path: root/net
2014-12-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #3 from Al Viro: "Assorted fixes and patches from the last cycle" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: [regression] chunk lost from bd9b51 vfs: make mounts and mountstats honor root dir like mountinfo does vfs: cleanup show_mountinfo init: fix read-write root mount unfuck binfmt_misc.c (broken by commit e6084d4) vm_area_operations: kill ->migrate() new helper: iter_is_iovec() move_extent_per_page(): get rid of unused w_flags lustre: get rid of playing with ->fs btrfs: filp_open() returns ERR_PTR() on failure, not NULL...
2014-12-19[regression] chunk lost from bd9b51Al Viro
Reported-by: Pavel Emelyanov <xemul@parallels.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix NBMA tunnel mac header handling in GRE, from Timo Teräs. 2) Fix a NAPI race in the fec driver, from Nimrod Andy. 3) The new IFF_VNET_LE bit is outside the size of the flags member it is stored in (which is 16-bits), store the state locally in the drivers. From Michael S Tsirkin. 4) We are kicking the tires with the new wireless maintainership situation. Bluetooth fixes via Johan Hedberg, and mac80211 fixes from Johannes Berg. 5) Fix locking and leaks in geneve driver, from Jesse Gross. 6) Make netlink TX mmap code always copy, so we don't have to be potentially exposed to the user changing the underlying contents from underneath us. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (63 commits) be2net: Fix incorrect setting of tunnel offload flag in netdev features bnx2x: fix typos in "configure" xen-netback: support frontends without feature-rx-notify again MAINTAINERS: changes for wireless cxgb4: Fix decoding QSA module for ethtool get settings geneve: Fix races between socket add and release. geneve: Remove socket and offload handlers at destruction. netlink: Don't reorder loads/stores before marking mmap netlink frame as available netlink: Always copy on mmap TX. Bluetooth: Fix bug with filter in service discovery optimization mac80211: free management frame keys when removing station net: Disallow providing non zero VLAN ID for NIC drivers FDB add flow net/mlx4: Cache line CQE/EQE stride fixes net: fec: Fix NAPI race xen-netfront: use napi_complete() correctly to prevent Rx stalling ip_tunnel: Add missing validation of encap type to ip_tunnel_encap_setup() ip_tunnel: Add sanity checks to ip_tunnel_encap_add_ops() net: Allow FIXED_PHY to be modular. if_tun: drop broken IFF_VNET_LE macvtap: drop broken IFF_VNET_LE ...
2014-12-18Merge tag 'mac80211-for-davem-2014-12-18' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211 Johannes Berg says: ==================== pull-request: mac80211 2014-12-18 Also from me a first pull request - we have a number of really old issues that happened to crop up now with new work (or just more testing) in the right areas as well as some small bugs newly introduced in 3.19. Let me know if there are any problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-18Merge branch 'for-upstream' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth Johan Hedberg says: ==================== pull request: bluetooth 2014-12-17 Here's the first direct (i.e. skipping the wireless tree) bluetooth pull request for you, intended for 3.19. It's just one patch: a fix from Marcel for for remote service discovery filtering which also fixes a 'used uninitialized' compiler warning. Please let me know if there are any issues pulling. Thanks. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-18geneve: Fix races between socket add and release.Jesse Gross
Currently, searching for a socket to add a reference to is not synchronized with deletion of sockets. This can result in use after free if there is another operation that is removing a socket at the same time. Solving this requires both holding the appropriate lock and checking the refcount to ensure that it has not already hit zero. Inspired by a related (but not exactly the same) issue in the VXLAN driver. Fixes: 0b5e8b8e ("net: Add Geneve tunneling protocol driver") CC: Andy Zhou <azhou@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-18geneve: Remove socket and offload handlers at destruction.Jesse Gross
Sockets aren't currently removed from the the global list when they are destroyed. In addition, offload handlers need to be cleaned up as well. Fixes: 0b5e8b8e ("net: Add Geneve tunneling protocol driver") CC: Andy Zhou <azhou@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-18netlink: Don't reorder loads/stores before marking mmap netlink frame as ↵Thomas Graf
