commit 52bd2d62ce6758d811edcbd2256eb9ea7f6a56cb upstream.
skb->sender_cpu and skb->napi_id share a common storage,
and we had various bugs about this.
We had to call skb_sender_cpu_clear() in some places to
not leave a prior skb->napi_id and fool netdev_pick_tx()
As suggested by Alexei, we could split the space so that
these errors can not happen.
0 value being reserved as the common (not initialized) value,
let's reserve [1 .. NR_CPUS] range for valid sender_cpu,
and [NR_CPUS+1 .. ~0U] for valid napi_id.
This will allow proper busy polling support over tunnels.
Suggested-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Cc: Paul Menzel <pmenzel@molgen.mpg.de>
[ Upstream commit aeb073241fe7a2b932e04e20c60e47718332877f ]
When the transition of NO_STP -> KERNEL_STP was fixed by always calling
mod_timer in br_stp_start, it introduced a new regression which causes
the timer to be armed even when the bridge is down, and since we stop
the timers in its ndo_stop() function, they never get disabled if the
device is destroyed before it's upped.
To reproduce:
$ while :; do ip l add br0 type bridge hello_time 100; brctl stp br0 on;
ip l del br0; done;
CC: Xin Long <lucien.xin@gmail.com>
CC: Ivan Vecera <cera@cera.cz>
CC: Sebastian Ott <sebott@linux.vnet.ibm.com>
Reported-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Fixes: 6d18c732b95c ("bridge: start hello_timer when enabling KERNEL_STP in br_stp_start")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 77d4b1d36926a9b8387c6b53eeba42bcaaffcea3 ]
Alexander reported various KASAN messages triggered in recent kernels
The problem is that ping sockets should not use udp_poll() in the first
place, and recent changes in UDP stack finally exposed this old bug.
Fixes: c319b4d76b9e ("net: ipv4: add IPPROTO_ICMP socket kind")
Fixes: 6d0bfe226116 ("net: ipv6: Add IPv6 support to the ping socket.")
Reported-by: Sasha Levin <alexander.levin@verizon.com>
Cc: Solar Designer <solar@openwall.com>
Cc: Vasiliy Kulikov <segoon@openwall.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
Acked-By: Lorenzo Colitti <lorenzo@google.com>
Tested-By: Lorenzo Colitti <lorenzo@google.com>
[ Upstream commit e3e86b5119f81e5e2499bea7ea1ebe8ac6aab789 ]
If ip6_find_1stfragopt() fails and we return an error we have to free
up 'segs' because nobody else is going to.
Fixes: 2423496af35d ("ipv6: Prevent overrun when parsing v6 header options")
Reported-by: Ben Hutchings <ben@decadent.org.uk>
[ Upstream commit 44abafc4cc094214a99f860f778c48ecb23422fc ]
When the sender switches its congestion control during loss
recovery, if the recovery is spurious then it may incorrectly
revert cwnd and ssthresh to the older values set by a previous
congestion control. Consider a congestion control (like BBR)
that does not use ssthresh and keeps it infinite: the connection
may incorrectly revert cwnd to an infinite value when switching
from BBR to another congestion control.
This patch fixes it by disallowing such cwnd undo operation
upon switching congestion control. Note that undo_marker
is not reset s.t. the packets that were incorrectly marked
lost would be corrected. We only avoid undoing the cwnd in
tcp_undo_cwnd_reduction().
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 6e80ac5cc992ab6256c3dae87f7e57db15e1a58c ]
xfrm6_find_1stfragopt() may now return an error code and we must
not treat it as a length.
Acked-by: Craig Gallek <kraig@google.com>
commit f6ba8d33cfbb46df569972e64dbb5bb7e929bfd9 upstream.
I should have known that lowering skb->truesize was dangerous :/
In case packets are not leaving the host via a standard Ethernet device,
but looped back to local sockets, bad things can happen, as reported
by Michael Madsen ( https://bugzilla.kernel.org/show_bug.cgi?id=195713 )
So instead of tweaking skb->truesize, lets change skb->destructor
and keep a reference on the owner socket via its sk_refcnt.
Fixes: f2f872f9272a ("netem: Introduce skb_orphan_partial() helper")
Reported-by: Michael Madsen <mkm@nabto.com>
[ Upstream commit 3fb07daff8e99243366a081e5129560734de4ada ]
Andrey Konovalov reported crashes in ipv4_mtu()
I could reproduce the issue with KASAN kernels, between
10.246.7.151 and 10.246.7.152 :
1) 20 concurrent netperf -t TCP_RR -H 10.246.7.152 -l 1000 &
2) At the same time run following loop :
while :
do
ip ro add 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500
ip ro del 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500
done
Cong Wang attempted to add back rt->fi in commit
82486aa6f1b9 ("ipv4: restore rt->fi for reference counting")
but this proved to add some issues that were complex to solve.
Instead, I suggested to add a refcount to the metrics themselves,
being a standalone object (in particular, no reference to other objects)
I tried to make this patch as small as possible to ease its backport,
instead of being super clean. Note that we believe that only ipv4 dst
need to take care of the metric refcount. But if this is wrong,
this patch adds the basic infrastructure to extend this to other
families.
Many thanks to Julian Anastasov for reviewing this patch, and Cong Wang
for his efforts on this problem.
Fixes: 2860583fe840 ("ipv4: Kill rt->fi")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Reviewed-by: Julian Anastasov <ja@ssi.bg>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 804ec7ebe8ea003999ca8d1bfc499edc6a9e07df ]
sometimes ICMP replies to INIT chunks are ignored by the client, even if
the encapsulated SCTP headers match an open socket. This happens when the
ICMP packet is carried by a paged skb: use skb_header_pointer() to read
packet contents beyond the SCTP header, so that chunk header and initiate
tag are validated correctly.
v2:
- don't use skb_header_pointer() to read the transport header, since
icmp_socket_deliver() already puts these 8 bytes in the linear area.
- change commit message to make specific reference to INIT chunks.
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Reviewed-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit ba615f675281d76fd19aa03558777f81fb6b6084 ]
Fastopen API should be used to perform fastopen operations on the TCP
socket. It does not make sense to use fastopen API to perform disconnect
by calling it with AF_UNSPEC. The fastopen data path is also prone to
race conditions and bugs when using with AF_UNSPEC.
One issue reported and analyzed by Vegard Nossum is as follows:
Thread A: Thread B:
sendto()
- tcp_sendmsg()
- sk_stream_memory_free() = 0
- goto wait_for_sndbuf
- sk_stream_wait_memory()
- sk_wait_event() // sleep
| sendto(flags=MSG_FASTOPEN, dest_addr=AF_UNSPEC)
| - tcp_sendmsg()
| - tcp_sendmsg_fastopen()
| - __inet_stream_connect()
| - tcp_disconnect() //because of AF_UNSPEC
| - tcp_transmit_skb()// send RST
| - return 0; // no reconnect!
| - sk_stream_wait_connect()
| - sock_error()
| - xchg(&sk->sk_err, 0)
| - return -ECONNRESET
- ... // wake up, see sk->sk_err == 0
- skb_entail() on TCP_CLOSE socket
If the connection is reopened then we will send a brand new SYN packet
after thread A has already queued a buffer. At this point I think the
socket internal state (sequence numbers etc.) becomes messed up.
