE support was added in linux-3.14, CHECKSUM_COMPLETE handling broke on GRE+IPv6 because we did not update/use the appropriate csum : GRO layer is supposed to use/update NAPI_GRO_CB(skb)->csum instead of skb->csum Tested using a GRE tunnel and IPv6 traffic. GRO aggregation now happens at the first level (ethernet device) instead of being done in gre tunnel. Native IPv6+TCP is still properly aggregated. Fixes: bf5a755f5e918 ("net-gre-gro: Add GRE support to the GRO stack") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Jerry Chu <hkchu@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-21net_sched: fix an oops in tcindex filterCong Wang
Kelly reported the following crash: IP: [<ffffffff817a993d>] tcf_action_exec+0x46/0x90 PGD 3009067 PUD 300c067 PMD 11ff30067 PTE 800000011634b060 Oops: 0000 [#1] SMP DEBUG_PAGEALLOC CPU: 1 PID: 639 Comm: dhclient Not tainted 3.15.0-rc4+ #342 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff8801169ecd00 ti: ffff8800d21b8000 task.ti: ffff8800d21b8000 RIP: 0010:[<ffffffff817a993d>] [<ffffffff817a993d>] tcf_action_exec+0x46/0x90 RSP: 0018:ffff8800d21b9b90 EFLAGS: 00010283 RAX: 00000000ffffffff RBX: ffff88011634b8e8 RCX: ffff8800cf7133d8 RDX: ffff88011634b900 RSI: ffff8800cf7133e0 RDI: ffff8800d210f840 RBP: ffff8800d21b9bb0 R08: ffffffff8287bf60 R09: 0000000000000001 R10: ffff8800d2b22b24 R11: 0000000000000001 R12: ffff8800d210f840 R13: ffff8800d21b9c50 R14: ffff8800cf7133e0 R15: ffff8800cad433d8 FS: 00007f49723e1840(0000) GS:ffff88011a800000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffff88011634b8f0 CR3: 00000000ce469000 CR4: 00000000000006e0 Stack: ffff8800d2170188 ffff8800d210f840 ffff8800d2171b90 0000000000000000 ffff8800d21b9be8 ffffffff817c55bb ffff8800d21b9c50 ffff8800d2171b90 ffff8800d210f840 ffff8800d21b0300 ffff8800d21b9c50 ffff8800d21b9c18 Call Trace: [<ffffffff817c55bb>] tcindex_classify+0x88/0x9b [<ffffffff817a7f7d>] tc_classify_compat+0x3e/0x7b [<ffffffff817a7fdf>] tc_classify+0x25/0x9f [<ffffffff817b0e68>] htb_enqueue+0x55/0x27a [<ffffffff817b6c2e>] dsmark_enqueue+0x165/0x1a4 [<ffffffff81775642>] __dev_queue_xmit+0x35e/0x536 [<ffffffff8177582a>] dev_queue_xmit+0x10/0x12 [<ffffffff818f8ecd>] packet_sendmsg+0xb26/0xb9a [<ffffffff810b1507>] ? __lock_acquire+0x3ae/0xdf3 [<ffffffff8175cf08>] __sock_sendmsg_nosec+0x25/0x27 [<ffffffff8175d916>] sock_aio_write+0xd0/0xe7 [<ffffffff8117d6b8>] do_sync_write+0x59/0x78 [<ffffffff8117d84d>] vfs_write+0xb5/0x10a [<ffffffff8117d96a>] SyS_write+0x49/0x7f [<ffffffff8198e212>] system_call_fastpath+0x16/0x1b This is because we memcpy struct tcindex_filter_result which contains struct tcf_exts, obviously struct list_head can not be simply copied. This is a regression introduced by commit 33be627159913b094bb578 (net_sched: act: use standard struct list_head). It's not very easy to fix it as the code is a mess: if (old_r) memcpy(&cr, r, sizeof(cr)); else { memset(&cr, 0, sizeof(cr)); tcf_exts_init(&cr.exts, TCA_TCINDEX_ACT, TCA_TCINDEX_POLICE); } ... tcf_exts_change(tp, &cr.exts, &e); ... memcpy(r, &cr, sizeof(cr)); the above code should equal to: tcindex_filter_result_init(&cr); if (old_r) cr.res = r->res; ... if (old_r) tcf_exts_change(tp, &r->exts, &e); else tcf_exts_change(tp, &cr.exts, &e); ... r->res = cr.res; after this change, since there is no need to copy struct tcf_exts. And it also fixes other places zero'ing struct's contains struct tcf_exts. Fixes: commit 33be627159913b0 (net_sched: act: use standard struct list_head) Reported-by: Kelly Anderson <kelly@xilka.com> Tested-by: Kelly Anderson <kelly@xilka.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-21ip_tunnel: Initialize the fallback device properlySteffen Klassert
