[ Upstream commit f0e0d04413fcce9bc76388839099aee93cd0d33b ]
Update 'confirmed' timestamp when ARP packet is received. It shouldn't
affect locktime logic and anyway entry can be confirmed by any higher-layer
protocol. Thus it makes sense to confirm it when ARP packet is received.
Fixes: 77d7123342dc ("neighbour: update neigh timestamps iff update is effective")
Signed-off-by: Vasily Khoruzhick <vasilykh@arista.com>
[ Upstream commit bbd6528d28c1b8e80832b3b018ec402b6f5c3215 ]
In the unlikely case ip6_xmit() has to call skb_realloc_headroom(),
we need to call skb_set_owner_w() before consuming original skb,
otherwise we risk a use-after-free.
Bring IPv6 in line with what we do in IPv4 to fix this.
Fixes: 1da177e4c3f41 ("Linux-2.6.12-rc2")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit c56cae23c6b167acc68043c683c4573b80cbcc2c ]
When splitting a GSO segment that consists of encapsulated packets, the
skb->mac_len of the segments can end up being set wrong, causing packet
drops in particular when using act_mirred and ifb interfaces in
combination with a qdisc that splits GSO packets.
This happens because at the time skb_segment() is called, network_header
will point to the inner header, throwing off the calculation in
skb_reset_mac_len(). The network_header is subsequently adjust by the
outer IP gso_segment handlers, but they don't set the mac_len.
Fix this by adding skb_reset_mac_len() calls to both the IPv4 and IPv6
gso_segment handlers, after they modify the network_header.
Many thanks to Eric Dumazet for his help in identifying the cause of
the bug.
Acked-by: Dave Taht <dave.taht@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: Toke Høiland-Jørgensen <toke@toke.dk>
commit 674d9de02aa7d521ebdf66c3958758bdd9c64e11 upstream.
When handling SHDLC I-Frame commands "pipe" field used for indexing
into an array should be checked before usage. If left unchecked it
might access memory outside of the array of size NFC_HCI_MAX_PIPES(127).
Malformed NFC HCI frames could be injected by a malicious NFC device
communicating with the device being attacked (remote attack vector),
or even by an attacker with physical access to the I2C bus such that
they could influence the data transfers on that bus (local attack vector).
skb->data is controlled by the attacker and has only been sanitized in
the most trivial ways (CRC check), therefore we can consider the
create_info struct and all of its members to tainted. 'create_info->pipe'
with max value of 255 (uint8) is used to take an offset of the
hdev->pipes array of 127 elements which can lead to OOB write.
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Allen Pais <allen.pais@oracle.com>
Suggested-by: Kevin Deus <kdeus@google.com>
Signed-off-by: Suren Baghdasaryan <surenb@google.com>
Cc: stable <stable@vger.kernel.org>
[ Upstream commit 133bf90dbb8b873286f8ec2e81ba26e863114b8c ]
As explained in ieee80211_delayed_tailroom_dec(), during roam,
keys of the old AP will be destroyed and new keys will be
installed. Deletion of the old key causes
crypto_tx_tailroom_needed_cnt to go from 1 to 0 and the new key
installation causes a transition from 0 to 1.
Whenever crypto_tx_tailroom_needed_cnt transitions from 0 to 1,
we invoke synchronize_net(); the reason for doing this is to avoid
a race in the TX path as explained in increment_tailroom_need_count().
This synchronize_net() operation can be slow and can affect the station
roam time. To avoid this, decrementing the crypto_tx_tailroom_needed_cnt
is delayed for a while so that upon installation of new key the
transition would be from 1 to 2 instead of 0 to 1 and thereby
improving the roam time.
This is all correct for a STA iftype, but deferring the tailroom_needed
decrement for other iftypes may be unnecessary.
For example, let's consider the case of a 4-addr client connecting to
an AP for which AP_VLAN interface is also created, let the initial
value for tailroom_needed on the AP be 1.
* 4-addr client connects to the AP (AP: tailroom_needed = 1)
* AP will clear old keys, delay decrement of tailroom_needed count
* AP_VLAN is created, it takes the tailroom count from master
(AP_VLAN: tailroom_needed = 1, AP: tailroom_needed = 1)
* Install new key for the station, assume key is plumbed in the HW,
there won't be any change in tailroom_needed count on AP iface
* Delayed decrement of tailroom_needed count on AP
(AP: tailroom_needed = 0, AP_VLAN: tailroom_needed = 1)
Because of the delayed decrement on AP iface, tailroom_needed count goes
out of sync between AP(master iface) and AP_VLAN(slave iface) and
there would be unnecessary tailroom created for the packets going
through AP_VLAN iface.
Also, WARN_ONs were observed while trying to bring down the AP_VLAN
interface:
(warn_slowpath_common) (warn_slowpath_null+0x18/0x20)
(warn_slowpath_null) (ieee80211_free_keys+0x114/0x1e4)
(ieee80211_free_keys) (ieee80211_del_virtual_monitor+0x51c/0x850)
(ieee80211_del_virtual_monitor) (ieee80211_stop+0x30/0x3c)
(ieee80211_stop) (__dev_close_many+0x94/0xb8)
(__dev_close_many) (dev_close_many+0x5c/0xc8)
Restricting delayed decrement to station interface alone fixes the problem
and it makes sense to do so because delayed decrement is done to improve
roam time which is applicable only for client devices.
Signed-off-by: Manikanta Pubbisetty <mpubbise@codeaurora.org>
[ Upstream commit 934ffce1343f22ed5e2d0bd6da4440f4848074de ]
Fix a static code checker warning:
net/xfrm/xfrm_policy.c:1836 xfrm_resolve_and_create_bundle() warn: passing zero to 'ERR_PTR'
xfrm_tmpl_resolve return 0 just means no xdst found, return NULL
instead of passing zero to ERR_PTR.
Fixes: d809ec895505 ("xfrm: do not assume that template resolving always returns xfrms")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
xt_copy_counters_from_user
commit e466af75c074e76107ae1cd5a2823e9c61894ffb upstream.
syzkaller reports an out of bound read in strlcpy(), triggered
by xt_copy_counters_from_user()
Fix this by using memcpy(), then forcing a zero byte at the last position
of the destination, as Florian did for the non COMPAT code.
Fixes: d7591f0c41ce ("netfilter: x_tables: introduce and use xt_copy_counters_from_user")
Cc: Willem de Bruijn <willemb@google.com>
Acked-by: Florian Westphal <fw@strlen.de>
Cc: Greg Hackmann <ghackmann@google.com>
[ Upstream commit 08193d1a893c802c4b807e4d522865061f4e9f4f ]
The function dcb_app_lookup walks the list of specified DCB APP entries,
looking for one that matches a given criteria: ifindex, selector,
protocol ID and optionally also priority. The "don't care" value for
priority is set to 0, because that priority has not been allowed under
CEE regime, which predates the IEEE standardization.
Under IEEE, 0 is a valid priority number. But because dcb_app_lookup
considers zero a wild card, attempts to add an APP entry with priority 0
fail when other entries exist for a given ifindex / selector / PID
triplet.
Fix by changing the wild-card value to -1.
Signed-off-by: Petr Machata <petrm@mellanox.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
[ Upstream commit b3cadaa485f0c20add1644a5c877b0765b285c0c ]
This fixes two issues with setting hid->name information.
CC net/bluetooth/hidp/core.o
In function ‘hidp_setup_hid’,
inlined from ‘hidp_session_dev_init’ at net/bluetooth/hidp/core.c:815:9,
inlined from ‘hidp_session_new’ at net/bluetooth/hidp/core.c:953:8,
inlined from ‘hidp_connection_add’ at net/bluetooth/hidp/core.c:1366:8:
net/bluetooth/hidp/core.c:778:2: warning: ‘strncpy’ output may be truncated copying 127 bytes from a string of length 127 [-Wstringop-truncation]
strncpy(hid->name, req->name, sizeof(req->name) - 1);
net/bluetooth/hidp/core.c: In function ‘hidp_setup_hid’:
net/bluetooth/hidp/core.c:778:38: warning: argument to ‘sizeof’ in ‘strncpy’ call is the same expression as the source; did you mean to use the size of the destination? [-Wsizeof-pointer-memaccess]
strncpy(hid->name, req->name, sizeof(req->name));
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
commit c2d6511e6a4f1f3673d711569c00c3849549e9b0 upstream.
sch_tbf calls qdisc_watchdog_cancel() in both its ->reset and ->destroy
callbacks but it may fail before the timer is initialized due to missing
options (either not supplied by user-space or set as a default qdisc),
also q->qdisc is used by ->reset and ->destroy so we need it initialized.
