path: root/net
2006-12-13[NETFILTER]: bridge-netfilter: remove deferred hooksPatrick McHardy
Remove the deferred hooks and all related code as scheduled in feature-removal-schedule. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[IPV6]: Make fib6_node subtree depend on IPV6_SUBTREESKim Nordlund
Make fib6_node 'subtree' depend on IPV6_SUBTREES. Signed-off-by: Kim Nordlund <kim.nordlund@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[SCTP]: Add support for SCTP_CONTEXT socket option.Ivan Skytte Jorgensen
Signed-off-by: Ivan Skytte Jorgensen <isj-sctp@i1.dk> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[SCTP]: Enable auto loading of SCTP when creating an ipv6 SCTP socket.Sridhar Samudrala
2006-12-13[SCTP]: Handle address add/delete events in a more efficient way.Sridhar Samudrala
Currently in SCTP, we maintain a local address list by rebuilding the whole list from the device list whenever we get a address add/delete event. This patch fixes it by only adding/deleting the address for which we receive the event. Also removed the sctp_local_addr_lock() which is no longer needed as we now use list_for_each_safe() to traverse this list. This fixes the bugs in sctp_copy_laddrs_xxx() routines where we do copy_to_user() while holding this lock. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[TCP]: Fix oops caused by __tcp_put_md5sig_pool()David S. Miller
It should call tcp_free_md5sig_pool() not __tcp_free_md5sig_pool() so that it does proper refcounting. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[IPV6]: Fix IPV6_UNICAST_HOPS getsockopt().Brian Haley
> Relevant standard (RFC 3493) notes: > > The IPV6_UNICAST_HOPS option may be used with getsockopt() to > determine the hop limit value that the system will use for subsequent > unicast packets sent via that socket. > > I don't reckon -1 could be the hop limit value. -1 means un-initialized. > IMHO, the value from > case 1 (if socket is connected to some destination), otherwise case 2 > (if bound to a scope interface) or ultimately the default hop limit > ought to be returned instead, as it will be most often correct, while > the current behavior is always wrong, unless setsockopt() has been used > first. I don't if some people may think doing a route lookup in > getsockopt might be overly expensive, but at least the two other cases > should be ok, particularly the last one. The following patch seems to work for me, but this code has behaved this way for a while, so don't know if it will break any existing apps. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[DCCP] ccid3: return value in ccid3_hc_rx_calc_first_liIan McDonald
In a recent patch we introduced invalid return codes which will result in the opposite of what is intended (i.e. send more packets in face of peculiar network conditions). This fixes it by returning ~0 which means not calculated as per dccp_li_hist_calc_i_mean. Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-13[NETFILTER]: {ip,ip6,arp}_tables: fix exponential worst-case search for loopsAl Viro
If we come to node we'd already marked as seen and it's not a part of path (i.e. we don't have a loop right there), we already know that it isn't a part of any loop, so we don't need to revisit it. That speeds the things up if some chain is refered to from several places and kills O(exp(table size)) worst-case behaviour (without sleeping, at that, so if you manage to self-LART that way, you are SOL for a long time)... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[NETFILTER]: ip_tables: ipt and ipt_compat checks unificationDmitry Mishin
Matches and targets verification is duplicated in normal and compat processing ways. This patch refactors code in order to remove this. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[NETFILTER]: x_tables: add missing try to load conntrack from match/targetsYasuyuki Kozakai
CLUSTERIP, CONNMARK, CONNSECMARK, and connbytes need ip_conntrack or layer 3 protocol module of nf_conntrack. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[NETFILTER]: x_tables: error if ip_conntrack is asked to handle IPv6 packetsYasuyuki Kozakai
To do that, this makes nf_ct_l3proto_try_module_{get,put} compatible functions. As a result we can remove '#ifdef' surrounds and direct call of need_conntrack(). Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[NETFILTER]: nf_nat: fix NF_NAT dependencyYasuyuki Kozakai
NF_NAT depends on NF_CONNTRACK_IPV4, not NF_CONNTRACK. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[NETFILTER]: Fix INET=n linking errorPatrick McHardy
