[ Upstream commit 008ba2a13f2d04c947adc536d19debb8fe66f110 ]
Packet socket bind operations must hold the po->bind_lock. This keeps
po->running consistent with whether the socket is actually on a ptype
list to receive packets.
fanout_add unbinds a socket and its packet_rcv/tpacket_rcv call, then
binds the fanout object to receive through packet_rcv_fanout.
Make it hold the po->bind_lock when testing po->running and rebinding.
Else, it can race with other rebind operations, such as that in
packet_set_ring from packet_rcv to tpacket_rcv. Concurrent updates
can result in a socket being added to a fanout group twice, causing
use-after-free KASAN bug reports, among others.
Reported independently by both trinity and syzkaller.
Verified that the syzkaller reproducer passes after this patch.
Fixes: dc99f600698d ("packet: Add fanout support.")
Reported-by: nixioaming <nixiaoming@huawei.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit b5b7db8d680464b1d631fd016f5e093419f0bfd9 ]
Our recent change exposed a bug in TCP Fastopen Client that syzkaller
found right away [1]
When we prepare skb with SYN+DATA, we attempt to transmit it,
and we update socket state as if the transmit was a success.
In socket RTX queue we have two skbs, one with the SYN alone,
and a second one containing the DATA.
When (malicious) ACK comes in, we now complain that second one had no
skb_mstamp.
The proper fix is to make sure that if the transmit failed, we do not
pretend we sent the DATA skb, and make it our send_head.
When 3WHS completes, we can now send the DATA right away, without having
to wait for a timeout.
[1]
WARNING: CPU: 0 PID: 100189 at net/ipv4/tcp_input.c:3117 tcp_clean_rtx_queue+0x2057/0x2ab0 net/ipv4/tcp_input.c:3117()
WARN_ON_ONCE(last_ackt == 0);
Modules linked in:
CPU: 0 PID: 100189 Comm: syz-executor1 Not tainted
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
0000000000000000 ffff8800b35cb1d8 ffffffff81cad00d 0000000000000000
ffffffff828a4347 ffff88009f86c080 ffffffff8316eb20 0000000000000d7f
ffff8800b35cb220 ffffffff812c33c2 ffff8800baad2440 00000009d46575c0
Call Trace:
[<ffffffff81cad00d>] __dump_stack
[<ffffffff81cad00d>] dump_stack+0xc1/0x124
[<ffffffff812c33c2>] warn_slowpath_common+0xe2/0x150
[<ffffffff812c361e>] warn_slowpath_null+0x2e/0x40
[<ffffffff828a4347>] tcp_clean_rtx_queue+0x2057/0x2ab0 n
[<ffffffff828ae6fd>] tcp_ack+0x151d/0x3930
[<ffffffff828baa09>] tcp_rcv_state_process+0x1c69/0x4fd0
[<ffffffff828efb7f>] tcp_v4_do_rcv+0x54f/0x7c0
[<ffffffff8258aacb>] sk_backlog_rcv
[<ffffffff8258aacb>] __release_sock+0x12b/0x3a0
[<ffffffff8258ad9e>] release_sock+0x5e/0x1c0
[<ffffffff8294a785>] inet_wait_for_connect
[<ffffffff8294a785>] __inet_stream_connect+0x545/0xc50
[<ffffffff82886f08>] tcp_sendmsg_fastopen
[<ffffffff82886f08>] tcp_sendmsg+0x2298/0x35a0
[<ffffffff82952515>] inet_sendmsg+0xe5/0x520
[<ffffffff8257152f>] sock_sendmsg_nosec
[<ffffffff8257152f>] sock_sendmsg+0xcf/0x110
Fixes: 8c72c65b426b ("tcp: update skb->skb_mstamp more carefully")
Fixes: 783237e8daf1 ("net-tcp: Fast Open client - sending SYN-data")
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 3ff4cbec87da48b0ec1f7b6196607b034de0c680 ]
this script, edited from Linux Advanced Routing and Traffic Control guide
tc q a dev en0 root handle 1: htb default a
tc c a dev en0 parent 1: classid 1:1 htb rate 6mbit burst 15k
tc c a dev en0 parent 1:1 classid 1:a htb rate 5mbit ceil 6mbit burst 15k
tc c a dev en0 parent 1:1 classid 1:b htb rate 1mbit ceil 6mbit burst 15k
tc f a dev en0 parent 1:0 prio 1 $clsname $clsargs classid 1:b
ping $address -c1
tc -s c s dev en0
classifies traffic to 1:b or 1:a, depending on whether the packet matches
or not the pattern $clsargs of filter $clsname. However, when $clsname is
'matchall', a systematic crash can be observed in htb_classify(). HTB and
classful qdiscs don't assign initial value to struct tcf_result, but then
they expect it to contain valid values after filters have been run. Thus,
current 'matchall' ignores the TCA_MATCHALL_CLASSID attribute, configured
by user, and makes HTB (and classful qdiscs) dereference random pointers.
