commit 6b8d9117ccb4f81b1244aafa7bc70ef8fa45fc49 upstream.
The timeout entries are sizeof(int) rather than sizeof(long), which
means that when they were getting read we'd also leak kernel memory
to userspace along with the timeout values.
commit db27ebb111e9f69efece08e4cb6a34ff980f8896 upstream.
Max unacked packets/bytes is an int while sizeof(long) was used in the
sysctl table.
This means that when they were getting read we'd also leak kernel memory
Stable commit "core, nfqueue, openvswitch: Orphan frags in
skb_zerocopy and handle errors", upstream commit
36d5fe6a000790f56039afe26834265db0a3ad4c, was not correctly backported
and missed to change a const 'from' parameter to non-const. This
results in a new batch of warnings:
net/netfilter/nfnetlink_queue_core.c: In function ‘nfqnl_zcopy’:
net/netfilter/nfnetlink_queue_core.c:272:2: warning: passing argument 1 of ‘skb_orphan_frags’ discards ‘const’ qualifier from pointer target type [enabled by default]
if (unlikely(skb_orphan_frags(from, GFP_ATOMIC))) {
In file included from net/netfilter/nfnetlink_queue_core.c:18:0:
include/linux/skbuff.h:1822:19: note: expected ‘struct sk_buff *’ but argument is of type ‘const struct sk_buff *’
static inline int skb_orphan_frags(struct sk_buff *skb, gfp_t gfp_mask)
net/netfilter/nfnetlink_queue_core.c:273:3: warning: passing argument 1 of ‘skb_tx_error’ discards ‘const’ qualifier from pointer target type [enabled by default]
skb_tx_error(from);
include/linux/skbuff.h:630:13: note: expected ‘struct sk_buff *’ but argument is of type ‘const struct sk_buff *’
extern void skb_tx_error(struct sk_buff *skb);
Remove const from the 'from' parameter, the same as in the upstream
commit.
As far as I can see, this leaked into 3.10, 3.12, and 3.13 already.
Cc: Zoltan Kiss <zoltan.kiss@citrix.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Kamal Mostafa <kamal.mostafa@canonical.com>
Commit 355a901e6cf1 ("tcp: make connect() mem charging friendly")
changed tcp_send_syn_data() to perform an open-coded copy of the 'syn'
skb rather than using skb_copy_expand().
The open-coded copy does not cover the skb_shared_info::gso_segs
field, so in the new skb it is left set to 0. When this commit was
backported into stable branches between 3.10.y and 3.16.7-ckty
inclusive, it triggered the BUG() in tcp_transmit_skb().
Since Linux 3.18 the GSO segment count is kept in the
tcp_skb_cb::tcp_gso_segs field and tcp_send_syn_data() does copy the
tcp_skb_cb structure to the new skb, so mainline and newer stable
branches are not affected.
Set skb_shared_info::gso_segs to the correct value of 1.
commit d0c22119f574b851e63360c6b8660fe9593bbc3c upstream.
The mesh forwarding path was not checking that data
frames were protected when running an encrypted network;
add the necessary check.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit aa75ebc275b2a91b193654a177daf900ad6703f0 upstream.
Some APs experience problems when working with
U-APSD. Decreasing the probability of that
happening by using legacy mode for all ACs but VO
isn't enough.
Cisco 4410N originally forced us to enable VO by
default only because it treated non-VO ACs as
legacy.
However some APs (notably Netgear R7000) silently
reclassify packets to different ACs. Since u-APSD
ACs require trigger frames for frame retrieval
clients would never see some frames (e.g. ARP
responses) or would fetch them accidentally after
a long time.
It makes little sense to enable u-APSD queues by
default because it needs userspace applications to
be aware of it to actually take advantage of the
possible additional powersavings. Implicitly
depending on driver autotrigger frame support
doesn't make much sense.
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
commit 496fcc294daab18799e190c0264863d653588d1f upstream.
As HT/VHT depend heavily on QoS/WMM, it's not a good idea to
let userspace add clients that have HT/VHT but not QoS/WMM.
Since it does so in certain cases we've observed (client is
using HT IEs but not QoS/WMM) just ignore the HT/VHT info at
this point and don't pass it down to the drivers which might
unconditionally use it.
commit 579eb62ac35845686a7c4286c0a820b4eb1f96aa upstream.
commit f5a41847acc5 ("ipvs: move ip_route_me_harder for ICMP")
from 2.6.37 introduced ip_route_me_harder() call for responses to
local clients, so that we can provide valid rt_src after SNAT.
It was used by TCP to provide valid daddr for ip_send_reply().
After commit 0a5ebb8000c5 ("ipv4: Pass explicit daddr arg to
ip_send_reply()." from 3.0 this rerouting is not needed anymore
and should be avoided, especially in LOCAL_IN.
