path: root/net
2015-07-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Must teardown SR-IOV before unregistering netdev in igb driver, from Alex Williamson. 2) Fix ipv6 route unreachable crash in IPVS, from Alex Gartrell. 3) Default route selection in ipv4 should take the prefix length, table ID, and TOS into account, from Julian Anastasov. 4) sch_plug must have a reset method in order to purge all buffered packets when the qdisc is reset, likewise for sch_choke, from WANG Cong. 5) Fix deadlock and races in slave_changelink/br_setport in bridging. From Nikolay Aleksandrov. 6) mlx4 bug fixes (wrong index in port even propagation to VFs, overzealous BUG_ON assertion, etc.) from Ido Shamay, Jack Morgenstein, and Or Gerlitz. 7) Turn off klog message about SCTP userspace interface compat that makes no sense at all, from Daniel Borkmann. 8) Fix unbounded restarts of inet frag eviction process, causing NMI watchdog soft lockup messages, from Florian Westphal. 9) Suspend/resume fixes for r8152 from Hayes Wang. 10) Fix busy loop when MSG_WAITALL|MSG_PEEK is used in TCP recv, from Sabrina Dubroca. 11) Fix performance regression when removing a lot of routes from the ipv4 routing tables, from Alexander Duyck. 12) Fix device leak in AF_PACKET, from Lars Westerhoff. 13) AF_PACKET also has a header length comparison bug due to signedness, from Alexander Drozdov. 14) Fix bug in EBPF tail call generation on x86, from Daniel Borkmann. 15) Memory leaks, TSO stats, watchdog timeout and other fixes to thunderx driver from Sunil Goutham and Thanneeru Srinivasulu. 16) act_bpf can leak memory when replacing programs, from Daniel Borkmann. 17) WOL packet fixes in gianfar driver, from Claudiu Manoil. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (79 commits) stmmac: fix missing MODULE_LICENSE in stmmac_platform gianfar: Enable device wakeup when appropriate gianfar: Fix suspend/resume for wol magic packet gianfar: Fix warning when CONFIG_PM off act_pedit: check binding before calling tcf_hash_release() net: sk_clone_lock() should only do get_net() if the parent is not a kernel socket net: sched: fix refcount imbalance in actions r8152: reset device when tx timeout r8152: add pre_reset and post_reset qlcnic: Fix corruption while copying act_bpf: fix memory leaks when replacing bpf programs net: thunderx: Fix for crash while BGX teardown net: thunderx: Add PCI driver shutdown routine net: thunderx: Fix crash when changing rss with mutliple traffic flows net: thunderx: Set watchdog timeout value net: thunderx: Wakeup TXQ only if CQE_TX are processed net: thunderx: Suppress alloc_pages() failure warnings net: thunderx: Fix TSO packet statistic net: thunderx: Fix memory leak when changing queue count net: thunderx: Fix RQ_DROP miscalculation ...
2015-07-31act_pedit: check binding before calling tcf_hash_release()WANG Cong
When we share an action within a filter, the bind refcnt should increase, therefore we should not call tcf_hash_release(). Fixes: 1a29321ed045 ("net_sched: act: Dont increment refcnt on replace") Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Cong Wang <cwang@twopensource.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-30net: sk_clone_lock() should only do get_net() if the parent is not a kernel ↵Sowmini Varadhan
socket The newsk returned by sk_clone_lock should hold a get_net() reference if, and only if, the parent is not a kernel socket (making this similar to sk_alloc()). E.g,. for the SYN_RECV path, tcp_v4_syn_recv_sock->..inet_csk_clone_lock sets up the syn_recv newsk from sk_clone_lock. When the parent (listen) socket is a kernel socket (defined in sk_alloc() as having sk_net_refcnt == 0), then the newsk should also have a 0 sk_net_refcnt and should not hold a get_net() reference. Fixes: 26abe14379f8 ("net: Modify sk_alloc to not reference count the netns of kernel sockets.") Acked-by: Eric Dumazet <edumazet@google.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-30net: sched: fix refcount imbalance in actionsDaniel Borkmann
Since commit 55334a5db5cd ("net_sched: act: refuse to remove bound action outside"), we end up with a wrong reference count for a tc action. Test case 1: FOO="1,6 0 0 4294967295," BAR="1,6 0 0 4294967294," tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 \ action bpf bytecode "$FOO" tc actions show action bpf action order 0: bpf bytecode '1,6 0 0 4294967295' default-action pipe index 1 ref 1 bind 1 tc actions replace action bpf bytecode "$BAR" index 1 tc actions show action bpf action order 0: bpf bytecode '1,6 0 0 4294967294' default-action pipe index 1 ref 2 bind 1 tc actions replace action bpf bytecode "$FOO" index 1 tc actions show action bpf action order 0: bpf bytecode '1,6 0 0 4294967295' default-action pipe index 1 ref 3 bind 1 Test case 2: FOO="1,6 0 0 4294967295," tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 action ok tc actions show action gact action order 0: gact action pass random type none pass val 0 index 1 ref 1 bind 1 tc actions add action drop index 1 RTNETLINK answers: File exists [...] tc actions show action gact action order 0: gact action pass random type none pass val 0 index 1 ref 2 bind 1 tc actions add action drop index 1 RTNETLINK answers: File exists [...] tc actions show action gact action order 0: gact action pass random type none pass val 0 index 1 ref 3 bind 1 What happens is that in tcf_hash_check(), we check tcf_common for a given index and increase tcfc_refcnt and conditionally tcfc_bindcnt when we've found an existing action. Now there are the following cases: 1) We do a late binding of an action. In that case, we leave the tcfc_refcnt/tcfc_bindcnt increased and are done with the ->init() handler. This is correctly handeled. 