path: root/net
2013-09-26netfilter: qtaguid: rate limit some of the printksJP Abgrall
Some of the printks are in the packet handling path. We now ratelimit the very unlikely errors to avoid kmsg spamming. Signed-off-by: JP Abgrall <jpa@google.com> Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-09-26netfilter: xt_qtaguid: Allow tracking loopbackJP Abgrall
In the past it would always ignore interfaces with loopback addresses. Now we just treat them like any other. This also helps with writing tests that check for the presence of the qtaguid module. Signed-off-by: JP Abgrall <jpa@google.com> Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-09-26netfilter: xt_qtaguid: extend iface stat to report protocolsJP Abgrall
In the past the iface_stat_fmt would only show global bytes/packets for the skb-based numbers. For stall detection in userspace, distinguishing tcp vs other protocols makes it easier. Now we report ifname total_skb_rx_bytes total_skb_rx_packets total_skb_tx_bytes total_skb_tx_packets {rx,tx}_{tcp,udp,ohter}_{bytes,packets} Bug: 6818637 Signed-off-by: JP Abgrall <jpa@google.com> Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-09-26netfilter: xt_qtaguid: remove AID_* dependency for access controlJP Abgrall
qtaguid limits what can be done with /ctrl and /stats based on group membership. This changes removes AID_NET_BW_STATS and AID_NET_BW_ACCT, and picks up the groups from the gid of the matching proc entry files. Signed-off-by: JP Abgrall <jpa@google.com> Change-Id: I42e477adde78a12ed5eb58fbc0b277cdaadb6f94 Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-09-26netfilter: qtaguid: Don't BUG_ON if create_if_tag_stat failsPontus Fuchs
If create_if_tag_stat fails to allocate memory (GFP_ATOMIC) the following will happen: qtaguid: iface_stat: tag stat alloc failed ... kernel BUG at xt_qtaguid.c:1482! Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com> Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-09-26netfilter: xt_qtaguid: fix error exit that would keep a spinlock.JP Abgrall
qtudev_open() could return with a uid_tag_data_tree_lock held when an kzalloc(..., GFP_ATOMIC) would fail. Very unlikely to get triggered AND survive the mayhem of running out of mem. Signed-off-by: JP Abgrall <jpa@google.com>
2013-01-06ENGR00180079 rfkill:revert "change rfkill node permission"Jianzheng Zhou
This reverts commit 60daab290bbab00c73cc057ff868f658ec73d304. For it will break android CTS. Change to fix it in upper. Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2012-12-27ENGR00238276: rfkill:change rfkill node permissionJianzheng Zhou
Use CONFIG_ANDROID_PARANOID_NETWORK to change the rfkill's attr permission (state and type) to fix android upper has no right to access and write issue when use dongle devices. Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2012-09-29Merge branch 'jb' into imx_3.0.35_androidXinyu Chen
Conflicts: drivers/cpufreq/cpufreq_interactive.c fs/proc/base.c
2012-08-28netfilter: xt_qtaguid: report only uid tags to non-privileged processesJP Abgrall
In the past, a process could only see its own stats (uid-based summary, and details). Now we allow any process to see other UIDs uid-based stats, but still hide the detailed stats. Change-Id: I7666961ed244ac1d9359c339b048799e5db9facc Signed-off-by: JP Abgrall <jpa@google.com>
2012-08-24cfg80211: allow registering to beaconsJohannes Berg
Add the ability to register to received beacon frames to allow implementing OLBC logic in userspace. The registration is per wiphy since there's no point in receiving the same frame multiple times. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-24nl80211: add API to probe a clientJohannes Berg
When the AP SME in hostapd is used it wants to probe the clients when they have been idle for some time. Add explicit API to support this. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-24nl80211: allow subscribing to unexpected class3 framesJohannes Berg
