path: root/net
2017-07-05netfilter: use skb_to_full_sk in ip_route_me_harderFlorian Westphal
commit 29e09229d9f26129a39462fae0ddabc4d9533989 upstream. inet_sk(skb->sk) is illegal in case skb is attached to request socket. Fixes: ca6fb0651883 ("tcp: attach SYNACK messages to request sockets instead of listener") Reported by: Daniel J Blueman <daniel@quora.org> Signed-off-by: Florian Westphal <fw@strlen.de> Tested-by: Daniel J Blueman <daniel@quora.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05xfrm: Oops on error in pfkey_msg2xfrm_state()Dan Carpenter
commit 1e3d0c2c70cd3edb5deed186c5f5c75f2b84a633 upstream. There are some missing error codes here so we accidentally return NULL instead of an error pointer. It results in a NULL pointer dereference. Fixes: df71837d5024 ("[LSM-IPSec]: Security association restriction.") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05xfrm: NULL dereference on allocation failureDan Carpenter
commit e747f64336fc15e1c823344942923195b800aa1e upstream. The default error code in pfkey_msg2xfrm_state() is -ENOBUFS. We added a new call to security_xfrm_state_alloc() which sets "err" to zero so there several places where we can return ERR_PTR(0) if kmalloc() fails. The caller is expecting error pointers so it leads to a NULL dereference. Fixes: df71837d5024 ("[LSM-IPSec]: Security association restriction.") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05xfrm: fix stack access out of bounds with CONFIG_XFRM_SUB_POLICYSabrina Dubroca
commit 9b3eb54106cf6acd03f07cf0ab01c13676a226c2 upstream. When CONFIG_XFRM_SUB_POLICY=y, xfrm_dst stores a copy of the flowi for that dst. Unfortunately, the code that allocates and fills this copy doesn't care about what type of flowi (flowi, flowi4, flowi6) gets passed. In multiple code paths (from raw_sendmsg, from TCP when replying to a FIN, in vxlan, geneve, and gre), the flowi that gets passed to xfrm is actually an on-stack flowi4, so we end up reading stuff from the stack past the end of the flowi4 struct. Since xfrm_dst->origin isn't used anywhere following commit ca116922afa8 ("xfrm: Eliminate "fl" and "pol" args to xfrm_bundle_ok()."), just get rid of it. xfrm_dst->partner isn't used either, so get rid of that too. Fixes: 9d6ec938019c ("ipv4: Use flowi4 in public route lookup interfaces.") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05ip6_tunnel, ip6_gre: fix setting of DSCP on encapsulated packetsPeter Dawson
[ Upstream commit 0e9a709560dbcfbace8bf4019dc5298619235891 ] This fix addresses two problems in the way the DSCP field is formulated on the encapsulating header of IPv6 tunnels. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195661 1) The IPv6 tunneling code was manipulating the DSCP field of the encapsulating packet using the 32b flowlabel. Since the flowlabel is only the lower 20b it was incorrect to assume that the upper 12b containing the DSCP and ECN fields would remain intact when formulating the encapsulating header. This fix handles the 'inherit' and 'fixed-value' DSCP cases explicitly using the extant dsfield u8 variable. 2) The use of INET_ECN_encapsulate(0, dsfield) in ip6_tnl_xmit was incorrect and resulted in the DSCP value always being set to 0. Commit 90427ef5d2a4 ("ipv6: fix flow labels when the traffic class is non-0") caused the regression by masking out the flowlabel which exposed the incorrect handling of the DSCP portion of the flowlabel in ip6_tunnel and ip6_gre. Fixes: 90427ef5d2a4 ("ipv6: fix flow labels when the traffic class is non-0") Signed-off-by: Peter Dawson <peter.a.dawson@boeing.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05sctp: check af before verify address in sctp_addr_id2transportXin Long
[ Upstream commit 912964eacb111551db73429719eb5fadcab0ff8a ] Commit 6f29a1306131 ("sctp: sctp_addr_id2transport should verify the addr before looking up assoc") invoked sctp_verify_addr to verify the addr. But it didn't check af variable beforehand, once users pass an address with family = 0 through sockopt, sctp_get_af_specific will return NULL and NULL pointer dereference will be caused by af->sockaddr_len. This patch is to fix it by returning NULL if af variable is NULL. Fixes: 6f29a1306131 ("sctp: sctp_addr_id2transport should verify the addr before looking up assoc") Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05tipc: allocate user memory with GFP_KERNEL flagParthasarathy Bhuvaragan
[ Upstream commit 57d5f64d83ab5b5a5118b1597386dd76eaf4340d ] Until now, we allocate memory always with GFP_ATOMIC flag. When the system is under memory pressure and a user tries to send, the send fails due to low memory. However, the user application can wait for free memory if we allocate it using GFP_KERNEL flag. In this commit, we use allocate memory with GFP_KERNEL for all user allocation. Reported-by: Rune Torgersen <runet@innovsys.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05mac80211: initialize SMPS field in HT capabilitiesFelix Fietkau