Building with INET=n results in WARNING: "ip_route_output_key" [net/netfilter/nf_conntrack_h323.ko] undefined! The entire code in net/netfilter is only used for IPv4/IPv6 currently, so let it depend on INET. Noticed by Toralf Förster <toralf.foerster@gmx.de>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] knfsd: Don't ignore kstrdup failure in rpc cachesNeilBrown
Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] knfsd: svcrpc: remove another silent drop from deferral codeJ.Bruce Fields
There's no point deferring something just to immediately fail the deferral, especially now that we can do something more useful in the failure case by returning an error. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] knfsd: nfsd: don't drop silently on upcall deferralJ.Bruce Fields
To avoid tying up server threads when nfsd makes an upcall (to mountd, to get export options, to idmapd, for nfsv4 name<->id mapping, etc.), we temporarily "drop" the request and save enough information so that we can revisit it later. Certain failures during the deferral process can cause us to really drop the request and never revisit it. This is often less than ideal, and is unacceptable in the NFSv4 case--rfc 3530 forbids the server from dropping a request without also closing the connection. As a first step, we modify the deferral code to return -ETIMEDOUT (which is translated to nfserr_jukebox in the v3 and v4 cases, and remains a drop in the v2 case). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] knfsd: svcrpc: fix gss krb5i memory leakJ.Bruce Fields
The memory leak here is embarassingly obvious. This fixes a problem that causes the kernel to leak a small amount of memory every time it receives a integrity-protected request. Thanks to Aim Le Rouzic for the bug report. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] hci endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Fix inotify maintainers entry Fix typo in new debug options. Jon needs a new shift key. fs: Convert kmalloc() + memset() to kzalloc() in fs/. configfs.h: Remove dead macro definitions. kconfig: Standardize "depends" -> "depends on" in Kconfig files e100: replace kmalloc with kcalloc um: replace kmalloc+memset with kzalloc fix typo in net/ipv4/ip_fragment.c include/linux/compiler.h: reject gcc 3 < gcc 3.2 Kconfig: fix spelling error in config KALLSYMS help text Remove duplicate "have to" in comment Fix small typo in drivers/serial/icom.c Use consistent casing in help message EXT{2,3,4}_FS: remove outdated part of the help text
2006-12-12fix typo in net/ipv4/ip_fragment.cPeter Zijlstra
2006-12-12[PATCH] netpoll: fix netpoll lockupIngo Molnar
current -git doesnt boot on my laptop due to netpoll not unlocking the tx lock in the else branch. booted this up on my laptop with lockdep enabled and there are no locking complaints and it works fine. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-11[NETPOLL]: Fix local_bh_enable() warning.Andrew Morton
During boot we get: netconsole: device eth0 not up yet, forcing it e1000: eth0: e1000_watchdog: NIC Link is Up 100 Mbps Full Duplex WARNING (!__warned) at kernel/softirq.c:137 local_bh_enable() Call Trace: [<ffffffff80235baf>] local_bh_enable+0x41/0xa3 [<ffffffff8045ab8e>] netpoll_send_skb+0x116/0x144 [<ffffffff8045b1ee>] netpoll_send_udp+0x263/0x271 [<ffffffff803d41ec>] write_msg+0x42/0x5e [<ffffffff80230c9b>] __call_console_drivers+0x5f/0x70 [<ffffffff80230d19>] _call_console_drivers+0x6d/0x71 [<ffffffff802313f0>] release_console_sem+0x148/0x1ec [<ffffffff802316ce>] register_console+0x1b1/0x1ba [<ffffffff803d4178>] init_netconsole+0x54/0x68 [<ffffffff802071ae>] init+0x152/0x308 [<ffffffff804dac8b>] _spin_unlock_irq+0x14/0x30 [<ffffffff8022c15e>] schedule_tail+0x43/0x9f [<ffffffff8020a758>] child_rip+0xa/0x12 Herbert sayeth: Normally networking isn't invoked with interrupts turned off, but I suppose we don't have a choice here. This is unique being a place where you can get called with BH on, off, or IRQs off. Given that this is only used for printk, the easiest solution is probably just to disable local IRQs instead of BH. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[IPVS]: Make ip_vs_sync.c <= 80col wide.Simon Horman
Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[IPVS]: Use msleep_interruptable() instead of ssleep() aka msleep()Simon Horman
