[ Upstream commit 15e5a030716468dce4032fa0f398d840fa2756f6 ]
gso_segs were reset to zero when kernel receive packets from untrusted
source. But we use this zero value to estimate precise packet len which is
wrong. So this patch tries to estimate the correct gso_segs value before using
it in qdisc_pkt_len_init().
Signed-off-by: Jason Wang <jasowang@redhat.com>
Cc: Eric Dumazet <edumazet@google.com>
[ Upstream commit c1aad275b0293d2b1905ec95a945422262470684 ]
Set the transport header for 1) some drivers (e.g ixgbe needs l4 header to do
atr) 2) precise packet length estimation (introduced in 1def9238) needs l4
header to compute header length.
So this patch first tries to get l4 header for packet socket through
skb_flow_dissect(), and pretend no l4 header if skb_flow_dissect() fails.
[ Upstream commit c5c7774d7eb4397891edca9ebdf750ba90977a69 ]
In commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86
(refactor sctp_outq_teardown to insure proper re-initalization)
we modified sctp_outq_teardown to use sctp_outq_init to fully re-initalize the
outq structure. Steve West recently asked me why I removed the q->error = 0
initalization from sctp_outq_teardown. I did so because I was operating under
the impression that sctp_outq_init would properly initalize that value for us,
but it doesn't. sctp_outq_init operates under the assumption that the outq
struct is all 0's (as it is when called from sctp_association_init), but using
it in __sctp_outq_teardown violates that assumption. We should do a memset in
sctp_outq_init to ensure that the entire structure is in a known state there
instead.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: "West, Steve (NSN - US/Fort Worth)" <steve.west@nsn.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: netdev@vger.kernel.org
CC: davem@davemloft.net
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit a6f79d0f26704214b5b702bbac525cb72997f984 ]
PPPoL2TP sockets should comply with the standard send*() return values
(i.e. return number of bytes sent instead of 0 upon success).
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 55b92b7a11690bc377b5d373872a6b650ae88e64 ]
Copy user data after PPP framing header. This prevents erasure of the
added PPP header and avoids leaking two bytes of uninitialised memory
at the end of skb's data buffer.
[ Upstream commit 2dc85bf323515e59e15dfa858d1472bb25cad0fe ]
uaddr->sa_data is exactly of size 14, which is hard-coded here and
passed as a size argument to strncpy(). A device name can be of size
IFNAMSIZ (== 16), meaning we might leave the destination string
unterminated. Thus, use strlcpy() and also sizeof() while we're
at it. We need to memset the data area beforehand, since strlcpy
does not padd the remaining buffer with zeroes for user space, so
that we do not possibly leak anything.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 1abd165ed757db1afdefaac0a4bc8a70f97d258c ]
While stress testing sctp sockets, I hit the following panic:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
PGD 7cead067 PUD 7ce76067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: sctp(F) libcrc32c(F) [...]
CPU: 7 PID: 2950 Comm: acc Tainted: GF 3.10.0-rc2+ #1
Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
task: ffff88007ce0e0c0 ti: ffff88007b568000 task.ti: ffff88007b568000
RIP: 0010:[<ffffffffa0490c4e>] [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP: 0018:ffff88007b569e08 EFLAGS: 00010292
RAX: 0000000000000000 RBX: ffff88007db78a00 RCX: dead000000200200
RDX: ffffffffa049fdb0 RSI: ffff8800379baf38 RDI: 0000000000000000
RBP: ffff88007b569e18 R08: ffff88007c230da0 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880077990d00 R14: 0000000000000084 R15: ffff88007db78a00
FS: 00007fc18ab61700(0000) GS:ffff88007fc60000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000020 CR3: 000000007cf9d000 CR4: 00000000000007e0
Stack:
ffff88007b569e38 ffff88007db78a00 ffff88007b569e38 ffffffffa049fded
ffffffff81abf0c0 ffff88007db78a00 ffff88007b569e58 ffffffff8145b60e
0000000000000000 0000000000000000 ffff88007b569eb8 ffffffff814df36e
Call Trace:
[<ffffffffa049fded>] sctp_destroy_sock+0x3d/0x80 [sctp]
[<ffffffff8145b60e>] sk_common_release+0x1e/0xf0
[<ffffffff814df36e>] inet_create+0x2ae/0x350
[<ffffffff81455a6f>] __sock_create+0x11f/0x240
[<ffffffff81455bf0>] sock_create+0x30/0x40
[<ffffffff8145696c>] SyS_socket+0x4c/0xc0
[<ffffffff815403be>] ? do_page_fault+0xe/0x10
[<ffffffff8153cb32>] ? page_fault+0x22/0x30
[<ffffffff81544e02>] system_call_fastpath+0x16/0x1b
Code: 0c c9 c3 66 2e 0f 1f 84 00 00 00 00 00 e8 fb fe ff ff c9 c3 66 0f
1f 84 00 00 00 00 00 55 48 89 e5 53 48 83 ec 08 66 66 66 66 90 <48>
8b 47 20 48 89 fb c6 47 1c 01 c6 40 12 07 e8 9e 68 01 00 48
RIP [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP <ffff88007b569e08>
---[ end trace e0d71ec1108c1dd9 ]---
I did not hit this with the lksctp-tools functional tests, but with a
small, multi-threaded test program, that heavily allocates, binds,
listens and waits in accept on sctp sockets, and then randomly kills
some of them (no need for an actual client in this case to hit this).