When the new connection is closed, the FIN-ACK is rejected because the
sequence number is outside the window. The other side tries to
retransmit,
but __tcp_retransmit_skb() calls tcp_trim_head() on an empty skb which
corrupts the skb data length and hits a BUG() in copy_and_csum_bits().
Hence, this patch adds a check for AF_UNSPEC in the fastopen data path
and return EOPNOTSUPP to user if such case happens.
Fixes: cf60af03ca4e7 ("tcp: Fast Open client - sendmsg(MSG_FASTOPEN)")
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Signed-off-by: Wei Wang <weiwan@google.com>
[ Upstream commit 232cd35d0804cc241eb887bb8d4d9b3b9881c64a ]
Andrey Konovalov and idaifish@gmail.com reported crashes caused by
one skb shared_info being overwritten from __ip6_append_data()
Andrey program lead to following state :
copy -4200 datalen 2000 fraglen 2040
maxfraglen 2040 alloclen 2048 transhdrlen 0 offset 0 fraggap 6200
The skb_copy_and_csum_bits(skb_prev, maxfraglen, data + transhdrlen,
fraggap, 0); is overwriting skb->head and skb_shared_info
Since we apparently detect this rare condition too late, move the
code earlier to even avoid allocating skb and risking crashes.
Once again, many thanks to Andrey and syzkaller team.
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Reported-by: <idaifish@gmail.com>
[ Upstream commit 6d18c732b95c0a9d35e9f978b4438bba15412284 ]
Since commit 76b91c32dd86 ("bridge: stp: when using userspace stp stop
kernel hello and hold timers"), bridge would not start hello_timer if
stp_enabled is not KERNEL_STP when br_dev_open.
The problem is even if users set stp_enabled with KERNEL_STP later,
the timer will still not be started. It causes that KERNEL_STP can
not really work. Users have to re-ifup the bridge to avoid this.
This patch is to fix it by starting br->hello_timer when enabling
KERNEL_STP in br_stp_start.
As an improvement, it's also to start hello_timer again only when
br->stp_enabled is KERNEL_STP in br_hello_timer_expired, there is
no reason to start the timer again when it's NO_STP.
Fixes: 76b91c32dd86 ("bridge: stp: when using userspace stp stop kernel hello and hold timers")
Reported-by: Haidong Li <haili@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Reviewed-by: Ivan Vecera <cera@cera.cz>
[ Upstream commit a285860211bf257b0e6d522dac6006794be348af ]
Currently it is allowed to set the default pvid of a bridge to a value
above VLAN_VID_MASK (0xfff). This patch adds a check to br_validate and
returns -EINVAL in case the pvid is out of bounds.
Reproduce by calling:
[root@test ~]# ip l a type bridge
[root@test ~]# ip l a type dummy
[root@test ~]# ip l s bridge0 type bridge vlan_filtering 1
[root@test ~]# ip l s bridge0 type bridge vlan_default_pvid 9999
[root@test ~]# ip l s dummy0 master bridge0
[root@test ~]# bridge vlan
port vlan ids
bridge0 9999 PVID Egress Untagged
dummy0 9999 PVID Egress Untagged
Fixes: 0f963b7592ef ("bridge: netlink: add support for default_pvid")
Signed-off-by: Tobias Jungel <tobias.jungel@bisdn.de>
Acked-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit 7dd7eb9513bd02184d45f000ab69d78cb1fa1531 ]
Do not use unsigned variables to see if it returns a negative
error or not.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
[ Upstream commit 2423496af35d94a87156b063ea5cedffc10a70a1 ]
The KASAN warning repoted below was discovered with a syzkaller
program. The reproducer is basically:
int s = socket(AF_INET6, SOCK_RAW, NEXTHDR_HOP);
send(s, &one_byte_of_data, 1, MSG_MORE);
send(s, &more_than_mtu_bytes_data, 2000, 0);
The socket() call sets the nexthdr field of the v6 header to
NEXTHDR_HOP, the first send call primes the payload with a non zero
byte of data, and the second send call triggers the fragmentation path.
The fragmentation code tries to parse the header options in order
to figure out where to insert the fragment option. Since nexthdr points
to an invalid option, the calculation of the size of the network header
can made to be much larger than the linear section of the skb and data
is read outside of it.
This fix makes ip6_find_1stfrag return an error if it detects
running out-of-bounds.