Fixes 3.12.33 crash in xfrm reported by Florian Wiessner:
"3.12.33 - BUG xfrm_selector_match+0x25/0x2f6"
Reported-by: Smart Weblications GmbH - Florian Wiessner <f.wiessner@smart-weblications.de>
Tested-by: Smart Weblications GmbH - Florian Wiessner <f.wiessner@smart-weblications.de>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit 528c943f3bb919aef75ab2fff4f00176f09a4019 upstream.
ip_vs_conn_fill_param_sync() gets in param.pe a module
reference for persistence engine from __ip_vs_pe_getbyname()
but forgets to put it. Problem occurs in backup for
sync protocol v1 (2.6.39).
Also, pe_data usually comes in sync messages for
connection templates and ip_vs_conn_new() copies
the pointer only in this case. Make sure pe_data
is not leaked if it comes unexpectedly for normal
connections. Leak can happen only if bogus messages
are sent to backup server.
Fixes: fe5e7a1efb66 ("IPVS: Backup, Adding Version 1 receive capability")
commit 969439016d2cf61fef53a973d7e6d2061c3793b1 upstream.
When accessing CAN network interfaces with AF_PACKET sockets e.g. by dhclient
this can lead to a skb_under_panic due to missing skb initialisations.
Add the missing initialisations at the CAN skbuff creation times on driver
level (rx path) and in the network layer (tx path).
Reported-by: Austin Schuh <austin@peloton-tech.com>
Reported-by: Daniel Steer <daniel.steer@mclaren.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit 355a901e6cf1b2b763ec85caa2a9f04fbcc4ab4a ]
While working on sk_forward_alloc problems reported by Denys
Fedoryshchenko, we found that tcp connect() (and fastopen) do not call
sk_wmem_schedule() for SYN packet (and/or SYN/DATA packet), so
sk_forward_alloc is negative while connect is in progress.
We can fix this by calling regular sk_stream_alloc_skb() both for the
SYN packet (in tcp_connect()) and the syn_data packet in
tcp_send_syn_data()
Then, tcp_send_syn_data() can avoid copying syn_data as we simply
can manipulate syn_data->cb[] to remove SYN flag (and increment seq)
Instead of open coding memcpy_fromiovecend(), simply use this helper.
This leaves in socket write queue clean fast clone skbs.
This was tested against our fastopen packetdrill tests.
Reported-by: Denys Fedoryshchenko <nuclearcat@nuclearcat.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
behaviour
[ Upstream commit 91edd096e224941131f896b86838b1e59553696a ]
Commit db31c55a6fb2 (net: clamp ->msg_namelen instead of returning an
error) introduced the clamping of msg_namelen when the unsigned value
was larger than sizeof(struct sockaddr_storage). This caused a
msg_namelen of -1 to be valid. The native code was subsequently fixed by
commit dbb490b96584 (net: socket: error on a negative msg_namelen).
In addition, the native code sets msg_namelen to 0 when msg_name is
NULL. This was done in commit (6a2a2b3ae075 net:socket: set msg_namelen
to 0 if msg_name is passed as NULL in msghdr struct from userland) and
subsequently updated by 08adb7dabd48 (fold verify_iovec() into
copy_msghdr_from_user()).
This patch brings the get_compat_msghdr() in line with
copy_msghdr_from_user().
Fixes: db31c55a6fb2 (net: clamp ->msg_namelen instead of returning an error)
Cc: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit d22e1537181188e5dc8cbc51451832625035bdc2 ]
tcp_send_fin() does not account for the memory it allocates properly, so
sk_forward_alloc can be negative in cases where we've sent a FIN:
ss example output (ss -amn | grep -B1 f4294):
tcp FIN-WAIT-1 0 1 192.168.0.1:45520 192.0.2.1:8080
skmem:(r0,rb87380,t0,tb87380,f4294966016,w1280,o0,bl0)
[ Upstream commit 7d985ed1dca5c90535d67ce92ef6ca520302340a ]
[I would really like an ACK on that one from dhowells; it appears to be
quite straightforward, but...]
MSG_PEEK isn't passed to ->recvmsg() via msg->msg_flags; as the matter of
fact, neither the kernel users of rxrpc, nor the syscalls ever set that bit
in there. It gets passed via flags; in fact, another such check in the same
function is done correctly - as flags & MSG_PEEK.
It had been that way (effectively disabled) for 8 years, though, so the patch
needs beating up - that case had never been tested. If it is correct, it's
-stable fodder.
[ Upstream commit 3eeff778e00c956875c70b145c52638c313dfb23 ]
It should be checking flags, not msg->msg_flags. It's ->sendmsg()
instances that need to look for that in ->msg_flags, ->recvmsg() ones
(including the other ->recvmsg() instance in that file, as well as
unix_dgram_recvmsg() this one claims to be imitating) check in flags.
Braino had been introduced in commit dcda13 ("caif: Bugfix - use MSG_TRUNC
in receive") back in 2010, so it goes quite a while back.
[ Upstream commit c8e2c80d7ec00d020320f905822bf49c5ad85250 ]
inet_diag_dump_one_icsk() allocates too small skb.
Add inet_sk_attr_size() helper right before inet_sk_diag_fill()
so that it can be updated if/when new attributes are added.
iproute2/ss currently does not use this dump_one() interface,
this might explain nobody noticed this problem yet.
