[ Upstream commit c0cb8bf3a8e4bd82e640862cdd8891400405cb89 ]
The length of the GSS MIC token need not be a multiple of four bytes.
It is then padded by XDR to a multiple of 4 B, but unwrap_integ_data()
would previously only trim mic.len + 4 B. The remaining up to three
bytes would then trigger a check in nfs4svc_decode_compoundargs(),
leading to a "garbage args" error and mount failure:
nfs4svc_decode_compoundargs: compound not properly padded!
nfsd: failed to decode arguments!
This would prevent older clients using the pre-RFC 4121 MIC format
(37-byte MIC including a 9-byte OID) from mounting exports from v3.9+
servers using krb5i.
The trimming was introduced by commit 4c190e2f913f ("sunrpc: trim off
trailing checksum before returning decrypted or integrity authenticated
buffer").
Fixes: 4c190e2f913f "unrpc: trim off trailing checksum..."
Signed-off-by: Tomáš Trnka <ttrnka@mail.muni.cz>
Cc: stable@vger.kernel.org
Acked-by: Jeff Layton <jlayton@poochiereds.net>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit 31b0b385f69d8d5491a4bca288e25e63f1d945d0 ]
The slab name ends up being visible in the directory structure under
/sys, and even if you don't have access rights to the file you can see
the filenames.
Just use a 64-bit counter instead of the pointer to the 'net' structure
to generate a unique name.
This code will go away in 4.7 when the conntrack code moves to a single
kmemcache, but this is the backportable simple solution to avoiding
leaking kernel pointers to user space.
Fixes: 5b3501faa874 ("netfilter: nf_conntrack: per netns nf_conntrack_cachep")
[ Upstream commit 8f815cdde3e550e10c2736990d791f60c2ce43eb ]
A non-privileged user can create a netlink socket with the same port_id as
used by an existing open nl80211 netlink socket (e.g. as used by a hostapd
process) with a different protocol number.
Closing this socket will then lead to the notification going to nl80211's
socket release notification handler, and possibly cause an action such as
removing a virtual interface.
Fix this issue by checking that the netlink protocol is NETLINK_GENERIC.
Since generic netlink has no notifier chain of its own, we can't fix the
problem more generically.
Fixes: 026331c4d9b5 ("cfg80211/mac80211: allow registering for and sending action frames")
Signed-off-by: Dmitry Ivanov <dima@ubnt.com>
[rewrite commit message]
[ Upstream commit e27260203912b40751fa353d009eaa5a642c739f ]
All existing users of NETLINK_URELEASE use it to clean up resources that
were previously allocated to a socket via some command. As a result, no
users require getting this notification for unbound sockets.
Sending it for unbound sockets, however, is a problem because any user
(including unprivileged users) can create a socket that uses the same ID
as an existing socket. Binding this new socket will fail, but if the
NETLINK_URELEASE notification is generated for such sockets, the users
thereof will be tricked into thinking the socket that they allocated the
resources for is closed.
In the nl80211 case, this will cause destruction of virtual interfaces
that still belong to an existing hostapd process; this is the case that
Dmitry noticed. In the NFC case, it will cause a poll abort. In the case
of netlink log/queue it will cause them to stop reporting events, as if
NFULNL_CFG_CMD_UNBIND/NFQNL_CFG_CMD_UNBIND had been called.
Fix this problem by checking that the socket is bound before generating
the NETLINK_URELEASE notification.
[ Upstream commit c2e7204d180f8efc80f27959ca9cf16fa17f67db ]
Tracking idle time in bictcp_cwnd_event() is imprecise, as epoch_start
is normally set at ACK processing time, not at send time.
Doing a proper fix would need to add an additional state variable,
and does not seem worth the trouble, given CUBIC bug has been there
forever before Jana noticed it.
Let's simply not set epoch_start in the future, otherwise
bictcp_update() could overflow and CUBIC would again
grow cwnd too fast.
This was detected thanks to a packetdrill test Neal wrote that was flaky
before applying this fix.
Fixes: 30927520dbae ("tcp_cubic: better follow cubic curve after idle period")
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Cc: Jana Iyengar <jri@google.com>
[ Upstream commit 30927520dbae297182990bb21d08762bcc35ce1d ]
Jana Iyengar found an interesting issue on CUBIC :
The epoch is only updated/reset initially and when experiencing losses.
The delta "t" of now - epoch_start can be arbitrary large after app idle
as well as the bic_target. Consequentially the slope (inverse of
ca->cnt) would be really large, and eventually ca->cnt would be
lower-bounded in the end to 2 to have delayed-ACK slow-start behavior.
This particularly shows up when slow_start_after_idle is disabled
as a dangerous cwnd inflation (1.5 x RTT) after few seconds of idle
time.
Jana initial fix was to reset epoch_start if app limited,
but Neal pointed out it would ask the CUBIC algorithm to recalculate the
curve so that we again start growing steeply upward from where cwnd is
now (as CUBIC does just after a loss). Ideally we'd want the cwnd growth
curve to be the same shape, just shifted later in time by the amount of
the idle period.