By assigning head->res to *res in mall_classify(), before the actions are
invoked, we fix this crash and enable TCA_MATCHALL_CLASSID functionality,
that had no effect on 'matchall' classifier since its first introduction.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1460213
Reported-by: Jiri Benc <jbenc@redhat.com>
Fixes: b87f7936a932 ("net/sched: introduce Match-all classifier")
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
Acked-by: Yotam Gigi <yotamg@mellanox.com>
[ Upstream commit 8c22dab03ad072e45060c299c70d02a4f6fc4aab ]
If ipv6 has been disabled from cmdline since kernel started, it makes
no sense to allow users to create any ip6 tunnel. Otherwise, it could
some potential problem.
Jianlin found a kernel crash caused by this in ip6_gre when he set
ipv6.disable=1 in grub:
[ 209.588865] Unable to handle kernel paging request for data at address 0x00000080
[ 209.588872] Faulting instruction address: 0xc000000000a3aa6c
[ 209.588879] Oops: Kernel access of bad area, sig: 11 [#1]
[ 209.589062] NIP [c000000000a3aa6c] fib_rules_lookup+0x4c/0x260
[ 209.589071] LR [c000000000b9ad90] fib6_rule_lookup+0x50/0xb0
[ 209.589076] Call Trace:
[ 209.589097] fib6_rule_lookup+0x50/0xb0
[ 209.589106] rt6_lookup+0xc4/0x110
[ 209.589116] ip6gre_tnl_link_config+0x214/0x2f0 [ip6_gre]
[ 209.589125] ip6gre_newlink+0x138/0x3a0 [ip6_gre]
[ 209.589134] rtnl_newlink+0x798/0xb80
[ 209.589142] rtnetlink_rcv_msg+0xec/0x390
[ 209.589151] netlink_rcv_skb+0x138/0x150
[ 209.589159] rtnetlink_rcv+0x48/0x70
[ 209.589169] netlink_unicast+0x538/0x640
[ 209.589175] netlink_sendmsg+0x40c/0x480
[ 209.589184] ___sys_sendmsg+0x384/0x4e0
[ 209.589194] SyS_sendmsg+0xd4/0x140
[ 209.589201] SyS_socketcall+0x3e0/0x4f0
[ 209.589209] system_call+0x38/0xe0
This patch is to return -EOPNOTSUPP in ip6_tunnel_init if ipv6 has been
disabled from cmdline.
Reported-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 76cc0d3282d4b933fa144fa41fbc5318e0fdca24 ]
Now in ip6gre_header before packing the ipv6 header, it skb_push t->hlen
which only includes encap_hlen + tun_hlen. It means greh and inner header
would be over written by ipv6 stuff and ipv6h might have no chance to set
up.
Jianlin found this issue when using remote any on ip6_gre, the packets he
captured on gre dev are truncated:
22:50:26.210866 Out ethertype IPv6 (0x86dd), length 120: truncated-ip6 -\
8128 bytes missing!(flowlabel 0x92f40, hlim 0, next-header Options (0) \
payload length: 8192) ::1:2000:0 > ::1:0:86dd: HBH [trunc] ip-proto-128 \
8184
It should also skb_push ipv6hdr so that ipv6h points to the right position
to set ipv6 stuff up.
This patch is to skb_push hlen + sizeof(*ipv6h) and also fix some indents
in ip6gre_header.
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
[ Upstream commit 63ecc3d9436f8012e49dc846d6cb0a85a3433517 ]
While trying an ESP transport mode encryption for UDPv6 packets of
datagram size 1436 with MTU 1500, checksum error was observed in
the secondary fragment.