[ Upstream commit 43071d8fb3b7f589d72663c496a6880fb097533c ] ibss and mesh modes copy the ht capabilites from the band without overriding the SMPS state. Unfortunately the default value 0 for the SMPS field means static SMPS instead of disabled. This results in HT ibss and mesh setups using only single-stream rates, even though SMPS is not supposed to be active. Initialize SMPS to disabled for all bands on ieee80211_hw_register to ensure that the value is sane where it is not overriden with the real SMPS state. Reported-by: Elektra Wagenrad <onelektra@gmx.net> Signed-off-by: Felix Fietkau <nbd@nbd.name> [move VHT TODO comment to a better place] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05mac80211: recalculate min channel width on VHT opmode changesJohannes Berg
[ Upstream commit d2941df8fbd9708035d66d889ada4d3d160170ce ] When an associated station changes its VHT operating mode this can/will affect the bandwidth it's using, and consequently we must recalculate the minimum bandwidth we need to use. Failure to do so can lead to one of two scenarios: 1) we use a too high bandwidth, this is benign 2) we use a too narrow bandwidth, causing rate control and actual PHY configuration to be out of sync, which can in turn cause problems/crashes Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05ip6_tunnel: must reload ipv6h in ip6ip6_tnl_xmit()Eric Dumazet
[ Upstream commit 21b995a9cb093fff33ec91d7cb3822b882a90a1e ] Since ip6_tnl_parse_tlv_enc_lim() can call pskb_may_pull(), we must reload any pointer that was related to skb->head (or skb->data), or risk use after free. Fixes: c12b395a4664 ("gre: Support GRE over IPv6") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05net: dsa: Check return value of phy_connect_direct()Florian Fainelli
[ Upstream commit 4078b76cac68e50ccf1f76a74e7d3d5788aec3fe ] We need to check the return value of phy_connect_direct() in dsa_slave_phy_connect() otherwise we may be continuing the initialization of a slave network device with a PHY that already attached somewhere else and which will soon be in error because the PHY device is in error. The conditions for such an error to occur are that we have a port of our switch that is not disabled, and has the same port number as a PHY address (say both 5) that can be probed using the DSA slave MII bus. We end-up having this slave network device find a PHY at the same address as our port number, and we try to attach to it. A slave network (e.g: port 0) has already attached to our PHY device, and we try to re-attach it with a different network device, but since we ignore the error we would end-up initializating incorrect device references by the time the slave network interface is opened. The code has been (re)organized several times, making it hard to provide an exact Fixes tag, this is a bugfix nonetheless. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05net: ethtool: Initialize buffer when querying device channel settingsEran Ben Elisha
[ Upstream commit 31a86d137219373c3222ca5f4f912e9a4d8065bb ] Ethtool channels respond struct was uninitialized when querying device channel boundaries settings. As a result, unreported fields by the driver hold garbage. This may cause sending unsupported params to driver. Fixes: 8bf368620486 ('ethtool: ensure channel counts are within bounds ...') Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com> Signed-off-by: Tariq Toukan <tariqt@mellanox.com> CC: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05l2tp: take a reference on sessions used in genetlink handlersGuillaume Nault
commit 2777e2ab5a9cf2b4524486c6db1517a6ded25261 upstream. Callers of l2tp_nl_session_find() need to hold a reference on the returned session since there's no guarantee that it isn't going to disappear from under them. Relying on the fact that no l2tp netlink message may be processed concurrently isn't enough: sessions can be deleted by other means (e.g. by closing the PPPOL2TP socket of a ppp pseudowire). l2tp_nl_cmd_session_delete() is a bit special: it runs a callback function that may require a previous call to session->ref(). In particular, for ppp pseudowires, the callback is l2tp_session_delete(), which then calls pppol2tp_session_close() and dereferences the PPPOL2TP socket. The socket might already be gone at the moment l2tp_session_delete() calls session->ref(), so we need to take a reference during the session lookup. So we need to pass the do_ref variable down to l2tp_session_get() and l2tp_session_get_by_ifname(). Since all callers have to be updated, l2tp_session_find_by_ifname() and l2tp_nl_session_find() are renamed to reflect their new behaviour. Fixes: 309795f4bec2 ("l2tp: Add netlink control API for L2TP") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05l2tp: hold session while sending creation notificationsGuillaume Nault
commit 5e6a9e5a3554a5b3db09cdc22253af1849c65dff upstream. l2tp_session_find() doesn't take any reference on the returned session. Therefore, the session may disappear while sending the notification. Use l2tp_session_get() instead and decrement session's refcount once the notification is sent. Fixes: 33f72e6f0c67 ("l2tp : multicast notification to the registered listeners") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05l2tp: fix duplicate session creationGuillaume Nault
