path: root/net
2014-09-24Merge tag 'master-2014-09-23' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-09-23 Please consider pulling this one last batch of fixes intended for the 3.17 stream! For the NFC bits, Samuel says: "Hopefully not too late for a handful of NFC fixes: - 2 potential build failures for ST21NFCA and ST21NFCB, triggered by a depmod dependenyc cycle. - One potential buffer overflow in the microread driver." On top of that... Emil Goode provides a fix for a brcmfmac off-by-one regression which was introduced in the 3.17 cycle. Loic Poulain fixes a polarity mismatch for a variable assignment inside of rfkill-gpio. Wojciech Dubowik prevents a NULL pointer dereference in ath9k. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) If the user gives us a msg_namelen of 0, don't try to interpret anything pointed to by msg_name. From Ani Sinha. 2) Fix some bnx2i/bnx2fc randconfig compilation errors. The gist of the issue is that we firstly have drivers that span both SCSI and networking. And at the top of that chain of dependencies we have things like SCSI_FC_ATTRS and SCSI_NETLINK which are selected. But since select is a sledgehammer and ignores dependencies, everything to select's SCSI_FC_ATTRS and/or SCSI_NETLINK has to also explicitly select their dependencies and so on and so forth. Generally speaking 'select' is supposed to only be used for child nodes, those which have no dependencies of their own. And this whole chain of dependencies in the scsi layer violates that rather strongly. So just make SCSI_NETLINK depend upon it's dependencies, and so on and so forth for the things selecting it (either directly or indirectly). From Anish Bhatt and Randy Dunlap. 3) Fix generation of blackhole routes in IPSEC, from Steffen Klassert. 4) Actually notice netdev feature changes in rtl_open() code, from Hayes Wang. 5) Fix divide by zero in bond enslaving, from Nikolay Aleksandrov. 6) Missing memory barrier in sunvnet driver, from David Stevens. 7) Don't leave anycast addresses around when ipv6 interface is destroyed, from Sabrina Dubroca. 8) Don't call efx_{arch}_filter_sync_rx_mode before addr_list_lock is initialized in SFC driver, from Edward Cree. 9) Fix missing DMA error checking in 3c59x, from Neal Horman. 10) Openvswitch doesn't emit OVS_FLOW_CMD_NEW notifications accidently, fix from Samuel Gauthier. 11) pch_gbe needs to select NET_PTP_CLASSIFY otherwise we can get a build error. 12) Fix macvlan regression wherein we stopped emitting broadcast/multicast frames over software devices. From Nicolas Dichtel. 13) Fix infiniband bug due to unintended overflow of skb->cb[], from Eric Dumazet. And add an assertion so this doesn't happen again. 14) dm9000_parse_dt() should return error pointers, not NULL. From Tobias Klauser. 15) IP tunneling code uses this_cpu_ptr() in preemptible contexts, fix from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits) net: bcmgenet: call bcmgenet_dma_teardown in bcmgenet_fini_dma net: bcmgenet: fix TX reclaim accounting for fragments ipv4: do not use this_cpu_ptr() in preemptible context dm9000: Return an ERR_PTR() in all error conditions of dm9000_parse_dt() r8169: fix an if condition r8152: disable ALDPS ipoib: validate struct ipoib_cb size net: sched: shrink struct qdisc_skb_cb to 28 bytes tg3: Work around HW/FW limitations with vlan encapsulated frames macvlan: allow to enqueue broadcast pkt on virtual device pch_gbe: 'select' NET_PTP_CLASSIFY. scsi: Use 'depends' with LIBFC instead of 'select'. openvswitch: restore OVS_FLOW_CMD_NEW notifications genetlink: add function genl_has_listeners() lib: rhashtable: remove second linux/log2.h inclusion net: allow macvlans to move to net namespace 3c59x: Fix bad offset spec in skb_frag_dma_map 3c59x: Add dma error checking and recovery sparc: bpf_jit: fix support for ldx/stx mem and SKF_AD_VLAN_TAG can: at91_can: add missing prepare and unprepare of the clock ...
