[ Upstream commit 6e601a53566d84e1ffd25e7b6fe0b6894ffd79c0 ]
Userland can send a netlink message requesting SOCK_DIAG_BY_FAMILY
with a family greater or equal then AF_MAX -- the array size of
sock_diag_handlers[]. The current code does not test for this
condition therefore is vulnerable to an out-of-bound access opening
doors for a privilege escalation.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
[ Upstream commit bc9540c637c3d8712ccbf9dcf28621f380ed5e64 ]
commit 9ca1b22d6d2 (net: splice: avoid high order page splitting)
forgot that skb->head could need a copy into several page frags.
This could be the case for loopback traffic mostly.
Also remove now useless skb argument from linear_to_page()
and __splice_segment() prototypes.
Cc: Willy Tarreau <w@1wt.eu>
[ Upstream commit 82bda6195615891181115f579a480aa5001ce7e9 ]
splice() can handle pages of any order, but network code tries hard to
split them in PAGE_SIZE units. Not quite successfully anyway, as
__splice_segment() assumed poff < PAGE_SIZE. This is true for
the skb->data part, not necessarily for the fragments.
This patch removes this logic to give the pages as they are in the skb.
[ Upstream commit f26845b43c75d3f32f98d194c1327b5b1e6b3fb0 ]
Under unusual circumstances, TCP collapse can split a big GRO TCP packet
while its being used in a splice(socket->pipe) operation.
skb_splice_bits() releases the socket lock before calling
splice_to_pipe().
[ 1081.353685] WARNING: at net/ipv4/tcp.c:1330 tcp_cleanup_rbuf+0x4d/0xfc()
[ 1081.371956] Hardware name: System x3690 X5 -[7148Z68]-
[ 1081.391820] cleanup rbuf bug: copied AD3BCF1 seq AD370AF rcvnxt AD3CF13
To fix this problem, we must eat skbs in tcp_recv_skb().
Remove the inline keyword from tcp_recv_skb() definition since
it has three call sites.
Reported-by: Christian Becker <c.becker@traviangames.com>
Tested-by: Willy Tarreau <w@1wt.eu>
[ Upstream commit ff905b1e4aad8ccbbb0d42f7137f19482742ff07 ]
commit 02275a2ee7c0 (tcp: don't abort splice() after small transfers)
added a regression.
[ 83.843570] INFO: rcu_sched self-detected stall on CPU
[ 83.844575] INFO: rcu_sched detected stalls on CPUs/tasks: { 6} (detected by 0, t=21002 jiffies, g=4457, c=4456, q=13132)
[ 83.844582] Task dump for CPU 6:
[ 83.844584] netperf R running task 0 8966 8952 0x0000000c
[ 83.844587] 0000000000000000 0000000000000006 0000000000006c6c 0000000000000000
[ 83.844589] 000000000000006c 0000000000000096 ffffffff819ce2bc ffffffffffffff10
[ 83.844592] ffffffff81088679 0000000000000010 0000000000000246 ffff880c4b9ddcd8
[ 83.844594] Call Trace:
[ 83.844596] [<ffffffff81088679>] ? vprintk_emit+0x1c9/0x4c0
[ 83.844601] [<ffffffff815ad449>] ? schedule+0x29/0x70
[ 83.844606] [<ffffffff81537bd2>] ? tcp_splice_data_recv+0x42/0x50
[ 83.844610] [<ffffffff8153beaa>] ? tcp_read_sock+0xda/0x260
[ 83.844613] [<ffffffff81537b90>] ? tcp_prequeue_process+0xb0/0xb0
[ 83.844615] [<ffffffff8153c0f0>] ? tcp_splice_read+0xc0/0x250
[ 83.844618] [<ffffffff814dc0c2>] ? sock_splice_read+0x22/0x30
[ 83.844622] [<ffffffff811b820b>] ? do_splice_to+0x7b/0xa0
[ 83.844627] [<ffffffff811ba4bc>] ? sys_splice+0x59c/0x5d0
[ 83.844630] [<ffffffff8119745b>] ? putname+0x2b/0x40
[ 83.844633] [<ffffffff8118bcb4>] ? do_sys_open+0x174/0x1e0
[ 83.844636] [<ffffffff815b6202>] ? system_call_fastpath+0x16/0x1b
if recv_actor() returns 0, we should stop immediately,
because looping wont give a chance to drain the pipe.