Reported-by: Jana Iyengar <jri@google.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Sangtae Ha <sangtae.ha@gmail.com>
Cc: Lawrence Brakmo <lawrence@brakmo.org>
[ Upstream commit 62b14b241ca6f790a17ccd9dd9f62ce1b006d406 ]
The original hand-implemented hash-table in mac80211 couldn't result
in insertion errors, and while converting to rhashtable I evidently
forgot to check the errors.
This surfaced now only because Ben is adding many identical keys and
that resulted in hidden insertion errors.
Fixes: 7bedd0cfad4e1 ("mac80211: use rhashtable for station table")
Reported-by: Ben Greear <greearb@candelatech.com>
[ Upstream commit 1ec7bae8bec9b72e347e01330c745ab5cdd66f0e ]
Public Action frames use special rules for how the BSSID field (Address
3) is set. A wildcard BSSID is used in cases where the transmitter and
recipient are not members of the same BSS. As such, we need to accept
Public Action frames with wildcard BSSID.
Commit db8e17324553 ("mac80211: ignore frames between TDLS peers when
operating as AP") added a rule that drops Action frames to TDLS-peers
based on an Action frame having different DA (Address 1) and BSSID
(Address 3) values. This is not correct since it misses the possibility
of BSSID being a wildcard BSSID in which case the Address 1 would not
necessarily match.
Fix this by allowing mac80211 to accept wildcard BSSID in an Action
frame when in AP mode.
Fixes: db8e17324553 ("mac80211: ignore frames between TDLS peers when operating as AP")
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
[ Upstream commit 9acc54beb474c81148e2946603d141cf8716b19f ]
Just like for CCMP we need to check that for GCMP the fragments
have PNs that increment by one; the spec was updated to fix this
security issue and now has the following text:
The receiver shall discard MSDUs and MMPDUs whose constituent
MPDU PN values are not incrementing in steps of 1.
Adapt the code for CCMP to work for GCMP as well, luckily the
relevant fields already alias each other so no code duplication
is needed (just check the aliasing with BUILD_BUG_ON.)
[ Upstream commit 7a36b930e6ed4702c866dc74a5ad07318a57c688 ]
The value 5000 was put here with the addition of the timeout field to
ieee80211_start_tx_ba_session. It was originally added in mac80211 to
save resources for drivers like iwlwifi, which only supports a limited
number of concurrent aggregation sessions.
Since iwlwifi does not use minstrel_ht and other drivers don't need
this, 0 is a better default - especially since there have been
recent reports of aggregation setup related issues reproduced with
ath9k. This should improve stability without causing any adverse
effects.
Acked-by: Avery Pennarun <apenwarr@gmail.com>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
[ Upstream commit 212c5a5e6ba61678be6b5fee576e38bccb50b613 ]
The change from cur_tp to the function
minstrel_get_tp_avg/minstrel_ht_get_tp_avg changed the unit used for the
current throughput. For example in minstrel_ht the correct
conversion between them would be:
mrs->cur_tp / 10 == minstrel_ht_get_tp_avg(..).
This factor 10 must also be included in the calculation of
minstrel_get_expected_throughput and minstrel_ht_get_expected_throughput to
return values with the unit [Kbps] instead of [10Kbps]. Otherwise routing
algorithms like B.A.T.M.A.N. V will make incorrect decision based on these
values. Its kernel based implementation expects expected_throughput always
to have the unit [Kbps] and not sometimes [10Kbps] and sometimes [Kbps].
The same requirement has iw or olsrdv2's nl80211 based statistics module
which retrieve the same data via NL80211_STA_INFO_TX_BITRATE.
Fixes: 6a27b2c40b48 ("mac80211: restructure per-rate throughput calculation into function")
Signed-off-by: Sven Eckelmann <sven@open-mesh.com>
[ Upstream commit f39ea2690bd61efec97622c48323f40ed6e16317 ]
Use kzalloc instead of kmalloc for struct tid_ampdu_rx to
initialize the "removed" field (all others are initialized
manually). That fixes:
UBSAN: Undefined behaviour in net/mac80211/rx.c:932:29
load of value 2 is not a valid value for type '_Bool'
CPU: 3 PID: 1134 Comm: kworker/u16:7 Not tainted 4.5.0-rc1+ #265
Workqueue: phy0 rt2x00usb_work_rxdone
0000000000000004 ffff880254a7ba50 ffffffff8181d866 0000000000000007
ffff880254a7ba78 ffff880254a7ba68 ffffffff8188422d ffffffff8379b500
ffff880254a7bab8 ffffffff81884747 0000000000000202 0000000348620032
Call Trace:
[<ffffffff8181d866>] dump_stack+0x45/0x5f
[<ffffffff8188422d>] ubsan_epilogue+0xd/0x40
[<ffffffff81884747>] __ubsan_handle_load_invalid_value+0x67/0x70
[<ffffffff82227b4d>] ieee80211_sta_reorder_release.isra.16+0x5ed/0x730
[<ffffffff8222ca14>] ieee80211_prepare_and_rx_handle+0xd04/0x1c00
[<ffffffff8222db03>] __ieee80211_rx_handle_packet+0x1f3/0x750
[<ffffffff8222e4a7>] ieee80211_rx_napi+0x447/0x990
While at it, convert to use sizeof(*tid_agg_rx) instead.