commit dbdbc73b44782e22b3b4b6e8b51e7a3d245f3086 upstream. l2tp_session_create() relies on its caller for checking for duplicate sessions. This is racy since a session can be concurrently inserted after the caller's verification. Fix this by letting l2tp_session_create() verify sessions uniqueness upon insertion. Callers need to be adapted to check for l2tp_session_create()'s return code instead of calling l2tp_session_find(). pppol2tp_connect() is a bit special because it has to work on existing sessions (if they're not connected) or to create a new session if none is found. When acting on a preexisting session, a reference must be held or it could go away on us. So we have to use l2tp_session_get() instead of l2tp_session_find() and drop the reference before exiting. Fixes: d9e31d17ceba ("l2tp: Add L2TP ethernet pseudowire support") Fixes: fd558d186df2 ("l2tp: Split pppol2tp patch into separate l2tp and ppp parts") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05l2tp: ensure session can't get removed during pppol2tp_session_ioctl()Guillaume Nault
commit 57377d63547861919ee634b845c7caa38de4a452 upstream. Holding a reference on session is required before calling pppol2tp_session_ioctl(). The session could get freed while processing the ioctl otherwise. Since pppol2tp_session_ioctl() uses the session's socket, we also need to take a reference on it in l2tp_session_get(). Fixes: fd558d186df2 ("l2tp: Split pppol2tp patch into separate l2tp and ppp parts") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05l2tp: fix race in l2tp_recv_common()Guillaume Nault
commit 61b9a047729bb230978178bca6729689d0c50ca2 upstream. Taking a reference on sessions in l2tp_recv_common() is racy; this has to be done by the callers. To this end, a new function is required (l2tp_session_get()) to atomically lookup a session and take a reference on it. Callers then have to manually drop this reference. Fixes: fd558d186df2 ("l2tp: Split pppol2tp patch into separate l2tp and ppp parts") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05netfilter: synproxy: fix conntrackd interactionEric Leblond
commit 87e94dbc210a720a34be5c1174faee5c84be963e upstream. This patch fixes the creation of connection tracking entry from netlink when synproxy is used. It was missing the addition of the synproxy extension. This was causing kernel crashes when a conntrack entry created by conntrackd was used after the switch of traffic from active node to the passive node. Signed-off-by: Eric Leblond <eric@regit.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05netfilter: xt_TCPMSS: add more sanity tests on tcph->doffEric Dumazet
commit 2638fd0f92d4397884fd991d8f4925cb3f081901 upstream. Denys provided an awesome KASAN report pointing to an use after free in xt_TCPMSS I have provided three patches to fix this issue, either in xt_TCPMSS or in xt_tcpudp.c. It seems xt_TCPMSS patch has the smallest possible impact. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Denys Fedoryshchenko <nuclearcat@nuclearcat.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05rtnetlink: add IFLA_GROUP to ifla_policySerhey Popovych
[ Upstream commit db833d40ad3263b2ee3b59a1ba168bb3cfed8137 ] Network interface groups support added while ago, however there is no IFLA_GROUP attribute description in policy and netlink message size calculations until now. Add IFLA_GROUP attribute to the policy. Fixes: cbda10fa97d7 ("net_device: add support for network device groups") Signed-off-by: Serhey Popovych <serhe.popovych@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05ipv6: Do not leak throw route referencesSerhey Popovych
[ Upstream commit 07f615574f8ac499875b21c1142f26308234a92c ] While commit 73ba57bfae4a ("ipv6: fix backtracking for throw routes") does good job on error propagation to the fib_rules_lookup() in fib rules core framework that also corrects throw routes handling, it does not solve route reference leakage problem happened when we return -EAGAIN to the fib_rules_lookup() and leave routing table entry referenced in arg->result. If rule with matched throw route isn't last matched in the list we overwrite arg->result losing reference on throw route stored previously forever. We also partially revert commit ab997ad40839 ("ipv6: fix the incorrect return value of throw route") since we never return routing table entry with dst.error == -EAGAIN when CONFIG_IPV6_MULTIPLE_TABLES is on. Also there is no point to check for RTF_REJECT flag since it is always set throw route. Fixes: 73ba57bfae4a ("ipv6: fix backtracking for throw routes") Signed-off-by: Serhey Popovych <serhe.popovych@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05net: 8021q: Fix one possible panic caused by BUG_ON in free_netdevGao Feng
