into imx_3.14.y_android_linaro
Documentation/devicetree/bindings/power/power_domain.txt
drivers/base/power/domain.c
drivers/cpufreq/Kconfig
drivers/cpufreq/cpufreq_interactive.c
drivers/mmc/core/core.c
drivers/usb/phy/Kconfig
drivers/usb/phy/Makefile
include/linux/cpufreq.h
include/linux/pm_domain.h
include/trace/events/cpufreq_interactive.h
This patch adds new ethtool cmd, ETHTOOL_GTUNABLE & ETHTOOL_STUNABLE for getting
tunable values from driver.
Add get_tunable and set_tunable to ethtool_ops. Driver implements these
functions for getting/setting tunable value.
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
We usually allocate special values of u32 fields starting from the top
down, so also change the value to 0xffffffff. As these operations
haven't been included in a stable release yet, it's not too late to
change.
This ethtool patch primarily copies the ioctl command data structures
from/to the User space and invokes the driver hook.
Signed-off-by: Venkat Duvvuru <VenkatKumar.Duvvuru@Emulex.com>
Although the implementation probably needs a lot of work, this initial API
allows to implement software TSO in mvneta and mv643xx_eth drivers in a not
so intrusive way.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
commit 28a9bc68124c319b2b3dc861e80828a8865fd1ba upstream.
When writing the code to allow per-station GTKs, I neglected to
take into account the management frame keys (index 4 and 5) when
freeing the station and only added code to free the first four
data frame keys.
Fix this by iterating the array of keys over the right length.
Fixes: e31b82136d1a ("cfg80211/mac80211: allow per-station GTKs")
commit d025933e29872cb1fe19fc54d80e4dfa4ee5779c upstream.
As multicast-frames can't be fragmented, "dot11MulticastReceivedFrameCount"
stopped being incremented after the use-after-free fix. Furthermore, the
RX-LED will be triggered by every multicast frame (which wouldn't happen
before) which wouldn't allow the LED to rest at all.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=89431 which also had the
patch.
Fixes: b8fff407a180 ("mac80211: fix use-after-free in defragmentation")
Signed-off-by: Andreas Müller <goo@stapelspeicher.org>
[rewrite commit message]
commit 4f031fa9f188b2b0641ac20087d9e16bcfb4e49d upstream.
Commit 7ec7c4a9a686c608315739ab6a2b0527a240883c (mac80211: port CCMP to
cryptoapi's CCM driver) introduced a regression when decrypting empty
packets (data_len == 0). This will lead to backtraces like:
(scatterwalk_start) from [<c01312f4>] (scatterwalk_map_and_copy+0x2c/0xa8)
(scatterwalk_map_and_copy) from [<c013a5a0>] (crypto_ccm_decrypt+0x7c/0x25c)
(crypto_ccm_decrypt) from [<c032886c>] (ieee80211_aes_ccm_decrypt+0x160/0x170)
(ieee80211_aes_ccm_decrypt) from [<c031c628>] (ieee80211_crypto_ccmp_decrypt+0x1ac/0x238)
(ieee80211_crypto_ccmp_decrypt) from [<c032ef28>] (ieee80211_rx_handlers+0x870/0x1d24)
(ieee80211_rx_handlers) from [<c0330c7c>] (ieee80211_prepare_and_rx_handle+0x8a0/0x91c)
(ieee80211_prepare_and_rx_handle) from [<c0331260>] (ieee80211_rx+0x568/0x730)
(ieee80211_rx) from [<c01d3054>] (__carl9170_rx+0x94c/0xa20)
(__carl9170_rx) from [<c01d3324>] (carl9170_rx_stream+0x1fc/0x320)
(carl9170_rx_stream) from [<c01cbccc>] (carl9170_usb_tasklet+0x80/0xc8)
(carl9170_usb_tasklet) from [<c00199dc>] (tasklet_hi_action+0x88/0xcc)
(tasklet_hi_action) from [<c00193c8>] (__do_softirq+0xcc/0x200)
(__do_softirq) from [<c0019734>] (irq_exit+0x80/0xe0)
(irq_exit) from [<c0009c10>] (handle_IRQ+0x64/0x80)
(handle_IRQ) from [<c000c3a0>] (__irq_svc+0x40/0x4c)
(__irq_svc) from [<c0009d44>] (arch_cpu_idle+0x2c/0x34)
Such packets can appear for example when using the carl9170 wireless driver
because hardware sometimes generates garbage when the internal FIFO overruns.
This patch adds an additional length check.
Fixes: 7ec7c4a9a686 ("mac80211: port CCMP to cryptoapi's CCM driver")
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Ronald Wahl <ronald.wahl@raritan.com>
[ Upstream commit 9772b54c55266ce80c639a80aa68eeb908f8ecf5 ]
To accomodate for enough headroom for tunnels, use MAX_HEADER instead
of LL_MAX_HEADER. Robert reported that he has hit after roughly 40hrs
of trinity an skb_under_panic() via SCTP output path (see reference).