[ Upstream commit f862e07cf95d5b62a5fc5e981dd7d0dbaf33a501 ]
The rds_iw_update_cm_id function stores a large 'struct rds_sock' object
on the stack in order to pass a pair of addresses. This happens to just
fit withint the 1024 byte stack size warning limit on x86, but just
exceed that limit on ARM, which gives us this warning:
net/rds/iw_rdma.c:200:1: warning: the frame size of 1056 bytes is larger than 1024 bytes [-Wframe-larger-than=]
As the use of this large variable is basically bogus, we can rearrange
the code to not do that. Instead of passing an rds socket into
rds_iw_get_device, we now just pass the two addresses that we have
available in rds_iw_update_cm_id, and we change rds_iw_get_mr accordingly,
to create two address structures on the stack there.
Acked-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
[ Upstream commit b1cb59cf2efe7971d3d72a7b963d09a512d994c9 ]
sysctl has sysctl.net.core.rmem_*/wmem_* parameters which can be
set to incorrect values. Given that 'struct sk_buff' allocates from
rcvbuf, incorrectly set buffer length could result to memory
allocation failures. For example, set them as follows:
# sysctl net.core.rmem_default=64
net.core.wmem_default = 64
# sysctl net.core.wmem_default=64
# ping localhost -s 1024 -i 0 > /dev/null
This could result to the following failure:
skbuff: skb_over_panic: text:ffffffff81628db4 len:-32 put:-32
head:ffff88003a1cc200 data:ffff88003a1cc200 tail:0xffffffe0 end:0xc0 dev:<NULL>
kernel BUG at net/core/skbuff.c:102!
invalid opcode: 0000 [#1] SMP
task: ffff88003b7f5550 ti: ffff88003ae88000 task.ti: ffff88003ae88000
RIP: 0010:[<ffffffff8155fbd1>] [<ffffffff8155fbd1>] skb_put+0xa1/0xb0
RSP: 0018:ffff88003ae8bc68 EFLAGS: 00010296
RAX: 000000000000008d RBX: 00000000ffffffe0 RCX: 0000000000000000
RDX: ffff88003fdcf598 RSI: ffff88003fdcd9c8 RDI: ffff88003fdcd9c8
RBP: ffff88003ae8bc88 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000001 R11: 00000000000002b2 R12: 0000000000000000
R13: 0000000000000000 R14: ffff88003d3f7300 R15: ffff88000012a900
FS: 00007fa0e2b4a840(0000) GS:ffff88003fc00000(0000) knlGS:0000000000000000
CR2: 0000000000d0f7e0 CR3: 000000003b8fb000 CR4: 00000000000006f0
Stack:
ffff88003a1cc200 00000000ffffffe0 00000000000000c0 ffffffff818cab1d
ffff88003ae8bd68 ffffffff81628db4 ffff88003ae8bd48 ffff88003b7f5550
ffff880031a09408 ffff88003b7f5550 ffff88000012aa48 ffff88000012ab00
Call Trace:
[<ffffffff81628db4>] unix_stream_sendmsg+0x2c4/0x470
[<ffffffff81556f56>] sock_write_iter+0x146/0x160
[<ffffffff811d9612>] new_sync_write+0x92/0xd0
[<ffffffff811d9cd6>] vfs_write+0xd6/0x180
[<ffffffff811da499>] SyS_write+0x59/0xd0
[<ffffffff81651532>] system_call_fastpath+0x12/0x17
Code: 00 00 48 89 44 24 10 8b 87 c8 00 00 00 48 89 44 24 08 48 8b 87 d8 00
00 00 48 c7 c7 30 db 91 81 48 89 04 24 31 c0 e8 4f a8 0e 00 <0f> 0b
eb fe 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 e5 48 83
RIP [<ffffffff8155fbd1>] skb_put+0xa1/0xb0
RSP <ffff88003ae8bc68>
Kernel panic - not syncing: Fatal exception
Moreover, the possible minimum is 1, so we can get another kernel panic:
BUG: unable to handle kernel paging request at ffff88013caee5c0
IP: [<ffffffff815604cf>] __alloc_skb+0x12f/0x1f0
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
commit 1711fd9addf214823b993468567cab1f8254fc51 upstream.
POLL_OUT isn't what callers of ->poll() are expecting to see; it's
actually __SI_POLL | 2 and it's a siginfo code, not a poll bitmap
bit...
Cc: Bruce Fields <bfields@fieldses.org>
commit 2c3fbe3cf28fbd7001545a92a83b4f8acfd9fa36 upstream.
In case an infinite timeout (0) is requested, the irda wait_until_sent
implementation would use a zero poll timeout rather than the default
200ms.
Note that wait_until_sent is currently never called with a 0-timeout
argument due to a bug in tty_wait_until_sent.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit acf8dd0a9d0b9e4cdb597c2f74802f79c699e802 ]
If an over-MTU UDP datagram is sent through a SOCK_RAW socket to a
UFO-capable device, ip_ufo_append_data() sets skb->ip_summed to
CHECKSUM_PARTIAL unconditionally as all GSO code assumes transport layer
checksum is to be computed on segmentation. However, in this case,
skb->csum_start and skb->csum_offset are never set as raw socket
transmit path bypasses udp_send_skb() where they are usually set. As a
result, driver may access invalid memory when trying to calculate the
checksum and store the result (as observed in virtio_net driver).