[ Upstream commit 02275a2ee7c0ea475b6f4a6428f5df592bc9d30b ]
TCP coalescing added a regression in splice(socket->pipe) performance,
for some workloads because of the way tcp_read_sock() is implemented.
The reason for this is the break when (offset + 1 != skb->len).
As we released the socket lock, this condition is possible if TCP stack
added a fragment to the skb, which can happen with TCP coalescing.
So let's go back to the beginning of the loop when this happens,
to give a chance to splice more frags per system call.
Doing so fixes the issue and makes GRO 10% faster than LRO
on CPU-bound splice() workloads instead of the opposite.
Signed-off-by: Willy Tarreau <w@1wt.eu>
[ Upstream commit 6731d2095bd4aef18027c72ef845ab1087c3ba63 ]
There are transients during normal FRTO procedure during which
the packets_in_flight can go to zero between write_queue state
updates and firing the resulting segments out. As FRTO processing
occurs during that window the check must be more precise to
not match "spuriously" :-). More specificly, e.g., when
packets_in_flight is zero but FLAG_DATA_ACKED is true the problematic
branch that set cwnd into zero would not be taken and new segments
might be sent out later.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Tested-by: Eric Dumazet <edumazet@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 2e5f421211ff76c17130b4597bc06df4eeead24f ]
Commit 9dc274151a548 (tcp: fix ABC in tcp_slow_start())
uncovered a bug in FRTO code :
tcp_process_frto() is setting snd_cwnd to 0 if the number
of in flight packets is 0.
As Neal pointed out, if no packet is in flight we lost our
chance to disambiguate whether a loss timeout was spurious.
We should assume it was a proper loss.
Reported-by: Pasi Kärkkäinen <pasik@iki.fi>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Cc: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 973ec449bb4f2b8c514bacbcb4d9506fc31c8ce3 ]
Since commit 9dc274151a548 (tcp: fix ABC in tcp_slow_start()),
a nul snd_cwnd triggers an infinite loop in tcp_slow_start()
Avoid this infinite loop and log a one time error for further
analysis. FRTO code is suspected to cause this bug.
Cc: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 66555e92fb7a619188c02cceae4bbc414f15f96d ]
On receiving the SYN-ACK, Fast Open checks icsk_retransmit for SYN
retransmission to detect SYN/data drops. But if F-RTO is disabled,
icsk_retransmit is reset at step D of tcp_fastretrans_alert() (
under tcp_ack()) before tcp_rcv_fastopen_synack(). The fix is to use
total_retrans instead which accounts for SYN retransmission regardless
the use of F-RTO.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit b5c37fe6e24eec194bb29d22fdd55d73bcc709bf ]
On sctp_endpoint_destroy, previously used sensitive keying material
should be zeroed out before the memory is returned, as we already do
with e.g. auth keys when released.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 6ba542a291a5e558603ac51cda9bded347ce7627 ]
In sctp_setsockopt_auth_key, we create a temporary copy of the user
passed shared auth key for the endpoint or association and after
internal setup, we free it right away. Since it's sensitive data, we
should zero out the key before returning the memory back to the
allocator. Thus, use kzfree instead of kfree, just as we do in
sctp_auth_key_put().