2014-09-22ipv4: do not use this_cpu_ptr() in preemptible contextEric Dumazet
this_cpu_ptr() in preemptible context is generally bad Sep 22 05:05:55 br kernel: [ 94.608310] BUG: using smp_processor_id() in preemptible [00000000] code: ip/2261 Sep 22 05:05:55 br kernel: [ 94.608316] caller is tunnel_dst_set.isra.28+0x20/0x60 [ip_tunnel] Sep 22 05:05:55 br kernel: [ 94.608319] CPU: 3 PID: 2261 Comm: ip Not tainted 3.17.0-rc5 #82 We can simply use raw_cpu_ptr(), as preemption is safe in these contexts. Should fix https://bugzilla.kernel.org/show_bug.cgi?id=84991 Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Joe <joe9mail@gmail.com> Fixes: 9a4aa9af447f ("ipv4: Use percpu Cache route in IP tunnels") Acked-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-22Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Steffen Klassert says: ==================== pull request (net): ipsec 2014-09-22 We generate a blackhole or queueing route if a packet matches an IPsec policy but a state can't be resolved. Here we assume that dst_output() is called to kill these packets. Unfortunately this assumption is not true in all cases, so it is possible that these packets leave the system without the necessary transformations. This pull request contains two patches to fix this issue: 1) Fix for blackhole routed packets. 2) Fix for queue routed packets. Both patches are serious stable candidates. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-22net: rfkill: gpio: Fix clock statusLoic Poulain
Clock is disabled when the device is blocked. So, clock_enabled is the logical negation of "blocked". Signed-off-by: Loic Poulain <loic.poulain@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-09-22net: sched: shrink struct qdisc_skb_cb to 28 bytesEric Dumazet
We cannot make struct qdisc_skb_cb bigger without impacting IPoIB, or increasing skb->cb[] size. Commit e0f31d849867 ("flow_keys: Record IP layer protocol in skb_flow_dissect()") broke IPoIB. Only current offender is sch_choke, and this one do not need an absolutely precise flow key. If we store 17 bytes of flow key, its more than enough. (Its the actual size of flow_keys if it was a packed structure, but we might add new fields at the end of it later) Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: e0f31d849867 ("flow_keys: Record IP layer protocol in skb_flow_dissect()") Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-19openvswitch: restore OVS_FLOW_CMD_NEW notificationsSamuel Gauthier
Since commit fb5d1e9e127a ("openvswitch: Build flow cmd netlink reply only if needed."), the new flows are not notified to the listeners of OVS_FLOW_MCGROUP. This commit fixes the problem by using the genl function, ie genl_has_listerners() instead of netlink_has_listeners(). Signed-off-by: Samuel Gauthier <samuel.gauthier@6wind.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-19Merge tag 'master-2014-09-16' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-09-17 Please pull this batch of fixes intended for the 3.17 stream... Arend van Spriel sends a trio of minor brcmfmac fixes, including a fix for a Kconfig/build issue, a fix for a crash (null reference), and a regression fix related to event handling on a P2P interface. Hante Meuleman follows-up with a brcmfmac fix for a memory leak. Johannes Stezenbach brings an ath9k_htc fix for a regression related to hardware decryption offload. Marcel Holtmann delivers a one-liner to properly mark a device ID table in rfkill-gpio. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-16net: rfkill: gpio: Enable module auto-loading for ACPI based switchesMarcel Holtmann
For the ACPI based switches the MODULE_DEVICE_TABLE is missing to export the entries for module auto-loading. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-09-16xfrm: Generate queueing routes only from route lookup functionsSteffen Klassert
Currently we genarate a queueing route if we have matching policies but can not resolve the states and the sysctl xfrm_larval_drop is disabled. Here we assume that dst_output() is called to kill the queued packets. Unfortunately this assumption is not true in all cases, so it is possible that these packets leave the system unwanted. We fix this by generating queueing routes only from the route lookup functions, here we can guarantee a call to dst_output() afterwards. Fixes: a0073fe18e71 ("xfrm: Add a state resolution packet queue") Reported-by: Konstantinos Kolelis <k.kolelis@sirrix.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2014-09-16xfrm: Generate blackhole routes only from route lookup functionsSteffen Klassert