Moreover, the very idea of modifying the userspace provided UDP header
is IMHO against raw socket semantics (I wasn't able to find a document
clearly stating this or the opposite, though). And while allowing
CHECKSUM_NONE in the UFO case would be more efficient, it would be a bit
too intrusive change just to handle a corner case like this. Therefore
disallowing UFO for packets from SOCK_DGRAM seems to be the best option.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit d720d8cec563ce4e4fa44a613d4f2dcb1caf2998 ]
With commit a7526eb5d06b (net: Unbreak compat_sys_{send,recv}msg), the
MSG_CMSG_COMPAT flag is blocked at the compat syscall entry points,
changing the kernel compat behaviour from the one before the commit it
was trying to fix (1be374a0518a, net: Block MSG_CMSG_COMPAT in
send(m)msg and recv(m)msg).
On 32-bit kernels (!CONFIG_COMPAT), MSG_CMSG_COMPAT is 0 and the native
32-bit sys_sendmsg() allows flag 0x80000000 to be set (it is ignored by
the kernel). However, on a 64-bit kernel, the compat ABI is different
with commit a7526eb5d06b.
This patch changes the compat_sys_{send,recv}msg behaviour to the one
prior to commit 1be374a0518a.
The problem was found running 32-bit LTP (sendmsg01) binary on an arm64
kernel. Arguably, LTP should not pass 0xffffffff as flags to sendmsg()
but the general rule is not to break user ABI (even when the user
behaviour is not entirely sane).
Fixes: a7526eb5d06b (net: Unbreak compat_sys_{send,recv}msg)
[ Upstream commit a4176a9391868bfa87705bcd2e3b49e9b9dd2996 ]
colons are used as a separator in netdev device lookup in dev_ioctl.c
Specific functions are SIOCGIFTXQLEN SIOCETHTOOL SIOCSIFNAME
Signed-off-by: Matthew Thode <mthode@mthode.org>
[ Upstream commit 34eea79e2664b314cab6a30fc582fdfa7a1bb1df ]
In tcf_em_validate(), after calling request_module() to load the
kind-specific module, set em->ops to NULL before returning -EAGAIN, so
that module_put() is not called again by tcf_em_tree_destroy().
Signed-off-by: Ignacy Gawędzki <ignacy.gawedzki@green-communications.fr>
Acked-by: Cong Wang <cwang@twopensource.com>
[ Upstream commit 3e32e733d1bbb3f227259dc782ef01d5706bdae0 ]
ip_check_defrag() may be used by af_packet to defragment outgoing packets.
skb_network_offset() of af_packet's outgoing packets is not zero.
Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com>
[ Upstream commit fba04a9e0c869498889b6445fd06cbe7da9bb834 ]
skb_copy_bits() returns zero on success and negative value on error,
so it is needed to invert the condition in ip_check_defrag().
Fixes: 1bf3751ec90c ("ipv4: ip_check_defrag must not modify skb before unsharing")
[ Upstream commit 1c4cff0cf55011792125b6041bc4e9713e46240f ]
The gnet_stats_copy_app() function gets called, more often than not, with its
second argument a pointer to an automatic variable in the caller's stack.
Therefore, to avoid copying garbage afterwards when calling
gnet_stats_finish_copy(), this data is better copied to a dynamically allocated
memory that gets freed after use.
[xiyou.wangcong@gmail.com: remove a useless kfree()]
[ Upstream commit 7afb8886a05be68e376655539a064ec672de8a8e ]
Ignacy reported that when eth0 is down and add a vlan device
on top of it like:
ip link add link eth0 name eth0.1 up type vlan id 1
We will get a refcount leak:
unregister_netdevice: waiting for eth0.1 to become free. Usage count = 2
The problem is when rtnl_configure_link() fails in rtnl_newlink(),
we simply call unregister_device(), but for stacked device like vlan,
we almost do nothing when we unregister the upper device, more work
is done when we unregister the lower device, so call its ->dellink().
Reported-by: Ignacy Gawedzki <ignacy.gawedzki@green-communications.fr>
[ Upstream commit 3b4711757d7903ab6fa88a9e7ab8901b8227da60 ]
ipv6_cow_metrics() currently assumes only DST_HOST routes require
dynamic metrics allocation from inetpeer. The assumption breaks
when ndisc discovered router with RTAX_MTU and RTAX_HOPLIMIT metric.
Refer to ndisc_router_discovery() in ndisc.c and note that dst_metric_set()
is called after the route is created.
This patch creates the metrics array (by calling dst_cow_metrics_generic) in
ipv6_cow_metrics().