available Each mmap Netlink frame contains a status field which indicates whether the frame is unused, reserved, contains data or needs to be skipped. Both loads and stores may not be reordeded and must complete before the status field is changed and another CPU might pick up the frame for use. Use an smp_mb() to cover needs of both types of callers to netlink_set_status(), callers which have been reading data frame from the frame, and callers which have been filling or releasing and thus writing to the frame. - Example code path requiring a smp_rmb(): memcpy(skb->data, (void *)hdr + NL_MMAP_HDRLEN, hdr->nm_len); netlink_set_status(hdr, NL_MMAP_STATUS_UNUSED); - Example code path requiring a smp_wmb(): hdr->nm_uid = from_kuid(sk_user_ns(sk), NETLINK_CB(skb).creds.uid); hdr->nm_gid = from_kgid(sk_user_ns(sk), NETLINK_CB(skb).creds.gid); netlink_frame_flush_dcache(hdr); netlink_set_status(hdr, NL_MMAP_STATUS_VALID); Fixes: f9c228 ("netlink: implement memory mapped recvmsg()") Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-18netlink: Always copy on mmap TX.David Miller
Checking the file f_count and the nlk->mapped count is not completely sufficient to prevent the mmap'd area contents from changing from under us during netlink mmap sendmsg() operations. Be careful to sample the header's length field only once, because this could change from under us as well. Fixes: 5fd96123ee19 ("netlink: implement memory mapped sendmsg()") Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Thomas Graf <tgraf@suug.ch>
2014-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull ceph updates from Sage Weil: "The big item here is support for inline data for CephFS and for message signatures from Zheng. There are also several bug fixes, including interrupted flock request handling, 0-length xattrs, mksnap, cached readdir results, and a message version compat field. Finally there are several cleanups from Ilya, Dan, and Markus. Note that there is another series coming soon that fixes some bugs in the RBD 'lingering' requests, but it isn't quite ready yet" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (27 commits) ceph: fix setting empty extended attribute ceph: fix mksnap crash ceph: do_sync is never initialized libceph: fixup includes in pagelist.h ceph: support inline data feature ceph: flush inline version ceph: convert inline data to normal data before data write ceph: sync read inline data ceph: fetch inline data when getting Fcr cap refs ceph: use getattr request to fetch inline data ceph: add inline data to pagecache ceph: parse inline data in MClientReply and MClientCaps libceph: specify position of extent operation libceph: add CREATE osd operation support libceph: add SETXATTR/CMPXATTR osd operations support rbd: don't treat CEPH_OSD_OP_DELETE as extent op ceph: remove unused stringification macros libceph: require cephx message signature by default ceph: introduce global empty snap context ceph: message versioning fixes ...
2014-12-17Bluetooth: Fix bug with filter in service discovery optimizationMarcel Holtmann
The optimization for filtering out extended inquiry results, advertising reports or scan response data based on provided UUID list has a logic bug. In case no match is found in the advertising data, the scan response is ignored and not checked against the filter. This will lead to events being filtered wrongly. Change the code to actually only drop the events when the scan response data is not present. If it is present, it needs to be checked against the provided filter. The patch is a bit more complex than it needs to be. That is because it also fixes this compiler warning that some gcc versions produce. CC net/bluetooth/mgmt.o net/bluetooth/mgmt.c: In function ‘mgmt_device_found’: net/bluetooth/mgmt.c:7028:7: warning: ‘match’ may be used uninitialized in this function [-Wmaybe-uninitialized] bool match; ^ It seems that gcc can not clearly figure out the context of the match variable. So just change the branches for the extended inquiry response and advertising data around so that it is clear. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-17libceph: specify position of extent operationYan, Zheng