Reproduce:
$ sysctl net.core.default_qdisc=tbf
$ ip l set ethX up
Crash log:
[ 959.160172] BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
[ 959.160323] IP: qdisc_reset+0xa/0x5c
[ 959.160400] PGD 59cdb067
[ 959.160401] P4D 59cdb067
[ 959.160466] PUD 59ccb067
[ 959.160532] PMD 0
[ 959.160597]
[ 959.160706] Oops: 0000 [#1] SMP
[ 959.160778] Modules linked in: sch_tbf sch_sfb sch_prio sch_netem
[ 959.160891] CPU: 2 PID: 1562 Comm: ip Not tainted 4.13.0-rc6+ #62
[ 959.160998] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 959.161157] task: ffff880059c9a700 task.stack: ffff8800376d0000
[ 959.161263] RIP: 0010:qdisc_reset+0xa/0x5c
[ 959.161347] RSP: 0018:ffff8800376d3610 EFLAGS: 00010286
[ 959.161531] RAX: ffffffffa001b1dd RBX: ffff8800373a2800 RCX: 0000000000000000
[ 959.161733] RDX: ffffffff8215f160 RSI: ffffffff8215f160 RDI: 0000000000000000
[ 959.161939] RBP: ffff8800376d3618 R08: 00000000014080c0 R09: 00000000ffffffff
[ 959.162141] R10: ffff8800376d3578 R11: 0000000000000020 R12: ffffffffa001d2c0
[ 959.162343] R13: ffff880037538000 R14: 00000000ffffffff R15: 0000000000000001
[ 959.162546] FS: 00007fcc5126b740(0000) GS:ffff88005d900000(0000) knlGS:0000000000000000
[ 959.162844] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 959.163030] CR2: 0000000000000018 CR3: 000000005abc4000 CR4: 00000000000406e0
[ 959.163233] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 959.163436] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 959.163638] Call Trace:
[ 959.163788] tbf_reset+0x19/0x64 [sch_tbf]
[ 959.163957] qdisc_destroy+0x8b/0xe5
[ 959.164119] qdisc_create_dflt+0x86/0x94
[ 959.164284] ? dev_activate+0x129/0x129
[ 959.164449] attach_one_default_qdisc+0x36/0x63
[ 959.164623] netdev_for_each_tx_queue+0x3d/0x48
[ 959.164795] dev_activate+0x4b/0x129
[ 959.164957] __dev_open+0xe7/0x104
[ 959.165118] __dev_change_flags+0xc6/0x15c
[ 959.165287] dev_change_flags+0x25/0x59
[ 959.165451] do_setlink+0x30c/0xb3f
[ 959.165613] ? check_chain_key+0xb0/0xfd
[ 959.165782] rtnl_newlink+0x3a4/0x729
[ 959.165947] ? rtnl_newlink+0x117/0x729
[ 959.166121] ? ns_capable_common+0xd/0xb1
[ 959.166288] ? ns_capable+0x13/0x15
[ 959.166450] rtnetlink_rcv_msg+0x188/0x197
[ 959.166617] ? rcu_read_unlock+0x3e/0x5f
[ 959.166783] ? rtnl_newlink+0x729/0x729
[ 959.166948] netlink_rcv_skb+0x6c/0xce
[ 959.167113] rtnetlink_rcv+0x23/0x2a
[ 959.167273] netlink_unicast+0x103/0x181
[ 959.167439] netlink_sendmsg+0x326/0x337
[ 959.167607] sock_sendmsg_nosec+0x14/0x3f
[ 959.167772] sock_sendmsg+0x29/0x2e
[ 959.167932] ___sys_sendmsg+0x209/0x28b
[ 959.168098] ? do_raw_spin_unlock+0xcd/0xf8
[ 959.168267] ? _raw_spin_unlock+0x27/0x31
[ 959.168432] ? __handle_mm_fault+0x651/0xdb1
[ 959.168602] ? check_chain_key+0xb0/0xfd
[ 959.168773] __sys_sendmsg+0x45/0x63
[ 959.168934] ? __sys_sendmsg+0x45/0x63
[ 959.169100] SyS_sendmsg+0x19/0x1b
[ 959.169260] entry_SYSCALL_64_fastpath+0x23/0xc2
[ 959.169432] RIP: 0033:0x7fcc5097e690
[ 959.169592] RSP: 002b:00007ffd0d5c7b48 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 959.169887] RAX: ffffffffffffffda RBX: ffffffff810d278c RCX: 00007fcc5097e690
[ 959.170089] RDX: 0000000000000000 RSI: 00007ffd0d5c7b90 RDI: 0000000000000003
[ 959.170292] RBP: ffff8800376d3f98 R08: 0000000000000001 R09: 0000000000000003
[ 959.170494] R10: 00007ffd0d5c7910 R11: 0000000000000246 R12: 0000000000000006
[ 959.170697] R13: 000000000066f1a0 R14: 00007ffd0d5cfc40 R15: 0000000000000000
[ 959.170900] ? trace_hardirqs_off_caller+0xa7/0xcf
[ 959.171076] Code: 00 41 c7 84 24 14 01 00 00 00 00 00 00 41 c7 84 24
98 00 00 00 00 00 00 00 41 5c 41 5d 41 5e 5d c3 66 66 66 66 90 55 48 89
e5 53 <48> 8b 47 18 48 89 fb 48 8b 40 48 48 85 c0 74 02 ff d0 48 8b bb
[ 959.171637] RIP: qdisc_reset+0xa/0x5c RSP: ffff8800376d3610
[ 959.171821] CR2: 0000000000000018
Fixes: 87b60cfacf9f ("net_sched: fix error recovery at qdisc creation")
Fixes: 0fbbeb1ba43b ("[PKT_SCHED]: Fix missing qdisc_destroy() in qdisc_create_dflt()")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 634576a1844dba15bc5e6fc61d72f37e13a21615 upstream.
netem can fail in ->init due to missing options (either not supplied by
user-space or used as a default qdisc) causing a timer->base null
pointer deref in its ->destroy() and ->reset() callbacks.
Reproduce:
$ sysctl net.core.default_qdisc=netem
$ ip l set ethX up
Crash log:
[ 1814.846943] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1814.847181] IP: hrtimer_active+0x17/0x8a
[ 1814.847270] PGD 59c34067
[ 1814.847271] P4D 59c34067
[ 1814.847337] PUD 37374067
[ 1814.847403] PMD 0
[ 1814.847468]
[ 1814.847582] Oops: 0000 [#1] SMP
[ 1814.847655] Modules linked in: sch_netem(O) sch_fq_codel(O)
[ 1814.847761] CPU: 3 PID: 1573 Comm: ip Tainted: G O 4.13.0-rc6+ #62
[ 1814.847884] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 1814.848043] task: ffff88003723a700 task.stack: ffff88005adc8000
[ 1814.848235] RIP: 0010:hrtimer_active+0x17/0x8a
[ 1814.848407] RSP: 0018:ffff88005adcb590 EFLAGS: 00010246
[ 1814.848590] RAX: 0000000000000000 RBX: ffff880058e359d8 RCX: 0000000000000000
[ 1814.848793] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff880058e359d8
[ 1814.848998] RBP: ffff88005adcb5b0 R08: 00000000014080c0 R09: 00000000ffffffff
[ 1814.849204] R10: ffff88005adcb660 R11: 0000000000000020 R12: 0000000000000000
[ 1814.849410] R13: ffff880058e359d8 R14: 00000000ffffffff R15: 0000000000000001
[ 1814.849616] FS: 00007f733bbca740(0000) GS:ffff88005d980000(0000) knlGS:0000000000000000
[ 1814.849919] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1814.850107] CR2: 0000000000000000 CR3: 0000000059f0d000 CR4: 00000000000406e0
[ 1814.850313] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 1814.850518] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 1814.850723] Call Trace:
[ 1814.850875] hrtimer_try_to_cancel+0x1a/0x93
[ 1814.851047] hrtimer_cancel+0x15/0x20
[ 1814.851211] qdisc_watchdog_cancel+0x12/0x14
[ 1814.851383] netem_reset+0xe6/0xed [sch_netem]
[ 1814.851561] qdisc_destroy+0x8b/0xe5
[ 1814.851723] qdisc_create_dflt+0x86/0x94
[ 1814.851890] ? dev_activate+0x129/0x129
[ 1814.852057] attach_one_default_qdisc+0x36/0x63
[ 1814.852232] netdev_for_each_tx_queue+0x3d/0x48
[ 1814.852406] dev_activate+0x4b/0x129
[ 1814.852569] __dev_open+0xe7/0x104
[ 1814.852730] __dev_change_flags+0xc6/0x15c
[ 1814.852899] dev_change_flags+0x25/0x59
[ 1814.853064] do_setlink+0x30c/0xb3f
[ 1814.853228] ? check_chain_key+0xb0/0xfd
[ 1814.853396] ? check_chain_key+0xb0/0xfd
[ 1814.853565] rtnl_newlink+0x3a4/0x729
[ 1814.853728] ? rtnl_newlink+0x117/0x729
[ 1814.853905] ? ns_capable_common+0xd/0xb1
[ 1814.854072] ? ns_capable+0x13/0x15
[ 1814.854234] rtnetlink_rcv_msg+0x188/0x197
[ 1814.854404] ? rcu_read_unlock+0x3e/0x5f
[ 1814.854572] ? rtnl_newlink+0x729/0x729
[ 1814.854737] netlink_rcv_skb+0x6c/0xce
[ 1814.854902] rtnetlink_rcv+0x23/0x2a
[ 1814.855064] netlink_unicast+0x103/0x181
[ 1814.855230] netlink_sendmsg+0x326/0x337
[ 1814.855398] sock_sendmsg_nosec+0x14/0x3f
[ 1814.855584] sock_sendmsg+0x29/0x2e
[ 1814.855747] ___sys_sendmsg+0x209/0x28b
[ 1814.855912] ? do_raw_spin_unlock+0xcd/0xf8
[ 1814.856082] ? _raw_spin_unlock+0x27/0x31
[ 1814.856251] ? __handle_mm_fault+0x651/0xdb1
[ 1814.856421] ? check_chain_key+0xb0/0xfd
[ 1814.856592] __sys_sendmsg+0x45/0x63
[ 1814.856755] ? __sys_sendmsg+0x45/0x63
[ 1814.856923] SyS_sendmsg+0x19/0x1b
[ 1814.857083] entry_SYSCALL_64_fastpath+0x23/0xc2
[ 1814.857256] RIP: 0033:0x7f733b2dd690
[ 1814.857419] RSP: 002b:00007ffe1d3387d8 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 1814.858238] RAX: ffffffffffffffda RBX: ffffffff810d278c RCX: 00007f733b2dd690
[ 1814.858445] RDX: 0000000000000000 RSI: 00007ffe1d338820 RDI: 0000000000000003
[ 1814.858651] RBP: ffff88005adcbf98 R08: 0000000000000001 R09: 0000000000000003
[ 1814.858856] R10: 00007ffe1d3385a0 R11: 0000000000000246 R12: 0000000000000002
[ 1814.859060] R13: 000000000066f1a0 R14: 00007ffe1d3408d0 R15: 0000000000000000
[ 1814.859267] ? trace_hardirqs_off_caller+0xa7/0xcf
[ 1814.859446] Code: 10 55 48 89 c7 48 89 e5 e8 45 a1 fb ff 31 c0 5d c3
31 c0 c3 66 66 66 66 90 55 48 89 e5 41 56 41 55 41 54 53 49 89 fd 49 8b
45 30 <4c> 8b 20 41 8b 5c 24 38 31 c9 31 d2 48 c7 c7 50 8e 1d 82 41 89
[ 1814.860022] RIP: hrtimer_active+0x17/0x8a RSP: ffff88005adcb590
[ 1814.860214] CR2: 0000000000000000
commit 32db864d33c21fd70a217ba53cb7224889354ffb upstream.
If sch_hhf fails in its ->init() function (either due to wrong
user-space arguments as below or memory alloc failure of hh_flows) it
will do a null pointer deref of q->hh_flows in its ->destroy() function.