This error occurs due to the UDP payload checksum being missed out
when computing the full checksum for these packets in
udp6_hwcsum_outgoing().
Fixes: d39d938c8228 ("ipv6: Introduce udpv6_send_skb()")
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
[ Upstream commit fc22579917eb7e13433448a342f1cb1592920940 ]
Now skb->mstamp_skb is updated later, we also need to call
tcp_rate_skb_sent() after the update is done.
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit 8c72c65b426b47b3c166a8fef0d8927fe5e8a28d ]
liujian reported a problem in TCP_USER_TIMEOUT processing with a patch
in tcp_probe_timer() :
https://www.spinics.net/lists/netdev/msg454496.html
After investigations, the root cause of the problem is that we update
skb->skb_mstamp of skbs in write queue, even if the attempt to send a
clone or copy of it failed. One reason being a routing problem.
This patch prevents this, solving liujian issue.
It also removes a potential RTT miscalculation, since
__tcp_retransmit_skb() is not OR-ing TCP_SKB_CB(skb)->sacked with
TCPCB_EVER_RETRANS if a failure happens, but skb->skb_mstamp has
been changed.
A future ACK would then lead to a very small RTT sample and min_rtt
would then be lowered to this too small value.
Tested:
# cat user_timeout.pkt
--local_ip=192.168.102.64
0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 1) = 0
+0 `ifconfig tun0 192.168.102.64/16; ip ro add 192.0.2.1 dev tun0`
+0 < S 0:0(0) win 0 <mss 1460>
+0 > S. 0:0(0) ack 1 <mss 1460>
+.1 < . 1:1(0) ack 1 win 65530
+0 accept(3, ..., ...) = 4
+0 setsockopt(4, SOL_TCP, TCP_USER_TIMEOUT, [3000], 4) = 0
+0 write(4, ..., 24) = 24
+0 > P. 1:25(24) ack 1 win 29200
+.1 < . 1:1(0) ack 25 win 65530
//change the ipaddress
+1 `ifconfig tun0 192.168.0.10/16`
+1 write(4, ..., 24) = 24
+0 `ifconfig tun0 192.168.102.64/16`
+0 < . 1:2(1) ack 25 win 65530
+0 `ifconfig tun0 192.168.0.10/16`
+3 write(4, ..., 24) = -1
# ./packetdrill user_timeout.pkt
Signed-off-by: Eric Dumazet <edumazet@googl.com>
Reported-by: liujian <liujian56@huawei.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 255cd50f207ae8ec7b22663246c833407744e634 ]
Recent commit d7fb60b9cafb ("net_sched: get rid of tcfa_rcu") removed
freeing in call_rcu, which changed already existing hard-to-hit
race condition into 100% hit:
[ 598.599825] BUG: unable to handle kernel NULL pointer dereference at 0000000000000030
[ 598.607782] IP: tcf_action_destroy+0xc0/0x140
Or:
[ 40.858924] BUG: unable to handle kernel NULL pointer dereference at 0000000000000030
[ 40.862840] IP: tcf_generic_walker+0x534/0x820
Fix this by storing the ops and use them directly for module_put call.
Fixes: a85a970af265 ("net_sched: move tc_action into tcf_common")
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 3b12f73a5c2977153f28a224392fd4729b50d1dc ]
In the function rds_ib_setup_qp, the error handle is missing. When some
error occurs, it is possible that memory leak occurs. As such, error
handle is added.
Cc: Joe Jin <joe.jin@oracle.com>
Reviewed-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Guanglei Li <guanglei.li@oracle.com>
Signed-off-by: Zhu Yanjun <yanjun.zhu@oracle.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit ae5c682113f9f94cc5e76f92cf041ee624c173ee ]
The helper->expect_class_max must be set to the total number of
expect_policy minus 1, since we will use the statement "if (class >
helper->expect_class_max)" to validate the CTA_EXPECT_CLASS attr in
ctnetlink_alloc_expect.
So for compatibility, set the helper->expect_class_max to the
NFCTH_POLICY_SET_NUM attr's value minus 1.
Also: it's invalid when the NFCTH_POLICY_SET_NUM attr's value is zero.
1. this will result "expect_policy = kzalloc(0, GFP_KERNEL);";
2. we cannot set the helper->expect_class_max to a proper value.