2) We replace the given action, or we try to add one without replacing and find out that the action at a specific index already exists (thus, we go out with error in that case). In case of 2), we have to undo the reference count increase from tcf_hash_check() in the tcf_hash_check() function. Currently, we fail to do so because of the 'tcfc_bindcnt > 0' check which bails out early with an -EPERM error. Now, while commit 55334a5db5cd prevents 'tc actions del action ...' on an already classifier-bound action to drop the reference count (which could then become negative, wrap around etc), this restriction only accounts for invocations outside a specific action's ->init() handler. One possible solution would be to add a flag thus we possibly trigger the -EPERM ony in situations where it is indeed relevant. After the patch, above test cases have correct reference count again. Fixes: 55334a5db5cd ("net_sched: act: refuse to remove bound action outside") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Reviewed-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-29act_bpf: fix memory leaks when replacing bpf programsDaniel Borkmann
We currently trigger multiple memory leaks when replacing bpf actions, besides others: comm "tc", pid 1909, jiffies 4294851310 (age 1602.796s) hex dump (first 32 bytes): 01 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 ................ 18 b0 98 6d 00 88 ff ff 00 00 00 00 00 00 00 00 ...m............ backtrace: [<ffffffff817e623e>] kmemleak_alloc+0x4e/0xb0 [<ffffffff8120a22d>] __vmalloc_node_range+0x1bd/0x2c0 [<ffffffff8120a37a>] __vmalloc+0x4a/0x50 [<ffffffff811a8d0a>] bpf_prog_alloc+0x3a/0xa0 [<ffffffff816c0684>] bpf_prog_create+0x44/0xa0 [<ffffffffa09ba4eb>] tcf_bpf_init+0x28b/0x3c0 [act_bpf] [<ffffffff816d7001>] tcf_action_init_1+0x191/0x1b0 [<ffffffff816d70a2>] tcf_action_init+0x82/0xf0 [<ffffffff816d4d12>] tcf_exts_validate+0xb2/0xc0 [<ffffffffa09b5838>] cls_bpf_modify_existing+0x98/0x340 [cls_bpf] [<ffffffffa09b5cd6>] cls_bpf_change+0x1a6/0x274 [cls_bpf] [<ffffffff816d56e5>] tc_ctl_tfilter+0x335/0x910 [<ffffffff816b9145>] rtnetlink_rcv_msg+0x95/0x240 [<ffffffff816df34f>] netlink_rcv_skb+0xaf/0xc0 [<ffffffff816b909e>] rtnetlink_rcv+0x2e/0x40 [<ffffffff816deaaf>] netlink_unicast+0xef/0x1b0 Issue is that the old content from tcf_bpf is allocated and needs to be released when we replace it. We seem to do that since the beginning of act_bpf on the filter and insns, later on the name as well. Example test case, after patch: # FOO="1,6 0 0 4294967295," # BAR="1,6 0 0 4294967294," # tc actions add action bpf bytecode "$FOO" index 2 # tc actions show action bpf action order 0: bpf bytecode '1,6 0 0 4294967295' default-action pipe index 2 ref 1 bind 0 # tc actions replace action bpf bytecode "$BAR" index 2 # tc actions show action bpf action order 0: bpf bytecode '1,6 0 0 4294967294' default-action pipe index 2 ref 1 bind 0 # tc actions replace action bpf bytecode "$FOO" index 2 # tc actions show action bpf action order 0: bpf bytecode '1,6 0 0 4294967295' default-action pipe index 2 ref 1 bind 0 # tc actions del action bpf index 2 [...] # echo "scan" > /sys/kernel/debug/kmemleak # cat /sys/kernel/debug/kmemleak | grep "comm \"tc\"" | wc -l 0 Fixes: d23b8ad8ab23 ("tc: add BPF based action") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-29ipv6: flush nd cache on IFF_NOARP changeEric Dumazet
This patch is the IPv6 equivalent of commit 6c8b4e3ff81b ("arp: flush arp cache on IFF_NOARP change") Without it, we keep buggy neighbours in the cache, with destination MAC address equal to our own MAC address. Tested: tcpdump -i eth0 -s 0 ip6 -n -e & ip link set dev eth0 arp off ping6 remote // sends buggy frames ip link set dev eth0 arp on ping6 remote // should work once kernel is patched Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Mario Fanelli <mariofanelli@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-29bridge: mdb: fix delmdb state in the notificationNikolay Aleksandrov
Since mdb states were introduced when deleting an entry the state was left as it was set in the delete request from the user which leads to the following output when doing a monitor (for example): $ bridge mdb add dev br0 port eth3 grp 239.0.0.1 permanent (monitor) dev br0 port eth3 grp 239.0.0.1 permanent $ bridge mdb del dev br0 port eth3 grp 239.0.0.1 permanent (monitor) dev br0 port eth3 grp 239.0.0.1 temp ^^^ Note the "temp" state in the delete notification which is wrong since the entry was permanent, the state in a delete is always reported as "temp" regardless of the real state of the entry. After this patch: $ bridge mdb add dev br0 port eth3 grp 239.0.0.1 permanent (monitor) dev br0 port eth3 grp 239.0.0.1 permanent $ bridge mdb del dev br0 port eth3 grp 239.0.0.1 permanent (monitor) dev br0 port eth3 grp 239.0.0.1 permanent There's one important note to make here that the state is actually not matched when doing a delete, so one can delete a permanent entry by stating "temp" in the end of the command, I've chosen this fix in order not to break user-space tools which rely on this (incorrect) behaviour. So to give an example after this patch and using the wrong state: $ bridge mdb add dev br0 port eth3 grp 239.0.0.1 permanent (monitor) dev br0 port eth3 grp 239.0.0.1 permanent $ bridge mdb del dev br0 port eth3 grp 239.0.0.1 temp (monitor) dev br0 port eth3 grp 239.0.0.1 permanent Note the state of the entry that got deleted is correct in the notification. Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Fixes: ccb1c31a7a87 ("bridge: add flags to distinguish permanent mdb entires") Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-29bridge: mcast: give fast leave precedence over multicast router and querierSatish Ashok
When fast leave is configured on a bridge port and an IGMP leave is received for a group, the group is not deleted immediately if there is a router detected or if multicast querier is configured. Ideally the group should be deleted immediately when fast leave is configured. Signed-off-by: Satish Ashok <sashok@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-29bridge: Fix network header pointer for vlan tagged packetsToshiaki Makita
