path: root/net
2010-08-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net/ipv4: Eliminate kstrdup memory leak net/caif/cfrfml.c: use asm/unaligned.h ax25: missplaced sock_put(sk) qlge: reset the chip before freeing the buffers l2tp: test for ethernet header in l2tp_eth_dev_recv() tcp: select(writefds) don't hang up when a peer close connection tcp: fix three tcp sysctls tuning tcp: Combat per-cpu skew in orphan tests. pxa168_eth: silence gcc warnings pxa168_eth: update call to phy_mii_ioctl() pxa168_eth: fix error handling in prope pxa168_eth: remove unneeded null check phylib: Fix race between returning phydev and calling adjust_link caif-driver: add HAS_DMA dependency 3c59x: Fix deadlock between boomerang_interrupt and boomerang_start_tx qlcnic: fix poll implementation netxen: fix poll implementation bridge: netfilter: fix a memory leak
2010-08-27net/ipv4: Eliminate kstrdup memory leakJulia Lawall
The string clone is only used as a temporary copy of the argument val within the while loop, and so it should be freed before leaving the function. The call to strsep, however, modifies clone, so a pointer to the front of the string is kept in saved_clone, to make it possible to free it. The sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ local idexpression x; expression E; identifier l; statement S; @@ *x= \(kasprintf\|kstrdup\)(...); ... if (x == NULL) S ... when != kfree(x) when != E = x if (...) { <... when != kfree(x) * goto l; ...> * return ...; } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26net/caif/cfrfml.c: use asm/unaligned.hJeff Mahoney
caif does not build on ia64 starting with 2.6.32-rc1. Using asm/unaligned.h instead of linux/unaligned/le_byteshift.h fixes the issue. include/linux/unaligned/le_byteshift.h:40:50: error: redefinition of 'get_unaligned_le16' include/linux/unaligned/le_byteshift.h:45:50: error: redefinition of 'get_unaligned_le32' include/linux/unaligned/le_byteshift.h:50:50: error: redefinition of 'get_unaligned_le64' include/linux/unaligned/le_byteshift.h:55:51: error: redefinition of 'put_unaligned_le16' include/linux/unaligned/le_byteshift.h:60:51: error: redefinition of 'put_unaligned_le32' include/linux/unaligned/le_byteshift.h:65:51: error: redefinition of 'put_unaligned_le64' include/linux/unaligned/le_struct.h:31:51: note: previous definition of 'put_unaligned_le64' was here Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26ax25: missplaced sock_put(sk)Bernard Pidoux F6BVP
This patch moves a missplaced sock_put(sk) after bh_unlock_sock(sk) like in other parts of AX25 driver. Signed-off-by: Bernard Pidoux <f6bvp@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26l2tp: test for ethernet header in l2tp_eth_dev_recv()Eric Dumazet
close https://bugzilla.kernel.org/show_bug.cgi?id=16529 Before calling dev_forward_skb(), we should make sure skb head contains at least an ethernet header, even if length included in upper layer said so. Use pskb_may_pull() to make sure this ethernet header is present in skb head. Reported-by: Thomas Heil <heil@terminal-consulting.de> Reported-by: Ian Campbell <Ian.Campbell@eu.citrix.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25tcp: select(writefds) don't hang up when a peer close connectionKOSAKI Motohiro
This issue come from ruby language community. Below test program hang up when only run on Linux. % uname -mrsv Linux 2.6.26-2-486 #1 Sat Dec 26 08:37:39 UTC 2009 i686 % ruby -rsocket -ve ' BasicSocket.do_not_reverse_lookup = true serv = TCPServer.open("127.0.0.1", 0) s1 = TCPSocket.open("127.0.0.1", serv.addr[1]) s2 = serv.accept s2.close s1.write("a") rescue p $! s1.write("a") rescue p $! Thread.new { s1.write("a") }.join' ruby 1.9.3dev (2010-07-06 trunk 28554) [i686-linux] #<Errno::EPIPE: Broken pipe> [Hang Here] FreeBSD, Solaris, Mac doesn't. because Ruby's write() method call select() internally. and tcp_poll has a bug. SUS defined 'ready for writing' of select() as following. | A descriptor shall be considered ready for writing when a call to an output | function with O_NONBLOCK clear would not block, whether or not the function | would transfer data successfully. That said, EPIPE situation is clearly one of 'ready for writing'. We don't have read-side issue because tcp_poll() already has read side shutdown care. | if (sk->sk_shutdown & RCV_SHUTDOWN) | mask |= POLLIN | POLLRDNORM | POLLRDHUP; So, Let's insert same logic in write side. - reference url http://blade.nagaokaut.ac.jp/cgi-bin/scat.rb/ruby/ruby-core/31065 http://blade.nagaokaut.ac.jp/cgi-bin/scat.rb/ruby/ruby-core/31068 Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25tcp: fix three tcp sysctls tuningEric Dumazet