So if nla_get_be32(tb[NFCTH_POLICY_SET_NUM]) is zero, report -EINVAL to
the userspace.
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
[ Upstream commit 3b7dabf029478bb80507a6c4500ca94132a2bc0b ]
Otherwise, another CPU may access the invalid pointer. For example:
CPU0 CPU1
- rcu_read_lock();
- pfunc = _hook_;
_hook_ = NULL; -
mod unload -
- pfunc(); // invalid, panic
- rcu_read_unlock();
So we must call synchronize_rcu() to wait the rcu reader to finish.
Also note, in nf_nat_snmp_basic_fini, synchronize_rcu() will be invoked
by later nf_conntrack_helper_unregister, but I'm inclined to add a
explicit synchronize_rcu after set the nf_nat_snmp_hook to NULL. Depend
on such obscure assumptions is not a good idea.
Last, in nfnetlink_cttimeout, we use kfree_rcu to free the time object,
so in cttimeout_exit, invoking rcu_barrier() is not necessary at all,
remove it too.
[ Upstream commit 5b8d5429daa05bebef6ffd3297df3b502cc6f184 ]
Peter reported a kernel oops when executing the following command:
$ ip link add name test type bridge vlan_default_pvid 1
[13634.939408] BUG: unable to handle kernel NULL pointer dereference at
0000000000000190
[13634.939436] IP: __vlan_add+0x73/0x5f0
[13634.939783] Call Trace:
[13634.939791] ? pcpu_next_unpop+0x3b/0x50
[13634.939801] ? pcpu_alloc+0x3d2/0x680
[13634.939810] ? br_vlan_add+0x135/0x1b0
[13634.939820] ? __br_vlan_set_default_pvid.part.28+0x204/0x2b0
[13634.939834] ? br_changelink+0x120/0x4e0
[13634.939844] ? br_dev_newlink+0x50/0x70
[13634.939854] ? rtnl_newlink+0x5f5/0x8a0
[13634.939864] ? rtnl_newlink+0x176/0x8a0
[13634.939874] ? mem_cgroup_commit_charge+0x7c/0x4e0
[13634.939886] ? rtnetlink_rcv_msg+0xe1/0x220
[13634.939896] ? lookup_fast+0x52/0x370
[13634.939905] ? rtnl_newlink+0x8a0/0x8a0
[13634.939915] ? netlink_rcv_skb+0xa1/0xc0
[13634.939925] ? rtnetlink_rcv+0x24/0x30
[13634.939934] ? netlink_unicast+0x177/0x220
[13634.939944] ? netlink_sendmsg+0x2fe/0x3b0
[13634.939954] ? _copy_from_user+0x39/0x40
[13634.939964] ? sock_sendmsg+0x30/0x40
[13634.940159] ? ___sys_sendmsg+0x29d/0x2b0
[13634.940326] ? __alloc_pages_nodemask+0xdf/0x230
[13634.940478] ? mem_cgroup_commit_charge+0x7c/0x4e0
[13634.940592] ? mem_cgroup_try_charge+0x76/0x1a0
[13634.940701] ? __handle_mm_fault+0xdb9/0x10b0
[13634.940809] ? __sys_sendmsg+0x51/0x90
[13634.940917] ? entry_SYSCALL_64_fastpath+0x1e/0xad
The problem is that the bridge's VLAN group is created after setting the
default PVID, when registering the netdevice and executing its
ndo_init().
Fix this by changing the order of both operations, so that
br_changelink() is only processed after the netdevice is registered,
when the VLAN group is already initialized.
Fixes: b6677449dff6 ("bridge: netlink: call br_changelink() during br_dev_newlink()")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Peter V. Saveliev <peter@svinota.eu>
Tested-by: Peter V. Saveliev <peter@svinota.eu>
[ Upstream commit b40c5f4fde22fb98eff205b3aece05b471c24eed ]
Otherwise, UDP checksum offloads could corrupt ESP packets by attempting
to calculate UDP checksum when this inner UDP packet is already protected
by IPsec.
One way to reproduce this bug is to have a VM with virtio_net driver (UFO
set to ON in the guest VM); and then encapsulate all guest's Ethernet
frames in Geneve; and then further encrypt Geneve with IPsec. In this
case following symptoms are observed:
1. If using ixgbe NIC, then it will complain with following error message:
ixgbe 0000:01:00.1: partial checksum but l4 proto=32!
