path: root/net
2017-10-02ip6_offload: fix compiler warningMax Krummenacher
Backports introduced the following compiler warning: net/ipv6/ip6_offload.c:264:25: warning: 'sit_gro_receive' defined but not used [-Wunused-function] Remove the static function definition. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-09-27Merge remote-tracking branch 'fslc/4.1-2.0.x-imx' into toradex_4.1-2.0.x-imxMax Krummenacher
2017-09-22Merge tag 'v4.1.44' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.44 * tag 'v4.1.44': (180 commits) Linux 4.1.44 mtd: fsl-quadspi: fix macro collision problems with READ/WRITE pinctrl: samsung: Remove bogus irq_[un]mask from resource management pinctrl: sunxi: add a missing function of A10/A20 pinctrl driver pnfs/blocklayout: require 64-bit sector_t iio: adc: vf610_adc: Fix VALT selection value for REFSEL bits usb:xhci:Add quirk for Certain failing HP keyboard on reset after resume usb: quirks: Add no-lpm quirk for Moshi USB to Ethernet Adapter USB: Check for dropped connection before switching to full speed uas: Add US_FL_IGNORE_RESIDUE for Initio Corporation INIC-3069 iio: light: tsl2563: use correct event code staging:iio:resolver:ad2s1210 fix negative IIO_ANGL_VEL read USB: hcd: Mark secondary HCD as dead if the primary one died USB: serial: pl2303: add new ATEN device id USB: serial: cp210x: add support for Qivicon USB ZigBee dongle USB: serial: option: add D-Link DWM-222 device ID nfs/flexfiles: fix leak of nfs4_ff_ds_version arrays fuse: initialize the flock flag in fuse_file on allocation iscsi-target: Fix iscsi_np reset hung task during parallel delete iscsi-target: fix memory leak in iscsit_setup_text_cmd() ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2017-09-10packet: fix tp_reserve race in packet_set_ringWillem de Bruijn
[ Upstream commit c27927e372f0785f3303e8fad94b85945e2c97b7 ] Updates to tp_reserve can race with reads of the field in packet_set_ring. Avoid this by holding the socket lock during updates in setsockopt PACKET_RESERVE. This bug was discovered by syzkaller. Fixes: 8913336a7e8d ("packet: add PACKET_RESERVE sockopt") Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10net: avoid skb_warn_bad_offload false positives on UFOWillem de Bruijn
[ Upstream commit 8d63bee643f1fb53e472f0e135cae4eb99d62d19 ] skb_warn_bad_offload triggers a warning when an skb enters the GSO stack at __skb_gso_segment that does not have CHECKSUM_PARTIAL checksum offload set. Commit b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise") observed that SKB_GSO_DODGY producers can trigger the check and that passing those packets through the GSO handlers will fix it up. But, the software UFO handler will set ip_summed to CHECKSUM_NONE. When __skb_gso_segment is called from the receive path, this triggers the warning again. Make UFO set CHECKSUM_UNNECESSARY instead of CHECKSUM_NONE. On Tx these two are equivalent. On Rx, this better matches the skb state (checksum computed), as CHECKSUM_NONE here means no checksum computed. See also this thread for context: http://patchwork.ozlabs.org/patch/799015/ Fixes: b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise") Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10tcp: avoid setting cwnd to invalid ssthresh after cwnd reduction statesYuchung Cheng
[ Upstream commit ed254971edea92c3ac5c67c6a05247a92aa6075e ] If the sender switches the congestion control during ECN-triggered cwnd-reduction state (CA_CWR), upon exiting recovery cwnd is set to the ssthresh value calculated by the previous congestion control. If the previous congestion control is BBR that always keep ssthresh to TCP_INIFINITE_SSTHRESH, cwnd ends up being infinite. The safe step is to avoid assigning invalid ssthresh value when recovery ends. Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10ipv4: Should use consistent conditional judgement for ip fragment in ↵zheng li
__ip_append_data and ip_finish_output [ Upstream commit 0a28cfd51e17f4f0a056bcf66bfbe492c3b99f38 ] There is an inconsistent conditional judgement in __ip_append_data and ip_finish_output functions, the variable length in __ip_append_data just include the length of application's payload and udp header, don't include the length of ip header, but in ip_finish_output use (skb->len > ip_skb_dst_mtu(skb)) as judgement, and skb->len include the length of ip header. That causes some particular application's udp payload whose length is between (MTU - IP Header) and MTU were fragmented by ip_fragment even though the rst->dev support UFO feature. Add the length of ip header to length in __ip_append_data to keep consistent conditional judgement as ip_finish_output for ip fragment. Signed-off-by: Zheng Li <james.z.li@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10dccp: fix a memleak for dccp_feat_init err processXin Long
[ Upstream commit e90ce2fc27cad7e7b1e72b9e66201a7a4c124c2b ] In dccp_feat_init, when ccid_get_builtin_ccids failsto alloc memory for rx.val, it should free tx.val before returning an error. Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10dccp: fix a memleak that dccp_ipv4 doesn't put reqsk properlyXin Long
[ Upstream commit b7953d3c0e30a5fc944f6b7bd0bcceb0794bcd85 ] The patch "dccp: fix a memleak that dccp_ipv6 doesn't put reqsk properly" fixed reqsk refcnt leak for dccp_ipv6. The same issue exists on dccp_ipv4. This patch is to fix it for dccp_ipv4. Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10packet: fix use-after-free in prb_retire_rx_blk_timer_expired()WANG Cong