To implement AP mode without monitor interfaces we need to be able to send a deauth to stations that send frames without being associated. Enable this by adding a new nl80211 event for such frames that an application can subscribe to. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-24nl80211: advertise device AP SMEJohannes Berg
Add the ability to advertise that the device contains the AP SME and what features it can support. There are currently no features in the bitmap -- probe response offload will be advertised by a few patches Arik is working on now (who took over from Guy Eilam) and a device with AP SME will typically implement and require response offload. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Conflicts: drivers/net/wireless/ath/ath6kl/init.c Change-Id: Ib1a65814860cf97cadd142c17be0e91f43743832
2012-08-24nl80211: advertise GTK rekey support, new triggersJohannes Berg
Since we now have the necessary API in place to support GTK rekeying, applications will need to know whether it is supported by a device. Add a pseudo-trigger that is used only to advertise that capability. Also, add some new triggers that match what iwlagn devices can do. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-24nl80211: support sending TDLS commands/framesArik Nemtsov
Add support for sending high-level TDLS commands and TDLS frames via NL80211_CMD_TDLS_OPER and NL80211_CMD_TDLS_MGMT, respectively. Add appropriate cfg80211 callbacks for lower level drivers. Add wiphy capability flags for TDLS support and advertise them via nl80211. Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: Kalyan C Gaddam <chakkal@iit.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com> Conflicts: include/linux/nl80211.h include/net/cfg80211.h net/wireless/nl80211.c Change-Id: I08e4de6e92680aed35b98838aa999d31963b6d50
2012-08-24cfg80211/nl80211: Add PMKSA caching candidate eventJouni Malinen
When the driver (or most likely firmware) decides which AP to use for roaming based on internal scan result processing, user space needs to be notified of PMKSA caching candidates to allow RSN pre-authentication to be used. Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Conflicts: include/linux/nl80211.h Change-Id: I31aa113747b75f5f35658b857fdfe8d9a75e4534
2012-08-24cfg80211/nl80211: support GTK rekey offloadJohannes Berg
In certain circumstances, like WoWLAN scenarios, devices may implement (partial) GTK rekeying on the device to avoid waking up the host for it. In order to successfully go through GTK rekeying, the KEK, KCK and the replay counter are required. Add API to let the supplicant hand the parameters to the driver which may store it for future GTK rekey operations. Note that, of course, if GTK rekeying is done by the device, the EAP frame must not be passed up to userspace, instead a rekey event needs to be sent to let userspace update its replay counter. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Conflicts: include/linux/nl80211.h net/wireless/nl80211.c Change-Id: Icd3a157742b08c01a3be20d46d4112e5d4b93a58
2012-08-13netfilter: xt_IDLETIMER: Rename INTERFACE to LABEL in netlink notification.Ashish Sharma
Signed-off-by: Ashish Sharma <ashishsharma@google.com>
2012-07-31ENGR00217401-2 android: fix build warningXinyu Chen
Fix build warning bring in by Google's code Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
2012-07-25Merge remote branch 'fsl-linux-sdk/imx_3.0.35' into imx_3.0.35_androidXinyu Chen