We need to initialize the fallback device to have a correct mtu set on this device. Otherwise the mtu is set to null and the device is unusable. Fixes: fd58156e456d ("IPIP: Use ip-tunneling code.") Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter/nftables fixes for net The following patchset contains nftables fixes for your net tree, they are: 1) Fix crash when using the goto action in a rule by making sure that we always fall back on the base chain. Otherwise, this may try to access the counter memory area of non-base chains, which does not exists. 2) Fix several aspects of the rule tracing that are currently broken: * Reset rule number counter after goto/jump action, otherwise the tracing reports a bogus rule number. * Fix tracing of the goto action. * Fix bogus rule number counter after goto. * Fix missing return trace after finishing the walk through the non-base chain. * Fix missing trace when matching non-terminal rule. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-19Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
2014-05-16bonding: Fix stacked device detection in arp monitoringVlad Yasevich
Prior to commit fbd929f2dce460456807a51e18d623db3db9f077 bonding: support QinQ for bond arp interval the arp monitoring code allowed for proper detection of devices stacked on top of vlans. Since the above commit, the code can still detect a device stacked on top of single vlan, but not a device stacked on top of Q-in-Q configuration. The search will only set the inner vlan tag if the route device is the vlan device. However, this is not always the case, as it is possible to extend the stacked configuration. With this patch it is possible to provision devices on top Q-in-Q vlan configuration that should be used as a source of ARP monitoring information. For example: ip link add link bond0 vlan10 type vlan proto 802.1q id 10 ip link add link vlan10 vlan100 type vlan proto 802.1q id 100 ip link add link vlan100 type macvlan Note: This patch limites the number of stacked VLANs to 2, just like before. The original, however had another issue in that if we had more then 2 levels of VLANs, we would end up generating incorrectly tagged traffic. This is no longer possible. Fixes: fbd929f2dce460456807a51e18d623db3db9f077 (bonding: support QinQ for bond arp interval) CC: Jay Vosburgh <j.vosburgh@gmail.com> CC: Veaceslav Falico <vfalico@redhat.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: Ding Tianhong <dingtianhong@huawei.com> CC: Patric McHardy <kaber@trash.net> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16vlan: Fix lockdep warning with stacked vlan devices.Vlad Yasevich
This reverts commit dc8eaaa006350d24030502a4521542e74b5cb39f. vlan: Fix lockdep warning when vlan dev handle notification Instead we use the new new API to find the lock subclass of our vlan device. This way we can support configurations where vlans are interspersed with other devices: bond -> vlan -> macvlan -> vlan Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16net: Find the nesting level of a given device by type.Vlad Yasevich
Multiple devices in the kernel can be stacked/nested and they need to know their nesting level for the purposes of lockdep. This patch provides a generic function that determines a nesting level of a particular device by its type (ex: vlan, macvlan, etc). We only care about nesting of the same type of devices. For example: eth0 <- vlan0.10 <- macvlan0 <- vlan1.20 The nesting level of vlan1.20 would be 1, since there is another vlan in the stack under it. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16net: gro: make sure skb->cb[] initial content has not to be zeroEric Dumazet
Starting from linux-3.13, GRO attempts to build full size skbs. Problem is the commit assumed one particular field in skb->cb[] was clean, but it is not the case on some stacked devices. Timo reported a crash in case traffic is decrypted before reaching a GRE device. Fix this by initializing NAPI_GRO_CB(skb)->last at the right place, this also removes one conditional. Thanks a lot to Timo for providing full reports and bisecting this. Fixes: 8a29111c7ca6 ("net: gro: allow to build full sized skb") Bisected-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16ipv4: ip_tunnels: disable cache for nbma gre tunnelsTimo Teräs