As discovered by Anton Blanchard, current code to autotune tcp_death_row.sysctl_max_tw_buckets, sysctl_tcp_max_orphans and sysctl_max_syn_backlog makes little sense. The bigger a page is, the less tcp_max_orphans is : 4096 on a 512GB machine in Anton's case. (tcp_hashinfo.bhash_size * sizeof(struct inet_bind_hashbucket)) is much bigger if spinlock debugging is on. Its wrong to select bigger limits in this case (where kernel structures are also bigger) bhash_size max is 65536, and we get this value even for small machines. A better ground is to use size of ehash table, this also makes code shorter and more obvious. Based on a patch from Anton, and another from David. Reported-and-tested-by: Anton Blanchard <anton@samba.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25tcp: Combat per-cpu skew in orphan tests.David S. Miller
As reported by Anton Blanchard when we use percpu_counter_read_positive() to make our orphan socket limit checks, the check can be off by up to num_cpus_online() * batch (which is 32 by default) which on a 128 cpu machine can be as large as the default orphan limit itself. Fix this by doing the full expensive sum check if the optimized check triggers. Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2010-08-23bridge: netfilter: fix a memory leakChangli Gao
nf_bridge_alloc() always reset the skb->nf_bridge, so we should always put the old one. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) netfilter: fix CONFIG_COMPAT support isdn/avm: fix build when PCMCIA is not enabled header: fix broken headers for user space e1000e: don't check for alternate MAC addr on parts that don't support it e1000e: disable ASPM L1 on 82573 ll_temac: Fix poll implementation netxen: fix a race in netxen_nic_get_stats() qlnic: fix a race in qlcnic_get_stats() irda: fix a race in irlan_eth_xmit() net: sh_eth: remove unused variable netxen: update version 4.0.74 netxen: fix inconsistent lock state vlan: Match underlying dev carrier on vlan add ibmveth: Fix opps during MTU change on an active device ehea: Fix synchronization between HW and SW send queue bnx2x: Update bnx2x version to 1.52.53-4 bnx2x: Fix PHY locking problem rds: fix a leak of kernel memory netlink: fix compat recvmsg netfilter: fix userspace header warning ...
2010-08-23netfilter: fix CONFIG_COMPAT supportFlorian Westphal
commit f3c5c1bfd430858d3a05436f82c51e53104feb6b (netfilter: xtables: make ip_tables reentrant) forgot to also compute the jumpstack size in the compat handlers. Result is that "iptables -I INPUT -j userchain" turns into -j DROP. Reported by Sebastian Roesner on #netfilter, closes http://bugzilla.netfilter.org/show_bug.cgi?id=669. Note: arptables change is compile-tested only. Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19irda: fix a race in irlan_eth_xmit()Eric Dumazet
After skb is queued, its illegal to dereference it. Cache skb->len into a temporary variable. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19vlan: Match underlying dev carrier on vlan addPhil Oester
When adding a new vlan, if the underlying interface has no carrier, then the newly added vlan interface should also have no carrier. At present, this is not true - the newly added vlan is added with carrier up. Fix by checking state of real device. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-18rds: fix a leak of kernel memoryEric Dumazet
struct rds_rdma_notify contains a 32 bits hole on 64bit arches, make sure it is zeroed before copying it to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-18netlink: fix compat recvmsgJohannes Berg
Since commit 1dacc76d0014a034b8aca14237c127d7c19d7726 Author: Johannes Berg <johannes@sipsolutions.net> Date: Wed Jul 1 11:26:02 2009 +0000 net/compat/wext: send different messages to compat tasks we had a race condition when setting and then restoring frag_list. Eric attempted to fix it, but the fix created even worse problems. However, the original motivation I had when I added the code that turned out to be racy is no longer clear to me, since we only copy up to skb->len to userspace, which doesn't include the frag_list length. As a result, not doing any frag_list clearing and restoring avoids the race condition, while not introducing any other problems. Additionally, while preparing this patch I found that since none of the remaining netlink code is really aware of the frag_list, we need to use the original skb's information for packet information and credentials. This fixes, for example, the group information received by compat tasks. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: stable@kernel.org [2.6.31+, for 2.6.35 revert 1235f504aa] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-18Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Fix an Oops in the NFSv4 atomic open code NFS: Fix the selection of security flavours in Kconfig NFS: fix the return value of nfs_file_fsync() rpcrdma: Fix SQ size calculation when memreg is FRMR xprtrdma: Do not truncate iova_start values in frmr registrations. nfs: Remove redundant NULL check upon kfree() nfs: Add "lookupcache" to displayed mount options NFS: allow close-to-open cache semantics to apply to root of NFS filesystem SUNRPC: fix NFS client over TCP hangs due to packet loss (Bug 16494)