[ Upstream commit c800aaf8d869f2b9b47b10c5c312fe19f0a94042 ] There are multiple reports showing we have a use-after-free in the timer prb_retire_rx_blk_timer_expired(), where we use struct tpacket_kbdq_core::pkbdq, a pg_vec, after it gets freed by free_pg_vec(). The interesting part is it is not freed via packet_release() but via packet_setsockopt(), which means we are not closing the socket. Looking into the big and fat function packet_set_ring(), this could happen if we satisfy the following conditions: 1. closing == 0, not on packet_release() path 2. req->tp_block_nr == 0, we don't allocate a new pg_vec 3. rx_ring->pg_vec is already set as V3, which means we already called packet_set_ring() wtih req->tp_block_nr > 0 previously 4. req->tp_frame_nr == 0, pass sanity check 5. po->mapped == 0, never called mmap() In this scenario we are clearing the old rx_ring->pg_vec, so we need to free this pg_vec, but we don't stop the timer on this path because of closing==0. The timer has to be stopped as long as we need to free pg_vec, therefore the check on closing!=0 is wrong, we should check pg_vec!=NULL instead. Thanks to liujian for testing different fixes. Reported-by: alexander.levin@verizon.com Reported-by: Dave Jones <davej@codemonkey.org.uk> Reported-by: liujian (CE) <liujian56@huawei.com> Tested-by: liujian (CE) <liujian56@huawei.com> Cc: Ding Tianhong <dingtianhong@huawei.com> Cc: Willem de Bruijn <willemdebruijn.kernel@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10rtnetlink: allocate more memory for dev_set_mac_address()WANG Cong
[ Upstream commit 153711f9421be5dbc973dc57a4109dc9d54c89b1 ] virtnet_set_mac_address() interprets mac address as struct sockaddr, but upper layer only allocates dev->addr_len which is ETH_ALEN + sizeof(sa_family_t) in this case. We lack a unified definition for mac address, so just fix the upper layer, this also allows drivers to interpret it to struct sockaddr freely. Reported-by: David Ahern <dsahern@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10ipv4: initialize fib_trie prior to register_netdev_notifier call.Mahesh Bandewar
[ Upstream commit 8799a221f5944a7d74516ecf46d58c28ec1d1f75 ] Net stack initialization currently initializes fib-trie after the first call to netdevice_notifier() call. In fact fib_trie initialization needs to happen before first rtnl_register(). It does not cause any problem since there are no devices UP at this moment, but trying to bring 'lo' UP at initialization would make this assumption wrong and exposes the issue. Fixes following crash Call Trace: ? alternate_node_alloc+0x76/0xa0 fib_table_insert+0x1b7/0x4b0 fib_magic.isra.17+0xea/0x120 fib_add_ifaddr+0x7b/0x190 fib_netdev_event+0xc0/0x130 register_netdevice_notifier+0x1c1/0x1d0 ip_fib_init+0x72/0x85 ip_rt_init+0x187/0x1e9 ip_init+0xe/0x1a inet_init+0x171/0x26c ? ipv4_offload_init+0x66/0x66 do_one_initcall+0x43/0x160 kernel_init_freeable+0x191/0x219 ? rest_init+0x80/0x80 kernel_init+0xe/0x150 ret_from_fork+0x22/0x30 Code: f6 46 23 04 74 86 4c 89 f7 e8 ae 45 01 00 49 89 c7 4d 85 ff 0f 85 7b ff ff ff 31 db eb 08 4c 89 ff e8 16 47 01 00 48 8b 44 24 38 <45> 8b 6e 14 4d 63 76 74 48 89 04 24 0f 1f 44 00 00 48 83 c4 08 RIP: kmem_cache_alloc+0xcf/0x1c0 RSP: ffff9b1500017c28 CR2: 0000000000000014 Fixes: 7b1a74fdbb9e ("[NETNS]: Refactor fib initialization so it can handle multiple namespaces.") Fixes: 7f9b80529b8a ("[IPV4]: fib hash|trie initialization") Signed-off-by: Mahesh Bandewar <maheshb@google.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10ipv6: avoid overflow of offset in ip6_find_1stfragoptSabrina Dubroca
[ Upstream commit 6399f1fae4ec29fab5ec76070435555e256ca3a6 ] In some cases, offset can overflow and can cause an infinite loop in ip6_find_1stfragopt(). Make it unsigned int to prevent the overflow, and cap it at IPV6_MAXPLEN, since packets larger than that should be invalid. This problem has been here since before the beginning of git history. Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10net: Zero terminate ifr_name in dev_ifname().David S. Miller
[ Upstream commit 63679112c536289826fec61c917621de95ba2ade ] The ifr.ifr_name is passed around and assumed to be NULL terminated. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10ipv6: Should use consistent conditional judgement for ip6 fragment between ↵Zheng Li
__ip6_append_data and ip6_finish_output [ Upstream commit e4c5e13aa45c23692e4acf56f0b3533f328199b2 ] There is an inconsistent conditional judgement between __ip6_append_data and ip6_finish_output functions, the variable length in __ip6_append_data just include the length of application's payload and udp6 header, don't include the length of ipv6 header, but in ip6_finish_output use (skb->len > ip6_skb_dst_mtu(skb)) as judgement, and skb->len include the length of ipv6 header. That causes some particular application's udp6 payloads whose length are between (MTU - IPv6 Header) and MTU were fragmented by ip6_fragment even though the rst->dev support UFO feature. Add the length of ipv6 header to length in __ip6_append_data to keep consistent conditional judgement as ip6_finish_output for ip6 fragment. Signed-off-by: Zheng Li <james.z.li@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10net: skb_needs_check() accepts CHECKSUM_NONE for txEric Dumazet
[ Upstream commit 6e7bc478c9a006c701c14476ec9d389a484b4864 ] My recent change missed fact that UFO would perform a complete UDP checksum before segmenting in frags. In this case skb->ip_summed is set to CHECKSUM_NONE. We need to add this valid case to skb_needs_check() Fixes: b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10vlan: Propagate MAC address to VLANsMike Manning
[ Upstream commit 308453aa9156a3b8ee382c0949befb507a32b0c1 ] The MAC address of the physical interface is only copied to the VLAN when it is first created, resulting in an inconsistency after MAC address changes of only newly created VLANs having an up-to-date MAC. The VLANs should continue inheriting the MAC address of the physical interface until the VLAN MAC address is explicitly set to any value. This allows IPv6 EUI64 addresses for the VLAN to reflect any changes to the MAC of the physical interface and thus for DAD to behave as expected. Signed-off-by: Mike Manning <mmanning@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10net: reduce skb_warn_bad_offload() noiseEric Dumazet