[ 42.361487] ==================================================================
[ 42.364412] BUG: KASAN: slab-out-of-bounds in ip6_fragment+0x11c8/0x3730
[ 42.365471] Read of size 840 at addr ffff88000969e798 by task ip6_fragment-oo/3789
[ 42.366469]
[ 42.366696] CPU: 1 PID: 3789 Comm: ip6_fragment-oo Not tainted 4.11.0+ #41
[ 42.367628] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.1-1ubuntu1 04/01/2014
[ 42.368824] Call Trace:
[ 42.369183] dump_stack+0xb3/0x10b
[ 42.369664] print_address_description+0x73/0x290
[ 42.370325] kasan_report+0x252/0x370
[ 42.370839] ? ip6_fragment+0x11c8/0x3730
[ 42.371396] check_memory_region+0x13c/0x1a0
[ 42.371978] memcpy+0x23/0x50
[ 42.372395] ip6_fragment+0x11c8/0x3730
[ 42.372920] ? nf_ct_expect_unregister_notifier+0x110/0x110
[ 42.373681] ? ip6_copy_metadata+0x7f0/0x7f0
[ 42.374263] ? ip6_forward+0x2e30/0x2e30
[ 42.374803] ip6_finish_output+0x584/0x990
[ 42.375350] ip6_output+0x1b7/0x690
[ 42.375836] ? ip6_finish_output+0x990/0x990
[ 42.376411] ? ip6_fragment+0x3730/0x3730
[ 42.376968] ip6_local_out+0x95/0x160
[ 42.377471] ip6_send_skb+0xa1/0x330
[ 42.377969] ip6_push_pending_frames+0xb3/0xe0
[ 42.378589] rawv6_sendmsg+0x2051/0x2db0
[ 42.379129] ? rawv6_bind+0x8b0/0x8b0
[ 42.379633] ? _copy_from_user+0x84/0xe0
[ 42.380193] ? debug_check_no_locks_freed+0x290/0x290
[ 42.380878] ? ___sys_sendmsg+0x162/0x930
[ 42.381427] ? rcu_read_lock_sched_held+0xa3/0x120
[ 42.382074] ? sock_has_perm+0x1f6/0x290
[ 42.382614] ? ___sys_sendmsg+0x167/0x930
[ 42.383173] ? lock_downgrade+0x660/0x660
[ 42.383727] inet_sendmsg+0x123/0x500
[ 42.384226] ? inet_sendmsg+0x123/0x500
[ 42.384748] ? inet_recvmsg+0x540/0x540
[ 42.385263] sock_sendmsg+0xca/0x110
[ 42.385758] SYSC_sendto+0x217/0x380
[ 42.386249] ? SYSC_connect+0x310/0x310
[ 42.386783] ? __might_fault+0x110/0x1d0
[ 42.387324] ? lock_downgrade+0x660/0x660
[ 42.387880] ? __fget_light+0xa1/0x1f0
[ 42.388403] ? __fdget+0x18/0x20
[ 42.388851] ? sock_common_setsockopt+0x95/0xd0
[ 42.389472] ? SyS_setsockopt+0x17f/0x260
[ 42.390021] ? entry_SYSCALL_64_fastpath+0x5/0xbe
[ 42.390650] SyS_sendto+0x40/0x50
[ 42.391103] entry_SYSCALL_64_fastpath+0x1f/0xbe
[ 42.391731] RIP: 0033:0x7fbbb711e383
[ 42.392217] RSP: 002b:00007ffff4d34f28 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
[ 42.393235] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007fbbb711e383
[ 42.394195] RDX: 0000000000001000 RSI: 00007ffff4d34f60 RDI: 0000000000000003
[ 42.395145] RBP: 0000000000000046 R08: 00007ffff4d34f40 R09: 0000000000000018
[ 42.396056] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000400aad
[ 42.396598] R13: 0000000000000066 R14: 00007ffff4d34ee0 R15: 00007fbbb717af00
[ 42.397257]
[ 42.397411] Allocated by task 3789:
[ 42.397702] save_stack_trace+0x16/0x20
[ 42.398005] save_stack+0x46/0xd0
[ 42.398267] kasan_kmalloc+0xad/0xe0
[ 42.398548] kasan_slab_alloc+0x12/0x20
[ 42.398848] __kmalloc_node_track_caller+0xcb/0x380
[ 42.399224] __kmalloc_reserve.isra.32+0x41/0xe0
[ 42.399654] __alloc_skb+0xf8/0x580
[ 42.400003] sock_wmalloc+0xab/0xf0
[ 42.400346] __ip6_append_data.isra.41+0x2472/0x33d0
[ 42.400813] ip6_append_data+0x1a8/0x2f0
[ 42.401122] rawv6_sendmsg+0x11ee/0x2db0
[ 42.401505] inet_sendmsg+0x123/0x500
[ 42.401860] sock_sendmsg+0xca/0x110
[ 42.402209] ___sys_sendmsg+0x7cb/0x930
[ 42.402582] __sys_sendmsg+0xd9/0x190
[ 42.402941] SyS_sendmsg+0x2d/0x50
[ 42.403273] entry_SYSCALL_64_fastpath+0x1f/0xbe
[ 42.403718]
[ 42.403871] Freed by task 1794:
[ 42.404146] save_stack_trace+0x16/0x20
[ 42.404515] save_stack+0x46/0xd0
[ 42.404827] kasan_slab_free+0x72/0xc0
[ 42.405167] kfree+0xe8/0x2b0
[ 42.405462] skb_free_head+0x74/0xb0
[ 42.405806] skb_release_data+0x30e/0x3a0
[ 42.406198] skb_release_all+0x4a/0x60
[ 42.406563] consume_skb+0x113/0x2e0
[ 42.406910] skb_free_datagram+0x1a/0xe0
[ 42.407288] netlink_recvmsg+0x60d/0xe40
[ 42.407667] sock_recvmsg+0xd7/0x110
[ 42.408022] ___sys_recvmsg+0x25c/0x580
[ 42.408395] __sys_recvmsg+0xd6/0x190
[ 42.408753] SyS_recvmsg+0x2d/0x50
[ 42.409086] entry_SYSCALL_64_fastpath+0x1f/0xbe
[ 42.409513]
[ 42.409665] The buggy address belongs to the object at ffff88000969e780
[ 42.409665] which belongs to the cache kmalloc-512 of size 512
[ 42.410846] The buggy address is located 24 bytes inside of
[ 42.410846] 512-byte region [ffff88000969e780, ffff88000969e980)
[ 42.411941] The buggy address belongs to the page:
[ 42.412405] page:ffffea000025a780 count:1 mapcount:0 mapping: (null) index:0x0 compound_mapcount: 0
[ 42.413298] flags: 0x100000000008100(slab|head)
[ 42.413729] raw: 0100000000008100 0000000000000000 0000000000000000 00000001800c000c
[ 42.414387] raw: ffffea00002a9500 0000000900000007 ffff88000c401280 0000000000000000
[ 42.415074] page dumped because: kasan: bad access detected
[ 42.415604]
[ 42.415757] Memory state around the buggy address:
[ 42.416222] ffff88000969e880: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 42.416904] ffff88000969e900: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 42.417591] >ffff88000969e980: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 42.418273] ^
[ 42.418588] ffff88000969ea00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 42.419273] ffff88000969ea80: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 42.419882] ==================================================================
Signed-off-by: Craig Gallek <kraig@google.com>
[ Upstream commit f6c5775ff0bfa62b072face6bf1d40f659f194b2 ]
In general, rtnetlink dumps do not anticipate failure to dump a single
object (e.g., link or route) on a single pass. As both route and link
objects have grown via more attributes, that is no longer a given.
netlink dumps can handle a failure if the dump function returns an
error; specifically, netlink_dump adds the return code to the response
if it is <= 0 so userspace is notified of the failure. The missing
piece is the rtnetlink dump functions returning the error.
Fix route and link dump functions to return the errors if no object is
added to an skb (detected by skb->len != 0). IPv6 route dumps
(rt6_dump_route) already return the error; this patch updates IPv4 and
link dumps. Other dump functions may need to be ajusted as well.
Reported-by: Jan Moskyto Matejka <mq@ucw.cz>
Signed-off-by: David Ahern <dsahern@gmail.com>
[ Upstream commit bafbb9c73241760023d8981191ddd30bb1c6dbac ]
tcp_ack() can call tcp_fragment() which may dededuct the
value tp->fackets_out when MSS changes. When prior_fackets
is larger than tp->fackets_out, tcp_clean_rtx_queue() can
invoke tcp_update_reordering() with negative values. This
results in absurd tp->reodering values higher than
sysctl_tcp_max_reordering.
Note that tcp_update_reordering indeeds sets tp->reordering
to min(sysctl_tcp_max_reordering, metric), but because
the comparison is signed, a negative metric always wins.