allow specifying position of extent operation in multi-operations osd request. This is required for cephfs to convert inline data to normal data (compare xattr, then write object). Signed-off-by: Yan, Zheng <zyan@redhat.com> Reviewed-by: Ilya Dryomov <idryomov@redhat.com>
2014-12-17libceph: add CREATE osd operation supportYan, Zheng
Add CEPH_OSD_OP_CREATE support. Also change libceph to not treat CEPH_OSD_OP_DELETE as an extent op and add an assert to that end. Signed-off-by: Yan, Zheng <zyan@redhat.com> Reviewed-by: Ilya Dryomov <idryomov@redhat.com>
2014-12-17libceph: add SETXATTR/CMPXATTR osd operations supportYan, Zheng
2014-12-17libceph: require cephx message signature by defaultYan, Zheng
2014-12-17libceph: message signature supportYan, Zheng
2014-12-17libceph: store session key in cephx authorizerYan, Zheng
Session key is required when calculating message signature. Save the session key in authorizer, this avoid lookup ticket handler for each message Signed-off-by: Yan, Zheng <zyan@redhat.com>
2014-12-17libceph: nuke ceph_kvfree()Ilya Dryomov
Use kvfree() from linux/mm.h instead, which is identical. Also fix the ceph_buffer comment: we will allocate with kmalloc() up to 32k - the value of PAGE_ALLOC_COSTLY_ORDER, but that really is just an implementation detail so don't mention it at all. Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
2014-12-17mac80211: free management frame keys when removing stationJohannes Berg
When writing the code to allow per-station GTKs, I neglected to take into account the management frame keys (index 4 and 5) when freeing the station and only added code to free the first four data frame keys. Fix this by iterating the array of keys over the right length. Cc: stable@vger.kernel.org Fixes: e31b82136d1a ("cfg80211/mac80211: allow per-station GTKs") Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #2 from Al Viro: "Next pile (and there'll be one or two more). The large piece in this one is getting rid of /proc/*/ns/* weirdness; among other things, it allows to (finally) make nameidata completely opaque outside of fs/namei.c, making for easier further cleanups in there" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coda_venus_readdir(): use file_inode() fs/namei.c: fold link_path_walk() call into path_init() path_init(): don't bother with LOOKUP_PARENT in argument fs/namei.c: new helper (path_cleanup()) path_init(): store the "base" pointer to file in nameidata itself make default ->i_fop have ->open() fail with ENXIO make nameidata completely opaque outside of fs/namei.c kill proc_ns completely take the targets of /proc/*/ns/* symlinks to separate fs bury struct proc_ns in fs/proc copy address of proc_ns_ops into ns_common new helpers: ns_alloc_inum/ns_free_inum make proc_ns_operations work with struct ns_common * instead of void * switch the rest of proc_ns_operations to working with &...->ns netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns common object embedded into various struct ....ns
2014-12-16Merge branch 'for-3.19' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "A comparatively quieter cycle for nfsd this time, but still with two larger changes: - RPC server scalability improvements from Jeff Layton (using RCU instead of a spinlock to find idle threads). - server-side NFSv4.2 ALLOCATE/DEALLOCATE support from Anna Schumaker, enabling fallocate on new clients" * 'for-3.19' of git://linux-nfs.org/~bfields/linux: (32 commits) nfsd4: fix xdr4 count of server in fs_location4 nfsd4: fix xdr4 inclusion of escaped char sunrpc/cache: convert to use string_escape_str() sunrpc: only call test_bit once in svc_xprt_received fs: nfsd: Fix signedness bug in compare_blob sunrpc: add some tracepoints around enqueue and dequeue of svc_xprt sunrpc: convert to lockless lookup of queued server threads sunrpc: fix potential races in pool_stats collection sunrpc: add a rcu_head to svc_rqst and use kfree_rcu to free it sunrpc: require svc_create callers to pass in meaningful shutdown routine sunrpc: have svc_wake_up only deal with pool 0 sunrpc: convert sp_task_pending flag to use atomic bitops sunrpc: move rq_cachetype field to better optimize space sunrpc: move rq_splice_ok flag into rq_flags sunrpc: move rq_dropme flag into rq_flags sunrpc: move rq_usedeferral flag to rq_flags sunrpc: move rq_local field to rq_flags sunrpc: add a generic rq_flags field to svc_rqst and move rq_secure to it nfsd: minor off by one checks in __write_versions() sunrpc: release svc_pool_map reference when serv allocation fails ...