The connected check fails to check for ip_gre nbma mode tunnels properly. ip_gre creates temporary tnl_params with daddr specified to pass-in the actual target on per-packet basis from neighbor layer. Detect these tunnels by inspecting the actual tunnel configuration. Minimal test case: ip route add 192.168.1.1/32 via 10.0.0.1 ip route add 192.168.1.2/32 via 10.0.0.2 ip tunnel add nbma0 mode gre key 1 tos c0 ip addr add 172.17.0.0/16 dev nbma0 ip link set nbma0 up ip neigh add 172.17.0.1 lladdr 192.168.1.1 dev nbma0 ip neigh add 172.17.0.2 lladdr 192.168.1.2 dev nbma0 ping 172.17.0.1 ping 172.17.0.2 The second ping should be going to 192.168.1.2 and head 10.0.0.2; but cached gre tunnel level route is used and it's actually going to 192.168.1.1 via 10.0.0.1. The lladdr's need to go to separate dst for the bug to trigger. Test case uses separate route entries, but this can also happen when the route entry is same: if there is a nexthop exception or the GRE tunnel is IPsec'ed in which case the dst points to xfrm bundle unique to the gre lladdr. Fixes: 7d442fab0a67 ("ipv4: Cache dst in tunnels") Signed-off-by: Timo Teräs <timo.teras@iki.fi> Cc: Tom Herbert <therbert@google.com> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16net/dsa/dsa.c: increment chip_index during of_node handling on dsa_of_probe()Fabian Godehardt
Adding more than one chip on device-tree currently causes the probing routine to always use the first chips data pointer. Signed-off-by: Fabian Godehardt <fg@emlix.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16net: ipv6: make "ip -6 route get mark xyz" work.Lorenzo Colitti
Currently, "ip -6 route get mark xyz" ignores the mark passed in by userspace. Make it honour the mark, just like IPv4 does. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16Merge tag 'batman-adv-fix-for-davem' of git://git.open-mesh.org/linux-mergeDavid S. Miller
Include changes: - fix NULL dereference in batadv_orig_hardif_seq_print_text() - fix reference counting imbalance when using fragmentation - avoid access to orig_node objects after they have been free'd - fix local TT check for outgoing arp requests in DAT
2014-05-16Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-05-15 Please pull this batch of fixes for the 3.15 stream... For the mac80211 bits, Johannes says: "One fix is to get better VHT performance and the other fixes tracing garbage or other potential issues with the interface name tracing." And... "This has a fix from Emmanuel for a problem I failed to fix - when association is in progress then it needs to be cancelled while suspending (I had fixed the same for authentication). Also included a fix from myself for a userspace API problem that hit the iw tool and a fix to the remain-on-channel framework." For the iwlwifi bits, Emmanuel says: "Alex fixes the scan by disabling the fragmented scan. David prevents scan offload while associated, the firmware seems not to like it. I fix a stupid bug I made in BT Coex, and fix a bad #ifdef clause in rate scaling. Along with that there is a fix for a NULL pointer exception that can happen if we load the driver and our ISR gets called because the interrupt line is shared. The fix has been tested by the reporter." And... "We have here a fix from David Spinadel that makes a previous fix more complete, and an off-by-one issue fixed by Eliad in the same area. I fix the monitor that broke on the way." Beyond that... Daniel Kim's one-liner fixes a brcmfmac regression caused by a typo in an earlier commit.. Rajkumar Manoharan fixes an ath9k oops reported by David Herrmann. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16af_rxrpc: Fix XDR length check in rxrpc key demarshalling.Nathaniel W Filardo
There may be padding on the ticket contained in the key payload, so just ensure that the claimed token length is large enough, rather than exactly the right size. Signed-off-by: Nathaniel Wesley Filardo <nwf@cs.jhu.edu> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16crush: decode and initialize chooseleaf_vary_rIlya Dryomov
Commit e2b149cc4ba0 ("crush: add chooseleaf_vary_r tunable") added the crush_map::chooseleaf_vary_r field but missed the decode part. This lead to misdirected requests caused by incorrect raw crush mapping sets. Fixes: http://tracker.ceph.com/issues/8226 Reported-and-Tested-by: Dmitry Smirnov <onlyjob@member.fsf.org> Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com>
2014-05-16libceph: fix corruption when using page_count 0 page in rbdChunwei Chen