Test:
radvd.conf:
interface qemubr0
AdvLinkMTU 1300;
AdvCurHopLimit 30;
prefix fd00:face:face:face::/64
AdvOnLink on;
AdvAutonomous on;
AdvRouterAddr off;
Before:
[root@qemu1 ~]# ip -6 r show | egrep -v unreachable
fd00:face:face:face::/64 dev eth0 proto kernel metric 256 expires 27sec
fe80::/64 dev eth0 proto kernel metric 256
default via fe80::74df:d0ff:fe23:8ef2 dev eth0 proto ra metric 1024 expires 27sec
After:
fd00:face:face:face::/64 dev eth0 proto kernel metric 256 expires 27sec mtu 1300
fe80::/64 dev eth0 proto kernel metric 256 mtu 1300
default via fe80::74df:d0ff:fe23:8ef2 dev eth0 proto ra metric 1024 expires 27sec mtu 1300 hoplimit 30
Fixes: 8e2ec639173f325 (ipv6: don't use inetpeer to store metrics for routes.)
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit 364d5716a7adb91b731a35765d369602d68d2881 ]
ifla_vf_policy[] is wrong in advertising its individual member types as
NLA_BINARY since .type = NLA_BINARY in combination with .len declares the
len member as *max* attribute length [0, len].
The issue is that when do_setvfinfo() is being called to set up a VF
through ndo handler, we could set corrupted data if the attribute length
is less than the size of the related structure itself.
The intent is exactly the opposite, namely to make sure to pass at least
data of minimum size of len.
Fixes: ebc08a6f47ee ("rtnetlink: Add VF config code to rtnetlink")
Cc: Mitch Williams <mitch.a.williams@intel.com>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Thomas Graf <tgraf@suug.ch>
commit 7eb71e0351fbb1b242ae70abb7bb17107fe2f792 upstream.
It turns out it's possible to get __remove_osd() called twice on the
same OSD. That doesn't sit well with rb_erase() - depending on the
shape of the tree we can get a NULL dereference, a soft lockup or
a random crash at some point in the future as we end up touching freed
memory. One scenario that I was able to reproduce is as follows:
<osd3 is idle, on the osd lru list>
<con reset - osd3>
con_fault_finish()
osd_reset()
<osdmap - osd3 down>
ceph_osdc_handle_map()
<takes map_sem>
kick_requests()
<takes request_mutex>
reset_changed_osds()
__reset_osd()
__remove_osd()
<releases request_mutex>
<releases map_sem>
<takes map_sem>
__kick_osd_requests()
__reset_osd()
__remove_osd() <-- !!!
A case can be made that osd refcounting is imperfect and reworking it
would be a proper resolution, but for now Sage and I decided to fix
this by adding a safe guard around __remove_osd().
Fixes: http://tracker.ceph.com/issues/8087
Cc: Sage Weil <sage@redhat.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Sage Weil <sage@redhat.com>
Reviewed-by: Alex Elder <elder@linaro.org>
commit cc9f1f518cec079289d11d732efa490306b1ddad upstream.
No reason to use BUG_ON for osd request list assertions.
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
commit 7c6e6fc53e7335570ed82f77656cedce1502744e upstream.
It is important that both regular and lingering requests lists are
empty when the OSD is removed.
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
sctp_process_param
[ Upstream commit cfbf654efc6d78dc9812e030673b86f235bf677d ]
When making use of RFC5061, section 4.2.4. for setting the primary IP
address, we're passing a wrong parameter header to param_type2af(),
resulting always in NULL being returned.
At this point, param.p points to a sctp_addip_param struct, containing
a sctp_paramhdr (type = 0xc004, length = var), and crr_id as a correlation
id. Followed by that, as also presented in RFC5061 section 4.2.4., comes
the actual sctp_addr_param, which also contains a sctp_paramhdr, but
this time with the correct type SCTP_PARAM_IPV{4,6}_ADDRESS that
param_type2af() can make use of. Since we already hold a pointer to
addr_param from previous line, just reuse it for param_type2af().
Fixes: d6de3097592b ("[SCTP]: Add the handling of "Set Primary IP Address" parameter to INIT")
Signed-off-by: Saran Maruti Ramanara <saran.neti@telus.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit bdbbb8527b6f6a358dbcb70dac247034d665b8e4 ]
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock")
I tried to address contention on a socket lock, but the solution
I chose was horrible :
commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside
of TCP stack") addressed a selinux regression.
commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1")
took care of another regression.
commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression.
commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate")
was another shot in the dark.
Really, just use a proper socket per cpu, and remove the skb_orphan()
call, to re-enable flow control.
This solves a serious problem with FQ packet scheduler when used in
hostile environments, as we do not want to allocate a flow structure
for every RST packet sent in response to a spoofed packet.
[ Upstream commit 811230cd853d62f09ed0addd0ce9a1b9b0e13fb5 ]
When I added sk_pacing_rate field, I forgot to initialize its value
in the per cpu unicast_sock used in ip_send_unicast_reply()
This means that for sch_fq users, RST packets, or ACK packets sent
on behalf of TIME_WAIT sockets might be sent to slowly or even dropped
once we reach the per flow limit.