Currently we genarate a blackhole route route whenever we have matching policies but can not resolve the states. Here we assume that dst_output() is called to kill the balckholed packets. Unfortunately this assumption is not true in all cases, so it is possible that these packets leave the system unwanted. We fix this by generating blackhole routes only from the route lookup functions, here we can guarantee a call to dst_output() afterwards. Fixes: 2774c131b1d ("xfrm: Handle blackhole route creation via afinfo.") Reported-by: Konstantinos Kolelis <k.kolelis@sirrix.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2014-09-15bridge: Fix br_should_learn to check vlan_enabledVlad Yasevich
As Toshiaki Makita pointed out, the BRIDGE_INPUT_SKB_CB will not be initialized in br_should_learn() as that function is called only from br_handle_local_finish(). That is an input handler for link-local ethernet traffic so it perfectly correct to check br->vlan_enabled here. Reported-by: Toshiaki Makita<toshiaki.makita1@gmail.com> Fixes: 20adfa1 bridge: Check if vlan filtering is enabled only once. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-15net: fix creation adjacent device symlinksAlexander Y. Fomichev
__netdev_adjacent_dev_insert may add adjust device of different net namespace, without proper check it leads to emergence of broken sysfs links from/to devices in another namespace. Fix: rewrite netdev_adjacent_is_neigh_list macro as a function, move net_eq check into netdev_adjacent_is_neigh_list. (thanks David) related to: 4c75431ac3520631f1d9e74aa88407e6374dbbc4 Signed-off-by: Alexander Fomichev <git.user@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-13bridge: Allow clearing of pvid and untagged bitmapVlad Yasevich
Currently, it is possible to modify the vlan filter configuration to add pvid or untagged support. For example: bridge vlan add vid 10 dev eth0 bridge vlan add vid 10 dev eth0 untagged pvid The second statement will modify vlan 10 to include untagged and pvid configuration. However, it is currently impossible to go backwards bridge vlan add vid 10 dev eth0 untagged pvid bridge vlan add vid 10 dev eth0 Here nothing happens. This patch correct this so that any modifiers not supplied are removed from the configuration. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-13bridge: Check if vlan filtering is enabled only once.Vlad Yasevich
The bridge code checks if vlan filtering is enabled on both ingress and egress. When the state flip happens, it is possible for the bridge to currently be forwarding packets and forwarding behavior becomes non-deterministic. Bridge may drop packets on some interfaces, but not others. This patch solves this by caching the filtered state of the packet into skb_cb on ingress. The skb_cb is guaranteed to not be over-written between the time packet entres bridge forwarding path and the time it leaves it. On egress, we can then check the cached state to see if we need to apply filtering information. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-12Merge tag 'master-2014-09-11' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-09-11 Please pull this batch of fixes intended for the 3.17 stream: For the mac80211 bits, Johannes says: "Two more fixes for mac80211 - one of them addresses a long-standing issue that we only found when using vendor events more frequently; the other addresses some bad information being reported in userspace that people were starting to actually look at." For the iwlwifi bits, Emmanuel says: "I re-enable scheduled scan on firmware that contain the fix for the bug that Linus reported. A few trivial fixes: endianity issues, the same DTIM period fix that I did in mac80211. Eyal fixes a few issues we identified with EAPOL, we now send them just as if they were management frames, this solves interrop issues. Johannes has another set of trivial fixes, while Luca fixes the way we configure the filters in the firmware. Last but not least, a new device is added by Oren." Emmanuel was traveling, resulting in his pull to be a bit larger than I would have liked to see at this point. FWIW, I have asked Emmanuel to be much more strict for any more pull requests in this cycle. In addition to the above, Sujith Manoharan reverts an earlier ath9k patch. The earlier change was found to allow for the device to sleep too long and miss beacons. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-12ipv6: clean up anycast when an interface is destroyedSabrina Dubroca