Dean Manners notices that when an IPVS synchonisation daemons are started the system load slowly climbs up to 1. This seems to be related to the call to ssleep(1) (aka msleep(1000) in the main loop. Replacing this with a call to msleep_interruptable() seems to make the problem go away. Though I'm not sure that it is correct. This is the second edition of this patch, which replaces ssleep() in the main loop for both the master and backup threads, as well as some thread synchronisation code. The latter is just for thorougness as it shouldn't be causing any problems. Signed-Off-By: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[HAMRADIO]: Fix baycom_epp.c compile failure.Ralf Baechle
Fix foobar in 15b1c0e822f578306332d4f4c449250db5c5dceb and e8cc49bb0fdb9e18a99e6780073d1400ba2b0d1f patch series. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[DCCP]: Whitespace cleanupsArnaldo Carvalho de Melo
That accumulated over the last months hackaton, shame on me for not using git-apply whitespace helping hand, will do that from now on. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Fixup some type conversions related to rttsArnaldo Carvalho de Melo
Spotted by David Miller when compiling on sparc64, I reproduced it here on parisc64, that are the only platforms to define __kernel_suseconds_t as an 'int', all the others, x86_64 and x86 included typedef it as a 'long', but from the definition of suseconds_t it should just be an 'int' on platforms where it is >= 32bits, it would not require all the castings from suseconds_t to (int) when printking variables of this type, that are not needed on parisc64 and sparc64. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: BUG-FIX - conversion errorsGerrit Renker
This fixes conversion errors which arose by not properly type-casting from u32 to __u64. Fixed by explicitly casting each type which is not __u64, or by performing operation after assignment. The patch further adds missing debug information to track the current value of X_recv. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Reorder packet history source fileGerrit Renker
No code change at all. This reorders the source file to follow the same order as the corresponding header file. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Reorder packet history header fileGerrit Renker
No code change at all. To make the header file easier to read, the following ordering is established among the declarations: * hist_new * hist_delete * hist_entry_new * hist_head * hist_find_entry * hist_add_entry * hist_entry_delete * hist_purge Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Make debug output consistentGerrit Renker
This patch does not alter any algorithm, just the debug message format: * s#%s, sk=%p#%s(%p)#g * when a statename is present, it now uses %s(%p, state=%s) * when only function entry is debugged, it adds an `- entry' Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Perform history operations only after packet has been sentGerrit Renker
This migrates all packet history operations into the routine ccid3_hc_tx_packet_sent, thereby removing synchronization problems that occur when, as before, the operations are spread over multiple routines. The following minor simplifications are also applied: * several simplifications now follow from this change - several tests are now no longer required * removal of one unnecessary variable (dp) Justification: Currently packet history operations span two different routines, one of which is likely to pass through several iterations of sleeping and awakening. The first routine, ccid3_hc_tx_send_packet, allocates an entry and sets a few fields. The remaining fields are filled in when the second routine (which is not within a sleeping context), ccid3_hc_tx_packet_sent, is called. This has several strong drawbacks: * it is not necessary to split history operations - all fields can be filled in by the second routine * the first routine is called multiple times, until a packet can be sent, and sleeps meanwhile - this causes a lot of difficulties with regard to keeping the list consistent * since both routines do not have a producer-consumer like synchronization, it is very difficult to maintain data across calls to these routines * the fact that the routines are called in different contexts (sleeping, not sleeping) adds further problems Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: TX history - remove unused fieldGerrit Renker
This removes the `dccphtx_ccval' field since it is nowhere used in the code and in fact not necessary for the accounting. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Shift window counter computationGerrit Renker