I couldn't reproduce it from here, but not using MAX_HEADER as elsewhere
in other protocols might be one possible cause for this.
In any case, it looks like accounting on chunks themself seems to look
good as the skb already passed the SCTP output path and did not hit
any skb_over_panic(). Given tunneling was enabled in his .config, the
headroom would have been expanded by MAX_HEADER in this case.
Reported-by: Robert Święcki <robert@swiecki.net>
Reference: https://lkml.org/lkml/2014/12/1/507
Fixes: 594ccc14dfe4d ("[SCTP] Replace incorrect use of dev_alloc_skb with alloc_skb in sctp_packet_transmit().")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 6fb2a756739aa507c1fd5b8126f0bfc2f070dc46 ]
Set the inner mac header to point to the GRE payload when
doing GRO. This is needed if we proceed to send the packet
through GRE GSO which now uses the inner mac header instead
of inner network header to determine the length of encapsulation
headers.
Fixes: 14051f0452a2 ("gre: Use inner mac length when computing tunnel length")
Reported-by: Wolfgang Walter <linux@stwm.de>
Signed-off-by: Tom Herbert <therbert@google.com>
[ Upstream commit e0ebde0e131b529fd721b24f62872def5ec3718c ]
rtnl_link_get_net() holds a reference on the 'struct net', we need to release
it in case of error.
CC: Eric W. Biederman <ebiederm@xmission.com>
Fixes: b51642f6d77b ("net: Enable a userns root rtnl calls that are safe for unprivilged users")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commit be6572fdb1bfbe23b2624d477de50af50b02f5d6 ]
When using GRE redirection in WCCP, it sets the wrong skb->protocol,
that is, ETH_P_IP instead of ETH_P_IPV6 for the encapuslated traffic.
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
Cc: Dmitry Kozlov <xeb@mail.ru>
Signed-off-by: Yuri Chislov <yuri.chislov@gmail.com>
Tested-by: Yuri Chislov <yuri.chislov@gmail.com>
[ Upstream commit 20ea60ca9952bd19d4b0d74719daba305aef5178 ]
Now the vti_link_ops do not point the .dellink, for fb tunnel device
(ip_vti0), the net_device will be removed as the default .dellink is
unregister_netdevice_queue,but the tunnel still in the tunnel list,
then if we add a new vti tunnel, in ip_tunnel_find():
hlist_for_each_entry_rcu(t, head, hash_node) {
if (local == t->parms.iph.saddr &&
remote == t->parms.iph.daddr &&
link == t->parms.link &&
==> type == t->dev->type &&
ip_tunnel_key_match(&t->parms, flags, key))
break;
the panic will happen, cause dev of ip_tunnel *t is null:
[ 3835.072977] IP: [<ffffffffa04103fd>] ip_tunnel_find+0x9d/0xc0 [ip_tunnel]
[ 3835.073008] PGD b2c21067 PUD b7277067 PMD 0
[ 3835.073008] Oops: 0000 [#1] SMP
[ 3835.073008] Stack:
[ 3835.073008] ffff8800b72d77f0 ffffffffa0411924 ffff8800bb956000 ffff8800b72d78e0
[ 3835.073008] ffff8800b72d78a0 0000000000000000 ffffffffa040d100 ffff8800b72d7858
[ 3835.073008] ffffffffa040b2e3 0000000000000000 0000000000000000 0000000000000000
[ 3835.073008] Call Trace:
[ 3835.073008] [<ffffffffa0411924>] ip_tunnel_newlink+0x64/0x160 [ip_tunnel]
[ 3835.073008] [<ffffffffa040b2e3>] vti_newlink+0x43/0x70 [ip_vti]
[ 3835.073008] [<ffffffff8150d4da>] rtnl_newlink+0x4fa/0x5f0
[ 3835.073008] [<ffffffff812f68bb>] ? nla_strlcpy+0x5b/0x70
[ 3835.073008] [<ffffffff81508fb0>] ? rtnl_link_ops_get+0x40/0x60
[ 3835.073008] [<ffffffff8150d11f>] ? rtnl_newlink+0x13f/0x5f0
[ 3835.073008] [<ffffffff81509cf4>] rtnetlink_rcv_msg+0xa4/0x270
[ 3835.073008] [<ffffffff8126adf5>] ? sock_has_perm+0x75/0x90
[ 3835.073008] [<ffffffff81509c50>] ? rtnetlink_rcv+0x30/0x30
[ 3835.073008] [<ffffffff81529e39>] netlink_rcv_skb+0xa9/0xc0
[ 3835.073008] [<ffffffff81509c48>] rtnetlink_rcv+0x28/0x30
modprobe ip_vti
ip link del ip_vti0 type vti
ip link add ip_vti0 type vti
rmmod ip_vti
do that one or more times, kernel will panic.
fix it by assigning ip_tunnel_dellink to vti_link_ops' dellink, in
which we skip the unregister of fb tunnel device. do the same on ip6_vti.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Signed-off-by: Cong Wang <cwang@twopensource.com>
commit b6ed5498601df40489606dbc14a9c7011c16630b upstream.
batman tries to search dev->iflink to check if it's a batman interface,
but ->iflink could be 0, which is not a valid ifindex. It should just
avoid iflink == 0 case.