Fixes: 95bd09eb2750 ("tcp: TSO packets automatic sizing")
[ Upstream commit 59ccaaaa49b5b096cdc1f16706a9f931416b2332 ]
Reported in: https://bugzilla.kernel.org/show_bug.cgi?id=92081
This patch avoids calling rtnl_notify if the device ndo_bridge_getlink
handler does not return any bytes in the skb.
Alternately, the skb->len check can be moved inside rtnl_notify.
For the bridge vlan case described in 92081, there is also a fix needed
in bridge driver to generate a proper notification. Will fix that in
subsequent patch.
v2: rebase patch on net tree
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
[ Upstream commit 6e9e16e6143b725662e47026a1d0f270721cdd24 ]
Lubomir Rintel reported that during replacing a route the interface
reference counter isn't correctly decremented.
To quote bug <https://bugzilla.kernel.org/show_bug.cgi?id=91941>:
| [root@rhel7-5 lkundrak]# sh -x lal
| + ip link add dev0 type dummy
| + ip link set dev0 up
| + ip link add dev1 type dummy
| + ip link set dev1 up
| + ip addr add 2001:db8:8086::2/64 dev dev0
| + ip route add 2001:db8:8086::/48 dev dev0 proto static metric 20
| + ip route add 2001:db8:8088::/48 dev dev1 proto static metric 10
| + ip route replace 2001:db8:8086::/48 dev dev1 proto static metric 20
| + ip link del dev0 type dummy
| Message from syslogd@rhel7-5 at Jan 23 10:54:41 ...
| kernel:unregister_netdevice: waiting for dev0 to become free. Usage count = 2
| Message from syslogd@rhel7-5 at Jan 23 10:54:51 ...
During replacement of a rt6_info we must walk all parent nodes and check
if the to be replaced rt6_info got propagated. If so, replace it with
an alive one.
Fixes: 4a287eba2de3957 ("IPv6 routing, NLM_F_* flag support: REPLACE and EXCL flags support, warn about missing CREATE flag")
Reported-by: Lubomir Rintel <lkundrak@v3.sk>
Tested-by: Lubomir Rintel <lkundrak@v3.sk>
[ Upstream commit fc752f1f43c1c038a2c6ae58cc739ebb5953ccb0 ]
An exception is seen in ICMP ping receive path where the skb
destructor sock_rfree() tries to access a freed socket. This happens
because ping_rcv() releases socket reference with sock_put() and this
internally frees up the socket. Later icmp_rcv() will try to free the
skb and as part of this, skb destructor is called and which leads
to a kernel panic as the socket is freed already in ping_rcv().
-->|exception
-007|sk_mem_uncharge
-007|sock_rfree
-008|skb_release_head_state
-009|skb_release_all
-009|__kfree_skb
-010|kfree_skb
-011|icmp_rcv
-012|ip_local_deliver_finish
Fix this incorrect free by cloning this skb and processing this cloned
skb instead.
This patch was suggested by Eric Dumazet
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Eric Dumazet <edumazet@google.com>
[ Upstream commit 86f3cddbc3037882414c7308973530167906b7e9 ]
While working on rhashtable walking I noticed that the UDP diag
dumping code is buggy. In particular, the socket skipping within
a chain never happens, even though we record the number of sockets
that should be skipped.
As this code was supposedly copied from TCP, this patch does what
TCP does and resets num before we walk a chain.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
[ Upstream commit df4d92549f23e1c037e83323aff58a21b3de7fe0 ]
Not caching dst_entries which cause redirects could be exploited by hosts
on the same subnet, causing a severe DoS attack. This effect aggravated
since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()").
Lookups causing redirects will be allocated with DST_NOCACHE set which
will force dst_release to free them via RCU. Unfortunately waiting for
RCU grace period just takes too long, we can end up with >1M dst_entries
waiting to be released and the system will run OOM. rcuos threads cannot
catch up under high softirq load.
Attaching the flag to emit a redirect later on to the specific skb allows
us to cache those dst_entries thus reducing the pressure on allocation
and deallocation.
This issue was discovered by Marcelo Leitner.
Cc: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Marcelo Leitner <mleitner@redhat.com>
[ Upstream commit 600ddd6825543962fb807884169e57b580dba208 ]
When hitting an INIT collision case during the 4WHS with AUTH enabled, as
already described in detail in commit 1be9a950c646 ("net: sctp: inherit
auth_capable on INIT collisions"), it can happen that we occasionally
still remotely trigger the following panic on server side which seems to
have been uncovered after the fix from commit 1be9a950c646 ...
[ 533.876389] BUG: unable to handle kernel paging request at 00000000ffffffff
[ 533.913657] IP: [<ffffffff811ac385>] __kmalloc+0x95/0x230
[ 533.940559] PGD 5030f2067 PUD 0
[ 533.957104] Oops: 0000 [#1] SMP
[ 533.974283] Modules linked in: sctp mlx4_en [...]