2010-08-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Fix a memmove bug in dev_gro_receive() net sched: fix some kernel memory leaks netfilter: {ip,ip6,arp}_tables: avoid lockdep false positive Revert "netlink: netlink_recvmsg() fix" ipv6: remove sysctl jiffies conversion on gc_elasticity and min_adv_mss xfrm: Use GFP_ATOMIC in xfrm_compile_policy ath5k: disable ASPM L0s for all cards ath9k_htc: load proper firmware for device ID 7015 wl1251: fix trigger scan timeout usage ath9k_htc: Fix disconnect issue in HT40 mode. ath9k_htc: fix panic on packet injection using airbase-ng tool. ipw2100: register pm_qos request before registering pci driver
2010-08-17net: Fix a memmove bug in dev_gro_receive()Jarek Poplawski
>Xin Xiaohui wrote: > I looked into the code dev_gro_receive(), found the code here: > if the frags[0] is pulled to 0, then the page will be released, > and memmove() frags left. > Is that right? I'm not sure if memmove do right or not, but > frags[0].size is never set after memove at least. what I think > a simple way is not to do anything if we found frags[0].size == 0. > The patch is as followed. ... This version of the patch fixes the bug directly in memmove. Reported-by: "Xin, Xiaohui" <xiaohui.xin@intel.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17net sched: fix some kernel memory leaksEric Dumazet
We leak at least 32bits of kernel memory to user land in tc dump, because we dont init all fields (capab ?) of the dumped structure. Use C99 initializers so that holes and non explicit fields are zeroed. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17netfilter: {ip,ip6,arp}_tables: avoid lockdep false positiveEric Dumazet
After commit 24b36f019 (netfilter: {ip,ip6,arp}_tables: dont block bottom half more than necessary), lockdep can raise a warning because we attempt to lock a spinlock with BH enabled, while the same lock is usually locked by another cpu in a softirq context. Disable again BH to avoid these lockdep warnings. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Diagnosed-by: David S. Miller <davem@davemloft.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17NFS: Fix the selection of security flavours in KconfigTrond Myklebust
Randy Dunlap reports: ERROR: "svc_gss_principal" [fs/nfs/nfs.ko] undefined! because in fs/nfs/Kconfig, NFS_V4 selects RPCSEC_GSS_KRB5 and/or in fs/nfsd/Kconfig, NFSD_V4 selects RPCSEC_GSS_KRB5. RPCSEC_GSS_KRB5 does 5 selects, but none of these is enforced/followed by the fs/nfs[d]/Kconfig configs: select SUNRPC_GSS select CRYPTO select CRYPTO_MD5 select CRYPTO_DES select CRYPTO_CBC Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: J. Bruce Fields <bfields@fieldses.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-15Revert "netlink: netlink_recvmsg() fix"David S. Miller
This reverts commit 1235f504aaba2ebeabc863fdb3ceac764a317d47. It causes regressions worse than the problem it was trying to fix. Eric will try to solve the problem another way. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-14ipv6: remove sysctl jiffies conversion on gc_elasticity and min_adv_mssMin Zhang
sysctl output ipv6 gc_elasticity and min_adv_mss as values divided by HZ. However, they are not in unit of jiffies, since ip6_rt_min_advmss refers to packet size and ip6_rt_fc_elasticity is used as scaler as in expire>>ip6_rt_gc_elasticity, so replace the jiffies conversion handler will regular handler for them. This has impact on scripts that are currently working assuming the divide by HZ, will yield different results with this patch in place. Signed-off-by: Min Zhang <mzhang@mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-14xfrm: Use GFP_ATOMIC in xfrm_compile_policyHerbert Xu
As xfrm_compile_policy runs within a read_lock, we cannot use GFP_KERNEL for memory allocations. Reported-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits) ctcm: rename READ/WRITE defines to avoid redefinitions claw: rename READ/WRITE defines to avoid redefinitions phylib: available for any speed ethernet can: add limit for nframes and clean up signed/unsigned variables pkt_sched: Check .walk and .leaf class handlers pkt_sched: Fix sch_sfq vs tc_modify_qdisc oops caif-spi: Bugfix SPI_DATA_POS settings were inverted. caif: Bugfix - Increase default headroom size for control channel. net: make netpoll_rx return bool for !CONFIG_NETPOLL Bluetooth: Use 3-DH5 payload size for default ERTM max PDU size Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTM Bluetooth: Change default L2CAP ERTM retransmit timeout Bluetooth: Fix endianness issue with L2CAP MPS configuration net: Use NET_XMIT_SUCCESS where possible. isdn: mISDN: call pci_disable_device() if pci_probe() failed isdn: avm: call pci_disable_device() if pci_probe() failed isdn: avm: call pci_disable_device() if pci_probe() failed usbnet: rx_submit() should return an error code. pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: add dummy bind/unbind handles pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: add dummy bind/unbind handles ...