Fixes: c7caf8d3ed7a ("[TCP]: Fix reord detection due to snd_una covered holes")
Reported-by: Rebecca Isaacs <risaacs@google.com>
[ Upstream commit fdcee2cbb8438702ea1b328fb6e0ac5e9a40c7f8 ]
SCTP needs fixes similar to 83eaddab4378 ("ipv6/dccp: do not inherit
ipv6_mc_list from parent"), otherwise bad things can happen.
[ Upstream commit dbc2b5e9a09e9a6664679a667ff81cff6e5f2641 ]
Commit 0ca50d12fe46 ("sctp: fix src address selection if using secondary
addresses") has fixed a src address selection issue when using secondary
addresses for ipv4.
Now sctp ipv6 also has the similar issue. When using a secondary address,
sctp_v6_get_dst tries to choose the saddr which has the most same bits
with the daddr by sctp_v6_addr_match_len. It may make some cases not work
as expected.
hostA:
[1] fd21:356b:459a:cf10::11 (eth1)
[2] fd21:356b:459a:cf20::11 (eth2)
hostB:
[a] fd21:356b:459a:cf30::2 (eth1)
[b] fd21:356b:459a:cf40::2 (eth2)
route from hostA to hostB:
fd21:356b:459a:cf30::/64 dev eth1 metric 1024 mtu 1500
The expected path should be:
fd21:356b:459a:cf10::11 <-> fd21:356b:459a:cf30::2
But addr[2] matches addr[a] more bits than addr[1] does, according to
sctp_v6_addr_match_len. It causes the path to be:
fd21:356b:459a:cf20::11 <-> fd21:356b:459a:cf30::2
This patch is to fix it with the same way as Marcelo's fix for sctp ipv4.
As no ip_dev_find for ipv6, this patch is to use ipv6_chk_addr to check
if the saddr is in a dev instead.
Note that for backwards compatibility, it will still do the addr_match_len
check here when no optimal is found.
Reported-by: Patrick Talbert <ptalbert@redhat.com>
[ Upstream commit b451e5d24ba6687c6f0e7319c727a709a1846c06 ]
This patch fixes a bug in splitting an SKB during SACK
processing. Specifically if an skb contains multiple
packets and is only partially sacked in the higher sequences,
tcp_match_sack_to_skb() splits the skb and marks the second fragment
as SACKed.
The current code further attempts rounding up the first fragment
to MSS boundaries. But it misses a boundary condition when the
rounded-up fragment size (pkt_len) is exactly skb size. Spliting
such an skb is pointless and causses a kernel warning and aborts
the SACK processing. This patch universally checks such over-split
before calling tcp_fragment to prevent these unnecessary warnings.
Fixes: adb92db857ee ("tcp: Make SACK code to split only at mss boundaries")
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 83eaddab4378db256d00d295bda6ca997cd13a52 ]
Like commit 657831ffc38e ("dccp/tcp: do not inherit mc_list from parent")
we should clear ipv6_mc_list etc. for IPv6 sockets too.
Cc: Eric Dumazet <edumazet@google.com>
[ Upstream commit 657831ffc38e30092a2d5f03d385d710eb88b09a ]
syzkaller found a way to trigger double frees from ip_mc_drop_socket()
It turns out that leave a copy of parent mc_list at accept() time,
which is very bad.
Very similar to commit 8b485ce69876 ("tcp: do not inherit
fastopen_req from parent")
Initial report from Pray3r, completed by Andrey one.
Thanks a lot to them !
Reported-by: Pray3r <pray3r.z@gmail.com>
commit ee0d8d8482345ff97a75a7d747efc309f13b0d80 upstream.
We should call ipxitf_put() if the copy_to_user() fails.
Reported-by: 李强 <liqiang6-s@360.cn>
commit 480dd46b9d6812e5fb7172c305ee0f1154c26eed upstream.
The ability to change the max_rx_aggregation frames is useful
in cases of IOP.
There exist some devices (latest mobile phones and some AP's)
that tend to not respect a BA sessions maximum size (in Kbps).
These devices won't respect the AMPDU size that was negotiated during
association (even though they do respect the maximal number of packets).
This violation is characterized by a valid number of packets in
a single AMPDU. Even so, the total size will exceed the size negotiated
during association.
Eventually, this will cause some undefined behavior, which in turn
causes the hw to drop packets, causing the throughput to plummet.
This patch will make the subframe limitation to be held by each station,
instead of being held only by hw.
Signed-off-by: Maxim Altshul <maxim.altshul@ti.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 50ea05efaf3bed7dd34bcc2635a8b3f53bd0ccc1 upstream.
Currently mac80211 does not inform the driver of the session
block ack timeout when starting a rx aggregation session.
Drivers that manage the reorder buffer need to know this
parameter.
Seeing that there are now too many arguments for the
drv_ampdu_action() function, wrap them inside a structure.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
commit fad471860c097844432c7cf5d3ae6a0a059c2bdc upstream.
Currently mac80211 does not inform the driver of the window
size when starting an RX aggregation session.
To enable managing the reorder buffer in the driver or hardware
the window size is needed.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit ab89f0bdd63a3721f7cd3f064f39fc4ac7ca14d4 upstream.
Running 32bit userspace on 64bit kernel results in MSG_CMSG_COMPAT being
defined as 0x80000000. This results in sendmsg failure if used from 32bit
userspace running on 64bit kernel. Fix this by accounting for MSG_CMSG_COMPAT
in flags check in hci_sock_sendmsg.
Signed-off-by: Szymon Janc <szymon.janc@codecoup.pl>
Signed-off-by: Marko Kiiskila <marko@runtime.io>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
[ Upstream commit 242d3a49a2a1a71d8eb9f953db1bcaa9d698ce00 ]
For each netns (except init_net), we initialize its null entry
in 3 places:
1) The template itself, as we use kmemdup()
2) Code around dst_init_metrics() in ip6_route_net_init()
3) ip6_route_dev_notify(), which is supposed to initialize it after
loopback registers
Unfortunately the last one still happens in a wrong order because
we expect to initialize net->ipv6.ip6_null_entry->rt6i_idev to
net->loopback_dev's idev, thus we have to do that after we add
idev to loopback. However, this notifier has priority == 0 same as
ipv6_dev_notf, and ipv6_dev_notf is registered after
ip6_route_dev_notifier so it is called actually after
ip6_route_dev_notifier. This is similar to commit 2f460933f58e
("ipv6: initialize route null entry in addrconf_init()") which
fixes init_net.
Fix it by picking a smaller priority for ip6_route_dev_notifier.
Also, we have to release the refcnt accordingly when unregistering
loopback_dev because device exit functions are called before subsys
exit functions.