Then, again, allocating, binding, etc, and then killing child processes.
This panic then only occurs when ``echo 1 > /proc/sys/net/sctp/auth_enable''
is set. The cause for that is actually very simple: in sctp_endpoint_init()
we enter the path of sctp_auth_init_hmacs(). There, we try to allocate
our crypto transforms through crypto_alloc_hash(). In our scenario,
it then can happen that crypto_alloc_hash() fails with -EINTR from
crypto_larval_wait(), thus we bail out and release the socket via
sk_common_release(), sctp_destroy_sock() and hit the NULL pointer
dereference as soon as we try to access members in the endpoint during
sctp_endpoint_free(), since endpoint at that time is still NULL. Now,
if we have that case, we do not need to do any cleanup work and just
leave the destruction handler.
[ Upstream commit 5343a7f8be11951cb3095b91e8e4eb506cfacc0f ]
commit 56b765b79 ("htb: improved accuracy at high rates") added another
regression for low rates, because it mixes 1ns and 64ns time units.
So the maximum delay (mbuffer) was not 60 second, but 937 ms.
Lets convert all time fields to 1ns as 64bit arches are becoming the
norm.
Reported-by: Jesper Dangaard Brouer <brouer@redhat.com>
Tested-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit 534c877928a16ae5f9776436a497109639bf67dc ]
Commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f
"net IPv6 : Fix broken IPv6 routing table after loopback down-up"
forgot to assign rt6_info to the inet6_ifaddr.
When disable the net device, the rt6_info which allocated
in init_loopback will not be destroied in __ipv6_ifa_notify.
This will trigger the waring message below
[23527.916091] unregister_netdevice: waiting for tap0 to become free. Usage count = 1
Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit 01cb71d2d47b78354358e4bb938bb06323e17498 ]
broke the "overhead xxx" handling, as well as the "linklayer atm"
attribute.
tc class add ... htb rate X ceil Y linklayer atm overhead 10
This patch restores the "overhead xxx" handling, for htb, tbf
and act_police
The "linklayer atm" thing needs a separate fix.
Cc: Vimalkumar <j.vimal@gmail.com>
Cc: Jiri Pirko <jpirko@redhat.com>
[ Upstream commit 1e2bd517c108816220f262d7954b697af03b5f9c ]
udp6 over GRE tunnel does not work after to GRE tso changes. GRE
tso handler passes inner packet but keeps track of outer header
start in SKB_GSO_CB(skb)->mac_offset. udp6 fragment need to
take care of outer header, which start at the mac_offset, while
adding fragment header.
This bug is introduced by commit 68c3316311 (GRE: Add TCP
segmentation offload for GRE).
Reported-by: Dmitry Kravkov <dkravkov@gmail.com>
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Tested-by: Dmitry Kravkov <dmitry@broadcom.com>
[ Upstream commit 456db6a4d495f40777da6f1f32f62f13026f52db ]
The three arrays of strings: af_family_key_strings,
af_family_slock_key_strings and af_family_clock_key_strings have not
VSOCK's string
Signed-off-by: Federico Vaga <federico.vaga@gmail.com>
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and
a7526eb5d06b0084ef12d7b168d008fcf516caab ]
MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API --
it's a hack that steals a bit to indicate to other networking code
that a compat entry was used. So don't allow it from a non-compat
syscall.