2014-12-16net: Disallow providing non zero VLAN ID for NIC drivers FDB add flowOr Gerlitz
The current implementations all use dev_uc_add_excl() and such whose API doesn't support vlans, so we can't make it with NICs HW for now. Fixes: f6f6424ba773 ('net: make vid as a parameter for ndo_fdb_add/ndo_fdb_del') Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Reviewed-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-16ip_tunnel: Add missing validation of encap type to ip_tunnel_encap_setup()Thomas Graf
The encap->type comes straight from Netlink. Validate it against max supported encap types just like ip_encap_hlen() already does. Fixes: a8c5f9 ("ip_tunnel: Ops registration for secondary encap (fou, gue)") Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-16ip_tunnel: Add sanity checks to ip_tunnel_encap_add_ops()Thomas Graf
The symbols are exported and could be used by external modules. Fixes: a8c5f9 ("ip_tunnel: Ops registration for secondary encap (fou, gue)") Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-16Merge tag 'master-2014-12-15' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-12-16 Please pull this batch of fixes intended for the 3.19 stream! For the Bluetooth bits, Johan says: "The patches consist of: - Coccinelle warning fix - hci_dev_lock/unlock fixes - Fixes for pending mgmt command handling - Fixes for properly following the force_lesc_support switch - Fix for a Microsoft branded Broadcom adapter - New device id for Atheros AR3012 - Fix for BR/EDR Secure Connections enabling" Along with that... Brian Norris avoids leaking some kernel memory contents via printk in brcmsmac. Julia Lawall corrects some misspellings in a few drivers. Larry Finger gives us one more rtlwifi fix to correct a porting oversight. Wei Yongjun fixes a sparse warning in rtlwifi. Please let me know if there are problems! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-15Merge branch 'for-upstream' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
2014-12-15rds: Fix min() warning in rds_message_inc_copy_to_user()Geert Uytterhoeven
net/rds/message.c: In function ‘rds_message_inc_copy_to_user’: net/rds/message.c:328: warning: comparison of distinct pointer types lacks a cast Use min_t(unsigned long, ...) like is done in rds_message_copy_from_user(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-15gre: fix the inner mac header in nbma tunnel xmit pathTimo Teräs
The NBMA GRE tunnels temporarily push GRE header that contain the per-packet NBMA destination on the skb via header ops early in xmit path. It is the later pulled before the real GRE header is constructed. The inner mac was thus set differently in nbma case: the GRE header has been pushed by neighbor layer, and mac header points to beginning of the temporary gre header (set by dev_queue_xmit). Now that the offloads expect mac header to point to the gre payload, fix the xmit patch to: - pull first the temporary gre header away - and reset mac header to point to gre payload This fixes tso to work again with nbma tunnels. Fixes: 14051f0452a2 ("gre: Use inner mac length when computing tunnel length") Signed-off-by: Timo Teräs <timo.teras@iki.fi> Cc: Tom Herbert <therbert@google.com> Cc: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - The crypto API is now documented :) - Disallow arbitrary module loading through crypto API. - Allow get request with empty driver name through crypto_user. - Allow speed testing of arbitrary hash functions. - Add caam support for ctr(aes), gcm(aes) and their derivatives. - nx now supports concurrent hashing properly. - Add sahara support for SHA1/256. - Add ARM64 version of CRC32. - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (77 commits) crypto: tcrypt - Allow speed testing of arbitrary hash functions crypto: af_alg - add user space interface for AEAD crypto: qat - fix problem with coalescing enable logic crypto: sahara - add support for SHA1/256 crypto: sahara - replace tasklets with kthread crypto: sahara - add support for i.MX53 crypto: sahara - fix spinlock initialization crypto: arm - replace memset by memzero_explicit crypto: powerpc - replace memset by memzero_explicit crypto: sha - replace memset by memzero_explicit crypto: sparc - replace memset by memzero_explicit crypto: algif_skcipher - initialize upon init request crypto: algif_skcipher - removed unneeded code crypto: algif_skcipher - Fixed blocking recvmsg crypto: drbg - use memzero_explicit() for clearing sensitive data crypto: drbg - use MODULE_ALIAS_CRYPTO crypto: include crypto- module prefix in template crypto: user - add MODULE_ALIAS crypto: sha-mb - remove a bogus NULL check crytpo: qat - Fix 64 bytes requests ...