Fixes: 788211d81bfdf ("mac80211: fix RX A-MPDU session reorder timer deletion")
Signed-off-by: Chris Bainbridge <chris.bainbridge@gmail.com>
[reword commit message, use sizeof(*tid_agg_rx)]
[ Upstream commit cb150b9d23be6ee7f3a0fff29784f1c5b5ac514d ]
Since cfg80211 frequently takes actions from its netdev notifier
call, wireless extensions messages could still be ordered badly
since the wext netdev notifier, since wext is built into the
kernel, runs before the cfg80211 netdev notifier. For example,
the following can happen:
5: wlan1: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN group default
link/ether 02:00:00:00:01:00 brd ff:ff:ff:ff:ff:ff
5: wlan1: <BROADCAST,MULTICAST,UP>
link/ether
when setting the interface down causes the wext message.
To also fix this, export the wireless_nlevent_flush() function
and also call it from the cfg80211 notifier.
[ Upstream commit 8bf862739a7786ae72409220914df960a0aa80d8 ]
Beniamino reported that he was getting an RTM_NEWLINK message for a
given interface, after the RTM_DELLINK for it. It turns out that the
message is a wireless extensions message, which was sent because the
interface had been connected and disconnection while it was deleted
caused a wext message.
For its netlink messages, wext uses RTM_NEWLINK, but the message is
without all the regular rtnetlink attributes, so "ip monitor link"
prints just rudimentary information:
Deleted 5: wlan1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default
link/ether
(from my hwsim reproduction)
This can cause userspace to get confused since it doesn't expect an
RTM_NEWLINK message after RTM_DELLINK.
The reason for this is that wext schedules a worker to send out the
messages, and the scheduling delay can cause the messages to get out
to userspace in different order.
To fix this, have wext register a netdevice notifier and flush out
any pending messages when netdevice state changes. This fixes any
ordering whenever the original message wasn't sent by a notifier
itself.
Reported-by: Beniamino Galvani <bgalvani@redhat.com>
[ Upstream commit 9ef2e965e55481a52d6d91ce61977a27836268d3 ]
This is a clone of commit 2ab957492d13b ("ip_forward: Drop frames with
attached skb->sk") for ipv6.
This commit has exactly the same reasons as the above mentioned commit,
namely to prevent panics during netfilter reload or a misconfigured stack.
[ Upstream commit dbc0d3caff5b7591e0cf8e34ca686ca6f4479ee1 ]
ceph_msg_footer is 21 bytes long, while ceph_msg_footer_old is only 13.
Don't skip too much when CEPH_FEATURE_MSG_AUTH isn't negotiated.
Cc: stable@vger.kernel.org # 3.19+
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Alex Elder <elder@linaro.org>
[ Upstream commit e7a88e82fe380459b864e05b372638aeacb0f52d ]
The contract between try_read() and try_write() is that when called
each processes as much data as possible. When instructed by osd_client
to skip a message, try_read() is violating this contract by returning
after receiving and discarding a single message instead of checking for
more. try_write() then gets a chance to write out more requests,
generating more replies/skips for try_read() to handle, forcing the
messenger into a starvation loop.
Cc: stable@vger.kernel.org # 3.10+
Reported-by: Varada Kari <Varada.Kari@sandisk.com>
Tested-by: Varada Kari <Varada.Kari@sandisk.com>
[ Upstream commit b7052cd7bcf3c1478796e93e3dff2b44c9e82943 ]
The qword_get() function NUL-terminates its output buffer. If the input
string is in hex format \xXXXX... and the same length as the output
buffer, there is an off-by-one:
int qword_get(char **bpp, char *dest, int bufsize)
while (len < bufsize) {
*dest++ = (h << 4) | l;
len++;
*dest = '\0';
return len;
This patch ensures the NUL terminator doesn't fall outside the output
buffer.
Signed-off-by: Stefan Hajnoczi <stefanha@redhat.com>
[ Upstream commit d9749fb5942f51555dc9ce1ac0dbb1806960a975 ]
Dmitry Vyukov noted recently that the sctp_port_hashtable had an error in
its size computation, observing that the current method never guaranteed
that the hashsize (measured in number of entries) would be a power of two,
which the input hash function for that table requires. The root cause of
the problem is that two values need to be computed (one, the allocation
order of the storage requries, as passed to __get_free_pages, and two the
number of entries for the hash table). Both need to be ^2, but for
different reasons, and the existing code is simply computing one order
value, and using it as the basis for both, which is wrong (i.e. it assumes
that ((1<<order)*PAGE_SIZE)/sizeof(bucket) is still ^2 when its not).
To fix this, we change the logic slightly. We start by computing a goal
allocation order (which is limited by the maximum size hash table we want
to support. Then we attempt to allocate that size table, decreasing the
order until a successful allocation is made. Then, with the resultant
successful order we compute the number of buckets that hash table supports,
which we then round down to the nearest power of two, giving us the number
of entries the table actually supports.