This prevents an oops when running this code:
int main()
int s;
struct sockaddr_in addr;
struct msghdr *hdr;
char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (highpage == MAP_FAILED)
err(1, "mmap");
s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (s == -1)
err(1, "socket");
addr.sin_family = AF_INET;
addr.sin_port = htons(1);
addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0)
err(1, "connect");
void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE;
printf("Evil address is %p\n", evil);
if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0)
err(1, "sendmmsg");
return 0;
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit f96ef988cc603487c03a6de07807b06cbe641829 ]
Unlike ipv4_redirect() and ipv4_sk_redirect(), ip_do_redirect()
doesn't call __build_flow_key() directly but via
ip_rt_build_flow_key() wrapper. This leads to __build_flow_key()
getting pointer to IPv4 header of the ICMP redirect packet
rather than pointer to the embedded IPv4 header of the packet
initiating the redirect.
As a result, handling of ICMP redirects initiated by TCP packets
is broken. Issue was introduced by
4895c771c ("ipv4: Add FIB nexthop exceptions.")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit a622260254ee481747cceaaa8609985b29a31565 ]
Daniel Petre reported crashes in icmp_dst_unreach() with following call
graph:
Daniel found a similar problem mentioned in
http://lkml.indiana.edu/hypermail/linux/kernel/1007.0/00961.html
And indeed this is the root cause : skb->cb[] contains data fooling IP
stack.
We must clear IPCB in ip_tunnel_xmit() sooner in case dst_link_failure()
is called. Or else skb->cb[] might contain garbage from GSO segmentation
layer.
A similar fix was tested on linux-3.9, but gre code was refactored in
linux-3.10. I'll send patches for stable kernels as well.
Many thanks to Daniel for providing reports, patches and testing !
Reported-by: Daniel Petre <daniel.petre@rcs-rds.ro>
[ Upstream commit 547669d483e5783d722772af1483fa474da7caf9 ]
commit 3853b5841c01a ("xps: Improvements in TX queue selection")
introduced ooo_okay flag, but the condition to set it is slightly wrong.
In our traces, we have seen ACK packets being received out of order,
and RST packets sent in response.
We should test if we have any packets still in host queue.
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 497574c72c9922cf20c12aed15313c389f722fa0 ]
The error exit path needs err explicitly set. Otherwise it
returns success and the only caller, xfrm_output_resume(),
would oops in skb_dst(skb)->ops derefence as skb_dst(skb) is
NULL.
Bug introduced in commit bb65a9cb (xfrm: removes a superfluous
check and add a statistic).
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
Cc: Li RongQing <roy.qing.li@gmail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 35f079ebbc860dcd1cca70890c9c8d59c1145525 ]
This patch is a fix for a bug triggering newly_acked_sacked < 0
in tcp_ack(.).
The bug is triggered by sacked_out decreasing relative to prior_sacked,
but packets_out remaining the same as pior_packets. This is because the
snapshot of prior_packets is taken after tcp_sacktag_write_queue() while
prior_sacked is captured before tcp_sacktag_write_queue(). The problem
is: tcp_sacktag_write_queue (tcp_match_skb_to_sack() -> tcp_fragment)
adjusts the pcount for packets_out and sacked_out (MSS change or other
reason). As a result, this delta in pcount is reflected in
(prior_sacked - sacked_out) but not in (prior_packets - packets_out).
This patch does the following:
1) initializes prior_packets at the start of tcp_ack() so as to
capture the delta in packets_out created by tcp_fragment.
2) introduces a new "previous_packets_out" variable that snapshots
packets_out right before tcp_clean_rtx_queue, so pkts_acked can be
correctly computed as before.
3) Computes pkts_acked using previous_packets_out, and computes
newly_acked_sacked using prior_packets.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 6b21e1b77d1a3d58ebfd513264c885695e8a0ba5 ]
The net/netlabel/netlabel_domainhash.c:netlbl_domhsh_add() function
does not properly validate new domain hash entries resulting in
potential problems when an administrator attempts to add an invalid
entry. One such problem, as reported by Vlad Halilov, is a kernel
BUG (found in netlabel_domainhash.c:netlbl_domhsh_audit_add()) when
adding an IPv6 outbound mapping with a CIPSO configuration.