2010-08-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [NFS] Set CONFIG_KEYS when CONFIG_NFS_USE_KERNEL_DNS is set AFS: Implement an autocell mount capability [ver #2] DNS: If the DNS server returns an error, allow that to be cached [ver #2] NFS: Use kernel DNS resolver [ver #2] cifs: update README to include details about 'fsc' option
2010-08-12Merge branch 'params' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits) param: don't deref arg in __same_type() checks param: update drivers/acpi/debug.c to new scheme param: use module_param in drivers/message/fusion/mptbase.c ide: use module_param_named rather than module_param_call param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes. param: lock myri10ge_fw_name against sysfs changes. param: simple locking for sysfs-writable charp parameters param: remove unnecessary writable charp param: add kerneldoc to moduleparam.h param: locking for kernel parameters param: make param sections const. param: use free hook for charp (fix leak of charp parameters) param: add a free hook to kernel_param_ops. param: silence .init.text references from param ops Add param ops struct for hvc_iucv driver. nfs: update for module_param_named API change AppArmor: update for module_param_named API change param: use ops in struct kernel_param, rather than get and set fns directly param: move the EXPORT_SYMBOL to after the definitions. ...
2010-08-12Add a dummy printk function for the maintenance of unused printksDavid Howells
Add a dummy printk function for the maintenance of unused printks through gcc format checking, and also so that side-effect checking is maintained too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11phylib: available for any speed ethernetRandy Dunlap
Several gigabit network drivers (SB1250_MAC, TIGON3, FSL, GIANFAR, UCC_GETH, MV643XX_ETH, XILINX_LL_TEMAC, S6GMAC, STMMAC_ETH, PASEMI_MAC, and OCTEON_ETHERNET) select PHYLIB. These drivers are not under NET_ETHERNET (10/100 mbit), so this warning is generated (long, irrelevant parts are omitted): warning: (NET_DSA && NET && EXPERIMENTAL && NET_ETHERNET && !S390 || ... || SB1250_MAC && NETDEVICES && NETDEV_1000 && SIBYTE_SB1xxx_SOC || TIGON3 && NETDEVICES && NETDEV_1000 && PCI || FSL_PQ_MDIO && NETDEVICES && NETDEV_1000 && FSL_SOC || GIANFAR && NETDEVICES && NETDEV_1000 && FSL_SOC || UCC_GETH && NETDEVICES && NETDEV_1000 && QUICC_ENGINE || MV643XX_ETH && NETDEVICES && NETDEV_1000 && (MV64X60 || PPC32 || PLAT_ORION) || XILINX_LL_TEMAC && NETDEVICES && NETDEV_1000 && (PPC || MICROBLAZE) || S6GMAC && NETDEVICES && NETDEV_1000 && XTENSA_VARIANT_S6000 || STMMAC_ETH && NETDEV_1000 && NETDEVICES && CPU_SUBTYPE_ST40 || PASEMI_MAC && NETDEVICES && NETDEV_10000 && PPC_PASEMI && PCI || OCTEON_ETHERNET && STAGING && !STAGING_EXCLUDE_BUILD && CPU_CAVIUM_OCTEON) selects PHYLIB which has unmet direct dependencies (!S390 && NET_ETHERNET) PHYLIB is used by non-10/100 mbit ethernet drivers, so change the dependencies to be NETDEVICES instead of NET_ETHERNET. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-11can: add limit for nframes and clean up signed/unsigned variablesOliver Hartkopp
This patch adds a limit for nframes as the number of frames in TX_SETUP and RX_SETUP are derived from a single byte multiplex value by default. Use-cases that would require to send/filter more than 256 CAN frames should be implemented in userspace for complexity reasons anyway. Additionally the assignments of unsigned values from userspace to signed values in kernelspace and vice versa are fixed by using unsigned values in kernelspace consistently. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Reported-by: Ben Hawkes <hawkes@google.com> Acked-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-11DNS: If the DNS server returns an error, allow that to be cached [ver #2]Wang Lei