I've tested this locally here, using non-debug and spinlock-debug kernels,
and the number of entries in the hashtable consistently work out to be
powers of two in all cases.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Dmitry Vyukov <dvyukov@google.com>
CC: Vladislav Yasevich <vyasevich@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
[ Upstream commit b5f0549231ffb025337be5a625b0ff9f52b016f0 ]
The value passed by unix_diag_get_exact to unix_lookup_by_ino has type
__u32, but unix_lookup_by_ino's argument ino has type int, which is not
a problem yet.
However, when ino is compared with sock_i_ino return value of type
unsigned long, ino is sign extended to signed long, and this results
to incorrect comparison on 64-bit architectures for inode numbers
greater than INT_MAX.
This bug was found by strace test suite.
Fixes: 5d3cae8bc39d ("unix_diag: Dumping exact socket core")
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit a97eb33ff225f34a8124774b3373fd244f0e83ce ]
An error response from a RTM_GETNETCONF request can return the positive
error value EINVAL in the struct nlmsgerr that can mislead userspace.
Signed-off-by: Anton Protopopov <a.s.protopopov@gmail.com>
[ Upstream commit deed49df7390d5239024199e249190328f1651e7 ]
Since the gc of ipv4 route was removed, the route cached would has
no chance to be removed, and even it has been timeout, it still could
be used, cause no code to check it's expires.
Fix this issue by checking and removing route cache when we get route.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 853effc55b0f975abd6d318cca486a9c1b67e10f ]
A previous commit (33f72e6) added notification via netlink for tunnels
when created/modified/deleted. If the notification returned an error,
this error was returned from the tunnel function. If there were no
listeners, the error code ESRCH was returned, even though having no
listeners is not an error. Other calls to this and other similar
notification functions either ignore the error code, or filter ESRCH.
This patch checks for ESRCH and does not flag this as an error.
Reviewed-by: Hamish Martin <hamish.martin@alliedtelesis.co.nz>
Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
[ Upstream commit a5527dda344fff0514b7989ef7a755729769daa1 ]
The unix_dgram_sendmsg routine use the following test
if (unlikely(unix_peer(other) != sk && unix_recvq_full(other))) {
to determine if sk and other are in an n:1 association (either
established via connect or by using sendto to send messages to an
unrelated socket identified by address). This isn't correct as the
specified address could have been bound to the sending socket itself or
because this socket could have been connected to itself by the time of
the unix_peer_get but disconnected before the unix_state_lock(other). In
both cases, the if-block would be entered despite other == sk which
might either block the sender unintentionally or lead to trying to unlock
the same spin lock twice for a non-blocking send. Add a other != sk
check to guard against this.
Fixes: 7d267278a9ec ("unix: avoid use-after-free in ep_remove_wait_queue")
Reported-By: Philipp Hahn <pmhahn@pmhahn.de>
Signed-off-by: Rainer Weikusat <rweikusat@mobileactivedefense.com>
Tested-by: Philipp Hahn <pmhahn@pmhahn.de>
[ Upstream commit 919483096bfe75dda338e98d56da91a263746a0a ]
Dmitry reported memory leaks of IP options allocated in
ip_cmsg_send() when/if this function returns an error.
Callers are responsible for the freeing.
Many thanks to Dmitry for the report and diagnostic.
[ Upstream commit 78565208d73ca9b654fb9a6b142214d52eeedfd1 ]
This patch corrects the unaligned accesses seen on GRE TEB tunnels when
generating hash keys. Specifically what this patch does is make it so that
we force the use of skb_copy_bits when the GRE inner headers will be
unaligned due to NET_IP_ALIGNED being a non-zero value.
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
Acked-by: Tom Herbert <tom@herbertland.com>
eth_get_headlen
[ Upstream commit 461547f3158978c180d74484d58e82be9b8e7357, since
we lack the flow dissector flags in this release we guard the
flow label access using a test on 'skb' being NULL ]
This patch fixes an issue with unaligned accesses when using
eth_get_headlen on a page that was DMA aligned instead of being IP aligned.
The fact is when trying to check the length we don't need to be looking at
the flow label so we can reorder the checks to first check if we are
supposed to gather the flow label and then make the call to actually get
it.
v2: Updated path so that either STOP_AT_FLOW_LABEL or KEY_FLOW_LABEL can
cause us to check for the flow label.
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
[ Upstream commit 7a84bd46647ff181eb2659fdc99590e6f16e501d ]
Commit ed5a377d87dc ("sctp: translate host order to network order when
setting a hmacid") corrected the hmacid byte-order when setting a hmacid.
but the same issue also exists on getting a hmacid.
We fix it by changing hmacids to host order when users get them with
getsockopt.
Fixes: Commit ed5a377d87dc ("sctp: translate host order to network order when setting a hmacid")
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit 5f74f82ea34c0da80ea0b49192bb5ea06e063593 ]
Devices may have limits on the number of fragments in an skb they support.
Current codebase uses a constant as maximum for number of fragments one
skb can hold and use.