This patch corrects this problem by adding the necessary validation
code to netlbl_domhsh_add() via the newly created
netlbl_domhsh_validate() function.
Ideally this patch should also be pushed to the currently active
-stable trees.
Reported-by: Vlad Halilov <vlad.halilov@gmail.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commit 284041ef21fdf2e0d216ab6b787bc9072b4eb58a ]
commit 0178b695fd6b4 ("ipv6: Copy cork options in ip6_append_data")
added some code duplication and bad error recovery, leading to potential
crash in ip6_cork_release() as kfree() could be called with garbage.
use kzalloc() to make sure this wont happen.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
[ Upstream commit faff57a92ba1d7247c5e86ecea2886d2c9d54507 ]
commit fb745e9a037895 ("net/802/mrp: fix possible race condition when
calling mrp_pdu_queue()") introduced a lockdep splat.
[ 19.735147] =================================
[ 19.735235] [ INFO: inconsistent lock state ]
[ 19.735324] 3.9.2-build-0063 #4 Not tainted
[ 19.735412] ---------------------------------
[ 19.735500] inconsistent {IN-SOFTIRQ-W} -> {SOFTIRQ-ON-W} usage.
[ 19.735592] rmmod/1840 [HC0[0]:SC0[0]:HE1:SE1] takes:
[ 19.735682] (&(&app->lock)->rlock#2){+.?...}, at: [<f862bb5b>]
mrp_uninit_applicant+0x69/0xba [mrp]
app->lock is normally taken under softirq context, so disable BH to
avoid the splat.
Reported-by: Denys Fedoryshchenko <denys@visp.net.lb>
Cc: David Ward <david.ward@ll.mit.edu>
Cc: Cong Wang <amwang@redhat.com>
Tested-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 54d27fcb338bd9c42d1dfc5a39e18f6f9d373c2e ]
TCP md5 communications fail [1] for some devices, because sg/crypto code
assume page offsets are below PAGE_SIZE.
This was discovered using mlx4 driver [2], but I suspect loopback
might trigger the same bug now we use order-3 pages in tcp_sendmsg()
[1] Failure is giving following messages.
huh, entered softirq 3 NET_RX ffffffff806ad230 preempt_count 00000100,
exited with 00000101?
[2] mlx4 driver uses order-2 pages to allocate RX frags
Reported-by: Matt Schnall <mischnal@google.com>
Cc: Bernhard Beck <bbeck@google.com>
commit e9966076cdd952e19f2dd4854cd719be0d7cbebc upstream.
The auth code is called from a variety of contexts, include the mon_client
(protected by the monc's mutex) and the messenger callbacks (currently
protected by nothing). Avoid chaos by protecting all auth state with a
mutex. Nothing is blocking, so this should be simple and lightweight.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@inktank.com>
commit 27859f9773e4a0b2042435b13400ee2c891a61f4 upstream.
Use wrapper functions that check whether the auth op exists so that callers
do not need a bunch of conditional checks. Simplifies the external
interface.
commit 0bed9b5c523d577378b6f83eab5835fe30c27208 upstream.
Currently the messenger calls out to a get_authorizer con op, which will
create a new authorizer if it doesn't yet have one. In the meantime, when
we rotate our service keys, the authorizer doesn't get updated. Eventually
it will be rejected by the server on a new connection attempt and get
invalidated, and we will then rebuild a new authorizer, but this is not
ideal.
Instead, if we do have an authorizer, call a new update_authorizer op that
will verify that the current authorizer is using the latest secret. If it
is not, we will build a new one that does. This avoids the transient
failure.
This fixes one of the sorry sequence of events for bug
http://tracker.ceph.com/issues/4282
commit 4b8e8b5d78b8322351d44487c1b76f7e9d3412bc upstream.