[ Upstream commit b2504a5dbef3305ef41988ad270b0e8ec289331c ] Dmitry reported warnings occurring in __skb_gso_segment() [1] All SKB_GSO_DODGY producers can allow user space to feed packets that trigger the current check. We could prevent them from doing so, rejecting packets, but this might add regressions to existing programs. It turns out our SKB_GSO_DODGY handlers properly set up checksum information that is needed anyway when packets needs to be segmented. By checking again skb_needs_check() after skb_mac_gso_segment(), we should remove these pesky warnings, at a very minor cost. With help from Willem de Bruijn [1] WARNING: CPU: 1 PID: 6768 at net/core/dev.c:2439 skb_warn_bad_offload+0x2af/0x390 net/core/dev.c:2434 lo: caps=(0x000000a2803b7c69, 0x0000000000000000) len=138 data_len=0 gso_size=15883 gso_type=4 ip_summed=0 Kernel panic - not syncing: panic_on_warn set ... CPU: 1 PID: 6768 Comm: syz-executor1 Not tainted 4.9.0 #5 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 ffff8801c063ecd8 ffffffff82346bdf ffffffff00000001 1ffff100380c7d2e ffffed00380c7d26 0000000041b58ab3 ffffffff84b37e38 ffffffff823468f1 ffffffff84820740 ffffffff84f289c0 dffffc0000000000 ffff8801c063ee20 Call Trace: [<ffffffff82346bdf>] __dump_stack lib/dump_stack.c:15 [inline] [<ffffffff82346bdf>] dump_stack+0x2ee/0x3ef lib/dump_stack.c:51 [<ffffffff81827e34>] panic+0x1fb/0x412 kernel/panic.c:179 [<ffffffff8141f704>] __warn+0x1c4/0x1e0 kernel/panic.c:542 [<ffffffff8141f7e5>] warn_slowpath_fmt+0xc5/0x100 kernel/panic.c:565 [<ffffffff8356cbaf>] skb_warn_bad_offload+0x2af/0x390 net/core/dev.c:2434 [<ffffffff83585cd2>] __skb_gso_segment+0x482/0x780 net/core/dev.c:2706 [<ffffffff83586f19>] skb_gso_segment include/linux/netdevice.h:3985 [inline] [<ffffffff83586f19>] validate_xmit_skb+0x5c9/0xc20 net/core/dev.c:2969 [<ffffffff835892bb>] __dev_queue_xmit+0xe6b/0x1e70 net/core/dev.c:3383 [<ffffffff8358a2d7>] dev_queue_xmit+0x17/0x20 net/core/dev.c:3424 [<ffffffff83ad161d>] packet_snd net/packet/af_packet.c:2930 [inline] [<ffffffff83ad161d>] packet_sendmsg+0x32ed/0x4d30 net/packet/af_packet.c:2955 [<ffffffff834f0aaa>] sock_sendmsg_nosec net/socket.c:621 [inline] [<ffffffff834f0aaa>] sock_sendmsg+0xca/0x110 net/socket.c:631 [<ffffffff834f329a>] ___sys_sendmsg+0x8fa/0x9f0 net/socket.c:1954 [<ffffffff834f5e58>] __sys_sendmsg+0x138/0x300 net/socket.c:1988 [<ffffffff834f604d>] SYSC_sendmsg net/socket.c:1999 [inline] [<ffffffff834f604d>] SyS_sendmsg+0x2d/0x50 net/socket.c:1995 [<ffffffff84371941>] entry_SYSCALL_64_fastpath+0x1f/0xc2 Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10af_key: Add lock to key dumpYuejie Shi
[ Upstream commit 89e357d83c06b6fac581c3ca7f0ee3ae7e67109e ] A dump may come in the middle of another dump, modifying its dump structure members. This race condition will result in NULL pointer dereference in kernel. So add a lock to prevent that race. Fixes: 83321d6b9872 ("[AF_KEY]: Dump SA/SP entries non-atomically") Signed-off-by: Yuejie Shi <syjcnss@gmail.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-10af_key: Fix sadb_x_ipsecrequest parsingHerbert Xu
[ Upstream commit 096f41d3a8fcbb8dde7f71379b1ca85fe213eded ] The parsing of sadb_x_ipsecrequest is broken in a number of ways. First of all we're not verifying sadb_x_ipsecrequest_len. This is needed when the structure carries addresses at the end. Worse we don't even look at the length when we parse those optional addresses. The migration code had similar parsing code that's better but it also has some deficiencies. The length is overcounted first of all as it includes the header itself. It also fails to check the length before dereferencing the sa_family field. This patch fixes those problems in parse_sockaddr_pair and then uses it in parse_ipsecrequest. Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-01Bluetooth: use constant time memory comparison for secret valuesJason A. Donenfeld
[ Upstream commit 329d82309824ff1082dc4a91a5bbed8c3bec1580 ] This file is filled with complex cryptography. Thus, the comparisons of MACs and secret keys and curve points and so forth should not add timing attacks, which could either result in a direct forgery, or, given the complexity, some other type of attack. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-01NFC: Add sockaddr length checks before accessing sa_family in bind handlersMateusz Jurczyk
[ Upstream commit f6a5885fc4d68e7f25ffb42b9d8d80aebb3bacbb ] Verify that the caller-provided sockaddr structure is large enough to contain the sa_family field, before accessing it in bind() handlers of the AF_NFC socket. Since the syscall doesn't enforce a minimum size of the corresponding memory region, very short sockaddrs (zero or one byte long) result in operating on uninitialized memory while referencing .sa_family. Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-01nfc: Fix the sockaddr length sanitization in llcp_sock_connectMateusz Jurczyk