Conflicts: arch/arm/configs/imx6_defconfig arch/arm/configs/imx6_updater_defconfig arch/arm/configs/imx6s_defconfig arch/arm/include/asm/dma-mapping.h arch/arm/kernel/smp.c arch/arm/mach-mx6/Kconfig arch/arm/mach-mx6/board-mx6dl_arm2.h arch/arm/mach-mx6/board-mx6dl_sabresd.h arch/arm/mach-mx6/board-mx6q_arm2.c arch/arm/mach-mx6/board-mx6q_arm2.h arch/arm/mach-mx6/board-mx6q_sabreauto.c arch/arm/mach-mx6/board-mx6q_sabreauto.h arch/arm/mach-mx6/board-mx6q_sabrelite.c arch/arm/mach-mx6/board-mx6q_sabresd.c arch/arm/mach-mx6/board-mx6q_sabresd.h arch/arm/mach-mx6/board-mx6sl_arm2.c arch/arm/mach-mx6/board-mx6sl_arm2.h arch/arm/mach-mx6/board-mx6solo_sabreauto.h arch/arm/mach-mx6/bus_freq.c arch/arm/mach-mx6/clock.c arch/arm/mach-mx6/clock_mx6sl.c arch/arm/mach-mx6/cpu.c arch/arm/mach-mx6/crm_regs.h arch/arm/mach-mx6/devices-imx6q.h arch/arm/mach-mx6/devices.c arch/arm/mach-mx6/mx6_anatop_regulator.c arch/arm/mach-mx6/pcie.c arch/arm/mach-mx6/system.c arch/arm/mm/dma-mapping.c arch/arm/plat-mxc/devices/Makefile arch/arm/plat-mxc/devices/platform-imx-dcp.c arch/arm/plat-mxc/devices/platform-imx-ocotp.c arch/arm/plat-mxc/devices/platform-imx-rngb.c arch/arm/plat-mxc/devices/platform-mxc_hdmi.c arch/arm/plat-mxc/include/mach/devices-common.h arch/arm/plat-mxc/include/mach/esdhc.h arch/arm/plat-mxc/include/mach/iomux-mx6dl.h arch/arm/plat-mxc/include/mach/iomux-mx6q.h arch/arm/plat-mxc/include/mach/memory.h arch/arm/plat-mxc/include/mach/mx6.h arch/arm/plat-mxc/include/mach/mxc_edid.h arch/arm/plat-mxc/include/mach/mxc_hdmi.h arch/arm/plat-mxc/system.c drivers/Kconfig drivers/char/hw_random/fsl-rngc.c drivers/cpufreq/Makefile drivers/cpufreq/cpufreq_interactive.c drivers/crypto/Kconfig drivers/crypto/caam/caamalg.c drivers/crypto/caam/compat.h drivers/crypto/caam/ctrl.c drivers/crypto/caam/desc_constr.h drivers/crypto/caam/intern.h drivers/crypto/dcp.c drivers/dma/pch_dma.c drivers/input/keyboard/gpio_keys.c drivers/input/touchscreen/egalax_ts.c drivers/input/touchscreen/max11801_ts.c drivers/media/video/mxc/capture/Kconfig drivers/media/video/mxc/capture/adv7180.c drivers/media/video/mxc/capture/ipu_csi_enc.c drivers/media/video/mxc/capture/ipu_prp_vf_sdc.c drivers/media/video/mxc/capture/ipu_prp_vf_sdc_bg.c drivers/media/video/mxc/capture/mxc_v4l2_capture.c drivers/media/video/mxc/capture/ov5640_mipi.c drivers/media/video/mxc/output/mxc_vout.c drivers/misc/Kconfig drivers/misc/Makefile drivers/mmc/card/block.c drivers/mmc/core/mmc.c drivers/mmc/host/mmci.c drivers/mmc/host/sdhci-esdhc-imx.c drivers/mmc/host/sdhci.c drivers/mmc/host/sdhci.h drivers/mxc/Kconfig drivers/mxc/Makefile drivers/mxc/asrc/mxc_asrc.c drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_context.c drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_hardware.c drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.c drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.h drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_command.c drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_event.c drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal.h drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_base.h drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_options.h drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_os.c drivers/mxc/ipu3/ipu_device.c drivers/mxc/vpu/mxc_vpu.c drivers/net/fec.c drivers/net/wireless/Makefile drivers/power/sabresd_battery.c drivers/regulator/core.c drivers/tty/serial/imx.c drivers/usb/core/hub.c drivers/usb/gadget/arcotg_udc.c drivers/usb/gadget/fsl_updater.c drivers/usb/gadget/inode.c drivers/usb/host/ehci-hub.c drivers/video/mxc/ldb.c drivers/video/mxc/mipi_dsi.c drivers/video/mxc/mxc_dispdrv.c drivers/video/mxc/mxc_dispdrv.h drivers/video/mxc/mxc_edid.c drivers/video/mxc/mxc_elcdif_fb.c drivers/video/mxc/mxc_ipuv3_fb.c drivers/video/mxc/mxc_spdc_fb.c drivers/video/mxc_hdmi.c drivers/watchdog/imx2_wdt.c fs/proc/base.c include/linux/mmc/host.h include/linux/mmc/sdhci.h include/linux/mxc_v4l2.h kernel/power/main.c sound/soc/codecs/mxc_hdmi.c sound/soc/codecs/mxc_spdif.c sound/soc/codecs/wm8962.c sound/soc/imx/Kconfig sound/soc/imx/Makefile sound/soc/imx/imx-cs42888.c sound/soc/imx/imx-esai.c sound/soc/imx/imx-wm8958.c sound/soc/imx/imx-wm8962.c
2012-07-25net: l2tp_eth: fix kernel panic on rmmod l2tp_ethEric Dumazet