To reproduce the crash:
$ tc qdisc add dev eth0 root hhf quantum 2000000 non_hh_weight 10000000
Crash log:
[ 690.654882] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 690.655565] IP: hhf_destroy+0x48/0xbc
[ 690.655944] PGD 37345067
[ 690.655948] P4D 37345067
[ 690.656252] PUD 58402067
[ 690.656554] PMD 0
[ 690.656857]
[ 690.657362] Oops: 0000 [#1] SMP
[ 690.657696] Modules linked in:
[ 690.658032] CPU: 3 PID: 920 Comm: tc Not tainted 4.13.0-rc6+ #57
[ 690.658525] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 690.659255] task: ffff880058578000 task.stack: ffff88005acbc000
[ 690.659747] RIP: 0010:hhf_destroy+0x48/0xbc
[ 690.660146] RSP: 0018:ffff88005acbf9e0 EFLAGS: 00010246
[ 690.660601] RAX: 0000000000000000 RBX: 0000000000000020 RCX: 0000000000000000
[ 690.661155] RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffffffff821f63f0
[ 690.661710] RBP: ffff88005acbfa08 R08: ffffffff81b10a90 R09: 0000000000000000
[ 690.662267] R10: 00000000f42b7019 R11: ffff880058578000 R12: 00000000ffffffea
[ 690.662820] R13: ffff8800372f6400 R14: 0000000000000000 R15: 0000000000000000
[ 690.663769] FS: 00007f8ae5e8b740(0000) GS:ffff88005d980000(0000) knlGS:0000000000000000
[ 690.667069] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 690.667965] CR2: 0000000000000000 CR3: 0000000058523000 CR4: 00000000000406e0
[ 690.668918] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 690.669945] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 690.671003] Call Trace:
[ 690.671743] qdisc_create+0x377/0x3fd
[ 690.672534] tc_modify_qdisc+0x4d2/0x4fd
[ 690.673324] rtnetlink_rcv_msg+0x188/0x197
[ 690.674204] ? rcu_read_unlock+0x3e/0x5f
[ 690.675091] ? rtnl_newlink+0x729/0x729
[ 690.675877] netlink_rcv_skb+0x6c/0xce
[ 690.676648] rtnetlink_rcv+0x23/0x2a
[ 690.677405] netlink_unicast+0x103/0x181
[ 690.678179] netlink_sendmsg+0x326/0x337
[ 690.678958] sock_sendmsg_nosec+0x14/0x3f
[ 690.679743] sock_sendmsg+0x29/0x2e
[ 690.680506] ___sys_sendmsg+0x209/0x28b
[ 690.681283] ? __handle_mm_fault+0xc7d/0xdb1
[ 690.681915] ? check_chain_key+0xb0/0xfd
[ 690.682449] __sys_sendmsg+0x45/0x63
[ 690.682954] ? __sys_sendmsg+0x45/0x63
[ 690.683471] SyS_sendmsg+0x19/0x1b
[ 690.683974] entry_SYSCALL_64_fastpath+0x23/0xc2
[ 690.684516] RIP: 0033:0x7f8ae529d690
[ 690.685016] RSP: 002b:00007fff26d2d6b8 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 690.685931] RAX: ffffffffffffffda RBX: ffffffff810d278c RCX: 00007f8ae529d690
[ 690.686573] RDX: 0000000000000000 RSI: 00007fff26d2d700 RDI: 0000000000000003
[ 690.687047] RBP: ffff88005acbff98 R08: 0000000000000001 R09: 0000000000000000
[ 690.687519] R10: 00007fff26d2d480 R11: 0000000000000246 R12: 0000000000000002
[ 690.687996] R13: 0000000001258070 R14: 0000000000000001 R15: 0000000000000000
[ 690.688475] ? trace_hardirqs_off_caller+0xa7/0xcf
[ 690.688887] Code: 00 00 e8 2a 02 ae ff 49 8b bc 1d 60 02 00 00 48 83
c3 08 e8 19 02 ae ff 48 83 fb 20 75 dc 45 31 f6 4d 89 f7 4d 03 bd 20 02
00 00 <49> 8b 07 49 39 c7 75 24 49 83 c6 10 49 81 fe 00 40 00 00 75 e1
[ 690.690200] RIP: hhf_destroy+0x48/0xbc RSP: ffff88005acbf9e0
[ 690.690636] CR2: 0000000000000000
Fixes: 10239edf86f1 ("net-qdisc-hhf: Heavy-Hitter Filter (HHF) qdisc")
commit e89d469e3be3ed3d7124a803211a463ff83d0964 upstream.
The below commit added a call to ->destroy() on init failure, but multiq
still frees ->queues on error in init, but ->queues is also freed by
->destroy() thus we get double free and corrupted memory.
Very easy to reproduce (eth0 not multiqueue):
$ tc qdisc add dev eth0 root multiq
RTNETLINK answers: Operation not supported
$ ip l add dumdum type dummy
(crash)
Trace log:
[ 3929.467747] general protection fault: 0000 [#1] SMP
[ 3929.468083] Modules linked in:
[ 3929.468302] CPU: 3 PID: 967 Comm: ip Not tainted 4.13.0-rc6+ #56
[ 3929.468625] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 3929.469124] task: ffff88003716a700 task.stack: ffff88005872c000
[ 3929.469449] RIP: 0010:__kmalloc_track_caller+0x117/0x1be
[ 3929.469746] RSP: 0018:ffff88005872f6a0 EFLAGS: 00010246
[ 3929.470042] RAX: 00000000000002de RBX: 0000000058a59000 RCX: 00000000000002df
[ 3929.470406] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffffffff821f7020
[ 3929.470770] RBP: ffff88005872f6e8 R08: 000000000001f010 R09: 0000000000000000
[ 3929.471133] R10: ffff88005872f730 R11: 0000000000008cdd R12: ff006d75646d7564
[ 3929.471496] R13: 00000000014000c0 R14: ffff88005b403c00 R15: ffff88005b403c00
[ 3929.471869] FS: 00007f0b70480740(0000) GS:ffff88005d980000(0000) knlGS:0000000000000000
[ 3929.472286] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3929.472677] CR2: 00007ffcee4f3000 CR3: 0000000059d45000 CR4: 00000000000406e0
[ 3929.473209] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 3929.474109] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 3929.474873] Call Trace:
[ 3929.475337] ? kstrdup_const+0x23/0x25
[ 3929.475863] kstrdup+0x2e/0x4b
[ 3929.476338] kstrdup_const+0x23/0x25
[ 3929.478084] __kernfs_new_node+0x28/0xbc
[ 3929.478478] kernfs_new_node+0x35/0x55
[ 3929.478929] kernfs_create_link+0x23/0x76
[ 3929.479478] sysfs_do_create_link_sd.isra.2+0x85/0xd7
[ 3929.480096] sysfs_create_link+0x33/0x35
[ 3929.480649] device_add+0x200/0x589
[ 3929.481184] netdev_register_kobject+0x7c/0x12f
[ 3929.481711] register_netdevice+0x373/0x471
[ 3929.482174] rtnl_newlink+0x614/0x729
[ 3929.482610] ? rtnl_newlink+0x17f/0x729
[ 3929.483080] rtnetlink_rcv_msg+0x188/0x197
[ 3929.483533] ? rcu_read_unlock+0x3e/0x5f
[ 3929.483984] ? rtnl_newlink+0x729/0x729
[ 3929.484420] netlink_rcv_skb+0x6c/0xce
[ 3929.484858] rtnetlink_rcv+0x23/0x2a
[ 3929.485291] netlink_unicast+0x103/0x181
[ 3929.485735] netlink_sendmsg+0x326/0x337
[ 3929.486181] sock_sendmsg_nosec+0x14/0x3f
[ 3929.486614] sock_sendmsg+0x29/0x2e
[ 3929.486973] ___sys_sendmsg+0x209/0x28b
[ 3929.487340] ? do_raw_spin_unlock+0xcd/0xf8
[ 3929.487719] ? _raw_spin_unlock+0x27/0x31
[ 3929.488092] ? __handle_mm_fault+0x651/0xdb1
[ 3929.488471] ? check_chain_key+0xb0/0xfd
[ 3929.488847] __sys_sendmsg+0x45/0x63
[ 3929.489206] ? __sys_sendmsg+0x45/0x63
[ 3929.489576] SyS_sendmsg+0x19/0x1b
[ 3929.489901] entry_SYSCALL_64_fastpath+0x23/0xc2
[ 3929.490172] RIP: 0033:0x7f0b6fb93690
[ 3929.490423] RSP: 002b:00007ffcee4ed588 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 3929.490881] RAX: ffffffffffffffda RBX: ffffffff810d278c RCX: 00007f0b6fb93690
[ 3929.491198] RDX: 0000000000000000 RSI: 00007ffcee4ed5d0 RDI: 0000000000000003
[ 3929.491521] RBP: ffff88005872ff98 R08: 0000000000000001 R09: 0000000000000000
[ 3929.491801] R10: 00007ffcee4ed350 R11: 0000000000000246 R12: 0000000000000002
[ 3929.492075] R13: 000000000066f1a0 R14: 00007ffcee4f5680 R15: 0000000000000000
[ 3929.492352] ? trace_hardirqs_off_caller+0xa7/0xcf
[ 3929.492590] Code: 8b 45 c0 48 8b 45 b8 74 17 48 8b 4d c8 83 ca ff 44
89 ee 4c 89 f7 e8 83 ca ff ff 49 89 c4 eb 49 49 63 56 20 48 8d 48 01 4d
8b 06 <49> 8b 1c 14 48 89 c2 4c 89 e0 65 49 0f c7 08 0f 94 c0 83 f0 01
[ 3929.493335] RIP: __kmalloc_track_caller+0x117/0x1be RSP: ffff88005872f6a0
Fixes: f07d1501292b ("multiq: Further multiqueue cleanup")
[AmitP: Removed unused variable 'err' in multiq_init()]
commit 88c2ace69dbef696edba77712882af03879abc9c upstream.
The commit below added a call to the ->destroy() callback for all qdiscs
which failed in their ->init(), but some were not prepared for such
change and can't handle partially initialized qdisc. HTB is one of them
and if any error occurs before the qdisc watchdog timer and qdisc work are
initialized then we can hit either a null ptr deref (timer->base) when
canceling in ->destroy or lockdep error info about trying to register
a non-static key and a stack dump. So to fix these two move the watchdog
timer and workqueue init before anything that can err out.
To reproduce userspace needs to send broken htb qdisc create request,
tested with a modified tc (q_htb.c).