[ Upstream commit 608c4adfcabab220142ee335a2a003ccd1c0b25b ] Fix the sockaddr length verification in the connect() handler of NFC/LLCP sockets, to compare against the size of the actual structure expected on input (sockaddr_nfc_llcp) instead of its shorter version (sockaddr_nfc). Both structures are defined in include/uapi/linux/nfc.h. The fields specific to the _llcp extended struct are as follows: 276 __u8 dsap; /* Destination SAP, if known */ 277 __u8 ssap; /* Source SAP to be bound to */ 278 char service_name[NFC_LLCP_MAX_SERVICE_NAME]; /* Service name URI */; 279 size_t service_name_len; If the caller doesn't provide a sufficiently long sockaddr buffer, these fields remain uninitialized (and they currently originate from the stack frame of the top-level sys_connect handler). They are then copied by llcp_sock_connect() into internal storage (nfc_llcp_sock structure), and could be subsequently read back through the user-mode getsockname() function (handled by llcp_sock_getname()). This would result in the disclosure of up to ~70 uninitialized bytes from the kernel stack to user-mode clients capable of creating AFC_NFC sockets. Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-01nfc: Ensure presence of required attributes in the activate_target handlerMateusz Jurczyk
[ Upstream commit a0323b979f81ad2deb2c8836eab506534891876a ] Check that the NFC_ATTR_TARGET_INDEX and NFC_ATTR_PROTOCOLS attributes (in addition to NFC_ATTR_DEVICE_INDEX) are provided by the netlink client prior to accessing them. This prevents potential unhandled NULL pointer dereference exceptions which can be triggered by malicious user-mode programs, if they omit one or both of these attributes. Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-09-01NFC: fix broken device allocationJohan Hovold
[ Upstream commit 20777bc57c346b6994f465e0d8261a7fbf213a09 ] Commit 7eda8b8e9677 ("NFC: Use IDR library to assing NFC devices IDs") moved device-id allocation and struct-device initialisation from nfc_allocate_device() to nfc_register_device(). This broke just about every nfc-device-registration error path, which continue to call nfc_free_device() that tries to put the device reference of the now uninitialised (but zeroed) struct device: kobject: '(null)' (ce316420): is not initialized, yet kobject_put() is being called. The late struct-device initialisation also meant that various work queues whose names are derived from the nfc device name were also misnamed: 421 root 0 SW< [(null)_nci_cmd_] 422 root 0 SW< [(null)_nci_rx_w] 423 root 0 SW< [(null)_nci_tx_w] Move the id-allocation and struct-device initialisation back to nfc_allocate_device() and fix up the single call site which did not use nfc_free_device() in its error path. Fixes: 7eda8b8e9677 ("NFC: Use IDR library to assing NFC devices IDs") Cc: stable <stable@vger.kernel.org> # 3.8 Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-08-06Merge tag 'v4.1.43' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.43 * tag 'v4.1.43': (182 commits) Linux 4.1.43 HID: core: prevent out-of-bound readings ipvs: SNAT packet replies only for NATed connections Revert "dmaengine: ep93xx: Don't drain the transfers in terminate_all()" staging: comedi: ni_mio_common: fix E series ni_ai_insn_read() data kvm: vmx: Do not disable intercepts for BNDCFGS tracing: Use SOFTIRQ_OFFSET for softirq dectection for more accurate results PM / QoS: return -EINVAL for bogus strings sched/topology: Optimize build_group_mask() sched/topology: Fix overlapping sched_group_mask crypto: caam - fix signals handling crypto: atmel - only treat EBUSY as transient if backlog crypto: talitos - Extend max key length for SHA384/512-HMAC and AEAD Add "shutdown" to "struct class". mnt: Make propagate_umount less slow for overlapping mount propagation trees mnt: In propgate_umount handle visiting mounts in any order mnt: In umount propagation reparent in a separate pass vt: fix unchecked __put_user() in tioclinux ioctls exec: Limit arg stack to at most 75% of _STK_LIM s390: reduce ELF_ET_DYN_BASE ...
2017-07-31ipvs: SNAT packet replies only for NATed connectionsSasha Levin
[ Upstream commit 3c5ab3f395d66a9e4e937fcfdf6ebc63894f028b ] We do not check if packet from real server is for NAT connection before performing SNAT. This causes problems for setups that use DR/TUN and allow local clients to access the real server directly, for example: - local client in director creates IPVS-DR/TUN connection CIP->VIP and the request packets are routed to RIP. Talks are finished but IPVS connection is not expired yet. - second local client creates non-IPVS connection CIP->RIP with same reply tuple RIP->CIP and when replies are received on LOCAL_IN we wrongly assign them for the first client connection because RIP->CIP matches the reply direction. As result, IPVS SNATs replies for non-IPVS connections. The problem is more visible to local UDP clients but in rare cases it can happen also for TCP or remote clients when the real server sends the reply traffic via the director. So, better to be more precise for the reply traffic. As replies are not expected for DR/TUN connections, better to not touch them. Reported-by: Nick Moriarty <nick.moriarty@york.ac.uk> Tested-by: Nick Moriarty <nick.moriarty@york.ac.uk> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31cfg80211: Check if PMKID attribute is of expected sizeSrinivas Dasari
[ Upstream commit 9361df14d1cbf966409d5d6f48bb334384fbe138 ] nla policy checks for only maximum length of the attribute data when the attribute type is NLA_BINARY. If userspace sends less data than specified, the wireless drivers may access illegal memory. When type is NLA_UNSPEC, nla policy check ensures that userspace sends minimum specified length number of bytes. Remove type assignment to NLA_BINARY from nla_policy of NL80211_ATTR_PMKID to make this NLA_UNSPEC and to make sure minimum WLAN_PMKID_LEN bytes are received from userspace with NL80211_ATTR_PMKID. Fixes: 67fbb16be69d ("nl80211: PMKSA caching support") Cc: stable@vger.kernel.org Signed-off-by: Srinivas Dasari <dasaris@qti.qualcomm.com> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31cfg80211: Validate frequencies nested in NL80211_ATTR_SCAN_FREQUENCIESSrinivas Dasari