It has been reported that using ZFSonLinux on rbd will result in memory corruption. The bug report can be found here: https://github.com/zfsonlinux/spl/issues/241 http://tracker.ceph.com/issues/7790 The reason is that ZFS will send pages with page_count 0 into rbd, which in turns send them to tcp_sendpage. However, tcp_sendpage cannot deal with page_count 0, as it will do get_page and put_page, and erroneously free the page. This type of issue has been noted before, and handled in iscsi, drbd, etc. So, rbd should also handle this. This fix address this issue by fall back to slower sendmsg when page_count 0 detected. Cc: Sage Weil <sage@inktank.com> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: stable@vger.kernel.org Signed-off-by: Chunwei Chen <tuxoko@gmail.com> Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
2014-05-15ipv6: update Destination Cache entries when gateway turn into hostDuan Jiong
RFC 4861 states in 7.2.5: The IsRouter flag in the cache entry MUST be set based on the Router flag in the received advertisement. In those cases where the IsRouter flag changes from TRUE to FALSE as a result of this update, the node MUST remove that router from the Default Router List and update the Destination Cache entries for all destinations using that neighbor as a router as specified in Section 7.3.3. This is needed to detect when a node that is used as a router stops forwarding packets due to being configured as a host. Currently, when dealing with NA Message which IsRouter flag changes from TRUE to FALSE, the kernel only removes router from the Default Router List, and don't update the Destination Cache entries. Now in order to update those Destination Cache entries, i introduce function rt6_clean_tohost(). Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Conflicts: net/ipv4/ip_vti.c Steffen Klassert says: ==================== pull request (net): ipsec 2014-05-15 This pull request has a merge conflict in net/ipv4/ip_vti.c between commit 8d89dcdf80d8 ("vti: don't allow to add the same tunnel twice") and commit a32452366b72 ("vti4:Don't count header length twice"). It can be solved like it is done in linux-next. 1) Fix a ipv6 xfrm output crash when a packet is rerouted by netfilter to not use IPsec. 2) vti4 counts some header lengths twice leading to an incorrect device mtu. Fix this by counting these headers only once. 3) We don't catch the case if an unsupported protocol is submitted to the xfrm protocol handlers, this can lead to NULL pointer dereferences. Fix this by adding the appropriate checks. 4) vti6 may unregister pernet ops twice on init errors. Fix this by removing one of the calls to do it only once. From Mathias Krause. 5) Set the vti tunnel mark before doing a lookup in the error handlers. Otherwise we don't find the correct xfrm state. ==================== The conflict in ip_vti.c was simple, 'net' had a commit removing a line from vti_tunnel_init() and this tree being merged had a commit adding a line to the same location. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15rtnetlink: wait for unregistering devices in rtnl_link_unregister()Cong Wang
From: Cong Wang <cwang@twopensource.com> commit 50624c934db18ab90 (net: Delay default_device_exit_batch until no devices are unregistering) introduced rtnl_lock_unregistering() for default_device_exit_batch(). Same race could happen we when rmmod a driver which calls rtnl_link_unregister() as we call dev->destructor without rtnl lock. For long term, I think we should clean up the mess of netdev_run_todo() and net namespce exit code. Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15batman-adv: fix local TT check for outgoing arp requests in DATAntonio Quartulli
Change introduced by 88e48d7b3340ef07b108eb8a8b3813dd093cc7f7 ("batman-adv: make DAT drop ARP requests targeting local clients") implements a check that prevents DAT from using the caching mechanism when the client that is supposed to provide a reply to an arp request is local. However change brought by be1db4f6615b5e6156c807ea8985171c215c2d57 ("batman-adv: make the Distributed ARP Table vlan aware") has not converted the above check into its vlan aware version thus making it useless when the local client is behind a vlan. Fix the behaviour by properly specifying the vlan when checking for a client being local or not. Reported-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-05-15batman-adv: increase orig refcount when storing ref in gw_nodeAntonio Quartulli