Trace log:
[ 2710.897602] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 2710.897977] IP: hrtimer_active+0x17/0x8a
[ 2710.898174] PGD 58fab067
[ 2710.898175] P4D 58fab067
[ 2710.898353] PUD 586c0067
[ 2710.898531] PMD 0
[ 2710.898710]
[ 2710.899045] Oops: 0000 [#1] SMP
[ 2710.899232] Modules linked in:
[ 2710.899419] CPU: 1 PID: 950 Comm: tc Not tainted 4.13.0-rc6+ #54
[ 2710.899646] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 2710.900035] task: ffff880059ed2700 task.stack: ffff88005ad4c000
[ 2710.900262] RIP: 0010:hrtimer_active+0x17/0x8a
[ 2710.900467] RSP: 0018:ffff88005ad4f960 EFLAGS: 00010246
[ 2710.900684] RAX: 0000000000000000 RBX: ffff88003701e298 RCX: 0000000000000000
[ 2710.900933] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88003701e298
[ 2710.901177] RBP: ffff88005ad4f980 R08: 0000000000000001 R09: 0000000000000001
[ 2710.901419] R10: ffff88005ad4f800 R11: 0000000000000400 R12: 0000000000000000
[ 2710.901663] R13: ffff88003701e298 R14: ffffffff822a4540 R15: ffff88005ad4fac0
[ 2710.901907] FS: 00007f2f5e90f740(0000) GS:ffff88005d880000(0000) knlGS:0000000000000000
[ 2710.902277] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 2710.902500] CR2: 0000000000000000 CR3: 0000000058ca3000 CR4: 00000000000406e0
[ 2710.902744] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 2710.902977] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 2710.903180] Call Trace:
[ 2710.903332] hrtimer_try_to_cancel+0x1a/0x93
[ 2710.903504] hrtimer_cancel+0x15/0x20
[ 2710.903667] qdisc_watchdog_cancel+0x12/0x14
[ 2710.903866] htb_destroy+0x2e/0xf7
[ 2710.904097] qdisc_create+0x377/0x3fd
[ 2710.904330] tc_modify_qdisc+0x4d2/0x4fd
[ 2710.904511] rtnetlink_rcv_msg+0x188/0x197
[ 2710.904682] ? rcu_read_unlock+0x3e/0x5f
[ 2710.904849] ? rtnl_newlink+0x729/0x729
[ 2710.905017] netlink_rcv_skb+0x6c/0xce
[ 2710.905183] rtnetlink_rcv+0x23/0x2a
[ 2710.905345] netlink_unicast+0x103/0x181
[ 2710.905511] netlink_sendmsg+0x326/0x337
[ 2710.905679] sock_sendmsg_nosec+0x14/0x3f
[ 2710.905847] sock_sendmsg+0x29/0x2e
[ 2710.906010] ___sys_sendmsg+0x209/0x28b
[ 2710.906176] ? do_raw_spin_unlock+0xcd/0xf8
[ 2710.906346] ? _raw_spin_unlock+0x27/0x31
[ 2710.906514] ? __handle_mm_fault+0x651/0xdb1
[ 2710.906685] ? check_chain_key+0xb0/0xfd
[ 2710.906855] __sys_sendmsg+0x45/0x63
[ 2710.907018] ? __sys_sendmsg+0x45/0x63
[ 2710.907185] SyS_sendmsg+0x19/0x1b
[ 2710.907344] entry_SYSCALL_64_fastpath+0x23/0xc2
Note that probably this bug goes further back because the default qdisc
handling always calls ->destroy on init failure too.
[AmitP: Rebased for linux-4.4.y]
The irda_setsockopt() function conditionally allocates memory for a new
self->ias_object or, in some cases, reuses the existing
self->ias_object. Existing objects were incorrectly reinserted into the
LM_IAS database which corrupted the doubly linked list used for the
hashbin implementation of the LM_IAS database. When combined with a
memory leak in irda_bind(), this issue could be leveraged to create a
use-after-free vulnerability in the hashbin list. This patch fixes the
issue by only inserting newly allocated objects into the database.
CVE-2018-6555
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Reviewed-by: Seth Arnold <seth.arnold@canonical.com>
Reviewed-by: Stefan Bader <stefan.bader@canonical.com>
The irda_bind() function allocates memory for self->ias_obj without
checking to see if the socket is already bound. A userspace process
could repeatedly bind the socket, have each new object added into the
LM-IAS database, and lose the reference to the old object assigned to
the socket to exhaust memory resources. This patch errors out of the
bind operation when self->ias_obj is already assigned.
CVE-2018-6554
[ Upstream commit 92aef4675d5b1b55404e1532379e343bed0e5cf2 ]
Currently when virtio_find_single_vq fails, we go through del_vqs which
throws a warning (Trying to free already-free IRQ). Skip del_vqs if vq
allocation failed.
Link: http://lkml.kernel.org/r/20180524101021.49880-1-jean-philippe.brucker@arm.com
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
Reviewed-by: Greg Kurz <groug@kaod.org>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
[ Upstream commit a53b42c11815d2357e31a9403ae3950517525894 ]
We came across infinite loop in ipvs when using ipvs in docker
env.
When ipvs receives new packets and cannot find an ipvs connection,
it will create a new connection, then if the dest is unavailable
(i.e. IP_VS_DEST_F_AVAILABLE), the packet will be dropped sliently.
But if the dropped packet is the first packet of this connection,
the connection control timer never has a chance to start and the
ipvs connection cannot be released. This will lead to memory leak, or
infinite loop in cleanup_net() when net namespace is released like
this:
ip_vs_conn_net_cleanup at ffffffffa0a9f31a [ip_vs]
__ip_vs_cleanup at ffffffffa0a9f60a [ip_vs]
ops_exit_list at ffffffff81567a49
cleanup_net at ffffffff81568b40
process_one_work at ffffffff810a851b
worker_thread at ffffffff810a9356
kthread at ffffffff810b0b6f
ret_from_fork at ffffffff81697a18
race condition:
CPU1 CPU2
ip_vs_in()
ip_vs_conn_new()
ip_vs_del_dest()
__ip_vs_unlink_dest()
~IP_VS_DEST_F_AVAILABLE
cp->dest && !IP_VS_DEST_F_AVAILABLE
__ip_vs_conn_put
cleanup_net ---> infinite looping
Fix this by checking whether the timer already started.
Signed-off-by: Tan Hu <tan.hu@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Acked-by: Julian Anastasov <ja@ssi.bg>
Acked-by: Simon Horman <horms@verge.net.au>
[ Upstream commit 9f2895461439fda2801a7906fb4c5fb3dbb37a0a ]
Before the commit d6990976af7c ("vti6: fix PMTU caching and reporting
on xmit") '!skb->ignore_df' check was always true because the function
skb_scrub_packet() was called before it, resetting ignore_df to zero.
In the commit, skb_scrub_packet() was moved below, and now this check
can be false for the packet, e.g. when sending it in the two fragments,
this prevents successful PMTU updates in such case. The next attempts
to send the packet lead to the same tx error. Moreover, vti6 initial
MTU value relies on PMTU adjustments.
This issue can be reproduced with the following LTP test script:
udp_ipsec_vti.sh -6 -p ah -m tunnel -s 2000
Fixes: ccd740cbc6e0 ("vti6: Add pmtu handling to vti6_xmit.")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 63cc357f7bba6729869565a12df08441a5995d9a ]
RFC 1337 says:
''Ignore RST segments in TIME-WAIT state.
If the 2 minute MSL is enforced, this fix avoids all three hazards.''
So with net.ipv4.tcp_rfc1337=1, expected behaviour is to have TIME-WAIT sk
expire rather than removing it instantly when a reset is received.
However, Linux will also re-start the TIME-WAIT timer.
This causes connect to fail when tying to re-use ports or very long
delays (until syn retry interval exceeds MSL).
packetdrill test case:
// Demonstrate bogus rearming of TIME-WAIT timer in rfc1337 mode.
`sysctl net.ipv4.tcp_rfc1337=1`
0.000 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
0.000 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
0.000 bind(3, ..., ...) = 0
0.000 listen(3, 1) = 0
0.100 < S 0:0(0) win 29200 <mss 1460,nop,nop,sackOK,nop,wscale 7>
0.100 > S. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK,nop,wscale 7>
0.200 < . 1:1(0) ack 1 win 257
0.200 accept(3, ..., ...) = 4
// Receive first segment
0.310 < P. 1:1001(1000) ack 1 win 46
// Send one ACK
0.310 > . 1:1(0) ack 1001
// read 1000 byte
0.310 read(4, ..., 1000) = 1000
// Application writes 100 bytes
0.350 write(4, ..., 100) = 100
0.350 > P. 1:101(100) ack 1001
// ACK
0.500 < . 1001:1001(0) ack 101 win 257
// close the connection
0.600 close(4) = 0
0.600 > F. 101:101(0) ack 1001 win 244
// Our side is in FIN_WAIT_1 & waits for ack to fin
0.7 < . 1001:1001(0) ack 102 win 244
// Our side is in FIN_WAIT_2 with no outstanding data.
0.8 < F. 1001:1001(0) ack 102 win 244
0.8 > . 102:102(0) ack 1002 win 244
// Our side is now in TIME_WAIT state, send ack for fin.
0.9 < F. 1002:1002(0) ack 102 win 244
0.9 > . 102:102(0) ack 1002 win 244
// Peer reopens with in-window SYN:
1.000 < S 1000:1000(0) win 9200 <mss 1460,nop,nop,sackOK,nop,wscale 7>
// Therefore, reply with ACK.
1.000 > . 102:102(0) ack 1002 win 244
// Peer sends RST for this ACK. Normally this RST results
// in tw socket removal, but rfc1337=1 setting prevents this.
1.100 < R 1002:1002(0) win 244
// second syn. Due to rfc1337=1 expect another pure ACK.
31.0 < S 1000:1000(0) win 9200 <mss 1460,nop,nop,sackOK,nop,wscale 7>
31.0 > . 102:102(0) ack 1002 win 244
// .. and another RST from peer.
31.1 < R 1002:1002(0) win 244
31.2 `echo no timer restart;ss -m -e -a -i -n -t -o state TIME-WAIT`
// third syn after one minute. Time-Wait socket should have expired by now.
63.0 < S 1000:1000(0) win 9200 <mss 1460,nop,nop,sackOK,nop,wscale 7>
// so we expect a syn-ack & 3whs to proceed from here on.
63.0 > S. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK,nop,wscale 7>
Without this patch, 'ss' shows restarts of tw timer and last packet is
thus just another pure ack, more than one minute later.
This restores the original code from commit 283fd6cf0be690a83
("Merge in ANK networking jumbo patch") in netdev-vger-cvs.git .
For some reason the else branch was removed/lost in 1f28b683339f7
("Merge in TCP/UDP optimizations and [..]") and timer restart became
unconditional.
Reported-by: Michal Tesar <mtesar@redhat.com>
commit 10aa14527f458e9867cf3d2cc6b8cb0f6704448b upstream.
Added checks to prevent GPFs from raising.
Link: http://lkml.kernel.org/r/20180727110558.5479-1-tomasbortoli@gmail.com
Signed-off-by: Tomas Bortoli <tomasbortoli@gmail.com>
Reported-by: syzbot+1a262da37d3bead15c39@syzkaller.appspotmail.com
Cc: stable@vger.kernel.org
commit 430ac66eb4c5b5c4eb846b78ebf65747510b30f1 upstream.
The patch adds the flush in p9_mux_poll_stop() as it the function used by
p9_conn_destroy(), in turn called by p9_fd_close() to stop the async
polling associated with the data regarding the connection.
Link: http://lkml.kernel.org/r/20180720092730.27104-1-tomasbortoli@gmail.com
Reported-by: syzbot+39749ed7d9ef6dfb23f6@syzkaller.appspotmail.com
To: Eric Van Hensbergen <ericvh@gmail.com>
To: Ron Minnich <rminnich@sandia.gov>
To: Latchesar Ionkov <lucho@ionkov.net>
Cc: Yiwen Jiang <jiangyiwen@huwei.com>
commit 7913690dcc5e18e235769fd87c34143072f5dbea upstream.
The p9_client_version() does not initialize the version pointer. If the
call to p9pdu_readf() returns an error and version has not been allocated
in p9pdu_readf(), then the program will jump to the "error" label and will
try to free the version pointer. If version is not initialized, free()
will be called with uninitialized, garbage data and will provoke a crash.