[ Upstream commit d7f13f7450369281a5d0ea463cc69890a15923ae ] validate_scan_freqs() retrieves frequencies from attributes nested in the attribute NL80211_ATTR_SCAN_FREQUENCIES with nla_get_u32(), which reads 4 bytes from each attribute without validating the size of data received. Attributes nested in NL80211_ATTR_SCAN_FREQUENCIES don't have an nla policy. Validate size of each attribute before parsing to avoid potential buffer overread. Fixes: 2a519311926 ("cfg80211/nl80211: scanning (and mac80211 update to use it)") Cc: stable@vger.kernel.org Signed-off-by: Srinivas Dasari <dasaris@qti.qualcomm.com> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31cfg80211: Define nla_policy for NL80211_ATTR_LOCAL_MESH_POWER_MODESrinivas Dasari
[ Upstream commit 8feb69c7bd89513be80eb19198d48f154b254021 ] Buffer overread may happen as nl80211_set_station() reads 4 bytes from the attribute NL80211_ATTR_LOCAL_MESH_POWER_MODE without validating the size of data received when userspace sends less than 4 bytes of data with NL80211_ATTR_LOCAL_MESH_POWER_MODE. Define nla_policy for NL80211_ATTR_LOCAL_MESH_POWER_MODE to avoid the buffer overread. Fixes: 3b1c5a5307f ("{cfg,nl}80211: mesh power mode primitives and userspace access") Cc: stable@vger.kernel.org Signed-off-by: Srinivas Dasari <dasaris@qti.qualcomm.com> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31ipv6: dad: don't remove dynamic addresses if link is downSabrina Dubroca
[ Upstream commit ec8add2a4c9df723c94a863b8fcd6d93c472deed ] Currently, when the link for $DEV is down, this command succeeds but the address is removed immediately by DAD (1): ip addr add 1111::12/64 dev $DEV valid_lft 3600 preferred_lft 1800 In the same situation, this will succeed and not remove the address (2): ip addr add 1111::12/64 dev $DEV ip addr change 1111::12/64 dev $DEV valid_lft 3600 preferred_lft 1800 The comment in addrconf_dad_begin() when !IF_READY makes it look like this is the intended behavior, but doesn't explain why: * If the device is not ready: * - keep it tentative if it is a permanent address. * - otherwise, kill it. We clearly cannot prevent userspace from doing (2), but we can make (1) work consistently with (2). addrconf_dad_stop() is only called in two cases: if DAD failed, or to skip DAD when the link is down. In that second case, the fix is to avoid deleting the address, like we already do for permanent addresses. Fixes: 3c21edbd1137 ("[IPV6]: Defer IPv6 device initialization until the link becomes ready.") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31net: prevent sign extension in dev_get_stats()Eric Dumazet
[ Upstream commit 6f64ec74515925cced6df4571638b5a099a49aae ] Similar to the fix provided by Dominik Heidler in commit 9b3dc0a17d73 ("l2tp: cast l2tp traffic counter to unsigned") we need to take care of 32bit kernels in dev_get_stats(). When using atomic_long_read(), we add a 'long' to u64 and might misinterpret high order bit, unless we cast to unsigned. Fixes: caf586e5f23ce ("net: add a core netdev->rx_dropped counter") Fixes: 015f0688f57ca ("net: net: add a core netdev->tx_dropped counter") Fixes: 6e7333d315a76 ("net: add rx_nohandler stat counter") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Jarod Wilson <jarod@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31net: sched: Fix one possible panic when no destroy callbackGao Feng
[ Upstream commit c1a4872ebfb83b1af7144f7b29ac8c4b344a12a8 ] When qdisc fail to init, qdisc_create would invoke the destroy callback to cleanup. But there is no check if the callback exists really. So it would cause the panic if there is no real destroy callback like the qdisc codel, fq, and so on. Take codel as an example following: When a malicious user constructs one invalid netlink msg, it would cause codel_init->codel_change->nla_parse_nested failed. Then kernel would invoke the destroy callback directly but qdisc codel doesn't define one. It causes one panic as a result. Now add one the check for destroy to avoid the possible panic. Fixes: 87b60cfacf9f ("net_sched: fix error recovery at qdisc creation") Signed-off-by: Gao Feng <gfree.wind@vip.163.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31net_sched: fix error recovery at qdisc creationEric Dumazet
[ Upstream commit 87b60cfacf9f17cf71933c6e33b66e68160af71d ] Dmitry reported uses after free in qdisc code [1] The problem here is that ops->init() can return an error. qdisc_create_dflt() then call ops->destroy(), while qdisc_create() does _not_ call it. Four qdisc chose to call their own ops->destroy(), assuming their caller would not. This patch makes sure qdisc_create() calls ops->destroy() and fixes the four qdisc to avoid double free. [1] BUG: KASAN: use-after-free in mq_destroy+0x242/0x290 net/sched/sch_mq.c:33 at addr ffff8801d415d440 Read of size 8 by task syz-executor2/5030 CPU: 0 PID: 5030 Comm: syz-executor2 Not tainted 4.3.5-smp-DEV #119 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 0000000000000046 ffff8801b435b870 ffffffff81bbbed4 ffff8801db000400 ffff8801d415d440 ffff8801d415dc40 ffff8801c4988510 ffff8801b435b898 ffffffff816682b1 ffff8801b435b928 ffff8801d415d440 ffff8801c49880c0 Call Trace: [<ffffffff81bbbed4>] __dump_stack lib/dump_stack.c:15 [inline] [<ffffffff81bbbed4>] dump_stack+0x6c/0x98 lib/dump_stack.c:51 [<ffffffff816682b1>] kasan_object_err+0x21/0x70 mm/kasan/report.c:158 [<ffffffff81668524>] print_address_description mm/kasan/report.c:196 [inline] [<ffffffff81668524>] kasan_report_error+0x1b4/0x4b0 mm/kasan/report.c:285 [<ffffffff81668953>] kasan_report mm/kasan/report.c:305 [inline] [<ffffffff81668953>] __asan_report_load8_noabort+0x43/0x50 mm/kasan/report.c:326 [<ffffffff82527b02>] mq_destroy+0x242/0x290 net/sched/sch_mq.c:33 [<ffffffff82524bdd>] qdisc_destroy+0x12d/0x290 net/sched/sch_generic.c:953 [<ffffffff82524e30>] qdisc_create_dflt+0xf0/0x120 