There are several devices that can receive vlan tagged packets with CHECKSUM_PARTIAL like tap, possibly veth and xennet. When (multiple) vlan tagged packets with CHECKSUM_PARTIAL are forwarded by bridge to a device with the IP_CSUM feature, they end up with checksum error because before entering bridge, the network header is set to ETH_HLEN (not including vlan header length) in __netif_receive_skb_core(), get_rps_cpu(), or drivers' rx functions, and nobody fixes the pointer later. Since the network header is exepected to be ETH_HLEN in flow-dissection and hash-calculation in RPS in rx path, and since the header pointer fix is needed only in tx path, set the appropriate network header on forwarding packets. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-29packet: tpacket_snd(): fix signed/unsigned comparisonAlexander Drozdov
tpacket_fill_skb() can return a negative value (-errno) which is stored in tp_len variable. In that case the following condition will be (but shouldn't be) true: tp_len > dev->mtu + dev->hard_header_len as dev->mtu and dev->hard_header_len are both unsigned. That may lead to just returning an incorrect EMSGSIZE errno to the user. Fixes: 52f1454f629fa ("packet: allow to transmit +4 byte in TX_RING slot for VLAN case") Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-28arp: filter NOARP neighbours for SIOCGARPEric Dumazet
When arp is off on a device, and ioctl(SIOCGARP) is queried, a buggy answer is given with MAC address of the device, instead of the mac address of the destination/gateway. We filter out NUD_NOARP neighbours for /proc/net/arp, we must do the same for SIOCGARP ioctl. Tested: lpaa23:~# ./arp 10.246.7.190 MAC=00:01:e8:22:cb:1d // correct answer lpaa23:~# ip link set dev eth0 arp off lpaa23:~# cat /proc/net/arp # check arp table is now 'empty' IP address HW type Flags HW address Mask Device lpaa23:~# ./arp 10.246.7.190 MAC=00:1a:11:c3:0d:7f // buggy answer before patch (this is eth0 mac) After patch : lpaa23:~# ip link set dev eth0 arp off lpaa23:~# ./arp 10.246.7.190 ioctl(SIOCGARP) failed: No such device or address Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Vytautas Valancius <valas@google.com> Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-28net/ipv4: suppress NETDEV_UP notification on address lifetime updateDavid Ward
This notification causes the FIB to be updated, which is not needed because the address already exists, and more importantly it may undo intentional changes that were made to the FIB after the address was originally added. (As a point of comparison, when an address becomes deprecated because its preferred lifetime expired, a notification on this chain is not generated.) The motivation for this commit is fixing an incompatibility between DHCP clients which set and update the address lifetime according to the lease, and a commercial VPN client which replaces kernel routes in a way that outbound traffic is sent only through the tunnel (and disconnects if any further route changes are detected via netlink). Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-28bridge: stp: when using userspace stp stop kernel hello and hold timersNikolay Aleksandrov
These should be handled only by the respective STP which is in control. They become problematic for devices with limited resources with many ports because the hold_timer is per port and fires each second and the hello timer fires each 2 seconds even though it's global. While in user-space STP mode these timers are completely unnecessary so it's better to keep them off. Also ensure that when the bridge is up these timers are started only when running with kernel STP. Signed-off-by: Satish Ashok <sashok@cumulusnetworks.com> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-28Merge tag 'nfs-for-4.2-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include: Stable patches: - Fix a situation where the client uses the wrong (zero) stateid. - Fix a memory leak in nfs_do_recoalesce Bugfixes: - Plug a memory leak when ->prepare_layoutcommit fails - Fix an Oops in the NFSv4 open code - Fix a backchannel deadlock - Fix a livelock in sunrpc when sendmsg fails due to low memory availability - Don't revalidate the mapping if both size and change attr are up to date - Ensure we don't miss a file extension when doing pNFS - Several fixes to handle NFSv4.1 sequence operation status bits correctly - Several pNFS layout return bugfixes" * tag 'nfs-for-4.2-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (28 commits) nfs: Fix an oops caused by using other thread's stack space in ASYNC mode nfs: plug memory leak when ->prepare_layoutcommit fails SUNRPC: Report TCP errors to the caller sunrpc: translate -EAGAIN to -ENOBUFS when socket is writable. NFSv4.2: handle NFS-specific llseek errors NFS: Don't clear desc->pg_moreio in nfs_do_recoalesce() NFS: Fix a memory leak in nfs_do_recoalesce NFS: nfs_mark_for_revalidate should always set NFS_INO_REVAL_PAGECACHE NFS: Remove the "NFS_CAP_CHANGE_ATTR" capability NFS: Set NFS_INO_REVAL_PAGECACHE if the change attribute is uninitialised NFS: Don't revalidate the mapping if both size and change attr are up to date NFSv4/pnfs: Ensure we don't miss a file extension NFSv4: We must set NFS_OPEN_STATE flag in nfs_resync_open_stateid_locked SUNRPC: xprt_complete_bc_request must also decrement the free slot count SUNRPC: Fix a backchannel deadlock pNFS: Don't throw out valid layout segments pNFS: pnfs_roc_drain() fix a race with open pNFS: Fix races between return-on-close and layoutreturn. pNFS: pnfs_roc_drain should return 'true' when sleeping pNFS: Layoutreturn must invalidate all existing layout segments. ...