[ Upstream commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86 ]
Jamie Parsons reported a problem recently, in which the re-initalization of an
association (The duplicate init case), resulted in a loss of receive window
space. He tracked down the root cause to sctp_outq_teardown, which discarded
all the data on an outq during a re-initalization of the corresponding
association, but never reset the outq->outstanding_data field to zero. I wrote,
and he tested this fix, which does a proper full re-initalization of the outq,
fixing this problem, and hopefully future proofing us from simmilar issues down
the road.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Jamie Parsons <Jamie.Parsons@metaswitch.com>
Tested-by: Jamie Parsons <Jamie.Parsons@metaswitch.com>
CC: Jamie Parsons <Jamie.Parsons@metaswitch.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: netdev@vger.kernel.org
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit b44108dbdbaa07c609bb5755e8dd6c2035236251 ]
git commit 9cb3a50c (ipv4: Invalidate the socket cached route on
pmtu events if possible) introduced a refcount problem. We don't
get a refcount on the route if we get it from__sk_dst_get(), but
we need one if we want to reuse this route because __sk_dst_set()
releases the refcount of the old route. This patch adds proper
refcount handling for that case. We introduce a 'new' flag to
indicate that we are going to use a new route and we release the
old route only if we replace it by a new one.
Reported-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 8141ed9fcedb278f4a3a78680591bef1e55f75fb ]
This implements a socket release callback function to check
if the socket cached route got invalid during the time
we owned the socket. The function is used from udp, raw
and ping sockets.
[ Upstream commit 9cb3a50c5f63ed745702972f66eaee8767659acd ]
The route lookup in ipv4_sk_update_pmtu() might return a route
different from the route we cached at the socket. This is because
standart routes are per cpu, so each cpu has it's own struct rtable.
This means that we do not invalidate the socket cached route if the
NET_RX_SOFTIRQ is not served by the same cpu that the sending socket
uses. As a result, the cached route reused until we disconnect.
With this patch we invalidate the socket cached route if possible.
If the socket is owened by the user, we can't update the cached
route directly. A followup patch will implement socket release
callback functions for datagram sockets to handle this case.
Reported-by: Yurij M. Plotnikov <Yurij.Plotnikov@oktetlabs.ru>
[ Upstream commit 6f809da27c94425e07be4a64d5093e1df95188e9 ]
pmtu and redirect events are now handled in the protocols error handler,
so add an error handler for icmp6 to do this. It is needed in the case
when we have no socket context. Based on a patch by Duan Jiong.
Reported-by: Duan Jiong <djduanjiong@gmail.com>
[ Upstream commit fa1e492aa3cbafba9f8fc6d05e5b08a3091daf4a ]
Routes with locked mtu should not use learned pmtu informations,
so do not update the pmtu on these routes.
[ Upstream commit 38d523e2948162776903349c89d65f7b9370dadb ]
The output route check was introduced with git commit 261663b0
(ipv4: Don't use the cached pmtu informations for input routes)
during times when we cached the pmtu informations on the
inetpeer. Now the pmtu informations are back in the routes,
so this check is obsolete. It also had some unwanted side effects,
as reported by Timo Teras and Lukas Tribus.
Acked-by: Timo Teräs <timo.teras@iki.fi>
[ Upstream commit 41ab3e31bd50b42c85ac0aa0469642866aee2a9a ]
ip6gre_tunnel_xmit() is leaking the skb when we hit this error branch,
and the -1 return value from this function is bogus. Use the error
handling we already have in place in ip6gre_tunnel_xmit() for this error
case to fix this.
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
[ Upstream commit 9665d5d62487e8e7b1f546c00e11107155384b9a ]
When releasing a packet socket, the routine packet_set_ring() is reused
to free rings instead of allocating them. But when calling it for the
first time, it fills req->tp_block_nr with the value of rb->pg_vec_len
which in the second invocation makes it bail out since req->tp_block_nr
is greater zero but req->tp_block_size is zero.
This patch solves the problem by passing a zeroed auto-variable to
packet_set_ring() upon each invocation from packet_release().
As far as I can tell, this issue exists even since 69e3c75 (net: TX_RING
and packet mmap), i.e. the original inclusion of TX ring support into
af_packet, but applies only to sockets with both RX and TX ring
allocated, which is probably why this was unnoticed all the time.
Signed-off-by: Phil Sutter <phil.sutter@viprinet.com>
Cc: Johann Baudy <johann.baudy@gnu-log.net>
Cc: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit bd30e947207e2ea0ff2c08f5b4a03025ddce48d3 ]
They will be created at output, if ever needed. This avoids creating
empty neighbor entries when TPROXYing/Forwarding packets for addresses
that are not even directly reachable.