[ Upstream commit 9745e362add89432d2c951272a99b0a5fe4348a9 ] The register_vlan_device would invoke free_netdev directly, when register_vlan_dev failed. It would trigger the BUG_ON in free_netdev if the dev was already registered. In this case, the netdev would be freed in netdev_run_todo later. So add one condition check now. Only when dev is not registered, then free it directly. The following is the part coredump when netdev_upper_dev_link failed in register_vlan_dev. I removed the lines which are too long. [ 411.237457] ------------[ cut here ]------------ [ 411.237458] kernel BUG at net/core/dev.c:7998! [ 411.237484] invalid opcode: 0000 [#1] SMP [ 411.237705] [last unloaded: 8021q] [ 411.237718] CPU: 1 PID: 12845 Comm: vconfig Tainted: G E 4.12.0-rc5+ #6 [ 411.237737] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015 [ 411.237764] task: ffff9cbeb6685580 task.stack: ffffa7d2807d8000 [ 411.237782] RIP: 0010:free_netdev+0x116/0x120 [ 411.237794] RSP: 0018:ffffa7d2807dbdb0 EFLAGS: 00010297 [ 411.237808] RAX: 0000000000000002 RBX: ffff9cbeb6ba8fd8 RCX: 0000000000001878 [ 411.237826] RDX: 0000000000000001 RSI: 0000000000000282 RDI: 0000000000000000 [ 411.237844] RBP: ffffa7d2807dbdc8 R08: 0002986100029841 R09: 0002982100029801 [ 411.237861] R10: 0004000100029980 R11: 0004000100029980 R12: ffff9cbeb6ba9000 [ 411.238761] R13: ffff9cbeb6ba9060 R14: ffff9cbe60f1a000 R15: ffff9cbeb6ba9000 [ 411.239518] FS: 00007fb690d81700(0000) GS:ffff9cbebb640000(0000) knlGS:0000000000000000 [ 411.239949] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 411.240454] CR2: 00007f7115624000 CR3: 0000000077cdf000 CR4: 00000000003406e0 [ 411.240936] Call Trace: [ 411.241462] vlan_ioctl_handler+0x3f1/0x400 [8021q] [ 411.241910] sock_ioctl+0x18b/0x2c0 [ 411.242394] do_vfs_ioctl+0xa1/0x5d0 [ 411.242853] ? sock_alloc_file+0xa6/0x130 [ 411.243465] SyS_ioctl+0x79/0x90 [ 411.243900] entry_SYSCALL_64_fastpath+0x1e/0xa9 [ 411.244425] RIP: 0033:0x7fb69089a357 [ 411.244863] RSP: 002b:00007ffcd04e0fc8 EFLAGS: 00000202 ORIG_RAX: 0000000000000010 [ 411.245445] RAX: ffffffffffffffda RBX: 00007ffcd04e2884 RCX: 00007fb69089a357 [ 411.245903] RDX: 00007ffcd04e0fd0 RSI: 0000000000008983 RDI: 0000000000000003 [ 411.246527] RBP: 00007ffcd04e0fd0 R08: 0000000000000000 R09: 1999999999999999 [ 411.246976] R10: 000000000000053f R11: 0000000000000202 R12: 0000000000000004 [ 411.247414] R13: 00007ffcd04e1128 R14: 00007ffcd04e2888 R15: 0000000000000001 [ 411.249129] RIP: free_netdev+0x116/0x120 RSP: ffffa7d2807dbdb0 Signed-off-by: Gao Feng <gfree.wind@vip.163.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05decnet: always not take dst->__refcnt when inserting dst into hash tableWei Wang
[ Upstream commit 76371d2e3ad1f84426a30ebcd8c3b9b98f4c724f ] In the existing dn_route.c code, dn_route_output_slow() takes dst->__refcnt before calling dn_insert_route() while dn_route_input_slow() does not take dst->__refcnt before calling dn_insert_route(). This makes the whole routing code very buggy. In dn_dst_check_expire(), dnrt_free() is called when rt expires. This makes the routes inserted by dn_route_output_slow() not able to be freed as the refcnt is not released. In dn_dst_gc(), dnrt_drop() is called to release rt which could potentially cause the dst->__refcnt to be dropped to -1. In dn_run_flush(), dst_free() is called to release all the dst. Again, it makes the dst inserted by dn_route_output_slow() not able to be released and also, it does not wait on the rcu and could potentially cause crash in the path where other users still refer to this dst. This patch makes sure both input and output path do not take dst->__refcnt before calling dn_insert_route() and also makes sure dnrt_free()/dst_free() is called when removing dst from the hash table. The only difference between those 2 calls is that dnrt_free() waits on the rcu while dst_free() does not. Signed-off-by: Wei Wang <weiwan@google.com> Acked-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05sctp: return next obj by passing pos + 1 into sctp_transport_get_idxXin Long
[ Upstream commit 988c7322116970696211e902b468aefec95b6ec4 ] In sctp_for_each_transport, pos is used to save how many objs it has dumped. Now it gets the last obj by sctp_transport_get_idx, then gets the next obj by sctp_transport_get_next. The issue is that in the meanwhile if some objs in transport hashtable are removed and the objs nums are less than pos, sctp_transport_get_idx would return NULL and hti.walker.tbl is NULL as well. At this moment it should stop hti, instead of continue getting the next obj. Or it would cause a NULL pointer dereference in sctp_transport_get_next. This patch is to pass pos + 1 into sctp_transport_get_idx to get the next obj directly, even if pos > objs nums, it would return NULL and stop hti. Fixes: 626d16f50f39 ("sctp: export some apis or variables for sctp_diag and reuse some for proc") Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05ipv6: fix calling in6_ifa_hold incorrectly for dad workXin Long