We were invalidating the authorizer by removing the ticket handler
entirely. This was effective in inducing us to request a new authorizer,
but in the meantime it mean that any authorizer we generated would get a
new and initialized handler with secret_id=0, which would always be
rejected by the server side with a confusing error message:
auth: could not find secret_id=0
cephx: verify_authorizer could not get service secret for service osd secret_id=0
Instead, simply clear the validity field. This will still induce the auth
code to request a new secret, but will let us continue to use the old
ticket in the meantime. The messenger code will probably continue to fail,
but the exponential backoff will kick in, and eventually the we will get a
new (hopefully more valid) ticket from the mon and be able to continue.
commit 20e55c4cc758e4dccdfd92ae8e9588dd624b2cd7 upstream.
We maintain a counter of failed auth attempts to allow us to retry once
before failing. However, if the second attempt succeeds, the flag isn't
cleared, which makes us think auth failed again later when the connection
resets for other reasons (like a socket error).
This is one part of the sorry sequence of events in bug
commit 96570ffcca0b872dc8626e97569d2697f374d868 upstream.
If hci_dev_open fails we need to ensure that the corresponding
mgmt_set_powered command gets an appropriate response. This patch fixes
the missing response by adding a new mgmt_set_powered_failed function
that's used to indicate a power on failure to mgmt. Since a situation
with the device being rfkilled may require special handling in user
space the patch uses a new dedicated mgmt status code for this.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit cb3b3152b2f5939d67005cff841a1ca748b19888 upstream.
There has been code in place to check that the L2CAP length header
matches the amount of data received, but many PDU handlers have not been
checking that the data received actually matches that expected by the
specific PDU. This patch adds passing the length header to the specific
handler functions and ensures that those functions fail cleanly in the
case of an incorrect amount of data.
commit 14d2f38df67fadee34625fcbd282ee22514c4846 upstream.
An osd client has a red-black tree describing its osds, and
occasionally we would get crashes due to one of these trees tree
becoming corrupt somehow.
The problem turned out to be that reset_changed_osds() was being
called without protection of the osd client request mutex. That
function would call __reset_osd() for any osd that had changed, and
__reset_osd() would call __remove_osd() for any osd with no
outstanding requests, and finally __remove_osd() would remove the
corresponding entry from the red-black tree. Thus, the tree was
getting modified without having any lock protection, and was
vulnerable to problems due to concurrent updates.
This appears to be the only osd tree updating path that has this
problem. It can be fairly easily fixed by moving the call up
a few lines, to just before the request mutex gets dropped
in kick_requests().
This resolves:
http://tracker.ceph.com/issues/5043
Signed-off-by: Alex Elder <elder@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
commit c815797663b72e3ac1736f1886538152bc48e4af upstream.
If a P2P-Device is present and another virtual interface triggers
the connection work, the system crash because it tries to check
if the P2P-Device's netdev (which doesn't exist) is up. Skip any
wdevs that have no netdev to fix this.
Reported-by: YanBo <dreamfly281@gmail.com>
commit c8aa22db0112f640ac6631347f850879c621840b upstream.
Since Eric's commit efe117ab8 ("Speedup ieee80211_remove_interfaces")
there's a bug in mac80211 when it unregisters with AP_VLAN interfaces
up. If the AP_VLAN interface was registered after the AP it belongs
to (which is the typical case) and then we get into this code path,
unregister_netdevice_many() will crash because it isn't prepared to
deal with interfaces being closed in the middle of it. Exactly this
happens though, because we iterate the list, find the AP master this
AP_VLAN belongs to and dev_close() the dependent VLANs. After this,
unregister_netdevice_many() won't pick up the fact that the AP_VLAN
is already down and will do it again, causing a crash.
commit 6211dd12da609bc6893b9c3182630b494737ec4b upstream.
We send direct probe to broadcast address, as some APs do not respond to
unicast PROBE frames when unassociated. Broadcast frames are not acked,
so we can not use that for trigger MLME state machine, but we need to
use old timeout mechanism.