When enabling scatter/gather and running traffic with many small messages
the codebase uses the maximum number of fragments and may thereby violate
the max for certain devices.
The patch introduces a global variable as max number of fragments.
Signed-off-by: Hans Westgaard Ry <hans.westgaard.ry@oracle.com>
Reviewed-by: Håkon Bugge <haakon.bugge@oracle.com>
[ Upstream commit 415e3d3e90ce9e18727e8843ae343eda5a58fad6 ]
The commit referenced in the Fixes tag incorrectly accounted the number
of in-flight fds over a unix domain socket to the original opener
of the file-descriptor. This allows another process to arbitrary
deplete the original file-openers resource limit for the maximum of
open files. Instead the sending processes and its struct cred should
be credited.
To do so, we add a reference counted struct user_struct pointer to the
scm_fp_list and use it to account for the number of inflight unix fds.
Fixes: 712f4aad406bb1 ("unix: properly account for FDs passed over unix sockets")
Reported-by: David Herrmann <dh.herrmann@gmail.com>
Cc: David Herrmann <dh.herrmann@gmail.com>
Cc: Willy Tarreau <w@1wt.eu>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
[ Upstream commit 44c3d0c1c0a880354e9de5d94175742e2c7c9683 ]
Silence lockdep false positive about rcu_dereference() being
used in the wrong context.
First one should use rcu_dereference_protected() as we own the spinlock.
Second one should be a normal assignation, as no barrier is needed.
Fixes: 18367681a10bd ("ipv6 flowlabel: Convert np->ipv6_fl_list to RCU.")
Reported-by: Dave Jones <davej@codemonkey.org.uk>
[ Upstream commit 16186a82de1fdd868255448274e64ae2616e2640 ]
A rcu stall with the following backtrace was seen on a system with
forwarding, optimistic_dad and use_optimistic set. To reproduce,
set these flags and allow ipv6 autoconf.
This occurs because the device write_lock is acquired while already
holding the read_lock. Back trace below -
INFO: rcu_preempt self-detected stall on CPU { 1} (t=2100 jiffies
g=3992 c=3991 q=4471)
<6> Task dump for CPU 1:
<2> kworker/1:0 R running task 12168 15 2 0x00000002
<2> Workqueue: ipv6_addrconf addrconf_dad_work
<6> Call trace:
<2> [<ffffffc000084da8>] el1_irq+0x68/0xdc
<2> [<ffffffc000cc4e0c>] _raw_write_lock_bh+0x20/0x30
<2> [<ffffffc000bc5dd8>] __ipv6_dev_ac_inc+0x64/0x1b4
<2> [<ffffffc000bcbd2c>] addrconf_join_anycast+0x9c/0xc4
<2> [<ffffffc000bcf9f0>] __ipv6_ifa_notify+0x160/0x29c
<2> [<ffffffc000bcfb7c>] ipv6_ifa_notify+0x50/0x70
<2> [<ffffffc000bd035c>] addrconf_dad_work+0x314/0x334
<2> [<ffffffc0000b64c8>] process_one_work+0x244/0x3fc
<2> [<ffffffc0000b7324>] worker_thread+0x2f8/0x418
<2> [<ffffffc0000bb40c>] kthread+0xe0/0xec
v2: do addrconf_dad_kick inside read lock and then acquire write
lock for ipv6_ifa_notify as suggested by Eric
Fixes: 7fd2561e4ebdd ("net: ipv6: Add a sysctl to make optimistic
addresses useful candidates")
Cc: Eric Dumazet <edumazet@google.com>
Cc: Erik Kline <ek@google.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
[ Upstream commit 8013d1d7eafb0589ca766db6b74026f76b7f5cb4 ]
Commit 6fd99094de2b ("ipv6: Don't reduce hop limit for an interface")
disabled accept hop limit from RA if it is smaller than the current hop
limit for security stuff. But this behavior kind of break the RFC definition.
RFC 4861, 6.3.4. Processing Received Router Advertisements
A Router Advertisement field (e.g., Cur Hop Limit, Reachable Time,
and Retrans Timer) may contain a value denoting that it is
unspecified. In such cases, the parameter should be ignored and the
host should continue using whatever value it is already using.
If the received Cur Hop Limit value is non-zero, the host SHOULD set
its CurHopLimit variable to the received value.
So add sysctl option accept_ra_min_hop_limit to let user choose the minimum
hop limit value they can accept from RA. And set default to 1 to meet RFC
standards.
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Acked-by: YOSHIFUJI Hideaki <hideaki.yoshifuji@miraclelinux.com>
[ Upstream commit 1cdda91871470f15e79375991bd2eddc6e86ddb1 ]
Currently, the egress interface index specified via IPV6_PKTINFO
is ignored by __ip6_datagram_connect(), so that RFC 3542 section 6.7
can be subverted when the user space application calls connect()
before sendmsg().