[ Upstream commit f8a894b218138888542a5058d0e902378fd0d4ec ] Now when starting the dad work in addrconf_mod_dad_work, if the dad work is idle and queued, it needs to hold ifa. The problem is there's one gap in [1], during which if the pending dad work is removed elsewhere. It will miss to hold ifa, but the dad word is still idea and queue. if (!delayed_work_pending(&ifp->dad_work)) in6_ifa_hold(ifp); <--------------[1] mod_delayed_work(addrconf_wq, &ifp->dad_work, delay); An use-after-free issue can be caused by this. Chen Wei found this issue when WARN_ON(!hlist_unhashed(&ifp->addr_lst)) in net6_ifa_finish_destroy was hit because of it. As Hannes' suggestion, this patch is to fix it by holding ifa first in addrconf_mod_dad_work, then calling mod_delayed_work and putting ifa if the dad_work is already in queue. Note that this patch did not choose to fix it with: if (!mod_delayed_work(delay)) in6_ifa_hold(ifp); As with it, when delay == 0, dad_work would be scheduled immediately, all addrconf_mod_dad_work(0) callings had to be moved under ifp->lock. Reported-by: Wei Chen <weichen@redhat.com> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05igmp: add a missing spin_lock_init()WANG Cong
[ Upstream commit b4846fc3c8559649277e3e4e6b5cec5348a8d208 ] Andrey reported a lockdep warning on non-initialized spinlock: INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. CPU: 1 PID: 4099 Comm: a.out Not tainted 4.12.0-rc6+ #9 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 dump_stack+0x292/0x395 lib/dump_stack.c:52 register_lock_class+0x717/0x1aa0 kernel/locking/lockdep.c:755 ? 0xffffffffa0000000 __lock_acquire+0x269/0x3690 kernel/locking/lockdep.c:3255 lock_acquire+0x22d/0x560 kernel/locking/lockdep.c:3855 __raw_spin_lock_bh ./include/linux/spinlock_api_smp.h:135 _raw_spin_lock_bh+0x36/0x50 kernel/locking/spinlock.c:175 spin_lock_bh ./include/linux/spinlock.h:304 ip_mc_clear_src+0x27/0x1e0 net/ipv4/igmp.c:2076 igmpv3_clear_delrec+0xee/0x4f0 net/ipv4/igmp.c:1194 ip_mc_destroy_dev+0x4e/0x190 net/ipv4/igmp.c:1736 We miss a spin_lock_init() in igmpv3_add_delrec(), probably because previously we never use it on this code path. Since we already unlink it from the global mc_tomb list, it is probably safe not to acquire this spinlock here. It does not harm to have it although, to avoid conditional locking. Fixes: c38b7d327aaf ("igmp: acquire pmc lock for ip_mc_clear_src()") Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05igmp: acquire pmc lock for ip_mc_clear_src()WANG Cong
[ Upstream commit c38b7d327aafd1e3ad7ff53eefac990673b65667 ] Andrey reported a use-after-free in add_grec(): for (psf = *psf_list; psf; psf = psf_next) { ... psf_next = psf->sf_next; where the struct ip_sf_list's were already freed by: kfree+0xe8/0x2b0 mm/slub.c:3882 ip_mc_clear_src+0x69/0x1c0 net/ipv4/igmp.c:2078 ip_mc_dec_group+0x19a/0x470 net/ipv4/igmp.c:1618 ip_mc_drop_socket+0x145/0x230 net/ipv4/igmp.c:2609 inet_release+0x4e/0x1c0 net/ipv4/af_inet.c:411 sock_release+0x8d/0x1e0 net/socket.c:597 sock_close+0x16/0x20 net/socket.c:1072 This happens because we don't hold pmc->lock in ip_mc_clear_src() and a parallel mr_ifc_timer timer could jump in and access them. The RCU lock is there but it is merely for pmc itself, this spinlock could actually ensure we don't access them in parallel. Thanks to Eric and Long for discussion on this bug. Reported-by: Andrey Konovalov <andreyknvl@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Xin Long <lucien.xin@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Reviewed-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05proc: snmp6: Use correct type in memsetChristian Perle
[ Upstream commit 3500cd73dff48f28f4ba80c171c4c80034d40f76 ] Reading /proc/net/snmp6 yields bogus values on 32 bit kernels. Use "u64" instead of "unsigned long" in sizeof(). Fixes: 4a4857b1c81e ("proc: Reduce cache miss in snmp6_seq_show") Signed-off-by: Christian Perle <christian.perle@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05net: tipc: Fix a sleep-in-atomic bug in tipc_msg_reverseJia-Ju Bai
[ Upstream commit 343eba69c6968190d8654b857aea952fed9a6749 ] The kernel may sleep under a rcu read lock in tipc_msg_reverse, and the function call path is: tipc_l2_rcv_msg (acquire the lock by rcu_read_lock) tipc_rcv tipc_sk_rcv tipc_msg_reverse pskb_expand_head(GFP_KERNEL) --> may sleep tipc_node_broadcast tipc_node_xmit_skb tipc_node_xmit tipc_sk_rcv tipc_msg_reverse pskb_expand_head(GFP_KERNEL) --> may sleep To fix it, "GFP_KERNEL" is replaced with "GFP_ATOMIC". Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05net: caif: Fix a sleep-in-atomic bug in cfpkt_create_pfxJia-Ju Bai
[ Upstream commit f146e872eb12ebbe92d8e583b2637e0741440db3 ] The kernel may sleep under a rcu read lock in cfpkt_create_pfx, and the function call path is: cfcnfg_linkup_rsp (acquire the lock by rcu_read_lock) cfctrl_linkdown_req cfpkt_create cfpkt_create_pfx alloc_skb(GFP_KERNEL) --> may sleep cfserl_receive (acquire the lock by rcu_read_lock) cfpkt_split cfpkt_create_pfx alloc_skb(GFP_KERNEL) --> may sleep There is "in_interrupt" in cfpkt_create_pfx to decide use "GFP_KERNEL" or "GFP_ATOMIC". In this situation, "GFP_KERNEL" is used because the function is called under a rcu read lock, instead in interrupt. To fix it, only "GFP_ATOMIC" is used in cfpkt_create_pfx. Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05sctp: disable BH in sctp_for_each_endpointXin Long