Reported-by: Jet Chen <jet.chen@intel.com>
Tested-by: Jet Chen <jet.chen@intel.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Antonio Quartulli <antonio@open-mesh.com>
Cc: Marek Lindner <mareklindner@neomailbox.ch>
commit 91a0b603469069cdcce4d572b7525ffc9fd352a6 upstream.
ping_lookup() may return a wrong sock if sk_buff's and sock's protocols
dont' match. For example, sk_buff's protocol is ETH_P_IPV6, but sock's
sk_family is AF_INET, in that case, if sk->sk_bound_dev_if is zero, a wrong
sock will be returned.
the fix is to "continue" the searching, if no matching, return NULL.
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: netdev@vger.kernel.org
Signed-off-by: Jane Zhou <a17711@motorola.com>
Signed-off-by: Yiwei Zhao <gbjc64@motorola.com>
[ Upstream commit 01462405f0c093b2f8dfddafcadcda6c9e4c5cdf ]
This fixes an old regression introduced by commit
b0d0d915 (ipx: remove the BKL).
When a recvmsg syscall blocks waiting for new data, no data can be sent on the
same socket with sendmsg because ipx_recvmsg() sleeps with the socket locked.
This breaks mars-nwe (NetWare emulator):
- the ncpserv process reads the request using recvmsg
- ncpserv forks and spawns nwconn
- ncpserv calls a (blocking) recvmsg and waits for new requests
- nwconn deadlocks in sendmsg on the same socket
Commit b0d0d915 has simply replaced BKL locking with
lock_sock/release_sock. Unlike now, BKL got unlocked while
sleeping, so a blocking recvmsg did not block a concurrent
sendmsg.
Only keep the socket locked while actually working with the socket data and
release it prior to calling skb_recv_datagram().
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
[ Upstream commit 49dd18ba4615eaa72f15c9087dea1c2ab4744cf5 ]
Trying to add an unreachable route incorrectly returns -ESRCH if
if custom FIB rules are present:
[root@localhost ~]# ip route add 74.125.31.199 dev eth0 via 1.2.3.4
RTNETLINK answers: Network is unreachable
[root@localhost ~]# ip rule add to 55.66.77.88 table 200
RTNETLINK answers: No such process
[root@localhost ~]#
Commit 83886b6b636173b206f475929e58fac75c6f2446 ("[NET]: Change "not found"
return value for rule lookup") changed fib_rules_lookup()
to use -ESRCH as a "not found" code internally, but for user space it
should be translated into -ENETUNREACH. Handle the translation centrally in
ipv4-specific fib_lookup(), leaving the DECnet case alone.
On a related note, commit b7a71b51ee37d919e4098cd961d59a883fd272d8
("ipv4: removed redundant conditional") removed a similar translation from
ip_route_input_slow() prematurely AIUI.
Fixes: b7a71b51ee37 ("ipv4: removed redundant conditional")
Signed-off-by: Panu Matilainen <pmatilai@redhat.com>
commit 9de7922bc709eee2f609cd01d98aaedc4cf5ea74 upstream.
Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for
ASCONF chunk") added basic verification of ASCONF chunks, however,
it is still possible to remotely crash a server by sending a
special crafted ASCONF chunk, even up to pre 2.6.12 kernels:
skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768
head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950
end:0x440 dev:<NULL>
kernel BUG at net/core/skbuff.c:129!
Call Trace:
<IRQ>
[<ffffffff8144fb1c>] skb_put+0x5c/0x70
[<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp]
[<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp]
[<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20
[<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp]
[<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp]
[<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0
[<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp]
[<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp]
[<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp]
[<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp]
[<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter]
[<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0
[<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0
[<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120
[<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0
[<ffffffff81497078>] ip_local_deliver+0x98/0xa0
[<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440
[<ffffffff81496ac5>] ip_rcv+0x275/0x350
[<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750
[<ffffffff81460588>] netif_receive_skb+0x58/0x60
This can be triggered e.g., through a simple scripted nmap
connection scan injecting the chunk after the handshake, for
example, ...
-------------- INIT[ASCONF; ASCONF_ACK] ------------->
<----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
------------------ ASCONF; UNKNOWN ------------------>
... where ASCONF chunk of length 280 contains 2 parameters ...
1) Add IP address parameter (param length: 16)
2) Add/del IP address parameter (param length: 255)
... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the
Address Parameter in the ASCONF chunk is even missing, too.
This is just an example and similarly-crafted ASCONF chunks
could be used just as well.