This fixes authentication timed out like below:
[ 1024.671974] wlan6: authenticate with 54:e6:fc:98:63:fe
[ 1024.694125] wlan6: direct probe to 54:e6:fc:98:63:fe (try 1/3)
[ 1024.695450] wlan6: direct probe to 54:e6:fc:98:63:fe (try 2/3)
[ 1024.700586] wlan6: send auth to 54:e6:fc:98:63:fe (try 3/3)
[ 1024.701441] wlan6: authentication with 54:e6:fc:98:63:fe timed out
With fix, we have:
[ 4524.198978] wlan6: authenticate with 54:e6:fc:98:63:fe
[ 4524.220692] wlan6: direct probe to 54:e6:fc:98:63:fe (try 1/3)
[ 4524.421784] wlan6: send auth to 54:e6:fc:98:63:fe (try 2/3)
[ 4524.423272] wlan6: authenticated
[ 4524.423811] wlan6: associate with 54:e6:fc:98:63:fe (try 1/3)
[ 4524.427492] wlan6: RX AssocResp from 54:e6:fc:98:63:fe (capab=0x431 status=0 aid=1)
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit afe3c3fd5392b2f0066930abc5dbd3f4b14a0f13 upstream.
As of f025adf191924e3a75ce80e130afcd2485b53bb8 "sunrpc: Properly decode
kuids and kgids in RPC_AUTH_UNIX credentials" any rpc containing a -1
(0xffff) uid or gid would fail with a badcred error.
Reported symptoms were xmbc clients failing on upgrade of the NFS
server; examination of the network trace showed them sending -1 as the
gid.
Reported-by: Julian Sikorski <belegdol@gmail.com>
Tested-by: Julian Sikorski <belegdol@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit a3c3cac5d31879cd9ae2de7874dc6544ca704aec upstream.
The lockless RPC_IS_QUEUED() test in __rpc_execute means that we need to
be careful about ordering the calls to rpc_test_and_set_running(task) and
rpc_clear_queued(task). If we get the order wrong, then we may end up
testing the RPC_TASK_RUNNING flag after __rpc_execute() has looped
and changed the state of the rpc_task.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 2b9ccd4e4308272e5aec614b77c5385e7ec2ec90 upstream.
In AP mode, ignore frames with mis-matched BSSID that aren't
multicast or sent to the correct destination. This fixes
reporting public action frames to userspace multiple times
on multiple virtual AP interfaces.
Reported-by: Jouni Malinen <j@w1.fi>
commit 655914ab863bcc06c84270e4159fd59002d6b529 upstream.
ieee80211_get_tkip_p2k() may be called with interrupts
disabled, so spin_unlock_bh() isn't safe and leads to
warnings. Since it's always called with BHs disabled
already, just use spin_lock().
Reported-by: Milan Kocian <milon@wq.cz>
Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit e248ad30204eff6559b4d2d94d49d9d46c08185a upstream.
The code sending the current WoWLAN TCP wakeup settings in
nl80211_send_wowlan_tcp() is not closing the nested attribute,
thus causing the parser to get confused on the receiver side
in userspace (iw). Fix this.
Reported-by: Deepak Arora <deepakx.arora@intel.com>
commit 03cd7e4e1ea16cd151c799a33b5ca1fd41a464df upstream.
If rfkill_register() fails in wiphy_register() the struct device
is unregistered but everything else isn't (regulatory, debugfs)
and we even leave the wiphy instance on all internal lists even
though it will likely be freed soon, which is clearly a problem.
Fix this by cleaning up properly.
commit a92eecbbeaf01ea2267751569dd3301248513915 upstream.
If the device reports a non-wireless wakeup reason, the
tracing code crashes trying to dereference a NULL pointer.
Fix this by checking the pointer on all accesses and also
add a non_wireless tag to the event.
commit 22ee3b57c3ff71772b0c4178404b04f5df78d501 upstream.
If gcc (e.g. 4.1.2) decides not to inline vsock_init_tables(), this will
cause a section mismatch:
WARNING: net/vmw_vsock/vsock.o(.text+0x1bc): Section mismatch in reference from the function __vsock_core_init() to the function .init.text:vsock_init_tables()
The function __vsock_core_init() references
the function __init vsock_init_tables().
This is often because __vsock_core_init lacks a __init
annotation or the annotation of vsock_init_tables is wrong.
This may cause crashes if VSOCKETS=y and VMWARE_VMCI_VSOCKETS=m.
[ Upstream commit 84c4a9dfbf430861e7588d95ae3ff61535dca351 ]
We forget to call dev_put() on error path in xfrm6_fill_dst(),
its caller doesn't handle this.