[ 534.939704] Call Trace:
[ 534.951833] [<ffffffff81294e30>] ? crypto_init_shash_ops+0x60/0xf0
[ 534.984213] [<ffffffff81294e30>] crypto_init_shash_ops+0x60/0xf0
[ 535.015025] [<ffffffff8128c8ed>] __crypto_alloc_tfm+0x6d/0x170
[ 535.045661] [<ffffffff8128d12c>] crypto_alloc_base+0x4c/0xb0
[ 535.074593] [<ffffffff8160bd42>] ? _raw_spin_lock_bh+0x12/0x50
[ 535.105239] [<ffffffffa0418c11>] sctp_inet_listen+0x161/0x1e0 [sctp]
[ 535.138606] [<ffffffff814e43bd>] SyS_listen+0x9d/0xb0
[ 535.166848] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b
... or depending on the the application, for example this one:
[ 1370.026490] BUG: unable to handle kernel paging request at 00000000ffffffff
[ 1370.026506] IP: [<ffffffff811ab455>] kmem_cache_alloc+0x75/0x1d0
[ 1370.054568] PGD 633c94067 PUD 0
[ 1370.070446] Oops: 0000 [#1] SMP
[ 1370.085010] Modules linked in: sctp kvm_amd kvm [...]
[ 1370.963431] Call Trace:
[ 1370.974632] [<ffffffff8120f7cf>] ? SyS_epoll_ctl+0x53f/0x960
[ 1371.000863] [<ffffffff8120f7cf>] SyS_epoll_ctl+0x53f/0x960
[ 1371.027154] [<ffffffff812100d3>] ? anon_inode_getfile+0xd3/0x170
[ 1371.054679] [<ffffffff811e3d67>] ? __alloc_fd+0xa7/0x130
[ 1371.080183] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b
With slab debugging enabled, we can see that the poison has been overwritten:
[ 669.826368] BUG kmalloc-128 (Tainted: G W ): Poison overwritten
[ 669.826385] INFO: 0xffff880228b32e50-0xffff880228b32e50. First byte 0x6a instead of 0x6b
[ 669.826414] INFO: Allocated in sctp_auth_create_key+0x23/0x50 [sctp] age=3 cpu=0 pid=18494
[ 669.826424] __slab_alloc+0x4bf/0x566
[ 669.826433] __kmalloc+0x280/0x310
[ 669.826453] sctp_auth_create_key+0x23/0x50 [sctp]
[ 669.826471] sctp_auth_asoc_create_secret+0xcb/0x1e0 [sctp]
[ 669.826488] sctp_auth_asoc_init_active_key+0x68/0xa0 [sctp]
[ 669.826505] sctp_do_sm+0x29d/0x17c0 [sctp] [...]
[ 669.826629] INFO: Freed in kzfree+0x31/0x40 age=1 cpu=0 pid=18494
[ 669.826635] __slab_free+0x39/0x2a8
[ 669.826643] kfree+0x1d6/0x230
[ 669.826650] kzfree+0x31/0x40
[ 669.826666] sctp_auth_key_put+0x19/0x20 [sctp]
[ 669.826681] sctp_assoc_update+0x1ee/0x2d0 [sctp]
[ 669.826695] sctp_do_sm+0x674/0x17c0 [sctp]
Since this only triggers in some collision-cases with AUTH, the problem at
heart is that sctp_auth_key_put() on asoc->asoc_shared_key is called twice
when having refcnt 1, once directly in sctp_assoc_update() and yet again
from within sctp_auth_asoc_init_active_key() via sctp_assoc_update() on
the already kzfree'd memory, which is also consistent with the observation
of the poison decrease from 0x6b to 0x6a (note: the overwrite is detected
at a later point in time when poison is checked on new allocation).
Reference counting of auth keys revisited:
Shared keys for AUTH chunks are being stored in endpoints and associations
in endpoint_shared_keys list. On endpoint creation, a null key is being
added; on association creation, all endpoint shared keys are being cached
and thus cloned over to the association. struct sctp_shared_key only holds
a pointer to the actual key bytes, that is, struct sctp_auth_bytes which
keeps track of users internally through refcounting. Naturally, on assoc
or enpoint destruction, sctp_shared_key are being destroyed directly and
the reference on sctp_auth_bytes dropped.
User space can add keys to either list via setsockopt(2) through struct
sctp_authkey and by passing that to sctp_auth_set_key() which replaces or
adds a new auth key. There, sctp_auth_create_key() creates a new sctp_auth_bytes
with refcount 1 and in case of replacement drops the reference on the old
sctp_auth_bytes. A key can be set active from user space through setsockopt()
on the id via sctp_auth_set_active_key(), which iterates through either
endpoint_shared_keys and in case of an assoc, invokes (one of various places)
sctp_auth_asoc_init_active_key().
sctp_auth_asoc_init_active_key() computes the actual secret from local's
and peer's random, hmac and shared key parameters and returns a new key
directly as sctp_auth_bytes, that is asoc->asoc_shared_key, plus drops
the reference if there was a previous one. The secret, which where we
eventually double drop the ref comes from sctp_auth_asoc_set_secret() with
intitial refcount of 1, which also stays unchanged eventually in
sctp_assoc_update(). This key is later being used for crypto layer to
set the key for the hash in crypto_hash_setkey() from sctp_auth_calculate_hmac().