Acked-by: David Ahern <dsahern@gmail.com>
Tested-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 2f460933f58eee3393aba64f0f6d14acb08d1724 ]
Andrey reported a crash on init_net.ipv6.ip6_null_entry->rt6i_idev
since it is always NULL.
This is clearly wrong, we have code to initialize it to loopback_dev,
unfortunately the order is still not correct.
loopback_dev is registered very early during boot, we lose a chance
to re-initialize it in notifier. addrconf_init() is called after
ip6_route_init(), which means we have no chance to correct it.
Fix it by moving this initialization explicitly after
ipv6_add_dev(init_net.loopback_dev) in addrconf_init().
[ Upstream commit 77ef033b687c3e030017c94a29bf6ea3aaaef678 ]
IFLA_PHYS_PORT_NAME is a string attribute, so terminate it with \0.
Otherwise libnl3 fails to validate netlink messages with this attribute.
"ip -detail a" assumes too that the attribute is NUL-terminated when
printing it. It often was, due to padding.
I noticed this as libvirtd failing to start on a system with sfc driver
after upgrading it to Linux 4.11, i.e. when sfc added support for
phys_port_name.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
[ Upstream commit 86f4c90a1c5c1493f07f2d12c1079f5bf01936f2 ]
raw_send_hdrinc() and rawv6_send_hdrinc() expect that the buffer copied
from the userspace contains the IPv4/IPv6 header, so if too few bytes are
copied, parts of the header may remain uninitialized.
This bug has been detected with KMSAN.
For the record, the KMSAN report:
BUG: KMSAN: use of unitialized memory in nf_ct_frag6_gather+0xf5a/0x44a0
inter: 0
CPU: 0 PID: 1036 Comm: probe Not tainted 4.11.0-rc5+ #2455
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16
dump_stack+0x143/0x1b0 lib/dump_stack.c:52
kmsan_report+0x16b/0x1e0 mm/kmsan/kmsan.c:1078
__kmsan_warning_32+0x5c/0xa0 mm/kmsan/kmsan_instr.c:510
nf_ct_frag6_gather+0xf5a/0x44a0 net/ipv6/netfilter/nf_conntrack_reasm.c:577
ipv6_defrag+0x1d9/0x280 net/ipv6/netfilter/nf_defrag_ipv6_hooks.c:68
nf_hook_entry_hookfn ./include/linux/netfilter.h:102
nf_hook_slow+0x13f/0x3c0 net/netfilter/core.c:310
nf_hook ./include/linux/netfilter.h:212
NF_HOOK ./include/linux/netfilter.h:255
rawv6_send_hdrinc net/ipv6/raw.c:673
rawv6_sendmsg+0x2fcb/0x41a0 net/ipv6/raw.c:919
inet_sendmsg+0x3f8/0x6d0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633
sock_sendmsg net/socket.c:643
SYSC_sendto+0x6a5/0x7c0 net/socket.c:1696
SyS_sendto+0xbc/0xe0 net/socket.c:1664
do_syscall_64+0x72/0xa0 arch/x86/entry/common.c:285
entry_SYSCALL64_slow_path+0x25/0x25 arch/x86/entry/entry_64.S:246
RIP: 0033:0x436e03
RSP: 002b:00007ffce48baf38 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000004002b0 RCX: 0000000000436e03
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000003
RBP: 00007ffce48baf90 R08: 00007ffce48baf50 R09: 000000000000001c
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
R13: 0000000000401790 R14: 0000000000401820 R15: 0000000000000000
origin: 00000000d9400053
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:362
kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:257
kmsan_poison_shadow+0x6d/0xc0 mm/kmsan/kmsan.c:270
slab_alloc_node mm/slub.c:2735
__kmalloc_node_track_caller+0x1f4/0x390 mm/slub.c:4341
__kmalloc_reserve net/core/skbuff.c:138
__alloc_skb+0x2cd/0x740 net/core/skbuff.c:231
alloc_skb ./include/linux/skbuff.h:933
alloc_skb_with_frags+0x209/0xbc0 net/core/skbuff.c:4678
sock_alloc_send_pskb+0x9ff/0xe00 net/core/sock.c:1903
sock_alloc_send_skb+0xe4/0x100 net/core/sock.c:1920
rawv6_send_hdrinc net/ipv6/raw.c:638
rawv6_sendmsg+0x2918/0x41a0 net/ipv6/raw.c:919
return_from_SYSCALL_64+0x0/0x6a arch/x86/entry/entry_64.S:246
, triggered by the following syscalls:
socket(PF_INET6, SOCK_RAW, IPPROTO_RAW) = 3
sendto(3, NULL, 0, 0, {sa_family=AF_INET6, sin6_port=htons(0), inet_pton(AF_INET6, "ff00::", &sin6_addr), sin6_flowinfo=0, sin6_scope_id=0}, 28) = -1 EPERM
A similar report is triggered in net/ipv4/raw.c if we use a PF_INET socket
instead of a PF_INET6 one.
Signed-off-by: Alexander Potapenko <glider@google.com>
[ Upstream commit 8b485ce69876c65db12ed390e7f9c0d2a64eff2c ]
Under fuzzer stress, it is possible that a child gets a non NULL
fastopen_req pointer from its parent at accept() time, when/if parent
morphs from listener to active session.
We need to make sure this can not happen, by clearing the field after
socket cloning.