2015-07-27packet: missing dev_put() in packet_do_bind()Lars Westerhoff
When binding a PF_PACKET socket, the use count of the bound interface is always increased with dev_hold in dev_get_by_{index,name}. However, when rebound with the same protocol and device as in the previous bind the use count of the interface was not decreased. Ultimately, this caused the deletion of the interface to fail with the following message: unregister_netdevice: waiting for dummy0 to become free. Usage count = 1 This patch moves the dev_put out of the conditional part that was only executed when either the protocol or device changed on a bind. Fixes: 902fefb82ef7 ('packet: improve socket create/bind latency in some cases') Signed-off-by: Lars Westerhoff <lars.westerhoff@newtec.eu> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-27SUNRPC: Report TCP errors to the callerTrond Myklebust
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-27fib_trie: Drop unnecessary calls to leaf_pull_suffixAlexander Duyck
It was reported that update_suffix was taking a long time on systems where a large number of leaves were attached to a single node. As it turns out fib_table_flush was calling update_suffix for each leaf that didn't have all of the aliases stripped from it. As a result, on this large node removing one leaf would result in us calling update_suffix for every other leaf on the node. The fix is to just remove the calls to leaf_pull_suffix since they are redundant as we already have a call in resize that will go through and update the suffix length for the node before we exit out of fib_table_flush or fib_table_flush_external. Reported-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Tested-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-27sunrpc: translate -EAGAIN to -ENOBUFS when socket is writable.NeilBrown
The networking layer does not reliably report the distinction between a non-block write failing because: 1/ the queue is too full already and 2/ a memory allocation attempt failed. The distinction is important because in the first case it is appropriate to retry as soon as the socket reports that it is writable, and in the second case a small delay is required as the socket will most likely report as writable but kmalloc could still fail. sk_stream_wait_memory() exhibits this distinction nicely, setting 'vm_wait' if a small wait is needed. However in the non-blocking case it always returns -EAGAIN no matter the cause of the failure. This -EAGAIN call get all the way to sunrpc. The sunrpc layer expects EAGAIN to indicate the first cause, and ENOBUFS to indicate the second. Various documentation suggests that this is not unreasonable, but does not guarantee the desired error codes. The result of getting -EAGAIN when -ENOBUFS is expected is that the send is tried again in a tight loop and soft lockups are reported. so: add tests after calls to xs_sendpages() to translate -EAGAIN into -ENOBUFS if the socket is writable. This cannot happen inside xs_sendpages() as the test for "is socket writable" is different between TCP and UDP. With this change, the tight loop retrying xs_sendpages() becomes a loop which only retries every 250ms, and so will not trigger a soft-lockup warning. It is possible that the write did fail because the queue was too full and by the time xs_sendpages() completed, the queue was writable again. In this case an extra 250ms delay is inserted that isn't really needed. This circumstance suggests a degree of congestion so a delay is not necessarily a bad thing, and it can only cause a single 250ms delay, not a series of them. Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-27tcp: fix recv with flags MSG_WAITALL | MSG_PEEKSabrina Dubroca
Currently, tcp_recvmsg enters a busy loop in sk_wait_data if called with flags = MSG_WAITALL | MSG_PEEK. sk_wait_data waits for sk_receive_queue not empty, but in this case, the receive queue is not empty, but does not contain any skb that we can use. Add a "last skb seen on receive queue" argument to sk_wait_data, so that it sleeps until the receive queue has new skbs. Link: https://bugzilla.kernel.org/show_bug.cgi?id=99461 Link: https://sourceware.org/bugzilla/show_bug.cgi?id=18493 Link: https://bugzilla.redhat.com/show_bug.cgi?id=1205258 Reported-by: Enrico Scholz <rh-bugzilla@ensc.de> Reported-by: Dan Searle <dan@censornet.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-26Merge branch 'for-upstream' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth Johan Hedberg says: ==================== pull request: bluetooth 2015-07-23 Here's another one-patch pull request for 4.2 which targets a potential NULL pointer dereference in the LE Security Manager code that can be triggered by using older user space tools. The issue has been there since 4.0 so there's the appropriate "Cc: stable" in place. Let me know if there are any issues pulling. Thanks. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-26inet: frags: remove INET_FRAG_EVICTED and use list_evictor for the testNikolay Aleksandrov
We can simply remove the INET_FRAG_EVICTED flag to avoid all the flags race conditions with the evictor and use a participation test for the evictor list, when we're at that point (after inet_frag_kill) in the timer there're 2 possible cases: 1. The evictor added the entry to its evictor list while the timer was waiting for the chainlock or 2. The timer unchained the entry and the evictor won't see it In both cases we should be able to see list_evictor correctly due to the sync on the chainlock. Joint work with Florian Westphal. Tested-by: Frank Schreuder <fschreuder@transip.nl> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-26inet: frag: don't wait for timer deletion when evictingFlorian Westphal
Frank reports 'NMI watchdog: BUG: soft lockup' errors when load is high. Instead of (potentially) unbounded restarts of the eviction process, just skip to the next entry. One caveat is that, when a netns is exiting, a timer may still be running by the time inet_evict_bucket returns. We use the frag memory accounting to wait for outstanding timers, so that when we free the percpu counter we can be sure no running timer will trip over it. Reported-and-tested-by: Frank Schreuder <fschreuder@transip.nl> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-26inet: frag: change *_frag_mem_limit functions to take netns_frags as argumentFlorian Westphal