If we try to rmmod the driver for an interface while sockets with setsockopt(JOIN_ANYCAST) are alive, some refcounts aren't cleaned up and we get stuck on: unregister_netdevice: waiting for ens3 to become free. Usage count = 1 If we LEAVE_ANYCAST/close everything before rmmod'ing, there is no problem. We need to perform a cleanup similar to the one for multicast in addrconf_ifdown(how == 1). Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph fixes from Sage Weil: "The main thing here is a set of three patches that fix a buffer overrun for large authentication tickets (sigh). There is also a trivial warning fix and an error path fix that are both regressions" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: libceph: do not hard code max auth ticket len libceph: add process_one_ticket() helper libceph: gracefully handle large reply messages from the mon rbd: fix error return code in rbd_dev_device_setup() rbd: avoid format-security warning inside alloc_workqueue()
2014-09-10libceph: do not hard code max auth ticket lenIlya Dryomov
We hard code cephx auth ticket buffer size to 256 bytes. This isn't enough for any moderate setups and, in case tickets themselves are not encrypted, leads to buffer overflows (ceph_x_decrypt() errors out, but ceph_decode_copy() doesn't - it's just a memcpy() wrapper). Since the buffer is allocated dynamically anyway, allocated it a bit later, at the point where we know how much is going to be needed. Fixes: http://tracker.ceph.com/issues/8979 Cc: stable@vger.kernel.org Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-09-10libceph: add process_one_ticket() helperIlya Dryomov
Add a helper for processing individual cephx auth tickets. Needed for the next commit, which deals with allocating ticket buffers. (Most of the diff here is whitespace - view with git diff -b). Cc: stable@vger.kernel.org Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-09-10libceph: gracefully handle large reply messages from the monSage Weil
We preallocate a few of the message types we get back from the mon. If we get a larger message than we are expecting, fall back to trying to allocate a new one instead of blindly using the one we have. CC: stable@vger.kernel.org Signed-off-by: Sage Weil <sage@redhat.com> Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
2014-09-09RxRPC: Fix missing __user annotationDavid Howells
Fix a missing __user annotation in a cast of a user space pointer (found by checker). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-09net:socket: set msg_namelen to 0 if msg_name is passed as NULL in msghdr ↵Ani Sinha
struct from userland. Linux manpage for recvmsg and sendmsg calls does not explicitly mention setting msg_namelen to 0 when msg_name passed set as NULL. When developers don't set msg_namelen member in msghdr, it might contain garbage value which will fail the validation check and sendmsg and recvmsg calls from kernel will return EINVAL. This will break old binaries and any code for which there is no access to source code. To fix this, we set msg_namelen to 0 when msg_name is passed as NULL from userland. Signed-off-by: Ani Sinha <ani@arista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-09Merge tag 'mac80211-for-john-2014-09-08' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211 Johannes Berg <johannes@sipsolutions.net> says: "Two more fixes for mac80211 - one of them addresses a long-standing issue that we only found when using vendor events more frequently; the other addresses some bad information being reported in userspace that people were starting to actually look at." Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-09-08net: fix skb_page_frag_refill() kerneldocEric Dumazet
In commit d9b2938aabf7 ("net: attempt a single high order allocation) I forgot to update kerneldoc, as @prio parameter was renamed to @gfp Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-07Merge tag 'master-2014-09-04' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-09-05 Please pull this batch of fixes intended for the 3.17 stream... For the mac80211 bits, Johannes says: "Here are a few fixes for mac80211. One has been discussed for a while and adds a terminating NUL-byte to the alpha2 sent to userspace, which shouldn't be necessary but since many places treat it as a string we couldn't move to just sending two bytes. In addition to that, we have two VLAN fixes from Felix, a mesh fix, a fix for the recently introduced RX aggregation offload, a revert for a broken patch (that luckily didn't really cause any harm) and a small fix for alignment in debugfs." For the iwlwifi bits, Emmanuel says: "I revert a patch that disabled CTS to self in dvm because users reported issues. The revert is CCed to stable since the offending patch was sent to stable too. I also bump the firmware API versions since a new firmware is coming up. On top of that, Marcel fixes a bug I introduced while fixing a bug in our Kconfig file." Please let me know if there are problems! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-07ipv6: restore the behavior of ipv6_sock_ac_drop()WANG Cong