Fix it by initializing properly flowi6_oif in connect() before
performing the route lookup.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 6f21c96a78b835259546d8f3fb4edff0f651d478 ]
The current implementation of ip6_dst_lookup_tail basically
ignore the egress ifindex match: if the saddr is set,
ip6_route_output() purposefully ignores flowi6_oif, due
to the commit d46a9d678e4c ("net: ipv6: Dont add RT6_LOOKUP_F_IFACE
flag if saddr set"), if the saddr is 'any' the first route lookup
in ip6_dst_lookup_tail fails, but upon failure a second lookup will
be performed with saddr set, thus ignoring the ifindex constraint.
This commit adds an output route lookup function variant, which
allows the caller to specify lookup flags, and modify
ip6_dst_lookup_tail() to enforce the ifindex match on the second
lookup via said helper.
ip6_route_output() becames now a static inline function build on
top of ip6_route_output_flags(); as a side effect, out-of-tree
modules need now a GPL license to access the output route lookup
functionality.
Acked-by: David Ahern <dsa@cumulusnetworks.com>
[ Upstream commit ff5d749772018602c47509bdc0093ff72acd82ec ]
With some combinations of user provided flags in netlink command,
it is possible to call tcp_get_info() with a buffer that is not 8-bytes
aligned.
It does matter on some arches, so we need to use put_unaligned() to
store the u64 fields.
Current iproute2 package does not trigger this particular issue.
Fixes: 0df48c26d841 ("tcp: add tcpi_bytes_acked to tcp_info")
Fixes: 977cb0ecf82e ("tcp: add pacing_rate information into tcp_info")
[ Upstream commit 4f2c6ae5c64c353fb1b0425e4747e5603feadba1 ]
When switchdev drivers process FDB notifications from the underlying
device they resolve the netdev to which the entry points to and notify
the bridge using the switchdev notifier.
However, since the RTNL mutex is not held there is nothing preventing
the netdev from disappearing in the middle, which will cause
br_switchdev_event() to dereference a non-existing netdev.
Make switchdev drivers hold the lock at the beginning of the
notification processing session and release it once it ends, after
notifying the bridge.
Also, remove switchdev_mutex and fdb_lock, as they are no longer needed
when RTNL mutex is held.
Fixes: 03bf0c281234 ("switchdev: introduce switchdev notifier")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 4d5cfcba2f6ec494d8810b9e3c0a7b06255c8067 ]
In 'commit 7fe8097cef5f ("tipc: fix nullpointer bug when subscribing
to events")', we terminate the connection if the subscription
creation fails.
In the same commit, the subscription creation result was based on
the value of the subscription pointer (set in the function) instead
of the return code.
Unfortunately, the same function tipc_subscrp_create() handles
subscription cancel request. For a subscription cancellation request,
the subscription pointer cannot be set. Thus if a subscriber has
several subscriptions and cancels any of them, the connection is
terminated.
In this commit, we terminate the connection based on the return value
of tipc_subscrp_create().
Fixes: commit 7fe8097cef5f ("tipc: fix nullpointer bug when subscribing to events")
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
[ Upstream commit 27f7ed2b11d42ab6d796e96533c2076ec220affc ]
This patch extends commit b93d6471748d ("sctp: implement the sender side
for SACK-IMMEDIATELY extension") as it didn't white list
SCTP_SACK_IMMEDIATELY on sctp_msghdr_parse(), causing it to be
understood as an invalid flag and returning -EINVAL to the application.
Note that the actual handling of the flag is already there in
sctp_datamsg_from_user().
https://tools.ietf.org/html/rfc7053#section-7
Fixes: b93d6471748d ("sctp: implement the sender side for SACK-IMMEDIATELY extension")
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit fa0dc04df259ba2df3ce1920e9690c7842f8fa4b ]
Dmitry reported a struct pid leak detected by a syzkaller program.
Bug happens in unix_stream_recvmsg() when we break the loop when a
signal is pending, without properly releasing scm.
Fixes: b3ca9b02b007 ("net: fix multithreaded signal handling in unix recv routines")
Cc: Rainer Weikusat <rweikusat@mobileactivedefense.com>
[ Upstream commit e62a123b8ef7c5dc4db2c16383d506860ad21b47 ]
Neal reported crashes with this stack trace :
RIP: 0010:[<ffffffff8c57231b>] tcp_v4_send_ack+0x41/0x20f
CR2: 0000000000000018 CR3: 000000044005c000 CR4: 00000000001427e0
[<ffffffff8c57258e>] tcp_v4_reqsk_send_ack+0xa5/0xb4
[<ffffffff8c1a7caa>] tcp_check_req+0x2ea/0x3e0
[<ffffffff8c19e420>] tcp_rcv_state_process+0x850/0x2500
[<ffffffff8c1a6d21>] tcp_v4_do_rcv+0x141/0x330
[<ffffffff8c56cdb2>] sk_backlog_rcv+0x21/0x30
[<ffffffff8c098bbd>] tcp_recvmsg+0x75d/0xf90
[<ffffffff8c0a8700>] inet_recvmsg+0x80/0xa0
[<ffffffff8c17623e>] sock_aio_read+0xee/0x110
[<ffffffff8c066fcf>] do_sync_read+0x6f/0xa0
[<ffffffff8c0673a1>] SyS_read+0x1e1/0x290
[<ffffffff8c5ca262>] system_call_fastpath+0x16/0x1b
The problem here is the skb we provide to tcp_v4_send_ack() had to
be parked in the backlog of a new TCP fastopen child because this child
was owned by the user at the time an out of window packet arrived.