net/sched/sch_generic.c:848 [<ffffffff8252550d>] attach_default_qdiscs net/sched/sch_generic.c:1029 [inline] [<ffffffff8252550d>] dev_activate+0x6ad/0x880 net/sched/sch_generic.c:1064 [<ffffffff824b1db1>] __dev_open+0x221/0x320 net/core/dev.c:1403 [<ffffffff824b24ce>] __dev_change_flags+0x15e/0x3e0 net/core/dev.c:6858 [<ffffffff824b27de>] dev_change_flags+0x8e/0x140 net/core/dev.c:6926 [<ffffffff824f5bf6>] dev_ifsioc+0x446/0x890 net/core/dev_ioctl.c:260 [<ffffffff824f61fa>] dev_ioctl+0x1ba/0xb80 net/core/dev_ioctl.c:546 [<ffffffff82430509>] sock_do_ioctl+0x99/0xb0 net/socket.c:879 [<ffffffff82430d30>] sock_ioctl+0x2a0/0x390 net/socket.c:958 [<ffffffff816f3b68>] vfs_ioctl fs/ioctl.c:44 [inline] [<ffffffff816f3b68>] do_vfs_ioctl+0x8a8/0xe50 fs/ioctl.c:611 [<ffffffff816f41a4>] SYSC_ioctl fs/ioctl.c:626 [inline] [<ffffffff816f41a4>] SyS_ioctl+0x94/0xc0 fs/ioctl.c:617 [<ffffffff8123e357>] entry_SYSCALL_64_fastpath+0x12/0x17 Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31xfrm: Oops on error in pfkey_msg2xfrm_state()Dan Carpenter
[ Upstream commit 1e3d0c2c70cd3edb5deed186c5f5c75f2b84a633 ] There are some missing error codes here so we accidentally return NULL instead of an error pointer. It results in a NULL pointer dereference. Fixes: df71837d5024 ("[LSM-IPSec]: Security association restriction.") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31xfrm: NULL dereference on allocation failureDan Carpenter
[ Upstream commit e747f64336fc15e1c823344942923195b800aa1e ] The default error code in pfkey_msg2xfrm_state() is -ENOBUFS. We added a new call to security_xfrm_state_alloc() which sets "err" to zero so there several places where we can return ERR_PTR(0) if kmalloc() fails. The caller is expecting error pointers so it leads to a NULL dereference. Fixes: df71837d5024 ("[LSM-IPSec]: Security association restriction.") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31xfrm: fix stack access out of bounds with CONFIG_XFRM_SUB_POLICYSabrina Dubroca
[ Upstream commit 9b3eb54106cf6acd03f07cf0ab01c13676a226c2 ] When CONFIG_XFRM_SUB_POLICY=y, xfrm_dst stores a copy of the flowi for that dst. Unfortunately, the code that allocates and fills this copy doesn't care about what type of flowi (flowi, flowi4, flowi6) gets passed. In multiple code paths (from raw_sendmsg, from TCP when replying to a FIN, in vxlan, geneve, and gre), the flowi that gets passed to xfrm is actually an on-stack flowi4, so we end up reading stuff from the stack past the end of the flowi4 struct. Since xfrm_dst->origin isn't used anywhere following commit ca116922afa8 ("xfrm: Eliminate "fl" and "pol" args to xfrm_bundle_ok()."), just get rid of it. xfrm_dst->partner isn't used either, so get rid of that too. Fixes: 9d6ec938019c ("ipv4: Use flowi4 in public route lookup interfaces.") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31sctp: check af before verify address in sctp_addr_id2transportXin Long
[ Upstream commit 912964eacb111551db73429719eb5fadcab0ff8a ] Commit 6f29a1306131 ("sctp: sctp_addr_id2transport should verify the addr before looking up assoc") invoked sctp_verify_addr to verify the addr. But it didn't check af variable beforehand, once users pass an address with family = 0 through sockopt, sctp_get_af_specific will return NULL and NULL pointer dereference will be caused by af->sockaddr_len. This patch is to fix it by returning NULL if af variable is NULL. Fixes: 6f29a1306131 ("sctp: sctp_addr_id2transport should verify the addr before looking up assoc") Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31mac80211: initialize SMPS field in HT capabilitiesFelix Fietkau
[ Upstream commit 43071d8fb3b7f589d72663c496a6880fb097533c ] ibss and mesh modes copy the ht capabilites from the band without overriding the SMPS state. Unfortunately the default value 0 for the SMPS field means static SMPS instead of disabled. This results in HT ibss and mesh setups using only single-stream rates, even though SMPS is not supposed to be active. Initialize SMPS to disabled for all bands on ieee80211_hw_register to ensure that the value is sane where it is not overriden with the real SMPS state. Reported-by: Elektra Wagenrad <onelektra@gmx.net> Signed-off-by: Felix Fietkau <nbd@nbd.name> [move VHT TODO comment to a better place] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31net: dsa: Check return value of phy_connect_direct()Florian Fainelli
[ Upstream commit 4078b76cac68e50ccf1f76a74e7d3d5788aec3fe ] We need to check the return value of phy_connect_direct() in dsa_slave_phy_connect() otherwise we may be continuing the initialization of a slave network device with a PHY that already attached somewhere else and which will soon be in error because the PHY device is in error. The conditions for such an error to occur are that we have a port of our switch that is not disabled, and has the same port number as a PHY address (say both 5) that can be probed using the DSA slave MII bus. We end-up having this slave network device find a PHY at the same address as our port number, and we try to attach to it. A slave network (e.g: port 0) has already attached to our PHY device, and we try to re-attach it with a different network device, but since we ignore the error we would end-up initializating incorrect device references by the time the slave network interface is opened. The code has been (re)organized several times, making it hard to provide an exact Fixes tag, this is a bugfix nonetheless. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31netfilter: synproxy: fix conntrackd interactionEric Leblond