BUG: Double free or freeing an invalid pointer
Unexpected shadow byte: 0xFB
CPU: 3 PID: 20933 Comm: syz-executor3 Not tainted 4.11.0+ #306
01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x292/0x395 lib/dump_stack.c:52
kasan_object_err+0x1c/0x70 mm/kasan/report.c:164
kasan_report_double_free+0x5c/0x70 mm/kasan/report.c:185
kasan_slab_free+0x9d/0xc0 mm/kasan/kasan.c:580
slab_free_hook mm/slub.c:1357 [inline]
slab_free_freelist_hook mm/slub.c:1379 [inline]
slab_free mm/slub.c:2961 [inline]
kfree+0xe8/0x2b0 mm/slub.c:3882
tcp_free_fastopen_req net/ipv4/tcp.c:1077 [inline]
tcp_disconnect+0xc15/0x13e0 net/ipv4/tcp.c:2328
inet_child_forget+0xb8/0x600 net/ipv4/inet_connection_sock.c:898
inet_csk_reqsk_queue_add+0x1e7/0x250
net/ipv4/inet_connection_sock.c:928
tcp_get_cookie_sock+0x21a/0x510 net/ipv4/syncookies.c:217
cookie_v4_check+0x1a19/0x28b0 net/ipv4/syncookies.c:384
tcp_v4_cookie_check net/ipv4/tcp_ipv4.c:1384 [inline]
tcp_v4_do_rcv+0x731/0x940 net/ipv4/tcp_ipv4.c:1421
tcp_v4_rcv+0x2dc0/0x31c0 net/ipv4/tcp_ipv4.c:1715
ip_local_deliver_finish+0x4cc/0xc20 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:257 [inline]
ip_local_deliver+0x1ce/0x700 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:492 [inline]
ip_rcv_finish+0xb1d/0x20b0 net/ipv4/ip_input.c:396
ip_rcv+0xd8c/0x19c0 net/ipv4/ip_input.c:487
__netif_receive_skb_core+0x1ad1/0x3400 net/core/dev.c:4210
__netif_receive_skb+0x2a/0x1a0 net/core/dev.c:4248
process_backlog+0xe5/0x6c0 net/core/dev.c:4868
napi_poll net/core/dev.c:5270 [inline]
net_rx_action+0xe70/0x18e0 net/core/dev.c:5335
__do_softirq+0x2fb/0xb99 kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:899
</IRQ>
do_softirq.part.17+0x1e8/0x230 kernel/softirq.c:328
do_softirq kernel/softirq.c:176 [inline]
__local_bh_enable_ip+0x1cf/0x1e0 kernel/softirq.c:181
local_bh_enable include/linux/bottom_half.h:31 [inline]
rcu_read_unlock_bh include/linux/rcupdate.h:931 [inline]
ip_finish_output2+0x9ab/0x15e0 net/ipv4/ip_output.c:230
ip_finish_output+0xa35/0xdf0 net/ipv4/ip_output.c:316
NF_HOOK_COND include/linux/netfilter.h:246 [inline]
ip_output+0x1f6/0x7b0 net/ipv4/ip_output.c:404
dst_output include/net/dst.h:486 [inline]
ip_local_out+0x95/0x160 net/ipv4/ip_output.c:124
ip_queue_xmit+0x9a8/0x1a10 net/ipv4/ip_output.c:503
tcp_transmit_skb+0x1ade/0x3470 net/ipv4/tcp_output.c:1057
tcp_write_xmit+0x79e/0x55b0 net/ipv4/tcp_output.c:2265
__tcp_push_pending_frames+0xfa/0x3a0 net/ipv4/tcp_output.c:2450
tcp_push+0x4ee/0x780 net/ipv4/tcp.c:683
tcp_sendmsg+0x128d/0x39b0 net/ipv4/tcp.c:1342
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
SYSC_sendto+0x660/0x810 net/socket.c:1696
SyS_sendto+0x40/0x50 net/socket.c:1664
RIP: 0033:0x446059
RSP: 002b:00007faa6761fb58 EFLAGS: 00000282 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000000017 RCX: 0000000000446059
RDX: 0000000000000001 RSI: 0000000020ba3fcd RDI: 0000000000000017
RBP: 00000000006e40a0 R08: 0000000020ba4ff0 R09: 0000000000000010
R10: 0000000020000000 R11: 0000000000000282 R12: 0000000000708150
R13: 0000000000000000 R14: 00007faa676209c0 R15: 00007faa67620700
Object at ffff88003b5bbcb8, in cache kmalloc-64 size: 64
Allocated:
PID = 20909
save_stack+0x43/0xd0 mm/kasan/kasan.c:513
set_track mm/kasan/kasan.c:525 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:616
kmem_cache_alloc_trace+0x82/0x270 mm/slub.c:2745
kmalloc include/linux/slab.h:490 [inline]
kzalloc include/linux/slab.h:663 [inline]
tcp_sendmsg_fastopen net/ipv4/tcp.c:1094 [inline]
tcp_sendmsg+0x221a/0x39b0 net/ipv4/tcp.c:1139
Freed:
PID = 20909
kasan_slab_free+0x73/0xc0 mm/kasan/kasan.c:589
__inet_stream_connect+0x20c/0xf90 net/ipv4/af_inet.c:593
tcp_sendmsg_fastopen net/ipv4/tcp.c:1111 [inline]
tcp_sendmsg+0x23a8/0x39b0 net/ipv4/tcp.c:1139
Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets")
Fixes: 7db92362d2fe ("tcp: fix potential double free issue for fastopen_req")
Acked-by: Wei Wang <weiwan@google.com>
[ Upstream commit a9f11f963a546fea9144f6a6d1a307e814a387e7 ]
Be careful when comparing tcp_time_stamp to some u32 quantity,
otherwise result can be surprising.
Fixes: 7c106d7e782b ("[TCP]: TCP Low Priority congestion control")
[ Upstream commit 7162fb242cb8322beb558828fd26b33c3e9fc805 ]
Andrey found a way to trigger the WARN_ON_ONCE(delta < len) in
skb_try_coalesce() using syzkaller and a filter attached to a TCP
socket over loopback interface.
I believe one issue with looped skbs is that tcp_trim_head() can end up
producing skb with under estimated truesize.
It hardly matters for normal conditions, since packets sent over
loopback are never truncated.
Bytes trimmed from skb->head should not change skb truesize, since
skb->head is not reallocated.
The backport of d35c99ff77ec ("netlink: do not enter direct reclaim from
netlink_dump()") to the 4.4 branch (first in 4.4.32) mistakenly removed
direct claim from the initial large allocation _and_ the fallback
allocation which means that allocations can spuriously fail.
Fix the issue by adding back the direct reclaim flag to the fallback
allocation.
Fixes: 6d123f1d396b ("netlink: do not enter direct reclaim from netlink_dump()")
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
commit 71d6ad08379304128e4bdfaf0b4185d54375423e upstream.
Don't assume that server is sane and won't return more data than
asked for.
[ Upstream commit 105f5528b9bbaa08b526d3405a5bcd2ff0c953c8 ]
In situations where an skb is paged, the transport header pointer and
tail pointer can be the same because the skb contents are in frags.
This results in ioctl(SIOCINQ/FIONREAD) incorrectly returning a
length of 0 when the length to receive is actually greater than zero.
skb->len is already correctly set in ip6_input_finish() with
pskb_pull(), so use skb->len as it always returns the correct result
for both linear and paged data.
Signed-off-by: Jamie Bainbridge <jbainbri@redhat.com>
[ Upstream commit 199ab00f3cdb6f154ea93fa76fd80192861a821d ]
Andrey reported a out-of-bound access in ip6_tnl_xmit(), this
is because we use an ipv4 dst in ip6_tnl_xmit() and cast an IPv4
neigh key as an IPv6 address:
neigh = dst_neigh_lookup(skb_dst(skb),
&ipv6_hdr(skb)->daddr);
if (!neigh)
goto tx_err_link_failure;
addr6 = (struct in6_addr *)&neigh->primary_key; // <=== HERE
addr_type = ipv6_addr_type(addr6);
if (addr_type == IPV6_ADDR_ANY)
addr6 = &ipv6_hdr(skb)->daddr;
memcpy(&fl6->daddr, addr6, sizeof(fl6->daddr));
Also the network header of the skb at this point should be still IPv4
for 4in6 tunnels, we shold not just use it as IPv6 header.