Followup patch will call it after inet_frag_queue was freed, so q->net doesn't work anymore (but netf = q->net; free(q); mem_limit(netf) would). Tested-by: Frank Schreuder <fschreuder@transip.nl> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-26inet: frag: don't re-use chainlist for evictorFlorian Westphal
commit 65ba1f1ec0eff ("inet: frags: fix a race between inet_evict_bucket and inet_frag_kill") describes the bug, but the fix doesn't work reliably. Problem is that ->flags member can be set on other cpu without chainlock being held by that task, i.e. the RMW-Cycle can clear INET_FRAG_EVICTED bit after we put the element on the evictor private list. We can crash when walking the 'private' evictor list since an element can be deleted from list underneath the evictor. Join work with Nikolay Alexandrov. Fixes: b13d3cbfb8e8 ("inet: frag: move eviction of queues to work queue") Reported-by: Johan Schuijt <johan@transip.nl> Tested-by: Frank Schreuder <fschreuder@transip.nl> Signed-off-by: Nikolay Alexandrov <nikolay@cumulusnetworks.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-26net: sctp: stop spamming klog with rfc6458, 5.3.2. deprecation warningsDaniel Borkmann
Back then when we added support for SCTP_SNDINFO/SCTP_RCVINFO from RFC6458 5.3.4/5.3.5, we decided to add a deprecation warning for the (as per RFC deprecated) SCTP_SNDRCV via commit bbbea41d5e53 ("net: sctp: deprecate rfc6458, 5.3.2. SCTP_SNDRCV support"), see [1]. Imho, it was not a good idea, and we should just revert that message for a couple of reasons: 1) It's uapi and therefore set in stone forever. 2) To be able to run on older and newer kernels, an SCTP application would need to probe for both, SCTP_SNDRCV, but also SCTP_SNDINFO/ SCTP_RCVINFO support, so that on older kernels, it can make use of SCTP_SNDRCV, and on newer kernels SCTP_SNDINFO/SCTP_RCVINFO. In my (limited) experience, a lot of SCTP appliances are migrating to newer kernels only ve(ee)ry slowly. 3) Some people don't have the chance to change their applications, f.e. due to proprietary legacy stuff. So, they'll hit this warning in fast path and are stuck with older kernels. But i.e. due to point 1) I really fail to see the benefit of a warning. So just revert that for now, the issue was reported up Jamal. [1] http://thread.gmane.org/gmane.linux.network/321960/ Reported-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Cc: Michael Tuexen <tuexen@fh-muenster.de> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-26bridge: netlink: fix slave_changelink/br_setport race conditionsNikolay Aleksandrov
Since slave_changelink support was added there have been a few race conditions when using br_setport() since some of the port functions it uses require the bridge lock. It is very easy to trigger a lockup due to some internal spin_lock() usage without bh disabled, also it's possible to get the bridge into an inconsistent state. Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Fixes: 3ac636b8591c ("bridge: implement rtnl_link_ops->slave_changelink") Reviewed-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter/IPVS fixes for net The following patchset contains ten Netfilter/IPVS fixes, they are: 1) Address refcount leak when creating an expectation from the ctnetlink interface. 2) Fix bug splat in the IDLETIMER target related to sysfs, from Dmitry Torokhov. 3) Resolve panic for unreachable route in IPVS with locally generated traffic in the output path, from Alex Gartrell. 4) Fix wrong source address in rare cases for tunneled traffic in IPVS, from Julian Anastasov. 5) Fix crash if scheduler is changed via ipvsadm -E, again from Julian. 6) Make sure skb->sk is unset for forwarded traffic through IPVS, again from Alex Gartrell. 7) Fix crash with IPVS sync protocol v0 and FTP, from Julian. 8) Reset sender cpu for forwarded traffic in IPVS, also from Julian. 9) Allocate template conntracks through kmalloc() to resolve netns dependency problems with the conntrack kmem_cache. 10) Fix zones with expectations that clash using the same tuple, from Joe Stringer. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-25cgroup: net_cls: fix false-positive "suspicious RCU usage"Konstantin Khlebnikov
In dev_queue_xmit() net_cls protected with rcu-bh. [ 270.730026] =============================== [ 270.730029] [ INFO: suspicious RCU usage. ] [ 270.730033] 4.2.0-rc3+ #2 Not tainted [ 270.730036] ------------------------------- [ 270.730040] include/linux/cgroup.h:353 suspicious rcu_dereference_check() usage! [ 270.730041] other info that might help us debug this: [ 270.730043] rcu_scheduler_active = 1, debug_locks = 1 [ 270.730045] 2 locks held by dhclient/748: [ 270.730046] #0: (rcu_read_lock_bh){......}, at: [<ffffffff81682b70>] __dev_queue_xmit+0x50/0x960 [ 270.730085] #1: (&qdisc_tx_lock){+.....}, at: [<ffffffff81682d60>] __dev_queue_xmit+0x240/0x960 [ 270.730090] stack backtrace: [ 270.730096] CPU: 0 PID: 748 Comm: dhclient Not tainted 4.2.0-rc3+ #2 [ 270.730098] Hardware name: OpenStack Foundation OpenStack Nova, BIOS Bochs 01/01/2011 [ 270.730100] 0000000000000001 ffff8800bafeba58 ffffffff817ad487 0000000000000007 [ 270.730103] ffff880232a0a780 ffff8800bafeba88 ffffffff810ca4f2 ffff88022fb23e00 [ 270.730105] ffff880232a0a780 ffff8800bafebb68 ffff8800bafebb68 ffff8800bafebaa8 [ 270.730108] Call Trace: [ 270.730121] [<ffffffff817ad487>] dump_stack+0x4c/0x65 [ 270.730148] [<ffffffff810ca4f2>] lockdep_rcu_suspicious+0xe2/0x120 [ 270.730153] [<ffffffff816a62d2>] task_cls_state+0x92/0xa0 [ 270.730158] [<ffffffffa00b534f>] cls_cgroup_classify+0x4f/0x120 [cls_cgroup] [ 270.730164] [<ffffffff816aac74>] tc_classify_compat+0x74/0xc0 [ 270.730166] [<ffffffff816ab573>] tc_classify+0x33/0x90 [ 270.730170] [<ffffffffa00bcb0a>] htb_enqueue+0xaa/0x4a0 [sch_htb] [ 270.730172] [<ffffffff81682e26>] __dev_queue_xmit+0x306/0x960 [ 270.730174] [<ffffffff81682b70>] ? __dev_queue_xmit+0x50/0x960 [ 270.730176] [<ffffffff816834a3>] dev_queue_xmit_sk+0x13/0x20 [ 270.730185] [<ffffffff81787770>] dev_queue_xmit+0x10/0x20 [ 270.730187] [<ffffffff8178b91c>] packet_snd.isra.62+0x54c/0x760 [ 270.730190] [<ffffffff8178be25>] packet_sendmsg+0x2f5/0x3f0 [ 270.730203] [<ffffffff81665245>] ? sock_def_readable+0x5/0x190 [ 270.730210] [<ffffffff817b64bb>] ? _raw_spin_unlock+0x2b/0x40 [ 270.730216] [<ffffffff8173bcbc>] ? unix_dgram_sendmsg+0x5cc/0x640 [ 270.730219] [<ffffffff8165f367>] sock_sendmsg+0x47/0x50 [ 270.730221] [<ffffffff8165f42f>] sock_write_iter+0x7f/0xd0 [ 270.730232] [<ffffffff811fd4c7>] __vfs_write+0xa7/0xf0 [ 270.730234] [<ffffffff811fe5b8>] vfs_write+0xb8/0x190 [ 270.730236] [<ffffffff811fe8c2>] SyS_write+0x52/0xb0 [ 270.730239] [<ffffffff817b6bae>] entry_SYSCALL_64_fastpath+0x12/0x76 Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-24sch_choke: drop all packets in queue during resetWANG Cong
Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-24sch_plug: purge buffered packets during resetWANG Cong
Otherwise the skbuff related structures are not correctly refcount'ed. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-24ipv4: consider TOS in fib_select_defaultJulian Anastasov
fib_select_default considers alternative routes only when res->fi is for the first alias in res->fa_head. In the common case this can happen only when the initial lookup matches the first alias with highest TOS value. This prevents the alternative routes to require specific TOS. This patch solves the problem as follows: - routes that require specific TOS should be returned by fib_select_default only when TOS matches, as already done in fib_table_lookup. This rule implies that depending on the TOS we can have many different lists of alternative gateways and we have to keep the last used gateway (fa_default) in first alias for the TOS instead of using single tb_default value. - as the aliases are ordered by many keys (TOS desc, fib_priority asc), we restrict the possible results to routes with matching TOS and lowest metric (fib_priority) and routes that match any TOS, again with lowest metric. For example, packet with TOS 8 can not use gw3 (not lowest metric), gw4 (different TOS) and gw6 (not lowest metric), all other gateways can be used: tos 8 via gw1 metric 2 <--- res->fa_head and res->fi tos 8 via gw2 metric 2 tos 8 via gw3 metric 3 tos 4 via gw4 tos 0 via gw5 tos 0 via gw6 metric 1 Reported-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-24ipv4: fib_select_default should match the prefixJulian Anastasov
fib_trie starting from 4.1 can link fib aliases from different prefixes in same list. Make sure the alternative gateways are in same table and for same prefix (0) by checking tb_id and fa_slen. Fixes: 79e5ad2ceb00 ("fib_trie: Remove leaf_info") Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-23Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio/vhost fixes from Michael Tsirkin: "Bugfixes and documentation fixes. Igor's patch that allows users to tweak memory table size is borderline, but it does fix known crashes, so I merged it" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: vhost: add max_mem_regions module parameter vhost: extend memory regions allocation to vmalloc 9p/trans_virtio: reset virtio device on remove virtio/s390: rename drivers/s390/kvm -> drivers/s390/virtio MAINTAINERS: separate section for s390 virtio drivers virtio: define virtio_pci_cfg_cap in header. virtio: Fix typecast of pointer in vring_init() virtio scsi: fix unused variable warning vhost: use binary search instead of linear in find_region() virtio_net: document VIRTIO_NET_CTRL_GUEST_OFFLOADS
2015-07-23Bluetooth: Fix NULL pointer dereference in smp_conn_securityJohan Hedberg
The l2cap_conn->smp pointer may be NULL for various valid reasons where SMP has failed to initialize properly. One such scenario is when crypto support is missing, another when the adapter has been powered on through a legacy method. The smp_conn_security() function should have the appropriate check for this situation to avoid NULL pointer dereferences. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Cc: stable@vger.kernel.org # 4.0+
2015-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Don't use shared bluetooth antenna in iwlwifi driver for management frames, from Emmanuel Grumbach. 2) Fix device ID check in ath9k driver, from Felix Fietkau. 3) Off by one in xen-netback BUG checks, from Dan Carpenter. 4) Fix IFLA_VF_PORT netlink attribute validation, from Daniel Borkmann. 5) Fix races in setting peeked bit flag in SKBs during datagram receive. If it's shared we have to clone it otherwise the value can easily be corrupted. Fix from Herbert Xu. 6) Revert fec clock handling change, causes regressions. From Fabio Estevam. 7) Fix use after free in fq_codel and sfq packet schedulers, from WANG Cong. 8) ipvlan bug fixes (memory leaks, missing rcu_dereference_bh, etc.) from WANG Cong and Konstantin Khlebnikov. 9) Memory leak in act_bpf packet action, from Alexei Starovoitov. 10) ARM bpf JIT bug fixes from Nicolas Schichan. 11) Fix backwards compat of ANY_LAYOUT in virtio_net driver, from Michael S Tsirkin. 12) Destruction of bond with different ARP header types not handled correctly, fix from Nikolay Aleksandrov. 13) Revert GRO receive support in ipv6 SIT tunnel driver, causes regressions because the GRO packets created cannot be processed properly on the GSO side if we forward the frame. From Herbert Xu. 14) TCCR update race and other fixes to ravb driver from Sergei Shtylyov. 15) Fix SKB leaks in caif_queue_rcv_skb(), from Eric Dumazet. 16) Fix panics on packet scheduler filter replace, from Daniel Borkmann. 17) Make sure AF_PACKET sees properly IP headers in defragmented frames (via PACKET_FANOUT_FLAG_DEFRAG option), from Edward Hyunkoo Jee. 18) AF_NETLINK cannot hold mutex in RCU callback, fix from Florian Westphal. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (84 commits) ravb: fix ring memory allocation net: phy: dp83867: Fix warning check for setting the internal delay openvswitch: allocate nr_node_ids flow_stats instead of num_possible_nodes netlink: don't hold mutex in rcu callback when releasing mmapd ring ARM: net: fix vlan access instructions in ARM JIT. ARM: net: handle negative offsets in BPF JIT. ARM: net: fix condition for load_order > 0 when translating load instructions. tcp: suppress a division by zero warning drivers: net: cpsw: remove tx event processing in rx napi poll inet: frags: fix defragmented packet's IP header for af_packet net: mvneta: fix refilling for Rx DMA buffers stmmac: fix setting of driver data in stmmac_dvr_probe sched: cls_flow: fix panic on filter replace sched: cls_flower: fix panic on filter replace sched: cls_bpf: fix panic on filter replace net/mdio: fix mdio_bus_match for c45 PHY net: ratelimit warnings about dst entry refcount underflow or overflow caif: fix leaks and race in caif_queue_rcv_skb() qmi_wwan: add the second QMI/network interface for Sierra Wireless MC7305/MC7355 ravb: fix race updating TCCR ...