Note that IPv4 already handles it this way. No neighbor entries are
created for local input.
Tested by myself and customer.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
[ Upstream commit 604dfd6efc9b79bce432f2394791708d8e8f6efc ]
The return value of pktgen_add_device() is not checked, so
even if we fail to add some device, for example, non-exist one,
we still see "OK:...". This patch fixes it.
After this patch, I got:
# echo "add_device non-exist" > /proc/net/pktgen/kpktgend_0
-bash: echo: write error: No such device
# cat /proc/net/pktgen/kpktgend_0
Running:
Stopped:
Result: ERROR: can not add device non-exist
# echo "add_device eth0" > /proc/net/pktgen/kpktgend_0
Running:
Stopped: eth0
Result: OK: add_device=eth0
(Candidate for -stable)
Signed-off-by: Cong Wang <amwang@redhat.com>
[ Upstream commit 5465740ace36f179de5bb0ccb5d46ddeb945e309 ]
Due to IP_GRE GSO support, GRE can recieve non linear skb which
results in panic in case of GRE_CSUM. Following patch fixes it by
using correct csum API.
Bug introduced in commit 6b78f16e4bdde3936b (gre: add GSO support)
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
[ Upstream commit b74aa930ef49a3c0d8e4c1987f89decac768fb2c ]
commit 563d34d057 (tcp: dont drop MTU reduction indications)
added an error leading to incorrect accounting of
LINUX_MIB_LOCKDROPPEDICMPS
If socket is owned by the user, we want to increment
this SNMP counter, unless the message is a
(ICMP_DEST_UNREACH,ICMP_FRAG_NEEDED) one.
Reported-by: Maciej ¯enczykowski <maze@google.com>
Signed-off-by: Maciej ¯enczykowski <maze@google.com>
[ Upstream commit 7efdba5bd9a2f3e2059beeb45c9fa55eefe1bced ]
Commit 299b0767 (ipv6: Fix IPsec slowpath fragmentation problem)
has introduced a error in the header length calculation that
provokes corrupted packets when non-fragmentable extensions
headers (Destination Option or Routing Header Type 2) are used.
rt->rt6i_nfheader_len is the length of the non-fragmentable
extension header, and it should be substracted to
rt->dst.header_len, and not to exthdrlen, as it was done before
commit 299b0767.
This patch reverts to the original and correct behavior. It has
been successfully tested with and without IPsec on packets
that include non-fragmentable extensions headers.
Signed-off-by: Romain Kuntz <r.kuntz@ipflavors.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit cce894bb824429fd312706c7012acae43e725865 ]
spin_is_locked() on a non !SMP build is kind of useless.
BUG_ON(!spin_is_locked(xx)) is guaranteed to crash.
Just remove this check in reqsk_fastopen_remove() as
the callers do hold the socket lock.
Reported-by: Ketan Kulkarni <ketkulka@gmail.com>
Cc: Jerry Chu <hkchu@google.com>
Cc: Dave Taht <dave.taht@gmail.com>
Acked-by: H.K. Jerry Chu <hkchu@google.com>
[ Upstream commit d07d7507bfb4e23735c9b83e397c43e1e8a173e8 ]
Since:
commit 2c60db037034d27f8c636403355d52872da92f81
Author: Eric Dumazet <edumazet@google.com>
Date: Sun Sep 16 09:17:26 2012 +0000
net: provide a default dev->ethtool_ops
wireless core does not correctly assign ethtool_ops.
After alloc_netdev*() call, some cfg80211 drivers provide they own
ethtool_ops, but some do not. For them, wireless core provide generic
cfg80211_ethtool_ops, which is assigned in NETDEV_REGISTER notify call:
if (!dev->ethtool_ops)
dev->ethtool_ops = &cfg80211_ethtool_ops;
But after Eric's commit, dev->ethtool_ops is no longer NULL (on cfg80211
drivers without custom ethtool_ops), but points to &default_ethtool_ops.