Link: http://lkml.kernel.org/r/20180709222943.19503-1-tomasbortoli@gmail.com
Reported-by: syzbot+65c6b72f284a39d416b4@syzkaller.appspotmail.com
Reviewed-by: Jun Piao <piaojun@huawei.com>
Reviewed-by: Yiwen Jiang <jiangyiwen@huawei.com>
commit 23cba9cbde0bba05d772b335fe5f66aa82b9ad19 upstream.
Because the value of limit is VIRTQUEUE_NUM, if index is equal to
limit, it will cause sg array out of bounds, so correct the judgement
of BUG_ON.
Link: http://lkml.kernel.org/r/5B63D5F6.6080109@huawei.com
Signed-off-by: Yiwen Jiang <jiangyiwen@huawei.com>
Reported-By: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Jun Piao <piaojun@huawei.com>
commit d28c756caee6e414d9ba367d0b92da24145af2a8 upstream.
The zero-copy optimization when reading or writing large chunks of data
is quite useful. However, the 9p messages created through the zero-copy
write path have an incorrect message size: it should be the size of the
header + size of the data being written but instead it's just the size
of the header.
This only works if the server ignores the size field of the message and
otherwise breaks the framing of the protocol. Fix this by re-writing the
message size field with the correct value.
Tested by running `dd if=/dev/zero of=out bs=4k count=1` inside a
virtio-9p mount.
Link: http://lkml.kernel.org/r/20180717003529.114368-1-chirantan@chromium.org
Signed-off-by: Chirantan Ekbote <chirantan@chromium.org>
Tested-by: Greg Kurz <groug@kaod.org>
Cc: Dylan Reid <dgreid@chromium.org>
Cc: Guenter Roeck <groeck@chromium.org>
commit f9c52831133050c6b82aa8b6831c92da2bbf2a0b upstream.
This patch is necessary if case of AF_PACKET or other socket interface
which I am aware of it and didn't allocated the necessary room.
Reported-by: David Palma <david.palma@ntnu.no>
Reported-by: Rabi Narayan Sahoo <rabinarayans0828@gmail.com>
Signed-off-by: Alexander Aring <aring@mojatatu.com>
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
commit ac74f87c789af40936a80131c4759f3e72579c3a upstream.
This patch fixes patch add handling to take care tail and headroom for
single 6lowpan frames. We need to be sure we have a skb with the right
head and tailroom for single frames. This patch do it by using
skb_copy_expand() if head and tailroom is not enough allocated by upper
layer.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195059
[ Upstream commit 64119e05f7b31e83e2555f6782e6cdc8f81c63f4 ]
Add a missing rcu_read_unlock in the error path
Fixes: c95567c80352 ("caif: added check for potential null return")
[ Upstream commit 5cf3006cc81d9aa09a10aa781fc065546b12919d ]
I was looking at usually suppressed gcc warnings,
[-Wimplicit-fallthrough=] in this case:
The code definitely looks like a break is missing here.
However I am not able to test the NL80211_IFTYPE_MESH_POINT,
nor do I actually know what might be :)
So please use this patch with caution and only if you are
able to do some testing.
Signed-off-by: Bernd Edlinger <bernd.edlinger@hotmail.de>
[johannes: looks obvious enough to apply as is, interesting
though that it never seems to have been a problem]
[ Upstream commit 19103a4bfb42f320395daa5616ece3e89e759d63 ]
As part of hw reconfig, only stations linked to AP interfaces are added
back to the driver ignoring those which are tied to AP_VLAN interfaces.
It is true that there could be stations tied to the AP_VLAN interface while
serving 4addr clients or when using AP_VLAN for VLAN operations; we should
be adding these stations back to the driver as part of hw reconfig, failing
to do so can cause functional issues.
In the case of ath10k driver, the following errors were observed.
ath10k_pci : failed to install key for non-existent peer XX:XX:XX:XX:XX:XX
Workqueue: events_freezable ieee80211_restart_work [mac80211]
(unwind_backtrace) from (show_stack+0x10/0x14)
(show_stack) (dump_stack+0x80/0xa0)
(dump_stack) (warn_slowpath_common+0x68/0x8c)
(warn_slowpath_null) (ieee80211_enable_keys+0x88/0x154 [mac80211])
(ieee80211_enable_keys) (ieee80211_reconfig+0xc90/0x19c8 [mac80211])
(ieee80211_reconfig]) (ieee80211_restart_work+0x8c/0xa0 [mac80211])
(ieee80211_restart_work) (process_one_work+0x284/0x488)
(process_one_work) (worker_thread+0x228/0x360)
(worker_thread) (kthread+0xd8/0xec)
(kthread) (ret_from_fork+0x14/0x24)
Also while bringing down the AP VAP, WARN_ONs and errors related to peer
removal were observed.
ath10k_pci : failed to clear all peer wep keys for vdev 0: -2
ath10k_pci : failed to disassociate station: 8c:fd:f0:0a:8c:f5 vdev 0: -2
(unwind_backtrace) (show_stack+0x10/0x14)
(warn_slowpath_null) (sta_set_sinfo+0xb98/0xc9c [mac80211])
(sta_set_sinfo [mac80211]) (__sta_info_flush+0xf0/0x134 [mac80211])
(__sta_info_flush [mac80211]) (ieee80211_stop_ap+0xe8/0x390 [mac80211])
(ieee80211_stop_ap [mac80211]) (__cfg80211_stop_ap+0xe0/0x3dc [cfg80211])
(__cfg80211_stop_ap [cfg80211]) (cfg80211_stop_ap+0x30/0x44 [cfg80211])
(cfg80211_stop_ap [cfg80211]) (genl_rcv_msg+0x274/0x30c)
(genl_rcv_msg) (netlink_rcv_skb+0x58/0xac)
(netlink_rcv_skb) (genl_rcv+0x20/0x34)
(genl_rcv) (netlink_unicast+0x11c/0x204)
(netlink_unicast) (netlink_sendmsg+0x30c/0x370)
(netlink_sendmsg) (sock_sendmsg+0x70/0x84)
(sock_sendmsg) (___sys_sendmsg.part.3+0x188/0x228)
(___sys_sendmsg.part.3) (__sys_sendmsg+0x4c/0x70)
(__sys_sendmsg) (ret_fast_syscall+0x0/0x44)
These issues got fixed by adding the stations which are
tied to AP_VLANs back to the driver.
[ Upstream commit 86126b77dcd551ce223e7293bb55854e3df05646 ]
nlmsg_multicast() always frees the skb, so in case we cannot call
it we must do that ourselves.
Fixes: 21ee543edc0dea ("xfrm: fix race between netns cleanup and state expire notification")
[ Upstream commit 8cc88773855f988d6a3bbf102bbd9dd9c828eb81 ]
Fix missing dst_release() when local broadcast or multicast traffic is
xfrm policy blocked.
For IPv4 this results to dst leak: ip_route_output_flow() allocates
dst_entry via __ip_route_output_key() and passes it to
xfrm_lookup_route(). xfrm_lookup returns ERR_PTR(-EPERM) that is
propagated. The dst that was allocated is never released.
IPv4 local broadcast testcase:
ping -b 192.168.1.255 &
sleep 1
ip xfrm policy add src 0.0.0.0/0 dst 192.168.1.255/32 dir out action block
IPv4 multicast testcase:
ping 224.0.0.1 &
sleep 1
ip xfrm policy add src 0.0.0.0/0 dst 224.0.0.1/32 dir out action block
For IPv6 the missing dst_release() causes trouble e.g. when used in netns:
ip netns add TEST
ip netns exec TEST ip link set lo up
ip link add dummy0 type dummy
ip link set dev dummy0 netns TEST
ip netns exec TEST ip addr add fd00::1111 dev dummy0
ip netns exec TEST ip link set dummy0 up
ip netns exec TEST ping -6 -c 5 ff02::1%dummy0 &
sleep 1
ip netns exec TEST ip xfrm policy add src ::/0 dst ff02::1 dir out action block
wait
ip netns del TEST
After netns deletion we see:
[ 258.239097] unregister_netdevice: waiting for lo to become free. Usage count = 2
[ 268.279061] unregister_netdevice: waiting for lo to become free. Usage count = 2
[ 278.367018] unregister_netdevice: waiting for lo to become free. Usage count = 2
[ 288.375259] unregister_netdevice: waiting for lo to become free. Usage count = 2
Fixes: ac37e2515c1a ("xfrm: release dst_orig in case of error in xfrm_lookup()")
Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com>
[ Upstream commit d6990976af7c5d8f55903bfb4289b6fb030bf754 ]
When setting the skb->dst before doing the MTU check, the route PMTU
caching and reporting is done on the new dst which is about to be
released.
Instead, PMTU handling should be done using the original dst.
This is aligned with IPv4 VTI.
Fixes: ccd740cbc6 ("vti6: Add pmtu handling to vti6_xmit.")
Signed-off-by: Eyal Birger <eyal.birger@gmail.com>
commit 40413955ee265a5e42f710940ec78f5450d49149 upstream.
in for(),if((optlen > 0) && (optptr[1] == 0)), enter infinite loop.
Test: receive a packet which the ip length > 20 and the first byte of ip option is 0, produce this issue
Signed-off-by: yujuan.qi <yujuan.qi@mediatek.com>
Acked-by: Paul Moore <paul@paul-moore.com>
commit 08474cc1e6ea71237cab7e4a651a623c9dea1084 upstream.
Disallow adding interfaces to a bridge when vlan filtering operation
failed. Send the failure code to the user.
Signed-off-by: Elad Raz <eladr@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Signed-off-by: SZ Lin (林上智) <sz.lin@moxa.com>
commit 4576cd469d980317c4edd9173f8b694aa71ea3a3 upstream.
TPACKET_V3 stores variable length frames in fixed length blocks.
Blocks must be able to store a block header, optional private space
and at least one minimum sized frame.
Frames, even for a zero snaplen packet, store metadata headers and
optional reserved space.
In the block size bounds check, ensure that the frame of the
chosen configuration fits. This includes sockaddr_ll and optional
tp_reserve.
Syzbot was able to construct a ring with insuffient room for the
sockaddr_ll in the header of a zero-length frame, triggering an
out-of-bounds write in dev_parse_header.
Convert the comparison to less than, as zero is a valid snap len.
This matches the test for minimum tp_frame_size immediately below.
Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.")
Fixes: eb73190f4fbe ("net/packet: refine check for priv area size")
Signed-off-by: Willem de Bruijn <willemb@google.com>
commit 6613b6173dee098997229caf1f3b961c49da75e6 upstream.
When first DCCP packet is SYNC or SYNCACK, we insert a new conntrack
that has an un-initialized timeout value, i.e. such entry could be
reaped at any time.
Mark them as INVALID and only ignore SYNC/SYNCACK when connection had
an old state.