Signed-off-by: Cong Wang <amwang@redhat.com>
[ Upstream commit 5dbd5068430b8bd1c19387d46d6c1a88b261257f ]
There is a hole in struct ip6_tnl_parm2, so we have to
zero the struct on stack before copying it to user-space.
[ Upstream commit f77d602124d865c38705df7fa25c03de9c284ad2 ]
We have seen multiple NULL dereferences in __inet6_lookup_established()
After analysis, I found that inet6_sk() could be NULL while the
check for sk_family == AF_INET6 was true.
Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP
and TCP stacks.
Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash
table, we no longer can clear pinet6 field.
This patch extends logic used in commit fcbdf09d9652c891
("net: fix nulls list corruptions in sk_prot_alloc")
TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method
to make sure we do not clear pinet6 field.
At socket clone phase, we do not really care, as cloning the parent (non
NULL) pinet6 is not adding a fatal race.
[ Upstream commit b56141ab34e2c3e2d7960cea12c20c99530c0c76 ]
This patch fixes race between inet_frag_lru_move() and inet_frag_lru_add()
which was introduced in commit 3ef0eb0db4bf92c6d2510fe5c4dc51852746f206
("net: frag, move LRU list maintenance outside of rwlock")
One cpu already added new fragment queue into hash but not into LRU.
Other cpu found it in hash and tries to move it to the end of LRU.
This leads to NULL pointer dereference inside of list_move_tail().
Another possible race condition is between inet_frag_lru_move() and
inet_frag_lru_del(): move can happens after deletion.
This patch initializes LRU list head before adding fragment into hash and
inet_frag_lru_move() doesn't touches it if it's empty.
I saw this kernel oops two times in a couple of days.
[119482.128853] BUG: unable to handle kernel NULL pointer dereference at (null)
[119482.132693] IP: [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.136456] PGD 2148f6067 PUD 215ab9067 PMD 0
[119482.140221] Oops: 0000 [#1] SMP
[119482.144008] Modules linked in: vfat msdos fat 8021q fuse nfsd auth_rpcgss nfs_acl nfs lockd sunrpc ppp_async ppp_generic bridge slhc stp llc w83627ehf hwmon_vid snd_hda_codec_hdmi snd_hda_codec_realtek kvm_amd k10temp kvm snd_hda_intel snd_hda_codec edac_core radeon snd_hwdep ath9k snd_pcm ath9k_common snd_page_alloc ath9k_hw snd_timer snd soundcore drm_kms_helper ath ttm r8169 mii
[119482.152692] CPU 3
[119482.152721] Pid: 20, comm: ksoftirqd/3 Not tainted 3.9.0-zurg-00001-g9f95269 #132 To Be Filled By O.E.M. To Be Filled By O.E.M./RS880D
[119482.161478] RIP: 0010:[<ffffffff812ede89>] [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.166004] RSP: 0018:ffff880216d5db58 EFLAGS: 00010207
[119482.170568] RAX: 0000000000000000 RBX: ffff88020882b9c0 RCX: dead000000200200
[119482.175189] RDX: 0000000000000000 RSI: 0000000000000880 RDI: ffff88020882ba00
[119482.179860] RBP: ffff880216d5db58 R08: ffffffff8155c7f0 R09: 0000000000000014
[119482.184570] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88020882ba00
[119482.189337] R13: ffffffff81c8d780 R14: ffff880204357f00 R15: 00000000000005a0
[119482.194140] FS: 00007f58124dc700(0000) GS:ffff88021fcc0000(0000) knlGS:0000000000000000
[119482.198928] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[119482.203711] CR2: 0000000000000000 CR3: 00000002155f0000 CR4: 00000000000007e0
[119482.208533] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[119482.213371] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[119482.218221] Process ksoftirqd/3 (pid: 20, threadinfo ffff880216d5c000, task ffff880216d3a9a0)
[119482.223113] Stack:
[119482.228004] ffff880216d5dbd8 ffffffff8155dcda 0000000000000000 ffff000200000001
[119482.233038] ffff8802153c1f00 ffff880000289440 ffff880200000014 ffff88007bc72000
[119482.238083] 00000000000079d5 ffff88007bc72f44 ffffffff00000002 ffff880204357f00
[119482.243090] Call Trace:
[119482.248009] [<ffffffff8155dcda>] ip_defrag+0x8fa/0xd10