In order to fix the problem, provide function which will overwrite
default_ethtool_ops and use it by wireless core.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
[ Upstream commit 85da53bf1c336bb07ac038fb951403ab0478d2c5 ]
The tests on the flags in addrconf_get_prefix_route() does no make
much sense: the 'noflags' parameter contains the set of flags that
must not match with the route flags, so the test must be done
against 'noflags', and not against 'flags'.
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit c9be4a5c49cf51cc70a993f004c5bb30067a65ce ]
A regression is introduced by the following commit:
commit 4d52cfbef6266092d535237ba5a4b981458ab171
Author: Eric Dumazet <eric.dumazet@gmail.com>
Date: Tue Jun 2 00:42:16 2009 -0700
net: ipv4/ip_sockglue.c cleanups
Pure cleanups
but it is not a pure cleanup...
- if (val != -1 && (val < 1 || val>255))
+ if (val != -1 && (val < 0 || val > 255))
Since there is no reason provided to allow ttl=0, change it back.
Reported-by: nitin padalia <padalia.nitin@gmail.com>
Cc: nitin padalia <padalia.nitin@gmail.com>
commit 8cf9fa1240229cbdd888236c0c43fcbad680cf00 upstream.
The conn->smp_chan pointer can be NULL if SMP PDUs arrive at unexpected
moments. To avoid NULL pointer dereferences the code should be checking
for this and disconnect if an unexpected SMP PDU arrives. This patch
fixes the issue by adding a check for conn->smp_chan for all other PDUs
except pairing request and security request (which are are the first
PDUs to come to initialize the SMP context).
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 4610476d89d53714ca94aae081fa035908bc137a upstream.
net/netfilter/xt_CT.c: In function ‘xt_ct_tg_check_v1’:
net/netfilter/xt_CT.c:250:6: warning: ‘ret’ may be used uninitialized in this function [-Wmaybe-uninitialized]
net/netfilter/xt_CT.c: In function ‘xt_ct_tg_check_v0’:
net/netfilter/xt_CT.c:112:6: warning: ‘ret’ may be used uninitialized in this function [-Wmaybe-uninitialized]
Reported-by: Borislav Petkov <bp@alien8.de>
Acked-by: Borislav Petkov <bp@alien8.de>
commit 1310b955c804975651dca6c674ebfd1cb2b4c7ff upstream.
This patch fixes a leak in one of the error paths of
ctnetlink_create_expect if no helper and no timeout is specified.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
commit 5b76c4948fe6977bead2359c2054f3e6a2dcf3d0 upstream.
arptables 0.0.4 (released on 10th Jan 2013) supports calling the
CLASSIFY target, but on adding a rule to the wrong chain, the
diagnostic is as follows:
# arptables -A INPUT -j CLASSIFY --set-class 0:0
arptables: Invalid argument
# dmesg | tail -n1
x_tables: arp_tables: CLASSIFY target: used from hooks
PREROUTING, but only usable from INPUT/FORWARD
This is incorrect, since xt_CLASSIFY.c does specify
(1 << NF_ARP_OUT) | (1 << NF_ARP_FORWARD).
This patch corrects the x_tables diagnostic message to print the
proper hook names for the NFPROTO_ARP case.
Affects all kernels down to and including v2.6.31.
Signed-off-by: Jan Engelhardt <jengelh@inai.de>
commit 1e47ee8367babe6a5e8adf44a714c7086657b87e upstream.
canqun zhang reported that we're hitting BUG_ON in the
nf_conntrack_destroy path when calling kfree_skb while
rmmod'ing the nf_conntrack module.
Currently, the nf_ct_destroy hook is being set to NULL in the
destroy path of conntrack.init_net. However, this is a problem
since init_net may be destroyed before any other existing netns
(we cannot assume any specific ordering while releasing existing
netns according to what I read in recent emails).
Thanks to Gao feng for initial patch to address this issue.
Reported-by: canqun zhang <canqunzhang@gmail.com>
Acked-by: Gao feng <gaofeng@cn.fujitsu.com>
commit 2727de76041b2064c0b74f00a2a89678fb3efafc upstream.
xt_recent can try high order page allocations and this can fail.
iptables: page allocation failure: order:9, mode:0xc0d0
It also wastes about half the allocated space because of kmalloc()
power-of-two roundups and struct recent_table layout.