To close the loop: asoc->asoc_shared_key is freshly allocated secret
material and independant of the sctp_shared_key management keeping track
of only shared keys in endpoints and assocs. Hence, also commit 4184b2a79a76
("net: sctp: fix memory leak in auth key management") is independant of
this bug here since it concerns a different layer (though same structures
being used eventually). asoc->asoc_shared_key is reference dropped correctly
on assoc destruction in sctp_association_free() and when active keys are
being replaced in sctp_auth_asoc_init_active_key(), it always has a refcount
of 1. Hence, it's freed prematurely in sctp_assoc_update(). Simple fix is
to remove that sctp_auth_key_put() from there which fixes these panics.
Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing")
[ Upstream commit 9d289715eb5c252ae15bd547cb252ca547a3c4f2 ]
Reduce the attack vector and stop generating IPv6 Fragment Header for
paths with an MTU smaller than the minimum required IPv6 MTU
size (1280 byte) - called atomic fragments.
See IETF I-D "Deprecating the Generation of IPv6 Atomic Fragments" [1]
for more information and how this "feature" can be misused.
[1] https://tools.ietf.org/html/draft-ietf-6man-deprecate-atomfrag-generation-00
Signed-off-by: Fernando Gont <fgont@si6networks.com>
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit ac64da0b83d82abe62f78b3d0e21cca31aea24fa ]
softnet_data.input_pkt_queue is protected by a spinlock that
we must hold when transferring packets from victim queue to an active
one. This is because other cpus could still be trying to enqueue packets
into victim queue.
A second problem is that when we transfert the NAPI poll_list from
victim to current cpu, we absolutely need to special case the percpu
backlog, because we do not want to add complex locking to protect
process_queue : Only owner cpu is allowed to manipulate it, unless cpu
is offline.
Based on initial patch from Prasad Sodagudi & Subash Abhinov
Kasiviswanathan.
This version is better because we do not slow down packet processing,
only make migration safer.
Reported-by: Prasad Sodagudi <psodagud@codeaurora.org>
Reported-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Tom Herbert <therbert@google.com>
[ Upstream commit f812116b174e59a350acc8e4856213a166a91222 ]
The sockaddr is returned in IP(V6)_RECVERR as part of errhdr. That
structure is defined and allocated on the stack as
struct {
struct sock_extended_err ee;
struct sockaddr_in(6) offender;
} errhdr;
The second part is only initialized for certain SO_EE_ORIGIN values.
Always initialize it completely.
An MTU exceeded error on a SOCK_RAW/IPPROTO_RAW is one example that
would return uninitialized bytes.
Signed-off-by: Willem de Bruijn <willemb@google.com>
Also verified that there is no padding between errhdr.ee and
errhdr.offender that could leak additional kernel data.
commit 0fa7b39131576dd1baa6ca17fca53c65d7f62249 upstream.
In case userspace attempts to obtain key information for or delete a
unicast key, this is currently erroneously rejected unless the driver
sets the WIPHY_FLAG_IBSS_RSN flag. Apparently enough drivers do so it
was never noticed.
Fix that, and while at it fix a potential memory leak: the error path
in the get_key() function was placed after allocating a message but
didn't free it - move it to a better place. Luckily admin permissions
are needed to call this operation.
Fixes: e31b82136d1ad ("cfg80211/mac80211: allow per-station GTKs")
commit 3b05ac3824ed9648c0d9c02d51d9b54e4e7e874f upstream.
The app_tcp_pkt_out() function expects "*diff" to be set and ends up
using uninitialized data if CONFIG_IP_VS_IPV6 is turned on.
The same issue is there in app_tcp_pkt_in(). Thanks to Julian Anastasov
for noticing that.
Acked-by: Julian Anastasov <ja@ssi.bg>
commit 2196937e12b1b4ba139806d132647e1651d655df upstream.
We could be reading 8 bytes into a 4 byte buffer here. It seems
harmless but adding a check is the right thing to do and it silences a
static checker warning.
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
commit 08f6f147773b23b765b94633a8eaa82e7defcf4c upstream.
The VHT supported channel width field is a two bit integer, not a
bitfield. cfg80211_chandef_usable() was interpreting it incorrectly and
ended up rejecting 160 MHz channel width if the driver indicated support
for both 160 and 80+80 MHz channels.
Fixes: 3d9d1d6656a73 ("nl80211/cfg80211: support VHT channel configuration")
(however, no real drivers had 160 MHz support it until 3.16)
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
[ Upstream commit 843925f33fcc293d80acf2c5c8a78adf3344d49b ]
Thomas Jarosch reported IPsec TCP stalls when a PMTU event occurs.
In fact the problem was completely unrelated to IPsec. The bug is
also reproducible if you just disable TSO/GSO.
The problem is that when the MSS goes down, existing queued packet
on the TX queue that have not been transmitted yet all look like
TSO packets and get treated as such.
This then triggers a bug where tcp_mss_split_point tells us to
generate a zero-sized packet on the TX queue. Once that happens
we're screwed because the zero-sized packet can never be removed
by ACKs.
Fixes: 1485348d242 ("tcp: Apply device TSO segment limit earlier")
Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Cheers,