The ASCONF chunk passes through sctp_verify_asconf() as all
parameters passed sanity checks, and after walking, we ended
up successfully at the chunk end boundary, and thus may invoke
sctp_process_asconf(). Parameter walking is done with
WORD_ROUND() to take padding into account.
In sctp_process_asconf()'s TLV processing, we may fail in
sctp_process_asconf_param() e.g., due to removal of the IP
address that is also the source address of the packet containing
the ASCONF chunk, and thus we need to add all TLVs after the
failure to our ASCONF response to remote via helper function
sctp_add_asconf_response(), which basically invokes a
sctp_addto_chunk() adding the error parameters to the given
skb.
When walking to the next parameter this time, we proceed
with ...
length = ntohs(asconf_param->param_hdr.length);
asconf_param = (void *)asconf_param + length;
... instead of the WORD_ROUND()'ed length, thus resulting here
in an off-by-one that leads to reading the follow-up garbage
parameter length of 12336, and thus throwing an skb_over_panic
for the reply when trying to sctp_addto_chunk() next time,
which implicitly calls the skb_put() with that length.
Fix it by using sctp_walk_params() [ which is also used in
INIT parameter processing ] macro in the verification *and*
in ASCONF processing: it will make sure we don't spill over,
that we walk parameters WORD_ROUND()'ed. Moreover, we're being
more defensive and guard against unknown parameter types and
missized addresses.
Joint work with Vlad Yasevich.
Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.")
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit b69040d8e39f20d5215a03502a8e8b4c6ab78395 upstream.
When receiving a e.g. semi-good formed connection scan in the
form of ...
---------------- ASCONF_a; ASCONF_b ----------------->
... where ASCONF_a equals ASCONF_b chunk (at least both serials
need to be equal), we panic an SCTP server!
The problem is that good-formed ASCONF chunks that we reply with
ASCONF_ACK chunks are cached per serial. Thus, when we receive a
same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do
not need to process them again on the server side (that was the
idea, also proposed in the RFC). Instead, we know it was cached
and we just resend the cached chunk instead. So far, so good.
Where things get nasty is in SCTP's side effect interpreter, that
is, sctp_cmd_interpreter():
While incoming ASCONF_a (chunk = event_arg) is being marked
!end_of_packet and !singleton, and we have an association context,
we do not flush the outqueue the first time after processing the
ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it
queued up, although we set local_cork to 1. Commit 2e3216cd54b1
changed the precedence, so that as long as we get bundled, incoming
chunks we try possible bundling on outgoing queue as well. Before
this commit, we would just flush the output queue.
Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we
continue to process the same ASCONF_b chunk from the packet. As
we have cached the previous ASCONF_ACK, we find it, grab it and
do another SCTP_CMD_REPLY command on it. So, effectively, we rip
the chunk->list pointers and requeue the same ASCONF_ACK chunk
another time. Since we process ASCONF_b, it's correctly marked
with end_of_packet and we enforce an uncork, and thus flush, thus
crashing the kernel.
Fix it by testing if the ASCONF_ACK is currently pending and if
that is the case, do not requeue it. When flushing the output
queue we may relink the chunk for preparing an outgoing packet,
but eventually unlink it when it's copied into the skb right
before transmission.
Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet")
commit 26b87c7881006311828bb0ab271a551a62dcceb4 upstream.
This scenario is not limited to ASCONF, just taken as one
example triggering the issue. When receiving ASCONF probes
in the form of ...
---- ASCONF_a; [ASCONF_b; ...; ASCONF_n;] JUNK ------>
---- ASCONF_m; [ASCONF_o; ...; ASCONF_z;] JUNK ------>
... where ASCONF_a, ASCONF_b, ..., ASCONF_z are good-formed
ASCONFs and have increasing serial numbers, we process such
ASCONF chunk(s) marked with !end_of_packet and !singleton,
since we have not yet reached the SCTP packet end. SCTP does
only do verification on a chunk by chunk basis, as an SCTP
packet is nothing more than just a container of a stream of
chunks which it eats up one by one.
We could run into the case that we receive a packet with a
malformed tail, above marked as trailing JUNK. All previous
chunks are here goodformed, so the stack will eat up all
previous chunks up to this point. In case JUNK does not fit
into a chunk header and there are no more other chunks in
the input queue, or in case JUNK contains a garbage chunk
header, but the encoded chunk length would exceed the skb
tail, or we came here from an entirely different scenario
and the chunk has pdiscard=1 mark (without having had a flush
point), it will happen, that we will excessively queue up
the association's output queue (a correct final chunk may
then turn it into a response flood when flushing the
queue ;)): I ran a simple script with incremental ASCONF
serial numbers and could see the server side consuming
excessive amount of RAM [before/after: up to 2GB and more].
The issue at heart is that the chunk train basically ends
with !end_of_packet and !singleton markers and since commit
with 1 packet") therefore preventing an output queue flush
point in sctp_do_sm() -> sctp_cmd_interpreter() on the input
chunk (chunk = event_arg) even though local_cork is set,
but its precedence has changed since then. In the normal
case, the last chunk with end_of_packet=1 would trigger the
queue flush to accommodate possible outgoing bundling.