[119482.252921] [<ffffffff815a8013>] ipv4_conntrack_defrag+0x83/0xe0
[119482.257803] [<ffffffff8154485b>] nf_iterate+0x8b/0xa0
[119482.262658] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40
[119482.267527] [<ffffffff815448e4>] nf_hook_slow+0x74/0x130
[119482.272412] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40
[119482.277302] [<ffffffff8155d068>] ip_rcv+0x268/0x320
[119482.282147] [<ffffffff81519992>] __netif_receive_skb_core+0x612/0x7e0
[119482.286998] [<ffffffff81519b78>] __netif_receive_skb+0x18/0x60
[119482.291826] [<ffffffff8151a650>] process_backlog+0xa0/0x160
[119482.296648] [<ffffffff81519f29>] net_rx_action+0x139/0x220
[119482.301403] [<ffffffff81053707>] __do_softirq+0xe7/0x220
[119482.306103] [<ffffffff81053868>] run_ksoftirqd+0x28/0x40
[119482.310809] [<ffffffff81074f5f>] smpboot_thread_fn+0xff/0x1a0
[119482.315515] [<ffffffff81074e60>] ? lg_local_lock_cpu+0x40/0x40
[119482.320219] [<ffffffff8106d870>] kthread+0xc0/0xd0
[119482.324858] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40
[119482.329460] [<ffffffff816c32dc>] ret_from_fork+0x7c/0xb0
[119482.334057] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40
[119482.338661] Code: 00 00 55 48 8b 17 48 b9 00 01 10 00 00 00 ad de 48 8b 47 08 48 89 e5 48 39 ca 74 29 48 b9 00 02 20 00 00 00 ad de 48 39 c8 74 7a <4c> 8b 00 4c 39 c7 75 53 4c 8b 42 08 4c 39 c7 75 2b 48 89 42 08
[119482.343787] RIP [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.348675] RSP <ffff880216d5db58>
[119482.353493] CR2: 0000000000000000
Oops happened on this path:
ip_defrag() -> ip_frag_queue() -> inet_frag_lru_move() -> list_move_tail() -> __list_del_entry()
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Florian Westphal <fw@strlen.de>
Acked-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit 8da3056c04bfc5f69f840ab038a38389e2de8189 ]
Jakub reported that it is fairly easy to trigger the BUG() macro
from user space with TPACKET_V3's RX_RING by just giving a wrong
header status flag. We already had a similar situation in commit
7f5c3e3a80e6654 (``af_packet: remove BUG statement in
tpacket_destruct_skb'') where this was the case in the TX_RING
side that could be triggered from user space. So really, don't use
BUG() or BUG_ON() unless there's really no way out, and i.e.
don't use it for consistency checking when there's user space
involved, no excuses, especially not if you're slapping the user
with WARN + dump_stack + BUG all at once. The two functions are
of concern:
prb_retire_current_block() [when block status != TP_STATUS_KERNEL]
prb_open_block() [when block_status != TP_STATUS_KERNEL]
Calls to prb_open_block() are guarded by ealier checks if block_status
is really TP_STATUS_KERNEL (racy!), but the first one BUG() is easily
triggable from user space. System behaves still stable after they are
removed. Also remove that yoda condition entirely, since it's already
guarded.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
[ Upstream commit 83401eb4990ff6af55aeed8f49681558544192e6 ]
A bridge should only send topology change notice if it is not
the root bridge. It is possible for message age timer to elect itself
as a new root bridge, and still have a topology change timer running
but waiting for bridge lock on other CPU.
Solve the race by checking if we are root bridge before continuing.
This was the root cause of the cases where br_send_tcn_bpdu would OOPS.
Reported-by: JerryKang <jerry.kang@samsung.com>
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit b29d3145183da4e07d4b570fa8acdd3ac4a5c572 ]
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 6708c9e5cc9bfc7c9a00ce9c0fdd0b1d4952b3d1 ]
[ Upstream commit 0dcffd09641f3abb21ac5cabc61542ab289d1a3c ]
Deal with changes in newer xtables while maintaining backward
compatibility. Thanks to Jan Engelhardt for suggestions.
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