If the DNS server returns an error, allow that to be cached in the DNS resolver key in lieu of a value. Userspace passes the desired error number as an option in the payload: "#dnserror=<number>" Userspace must map h_errno from the name resolution routines to an appropriate Linux error before passing it up. Something like the following mapping is recommended: [HOST_NOT_FOUND] = ENODATA, [TRY_AGAIN] = EAGAIN, [NO_RECOVERY] = ECONNREFUSED, [NO_DATA] = ENODATA, in lieu of Linux errors specifically for representing name service errors. The filesystem must map these errors appropropriately before passing them to userspace. AFS is made to map ENODATA and EAGAIN to EDESTADDRREQ for the return to userspace; ECONNREFUSED is allowed to stand as is. The error can be seen in /proc/keys as a negative number after the description of the key. Compare, for example, the following key entries: 2f97238c I--Q-- 1 53s 3f010000 0 0 dns_resol afsdb:grand.centrall.org: -61 338bfbbe I--Q-- 1 59m 3f010000 0 0 dns_resol afsdb:grand.central.org: 37 If the error option is supplied in the payload, the main part of the payload is discarded. The key should have an expiry time set by userspace. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-11rpcrdma: Fix SQ size calculation when memreg is FRMRTom Tucker
This patch updates the computation to include the worst case situation where three FRMR are required to map a single RPC REQ. Signed-off-by: Tom Tucker <tom@ogc.us> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-11xprtrdma: Do not truncate iova_start values in frmr registrations.Steve Wise
A bad cast causes the iova_start, which in this case is a 64b DMA bus address, to be truncated on 32b systems. This breaks frmrs on 32b systems. No cast is needed. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-11param: simple locking for sysfs-writable charp parametersRusty Russell
Since the writing to sysfs can free the old one, we need to block that when we access the charp variables. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Dan Williams <dcbw@redhat.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Jing Huang <huangj@brocade.com> Cc: James E.J. Bottomley <James.Bottomley@suse.de> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: David S. Miller <davem@davemloft.net> Cc: user-mode-linux-devel@lists.sourceforge.net Cc: libertas-dev@lists.infradead.org Cc: linux-wireless@vger.kernel.org Cc: netdev@vger.kernel.org Cc: linux-scsi@vger.kernel.org Cc: linux-usb@vger.kernel.org
2010-08-11nfs: update for module_param_named API changeStephen Rothwell
After merging the rr tree, today's linux-next build (powerpc ppc64_defconfig) failed like this: net/sunrpc/auth.c:74: error: 'param_ops_hashtbl_sz' undeclared here (not in a function) Caused by commit 0685652df0929cec7d78efa85127f6eb34962132 ("param:param_ops") interacting with commit f8f853ab19fcc415b6eadd273373edc424916212 ("SUNRPC: Make the credential cache hashtable size configurable") from the nfs tree. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-11param: use ops in struct kernel_param, rather than get and set fns directlyRusty Russell
This is more kernel-ish, saves some space, and also allows us to expand the ops without breaking all the callers who are happy for the new members to be NULL. The few places which defined their own param types are changed to the new scheme (more which crept in recently fixed in following patches). Since we're touching them anyway, we change get() and set() to take a const struct kernel_param (which they really are). This causes some harmless warnings until we fix them (in following patches). To reduce churn, module_param_call creates the ops struct so the callers don't have to change (and casts the functions to reduce warnings). The modern version which takes an ops struct is called module_param_cb. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Alessandro Rubini <rubini@ipvvis.unipv.it> Cc: Michal Januszewski <spock@gentoo.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: linux-kernel@vger.kernel.org Cc: linux-input@vger.kernel.org Cc: linux-fbdev-devel@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: netdev@vger.kernel.org
2010-08-11pkt_sched: Check .walk and .leaf class handlersJarek Poplawski
Require qdisc class ops .walk and .leaf for classful qdisc in register_qdisc(). The checks could be done later insted, but these ops are really needed and used by most of classful qdiscs. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-11pkt_sched: Fix sch_sfq vs tc_modify_qdisc oopsJarek Poplawski
sch_sfq as a classful qdisc needs the .leaf handler. Otherwise, there is an oops possible in tc_modify_qdisc()/check_loop(). Fixes commit 7d2681a6ff4f9ab5e48d02550b4c6338f1638998 Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-10caif: Bugfix - Increase default headroom size for control channel.Sjur Braendeland