This patch fixes it by checking if skb->protocol is ETH_P_IPV6: if it
is, we are safe to do the nexthop lookup using skb_dst() and
ipv6_hdr(skb)->daddr; if not (aka IPv4), we have no clue about which
dest address we can pick here, we have to rely on callers to fill it
from tunnel config, so just fall to ip6_route_output() to make the
decision.
Fixes: ea3dc9601bda ("ip6_tunnel: Add support for wildcard tunnel endpoints.")
Cc: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 723b929ca0f79c0796f160c2eeda4597ee98d2b8 ]
Andrey Konovalov reported a BUG caused by the ip6mr code which is caused
because we call unregister_netdevice_many for a device that is already
being destroyed. In IPv4's ipmr that has been resolved by two commits
long time ago by introducing the "notify" parameter to the delete
function and avoiding the unregister when called from a notifier, so
let's do the same for ip6mr.
The trace from Andrey:
kernel BUG at net/core/dev.c:6813!
invalid opcode: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 1 PID: 1165 Comm: kworker/u4:3 Not tainted 4.11.0-rc7+ #251
01/01/2011
Workqueue: netns cleanup_net
task: ffff880069208000 task.stack: ffff8800692d8000
RIP: 0010:rollback_registered_many+0x348/0xeb0 net/core/dev.c:6813
RSP: 0018:ffff8800692de7f0 EFLAGS: 00010297
RAX: ffff880069208000 RBX: 0000000000000002 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88006af90569
RBP: ffff8800692de9f0 R08: ffff8800692dec60 R09: 0000000000000000
R10: 0000000000000006 R11: 0000000000000000 R12: ffff88006af90070
R13: ffff8800692debf0 R14: dffffc0000000000 R15: ffff88006af90000
FS: 0000000000000000(0000) GS:ffff88006cb00000(0000)
knlGS:0000000000000000
CR2: 00007fe7e897d870 CR3: 00000000657e7000 CR4: 00000000000006e0
Call Trace:
unregister_netdevice_many.part.105+0x87/0x440 net/core/dev.c:7881
unregister_netdevice_many+0xc8/0x120 net/core/dev.c:7880
ip6mr_device_event+0x362/0x3f0 net/ipv6/ip6mr.c:1346
notifier_call_chain+0x145/0x2f0 kernel/notifier.c:93
__raw_notifier_call_chain kernel/notifier.c:394
raw_notifier_call_chain+0x2d/0x40 kernel/notifier.c:401
call_netdevice_notifiers_info+0x51/0x90 net/core/dev.c:1647
call_netdevice_notifiers net/core/dev.c:1663
rollback_registered_many+0x919/0xeb0 net/core/dev.c:6841
unregister_netdevice_many net/core/dev.c:7880
default_device_exit_batch+0x4fa/0x640 net/core/dev.c:8333
ops_exit_list.isra.4+0x100/0x150 net/core/net_namespace.c:144
cleanup_net+0x5a8/0xb40 net/core/net_namespace.c:463
process_one_work+0xc04/0x1c10 kernel/workqueue.c:2097
worker_thread+0x223/0x19c0 kernel/workqueue.c:2231
kthread+0x35e/0x430 kernel/kthread.c:231
ret_from_fork+0x31/0x40 arch/x86/entry/entry_64.S:430
Code: 3c 32 00 0f 85 70 0b 00 00 48 b8 00 02 00 00 00 00 ad de 49 89
47 78 e9 93 fe ff ff 49 8d 57 70 49 8d 5f 78 eb 9e e8 88 7a 14 fe <0f>
0b 48 8b 9d 28 fe ff ff e8 7a 7a 14 fe 48 b8 00 00 00 00 00
RIP: rollback_registered_many+0x348/0xeb0 RSP: ffff8800692de7f0
---[ end trace e0b29c57e9b3292c ]---
[ Upstream commit c70b17b775edb21280e9de7531acf6db3b365274 ]
Reducing real_num_tx_queues needs to be in sync with skb queue_mapping
otherwise skbs with queue_mapping greater than real_num_tx_queues
can be sent to the underlying driver and can result in kernel panic.
One such event is running netconsole and enabling VF on the same
device. Or running netconsole and changing number of tx queues via
ethtool on same device.
e.g.
Unable to handle kernel NULL pointer dereference
tsk->{mm,active_mm}->context = 0000000000001525
tsk->{mm,active_mm}->pgd = fff800130ff9a000
\|/ ____ \|/
/_| \__/ |_\
\__U_/
kworker/48:1(475): Oops [#1]
CPU: 48 PID: 475 Comm: kworker/48:1 Tainted: G OE
4.11.0-rc3-davem-net+ #7
Workqueue: events queue_process
task: fff80013113299c0 task.stack: fff800131132c000
TSTATE: 0000004480e01600 TPC: 00000000103f9e3c TNPC: 00000000103f9e40 Y:
00000000 Tainted: G OE
TPC: <ixgbe_xmit_frame_ring+0x7c/0x6c0 [ixgbe]>
g0: 0000000000000000 g1: 0000000000003fff g2: 0000000000000000 g3:
0000000000000001
g4: fff80013113299c0 g5: fff8001fa6808000 g6: fff800131132c000 g7:
00000000000000c0
o0: fff8001fa760c460 o1: fff8001311329a50 o2: fff8001fa7607504 o3:
0000000000000003
o4: fff8001f96e63a40 o5: fff8001311d77ec0 sp: fff800131132f0e1 ret_pc:
000000000049ed94
RPC: <set_next_entity+0x34/0xb80>
l0: 0000000000000000 l1: 0000000000000800 l2: 0000000000000000 l3:
0000000000000000
l4: 000b2aa30e34b10d l5: 0000000000000000 l6: 0000000000000000 l7:
fff8001fa7605028
i0: fff80013111a8a00 i1: fff80013155a0780 i2: 0000000000000000 i3:
0000000000000000
i4: 0000000000000000 i5: 0000000000100000 i6: fff800131132f1a1 i7:
00000000103fa4b0
I7: <ixgbe_xmit_frame+0x30/0xa0 [ixgbe]>
Call Trace:
[00000000103fa4b0] ixgbe_xmit_frame+0x30/0xa0 [ixgbe]
[0000000000998c74] netpoll_start_xmit+0xf4/0x200
[0000000000998e10] queue_process+0x90/0x160
[0000000000485fa8] process_one_work+0x188/0x480
[0000000000486410] worker_thread+0x170/0x4c0
[000000000048c6b8] kthread+0xd8/0x120
[0000000000406064] ret_from_fork+0x1c/0x2c
[0000000000000000] (null)
Disabling lock debugging due to kernel taint
Caller[00000000103fa4b0]: ixgbe_xmit_frame+0x30/0xa0 [ixgbe]
Caller[0000000000998c74]: netpoll_start_xmit+0xf4/0x200
Caller[0000000000998e10]: queue_process+0x90/0x160
Caller[0000000000485fa8]: process_one_work+0x188/0x480
Caller[0000000000486410]: worker_thread+0x170/0x4c0
Caller[000000000048c6b8]: kthread+0xd8/0x120
Caller[0000000000406064]: ret_from_fork+0x1c/0x2c
Caller[0000000000000000]: (null)
Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com>
[ Upstream commit 557c44be917c322860665be3d28376afa84aa936 ]