Use vmalloc() instead to save space and be less prone to allocation
errors when memory is fragmented.
Reported-by: Miroslav Kratochvil <exa.exa@gmail.com>
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Harald Reindl <h.reindl@thelounge.net>
commit 665e205c16c1f902ac6763b8ce8a0a3a1dcefe59 upstream.
recent_net_exit() is called before recent_mt_destroy() in the
destroy path of network namespaces. Make sure there are no entries
in the parent proc entry xt_recent before removing it.
Signed-off-by: Vitaly E. Lavrov <lve@guap.ru>
commit 09181842b000344b1205801df3aa5b726c03cc62 upstream.
Two packets may race to create the same entry in the hashtable,
double check if this packet lost race. This double checking only
happens in the path of the packet that creates the hashtable for
first time.
Note that, with this patch, no packet drops occur if the race happens.
Reported-by: Feng Gao <gfree.wind@gmail.com>
commit 32263dd1b43378b4f7d7796ed713f77e95f27e8a upstream.
commit 757ae316fb35811cfd8c67de0e0b8680ec4c1f37 upstream.
warning: (NETFILTER_XT_TARGET_NOTRACK) selects NETFILTER_XT_TARGET_CT which has unmet direct
+dependencies (NET && INET && NETFILTER && NETFILTER_XTABLES && NF_CONNTRACK && (IP_NF_RAW ||
+IP6_NF_RAW) && NETFILTER_ADVANCED)
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
commit 10db9069eb5c60195170a4119bdbcbce69a4945f upstream.
Florian Westphal reported that the removal of the NOTRACK target
(9655050 netfilter: remove xt_NOTRACK) is breaking some existing
setups.
That removal was scheduled for removal since long time ago as
described in Documentation/feature-removal-schedule.txt
What: xt_NOTRACK
Files: net/netfilter/xt_NOTRACK.c
When: April 2011
Why: Superseded by xt_CT
Still, people may have not notice / may have decided to stick to an
old iptables version. I agree with him in that some more conservative
approach by spotting some printk to warn users for some time is less
agressive.
Current iptables 1.4.16.3 already contains the aliasing support
that makes it point to the CT target, so upgrading would fix it.
Still, the policy so far has been to avoid pushing our users to
upgrade.
As a solution, this patch recovers the NOTRACK target inside the CT
target and it now spots a warning.
Reported-by: Florian Westphal <fw@strlen.de>
commit e035edd16ee83498cccc9beedfc215e15cab3a07 upstream.
In (0c36b48 netfilter: nfnetlink_log: fix mac address for 6in4 tunnels)
the include file that defines ARPD_SIT was missing. This passed unnoticed
during my tests (I did not hit this problem here).
net/netfilter/nfnetlink_log.c: In function '__build_packet_message':
net/netfilter/nfnetlink_log.c:494:25: error: 'ARPHRD_SIT' undeclared (first use in this function)
net/netfilter/nfnetlink_log.c:494:25: note: each undeclared identifier is reported only once for
+each function it appears in
commit 0c36b48b36dc84d4215dc9d1cde1bda829214ba6 upstream.
For tunnelled ipv6in4 packets, the LOG target (xt_LOG.c) adjusts
the start of the mac field to start at the ethernet header instead
of the ipv4 header for the tunnel. This patch conforms what is
passed by the NFLOG target through nfnetlink to what the LOG target
does. Code borrowed from xt_LOG.c.
Signed-off-by: Bob Hockney <bhockney@ix.netcom.com>
commit 97cf00e93cc24898493e7a058105e3215257ee04 upstream.
Commit b836c99fd6c9 (ipv6: unify conntrack reassembly expire
code with standard one) use the standard IPv6 reassembly
code(ip6_expire_frag_queue) to handle conntrack reassembly expire.
In ip6_expire_frag_queue, it invoke dev_get_by_index_rcu to get
which device received this expired packet.so we must save ifindex
when NF_conntrack get this packet.
With this patch applied, I can see ICMP Time Exceeded sent
from the receiver when the sender sent out 1/2 fragmented
IPv6 packet.