In the input queue, sctp_inq_pop() seems to do the right thing
in terms of discarding invalid chunks. So, above JUNK will
not enter the state machine and instead be released and exit
the sctp_assoc_bh_rcv() chunk processing loop. It's simply
the flush point being missing at loop exit. Adding a try-flush
approach on the output queue might not work as the underlying
infrastructure might be long gone at this point due to the
side-effect interpreter run.
One possibility, albeit a bit of a kludge, would be to defer
invalid chunk freeing into the state machine in order to
possibly trigger packet discards and thus indirectly a queue
flush on error. It would surely be better to discard chunks
as in the current, perhaps better controlled environment, but
going back and forth, it's simply architecturally not possible.
I tried various trailing JUNK attack cases and it seems to
look good now.
commit 7965ee93719921ea5978f331da653dfa2d7b99f5 upstream.
The code looks for an already loaded target, and the correct list to search
is nft_target_list, not nft_match_list.
Signed-off-by: Arturo Borrero Gonzalez <arturo.borrero.glez@gmail.com>
commit b51d3fa364885a2c1e1668f88776c67c95291820 upstream.
The kernel should reserve enough room in the skb so that the DONE
message can always be appended. However, in case of e.g. new attribute
erronously not being size-accounted for, __nfulnl_send() will still
try to put next nlmsg into this full skbuf, causing the skb to be stuck
forever and blocking delivery of further messages.
Fix issue by releasing skb immediately after nlmsg_put error and
WARN() so we can track down the cause of such size mismatch.
[ fw@strlen.de: add tailroom/len info to WARN ]
Signed-off-by: Houcheng Lin <houcheng@gmail.com>
commit c1e7dc91eed0ed1a51c9b814d648db18bf8fc6e9 upstream.
don't try to queue payloads > 0xffff - NLA_HDRLEN, it does not work.
The nla length includes the size of the nla struct, so anything larger
results in u16 integer overflow.
This patch is similar to
9cefbbc9c8f9abe (netfilter: nfnetlink_queue: cleanup copy_range usage).
commit 9dfa1dfe4d5e5e66a991321ab08afe69759d797a upstream.
We currently neither account for the nlattr size, nor do we consider
the size of the trailing NLMSG_DONE when allocating nlmsg skb.
This can result in nflog to stop working, as __nfulnl_send() re-tries
sending forever if it failed to append NLMSG_DONE (which will never
work if buffer is not large enough).
Reported-by: Houcheng Lin <houcheng@gmail.com>
commit 0f9f5e1b83abd2b37c67658e02a6fc9001831fa5 upstream.
The ->ip_set_list[] array is initialized in ip_set_net_init() and it
has ->ip_set_max elements so this check should be >= instead of >
otherwise we are off by one.
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
commit b8fff407a180286aa683d543d878d98d9fc57b13 upstream.
Upon receiving the last fragment, all but the first fragment
are freed, but the multicast check for statistics at the end
of the function refers to the current skb (the last fragment)
causing a use-after-free bug.
Since multicast frames cannot be fragmented and we check for
this early in the function, just modify that check to also
do the accounting to fix the issue.
Reported-by: Yosef Khyal <yosefx.khyal@intel.com>
commit ff1e417c7c239b7abfe70aa90460a77eaafc7f83 upstream.
Due to the time it takes to process the beacon that started the CSA
process, we may be late for the switch if we try to reach exactly
beacon 0. To avoid that, use count - 1 when calculating the switch time.
Reported-by: Jouni Malinen <j@w1.fi>
Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
commit 84469a45a1bedec9918e94ab2f78c5dc0739e4a7 upstream.
If we are switching from an HT40+ to an HT40- channel (or vice-versa),
we need the secondary channel offset IE to specify what is the
post-CSA offset to be used. This applies both to beacons and to probe
responses.
In ieee80211_parse_ch_switch_ie() we were ignoring this IE from
beacons and using the *current* HT information IE instead. This was
causing us to use the same offset as before the switch.
Fix that by using the secondary channel offset IE also for beacons and
don't ever use the pre-switch offset. Additionally, remove the
"beacon" argument from ieee80211_parse_ch_switch_ie(), since it's not
needed anymore.
commit 46238845bd609a5c0fbe076e1b82b4c5b33360b2 upstream.
When an interface is deleted, an ongoing hardware scan is canceled and
the driver must abort the scan, at the very least reporting completion
while the interface is removed.
However, if it scheduled the work that might only run after everything
is said and done, which leads to cfg80211 warning that the scan isn't
reported as finished yet; this is no fault of the driver, it already
did, but mac80211 hasn't processed it.
To fix this situation, flush the delayed work when the interface being
removed is the one that was executing the scan.