Reported-by: syzbot+6f18401420df260e37ed@syzkaller.appspotmail.com
commit 45c180bc29babbedd6b8c01b975780ef44d9d09c upstream.
struct xfrm_userpolicy_type has two holes, so we should not
use C99 style initializer.
KMSAN report:
BUG: KMSAN: kernel-infoleak in copyout lib/iov_iter.c:140 [inline]
BUG: KMSAN: kernel-infoleak in _copy_to_iter+0x1b14/0x2800 lib/iov_iter.c:571
CPU: 1 PID: 4520 Comm: syz-executor841 Not tainted 4.17.0+ #5
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:113
kmsan_report+0x188/0x2a0 mm/kmsan/kmsan.c:1117
kmsan_internal_check_memory+0x138/0x1f0 mm/kmsan/kmsan.c:1211
kmsan_copy_to_user+0x7a/0x160 mm/kmsan/kmsan.c:1253
copy_to_iter include/linux/uio.h:106 [inline]
skb_copy_datagram_iter+0x422/0xfa0 net/core/datagram.c:431
skb_copy_datagram_msg include/linux/skbuff.h:3268 [inline]
netlink_recvmsg+0x6f1/0x1900 net/netlink/af_netlink.c:1959
sock_recvmsg_nosec net/socket.c:802 [inline]
sock_recvmsg+0x1d6/0x230 net/socket.c:809
___sys_recvmsg+0x3fe/0x810 net/socket.c:2279
__sys_recvmmsg+0x58e/0xe30 net/socket.c:2391
do_sys_recvmmsg+0x2a6/0x3e0 net/socket.c:2472
__do_sys_recvmmsg net/socket.c:2485 [inline]
__se_sys_recvmmsg net/socket.c:2481 [inline]
__x64_sys_recvmmsg+0x15d/0x1c0 net/socket.c:2481
do_syscall_64+0x15b/0x230 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x446ce9
RSP: 002b:00007fc307918db8 EFLAGS: 00000293 ORIG_RAX: 000000000000012b
RAX: ffffffffffffffda RBX: 00000000006dbc24 RCX: 0000000000446ce9
RDX: 000000000000000a RSI: 0000000020005040 RDI: 0000000000000003
RBP: 00000000006dbc20 R08: 0000000020004e40 R09: 0000000000000000
R10: 0000000040000000 R11: 0000000000000293 R12: 0000000000000000
R13: 00007ffc8d2df32f R14: 00007fc3079199c0 R15: 0000000000000001
Uninit was stored to memory at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline]
kmsan_save_stack mm/kmsan/kmsan.c:294 [inline]
kmsan_internal_chain_origin+0x12b/0x210 mm/kmsan/kmsan.c:685
kmsan_memcpy_origins+0x11d/0x170 mm/kmsan/kmsan.c:527
__msan_memcpy+0x109/0x160 mm/kmsan/kmsan_instr.c:413
__nla_put lib/nlattr.c:569 [inline]
nla_put+0x276/0x340 lib/nlattr.c:627
copy_to_user_policy_type net/xfrm/xfrm_user.c:1678 [inline]
dump_one_policy+0xbe1/0x1090 net/xfrm/xfrm_user.c:1708
xfrm_policy_walk+0x45a/0xd00 net/xfrm/xfrm_policy.c:1013
xfrm_dump_policy+0x1c0/0x2a0 net/xfrm/xfrm_user.c:1749
netlink_dump+0x9b5/0x1550 net/netlink/af_netlink.c:2226
__netlink_dump_start+0x1131/0x1270 net/netlink/af_netlink.c:2323
netlink_dump_start include/linux/netlink.h:214 [inline]
xfrm_user_rcv_msg+0x8a3/0x9b0 net/xfrm/xfrm_user.c:2577
netlink_rcv_skb+0x37e/0x600 net/netlink/af_netlink.c:2448
xfrm_netlink_rcv+0xb2/0xf0 net/xfrm/xfrm_user.c:2598
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0x1680/0x1750 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901
sock_sendmsg_nosec net/socket.c:629 [inline]
sock_sendmsg net/socket.c:639 [inline]
___sys_sendmsg+0xec8/0x1320 net/socket.c:2117
__sys_sendmsg net/socket.c:2155 [inline]
__do_sys_sendmsg net/socket.c:2164 [inline]
__se_sys_sendmsg net/socket.c:2162 [inline]
__x64_sys_sendmsg+0x331/0x460 net/socket.c:2162
Local variable description: ----upt.i@dump_one_policy
Variable was created at:
dump_one_policy+0x78/0x1090 net/xfrm/xfrm_user.c:1689
Byte 130 of 137 is uninitialized
Memory access starts at ffff88019550407f
Fixes: c0144beaeca42 ("[XFRM] netlink: Use nla_put()/NLA_PUT() variantes")
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit e56b8ce363a36fb7b74b80aaa5cc9084f2c908b4 ]
Attempt to make cryptic TCP seq number error messages clearer by
(1) identifying the source of the message as "TCP", (2) identifying the
errors as "seq # bug", and (3) grouping the field identifiers and values
by separating them with commas.
E.g., the following message is changed from:
recvmsg bug 2: copied 73BCB6CD seq 70F17CBE rcvnxt 73BCB9AA fl 0
WARNING: CPU: 2 PID: 1501 at /linux/net/ipv4/tcp.c:1881 tcp_recvmsg+0x649/0xb90
to:
TCP recvmsg seq # bug 2: copied 73BCB6CD, seq 70F17CBE, rcvnxt 73BCB9AA, fl 0
WARNING: CPU: 2 PID: 1501 at /linux/net/ipv4/tcp.c:2011 tcp_recvmsg+0x694/0xba0
Suggested-by: 積丹尼 Dan Jacobson <jidanni@jidanni.org>
[ Upstream commit a69258f7aa2623e0930212f09c586fd06674ad79 ]
After fixing the way DCTCP tracking delayed ACKs, the delayed-ACK
related callbacks are no longer needed
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Lawrence Brakmo <brakmo@fb.com>
[ Upstream commit 993675a3100b16a4c80dfd70cbcde8ea7127b31d ]
If variable length link layer headers result in a packet shorter
than dev->hard_header_len, reset the network header offset. Else
skb->mac_len may exceed skb->len after skb_mac_reset_len.
packet_sendmsg_spkt already has similar logic.
Fixes: b84bbaf7a6c8 ("packet: in packet_snd start writing at link layer allocation")
[ Upstream commit d376bef9c29b3c65aeee4e785fffcd97ef0a9a81 ]
nft_compat relies on xt_request_find_match to increment
refcount of the module that provides the match/target.
The (builtin) icmp matches did't set the module owner so it
was possible to rmmod ip(6)tables while icmp extensions were still in use.
[ Upstream commit 6c6da92808442908287fae8ebb0ca041a52469f4 ]
After recieving MLD querys, we update idev->mc_maxdelay with max_delay
from query header. This make the later unsolicited reports have the same
interval with mc_maxdelay, which means we may send unsolicited reports with
long interval time instead of default configured interval time.
Also as we will not call ipv6_mc_reset() after device up. This issue will
be there even after leave the group and join other groups.
Fixes: fc4eba58b4c14 ("ipv6: make unsolicited report intervals configurable for mld")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit 7892bd081045222b9e4027fec279a28d6fe7aa66 ]
if dev_get_valid_name failed, propagate its return code
and remove the setting err to ENODEV, it will be set to
0 again before dev_change_net_namespace exits.
Signed-off-by: Li RongQing <lirongqing@baidu.com>
[ Upstream commit 9ce7bc036ae4cfe3393232c86e9e1fea2153c237 ]
It is a waste of memory to use a full "struct netns_sysctl_ipv6"
while only one pointer is really used, considering netns_sysctl_ipv6
keeps growing.
Also, since "struct netns_frags" has cache line alignment,
it is better to move the frags_hdr pointer outside, otherwise
we spend a full cache line for this pointer.
This saves 192 bytes of memory per netns.
Fixes: c038a767cd69 ("ipv6: add a new namespace for nf_conntrack_reasm")
commit 4e1a720d0312fd510699032c7694a362a010170f upstream.