2015-07-22SUNRPC: xprt_complete_bc_request must also decrement the free slot countTrond Myklebust
Calling xprt_complete_bc_request() effectively causes the slot to be allocated, so it needs to decrement the backchannel free slot count as well. Fixes: 0d2a970d0ae5 ("SUNRPC: Fix a backchannel race") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-22SUNRPC: Fix a backchannel deadlockTrond Myklebust
xprt_alloc_bc_request() cannot call xprt_free_bc_request() without deadlocking, since it already holds the xprt->bc_pa_lock. Reported-by: Chuck Lever <chuck.lever@oracle.com> Fixes: 0d2a970d0ae55 ("SUNRPC: Fix a backchannel race") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-22netfilter: nf_conntrack: Support expectations in different zonesJoe Stringer
When zones were originally introduced, the expectation functions were all extended to perform lookup using the zone. However, insertion was not modified to check the zone. This means that two expectations which are intended to apply for different connections that have the same tuple but exist in different zones cannot both be tracked. Fixes: 5d0aa2ccd4 (netfilter: nf_conntrack: add support for "conntrack zones") Signed-off-by: Joe Stringer <joestringer@nicira.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-07-21openvswitch: allocate nr_node_ids flow_stats instead of num_possible_nodesChris J Arges
Some architectures like POWER can have a NUMA node_possible_map that contains sparse entries. This causes memory corruption with openvswitch since it allocates flow_cache with a multiple of num_possible_nodes() and assumes the node variable returned by for_each_node will index into flow->stats[node]. Use nr_node_ids to allocate a maximal sparse array instead of num_possible_nodes(). The crash was noticed after 3af229f2 was applied as it changed the node_possible_map to match node_online_map on boot. Fixes: 3af229f2071f5b5cb31664be6109561fbe19c861 Signed-off-by: Chris J Arges <chris.j.arges@canonical.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21netlink: don't hold mutex in rcu callback when releasing mmapd ringFlorian Westphal
Kirill A. Shutemov says: This simple test-case trigers few locking asserts in kernel: int main(int argc, char **argv) { unsigned int block_size = 16 * 4096; struct nl_mmap_req req = { .nm_block_size = block_size, .nm_block_nr = 64, .nm_frame_size = 16384, .nm_frame_nr = 64 * block_size / 16384, }; unsigned int ring_size; int fd; fd = socket(AF_NETLINK, SOCK_RAW, NETLINK_GENERIC); if (setsockopt(fd, SOL_NETLINK, NETLINK_RX_RING, &req, sizeof(req)) < 0) exit(1); if (setsockopt(fd, SOL_NETLINK, NETLINK_TX_RING, &req, sizeof(req)) < 0) exit(1); ring_size = req.nm_block_nr * req.nm_block_size; mmap(NULL, 2 * ring_size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); return 0; } +++ exited with 0 +++ BUG: sleeping function called from invalid context at /home/kas/git/public/linux-mm/kernel/locking/mutex.c:616 in_atomic(): 1, irqs_disabled(): 0, pid: 1, name: init 3 locks held by init/1: #0: (reboot_mutex){+.+...}, at: [<ffffffff81080959>] SyS_reboot+0xa9/0x220 #1: ((reboot_notifier_list).rwsem){.+.+..}, at: [<ffffffff8107f379>] __blocking_notifier_call_chain+0x39/0x70 #2: (rcu_callback){......}, at: [<ffffffff810d32e0>] rcu_do_batch.isra.49+0x160/0x10c0 Preemption disabled at:[<ffffffff8145365f>] __delay+0xf/0x20 CPU: 1 PID: 1 Comm: init Not tainted 4.1.0-00009-gbddf4c4818e0 #253 Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS Debian-1.8.2-1 04/01/2014 ffff88017b3d8000 ffff88027bc03c38 ffffffff81929ceb 0000000000000102 0000000000000000 ffff88027bc03c68 ffffffff81085a9d 0000000000000002 ffffffff81ca2a20 0000000000000268 0000000000000000 ffff88027bc03c98 Call Trace: <IRQ> [<ffffffff81929ceb>] dump_stack+0x4f/0x7b [<ffffffff81085a9d>] ___might_sleep+0x16d/0x270 [<ffffffff81085bed>] __might_sleep+0x4d/0x90 [<ffffffff8192e96f>] mutex_lock_nested+0x2f/0x430 [<ffffffff81932fed>] ? _raw_spin_unlock_irqrestore+0x5d/0x80 [<ffffffff81464143>] ? __this_cpu_preempt_check+0x13/0x20 [<ffffffff8182fc3d>] netlink_set_ring+0x1ed/0x350 [<ffffffff8182e000>] ? netlink_undo_bind+0x70/0x70 [<ffffffff8182fe20>] netlink_sock_destruct+0x80/0x150 [<ffffffff817e484d>] __sk_free+0x1d/0x160 [<ffffffff817e49a9>] sk_free+0x19/0x20 [..] Cong Wang says: We can't hold mutex lock in a rcu callback, [..] Thomas Graf says: The socket should be dead at this point. It might be simpler to add a netlink_release_ring() function which doesn't require locking at all. Reported-by: "Kirill A. Shutemov" <kirill@shutemov.name> Diagnosed-by: Cong Wang <cwang@twopensource.com> Suggested-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21tcp: suppress a division by zero warningEric Dumazet
Andrew Morton reported following warning on one ARM build with gcc-4.4 : net/ipv4/inet_hashtables.c: In function 'inet_ehash_locks_alloc': net/ipv4/inet_hashtables.c:617: warning: division by zero Even guarded with a test on sizeof(spinlock_t), compiler does not like current construct on a !CONFIG_SMP build. Remove the warning by using a temporary variable. Fixes: 095dc8e0c368 ("tcp: fix/cleanup inet_ehash_locks_alloc()") Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21inet: frags: fix defragmented packet's IP header for af_packetEdward Hyunkoo Jee
When ip_frag_queue() computes positions, it assumes that the passed sk_buff does not contain L2 headers. However, when PACKET_FANOUT_FLAG_DEFRAG is used, IP reassembly functions can be called on outgoing packets that contain L2 headers. Also, IPv4 checksum is not corrected after reassembly. Fixes: 7736d33f4262 ("packet: Add pre-defragmentation support for ipv4 fanouts.") Signed-off-by: Edward Hyunkoo Jee <edjee@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Cc: Jerry Chu <hkchu@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21sched: cls_flow: fix panic on filter replaceDaniel Borkmann