Signed-off-by: Haibo Xi <haibbo@gmail.com>
commit c6f408996c625cb950cad024f90e50519f94713c upstream.
The problem occurs when iptables constructs the tcp reset packet.
It doesn't initialize the pointer to the tcp header within the skb.
When the skb is passed to the ixgbe driver for transmit, the ixgbe
driver attempts to access the tcp header and crashes.
Currently, other drivers (such as our 1G e1000e or igb drivers) don't
access the tcp header on transmit unless the TSO option is turned on.
<1>BUG: unable to handle kernel NULL pointer dereference at 0000000d
<1>IP: [<d081621c>] ixgbe_xmit_frame_ring+0x8cc/0x2260 [ixgbe]
<4>*pdpt = 0000000085e5d001 *pde = 0000000000000000
<0>Oops: 0000 [#1] SMP
<4>Pid: 0, comm: swapper Tainted: P 2.6.35.12 #1 Greencity/Thurley
<4>EIP: 0060:[<d081621c>] EFLAGS: 00010246 CPU: 16
<4>EIP is at ixgbe_xmit_frame_ring+0x8cc/0x2260 [ixgbe]
<4>EAX: c7628820 EBX: 00000007 ECX: 00000000 EDX: 00000000
<4>ESI: 00000008 EDI: c6882180 EBP: dfc6b000 ESP: ced95c48
<4> DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
<0>Process swapper (pid: 0, ti=ced94000 task=ced73bd0 task.ti=ced94000)
<0>Stack:
<4> cbec7418 c779e0d8 c77cc888 c77cc8a8 0903010a 00000000 c77c0008 00000002
<4><0> cd4997c0 00000010 dfc6b000 00000000 d0d176c9 c77cc8d8 c6882180 cbec7318
<4><0> 00000004 00000004 cbec7230 cbec7110 00000000 cbec70c0 c779e000 00000002
<0>Call Trace:
<4> [<d0d176c9>] ? 0xd0d176c9
<4> [<d0d18a4d>] ? 0xd0d18a4d
<4> [<411e243e>] ? dev_hard_start_xmit+0x218/0x2d7
<4> [<411f03d7>] ? sch_direct_xmit+0x4b/0x114
<4> [<411f056a>] ? __qdisc_run+0xca/0xe0
<4> [<411e28b0>] ? dev_queue_xmit+0x2d1/0x3d0
<4> [<411e8120>] ? neigh_resolve_output+0x1c5/0x20f
<4> [<411e94a1>] ? neigh_update+0x29c/0x330
<4> [<4121cf29>] ? arp_process+0x49c/0x4cd
<4> [<411f80c9>] ? nf_hook_slow+0x3f/0xac
<4> [<4121ca8d>] ? arp_process+0x0/0x4cd
<4> [<4121c6d5>] ? T.901+0x38/0x3b
<4> [<4121c918>] ? arp_rcv+0xa3/0xb4
<4> [<411e1173>] ? __netif_receive_skb+0x32b/0x346
<4> [<411e19e1>] ? netif_receive_skb+0x5a/0x5f
<4> [<411e1ea9>] ? napi_skb_finish+0x1b/0x30
<4> [<d0816eb4>] ? ixgbe_xmit_frame_ring+0x1564/0x2260 [ixgbe]
<4> [<41013468>] ? lapic_next_event+0x13/0x16
<4> [<410429b2>] ? clockevents_program_event+0xd2/0xe4
<4> [<411e1b03>] ? net_rx_action+0x55/0x127
<4> [<4102da1a>] ? __do_softirq+0x77/0xeb
<4> [<4102dab1>] ? do_softirq+0x23/0x27
<4> [<41003a67>] ? do_IRQ+0x7d/0x8e
<4> [<41002a69>] ? common_interrupt+0x29/0x30
<4> [<41007bcf>] ? mwait_idle+0x48/0x4d
<4> [<4100193b>] ? cpu_idle+0x37/0x4c
<0>Code: df 09 d7 0f 94 c2 0f b6 d2 e9 e7 fb ff ff 31 db 31 c0 e9 38
ff ff ff 80 78 06 06 0f 85 3e fb ff ff 8b 7c 24 38 8b 8f b8 00 00 00
<0f> b6 51 0d f6 c2 01 0f 85 27 fb ff ff 80 e2 02 75 0d 8b 6c 24
<0>EIP: [<d081621c>] ixgbe_xmit_frame_ring+0x8cc/0x2260 [ixgbe] SS:ESP
Signed-off-by: Mukund Jampala <jbmukund@gmail.com>
commit 0a9ab9bdb3e891762553f667066190c1d22ad62b upstream.