[ Upstream commit a06998b88b1651c5f71c0e35f528bf2057188ead ] We must prevent module unloading if some devices are still attached to l2tp_eth driver. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Tested-by: Denys Fedoryshchenko <denys@visp.net.lb> Cc: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-25net: sock: validate data_len before allocating skb in sock_alloc_send_pskb()Jason Wang
[ Upstream commit cc9b17ad29ecaa20bfe426a8d4dbfb94b13ff1cc ] We need to validate the number of pages consumed by data_len, otherwise frags array could be overflowed by userspace. So this patch validate data_len and return -EMSGSIZE when data_len may occupies more frags than MAX_SKB_FRAGS. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-20net: remove mm.h inclusion from netdevice.hAlexey Dobriyan
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually). To prevent mm.h inclusion via other channels also extract "enum dma_data_direction" definition into separate header. This tiny piece is what gluing netdevice.h with mm.h via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h". Removal of mm.h from scatterlist.h was tried and was found not feasible on most archs, so the link was cutoff earlier. Hope people are OK with tiny include file. Note, that mm_types.h is still dragged in, but it is a separate story. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-17cfg80211: fix interface combinations checkJohannes Berg
commit 463454b5dbd8dbab6e2fc6c557329e5b811b9c32 upstream. If a given interface combination doesn't contain a required interface type then we missed checking that and erroneously allowed it even though iface type wasn't there at all. Add a check that makes sure that all interface types are accounted for. Reported-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17mac80211: clean up remain-on-channel on interface stopJohannes Berg
commit 71ecfa1893034eeb1c93e02e22ee2ad26d080858 upstream. When any interface goes down, it could be the one that we were doing a remain-on-channel with. We therefore need to cancel the remain-on-channel and flush the related work structs so they don't run after the interface has been removed or even destroyed. It's also possible in this case that an off-channel SKB was never transmitted, so free it if this is the case. Note that this can also happen if the driver finishes the off-channel period without ever starting it. Reported-by: Nirav Shah <nirav.j2.shah@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10xfrm: take net hdr len into account for esp payload size calculationBenjamin Poirier
[ Upstream commit 91657eafb64b4cb53ec3a2fbc4afc3497f735788 ] Corrects the function that determines the esp payload size. The calculations done in esp{4,6}_get_mtu() lead to overlength frames in transport mode for certain mtu values and suboptimal frames for others. According to what is done, mainly in esp{,6}_output() and tcp_mtu_to_mss(), net_header_len must be taken into account before doing the alignment calculation. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10sctp: check cached dst before using itNicolas Dichtel
[ Upstream commit e0268868ba064980488fc8c194db3d8e9fb2959c ] dst_check() will take care of SA (and obsolete field), hence IPsec rekeying scenario is taken into account. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Vlad Yaseivch <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10Revert "net: maintain namespace isolation between vlan and real device"David S. Miller
[ Upstream commit 59b9997baba5242997ddc7bd96b1391f5275a5a4 ] This reverts commit 8a83a00b0735190384a348156837918271034144. It causes regressions for S390 devices, because it does an unconditional DST drop on SKBs for vlans and the QETH device needs the neighbour entry hung off the DST for certain things on transmit. Arnd can't remember exactly why he even needed this change. Conflicts: drivers/net/macvlan.c net/8021q/vlan_dev.c net/core/dev.c Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10pktgen: fix module unload for goodEric Dumazet