2. Receiving IPsec stack will drop all the corrupted ESP packets and
increase XfrmInStateProtoError counter in /proc/net/xfrm_stat.
3. iperf UDP test from the VM with packet sizes above MTU will not work at
all.
4. iperf TCP test from the VM will get ridiculously low performance because.
Signed-off-by: Ansis Atteka <aatteka@ovn.org>
Co-authored-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit fd2c83b35752f0a8236b976978ad4658df14a59f ]
In the case getsockopt() is called with PACKET_HDRLEN and optlen < 4
|val| remains uninitialized and the syscall may behave differently
depending on its value, and even copy garbage to userspace on certain
architectures. To fix this we now return -EINVAL if optlen is too small.
This bug has been detected with KMSAN.
Signed-off-by: Alexander Potapenko <glider@google.com>
[ Upstream commit 9899886d5e8ec5b343b1efe44f185a0e68dc6454 ]
Added NULL check to make __dev_kfree_skb_irq consistent with kfree
family of functions.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=195289
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
[ Upstream commit 62bc306e2083436675e33b5bdeb6a77907d35971 ]
32-bit socketcalls were not being logged by audit on x86_64 systems.
Log them. This is basically a duplicate of the call from
net/socket.c:sys_socketcall(), but it addresses the impedance mismatch
between 32-bit userspace process and 64-bit kernel audit.
See: https://github.com/linux-audit/audit-kernel/issues/14
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 941f8d55f6d613a460a5e080d25a38509f45eb75 ]
When application sends an RDS RDMA composite message consist of
RDMA transfer to be followed up by non RDMA payload, it expect to
be notified *only* when the full message gets delivered. RDS RDMA
notification doesn't behave this way though.
Thanks to Venkat for debug and root casuing the issue
where only first part of the message(RDMA) was
successfully delivered but remainder payload delivery failed.
In that case, application should not be notified with
a false positive of message delivery success.
Fix this case by making sure the user gets notified only after
the full message delivery.
Reviewed-by: Venkat Venkatsubra <venkat.x.venkatsubra@oracle.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
commit e785fa0a164aa11001cba931367c7f94ffaff888 upstream.
nl80211_set_rekey_data() does not check if the required attributes
NL80211_REKEY_DATA_{REPLAY_CTR,KEK,KCK} are present when processing
NL80211_CMD_SET_REKEY_OFFLOAD request. This request can be issued by
users with CAP_NET_ADMIN privilege and may result in NULL dereference
and a system crash. Add a check for the required attributes presence.
This patch is based on the patch by bo Zhang.
This fixes CVE-2017-12153.
References: https://bugzilla.redhat.com/show_bug.cgi?id=1491046
Fixes: e5497d766ad ("cfg80211/nl80211: support GTK rekey offload")
Reported-by: bo Zhang <zhangbo5891001@gmail.com>
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
commit 6e46d8ce894374fc135c96a8d1057c6af1fef237 upstream.
When HW ROC is supported it is possible that after the HW notified
that the ROC has started, the ROC was cancelled and another ROC was
added while the hw_roc_start worker is waiting on the mutex (since
cancelling the ROC and adding another one also holds the same mutex).
As a result, the hw_roc_start worker will continue to run after the
new ROC is added but before it is actually started by the HW.
This may result in notifying userspace that the ROC has started before
it actually does, or in case of management tx ROC, in an attempt to
tx while not on the right channel.
In addition, when the driver will notify mac80211 that the second ROC
has started, mac80211 will warn that this ROC has already been
notified.
Fix this by flushing the hw_roc_start work before cancelling an ROC.
Cc: stable@vger.kernel.org
Signed-off-by: Avraham Stern <avraham.stern@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
commit 53168215909281a09d3afc6fb51a9d4f81f74d39 upstream.
With TXQs, the AP_VLAN interfaces are resolved to their owner AP
interface when enqueuing the frame, which makes sense since the
frame really goes out on that as far as the driver is concerned.
However, this introduces a problem: frames to be encrypted with
a VLAN-specific GTK will now be encrypted with the AP GTK, since
the information about which virtual interface to use to select
the key is taken from the TXQ.
Fix this by preserving info->control.vif and using that in the
dequeue function. This now requires doing the driver-mapping
in the dequeue as well.