Reported-by: Sujith Manoharan <sujith@msujith.org>
Tested-by: Sujith Manoharan <sujith@msujith.org>
commit aaef31703a0cf6a733e651885bfb49edc3ac6774 upstream.
Large (greater than 32k, the value of PAGE_ALLOC_COSTLY_ORDER) auth
tickets will have their buffers vmalloc'ed, which leads to the
following crash in crypto:
[ 28.685082] BUG: unable to handle kernel paging request at ffffeb04000032c0
[ 28.686032] IP: [<ffffffff81392b42>] scatterwalk_pagedone+0x22/0x80
[ 28.686032] PGD 0
[ 28.688088] Oops: 0000 [#1] PREEMPT SMP
[ 28.688088] Modules linked in:
[ 28.688088] CPU: 0 PID: 878 Comm: kworker/0:2 Not tainted 3.17.0-vm+ #305
[ 28.688088] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[ 28.688088] Workqueue: ceph-msgr con_work
[ 28.688088] task: ffff88011a7f9030 ti: ffff8800d903c000 task.ti: ffff8800d903c000
[ 28.688088] RIP: 0010:[<ffffffff81392b42>] [<ffffffff81392b42>] scatterwalk_pagedone+0x22/0x80
[ 28.688088] RSP: 0018:ffff8800d903f688 EFLAGS: 00010286
[ 28.688088] RAX: ffffeb04000032c0 RBX: ffff8800d903f718 RCX: ffffeb04000032c0
[ 28.688088] RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8800d903f750
[ 28.688088] RBP: ffff8800d903f688 R08: 00000000000007de R09: ffff8800d903f880
[ 28.688088] R10: 18df467c72d6257b R11: 0000000000000000 R12: 0000000000000010
[ 28.688088] R13: ffff8800d903f750 R14: ffff8800d903f8a0 R15: 0000000000000000
[ 28.688088] FS: 00007f50a41c7700(0000) GS:ffff88011fc00000(0000) knlGS:0000000000000000
[ 28.688088] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 28.688088] CR2: ffffeb04000032c0 CR3: 00000000da3f3000 CR4: 00000000000006b0
[ 28.688088] Stack:
[ 28.688088] ffff8800d903f698 ffffffff81392ca8 ffff8800d903f6e8 ffffffff81395d32
[ 28.688088] ffff8800dac96000 ffff880000000000 ffff8800d903f980 ffff880119b7e020
[ 28.688088] ffff880119b7e010 0000000000000000 0000000000000010 0000000000000010
[ 28.688088] Call Trace:
[ 28.688088] [<ffffffff81392ca8>] scatterwalk_done+0x38/0x40
[ 28.688088] [<ffffffff81395d32>] blkcipher_walk_done+0x182/0x220
[ 28.688088] [<ffffffff813990bf>] crypto_cbc_encrypt+0x15f/0x180
[ 28.688088] [<ffffffff81399780>] ? crypto_aes_set_key+0x30/0x30
[ 28.688088] [<ffffffff8156c40c>] ceph_aes_encrypt2+0x29c/0x2e0
[ 28.688088] [<ffffffff8156d2a3>] ceph_encrypt2+0x93/0xb0
[ 28.688088] [<ffffffff8156d7da>] ceph_x_encrypt+0x4a/0x60
[ 28.688088] [<ffffffff8155b39d>] ? ceph_buffer_new+0x5d/0xf0
[ 28.688088] [<ffffffff8156e837>] ceph_x_build_authorizer.isra.6+0x297/0x360
[ 28.688088] [<ffffffff8112089b>] ? kmem_cache_alloc_trace+0x11b/0x1c0
[ 28.688088] [<ffffffff8156b496>] ? ceph_auth_create_authorizer+0x36/0x80
[ 28.688088] [<ffffffff8156ed83>] ceph_x_create_authorizer+0x63/0xd0
[ 28.688088] [<ffffffff8156b4b4>] ceph_auth_create_authorizer+0x54/0x80
[ 28.688088] [<ffffffff8155f7c0>] get_authorizer+0x80/0xd0
[ 28.688088] [<ffffffff81555a8b>] prepare_write_connect+0x18b/0x2b0
[ 28.688088] [<ffffffff81559289>] try_read+0x1e59/0x1f10
This is because we set up crypto scatterlists as if all buffers were
kmalloc'ed. Fix it.