[ Upstream commit 581409dacc9176b0de1f6c4ca8d66e13aa8e1b29 ] Now sctp holds read_lock when foreach sctp_ep_hashtable without disabling BH. If CPU schedules to another thread A at this moment, the thread A may be trying to hold the write_lock with disabling BH. As BH is disabled and CPU cannot schedule back to the thread holding the read_lock, while the thread A keeps waiting for the read_lock. A dead lock would be triggered by this. This patch is to fix this dead lock by calling read_lock_bh instead to disable BH when holding the read_lock in sctp_for_each_endpoint. Fixes: 626d16f50f39 ("sctp: export some apis or variables for sctp_diag and reuse some for proc") Reported-by: Xiumei Mu <xmu@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05Fix an intermittent pr_emerg warning about lo becoming free.Krister Johansen
[ Upstream commit f186ce61bb8235d80068c390dc2aad7ca427a4c2 ] It looks like this: Message from syslogd@flamingo at Apr 26 00:45:00 ... kernel:unregister_netdevice: waiting for lo to become free. Usage count = 4 They seem to coincide with net namespace teardown. The message is emitted by netdev_wait_allrefs(). Forced a kdump in netdev_run_todo, but found that the refcount on the lo device was already 0 at the time we got to the panic. Used bcc to check the blocking in netdev_run_todo. The only places where we're off cpu there are in the rcu_barrier() and msleep() calls. That behavior is expected. The msleep time coincides with the amount of time we spend waiting for the refcount to reach zero; the rcu_barrier() wait times are not excessive. After looking through the list of callbacks that the netdevice notifiers invoke in this path, it appears that the dst_dev_event is the most interesting. The dst_ifdown path places a hold on the loopback_dev as part of releasing the dev associated with the original dst cache entry. Most of our notifier callbacks are straight-forward, but this one a) looks complex, and b) places a hold on the network interface in question. I constructed a new bcc script that watches various events in the liftime of a dst cache entry. Note that dst_ifdown will take a hold on the loopback device until the invalidated dst entry gets freed. [ __dst_free] on DST: ffff883ccabb7900 IF tap1008300eth0 invoked at 1282115677036183 __dst_free rcu_nocb_kthread kthread ret_from_fork Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05af_unix: Add sockaddr length checks before accessing sa_family in bind and ↵Mateusz Jurczyk
connect handlers [ Upstream commit defbcf2decc903a28d8398aa477b6881e711e3ea ] Verify that the caller-provided sockaddr structure is large enough to contain the sa_family field, before accessing it in bind() and connect() handlers of the AF_UNIX socket. Since neither syscall enforces a minimum size of the corresponding memory region, very short sockaddrs (zero or one byte long) result in operating on uninitialized memory while referencing .sa_family. Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05net: Zero ifla_vf_info in rtnl_fill_vfinfo()Mintz, Yuval
[ Upstream commit 0eed9cf58446b28b233388b7f224cbca268b6986 ] Some of the structure's fields are not initialized by the rtnetlink. If driver doesn't set those in ndo_get_vf_config(), they'd leak memory to user. Signed-off-by: Yuval Mintz <Yuval.Mintz@cavium.com> CC: Michal Schmidt <mschmidt@redhat.com> Reviewed-by: Greg Rose <gvrose8192@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05decnet: dn_rtmsg: Improve input length sanitization in dnrmg_receive_user_skbMateusz Jurczyk
[ Upstream commit dd0da17b209ed91f39872766634ca967c170ada1 ] Verify that the length of the socket buffer is sufficient to cover the nlmsghdr structure before accessing the nlh->nlmsg_len field for further input sanitization. If the client only supplies 1-3 bytes of data in sk_buff, then nlh->nlmsg_len remains partially uninitialized and contains leftover memory from the corresponding kernel allocation. Operating on such data may result in indeterminate evaluation of the nlmsg_len < sizeof(*nlh) expression. The bug was discovered by a runtime instrumentation designed to detect use of uninitialized memory in the kernel. The patch prevents this and other similar tools (e.g. KMSAN) from flagging this behavior in the future. Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05net: don't call strlen on non-terminated string in dev_set_alias()Alexander Potapenko
[ Upstream commit c28294b941232931fbd714099798eb7aa7e865d7 ] KMSAN reported a use of uninitialized memory in dev_set_alias(), which was caused by calling strlcpy() (which in turn called strlen()) on the user-supplied non-terminated string. Signed-off-by: Alexander Potapenko <glider@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05ipv6: release dst on error in ip6_dst_lookup_tailWillem de Bruijn
commit 00ea1ceebe0d9f2dc1cc2b7bd575a00100c27869 upstream. If ip6_dst_lookup_tail has acquired a dst and fails the IPv4-mapped check, release the dst before returning an error. Fixes: ec5e3b0a1d41 ("ipv6: Inhibit IPv4-mapped src address on the wire.") Signed-off-by: Willem de Bruijn <willemb@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-29rxrpc: Fix several cases where a padded len isn't checked in ticket decodeDavid Howells