It is possible that the interface is already gone after joining the list of anycast on this interface as we don't hold a refcount for the device, in this case we are safe to ignore the error. What's more important, for API compatibility we should not change this behavior for applications even if it were correct. Fixes: commit a9ed4a2986e13011 ("ipv6: fix rtnl locking in setsockopt for anycast and multicast") Cc: Sabrina Dubroca <sd@queasysnail.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05net: treewide: Fix typo found in DocBook/networking.xmlMasanari Iida
This patch fix spelling typo found in DocBook/networking.xml. It is because the neworking.xml is generated from comments in the source, I have to fix typo in comments within the source. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05netfilter: add explicit Kconfig for NETFILTER_XT_NATPablo Neira Ayuso
Paul Bolle reports that 'select NETFILTER_XT_NAT' from the IPV4 and IPV6 NAT tables becomes noop since there is no Kconfig switch for it. Add the Kconfig switch to resolve this problem. Fixes: 8993cf8 netfilter: move NAT Kconfig switches out of the iptables scope Reported-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05ipv6: use addrconf_get_prefix_route() to remove peer addrNicolas Dichtel
addrconf_get_prefix_route() ensures to get the right route in the right table. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05ipv6: fix a refcnt leak with peer addrNicolas Dichtel
There is no reason to take a refcnt before deleting the peer address route. It's done some lines below for the local prefix route because inet6_ifa_finish_destroy() will release it at the end. For the peer address route, we want to free it right now. This bug has been introduced by commit caeaba79009c ("ipv6: add support of peer address"). Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05net-timestamp: only report sw timestamp if reporting bit is setWillem de Bruijn
The timestamping API has separate bits for generating and reporting timestamps. A software timestamp should only be reported for a packet when the packet has the relevant generation flag (SKBTX_..) set and the socket has reporting bit SOF_TIMESTAMPING_SOFTWARE set. The second check was accidentally removed. Reinstitute the original behavior. Tested: Without this patch, Documentation/networking/txtimestamp reports timestamps regardless of whether SOF_TIMESTAMPING_SOFTWARE is set. After the patch, it only reports them when the flag is set. Fixes: f24b9be5957b ("net-timestamp: extend SCM_TIMESTAMPING ancillary data struct") Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05l2tp: fix race while getting PMTU on PPP pseudo-wireGuillaume Nault
Use dst_entry held by sk_dst_get() to retrieve tunnel's PMTU. The dst_mtu(__sk_dst_get(tunnel->sock)) call was racy. __sk_dst_get() could return NULL if tunnel->sock->sk_dst_cache was reset just before the call, thus making dst_mtu() dereference a NULL pointer: [ 1937.661598] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 [ 1937.664005] IP: [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] PGD daf0c067 PUD d9f93067 PMD 0 [ 1937.664005] Oops: 0000 [#1] SMP [ 1937.664005] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6table_filter ip6_tables iptable_filter ip_tables ebtable_nat ebtables x_tables udp_tunnel pppoe pppox ppp_generic slhc deflate ctr twofish_generic twofish_x86_64_3way xts lrw gf128mul glue_helper twofish_x86_64 twofish_common blowfish_generic blowfish_x86_64 blowfish_common des_generic cbc xcbc rmd160 sha512_generic hmac crypto_null af_key xfrm_algo 8021q garp bridge stp llc tun atmtcp clip atm ext3 mbcache jbd iTCO_wdt coretemp kvm_intel iTCO_vendor_support kvm pcspkr evdev ehci_pci lpc_ich mfd_core i5400_edac edac_core i5k_amb shpchp button processor thermal_sys xfs crc32c_generic libcrc32c dm_mod usbhid sg hid sr_mod sd_mod cdrom crc_t10dif crct10dif_common ata_generic ahci ata_piix tg3 libahci libata uhci_hcd ptp ehci_hcd pps_core usbcore scsi_mod libphy usb_common [last unloaded: l2tp_core] [ 1937.664005] CPU: 0 PID: 10022 Comm: l2tpstress Tainted: G O 3.17.0-rc1 #1 [ 1937.664005] Hardware name: HP ProLiant DL160 G5, BIOS O12 08/22/2008 [ 1937.664005] task: ffff8800d8fda790 ti: ffff8800c43c4000 task.ti: ffff8800c43c4000 [ 1937.664005] RIP: 0010:[<ffffffffa049db88>] [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] RSP: 0018:ffff8800c43c7de8 EFLAGS: 00010282 [ 1937.664005] RAX: ffff8800da8a7240 RBX: ffff8800d8c64600 RCX: 