[ Upstream commit d4b1133558e0d417342d5d2c49e4c35b428ff20d ] commit c57b5468406 (pktgen: fix crash at module unload) did a very poor job with list primitives. 1) list_splice() arguments were in the wrong order 2) list_splice(list, head) has undefined behavior if head is not initialized. 3) We should use the list_splice_init() variant to clear pktgen_threads list. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10pktgen: fix crash at module unloadEric Dumazet
[ Upstream commit c57b54684060c8aced64a5b78ff69ff289af97b9 ] commit 7d3d43dab4e9 (net: In unregister_netdevice_notifier unregister the netdevices.) makes pktgen crashing at module unload. [ 296.820578] BUG: spinlock bad magic on CPU#6, rmmod/3267 [ 296.820719] lock: ffff880310c38000, .magic: ffff8803, .owner: <none>/-1, .owner_cpu: -1 [ 296.820943] Pid: 3267, comm: rmmod Not tainted 3.4.0-rc5+ #254 [ 296.821079] Call Trace: [ 296.821211] [<ffffffff8168a715>] spin_dump+0x8a/0x8f [ 296.821345] [<ffffffff8168a73b>] spin_bug+0x21/0x26 [ 296.821507] [<ffffffff812b4741>] do_raw_spin_lock+0x131/0x140 [ 296.821648] [<ffffffff8169188e>] _raw_spin_lock+0x1e/0x20 [ 296.821786] [<ffffffffa00cc0fd>] __pktgen_NN_threads+0x4d/0x140 [pktgen] [ 296.821928] [<ffffffffa00ccf8d>] pktgen_device_event+0x10d/0x1e0 [pktgen] [ 296.822073] [<ffffffff8154ed4f>] unregister_netdevice_notifier+0x7f/0x100 [ 296.822216] [<ffffffffa00d2a0b>] pg_cleanup+0x48/0x73 [pktgen] [ 296.822357] [<ffffffff8109528e>] sys_delete_module+0x17e/0x2a0 [ 296.822502] [<ffffffff81699652>] system_call_fastpath+0x16/0x1b Hold the pktgen_thread_lock while splicing pktgen_threads, and test pktgen_exiting in pktgen_device_event() to make unload faster. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10l2tp: fix oops in L2TP IP sockets for connect() AF_UNSPEC caseJames Chapman
[ Upstream commit c51ce49735c183ef2592db70f918ee698716276b ] An application may call connect() to disconnect a socket using an address with family AF_UNSPEC. The L2TP IP sockets were not handling this case when the socket is not bound and an attempt to connect() using AF_UNSPEC in such cases would result in an oops. This patch addresses the problem by protecting the sk_prot->disconnect() call against trying to unhash the socket before it is bound. The patch also adds more checks that the sockaddr supplied to bind() and connect() calls is valid. RIP: 0010:[<ffffffff82e133b0>] [<ffffffff82e133b0>] inet_unhash+0x50/0xd0 RSP: 0018:ffff88001989be28 EFLAGS: 00010293 Stack: ffff8800407a8000 0000000000000000 ffff88001989be78 ffffffff82e3a249 ffffffff82e3a050 ffff88001989bec8 ffff88001989be88 ffff8800407a8000 0000000000000010 ffff88001989bec8 ffff88001989bea8 ffffffff82e42639 Call Trace: [<ffffffff82e3a249>] udp_disconnect+0x1f9/0x290 [<ffffffff82e42639>] inet_dgram_connect+0x29/0x80 [<ffffffff82d012fc>] sys_connect+0x9c/0x100 Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10ipv6: fix incorrect ipsec fragmentGao feng
[ Upstream commit 0c1833797a5a6ec23ea9261d979aa18078720b74 ] Since commit ad0081e43a "ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed" the fragment of packets is incorrect. because tunnel mode needs IPsec headers and trailer for all fragments, while on transport mode it is sufficient to add the headers to the first fragment and the trailer to the last. so modify mtu and maxfraglen base on ipsec mode and if fragment is first or last. with my test,it work well(every fragment's size is the mtu) and does not trigger slow fragment path. Changes from v1: though optimization, mtu_prev and maxfraglen_prev can be delete. replace xfrm mode codes with dst_entry's new frag DST_XFRM_TUNNEL. add fuction ip6_append_data_mtu to make codes clearer. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10ipv4: fix the rcu race between free_fib_info and ip_route_output_slowYanmin Zhang