slub debug reported:
[ 440.648642] =============================================================================
[ 440.648649] BUG kmalloc-1024 (Tainted: G BU O ): Poison overwritten
[ 440.648651] -----------------------------------------------------------------------------
[ 440.648655] INFO: 0xe70f4bec-0xe70f4bec. First byte 0x6a instead of 0x6b
[ 440.648665] INFO: Allocated in sk_prot_alloc+0x6b/0xc6 age=33155 cpu=1 pid=1047
[ 440.648671] ___slab_alloc.constprop.24+0x1fc/0x292
[ 440.648675] __slab_alloc.isra.18.constprop.23+0x1c/0x25
[ 440.648677] __kmalloc+0xb6/0x17f
[ 440.648680] sk_prot_alloc+0x6b/0xc6
[ 440.648683] sk_alloc+0x1e/0xa1
[ 440.648700] sco_sock_alloc.constprop.6+0x26/0xaf [bluetooth]
[ 440.648716] sco_connect_cfm+0x166/0x281 [bluetooth]
[ 440.648731] hci_conn_request_evt.isra.53+0x258/0x281 [bluetooth]
[ 440.648746] hci_event_packet+0x28b/0x2326 [bluetooth]
[ 440.648759] hci_rx_work+0x161/0x291 [bluetooth]
[ 440.648764] process_one_work+0x163/0x2b2
[ 440.648767] worker_thread+0x1a9/0x25c
[ 440.648770] kthread+0xf8/0xfd
[ 440.648774] ret_from_fork+0x2e/0x38
[ 440.648779] INFO: Freed in __sk_destruct+0xd3/0xdf age=3815 cpu=1 pid=1047
[ 440.648782] __slab_free+0x4b/0x27a
[ 440.648784] kfree+0x12e/0x155
[ 440.648787] __sk_destruct+0xd3/0xdf
[ 440.648790] sk_destruct+0x27/0x29
[ 440.648793] __sk_free+0x75/0x91
[ 440.648795] sk_free+0x1c/0x1e
[ 440.648810] sco_sock_kill+0x5a/0x5f [bluetooth]
[ 440.648825] sco_conn_del+0x8e/0xba [bluetooth]
[ 440.648840] sco_disconn_cfm+0x3a/0x41 [bluetooth]
[ 440.648855] hci_event_packet+0x45e/0x2326 [bluetooth]
[ 440.648868] hci_rx_work+0x161/0x291 [bluetooth]
[ 440.648872] process_one_work+0x163/0x2b2
[ 440.648875] worker_thread+0x1a9/0x25c
[ 440.648877] kthread+0xf8/0xfd
[ 440.648880] ret_from_fork+0x2e/0x38
[ 440.648884] INFO: Slab 0xf4718580 objects=27 used=27 fp=0x (null) flags=0x40008100
[ 440.648886] INFO: Object 0xe70f4b88 @offset=19336 fp=0xe70f54f8
When KASAN was enabled, it reported:
[ 210.096613] ==================================================================
[ 210.096634] BUG: KASAN: use-after-free in ex_handler_refcount+0x5b/0x127
[ 210.096641] Write of size 4 at addr ffff880107e17160 by task kworker/u9:1/2040
[ 210.096651] CPU: 1 PID: 2040 Comm: kworker/u9:1 Tainted: G U O 4.14.47-20180606+ #2
[ 210.096654] Hardware name: , BIOS 2017.01-00087-g43e04de 08/30/2017
[ 210.096693] Workqueue: hci0 hci_rx_work [bluetooth]
[ 210.096698] Call Trace:
[ 210.096711] dump_stack+0x46/0x59
[ 210.096722] print_address_description+0x6b/0x23b
[ 210.096729] ? ex_handler_refcount+0x5b/0x127
[ 210.096736] kasan_report+0x220/0x246
[ 210.096744] ex_handler_refcount+0x5b/0x127
[ 210.096751] ? ex_handler_clear_fs+0x85/0x85
[ 210.096757] fixup_exception+0x8c/0x96
[ 210.096766] do_trap+0x66/0x2c1
[ 210.096773] do_error_trap+0x152/0x180
[ 210.096781] ? fixup_bug+0x78/0x78
[ 210.096817] ? hci_debugfs_create_conn+0x244/0x26a [bluetooth]
[ 210.096824] ? __schedule+0x113b/0x1453
[ 210.096830] ? sysctl_net_exit+0xe/0xe
[ 210.096837] ? __wake_up_common+0x343/0x343
[ 210.096843] ? insert_work+0x107/0x163
[ 210.096850] invalid_op+0x1b/0x40
[ 210.096888] RIP: 0010:hci_debugfs_create_conn+0x244/0x26a [bluetooth]
[ 210.096892] RSP: 0018:ffff880094a0f970 EFLAGS: 00010296
[ 210.096898] RAX: 0000000000000000 RBX: ffff880107e170e8 RCX: ffff880107e17160
[ 210.096902] RDX: 000000000000002f RSI: ffff88013b80ed40 RDI: ffffffffa058b940
[ 210.096906] RBP: ffff88011b2b0578 R08: 00000000852f0ec9 R09: ffffffff81cfcf9b
[ 210.096909] R10: 00000000d21bdad7 R11: 0000000000000001 R12: ffff8800967b0488
[ 210.096913] R13: ffff880107e17168 R14: 0000000000000068 R15: ffff8800949c0008
[ 210.096920] ? __sk_destruct+0x2c6/0x2d4
[ 210.096959] hci_event_packet+0xff5/0x7de2 [bluetooth]
[ 210.096969] ? __local_bh_enable_ip+0x43/0x5b
[ 210.097004] ? l2cap_sock_recv_cb+0x158/0x166 [bluetooth]
[ 210.097039] ? hci_le_meta_evt+0x2bb3/0x2bb3 [bluetooth]
[ 210.097075] ? l2cap_ertm_init+0x94e/0x94e [bluetooth]
[ 210.097093] ? xhci_urb_enqueue+0xbd8/0xcf5 [xhci_hcd]
[ 210.097102] ? __accumulate_pelt_segments+0x24/0x33
[ 210.097109] ? __accumulate_pelt_segments+0x24/0x33
[ 210.097115] ? __update_load_avg_se.isra.2+0x217/0x3a4
[ 210.097122] ? set_next_entity+0x7c3/0x12cd
[ 210.097128] ? pick_next_entity+0x25e/0x26c
[ 210.097135] ? pick_next_task_fair+0x2ca/0xc1a
[ 210.097141] ? switch_mm_irqs_off+0x346/0xb4f
[ 210.097147] ? __switch_to+0x769/0xbc4
[ 210.097153] ? compat_start_thread+0x66/0x66
[ 210.097188] ? hci_conn_check_link_mode+0x1cd/0x1cd [bluetooth]
[ 210.097195] ? finish_task_switch+0x392/0x431
[ 210.097228] ? hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097260] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097269] process_one_work+0x579/0x9e9
[ 210.097277] worker_thread+0x68f/0x804
[ 210.097285] kthread+0x31c/0x32b
[ 210.097292] ? rescuer_thread+0x70c/0x70c
[ 210.097299] ? kthread_create_on_node+0xa3/0xa3
[ 210.097306] ret_from_fork+0x35/0x40
[ 210.097314] Allocated by task 2040:
[ 210.097323] kasan_kmalloc.part.1+0x51/0xc7
[ 210.097328] __kmalloc+0x17f/0x1b6
[ 210.097335] sk_prot_alloc+0xf2/0x1a3
[ 210.097340] sk_alloc+0x22/0x297
[ 210.097375] sco_sock_alloc.constprop.7+0x23/0x202 [bluetooth]
[ 210.097410] sco_connect_cfm+0x2d0/0x566 [bluetooth]
[ 210.097443] hci_conn_request_evt.isra.53+0x6d3/0x762 [bluetooth]
[ 210.097476] hci_event_packet+0x85e/0x7de2 [bluetooth]
[ 210.097507] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097512] process_one_work+0x579/0x9e9
[ 210.097517] worker_thread+0x68f/0x804
[ 210.097523] kthread+0x31c/0x32b
[ 210.097529] ret_from_fork+0x35/0x40
[ 210.097533] Freed by task 2040:
[ 210.097539] kasan_slab_free+0xb3/0x15e
[ 210.097544] kfree+0x103/0x1a9
[ 210.097549] __sk_destruct+0x2c6/0x2d4
[ 210.097584] sco_conn_del.isra.1+0xba/0x10e [bluetooth]
[ 210.097617] hci_event_packet+0xff5/0x7de2 [bluetooth]
[ 210.097648] hci_rx_work+0x154/0x487 [bluetooth]
[ 210.097653] process_one_work+0x579/0x9e9
[ 210.097658] worker_thread+0x68f/0x804
[ 210.097663] kthread+0x31c/0x32b
[ 210.097670] ret_from_fork+0x35/0x40
[ 210.097676] The buggy address belongs to the object at ffff880107e170e8
which belongs to the cache kmalloc-1024 of size 1024
[ 210.097681] The buggy address is located 120 bytes inside of
1024-byte region [ffff880107e170e8, ffff880107e174e8)
[ 210.097683] The buggy address belongs to the page:
[ 210.097689] page:ffffea00041f8400 count:1 mapcount:0 mapping: (null) index:0xffff880107e15b68 compound_mapcount: 0
[ 210.110194] flags: 0x8000000000008100(slab|head)
[ 210.115441] raw: 8000000000008100 0000000000000000 ffff880107e15b68 0000000100170016
[ 210.115448] raw: ffffea0004a47620 ffffea0004b48e20 ffff88013b80ed40 0000000000000000
[ 210.115451] page dumped because: kasan: bad access detected
[ 210.115454] Memory state around the buggy address:
[ 210.115460] ffff880107e17000: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 210.115465] ffff880107e17080: fc fc fc fc fc fc fc fc fc fc fc fc fc fb fb fb
[ 210.115469] >ffff880107e17100: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115472] ^
[ 210.115477] ffff880107e17180: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115481] ffff880107e17200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 210.115483] ==================================================================
And finally when BT_DBG() and ftrace was enabled it showed:
<...>-14979 [001] .... 186.104191: sco_sock_kill <-sco_sock_close
<...>-14979 [001] .... 186.104191: sco_sock_kill <-sco_sock_release
<...>-14979 [001] .... 186.104192: sco_sock_kill: sk ef0497a0 state 9
<...>-14979 [001] .... 186.104193: bt_sock_unlink <-sco_sock_kill
kworker/u9:2-792 [001] .... 186.104246: sco_sock_kill <-sco_conn_del
kworker/u9:2-792 [001] .... 186.104248: sco_sock_kill: sk ef0497a0 state 9
kworker/u9:2-792 [001] .... 186.104249: bt_sock_unlink <-sco_sock_kill
kworker/u9:2-792 [001] .... 186.104250: sco_sock_destruct <-__sk_destruct
kworker/u9:2-792 [001] .... 186.104250: sco_sock_destruct: sk ef0497a0
kworker/u9:2-792 [001] .... 186.104860: hci_conn_del <-hci_event_packet
kworker/u9:2-792 [001] .... 186.104864: hci_conn_del: hci0 hcon ef0484c0 handle 266
Only in the failed case, sco_sock_kill() gets called with the same sock
pointer two times. Add a check for SOCK_DEAD to avoid continue killing
a socket which has already been killed.