000001c325a137b5 [ 1937.664005] RDX: 8c6318c6318c6320 RSI: 000000000000010c RDI: 0000000000000000 [ 1937.664005] RBP: ffff8800c43c7ea8 R08: 0000000000000000 R09: 0000000000000000 [ 1937.664005] R10: ffffffffa048e2c0 R11: ffff8800d8c64600 R12: ffff8800ca7a5000 [ 1937.664005] R13: ffff8800c439bf40 R14: 000000000000000c R15: 0000000000000009 [ 1937.664005] FS: 00007fd7f610f700(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000 [ 1937.664005] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1937.664005] CR2: 0000000000000020 CR3: 00000000d9d75000 CR4: 00000000000027e0 [ 1937.664005] Stack: [ 1937.664005] ffffffffa049da80 ffff8800d8fda790 000000000000005b ffff880000000009 [ 1937.664005] ffff8800daf3f200 0000000000000003 ffff8800c43c7e48 ffffffff81109b57 [ 1937.664005] ffffffff81109b0e ffffffff8114c566 0000000000000000 0000000000000000 [ 1937.664005] Call Trace: [ 1937.664005] [<ffffffffa049da80>] ? pppol2tp_connect+0x235/0x41e [l2tp_ppp] [ 1937.664005] [<ffffffff81109b57>] ? might_fault+0x9e/0xa5 [ 1937.664005] [<ffffffff81109b0e>] ? might_fault+0x55/0xa5 [ 1937.664005] [<ffffffff8114c566>] ? rcu_read_unlock+0x1c/0x26 [ 1937.664005] [<ffffffff81309196>] SYSC_connect+0x87/0xb1 [ 1937.664005] [<ffffffff813e56f7>] ? sysret_check+0x1b/0x56 [ 1937.664005] [<ffffffff8107590d>] ? trace_hardirqs_on_caller+0x145/0x1a1 [ 1937.664005] [<ffffffff81213dee>] ? trace_hardirqs_on_thunk+0x3a/0x3f [ 1937.664005] [<ffffffff8114c262>] ? spin_lock+0x9/0xb [ 1937.664005] [<ffffffff813092b4>] SyS_connect+0x9/0xb [ 1937.664005] [<ffffffff813e56d2>] system_call_fastpath+0x16/0x1b [ 1937.664005] Code: 10 2a 84 81 e8 65 76 bd e0 65 ff 0c 25 10 bb 00 00 4d 85 ed 74 37 48 8b 85 60 ff ff ff 48 8b 80 88 01 00 00 48 8b b8 10 02 00 00 <48> 8b 47 20 ff 50 20 85 c0 74 0f 83 e8 28 89 83 10 01 00 00 89 [ 1937.664005] RIP [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] RSP <ffff8800c43c7de8> [ 1937.664005] CR2: 0000000000000020 [ 1939.559375] ---[ end trace 82d44500f28f8708 ]--- Fixes: f34c4a35d879 ("l2tp: take PMTU from tunnel UDP socket") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05ipv6: fix rtnl locking in setsockopt for anycast and multicastSabrina Dubroca
Calling setsockopt with IPV6_JOIN_ANYCAST or IPV6_LEAVE_ANYCAST triggers the assertion in addrconf_join_solict()/addrconf_leave_solict() ipv6_sock_ac_join(), ipv6_sock_ac_drop(), ipv6_sock_ac_close() need to take RTNL before calling ipv6_dev_ac_inc/dec. Same thing with ipv6_sock_mc_join(), ipv6_sock_mc_drop(), ipv6_sock_mc_close() before calling ipv6_dev_mc_inc/dec. This patch moves ASSERT_RTNL() up a level in the call stack. Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Reported-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05mac80211: use bss_conf->dtim_period instead of conf.ps_dtim_periodEmmanuel Grumbach
sta_set_sinfo is obviously takes data for specific station. This specific station is attached to a specific virtual interface. Hence we should use the dtim_period from this virtual interface rather than the system wide dtim_period. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-09-04Merge tag 'mac80211-for-john-2014-08-29' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211 Johannes Berg <johannes@sipsolutions.net> says: "Here are a few fixes for mac80211. One has been discussed for a while and adds a terminating NUL-byte to the alpha2 sent to userspace, which shouldn't be necessary but since many places treat it as a string we couldn't move to just sending two bytes. In addition to that, we have two VLAN fixes from Felix, a mesh fix, a fix for the recently introduced RX aggregation offload, a revert for a broken patch (that luckily didn't really cause any harm) and a small fix for alignment in debugfs." Signed-off-by: John W. Linville <linville@redhat.com>
2014-09-03openvswitch: distinguish between the dropped and consumed skbLi RongQing
distinguish between the dropped and consumed skb, not assume the skb is consumed always Cc: Thomas Graf <tgraf@noironetworks.com> Cc: Pravin Shelar <pshelar@nicira.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-03nl80211: clear skb cb before passing to netlinkJohannes Berg
In testmode and vendor command reply/event SKBs we use the skb cb data to store nl80211 parameters between allocation and sending. This causes the code for CONFIG_NETLINK_MMAP to get confused, because it takes ownership of the skb cb data when the SKB is handed off to netlink, and it doesn't explicitly clear it. Clear the skb cb explicitly when we're done and before it gets passed to netlink to avoid this issue. Cc: stable@vger.kernel.org [this goes way back] Reported-by: Assaf Azulay <assaf.azulay@intel.com> Reported-by: David Spinadel <david.spinadel@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-09-02openvswitch: fix a memory leakLi RongQing