Andrey reported a fault in the IPv6 route code:
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 1 PID: 4035 Comm: a.out Not tainted 4.11.0-rc7+ #250
task: ffff880069809600 task.stack: ffff880062dc8000
RIP: 0010:ip6_rt_cache_alloc+0xa6/0x560 net/ipv6/route.c:975
RSP: 0018:ffff880062dced30 EFLAGS: 00010206
RAX: dffffc0000000000 RBX: ffff8800670561c0 RCX: 0000000000000006
RDX: 0000000000000003 RSI: ffff880062dcfb28 RDI: 0000000000000018
RBP: ffff880062dced68 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880062dcfb28 R14: dffffc0000000000 R15: 0000000000000000
FS: 00007feebe37e7c0(0000) GS:ffff88006cb00000(0000) knlGS:0000000000000000
CR2: 00000000205a0fe4 CR3: 000000006b5c9000 CR4: 00000000000006e0
Call Trace:
ip6_pol_route+0x1512/0x1f20 net/ipv6/route.c:1128
ip6_pol_route_output+0x4c/0x60 net/ipv6/route.c:1212
Andrey's syzkaller program passes rtmsg.rtmsg_flags with the RTF_PCPU bit
set. Flags passed to the kernel are blindly copied to the allocated
rt6_info by ip6_route_info_create making a newly inserted route appear
as though it is a per-cpu route. ip6_rt_cache_alloc sees the flag set
and expects rt->dst.from to be set - which it is not since it is not
really a per-cpu copy. The subsequent call to __ip6_dst_alloc then
generates the fault.
Fix by checking for the flag and failing with EINVAL.
Fixes: d52d3997f843f ("ipv6: Create percpu rt6_info")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit 17c3060b1701fc69daedb4c90be6325d3d9fca8e ]
In the (very unlikely) case a passive socket becomes a listener,
we do not want to duplicate its saved SYN headers.
This would lead to double frees, use after free, and please hackers and
various fuzzers
Tested:
0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 setsockopt(3, IPPROTO_TCP, TCP_SAVE_SYN, [1], 4) = 0
+0 fcntl(3, F_SETFL, O_RDWR|O_NONBLOCK) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 5) = 0
+0 < S 0:0(0) win 32972 <mss 1460,nop,wscale 7>
+0 > S. 0:0(0) ack 1 <...>
+.1 < . 1:1(0) ack 1 win 257
+0 accept(3, ..., ...) = 4
+0 connect(4, AF_UNSPEC, ...) = 0
+0 close(3) = 0
+0 bind(4, ..., ...) = 0
+0 listen(4, 5) = 0
Fixes: cd8ae85299d5 ("tcp: provide SYN headers for passive connections")
[ Upstream commit 34b2789f1d9bf8dcca9b5cb553d076ca2cd898ee ]
Now sctp doesn't check sock's state before listening on it. It could
even cause changing a sock with any state to become a listening sock
when doing sctp_listen.
This patch is to fix it by checking sock's state in sctp_listen, so
that it will listen on the sock with right state.
[ Upstream commit a8801799c6975601fd58ae62f48964caec2eb83f ]
inet_rtm_getroute synthesizes a skeletal ICMP skb, which is passed to
ip_route_input when iif is given. If a multipath route is present for
the designated destination, ip_multipath_icmp_hash ends up being called,
which uses the source/destination addresses within the skb to calculate
a hash. However, those are not set in the synthetic skb, causing it to
return an arbitrary and incorrect result.
Instead, use UDP, which gets no such special treatment.
Signed-off-by: Florian Larysch <fl@n621.de>
[ Upstream commit 249ee819e24c180909f43c1173c8ef6724d21faf ]
PPP pseudo-wire type is 7 (11 is L2TP_PWTYPE_IP).
Fixes: f1f39f911027 ("l2tp: auto load type modules")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit e08293a4ccbcc993ded0fdc46f1e57926b833d63 ]
Take a reference on the sessions returned by l2tp_session_find_nth()
(and rename it l2tp_session_get_nth() to reflect this change), so that
caller is assured that the session isn't going to disappear while
processing it.
For procfs and debugfs handlers, the session is held in the .start()
callback and dropped in .show(). Given that pppol2tp_seq_session_show()
dereferences the associated PPPoL2TP socket and that
l2tp_dfs_seq_session_show() might call pppol2tp_show(), we also need to
call the session's .ref() callback to prevent the socket from going
away from under us.
Fixes: fd558d186df2 ("l2tp: Split pppol2tp patch into separate l2tp and ppp parts")
Fixes: 0ad6614048cf ("l2tp: Add debugfs files for dumping l2tp debug info")
Fixes: 309795f4bec2 ("l2tp: Add netlink control API for L2TP")
[ Upstream commit bcc5364bdcfe131e6379363f089e7b4108d35b70 ]
When calculating po->tp_hdrlen + po->tp_reserve the result can overflow.
Fix by checking that tp_reserve <= INT_MAX on assign.
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 8f8d28e4d6d815a391285e121c3a53a0b6cb9e7b ]
When calculating rb->frames_per_block * req->tp_block_nr the result
can overflow.
Add a check that tp_block_size * tp_block_nr <= UINT_MAX.
Since frames_per_block <= tp_block_size, the expression would
never overflow.
[ Upstream commit e91793bb615cf6cdd59c0b6749fe173687bb0947 ]
The Rx path may grab the socket right before pppol2tp_release(), but
nothing guarantees that it will enqueue packets before
skb_queue_purge(). Therefore, the socket can be destroyed without its
queues fully purged.
Fix this by purging queues in pppol2tp_session_destruct() where we're
guaranteed nothing is still referencing the socket.
Fixes: 9e9cb6221aa7 ("l2tp: fix userspace reception on plain L2TP sockets")
[ Upstream commit 48481c8fa16410ffa45939b13b6c53c2ca609e5f ]
Dmitry posted a nice reproducer of a bug triggering in neigh_probe()
when dereferencing a NULL neigh->ops->solicit method.
This can happen for arp_direct_ops/ndisc_direct_ops and similar,
which can be used for NUD_NOARP neighbours (created when dev->header_ops
is NULL). Admin can then force changing nud_state to some other state
that would fire neigh timer.