Headroom size for control channel must be at least 48 bytes in some scenarios. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-10Merge branch 'master' of ↵David S. Miller
2010-08-10Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6
2010-08-10SUNRPC: fix NFS client over TCP hangs due to packet loss (Bug 16494)Andy Chittenden
When reusing a TCP connection, ensure that it's aborted if a previous shutdown attempt has been made on that connection so that the RPC over TCP recovery mechanism succeeds. Signed-off-by: Andy Chittenden <andyc.bluearc@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-10Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTMMat Martineau
remote_tx_win is intended to be set on receipt of an L2CAP configuration request. The value is used to determine the size of the transmit window on the remote side of an ERTM connection, so L2CAP can stop sending frames when that remote window is full. An incorrect remote_tx_win value will cause the stack to not fully utilize the tx window (performance impact), or to overfill the remote tx window (causing dropped frames or a disconnect). This patch removes an extra setting of remote_tx_win when a configuration response is received. The transmit window has a different meaning in a response - it is an informational value less than or equal to the local tx_win. Signed-off-by: Mat Martineau <mathewm@codeaurora.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-08-10Bluetooth: Fix endianness issue with L2CAP MPS configurationMat Martineau
Incoming configuration values must be converted to native CPU order before use. This fixes a bug where a little-endian MPS value is compared to a native CPU value. On big-endian processors, this can cause ERTM and streaming mode segmentation to produce PDUs that are larger than the remote stack is expecting, or that would produce fragmented skbs that the current FCS code cannot handle. Signed-off-by: Mat Martineau <mathewm@codeaurora.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-08-10net: Use NET_XMIT_SUCCESS where possible.Ben Greear
This is based on work originally done by Patric McHardy. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-10pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: ↵Jarek Poplawski
add dummy bind/unbind handles Verify in register_qdisc() some basic qdisc class handlers are present. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-10pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: ↵Jarek Poplawski
add dummy bind/unbind handles Add dummy .unbind_tcf and .put qdisc class ops for easier verification. (All other schedulers have it like this.) Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (59 commits) igbvf.txt: Add igbvf Documentation igb.txt: Add igb documentation e100/e1000*/igb*/ixgb*: Add missing read memory barrier ixgbe: fix build error with FCOE_CONFIG without DCB_CONFIG netxen: protect tx timeout recovery by rtnl lock isdn: gigaset: use after free isdn: gigaset: add missing unlock solos-pci: Fix race condition in tasklet RX handling pkt_sched: Fix sch_sfq vs tcf_bind_filter oops net: disable preemption before call smp_processor_id() tcp: no md5sig option size check bug iwlwifi: fix locking assertions iwlwifi: fix TX tracer isdn: fix information leak net: Fix napi_gro_frags vs netpoll path usbnet: remove noisy and hardly useful printk rtl8180: avoid potential NULL deref in rtl8180_beacon_work ath9k: Remove myself from the MAINTAINERS list libertas: scan before assocation if no BSSID was given libertas: fix association with some APs by using extended rates ...
2010-08-09cfg80211: fix locking in action frame TXJohannes Berg
Accesses to "wdev->current_bss" must be locked with the wdev lock, which action frame transmission is missing. Cc: stable@kernel.org [2.6.33+] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-07pkt_sched: Fix sch_sfq vs tcf_bind_filter oopsJarek Poplawski
Since there was added ->tcf_chain() method without ->bind_tcf() to sch_sfq class options, there is oops when a filter is added with the classid parameter. Fixes commit 7d2681a6ff4f9ab5e48d02550b4c6338f1638998 netdev thread: null pointer at cls_api.c Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Reported-by: Franchoze Eric <franchoze@yandex.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