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
Reviewed-by: Sage Weil <sage@redhat.com>
[ Upstream commit 4184b2a79a7612a9272ce20d639934584a1f3786 ]
A very minimal and simple user space application allocating an SCTP
socket, setting SCTP_AUTH_KEY setsockopt(2) on it and then closing
the socket again will leak the memory containing the authentication
key from user space:
unreferenced object 0xffff8800837047c0 (size 16):
comm "a.out", pid 2789, jiffies 4296954322 (age 192.258s)
hex dump (first 16 bytes):
01 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff816d7e8e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff811c88d8>] __kmalloc+0xe8/0x270
[<ffffffffa0870c23>] sctp_auth_create_key+0x23/0x50 [sctp]
[<ffffffffa08718b1>] sctp_auth_set_key+0xa1/0x140 [sctp]
[<ffffffffa086b383>] sctp_setsockopt+0xd03/0x1180 [sctp]
[<ffffffff815bfd94>] sock_common_setsockopt+0x14/0x20
[<ffffffff815beb61>] SyS_setsockopt+0x71/0xd0
[<ffffffff816e58a9>] system_call_fastpath+0x12/0x17
[<ffffffffffffffff>] 0xffffffffffffffff
This is bad because of two things, we can bring down a machine from
user space when auth_enable=1, but also we would leave security sensitive
keying material in memory without clearing it after use. The issue is
that sctp_auth_create_key() already sets the refcount to 1, but after
allocation sctp_auth_set_key() does an additional refcount on it, and
thus leaving it around when we free the socket.
Fixes: 65b07e5d0d0 ("[SCTP]: API updates to suport SCTP-AUTH extensions.")
Cc: Vlad Yasevich <vyasevich@gmail.com>
packet
[ Upstream commit e40607cbe270a9e8360907cb1e62ddf0736e4864 ]
An SCTP server doing ASCONF will panic on malformed INIT ping-of-death
in the form of:
------------ INIT[PARAM: SET_PRIMARY_IP] ------------>
While the INIT chunk parameter verification dissects through many things
in order to detect malformed input, it misses to actually check parameters
inside of parameters. E.g. RFC5061, section 4.2.4 proposes a 'set primary
IP address' parameter in ASCONF, which has as a subparameter an address
parameter.
So an attacker may send a parameter type other than SCTP_PARAM_IPV4_ADDRESS
or SCTP_PARAM_IPV6_ADDRESS, param_type2af() will subsequently return 0
and thus sctp_get_af_specific() returns NULL, too, which we then happily
dereference unconditionally through af->from_addr_param().
The trace for the log:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000078
IP: [<ffffffffa01e9c62>] sctp_process_init+0x492/0x990 [sctp]
PGD 0
Oops: 0000 [#1] SMP
Pid: 0, comm: swapper Not tainted 2.6.32-504.el6.x86_64 #1 Bochs Bochs
RIP: 0010:[<ffffffffa01e9c62>] [<ffffffffa01e9c62>] sctp_process_init+0x492/0x990 [sctp]
Call Trace:
<IRQ>
[<ffffffffa01f2add>] ? sctp_bind_addr_copy+0x5d/0xe0 [sctp]
[<ffffffffa01e1fcb>] sctp_sf_do_5_1B_init+0x21b/0x340 [sctp]
[<ffffffffa01e5c09>] ? sctp_endpoint_lookup_assoc+0xc9/0xf0 [sctp]
[<ffffffffa01e61f6>] sctp_endpoint_bh_rcv+0x116/0x230 [sctp]
A minimal way to address this is to check for NULL as we do on all
other such occasions where we know sctp_get_af_specific() could
possibly return with NULL.
Fixes: d6de3097592b ("[SCTP]: Add the handling of "Set Primary IP Address" parameter to INIT")
[ Upstream commit f03eb128e3f4276f46442d14f3b8f864f3775821 ]
Otherwise it gets overwritten by register_netdev().
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit ebe084aafb7e93adf210e80043c9f69adf56820d ]
ipip6_tunnel_init() sets the dev->iflink via a call to
ipip6_tunnel_bind_dev(). After that, register_netdevice()
sets dev->iflink = -1. So we loose the iflink configuration
for ipv6 tunnels. Fix this by using ipip6_tunnel_init() as the
ndo_init function. Then ipip6_tunnel_init() is called after
dev->iflink is set to -1 from register_netdevice().
[ Upstream commit 16a0231bf7dc3fb37e9b1f1cb1a277dc220b5c5e ]
vti6_dev_init() sets the dev->iflink via a call to
vti6_link_config(). After that, register_netdevice()
for vti6 tunnels. Fix this by using vti6_dev_init() as the
ndo_init function. Then vti6_dev_init() is called after
[ Upstream commit 6c6151daaf2d8dc2046d9926539feed5f66bf74e ]
ip6_tnl_dev_init() sets the dev->iflink via a call to
ip6_tnl_link_config(). After that, register_netdevice()
for ipv6 tunnels. Fix this by using ip6_tnl_dev_init() as the
ndo_init function. Then ip6_tnl_dev_init() is called after
commit c7abf25af0f41be4b50d44c5b185d52eea360cb8 upstream.
It affects non-(V)HT rates and can lead to selecting an rts_cts rate
that is not a basic rate or way superior to the reference rate (ATM
rates[0] used for the 1st attempt of the protected frame data).