Before queuing a packet, TCP has to set skb->dev to NULL as the device
could disappear before packet is removed from the queue.
Fix this issue by using the net pointer provided by the socket (being a
timewait or a request socket).
IPv6 is immune to the bug : tcp_v6_send_response() already gets the net
pointer from the socket if provided.
Fixes: 168a8f58059a ("tcp: TCP Fast Open Server - main code path")
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Jerry Chu <hkchu@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 52a82e23b9f2a9e1d429c5207f8575784290d008 ]
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Reviewed-by: Evgeny Cherkashin <Eugene.Crosser@ru.ibm.com>
[ Upstream commit 6736fde9672ff6717ac576e9bba2fd5f3dfec822 ]
The code within wait_event_interruptible() is called with
!TASK_RUNNING, so mustn't call any functions that can sleep,
like mutex_lock().
Since we re-check the list_empty() in a loop after the wait,
it's safe to simply use list_empty() without locking.
This bug has existed forever, but was only discovered now
because all userspace implementations, including the default
'rfkill' tool, use poll() or select() to get a readable fd
before attempting to read.
Fixes: c64fb01627e24 ("rfkill: create useful userspace interface")
[ Upstream commit 4fa11ec726a32ea6dd768dbb2e2af3453a98ec0a ]
During a sw scan ieee80211_iface_work ignores work items for all vifs.
However after the scan complete work is requeued only for STA, ADHOC
and MESH iftypes.
This occasionally results in event processing getting delayed/not
processed for iftype AP when it coexists with a STA. This can result
in data halt and eventually disconnection on the AP interface.
Signed-off-by: Sachin Kulkarni <Sachin.Kulkarni@imgtec.com>
[ Upstream commit 67645d7619738e51c668ca69f097cb90b5470422 ]
There are a number of problems with revoking a "was sending" message:
(1) We never make any attempt to revoke data - only kvecs contibute to
con->out_skip. However, once the header (envelope) is written to the
socket, our peer learns data_len and sets itself to expect at least
data_len bytes to follow front or front+middle. If ceph_msg_revoke()
is called while the messenger is sending message's data portion,
anything we send after that call is counted by the OSD towards the now
revoked message's data portion. The effects vary, the most common one
is the eventual hang - higher layers get stuck waiting for the reply to
the message that was sent out after ceph_msg_revoke() returned and
treated by the OSD as a bunch of data bytes. This is what Matt ran
into.
(2) Flat out zeroing con->out_kvec_bytes worth of bytes to handle kvecs
is wrong. If ceph_msg_revoke() is called before the tag is sent out or
while the messenger is sending the header, we will get a connection
reset, either due to a bad tag (0 is not a valid tag) or a bad header
CRC, which kind of defeats the purpose of revoke. Currently the kernel
client refuses to work with header CRCs disabled, but that will likely
change in the future, making this even worse.
(3) con->out_skip is not reset on connection reset, leading to one or
more spurious connection resets if we happen to get a real one between
con->out_skip is set in ceph_msg_revoke() and before it's cleared in
write_partial_skip().
Fixing (1) and (3) is trivial. The idea behind fixing (2) is to never
zero the tag or the header, i.e. send out tag+header regardless of when
ceph_msg_revoke() is called. That way the header is always correct, no
unnecessary resets are induced and revoke stands ready for disabled
CRCs. Since ceph_msg_revoke() rips out con->out_msg, introduce a new
"message out temp" and copy the header into it before sending.
Cc: stable@vger.kernel.org # 4.0+
Reported-by: Matt Conner <matt.conner@keepertech.com>
Tested-by: Matt Conner <matt.conner@keepertech.com>
Reviewed-by: Sage Weil <sage@redhat.com>
[ Upstream commit a8a572a6b5f2a79280d6e302cb3c1cb1fbaeb3e8 ]
Remove the dst_entries_init/destroy calls for xfrm4 and xfrm6 dst_ops
templates; their dst_entries counters will never be used. Move the
xfrm dst_ops initialization from the common xfrm/xfrm_policy.c to
xfrm4/xfrm4_policy.c and xfrm6/xfrm6_policy.c, and call dst_entries_init
and dst_entries_destroy for each net namespace.
The ipv4 and ipv6 xfrms each create dst_ops template, and perform
dst_entries_init on the templates. The template values are copied to each
net namespace's xfrm.xfrm*_dst_ops. The problem there is the dst_ops
pcpuc_entries field is a percpu counter and cannot be used correctly by
simply copying it to another object.