[ Upstream commit e49cc0da7283088c5e03d475ffe2fdcb24a6d5b1 ] We hit a kernel OOPS. <3>[23898.789643] BUG: sleeping function called from invalid context at /data/buildbot/workdir/ics/hardware/intel/linux-2.6/arch/x86/mm/fault.c:1103 <3>[23898.862215] in_atomic(): 0, irqs_disabled(): 0, pid: 10526, name: Thread-6683 <4>[23898.967805] HSU serial 0000:00:05.1: 0000:00:05.2:HSU serial prevented me to suspend... <4>[23899.258526] Pid: 10526, comm: Thread-6683 Tainted: G W 3.0.8-137685-ge7742f9 #1 <4>[23899.357404] HSU serial 0000:00:05.1: 0000:00:05.2:HSU serial prevented me to suspend... <4>[23899.904225] Call Trace: <4>[23899.989209] [<c1227f50>] ? pgtable_bad+0x130/0x130 <4>[23900.000416] [<c1238c2a>] __might_sleep+0x10a/0x110 <4>[23900.007357] [<c1228021>] do_page_fault+0xd1/0x3c0 <4>[23900.013764] [<c18e9ba9>] ? restore_all+0xf/0xf <4>[23900.024024] [<c17c007b>] ? napi_complete+0x8b/0x690 <4>[23900.029297] [<c1227f50>] ? pgtable_bad+0x130/0x130 <4>[23900.123739] [<c1227f50>] ? pgtable_bad+0x130/0x130 <4>[23900.128955] [<c18ea0c3>] error_code+0x5f/0x64 <4>[23900.133466] [<c1227f50>] ? pgtable_bad+0x130/0x130 <4>[23900.138450] [<c17f6298>] ? __ip_route_output_key+0x698/0x7c0 <4>[23900.144312] [<c17f5f8d>] ? __ip_route_output_key+0x38d/0x7c0 <4>[23900.150730] [<c17f63df>] ip_route_output_flow+0x1f/0x60 <4>[23900.156261] [<c181de58>] ip4_datagram_connect+0x188/0x2b0 <4>[23900.161960] [<c18e981f>] ? _raw_spin_unlock_bh+0x1f/0x30 <4>[23900.167834] [<c18298d6>] inet_dgram_connect+0x36/0x80 <4>[23900.173224] [<c14f9e88>] ? _copy_from_user+0x48/0x140 <4>[23900.178817] [<c17ab9da>] sys_connect+0x9a/0xd0 <4>[23900.183538] [<c132e93c>] ? alloc_file+0xdc/0x240 <4>[23900.189111] [<c123925d>] ? sub_preempt_count+0x3d/0x50 Function free_fib_info resets nexthop_nh->nh_dev to NULL before releasing fi. Other cpu might be accessing fi. Fixing it by delaying the releasing. With the patch, we ran MTBF testing on Android mobile for 12 hours and didn't trigger the issue. Thank Eric for very detailed review/checking the issue. Signed-off-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Kun Jiang <kunx.jiang@intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10ipv4: Do not use dead fib_info entries.David S. Miller
[ Upstream commit dccd9ecc374462e5d6a5b8f8110415a86c2213d8 ] Due to RCU lookups and RCU based release, fib_info objects can be found during lookup which have fi->fib_dead set. We must ignore these entries, otherwise we risk dereferencing the parts of the entry which are being torn down. Reported-by: Yevgen Pronenko <yevgen.pronenko@sonymobile.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10mac80211: fix ADDBA declined after suspend with wowlanEyal Shapira
commit 7b21aea04d084916ac4e0e8852dcc9cd60ec0d1d upstream. WLAN_STA_BLOCK_BA is set while suspending but doesn't get cleared when resuming in case of wowlan. This causes further ADDBA requests received to be rejected. Fix it by clearing it in the wowlan path as well. Signed-off-by: Eyal Shapira <eyal@wizery.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01cfg80211: warn if db.txt is empty with CONFIG_CFG80211_INTERNAL_REGDBLuis R. Rodriguez
commit 80007efeff0568375b08faf93c7aad65602cb97e upstream. It has happened twice now where elaborate troubleshooting has undergone on systems where CONFIG_CFG80211_INTERNAL_REGDB [0] has been set but yet net/wireless/db.txt was not updated. Despite the documentation on this it seems system integrators could use some more help with this, so throw out a kernel warning at boot time when their database is empty. This does mean that the error-prone system integrator won't likely realize the issue until they boot the machine but -- it does not seem to make sense to enable a build bug breaking random build testing. [0] http://wireless.kernel.org/en/developers/Regulatory/CRDA#CONFIG_CFG80211_INTERNAL_REGDB Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Youngsin Lee <youngsin@qualcomm.com> Cc: Raja Mani <rmani@qca.qualcomm.com> Cc: Senthil Kumar Balasubramanian <senthilb@qca.qualcomm.com> Cc: Vipin Mehta <vipimeht@qca.qualcomm.com> Cc: yahuan@qca.qualcomm.com Cc: jjan@qca.qualcomm.com Cc: vthiagar@qca.qualcomm.com Cc: henrykim@qualcomm.com Cc: jouni@qca.qualcomm.com Cc: athiruve@qca.qualcomm.com Cc: cjkim@qualcomm.com Cc: philipk@qca.qualcomm.com Cc: sunnykim@qualcomm.com Cc: sskwak@qualcomm.com Cc: kkim@qualcomm.com Cc: mattbyun@qualcomm.com Cc: ryanlee@qualcomm.com Cc: simbap@qualcomm.com Cc: krislee@qualcomm.com Cc: conner@qualcomm.com Cc: hojinkim@qualcomm.com Cc: honglee@qualcomm.com Cc: johnwkim@qualcomm.com Cc: jinyong@qca.qualcomm.com Signed-off-by: Luis R. Rodriguez <mcgrof@frijolero.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21tcp: do_tcp_sendpages() must try to push data out on oom conditionsWilly Tarreau
commit bad115cfe5b509043b684d3a007ab54b80090aa1 upstream. Since recent changes on TCP splicing (starting with commits 2f533844 "tcp: allow splice() to build full TSO packets" and 35f9c09f "tcp: tcp_sendpages() should call tcp_push() once"), I started seeing massive stalls when forwarding traffic between two sockets using splice() when pipe buffers were larger than socket buffers. Latest changes (net: netdev_alloc_skb() use build_skb()) made the problem even more apparent. The reason seems to be that if do_tcp_sendpages() fails on out of memory condition without being able to send at least one byte, tcp_push() is not called and the buffers cannot be flushed. After applying the attached patch, I cannot reproduce the stalls at all and the data rate it perfectly stable and steady under any condition which previously caused the problem to be permanent. The issue seems to have been there since before the kernel migrated to git, which makes me think that the stalls I occasionally experienced with tux during stress-tests years ago were probably related to the same issue. This issue was first encountered on 3.0.31 and 3.2.17, so please backport to -stable. Signed-off-by: Willy Tarreau <w@1wt.eu> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21tcp: change tcp_adv_win_scale and tcp_rmem[2]Eric Dumazet
[ Upstream commit b49960a05e32121d29316cfdf653894b88ac9190 ] tcp_adv_win_scale default value is 2, meaning we expect a good citizen skb to have skb->len / skb->truesize ratio of 75% (3/4) In 2.6 kernels we (mis)accounted for typical MSS=1460 frame : 1536 + 64 + 256 = 1856 'estimated truesize', and 1856 * 3/4 = 1392. So these skbs were considered as not bloated. With recent truesize fixes, a typical MSS=1460 frame truesize is now the more precise : 2048 + 256 = 2304. But 2304 * 3/4 = 1728. So these skb are not good citizen anymore, because 1460 < 1728 (GRO can escape this problem because it build skbs with a too low truesize.) This also means tcp advertises a too optimistic window for a given allocated rcvspace : When receiving frames, sk_rmem_alloc can hit sk_rcvbuf limit and we call tcp_prune_queue()/tcp_collapse() too often, especially when application is slow to drain its receive queue or in case of losses (netperf is fast, scp is slow). This is a major latency source. We should adjust the len/truesize ratio to 50% instead of 75% This patch : 1) changes tcp_adv_win_scale default to 1 instead of 2 2) increase tcp_rmem[2] limit from 4MB to 6MB to take into account better truesize tracking and to allow autotuning tcp receive window to reach same value than before. Note that same amount of kernel memory is consumed compared to 2.6 kernels. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21net: l2tp: unlock socket lock before returning from l2tp_ip_sendmsgSasha Levin