Since there's no way to filter the frames that are sitting on a
TXQ, drop all frames, which may affect other interfaces, when an
AP_VLAN is removed.
commit 3ef0c7a730de0bae03d86c19570af764fa3c4445 upstream.
As we want to remove spin_unlock_wait() and replace it with explicit
spin_lock()/spin_unlock() calls, we can use this to simplify the
locking.
In addition:
- Reading nf_conntrack_locks_all needs ACQUIRE memory ordering.
- The new code avoids the backwards loop.
Only slightly tested, I did not manage to trigger calls to
nf_conntrack_all_lock().
V2: With improved comments, to clearly show how the barriers
pair.
Fixes: b16c29191dc8 ("netfilter: nf_conntrack: use safer way to lock all buckets")
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: netfilter-devel@vger.kernel.org
commit ed6473ddc704a2005b9900ca08e236ebb2d8540a upstream.
We want to use kthread_stop() in order to ensure the threads are
shut down before we tear down the nfs_callback_info in nfs_callback_down.
Tested-and-reviewed-by: Kinglong Mee <kinglongmee@gmail.com>
Reported-by: Kinglong Mee <kinglongmee@gmail.com>
Fixes: bb6aeba736ba9 ("NFSv4.x: Switch to using svc_set_num_threads()...")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Cc: Jan Hudoba <kernel@jahu.sk>
commit 9e0d87680d689f1758185851c3da6eafb16e71e1 upstream.
Refactor to separate out the functions of starting and stopping threads
so that they can be used in other helpers.
commit 3614364527daa870264f6dde77f02853cdecd02c upstream.
rt_cookie might be used uninitialized, fix this by
initializing it.
Fixes: c5cff8561d2d ("ipv6: add rcu grace period before freeing fib6_node")
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 0f693f1995cf002432b70f43ce73f79bf8d0b6c9 ]
ttl and tos variables are declared and assigned, but are not used in
iptunnel_xmit() function.
Fixes: cfc7381b3002 ("ip_tunnel: add collect_md mode to IPIP tunnel")
Cc: Alexei Starovoitov <ast@fb.com>
Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 7906b00f5cd1cd484fced7fcda892176e3202c8a ]
Commit fb586f25300f ("sctp: delay calls to sk_data_ready() as much as
possible") minimized the number of wake ups that are triggered in case
the association receives a packet with multiple data chunks on it and/or
when io_events are enabled and then commit 0970f5b36659 ("sctp: signal
sk_data_ready earlier on data chunks reception") moved the wake up to as
soon as possible. It thus relies on the state machine running later to
clean the flag that the event was already generated.
The issue is that there are 2 call paths that calls
sctp_ulpq_tail_event() outside of the state machine, causing the flag to
linger and possibly omitting a needed wake up in the sequence.
One of the call paths is when enabling SCTP_SENDER_DRY_EVENTS via
setsockopt(SCTP_EVENTS), as noticed by Harald Welte. The other is when
partial reliability triggers removal of chunks from the send queue when
the application calls sendmsg().
This commit fixes it by not setting the flag in case the socket is not
owned by the user, as it won't be cleaned later. This works for
user-initiated calls and also for rx path processing.
Fixes: fb586f25300f ("sctp: delay calls to sk_data_ready() as much as possible")
Reported-by: Harald Welte <laforge@gnumonks.org>
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit 32a805baf0fb70b6dbedefcd7249ac7f580f9e3b ]
IPv6 FIB should use FIB6_TABLE_HASHSZ, not FIB_TABLE_HASHSZ.
Fixes: ba1cc08d9488 ("ipv6: fix memory leak with multiple tables during netns destruction")
[ Upstream commit ba1cc08d9488c94cb8d94f545305688b72a2a300 ]
fib6_net_exit only frees the main and local tables. If another table was
created with fib6_alloc_table, we leak it when the netns is destroyed.
Fix this in the same way ip_fib_net_exit cleans up tables, by walking
through the whole hashtable of fib6_table's. We can get rid of the
special cases for local and main, since they're also part of the
hashtable.