E.g, assuming drivers register growing (bitrate) sorted tables of
ieee80211_rate-s, having :
- rates[0].idx == d'2 and basic_rates == b'10100
will select rts_cts idx b'10011 & ~d'(BIT(2)-1), i.e. 1, likewise
- rates[0].idx == d'2 and basic_rates == b'10001
will select rts_cts idx b'10000
The first is not a basic rate and the second is > rates[0].
Also, wrt severity of the addressed misbehavior, ATM we only have one
rts_cts_rate_idx rather than one per rate table entry, so this idx might
still point to bitrates > rates[1..MAX_RATES].
Fixes: 5253ffb8c9e1 ("mac80211: always pick a basic rate to tx RTS/CTS for pre-HT rates")
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
commit f9865f06f7f18c6661c88d0511f05c48612319cc upstream.
Commit f363e45fd118 ("net/ceph: make ceph_msgr_wq non-reentrant")
effectively removed WQ_MEM_RECLAIM flag from ceph_msgr_wq. This is
wrong - libceph is very much a memory reclaim path, so restore it.
Tested-by: Micha Krause <micha@krausam.de>
commit 24dff96a37a2ca319e75a74d3929b2de22447ca6 upstream.
we used to check for "nobody else could start doing anything with
that opened file" by checking that refcount was 2 or less - one
for descriptor table and one we'd acquired in fget() on the way to
wherever we are. That was race-prone (somebody else might have
had a reference to descriptor table and do fget() just as we'd
been checking) and it had become flat-out incorrect back when
we switched to fget_light() on those codepaths - unlike fget(),
it doesn't grab an extra reference unless the descriptor table
is shared. The same change allowed a race-free check, though -
we are safe exactly when refcount is less than 2.
It was a long time ago; pre-2.6.12 for ioctl() (the codepath leading
to ppp one) and 2.6.17 for sendmsg() (netlink one). OTOH,
netlink hadn't grown that check until 3.9 and ppp used to live
in drivers/net, not drivers/net/ppp until 3.1. The bug existed
well before that, though, and the same fix used to apply in old
location of file.
commit 2aca5b869ace67a63aab895659e5dc14c33a4d6e upstream.
The flag RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT was intended introduced in
order to allow NFSv4 clients to disable resend timeouts. Since those
cause the RPC layer to break the connection, they mess up the duplicate
reply caches that remain indexed on the port number in NFSv4..
This patch includes the code that was missing in the original to
set the appropriate flag in struct rpc_clnt, when the caller of
rpc_create() sets RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT.
Fixes: 8a19a0b6cb2e (SUNRPC: Add RPC task and client level options to...)
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit a743419f420a64d442280845c0377a915b76644f upstream.
When aborting a connection to preserve source ports, don't wake the task in
xs_error_report. This allows tasks with RPC_TASK_SOFTCONN to succeed if the
connection needs to be re-established since it preserves the task's status
instead of setting it to the status of the aborting kernel_connect().
This may also avoid a potential conflict on the socket's lock.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
[ Upstream commit 5188cd44c55db3e92cd9e77a40b5baa7ed4340f7 ]
UFO is now disabled on all drivers that work with virtio net headers,
but userland may try to send UFO/IPv6 packets anyway. Instead of
sending with ID=0, we should select identifiers on their behalf (as we
used to).
Fixes: 916e4cf46d02 ("ipv6: reuse ip6_frag_id from ip6_ufo_append_data")
[ Upstream commit 4062090e3e5caaf55bed4523a69f26c3265cc1d2 ]
ip_setup_cork() called inside ip_append_data() steals dst entry from rt to cork
and in case errors in __ip_append_data() nobody frees stolen dst entry
Fixes: 2e77d89b2fa8 ("net: avoid a pair of dst_hold()/dst_release() in ip_append_data()")
Signed-off-by: Vasily Averin <vvs@parallels.com>
[ Upstream commit 14051f0452a2c26a3f4791e6ad6a435e8f1945ff ]
Currently, skb_inner_network_header is used but this does not account
for Ethernet header for ETH_P_TEB. Use skb_inner_mac_header which
handles TEB and also should work with IP encapsulation in which case
inner mac and inner network headers are the same.
Tested: Ran TCP_STREAM over GRE, worked as expected.
Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com>
[ Upstream commit 349ce993ac706869d553a1816426d3a4bfda02b1 ]
percpu tcp_md5sig_pool contains memory blobs that ultimately
go through sg_set_buf().
-> sg_set_page(sg, virt_to_page(buf), buflen, offset_in_page(buf));
This requires that whole area is in a physically contiguous portion
of memory. And that @buf is not backed by vmalloc().
Given that alloc_percpu() can use vmalloc() areas, this does not
fit the requirements.
Replace alloc_percpu() by a static DEFINE_PER_CPU() as tcp_md5sig_pool
is small anyway, there is no gain to dynamically allocate it.
Fixes: 765cf9976e93 ("tcp: md5: remove one indirection level in tcp_md5sig_pool")
Reported-by: Crestez Dan Leonard <cdleonard@gmail.com>