2014-12-12fib_trie: Fix trie balancing issue if new node pushes down existing nodeAlexander Duyck
This patch addresses an issue with the level compression of the fib_trie. Specifically in the case of adding a new leaf that triggers a new node to be added that takes the place of the old node. The result is a trie where the 1 child tnode is on one side and one leaf is on the other which gives you a very deep trie. Below is the script I used to generate a trie on dummy0 with a 10.X.X.X family of addresses. ip link add type dummy ipval=184549374 bit=2 for i in `seq 1 23` do ifconfig dummy0:$bit $ipval/8 ipval=`expr $ipval - $bit` bit=`expr $bit \* 2` done cat /proc/net/fib_triestat Running the script before the patch: Local: Aver depth: 10.82 Max depth: 23 Leaves: 29 Prefixes: 30 Internal nodes: 27 1: 26 2: 1 Pointers: 56 Null ptrs: 1 Total size: 5 kB After applying the patch and repeating: Local: Aver depth: 4.72 Max depth: 9 Leaves: 29 Prefixes: 30 Internal nodes: 12 1: 3 2: 2 3: 7 Pointers: 70 Null ptrs: 30 Total size: 4 kB What this fix does is start the rebalance at the newly created tnode instead of at the parent tnode. This way if there is a gap between the parent and the new node it doesn't prevent the new tnode from being coalesced with any pre-existing nodes that may have been pushed into one of the new nodes child branches. Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-12vlan: Add ability to always enable TSO/UFOToshiaki Makita
Since the real device can segment packets by software, a vlan device can set TSO/UFO even when the real device doesn't have those features. Unlike GSO, this allows packets to be segmented after Qdisc. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-12cfg80211: correctly check ad-hoc channelsArik Nemtsov
Ad-hoc requires beaconing for regulatory purposes. Validate that the channel is valid for beaconing, and not only enabled. Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Reviewed-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-12cfg80211: don't WARN about two consecutive Country IE hintEmmanuel Grumbach
This can happen and there is no point in added more detection code lower in the stack. Catching these in one single point (cfg80211) is enough. Stop WARNING about this case. This fixes: https://bugzilla.kernel.org/show_bug.cgi?id=89001 Cc: stable@vger.kernel.org Fixes: 2f1c6c572d7b ("cfg80211: process non country IE conflicting first") Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-12Bluetooth: Fix mgmt response status when removing adapterJohan Hedberg
When an adapter is removed (hci_unregister_dev) any pending mgmt commands for that adapter should get the appropriate INVALID_INDEX response. Since hci_unregister_dev() calls hci_dev_do_close() first that'd so far have caused "not powered" responses to be sent. Skipping the HCI_UNREGISTER case in mgmt_powered() is also not a solution since before reaching the mgmt_index_removed() stage any hci_conn callbacks (e.g. used by pairing) will get called, thereby causing "disconnected" status responses to be sent. The fix that covers all scenarios is to handle both INVALID_INDEX and NOT_POWERED responses through the mgmt_powered() function. The INVALID_INDEX response sending from mgmt_index_removed() is left untouched since there are a couple of places not related to powering off or removing an adapter that call it (e.g. configuring a new bdaddr). Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-12-12Bluetooth: Fix enabling BR/EDR SC when powering onJohan Hedberg
If we're in the AUTO_OFF stage the powered_update_hci() function is responsible for doing the updates to the HCI state that were not done during the actual mgmt command handlers. One of the updates needing done is for BR/EDR SC support. This patch adds the missing HCI command for SC support to the powered_update_hci() function. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-12-12mac80211: update the channel context after channel switchEmmanuel Grumbach
When the channel switch has been made, a vif is now using the channel context which was reserved. When that happens, we need to update the channel context since its parameters may change. I hit a case in which I switched to a 40Mhz channel but the reserved channel context was still on 20Mhz. The rate control would try to send 40Mhz packets on a 20Mhz channel context and that made iwlwifi's firmware unhappy. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-12nl80211: check matches array length before acessing itLuciano Coelho