The following test case causes a NULL pointer dereference in cls_flow: tc filter add dev foo parent 1: handle 0x1 flow hash keys dst action ok tc filter replace dev foo parent 1: pref 49152 handle 0x1 \ flow hash keys mark action drop To be more precise, actually two different panics are fixed, the first occurs because tcf_exts_init() is not called on the newly allocated filter when we do a replace. And the second panic uncovered after that happens since the arguments of list_replace_rcu() are swapped, the old element needs to be the first argument and the new element the second. Fixes: 70da9f0bf999 ("net: sched: cls_flow use RCU") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21sched: cls_flower: fix panic on filter replaceDaniel Borkmann
The following test case causes a NULL pointer dereference in cls_flower: tc filter add dev foo parent 1: flower eth_type ipv4 action ok flowid 1:1 tc filter replace dev foo parent 1: pref 49152 handle 0x1 \ flower eth_type ipv6 action ok flowid 1:1 The problem is that commit 77b9900ef53a ("tc: introduce Flower classifier") accidentally swapped the arguments of list_replace_rcu(), the old element needs to be the first argument and the new element the second. Fixes: 77b9900ef53a ("tc: introduce Flower classifier") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21sched: cls_bpf: fix panic on filter replaceDaniel Borkmann
The following test case causes a NULL pointer dereference in cls_bpf: FOO="1,6 0 0 4294967295," tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 action ok tc filter replace dev foo parent 1: pref 49152 handle 0x1 \ bpf bytecode "$FOO" flowid 1:1 action drop The problem is that commit 1f947bf151e9 ("net: sched: rcu'ify cls_bpf") accidentally swapped the arguments of list_replace_rcu(), the old element needs to be the first argument and the new element the second. Fixes: 1f947bf151e9 ("net: sched: rcu'ify cls_bpf") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21Merge tag 'mac80211-for-davem-2015-07-17' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211 Johannes Berg says: ==================== Some fixes for the current cycle: 1. Arik introduced an rtnl-locked regulatory API to be able to differentiate between place do/don't have the RTNL; this fixes missing locking in some of the code paths 2. Two small mesh bugfixes from Bob, one to avoid treating a certain malformed over-the-air frame and one to avoid sending a garbage field over the air. 3. A fix for powersave during WoWLAN suspend from Krishna Chaitanya. 4. A fix for a powersave vs. aggregation teardown race, from Michal. 5. Thomas reduced the loglevel of CRDA messages to avoid spamming the kernel log with mostly irrelevant information. 6. Tom fixed a dangling debugfs directory pointer that could cause crashes if subsequent addition of the same interface to debugfs failed for some reason. 7. A fix from myself for a list corruption issue in mac80211 during combined interface shutdown/removal - shut down interfaces first and only then remove them to avoid that. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21net: ratelimit warnings about dst entry refcount underflow or overflowKonstantin Khlebnikov
Kernel generates a lot of warnings when dst entry reference counter overflows and becomes negative. That bug was seen several times at machines with outdated 3.10.y kernels. Most like it's already fixed in upstream. Anyway that flood completely kills machine and makes further debugging impossible. Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21caif: fix leaks and race in caif_queue_rcv_skb()Eric Dumazet
1) If sk_filter() is applied, skb was leaked (not freed) 2) Testing SOCK_DEAD twice is racy : packet could be freed while already queued. 3) Remove obsolete comment about caching skb->len Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-20Revert "sit: Add gro callbacks to sit_offload"Herbert Xu
This patch reverts 19424e052fb44da2f00d1a868cbb51f3e9f4bbb5 ("sit: Add gro callbacks to sit_offload") because it generates packets that cannot be handled even by our own GSO. Reported-by: Wolfgang Walter <linux@stwm.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-20Merge tag 'ipvs-fixes-for-v4.2' of ↵Pablo Neira Ayuso
https://git.kernel.org/pub/scm/linux/kernel/git/horms/ipvs Simon Horman says: ==================== IPVS Fixes for v4.2 please consider this fix for v4.2. For reasons that are not clear to me it is a bumper crop. It seems to me that they are all relevant to stable. Please let me know if you need my help to get the fixes into stable. * ipvs: fix ipv6 route unreach panic This problem appears to be present since IPv6 support was added to IPVS in v2.6.28. * ipvs: skb_orphan in case of forwarding This appears to resolve a problem resulting from a side effect of 41063e9dd119 ("ipv4: Early TCP socket demux.") which was included in v3.6. * ipvs: do not use random local source address for tunnels This appears to resolve a problem introduced by 026ace060dfe ("ipvs: optimize dst usage for real server") in v3.10. * ipvs: fix crash if scheduler is changed This appears to resolve a problem introduced by ceec4c381681 ("ipvs: convert services to rcu") in v3.10. Julian has provided backports of the fix: * [PATCHv2 3.10.81] ipvs: fix crash if scheduler is changed http://www.spinics.net/lists/lvs-devel/msg04008.html * [PATCHv2 3.12.44,3.14.45,3.18.16,4.0.6] ipvs: fix crash if scheduler is changed http://www.spinics.net/lists/lvs-devel/msg04007.html Please let me know how you would like to handle guiding these backports into stable. * ipvs: fix crash with sync protocol v0 and FTP This appears to resolve a problem introduced by 749c42b620a9 ("ipvs: reduce sync rate with time thresholds") in v3.5 ==================== Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