commit 5f2f97656ada8d811d3c1bef503ced266fcd53a0 upstream. This fixes CVE-2017-7482. When a kerberos 5 ticket is being decoded so that it can be loaded into an rxrpc-type key, there are several places in which the length of a variable-length field is checked to make sure that it's not going to overrun the available data - but the data is padded to the nearest four-byte boundary and the code doesn't check for this extra. This could lead to the size-remaining variable wrapping and the data pointer going over the end of the buffer. Fix this by making the various variable-length data checks use the padded length. Reported-by: 石磊 <shilei-c@360.cn> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Marc Dionne <marc.c.dionne@auristor.com> Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mac80211: don't send SMPS action frame in AP mode when not neededEmmanuel Grumbach
commit b3dd8279659f14f3624bb32559782d699fa6f7d1 upstream. mac80211 allows to modify the SMPS state of an AP both, when it is started, and after it has been started. Such a change will trigger an action frame to all the peers that are currently connected, and will be remembered so that new peers will get notified as soon as they connect (since the SMPS setting in the beacon may not be the right one). This means that we need to remember the SMPS state currently requested as well as the SMPS state that was configured initially (and advertised in the beacon). The former is bss->req_smps and the latter is sdata->smps_mode. Initially, the AP interface could only be started with SMPS_OFF, which means that sdata->smps_mode was SMPS_OFF always. Later, a nl80211 API was added to be able to start an AP with a different AP mode. That code forgot to update bss->req_smps and because of that, if the AP interface was started with SMPS_DYNAMIC, we had: sdata->smps_mode = SMPS_DYNAMIC bss->req_smps = SMPS_OFF That configuration made mac80211 think it needs to fire off an action frame to any new station connecting to the AP in order to let it know that the actual SMPS configuration is SMPS_OFF. Fix that by properly setting bss->req_smps in ieee80211_start_ap. Fixes: f69931748730 ("mac80211: set smps_mode according to ap params") Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mac80211: fix dropped counter in multiqueue RXJohannes Berg
commit e165bc02a02c70e40d5c811c705ba269aeca0497 upstream. In the commit enabling per-CPU station statistics, I inadvertedly copy-pasted some code to update rx_packets and forgot to change it to update rx_dropped_misc. Fix that. This addresses https://bugzilla.kernel.org/show_bug.cgi?id=195953. Fixes: c9c5962b56c1 ("mac80211: enable collecting station statistics per-CPU") Reported-by: Petru-Florin Mihancea <petrum@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mac80211: strictly check mesh address extension modeRajkumar Manoharan
commit 5667c86acf021e6dcf02584408b4484a273ac68f upstream. Mesh forwarding path checks for address extension mode to fetch appropriate proxied address and MPP address. Existing condition that looks for 6 address format is not strict enough so that frames with improper values are processed and invalid entries are added into MPP table. Fix that by adding a stricter check before processing the packet. Per IEEE Std 802.11s-2011 spec. Table 7-6g1 lists address extension mode 0x3 as reserved one. And also Table Table 9-13 does not specify 0x3 as valid address field. Fixes: 9b395bc3be1c ("mac80211: verify that skb data is present") Signed-off-by: Rajkumar Manoharan <rmanohar@qti.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mac80211: fix IBSS presp allocation sizeJohannes Berg
commit f1f3e9e2a50a70de908f9dfe0d870e9cdc67e042 upstream. When VHT IBSS support was added, the size of the extra elements wasn't considered in ieee80211_ibss_build_presp(), which makes it possible that it would overrun the allocated buffer. Fix it by allocating the necessary space. Fixes: abcff6ef01f9 ("mac80211: add VHT support for IBSS") Reported-by: Shaul Triebitz <shaul.triebitz@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mac80211: fix packet statistics for fast-RXJohannes Berg
commit 0328edc77d4f35014b35f32b46be0a7e16aae74f upstream. When adding per-CPU statistics, which added statistics back to mac80211 for the fast-RX path, I evidently forgot to add the "stats->packets++" line. The reason for that is likely that I didn't see it since it's done in defragmentation for the regular RX path. Add the missing line to properly count received packets in the fast-RX case. Fixes: c9c5962b56c1 ("mac80211: enable collecting station statistics per-CPU") Reported-by: Oren Givon <oren.givon@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mac80211: fix CSA in IBSS modeKoen Vandeputte
commit f181d6a3bcc35633facf5f3925699021c13492c5 upstream. Add the missing IBSS capability flag during capability init as it needs to be inserted into the generated beacon in order for CSA to work. Fixes: cd7760e62c2ac ("mac80211: add support for CSA in IBSS mode") Signed-off-by: Piotr Gawlowicz <gawlowicz@tkn.tu-berlin.de> Signed-off-by: Mikołaj Chwalisz <chwalisz@tkn.tu-berlin.de> Tested-by: Koen Vandeputte <koen.vandeputte@ncentric.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mac80211/wpa: use constant time memory comparison for MACsJason A. Donenfeld