[ Upstream commit 84768edbb2721637620b2d84501bb0d5aed603f1 ] l2tp_ip_sendmsg could return without releasing socket lock, making it all the way to userspace, and generating the following warning: [ 130.891594] ================================================ [ 130.894569] [ BUG: lock held when returning to user space! ] [ 130.897257] 3.4.0-rc5-next-20120501-sasha #104 Tainted: G W [ 130.900336] ------------------------------------------------ [ 130.902996] trinity/8384 is leaving the kernel with locks still held! [ 130.906106] 1 lock held by trinity/8384: [ 130.907924] #0: (sk_lock-AF_INET){+.+.+.}, at: [<ffffffff82b9503f>] l2tp_ip_sendmsg+0x2f/0x550 Introduced by commit 2f16270 ("l2tp: Fix locking in l2tp_ip.c"). Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21net: In unregister_netdevice_notifier unregister the netdevices.Eric W. Biederman
[ Upstream commit 7d3d43dab4e978d8d9ad1acf8af15c9b1c4b0f0f ] We already synthesize events in register_netdevice_notifier and synthesizing events in unregister_netdevice_notifier allows to us remove the need for special case cleanup code. This change should be safe as it adds no new cases for existing callers of unregiser_netdevice_notifier to handle. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21netem: fix possible skb leakEric Dumazet
[ Upstream commit 116a0fc31c6c9b8fc821be5a96e5bf0b43260131 ] skb_checksum_help(skb) can return an error, we must free skb in this case. qdisc_drop(skb, sch) can also be feeded with a NULL skb (if skb_unshare() failed), so lets use this generic helper. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-09ipv6: check return value for dst_allocMadalin Bucur
return value of dst_alloc must be checked before use Signed-off-by: Madalin Bucur <madalin.bucur@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-09net: check return value for dst_allocMadalin Bucur
2012-05-08Merge commit 'v3.0.31' into android-3.0Todd Poynor
2012-05-07mac80211: fix AP mode EAP tx for VLAN stationsFelix Fietkau
commit 66f2c99af3d6f2d0aa1120884cf1c60613ef61c0 upstream. EAP frames for stations in an AP VLAN are sent on the main AP interface to avoid race conditions wrt. moving stations. For that to work properly, sta_info_get_bss must be used instead of sta_info_get when sending EAP packets. Previously this was only done for cooked monitor injected packets, so this patch adds a check for tx->skb->protocol to the same place. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-07nl80211: ensure interface is up in various APIsJohannes Berg
commit 2b5f8b0b44e17e625cfba1e7b88db44f4dcc0441 upstream. [backported by Ben Greear] The nl80211 handling code should ensure as much as it can that the interface is in a valid state, it can certainly ensure the interface is running. Not doing so can cause calls through mac80211 into the driver that result in warnings and unspecified behaviour in the driver. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-04netfilter: xt_qtaguid: start tracking iface rx/tx at low levelJP Abgrall
qtaguid tracks the device stats by monitoring when it goes up and down, then it gets the dev_stats(). But devs don't correctly report stats (either they don't count headers symmetrically between rx/tx, or they count internal control messages). Now qtaguid counts the rx/tx bytes/packets during raw:prerouting and mangle:postrouting (nat is not available in ipv6). The results are in /proc/net/xt_qtaguid/iface_stat_fmt which outputs a format line (bash expansion): ifname total_skb_{rx,tx}_{bytes,packets} Added event counters for pre/post handling. Added extra ctrl_*() pid/uid debugging. Change-Id: Id84345d544ad1dd5f63e3842cab229e71d339297 Signed-off-by: JP Abgrall <jpa@google.com>
2012-05-04netfilter: xt_IDLETIMER: Use uevent instead of new netlink msg typeJP Abgrall
Send netlink message notifications using a uevent with subsystem=xt_idletimer INTERFACE=... STATE={active,inactive} instead of needing a new netlink message type. Revert the netlink.h change added by commit beb914e987cbbd368988d2b94a6661cb907c4d5a Change-Id: I6881936bf754f3367ff3c8f6c1e9661cec0357d4 Signed-off-by: JP Abgrall <jpa@google.com>
2012-04-30Merge commit 'v3.0.30' into android-3.0Todd Poynor