If the userspace passes a malformed sched scan request (or a net detect wowlan configuration) by adding a NL80211_ATTR_SCHED_SCAN_MATCH attribute without any nested matchsets, a NULL pointer dereference will occur. Fix this by checking that we do have matchsets in our array before trying to access it. BUG: unable to handle kernel NULL pointer dereference at 0000000000000024 IP: [<ffffffffa002fd69>] nl80211_parse_sched_scan.part.67+0x6e9/0x900 [cfg80211] PGD 865c067 PUD 865b067 PMD 0 Oops: 0002 [#1] SMP Modules linked in: iwlmvm(O) iwlwifi(O) mac80211(O) cfg80211(O) compat(O) [last unloaded: compat] CPU: 2 PID: 2442 Comm: iw Tainted: G O 3.17.2 #31 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff880013800790 ti: ffff880008d80000 task.ti: ffff880008d80000 RIP: 0010:[<ffffffffa002fd69>] [<ffffffffa002fd69>] nl80211_parse_sched_scan.part.67+0x6e9/0x900 [cfg80211] RSP: 0018:ffff880008d838d0 EFLAGS: 00010293 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 000000000000143c RSI: 0000000000000000 RDI: ffff880008ee8dd0 RBP: ffff880008d83948 R08: 0000000000000002 R09: 0000000000000019 R10: ffff88001d1b3c40 R11: 0000000000000002 R12: ffff880019e85e00 R13: 00000000fffffed4 R14: ffff880009757800 R15: 0000000000001388 FS: 00007fa3b6d13700(0000) GS:ffff88003e200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000024 CR3: 0000000008670000 CR4: 00000000000006e0 Stack: ffff880009757800 ffff880000000001 0000000000000000 ffff880008ee84e0 0000000000000000 ffff880009757800 00000000fffffed4 ffff880008d83948 ffffffff814689c9 ffff880009757800 ffff880008ee8000 0000000000000000 Call Trace: [<ffffffff814689c9>] ? nla_parse+0xb9/0x120 [<ffffffffa00306de>] nl80211_set_wowlan+0x75e/0x960 [cfg80211] [<ffffffff810bf3d5>] ? mark_held_locks+0x75/0xa0 [<ffffffff8161a77b>] genl_family_rcv_msg+0x18b/0x360 [<ffffffff810bf66d>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff8161a9d4>] genl_rcv_msg+0x84/0xc0 [<ffffffff8161a950>] ? genl_family_rcv_msg+0x360/0x360 [<ffffffff81618e79>] netlink_rcv_skb+0xa9/0xd0 [<ffffffff81619458>] genl_rcv+0x28/0x40 [<ffffffff816184a5>] netlink_unicast+0x105/0x180 [<ffffffff8161886f>] netlink_sendmsg+0x34f/0x7a0 [<ffffffff8105a097>] ? kvm_clock_read+0x27/0x40 [<ffffffff815c644d>] sock_sendmsg+0x8d/0xc0 [<ffffffff811a75c9>] ? might_fault+0xb9/0xc0 [<ffffffff811a756e>] ? might_fault+0x5e/0xc0 [<ffffffff815d5d26>] ? verify_iovec+0x56/0xe0 [<ffffffff815c73e0>] ___sys_sendmsg+0x3d0/0x3e0 [<ffffffff810a7be8>] ? sched_clock_cpu+0x98/0xd0 [<ffffffff810611b4>] ? __do_page_fault+0x254/0x580 [<ffffffff810bb39f>] ? up_read+0x1f/0x40 [<ffffffff810611b4>] ? __do_page_fault+0x254/0x580 [<ffffffff812146ed>] ? __fget_light+0x13d/0x160 [<ffffffff815c7b02>] __sys_sendmsg+0x42/0x80 [<ffffffff815c7b52>] SyS_sendmsg+0x12/0x20 [<ffffffff81751f69>] system_call_fastpath+0x16/0x1b Fixes: ea73cbce4e1f ("nl80211: fix scheduled scan RSSI matchset attribute confusion") Cc: stable@vger.kernel.org [3.15+] Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-12cfg80211: avoid mem leak on driver hint setArik Nemtsov
In the already-set and intersect case of a driver-hint, the previous wiphy regdomain was not freed before being reset with a copy of the cfg80211 regdomain. Cc: stable@vger.kernel.org Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Acked-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-12cfg80211: Fix 160 MHz channels with 80+80 and 160 MHz driversJouni Malinen
The VHT supported channel width field is a two bit integer, not a bitfield. cfg80211_chandef_usable() was interpreting it incorrectly and ended up rejecting 160 MHz channel width if the driver indicated support for both 160 and 80+80 MHz channels. Cc: stable@vger.kernel.org (3.16+) Fixes: 3d9d1d6656a73 ("nl80211/cfg80211: support VHT channel configuration") (however, no real drivers had 160 MHz support it until 3.16) Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-12mac80211: fix multicast LED blinking and counterAndreas Müller