This puts the window counter computation [RFC 4342, 8.1] into a separate function which is called whenever a new packet is ready for immediate transmission in ccid3_hc_tx_send_packet. Justification: The window counter update was previously computed after the packet was sent. This has two drawbacks, both fixed by this patch: 1) re-compute another timestamp almost directly after the packet was sent (expensive), 2) the CCVal for the window counter is needed at the instant the packet is sent. Further details: The initialisation of the window counter is left in the state NO_SENT, as before. The algorithm will do nothing if either RTT is initialised to 0 (which is ok) or if the RTT value remains below 4 microseconds (which is almost pathological). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Sanity-check RTT samplesGerrit Renker
CCID3 performance depends much on the accuracy of RTT samples. If RTT samples grow too large, performance can be catastrophically poor. To limit the amount of possible damage in such cases, the patch * introduces an upper limit which identifies a maximum `sane' RTT value; * uses a macro to enforce this upper limit. Using a macro was given preference, since it is necessary to identify the calling function in the warning message. Since exceeding this threshold identifies a critical condition, DCCP_CRIT is used and not DCCP_WARN. Many thanks to Ian McDonald for collaboration on this issue. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Initialise RTT valuesGerrit Renker
In both the sender and the receiver it is possible that the stored RTT value is accessed before an actual RTT estimate has been computed. This patch * initialises the sender RTT to 0 - the sender always accesses the RTT in ccid3_hc_tx_packet_sent - the RTT is further needed for the window counter algorithm * replaces the receiver initialisation of 5msec with 0 - which has the same effect and removes an `XXX' - the RTT value is needed in ccid3_hc_rx_packet_recv as rtt_prev Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid: Deprecate ccid_hc_tx_insert_optionsGerrit Renker
The function ccid3_hc_tx_insert_options only does a redundant no-op, as the operation DCCP_SKB_CB(skb)->dccpd_ccval = hctx->ccid3hctx_last_win_count; is already performed _unconditionally_ in ccid3_hc_tx_send_packet. Since there is further no current need for this function, it is removed entirely. Since furthermore, there is actually no present need for the entire interface function ccid_hc_tx_insert_options, it was decided to remove it also, to clean up the interface. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Warn when discarding packet due to internal errorsGerrit Renker
This adds a (debug) warning message which is triggered whenever a packet is discarded due to send failure. It also adds a conditional, so that an interruption during dccp_wait_for_ccid is not treated as a `BUG': the rationale is that interruptions are external, whereas bug warnings are concerned with the internals. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Only deliver to the CCID rx side in chargeGerrit Renker
This is an optimisation to reduce CPU load. The received feedback is now only directed to the active CCID component, without requiring processing also by the inactive one. As a consequence, a similar test in ccid3.c is now redundant and is also removed. Justification: Currently DCCP works as a unidirectional service, i.e. a listening server is not at the same time a connecting client. As far as I can see, several modifications are necessary until that becomes possible. At the present time, received feedback is both fed to the rx/tx CCID modules. In unidirectional service, only one of these is active at any one time. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Simplify TFRC calculationGerrit Renker
In migrating towards using the newer functions scaled_div/scaled_div32 for TFRC computations mapped from floating-point onto integer arithmetic, this completes the last stage of modifications. In particular, the overflow case for computing X_calc is circumvented by * breaking the computation into two stages * the first stage, res = (s*1E6)/R, cannot overflow due to use of u64 * in the second stage, res = (res*1E6)/f, overflow on u32 is avoided due to (i) returning UINT_MAX in this case (which is logically appropriate) and (ii) issuing a warning message into the system log (since very likely there is a problem somewhere else with the parameters) Lastly, all such scaling operations are now exported into tfrc.h, since actually this form of scaled computation is specific to TFRC and not to CCID3. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Debug timeval operationsGerrit Renker