[ Upstream commit 87e94dbc210a720a34be5c1174faee5c84be963e ] This patch fixes the creation of connection tracking entry from netlink when synproxy is used. It was missing the addition of the synproxy extension. This was causing kernel crashes when a conntrack entry created by conntrackd was used after the switch of traffic from active node to the passive node. Signed-off-by: Eric Leblond <eric@regit.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31netfilter: xt_TCPMSS: add more sanity tests on tcph->doffEric Dumazet
[ Upstream commit 2638fd0f92d4397884fd991d8f4925cb3f081901 ] Denys provided an awesome KASAN report pointing to an use after free in xt_TCPMSS I have provided three patches to fix this issue, either in xt_TCPMSS or in xt_tcpudp.c. It seems xt_TCPMSS patch has the smallest possible impact. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Denys Fedoryshchenko <nuclearcat@nuclearcat.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31net: 8021q: Fix one possible panic caused by BUG_ON in free_netdevGao Feng
[ Upstream commit 9745e362add89432d2c951272a99b0a5fe4348a9 ] The register_vlan_device would invoke free_netdev directly, when register_vlan_dev failed. It would trigger the BUG_ON in free_netdev if the dev was already registered. In this case, the netdev would be freed in netdev_run_todo later. So add one condition check now. Only when dev is not registered, then free it directly. The following is the part coredump when netdev_upper_dev_link failed in register_vlan_dev. I removed the lines which are too long. [ 411.237457] ------------[ cut here ]------------ [ 411.237458] kernel BUG at net/core/dev.c:7998! [ 411.237484] invalid opcode: 0000 [#1] SMP [ 411.237705] [last unloaded: 8021q] [ 411.237718] CPU: 1 PID: 12845 Comm: vconfig Tainted: G E 4.12.0-rc5+ #6 [ 411.237737] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015 [ 411.237764] task: ffff9cbeb6685580 task.stack: ffffa7d2807d8000 [ 411.237782] RIP: 0010:free_netdev+0x116/0x120 [ 411.237794] RSP: 0018:ffffa7d2807dbdb0 EFLAGS: 00010297 [ 411.237808] RAX: 0000000000000002 RBX: ffff9cbeb6ba8fd8 RCX: 0000000000001878 [ 411.237826] RDX: 0000000000000001 RSI: 0000000000000282 RDI: 0000000000000000 [ 411.237844] RBP: ffffa7d2807dbdc8 R08: 0002986100029841 R09: 0002982100029801 [ 411.237861] R10: 0004000100029980 R11: 0004000100029980 R12: ffff9cbeb6ba9000 [ 411.238761] R13: ffff9cbeb6ba9060 R14: ffff9cbe60f1a000 R15: ffff9cbeb6ba9000 [ 411.239518] FS: 00007fb690d81700(0000) GS:ffff9cbebb640000(0000) knlGS:0000000000000000 [ 411.239949] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 411.240454] CR2: 00007f7115624000 CR3: 0000000077cdf000 CR4: 00000000003406e0 [ 411.240936] Call Trace: [ 411.241462] vlan_ioctl_handler+0x3f1/0x400 [8021q] [ 411.241910] sock_ioctl+0x18b/0x2c0 [ 411.242394] do_vfs_ioctl+0xa1/0x5d0 [ 411.242853] ? sock_alloc_file+0xa6/0x130 [ 411.243465] SyS_ioctl+0x79/0x90 [ 411.243900] entry_SYSCALL_64_fastpath+0x1e/0xa9 [ 411.244425] RIP: 0033:0x7fb69089a357 [ 411.244863] RSP: 002b:00007ffcd04e0fc8 EFLAGS: 00000202 ORIG_RAX: 0000000000000010 [ 411.245445] RAX: ffffffffffffffda RBX: 00007ffcd04e2884 RCX: 00007fb69089a357 [ 411.245903] RDX: 00007ffcd04e0fd0 RSI: 0000000000008983 RDI: 0000000000000003 [ 411.246527] RBP: 00007ffcd04e0fd0 R08: 0000000000000000 R09: 1999999999999999 [ 411.246976] R10: 000000000000053f R11: 0000000000000202 R12: 0000000000000004 [ 411.247414] R13: 00007ffcd04e1128 R14: 00007ffcd04e2888 R15: 0000000000000001 [ 411.249129] RIP: free_netdev+0x116/0x120 RSP: ffffa7d2807dbdb0 Signed-off-by: Gao Feng <gfree.wind@vip.163.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31decnet: always not take dst->__refcnt when inserting dst into hash tableWei Wang
[ Upstream commit 76371d2e3ad1f84426a30ebcd8c3b9b98f4c724f ] In the existing dn_route.c code, dn_route_output_slow() takes dst->__refcnt before calling dn_insert_route() while dn_route_input_slow() does not take dst->__refcnt before calling dn_insert_route(). This makes the whole routing code very buggy. In dn_dst_check_expire(), dnrt_free() is called when rt expires. This makes the routes inserted by dn_route_output_slow() not able to be freed as the refcnt is not released. In dn_dst_gc(), dnrt_drop() is called to release rt which could potentially cause the dst->__refcnt to be dropped to -1. In dn_run_flush(), dst_free() is called to release all the dst. Again, it makes the dst inserted by dn_route_output_slow() not able to be released and also, it does not wait on the rcu and could potentially cause crash in the path where other users still refer to this dst. This patch makes sure both input and output path do not take dst->__refcnt before calling dn_insert_route() and also makes sure dnrt_free()/dst_free() is called when removing dst from the hash table. The only difference between those 2 calls is that dnrt_free() waits on the rcu while dst_free() does not. Signed-off-by: Wei Wang <weiwan@google.com> Acked-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31ipv6: fix calling in6_ifa_hold incorrectly for dad workXin Long
[ Upstream commit f8a894b218138888542a5058d0e902378fd0d4ec ] Now when starting the dad work in addrconf_mod_dad_work, if the dad work is idle and queued, it needs to hold ifa. The problem is there's one gap in [1], during which if the pending dad work is removed elsewhere. It will miss to hold ifa, but the dad word is still idea and queue. if (!delayed_work_pending(&ifp->dad_work)) in6_ifa_hold(ifp); <--------------[1] mod_delayed_work(addrconf_wq, &ifp->dad_work, delay); An use-after-free issue can be caused by this. Chen Wei found this issue when WARN_ON(!hlist_unhashed(&ifp->addr_lst)) in net6_ifa_finish_destroy was hit because of it. As Hannes' suggestion, this patch is to fix it by holding ifa first in addrconf_mod_dad_work, then calling mod_delayed_work and putting ifa if the dad_work is already in queue. Note that this patch did not choose to fix it with: if (!mod_delayed_work(delay)) in6_ifa_hold(ifp); As with it, when delay == 0, dad_work would be scheduled immediately, all addrconf_mod_dad_work(0) callings had to be moved under ifp->lock. Reported-by: Wei Chen <weichen@redhat.com> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31igmp: add a missing spin_lock_init()WANG Cong