The user_skb maybe be leaked if the operation on it failed and codes skipped into the label "out:" without calling genlmsg_unicast. Cc: Pravin Shelar <pshelar@nicira.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-02netfilter: fix missing dependencies in NETFILTER_XT_TARGET_LOGPablo Neira
make defconfig reports: warning: (NETFILTER_XT_TARGET_LOG) selects NF_LOG_IPV6 which has unmet direct dependencies (NET && INET && IPV6 && NETFILTER && NETFILTER_ADVANCED) Fixes: d79a61d netfilter: NETFILTER_XT_TARGET_LOG selects NF_LOG_* Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== pull request: Netfilter/IPVS fixes for net The following patchset contains seven Netfilter fixes for your net tree, they are: 1) Make the NAT infrastructure independent of x_tables, some users are already starting to test nf_tables with NAT without enabling x_tables. Without this patch for Kconfig, there's a superfluous dependency between NAT and x_tables. 2) Allow to use 0 in the cgroup match, the kernel rejects with -EINVAL with no good reason. From Daniel Borkmann. 3) Select CONFIG_NF_NAT from the nf_tables NAT expression, this also resolves another NAT dependency with x_tables. 4) Use HAVE_JUMP_LABEL instead of CONFIG_JUMP_LABEL in the Netfilter hook code as elsewhere in the kernel to resolve toolchain problems, from Zhouyi Zhou. 5) Use iptunnel_handle_offloads() to set up tunnel encapsulation depending on the offload capabilities, reported by Alex Gartrell patch from Julian Anastasov. 6) Fix wrong family when registering the ip_vs_local_reply6() hook, also from Julian. 7) Select the NF_LOG_* symbols from NETFILTER_XT_TARGET_LOG. Rafał Miłecki reported that when jumping from 3.16 to 3.17-rc, his log target is not selected anymore due to changes in the previous development cycle to accomodate the full logging support for nf_tables. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-01Merge tag 'master-2014-08-25' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-08-28 Please pull this batch of fixes intended for the 3.17 stream. For the Bluetooth/6LowPAN/802.15.4 bits, Johan says: 'It contains a connection reference counting fix for LE where a connection might stay up even though it should get disconnected. The other 802.15.4 6LoWPAN related patches were sent to the bluetooth tree by Alexander Aring and described as follows by him: " these patches contains patches for the bluetooth branch. This series includes memory leak fixes and an errno value fix. Also there are two patches for sending and receiving 1280 6LoWPAN packets, which makes the IEEE 802.15.4 6LoWPAN stack more RFC compliant. "' Along with that... Alexey Khoroshilov fixes a use-after-free bug on at76c50x-usb. Hauke Mehrtens adds a PCI ID to bcma. Himangi Saraogi fixes a silly "A || A" test in rtlwifi. Larry Finger adds a device ID to rtl8192cu. Maks Naumov fixes a strncmp argument in ath9k. Álvaro Fernández Rojas adds a PCI ID to ssb. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-01netfilter: NETFILTER_XT_TARGET_LOG selects NF_LOG_*Pablo Neira Ayuso
CONFIG_NETFILTER_XT_TARGET_LOG is not selected anymore when jumping from 3.16 to 3.17-rc1 if you don't set on the new NF_LOG_IPV4 and NF_LOG_IPV6 switches. Change this to select the three new symbols NF_LOG_COMMON, NF_LOG_IPV4 and NF_LOG_IPV6 instead, so NETFILTER_XT_TARGET_LOG remains enabled when moving from old to new kernels. Reported-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-08-29net: sctp: fix ABI mismatch through sctp_assoc_to_state helperDaniel Borkmann
Since SCTP day 1, that is, 19b55a2af145 ("Initial commit") from lksctp tree, the official <netinet/sctp.h> header carries a copy of enum sctp_sstat_state that looks like (compared to the current in-kernel enumeration): User definition: Kernel definition: enum sctp_sstat_state { typedef enum { SCTP_EMPTY = 0, <removed> SCTP_CLOSED = 1, SCTP_STATE_CLOSED = 0, SCTP_COOKIE_WAIT = 2, SCTP_STATE_COOKIE_WAIT = 1, SCTP_COOKIE_ECHOED = 3, SCTP_STATE_COOKIE_ECHOED = 2, SCTP_ESTABLISHED = 4, SCTP_STATE_ESTABLISHED = 3, SCTP_SHUTDOWN_PENDING = 5, SCTP_STATE_SHUTDOWN_PENDING = 4, SCTP_SHUTDOWN_SENT = 6, SCTP_STATE_SHUTDOWN_SENT = 5, SCTP_SHUTDOWN_RECEIVED = 7, SCTP_STATE_SHUTDOWN_RECEIVED = 6, SCTP_SHUTDOWN_ACK_SENT = 8, SCTP_STATE_SHUTDOWN_ACK_SENT = 7, }; } sctp_state_t; This header was later on also placed into the uapi, so that user space programs can compile without having <netinet/sctp.h>, but the shipped with <linux/sctp.h> instead. While RFC6458 under 8.2.1.Association Status (SCTP_STATUS) says that sstat_state can range from SCTP_CLOSED to SCTP_SHUTDOWN_ACK_SENT, we nevertheless have a what it appears to be dummy SCTP_EMPTY state from the very early days. While it seems to do just nothing, commit 0b8f9e25b0aa ("sctp: remove completely unsed EMPTY state") did the right thing and removed this dead code. That however, causes an off-by-one when the user asks the SCTP stack via SCTP_STATUS API and checks for the current socket state thus yielding possibly undefined behaviour in applications as they expect the kernel to tell the right thing. The enumeration had to be changed however as based on the current socket state, we access a function pointer lookup-table through this. Therefore, I think the best way to deal with this is just to add a helper function sctp_assoc_to_state() to encapsulate the off-by-one quirk. Reported-by: Tristan Su <sooqing@gmail.com> Fixes: 0b8f9e25b0aa ("sctp: remove completely unsed EMPTY state") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-29net: attempt a single high order allocationEric Dumazet
In commit ed98df3361f0 ("net: use __GFP_NORETRY for high order allocations") we tried to address one issue caused by order-3 allocations. We still observe high latencies and system overhead in situations where compaction is not successful. Instead of trying order-3, order-2, and order-1, do a single order-3 best effort and immediately fallback to plain order-0. This mimics slub strategy to fallback to slab min order if the high order allocation used for performance failed. Order-3 allocations give a performance boost only if they can be done without recurring and expensive memory scan. Quoting David : The page allocator relies on synchronous (sync light) memory compaction after direct reclaim for allocations that don't retry and deferred compaction doesn't work with this strategy because the allocation order is always decreasing from the previous failed attempt. This means sync light compaction will always be encountered if memory cannot be defragmented or reclaimed several times during the skb_page_frag_refill() iteration. Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-28ipvs: fix ipv6 hook registration for local repliesJulian Anastasov
commit fc604767613b6d2036cdc35b660bc39451040a47 ("ipvs: changes for local real server") from 2.6.37 introduced DNAT support to local real server but the IPv6 LOCAL_OUT handler ip_vs_local_reply6() is registered incorrectly as IPv4 hook causing any outgoing IPv4 traffic to be dropped depending on the IP header values. Chris tracked down the problem to CONFIG_IP_VS_IPV6=y Bug report: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1349768 Reported-by: Chris J Arges <chris.j.arges@canonical.com> Tested-by: Chris J Arges <chris.j.arges@canonical.com> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au>
2014-08-27ipvs: properly declare tunnel encapsulationJulian Anastasov
The tunneling method should properly use tunnel encapsulation. Fixes problem with CHECKSUM_PARTIAL packets when TCP/UDP csum offload is supported. Thanks to Alex Gartrell for reporting the problem, providing solution and for all suggestions. Reported-by: Alex Gartrell <agartrell@fb.com> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Alex Gartrell <agartrell@fb.com> Signed-off-by: Simon Horman <horms@verge.net.au>
2014-08-26mac80211: fix agg_status debugfs file alignmentJohannes Berg
The "RX active" string is too long, so the columns get shifted. Change it to just "RX" to avoid this. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-08-26mac80211: fix start_seq_num in Rx reorder offloadDenton Gentry
sta->last_seq_ctrl is the seq_ctrl field from the last header seen, need to shift it 4 bits to extract the sequence number. Otherwise the ieee80211_sn_less() check at the top of ieee80211_sta_manage_reorder_buf drops frames until the sequence number catches up. Cc: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Denton Gentry <denton.gentry@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-08-26mac80211: mesh_plink: handle confirm frames with new plidBob Copeland
The 802.11 standard says when processing a plink confirm frame: "If the peerLinkID in the mesh peering instance has not been set, the Local Link ID field of the Mesh Peering Confirm request shall be copied into the peerLinkID in the mesh peering instance." We were only doing this when receiving an open peering frame, but it could happen that the open frame gets lost and so we should handle this case rather than rejecting the confirm and failing the whole peering process. Reported-by: Yu Niiro <yu.niiro@gmail.com> Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