A pointer to the orig_node representing a bat-gateway is stored in the gw_node->orig_node member, but the refcount for such orig_node is never increased. This leads to memory faults when gw_node->orig_node is accessed and the originator has already been freed. Fix this by increasing the refcount on gw_node creation and decreasing it on gw_node free. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-05-15batman-adv: fix reference counting imbalance while sending fragmentAntonio Quartulli
In the new fragmentation code the batadv_frag_send_packet() function obtains a reference to the primary_if, but it does not release it upon return. This reference imbalance prevents the primary_if (and then the related netdevice) to be properly released on shut down. Fix this by releasing the primary_if in batadv_frag_send_packet(). Introduced by ee75ed88879af88558818a5c6609d85f60ff0df4 ("batman-adv: Fragment and send skbs larger than mtu") Cc: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Acked-by: Martin Hundebøll <martin@hundeboll.net>
2014-05-15batman-adv: fix indirect hard_iface NULL dereferenceMarek Lindner
If hard_iface is NULL and goto out is made batadv_hardif_free_ref() doesn't check for NULL before dereferencing it to get to refcount. Introduced in cb1c92ec37fb70543d133a1fa7d9b54d6f8a1ecd ("batman-adv: add debugfs support to view multiif tables"). Reported-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Acked-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-05-15netfilter: nf_tables: fix trace of matching non-terminal rulePablo Neira Ayuso
Add the corresponding trace if we have a full match in a non-terminal rule. Note that the traces will look slightly different than in x_tables since the log message after all expressions have been evaluated (contrary to x_tables, that emits it before the target action). This manifests in two differences in nf_tables wrt. x_tables: 1) The rule that enables the tracing is included in the trace. 2) If the rule emits some log message, that is shown before the trace log message. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-05-15Merge branch 'master' of ↵John W. Linville
2014-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211John W. Linville
2014-05-14af_iucv: wrong mapping of sent and confirmed skbsUrsula Braun
When sending data through IUCV a MESSAGE COMPLETE interrupt signals that sent data memory can be freed or reused again. With commit f9c41a62bba3f3f7ef3541b2a025e3371bcbba97 "af_iucv: fix recvmsg by replacing skb_pull() function" the MESSAGE COMPLETE callback iucv_callback_txdone() identifies the wrong skb as being confirmed, which leads to data corruption. This patch fixes the skb mapping logic in iucv_callback_txdone(). Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-14Bluetooth: Fix L2CAP LE debugfs entries permissionsSamuel Ortiz
0466 was probably meant to be 0644, there's no reason why everyone except root could write there. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Cc: stable@vger.kernel.org
2014-05-14mac80211: fix on-channel remain-on-channelJohannes Berg
Jouni reported that if a remain-on-channel was active on the same channel as the current operating channel, then the ROC would start, but any frames transmitted using mgmt-tx on the same channel would get delayed until after the ROC. The reason for this is that the ROC starts, but doesn't have any handling for "remain on the same channel", so it stops the interface queues. The later mgmt-tx then puts the frame on the interface queues (since it's on the current operating channel) and thus they get delayed until after the ROC. To fix this, add some logic to handle remaining on the same channel specially and not stop the queues etc. in this case. This not only fixes the bug but also improves behaviour in this case as data frames etc. can continue to flow. Cc: stable@vger.kernel.org Reported-by: Jouni Malinen <j@w1.fi> Tested-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