[ Upstream commit b4846fc3c8559649277e3e4e6b5cec5348a8d208 ] Andrey reported a lockdep warning on non-initialized spinlock: INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. CPU: 1 PID: 4099 Comm: a.out Not tainted 4.12.0-rc6+ #9 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 dump_stack+0x292/0x395 lib/dump_stack.c:52 register_lock_class+0x717/0x1aa0 kernel/locking/lockdep.c:755 ? 0xffffffffa0000000 __lock_acquire+0x269/0x3690 kernel/locking/lockdep.c:3255 lock_acquire+0x22d/0x560 kernel/locking/lockdep.c:3855 __raw_spin_lock_bh ./include/linux/spinlock_api_smp.h:135 _raw_spin_lock_bh+0x36/0x50 kernel/locking/spinlock.c:175 spin_lock_bh ./include/linux/spinlock.h:304 ip_mc_clear_src+0x27/0x1e0 net/ipv4/igmp.c:2076 igmpv3_clear_delrec+0xee/0x4f0 net/ipv4/igmp.c:1194 ip_mc_destroy_dev+0x4e/0x190 net/ipv4/igmp.c:1736 We miss a spin_lock_init() in igmpv3_add_delrec(), probably because previously we never use it on this code path. Since we already unlink it from the global mc_tomb list, it is probably safe not to acquire this spinlock here. It does not harm to have it although, to avoid conditional locking. Fixes: c38b7d327aaf ("igmp: acquire pmc lock for ip_mc_clear_src()") Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31igmp: acquire pmc lock for ip_mc_clear_src()WANG Cong
[ Upstream commit c38b7d327aafd1e3ad7ff53eefac990673b65667 ] Andrey reported a use-after-free in add_grec(): for (psf = *psf_list; psf; psf = psf_next) { ... psf_next = psf->sf_next; where the struct ip_sf_list's were already freed by: kfree+0xe8/0x2b0 mm/slub.c:3882 ip_mc_clear_src+0x69/0x1c0 net/ipv4/igmp.c:2078 ip_mc_dec_group+0x19a/0x470 net/ipv4/igmp.c:1618 ip_mc_drop_socket+0x145/0x230 net/ipv4/igmp.c:2609 inet_release+0x4e/0x1c0 net/ipv4/af_inet.c:411 sock_release+0x8d/0x1e0 net/socket.c:597 sock_close+0x16/0x20 net/socket.c:1072 This happens because we don't hold pmc->lock in ip_mc_clear_src() and a parallel mr_ifc_timer timer could jump in and access them. The RCU lock is there but it is merely for pmc itself, this spinlock could actually ensure we don't access them in parallel. Thanks to Eric and Long for discussion on this bug. Reported-by: Andrey Konovalov <andreyknvl@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Xin Long <lucien.xin@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Reviewed-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31net: caif: Fix a sleep-in-atomic bug in cfpkt_create_pfxJia-Ju Bai
[ Upstream commit f146e872eb12ebbe92d8e583b2637e0741440db3 ] The kernel may sleep under a rcu read lock in cfpkt_create_pfx, and the function call path is: cfcnfg_linkup_rsp (acquire the lock by rcu_read_lock) cfctrl_linkdown_req cfpkt_create cfpkt_create_pfx alloc_skb(GFP_KERNEL) --> may sleep cfserl_receive (acquire the lock by rcu_read_lock) cfpkt_split cfpkt_create_pfx alloc_skb(GFP_KERNEL) --> may sleep There is "in_interrupt" in cfpkt_create_pfx to decide use "GFP_KERNEL" or "GFP_ATOMIC". In this situation, "GFP_KERNEL" is used because the function is called under a rcu read lock, instead in interrupt. To fix it, only "GFP_ATOMIC" is used in cfpkt_create_pfx. Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31Fix an intermittent pr_emerg warning about lo becoming free.Krister Johansen
[ Upstream commit f186ce61bb8235d80068c390dc2aad7ca427a4c2 ] It looks like this: Message from syslogd@flamingo at Apr 26 00:45:00 ... kernel:unregister_netdevice: waiting for lo to become free. Usage count = 4 They seem to coincide with net namespace teardown. The message is emitted by netdev_wait_allrefs(). Forced a kdump in netdev_run_todo, but found that the refcount on the lo device was already 0 at the time we got to the panic. Used bcc to check the blocking in netdev_run_todo. The only places where we're off cpu there are in the rcu_barrier() and msleep() calls. That behavior is expected. The msleep time coincides with the amount of time we spend waiting for the refcount to reach zero; the rcu_barrier() wait times are not excessive. After looking through the list of callbacks that the netdevice notifiers invoke in this path, it appears that the dst_dev_event is the most interesting. The dst_ifdown path places a hold on the loopback_dev as part of releasing the dev associated with the original dst cache entry. Most of our notifier callbacks are straight-forward, but this one a) looks complex, and b) places a hold on the network interface in question. I constructed a new bcc script that watches various events in the liftime of a dst cache entry. Note that dst_ifdown will take a hold on the loopback device until the invalidated dst entry gets freed. [ __dst_free] on DST: ffff883ccabb7900 IF tap1008300eth0 invoked at 1282115677036183 __dst_free rcu_nocb_kthread kthread ret_from_fork Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-07-31af_unix: Add sockaddr length checks before accessing sa_family in bind and ↵Mateusz Jurczyk
connect handlers [ Upstream commit defbcf2decc903a28d8398aa477b6881e711e3ea ] Verify that the caller-provided sockaddr structure is large enough to contain the sa_family field, before accessing it in bind() and connect() handlers of the AF_UNIX socket. Since neither syscall enforces a minimum size of the corresponding memory region, very short sockaddrs (zero or one byte long) result in operating on uninitialized memory while referencing .sa_family. Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