The length parameter should be sizeof(req->name) - 1 because there is no
guarantee that string provided by userspace will contain the trailing
'\0'.
Can be easily reproduced by manually setting req->name to 128 non-zero
bytes prior to ioctl(HIDPCONNADD) and checking the device name setup on
input subsystem:
$ cat /sys/devices/pnp0/00\:04/tty/ttyS0/hci0/hci0\:1/input8/name
AAAAAA[...]AAAAAAAAf0:af:f0:af:f0:af
("f0:af:f0:af:f0:af" is the device bluetooth address, taken from "phys"
field in struct hid_device due to overflow.)
Signed-off-by: Anderson Lizardo <anderson.lizardo@openbossa.org>
commit 1626e0fa740dec8665a973cf2349405cdfeb46dc upstream.
During FT roaming, wpa_supplicant attempts to set the
key before association. This used to be rejected, but
as a side effect of my commit 66e67e418908442389d3a9e
("mac80211: redesign auth/assoc") the key was accepted
causing hardware crypto to not be used for it as the
station isn't added to the driver yet.
It would be possible to accept the key and then add it
to the driver when the station has been added. However,
this may run into issues with drivers using the state-
based station adding if they accept the key only after
association like it used to be.
For now, revert to the behaviour from before the auth
and assoc change.
Reported-by: Cédric Debarge <cedric.debarge@acksys.fr>
Tested-by: Cédric Debarge <cedric.debarge@acksys.fr>
commit aacde9ee45225f7e0b90960f479aef83c66bfdc0 upstream.
Since:
commit b23b025fe246f3acc2988eb6d400df34c27cb8ae
Author: Ben Greear <greearb@candelatech.com>
Date: Fri Feb 4 11:54:17 2011 -0800
mac80211: Optimize scans on current operating channel.
we do not disable PS while going back to operational channel (on
ieee80211_scan_state_suspend) and deffer that until scan finish.
But since we are allowed to send frames, we can send a frame to AP
without PM bit set, so disable PS on AP side. Then when we switch
to off-channel (in ieee80211_scan_state_resume) we do not enable PS.
Hence we are off-channel with PS disabled, frames are not buffered
by AP.
To fix remove offchannel_ps_disable argument and always enable PS when
going off-channel and disable it when going on-channel, like it was
before.
Tested-by: Seth Forshee <seth.forshee@canonical.com>
commit dbccd791a3fbbdac12c33834b73beff3984988e9 upstream.
After sending reset command wait for its command complete event before
sending next command. Some chips sends CC event for command received
before reset if reset was send before chip replied with CC.
This is also required by specification that host shall not send
additional HCI commands before receiving CC for reset.
< HCI Command: Reset (0x03|0x0003) plen 0 [hci0] 18.404612
> HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.405850
Write Extended Inquiry Response (0x03|0x0052) ncmd 1
Status: Success (0x00)
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.406079
> HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.407864
Reset (0x03|0x0003) ncmd 1
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.408062
> HCI Event: Command Complete (0x0e) plen 12 [hci0] 18.408835
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
Acked-by: Johan Hedberg <johan.hedberg@intel.com>
(cherry picked from commit 61c74035626beb25a39b0273ccf7d75510bc36a1)
In __unregister_linger_request(), the request is being removed
from the osd client's req_linger list only when the request
has a non-null osd pointer. It should be done whether or not
the request currently has an osd.
This is most likely a non-issue because I believe the request
will always have an osd when this function is called.
Signed-off-by: Alex Elder <elder@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