As multicast-frames can't be fragmented, "dot11MulticastReceivedFrameCount" stopped being incremented after the use-after-free fix. Furthermore, the RX-LED will be triggered by every multicast frame (which wouldn't happen before) which wouldn't allow the LED to rest at all. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=89431 which also had the patch. Cc: stable@vger.kernel.org Fixes: b8fff407a180 ("mac80211: fix use-after-free in defragmentation") Signed-off-by: Andreas Müller <goo@stapelspeicher.org> [rewrite commit message] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-12mac80211: avoid using uninitialized stack dataJes Sorensen
Avoid a case where we would access uninitialized stack data if the AP advertises HT support without 40MHz channel support. Cc: stable@vger.kernel.org Fixes: f3000e1b43f1 ("mac80211: fix broken use of VHT/20Mhz with some APs") Signed-off-by: Jes Sorensen <Jes.Sorensen@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-11net: dsa: propagate error code from dsa_slave_phy_setupFlorian Fainelli
In case we cannot attach to our slave netdevice PHY, error out and propagate that error up to the caller: dsa_slave_create(). Fixes: 0d8bcdd383b8 ("net: dsa: allow for more complex PHY setups") Signed-off-by: Andrey Volkov <andrey.volkov@nexvision.fr> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-11net: dsa: handle non-existing PHYs on switch internal busFlorian Fainelli
In case there is no PHY at the designated address on the internal switch, we would basically de-reference a null pointer here: dsa_slave_phy_setup(...) { p->phy = ds->slave_mii_bus->phy_map[p->port]; phy_connect_direct(slave_dev, p->phy, dsa_slave_adjust_link, ^------ This can be triggered when the platform configuration (platform_data or Device Tree) indicates there should be a PHY device at this address, but the HW is non-responsive, such that we cannot attach a PHY device at this specific location. Fix this by checking the return value prior to calling phy_connect_direct(). CC: Andrew Lunn <andrew@lunn.ch> Fixes: b31f65fb4383 ("net: dsa: slave: Fix autoneg for phys on switch MDIO bus") Reported-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Andrey Volkov <andrey.volkov@nexvision.fr> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) New offloading infrastructure and example 'rocker' driver for offloading of switching and routing to hardware. This work was done by a large group of dedicated individuals, not limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend, Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu 2) Start making the networking operate on IOV iterators instead of modifying iov objects in-situ during transfers. Thanks to Al Viro and Herbert Xu. 3) A set of new netlink interfaces for the TIPC stack, from Richard Alpe. 4) Remove unnecessary looping during ipv6 routing lookups, from Martin KaFai Lau. 5) Add PAUSE frame generation support to gianfar driver, from Matei Pavaluca. 6) Allow for larger reordering levels in TCP, which are easily achievable in the real world right now, from Eric Dumazet. 7) Add a variable of napi_schedule that doesn't need to disable cpu interrupts, from Eric Dumazet. 8) Use a doubly linked list to optimize neigh_parms_release(), from Nicolas Dichtel. 9) Various enhancements to the kernel BPF verifier, and allow eBPF programs to actually be attached to sockets. From Alexei Starovoitov. 10) Support TSO/LSO in sunvnet driver, from David L Stevens. 11) Allow controlling ECN usage via routing metrics, from Florian Westphal. 12) Remote checksum offload, from Tom Herbert. 13) Add split-header receive, BQL, and xmit_more support to amd-xgbe driver, from Thomas Lendacky. 14) Add MPLS support to openvswitch, from Simon Horman. 15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen Klassert. 16) Do gro flushes on a per-device basis using a timer, from Eric Dumazet. This tries to resolve the conflicting goals between the desired handling of bulk vs. RPC-like traffic. 17) Allow userspace to ask for the CPU upon what a packet was received/steered, via SO_INCOMING_CPU. From Eric Dumazet. 18) Limit GSO packets to half the current congestion window, from Eric Dumazet. 19) Add a generic helper so that all drivers set their RSS keys in a consistent way, from Eric Dumazet. 20) Add xmit_more support to enic driver, from Govindarajulu Varadarajan. 21) Add VLAN packet scheduler action, from Jiri Pirko. 22) Support configurable RSS hash functions via ethtool, from Eyal Perry. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits) Fix race condition between vxlan_sock_add and vxlan_sock_release net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header net/mlx4: Add support for A0 steering net/mlx4: Refactor QUERY_PORT net/mlx4_core: Add explicit error message when rule doesn't meet configuration net/mlx4: Add A0 hybrid steering net/mlx4: Add mlx4_bitmap zone allocator net/mlx4: Add a check if there are too many reserved QPs net/mlx4: Change QP allocation scheme net/mlx4_core: Use tasklet for user-space CQ completion events net/mlx4_core: Mask out host side virtualization features for guests net/mlx4_en: Set csum level for encapsulated packets be2net: Export tunnel offloads only when a VxLAN tunnel is created gianfar: Fix dma check map error when DMA_API_DEBUG is enabled cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call net: fec: only enable mdio interrupt before phy device link up net: fec: clear all interrupt events to support i.MX6SX net: fec: reset fep link status in suspend function net: sock: fix access via invalid file descriptor net: introduce helper macro for_each_cmsghdr ...
2014-12-11Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio updates from Michael Tsirkin: "virtio: virtio 1.0 support, misc patches This adds a lot of infrastructure for virtio 1.0 support. Notable missing pieces: virtio pci, virtio balloon (needs spec extension), vhost scsi. Plus, there are some minor fixes in a couple of places. Note: some net drivers are affected by these patches. David said he's fine with merging these patches through my tree. Rusty's on vacation, he acked using my tree for these, too" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: (70 commits) virtio_ccw: finalize_features error handling virtio_ccw: future-proof finalize_features virtio_pci: rename virtio_pci -> virtio_pci_common virtio_pci: update file descriptions and copyright virtio_pci: split out legacy device support virtio_pci: setup config vector indirectly virtio_pci: setup vqs indirectly virtio_pci: delete vqs indirectly virtio_pci: use priv for vq notification virtio_pci: free up vq->priv virtio_pci: fix coding style for structs virtio_pci: add isr field virtio: drop legacy_only driver flag virtio_balloon: drop legacy_only driver flag virtio_ccw: rev 1 devices set VIRTIO_F_VERSION_1 virtio: allow finalize_features to fail virtio_ccw: legacy: don't negotiate rev 1/features virtio: add API to detect legacy devices virtio_console: fix sparse warnings vhost: remove unnecessary forward declarations in vhost.h ...
2014-12-11Bluetooth: Fix notifying mgmt power off before flushing connection listJohan Hedberg
This patch moves the mgmt_powered() notification earlier in the hci_dev_do_close() function. This way the correct "not powered" error gets passed to any pending mgmt commands. Without the patch the pending commands would instead get a misleading "disconnected" response when powering down the adapter. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-12-11Bluetooth: Fix incorrect pending cmd removal in pairing_complete()Johan Hedberg
The pairing_complete() function is used as a pending mgmt command cmd_complete callback. The expectation of such functions is that they are not responsible themselves for calling mgmt_pending_remove(). This patch fixes the incorrect mgmt_pending_remove() call in pairing_complete() and adds it to the appropriate changes. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-12-11Bluetooth: Fix calling hci_conn_put too earlyJohan Hedberg
The pairing_complete() function relies on a hci_conn reference to be able to access the hci_conn object. It should therefore only release this reference once it's done accessing the object, i.e. at the end of the function. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-12-11Bluetooth: Fix check for support for page scan related commandsMarcel Holtmann
The Read Page Scan Activity and Read Page Scan Type commands are not supported by all controllers. Move the execution of both commands into the 3rd phase of the init procedure. And then check the bit mask of supported commands before adding them to the init sequence. With this re-ordering of the init sequence, the extra check for AVM BlueFritz! controllers is no longer needed. They will report that these two commands are not supported. This fixes an issue with the Microsoft Corp. Wireless Transceiver for Bluetooth 2.0 (ID 045e:009c). Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