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit 2df8bee5654bb2b7312662ca6810d4dc16b0b67f ]
Li Shuang reported the following crash:
[ 71.267724] BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
[ 71.276456] PGD 800000085d9bd067 P4D 800000085d9bd067 PUD 859a0b067 PMD 0
[ 71.284127] Oops: 0000 [#1] SMP PTI
[ 71.288015] CPU: 12 PID: 2386 Comm: tc Not tainted 4.18.0-rc8.latest+ #131
[ 71.295686] Hardware name: Dell Inc. PowerEdge R730/0WCJNT, BIOS 2.1.5 04/11/2016
[ 71.304037] RIP: 0010:tcindex_delete+0x72/0x280 [cls_tcindex]
[ 71.310446] Code: 00 31 f6 48 87 75 20 48 85 f6 74 11 48 8b 47 18 48 8b 40 08 48 8b 40 50 e8 fb a6 f8 fc 48 85 db 0f 84 dc 00 00 00 48 8b 73 18 <8b> 56 04 48 8d 7e 04 85 d2 0f 84 7b 01 00
[ 71.331517] RSP: 0018:ffffb45207b3f898 EFLAGS: 00010282
[ 71.337345] RAX: ffff8ad3d72d6360 RBX: ffff8acc84393680 RCX: 000000000000002e
[ 71.345306] RDX: ffff8ad3d72c8570 RSI: 0000000000000000 RDI: ffff8ad847a45800
[ 71.353277] RBP: ffff8acc84393688 R08: ffff8ad3d72c8400 R09: 0000000000000000
[ 71.361238] R10: ffff8ad3de786e00 R11: 0000000000000000 R12: ffffb45207b3f8c7
[ 71.369199] R13: ffff8ad3d93bd2a0 R14: 000000000000002e R15: ffff8ad3d72c9600
[ 71.377161] FS: 00007f9d3ec3e740(0000) GS:ffff8ad3df980000(0000) knlGS:0000000000000000
[ 71.386188] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 71.392597] CR2: 0000000000000004 CR3: 0000000852f06003 CR4: 00000000001606e0
[ 71.400558] Call Trace:
[ 71.403299] tcindex_destroy_element+0x25/0x40 [cls_tcindex]
[ 71.409611] tcindex_walk+0xbb/0x110 [cls_tcindex]
[ 71.414953] tcindex_destroy+0x44/0x90 [cls_tcindex]
[ 71.420492] ? tcindex_delete+0x280/0x280 [cls_tcindex]
[ 71.426323] tcf_proto_destroy+0x16/0x40
[ 71.430696] tcf_chain_flush+0x51/0x70
[ 71.434876] tcf_block_put_ext.part.30+0x8f/0x1b0
[ 71.440122] tcf_block_put+0x4d/0x70
[ 71.444108] cbq_destroy+0x4d/0xd0 [sch_cbq]
[ 71.448869] qdisc_destroy+0x62/0x130
[ 71.452951] dsmark_destroy+0x2a/0x70 [sch_dsmark]
[ 71.458300] qdisc_destroy+0x62/0x130
[ 71.462373] qdisc_graft+0x3ba/0x470
[ 71.466359] tc_get_qdisc+0x2a6/0x2c0
[ 71.470443] ? cred_has_capability+0x7d/0x130
[ 71.475307] rtnetlink_rcv_msg+0x263/0x2d0
[ 71.479875] ? rtnl_calcit.isra.30+0x110/0x110
[ 71.484832] netlink_rcv_skb+0x4d/0x130
[ 71.489109] netlink_unicast+0x1a3/0x250
[ 71.493482] netlink_sendmsg+0x2ae/0x3a0
[ 71.497859] sock_sendmsg+0x36/0x40
[ 71.501748] ___sys_sendmsg+0x26f/0x2d0
[ 71.506029] ? handle_pte_fault+0x586/0xdf0
[ 71.510694] ? __handle_mm_fault+0x389/0x500
[ 71.515457] ? __sys_sendmsg+0x5e/0xa0
[ 71.519636] __sys_sendmsg+0x5e/0xa0
[ 71.523626] do_syscall_64+0x5b/0x180
[ 71.527711] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 71.533345] RIP: 0033:0x7f9d3e257f10
[ 71.537331] Code: c3 48 8b 05 82 6f 2c 00 f7 db 64 89 18 48 83 cb ff eb dd 0f 1f 80 00 00 00 00 83 3d 8d d0 2c 00 00 75 10 b8 2e 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8
[ 71.558401] RSP: 002b:00007fff6f893398 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 71.566848] RAX: ffffffffffffffda RBX: 000000005b71274d RCX: 00007f9d3e257f10
[ 71.574810] RDX: 0000000000000000 RSI: 00007fff6f8933e0 RDI: 0000000000000003
[ 71.582770] RBP: 00007fff6f8933e0 R08: 000000000000ffff R09: 0000000000000003
[ 71.590729] R10: 00007fff6f892e20 R11: 0000000000000246 R12: 0000000000000000
[ 71.598689] R13: 0000000000662ee0 R14: 0000000000000000 R15: 0000000000000000
[ 71.606651] Modules linked in: sch_cbq cls_tcindex sch_dsmark xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_coni
[ 71.685425] libahci i2c_algo_bit i2c_core i40e libata dca mdio megaraid_sas dm_mirror dm_region_hash dm_log dm_mod
[ 71.697075] CR2: 0000000000000004
[ 71.700792] ---[ end trace f604eb1acacd978b ]---
Reproducer:
tc qdisc add dev lo handle 1:0 root dsmark indices 64 set_tc_index
tc filter add dev lo parent 1:0 protocol ip prio 1 tcindex mask 0xfc shift 2
tc qdisc add dev lo parent 1:0 handle 2:0 cbq bandwidth 10Mbit cell 8 avpkt 1000 mpu 64
tc class add dev lo parent 2:0 classid 2:1 cbq bandwidth 10Mbit rate 1500Kbit avpkt 1000 prio 1 bounded isolated allot 1514 weight 1 maxburst 10
tc filter add dev lo parent 2:0 protocol ip prio 1 handle 0x2e tcindex classid 2:1 pass_on
tc qdisc add dev lo parent 2:1 pfifo limit 5
tc qdisc del dev lo root
This is because in tcindex_set_parms, when there is no old_r, we set new
exts to cr.exts. And we didn't set it to filter when r == &new_filter_result.
Then in tcindex_delete() -> tcf_exts_get_net(), we will get NULL pointer
dereference as we didn't init exts.
Fix it by moving tcf_exts_change() after "if (old_r && old_r != r)" check.
Then we don't need "cr" as there is no errout after that.
Fixes: bf63ac73b3e13 ("net_sched: fix an oops in tcindex filter")
Reported-by: Li Shuang <shuali@redhat.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 455f05ecd2b219e9a216050796d30c830d9bc393 ]
syzbot reported that we reinitialize an active delayed
work in vsock_stream_connect():
ODEBUG: init active (active state 0) object type: timer_list hint:
delayed_work_timer_fn+0x0/0x90 kernel/workqueue.c:1414
WARNING: CPU: 1 PID: 11518 at lib/debugobjects.c:329
debug_print_object+0x16a/0x210 lib/debugobjects.c:326
The pattern is apparently wrong, we should only initialize
the dealyed work once and could repeatly schedule it. So we
have to move out the initializations to allocation side.
And to avoid confusion, we can split the shared dwork
into two, instead of re-using the same one.
Fixes: d021c344051a ("VSOCK: Introduce VM Sockets")
Reported-by: <syzbot+8a9b1bd330476a4f3db6@syzkaller.appspotmail.com>
Cc: Andy king <acking@vmware.com>
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
[ Upstream commit 008369dcc5f7bfba526c98054f8525322acf0ea3 ]
Li Shuang reported the following warn:
[ 733.484610] WARNING: CPU: 6 PID: 21123 at net/sched/sch_cbq.c:1418 cbq_destroy_class+0x5d/0x70 [sch_cbq]
[ 733.495190] Modules linked in: sch_cbq cls_tcindex sch_dsmark rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd grace fscache xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat l
[ 733.574155] syscopyarea sysfillrect sysimgblt fb_sys_fops ttm drm igb ixgbe ahci libahci i2c_algo_bit libata i40e i2c_core dca mdio megaraid_sas dm_mirror dm_region_hash dm_log dm_mod
[ 733.592500] CPU: 6 PID: 21123 Comm: tc Not tainted 4.18.0-rc8.latest+ #131
[ 733.600169] Hardware name: Dell Inc. PowerEdge R730/0WCJNT, BIOS 2.1.5 04/11/2016
[ 733.608518] RIP: 0010:cbq_destroy_class+0x5d/0x70 [sch_cbq]
[ 733.614734] Code: e7 d9 d2 48 8b 7b 48 e8 61 05 da d2 48 8d bb f8 00 00 00 e8 75 ae d5 d2 48 39 eb 74 0a 48 89 df 5b 5d e9 16 6c 94 d2 5b 5d c3 <0f> 0b eb b6 0f 1f 44 00 00 66 2e 0f 1f 84
[ 733.635798] RSP: 0018:ffffbfbb066bb9d8 EFLAGS: 00010202
[ 733.641627] RAX: 0000000000000001 RBX: ffff9cdd17392800 RCX: 000000008010000f
[ 733.649588] RDX: ffff9cdd1df547e0 RSI: ffff9cdd17392800 RDI: ffff9cdd0f84c800
[ 733.657547] RBP: ffff9cdd0f84c800 R08: 0000000000000001 R09: 0000000000000000
[ 733.665508] R10: ffff9cdd0f84d000 R11: 0000000000000001 R12: 0000000000000001
[ 733.673469] R13: 0000000000000000 R14: 0000000000000001 R15: ffff9cdd17392200
[ 733.681430] FS: 00007f911890a740(0000) GS:ffff9cdd1f8c0000(0000) knlGS:0000000000000000
[ 733.690456] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 733.696864] CR2: 0000000000b5544c CR3: 0000000859374002 CR4: 00000000001606e0
[ 733.704826] Call Trace:
[ 733.707554] cbq_destroy+0xa1/0xd0 [sch_cbq]
[ 733.712318] qdisc_destroy+0x62/0x130
[ 733.716401] dsmark_destroy+0x2a/0x70 [sch_dsmark]
[ 733.721745] qdisc_destroy+0x62/0x130
[ 733.725829] qdisc_graft+0x3ba/0x470
[ 733.729817] tc_get_qdisc+0x2a6/0x2c0
[ 733.733901] ? cred_has_capability+0x7d/0x130
[ 733.738761] rtnetlink_rcv_msg+0x263/0x2d0
[ 733.743330] ? rtnl_calcit.isra.30+0x110/0x110
[ 733.748287] netlink_rcv_skb+0x4d/0x130
[ 733.752576] netlink_unicast+0x1a3/0x250
[ 733.756949] netlink_sendmsg+0x2ae/0x3a0
[ 733.761324] sock_sendmsg+0x36/0x40
[ 733.765213] ___sys_sendmsg+0x26f/0x2d0
[ 733.769493] ? handle_pte_fault+0x586/0xdf0
[ 733.774158] ? __handle_mm_fault+0x389/0x500
[ 733.778919] ? __sys_sendmsg+0x5e/0xa0
[ 733.783099] __sys_sendmsg+0x5e/0xa0
[ 733.787087] do_syscall_64+0x5b/0x180
[ 733.791171] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 733.796805] RIP: 0033:0x7f9117f23f10
[ 733.800791] Code: c3 48 8b 05 82 6f 2c 00 f7 db 64 89 18 48 83 cb ff eb dd 0f 1f 80 00 00 00 00 83 3d 8d d0 2c 00 00 75 10 b8 2e 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8
[ 733.821873] RSP: 002b:00007ffe96818398 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 733.830319] RAX: ffffffffffffffda RBX: 000000005b71244c RCX: 00007f9117f23f10
[ 733.838280] RDX: 0000000000000000 RSI: 00007ffe968183e0 RDI: 0000000000000003
[ 733.846241] RBP: 00007ffe968183e0 R08: 000000000000ffff R09: 0000000000000003
[ 733.854202] R10: 00007ffe96817e20 R11: 0000000000000246 R12: 0000000000000000
[ 733.862161] R13: 0000000000662ee0 R14: 0000000000000000 R15: 0000000000000000
[ 733.870121] ---[ end trace 28edd4aad712ddca ]---
This is because we didn't update f->result.res when create new filter. Then in
tcindex_delete() -> tcf_unbind_filter(), we will failed to find out the res
and unbind filter, which will trigger the WARN_ON() in cbq_destroy_class().
Fix it by updating f->result.res when create new filter.
Fixes: 6e0565697a106 ("net_sched: fix another crash in cls_tcindex")
[ Upstream commit 0dcb82254d65f72333aa50ad626d1e9665ad093b ]
llc_sap_put() decreases the refcnt before deleting sap
from the global list. Therefore, there is a chance
llc_sap_find() could find a sap with zero refcnt
in this global list.
Close this race condition by checking if refcnt is zero
or not in llc_sap_find(), if it is zero then it is being
removed so we can just treat it as gone.
Reported-by: <syzbot+278893f3f7803871f7ce@syzkaller.appspotmail.com>