commit 98c67d187db7808b1f3c95f2110dd4392d034182 upstream. Otherwise, we enable all sorts of forgeries via timing attack. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: linux-wireless@vger.kernel.org Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mac80211: don't look at the PM bit of BAR framesEmmanuel Grumbach
commit 769dc04db3ed8484798aceb015b94deacc2ba557 upstream. When a peer sends a BAR frame with PM bit clear, we should not modify its PM state as madated by the spec in 802.11-20012 10.2.1.2. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24ila_xlat: add missing hash secret initializationArnd Bergmann
commit 0db47e3d323411beeb6ea97f2c4d19395c91fd8b upstream. While discussing the possible merits of clang warning about unused initialized functions, I found one function that was clearly meant to be called but never actually is. __ila_hash_secret_init() initializes the hash value for the ila locator, apparently this is intended to prevent hash collision attacks, but this ends up being a read-only zero constant since there is no caller. I could find no indication of why it was never called, the earliest patch submission for the module already was like this. If my interpretation is right, we certainly want to backport the patch to stable kernels as well. I considered adding it to the ila_xlat_init callback, but for best effect the random data is read as late as possible, just before it is first used. The underlying net_get_random_once() is already highly optimized to avoid overhead when called frequently. Fixes: 7f00feaf1076 ("ila: Add generic ILA translation facility") Link: https://www.spinics.net/lists/kernel/msg2527243.html Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17netfilter: nft_log: restrict the log prefix length to 127Liping Zhang
[ Upstream commit 5ce6b04ce96896e8a79e6f60740ced911eaac7a4 ] First, log prefix will be truncated to NF_LOG_PREFIXLEN-1, i.e. 127, at nf_log_packet(), so the extra part is useless. Second, after adding a log rule with a very very long prefix, we will fail to dump the nft rules after this _special_ one, but acctually, they do exist. For example: # name_65000=$(printf "%0.sQ" {1..65000}) # nft add rule filter output log prefix "$name_65000" # nft add rule filter output counter # nft add rule filter output counter # nft list chain filter output table ip filter { chain output { type filter hook output priority 0; policy accept; } } So now, restrict the log prefix length to NF_LOG_PREFIXLEN-1. Fixes: 96518518cc41 ("netfilter: add nftables") Signed-off-by: Liping Zhang <zlpnobody@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17netfilter: nf_tables: fix set->nelems counting with no NLM_F_EXCLPablo Neira Ayuso
[ Upstream commit 35d0ac9070ef619e3bf44324375878a1c540387b ] If the element exists and no NLM_F_EXCL is specified, do not bump set->nelems, otherwise we leak one set element slot. This problem amplifies if the set is full since the abort path always decrements the counter for the -ENFILE case too, giving one spare extra slot. Fix this by moving set->nelems update to nft_add_set_elem() after successful element insertion. Moreover, remove the element if the set is full so there is no need to rely on the abort path to undo things anymore. Fixes: c016c7e45ddf ("netfilter: nf_tables: honor NLM_F_EXCL flag in set element insertion") Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17tipc: fix nametbl_lock soft lockup at node/link eventsParthasarathy Bhuvaragan
[ Upstream commit 93f955aad4bacee5acebad141d1a03cd51f27b4e ] We trigger a soft lockup as we grab nametbl_lock twice if the node has a pending node up/down or link up/down event while: - we process an incoming named message in tipc_named_rcv() and perform an tipc_update_nametbl(). - we have pending backlog items in the name distributor queue during a nametable update using tipc_nametbl_publish() or tipc_nametbl_withdraw(). The following are the call chain associated: tipc_named_rcv() Grabs nametbl_lock tipc_update_nametbl() (publish/withdraw) tipc_node_subscribe()/unsubscribe() tipc_node_write_unlock() << lockup occurs if an outstanding node/link event exits, as we grabs nametbl_lock again >> tipc_nametbl_withdraw() Grab nametbl_lock tipc_named_process_backlog() tipc_update_nametbl() << rest as above >> The function tipc_node_write_unlock(), in addition to releasing the lock processes the outstanding node/link up/down events. To do this, we need to grab the nametbl_lock again leading to the lockup. In this commit we fix the soft lockup by introducing a fast variant of node_unlock(), where we just release the lock. We adapt the node_subscribe()/node_unsubscribe() to use the fast variants. Reported-and-Tested-by: John Thompson <thompa.atl@gmail.com> Acked-by: Ying Xue <ying.xue@windriver.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