The result of this is a very subtle bug; changes to the dst entries
counter from one net namespace may sometimes get applied to a different
net namespace dst entries counter. This is because of how the percpu
counter works; it has a main count field as well as a pointer to the
percpu variables. Each net namespace maintains its own main count
variable, but all point to one set of percpu variables. When any net
namespace happens to change one of the percpu variables to outside its
small batch range, its count is moved to the net namespace's main count
variable. So with multiple net namespaces operating concurrently, the
dst_ops entries counter can stray from the actual value that it should
be; if counts are consistently moved from one net namespace to another
(which my testing showed is likely), then one net namespace winds up
with a negative dst_ops count while another winds up with a continually
increasing count, eventually reaching its gc_thresh limit, which causes
all new traffic on the net namespace to fail with -ENOBUFS.
Signed-off-by: Dan Streetman <dan.streetman@canonical.com>
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 635682a14427d241bab7bbdeebb48a7d7b91638e ]
A case can occur when sctp_accept() is called by the user during
a heartbeat timeout event after the 4-way handshake. Since
sctp_assoc_migrate() changes both assoc->base.sk and assoc->ep, the
bh_sock_lock in sctp_generate_heartbeat_event() will be taken with
the listening socket but released with the new association socket.
The result is a deadlock on any future attempts to take the listening
socket lock.
Note that this race can occur with other SCTP timeouts that take
the bh_lock_sock() in the event sctp_accept() is called.
BUG: soft lockup - CPU#9 stuck for 67s! [swapper:0]
RIP: 0010:[<ffffffff8152d48e>] [<ffffffff8152d48e>] _spin_lock+0x1e/0x30
RSP: 0018:ffff880028323b20 EFLAGS: 00000206
RAX: 0000000000000002 RBX: ffff880028323b20 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffff880028323be0 RDI: ffff8804632c4b48
RBP: ffffffff8100bb93 R08: 0000000000000000 R09: 0000000000000000
R10: ffff880610662280 R11: 0000000000000100 R12: ffff880028323aa0
R13: ffff8804383c3880 R14: ffff880028323a90 R15: ffffffff81534225
FS: 0000000000000000(0000) GS:ffff880028320000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000000006df528 CR3: 0000000001a85000 CR4: 00000000000006e0
Process swapper (pid: 0, threadinfo ffff880616b70000, task ffff880616b6cab0)
Stack:
ffff880028323c40 ffffffffa01c2582 ffff880614cfb020 0000000000000000
<d> 0100000000000000 00000014383a6c44 ffff8804383c3880 ffff880614e93c00
<d> ffff880614e93c00 0000000000000000 ffff8804632c4b00 ffff8804383c38b8
Call Trace:
<IRQ>
[<ffffffffa01c2582>] ? sctp_rcv+0x492/0xa10 [sctp]
[<ffffffff8148c559>] ? nf_iterate+0x69/0xb0
[<ffffffff814974a0>] ? ip_local_deliver_finish+0x0/0x2d0
[<ffffffff8148c716>] ? nf_hook_slow+0x76/0x120
[<ffffffff8149757d>] ? ip_local_deliver_finish+0xdd/0x2d0
[<ffffffff81497808>] ? ip_local_deliver+0x98/0xa0
[<ffffffff81496ccd>] ? ip_rcv_finish+0x12d/0x440
[<ffffffff81497255>] ? ip_rcv+0x275/0x350
[<ffffffff8145cfeb>] ? __netif_receive_skb+0x4ab/0x750
With lockdep debugging:
[ BUG: bad unlock balance detected! ]
CslRx/12087 is trying to release lock (slock-AF_INET) at:
[<ffffffffa01bcae0>] sctp_generate_timeout_event+0x40/0xe0 [sctp]
but there are no more locks to release!
2 locks held by CslRx/12087:
#0: (&asoc->timers[i]){+.-...}, at: [<ffffffff8108ce1f>] run_timer_softirq+0x16f/0x3e0
#1: (slock-AF_INET){+.-...}, at: [<ffffffffa01bcac3>] sctp_generate_timeout_event+0x23/0xe0 [sctp]
Ensure the socket taken is also the same one that is released by
saving a copy of the socket before entering the timeout event
critical section.
Signed-off-by: Karl Heiss <kheiss@gmail.com>
[ Upstream commit 42eff6a617e23b691f8e4467f4687ed7245a92db ]
It is not allowed to free the memory of an object which is part of a list
which is protected by rcu-read-side-critical sections without making sure
that no other context is accessing the object anymore. This usually happens
by removing the references to this object and then waiting until the rcu
grace period is over and no one (allowedly) accesses it anymore.
But the _now functions ignore this completely. They free the object
directly even when a different context still tries to access it. This has
to be avoided and thus these functions must be removed and all functions
have to use batadv_orig_node_free_ref.
Fixes: 72822225bd41 ("batman-adv: Fix rcu_barrier() miss due to double call_rcu() in TT code")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <a@unstable.cc>
[ Upstream commit b4d922cfc9c08318eeb77d53b7633740e6b0efb0 ]
have to use batadv_hardif_free_ref.
Fixes: 89652331c00f ("batman-adv: split tq information in neigh_node struct")
[ Upstream commit ae3e1e36e3cb6c686a7a2725af20ca86aa46d62a ]
have to use batadv_neigh_ifinfo_free_ref.