Problem: Most target types in the CCID3 code are u32, so subtle conversion errors can occur if signed time calculations yield negative results: the original values are lost in the conversion to unsigned, calculation errors go undetected. This patch therefore * sets all critical time types from unsigned to suseconds_t * avoids comparison between signed/unsigned via type-casting * provides ample warning messages in case time calculations are negative These warning messages can be removed at a later stage when the code has undergone more testing. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Simplify calculation for reverse lookup of pGerrit Renker
This simplifies the calculation of a value p for a given fval when the first loss interval is computed (RFC 3448, 6.3.1). It makes use of the two new functions scaled_div/scaled_div32 to provide overflow protection. Additionally, protection against divide-by-zero is extended - in this case the function will return the maximally possible value of p=100%. Background: The maximum fval, f(100%), is approximately 244, i.e. the scaled value of fval should never exceed 244E6, which fits easily into u32. The problem is the scaling by 10^6, since additionally R(TT) is in microseconds. This is resolved by breaking the division into two stages: the first stage computes fval=(s*10^6)/R, stores that into u64; the second stage computes fval = (fval*10^6)/X_recv and complains if overflow is reached for u32. This case is safe since the TFRC reverse-lookup routine then returns p=100%. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Replace scaled division operationsGerrit Renker
This replaces the remaining uses of usecs_div with scaled_div32, which internally uses 64bit division and produces a warning on overflow. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Finer-grained resolution of sending ratesGerrit Renker
This patch * resolves a bug where packets smaller than 32/64 bytes resulted in sending rates of 0 * supports all sending rates from 1/64 bytes/second up to 4Gbyte/second * simplifies the present overflow problems in calculations Current sending rate X and the cached value X_recv of the receiver-estimated sending rate are both scaled by 64 (2^6) in order to * cope with low sending rates (minimally 1 byte/second) * allow upgrading to use a packets-per-second implementation of CCID 3 * avoid calculation errors due to integer arithmetic cut-off The patch implements a revised strategy from http://www.mail-archive.com/dccp@vger.kernel.org/msg01040.html The only difference with regard to that strategy is that t_ipi is already used in the calculation of the nofeedback timeout, which saves one division. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Fix two bugs in sending rate computationGerrit Renker
This fixes 1) a bug in the recomputation of the sending rate by the nofeedback timer when no feedback at all has so far been sent by the receiver: min_t was used instead of max_t, which is wrong (cf. RFC 3448, p. 10); 2) an error in the computation of larger initial windows: instead of min(... max()) (cf. RFC 4342, 5.), the code had used max(... max()). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Two optimisations for sending rate recomputationGerrit Renker
This performs two optimisations for the recomputation of the sending rate. 1) Currently the target sending rate X_calc is recalculated whenever a) the nofeedback timer expires, or b) a feedback packet is received. In the (a) case, recomputing X_calc is redundant, since * the parameters p and RTT do not change in between the reception of feedback packets; * the parameter X_recv is either modified from received feedback or via the nofeedback timer; * a test (`p == 0') in the nofeedback timer avoids using a stale/undefined value of X_calc if p was previously 0. 2) The nofeedback timer now only recomputes a timestamp when p == 0. This is according to step (4) of [RFC 3448, 4.3] and avoids unnecessarily determining a timestamp. A debug statement about not updating X is also removed - it helps very little in debugging and just clutters the logs. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Check against too large pGerrit Renker
This patch follows a suggestion by Ian McDonald and ensures that in the current code the value of p can not exceed 100%. Such a value is illegal and would consequently cause a bug condition in tfrc_calc_x(). The receiver case is also tested, and a warning message is added. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