Reproducer:
ip netns add x
ip -net x -6 rule add from 6003:1::/64 table 100
ip netns del x
Fixes: 58f09b78b730 ("[NETNS][IPV6] ip6_fib - make it per network namespace")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit 5c25f30c93fdc5bf25e62101aeaae7a4f9b421b3 ]
Now when probessing ICMPV6_PKT_TOOBIG, ip6gre_err only subtracts the
offset of gre header from mtu info. The expected mtu of gre device
should also subtract gre header. Otherwise, the next packets still
can't be sent out.
Jianlin found this issue when using the topo:
client(ip6gre)<---->(nic1)route(nic2)<----->(ip6gre)server
and reducing nic2's mtu, then both tcp and sctp's performance with
big size data became 0.
This patch is to fix it by also subtracting grehdr (tun->tun_hlen)
from mtu info when updating gre device's mtu in ip6gre_err(). It
also needs to subtract ETH_HLEN if gre dev'type is ARPHRD_ETHER.
[ Upstream commit 5a63643e583b6a9789d7a225ae076fb4e603991c ]
This reverts commit 1d6119baf0610f813eb9d9580eb4fd16de5b4ceb.
After reverting commit 6d7b857d541e ("net: use lib/percpu_counter API
for fragmentation mem accounting") then here is no need for this
fix-up patch. As percpu_counter is no longer used, it cannot
memory leak it any-longer.
Fixes: 6d7b857d541e ("net: use lib/percpu_counter API for fragmentation mem accounting")
Fixes: 1d6119baf061 ("net: fix percpu memory leaks")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit fb452a1aa3fd4034d7999e309c5466ff2d7005aa ]
This reverts commit 6d7b857d541ecd1d9bd997c97242d4ef94b19de2.
There is a bug in fragmentation codes use of the percpu_counter API,
that can cause issues on systems with many CPUs.
The frag_mem_limit() just reads the global counter (fbc->count),
without considering other CPUs can have upto batch size (130K) that
haven't been subtracted yet. Due to the 3MBytes lower thresh limit,
this become dangerous at >=24 CPUs (3*1024*1024/130000=24).
The correct API usage would be to use __percpu_counter_compare() which
does the right thing, and takes into account the number of (online)
CPUs and batch size, to account for this and call __percpu_counter_sum()
when needed.
We choose to revert the use of the lib/percpu_counter API for frag
memory accounting for several reasons:
1) On systems with CPUs > 24, the heavier fully locked
__percpu_counter_sum() is always invoked, which will be more
expensive than the atomic_t that is reverted to.
Given systems with more than 24 CPUs are becoming common this doesn't
seem like a good option. To mitigate this, the batch size could be
decreased and thresh be increased.
2) The add_frag_mem_limit+sub_frag_mem_limit pairs happen on the RX
CPU, before SKBs are pushed into sockets on remote CPUs. Given
NICs can only hash on L2 part of the IP-header, the NIC-RXq's will
likely be limited. Thus, a fair chance that atomic add+dec happen
on the same CPU.
Revert note that commit 1d6119baf061 ("net: fix percpu memory leaks")
removed init_frag_mem_limit() and instead use inet_frags_init_net().
After this revert, inet_frags_uninit_net() becomes empty.
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit 79e99bdd60b484af9afe0147e85a13e66d5c1cdb ]
Commit 6bc506b4fb06 ("bridge: switchdev: Add forward mark support for
stacked devices") added the 'offload_fwd_mark' bit to the skb in order
to allow drivers to indicate to the bridge driver that they already
forwarded the packet in L2.
In case the bit is set, before transmitting the packet from each port,
the port's mark is compared with the mark stored in the skb's control
block. If both marks are equal, we know the packet arrived from a switch
device that already forwarded the packet and it's not re-transmitted.
However, if the packet is transmitted from the bridge device itself
(e.g., br0), we should clear the 'offload_fwd_mark' bit as the mark
stored in the skb's control block isn't valid.
This scenario can happen in rare cases where a packet was trapped during
L3 forwarding and forwarded by the kernel to a bridge device.
Fixes: 6bc506b4fb06 ("bridge: switchdev: Add forward mark support for stacked devices")
Reported-by: Yotam Gigi <yotamg@mellanox.com>
Tested-by: Yotam Gigi <yotamg@mellanox.com>
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 25cc72a33835ed8a6f53180a822cadab855852ac ]
The mlxsw driver relies on NETDEV_CHANGEUPPER events to configure the
device in case a port is enslaved to a master netdev such as bridge or
bond.
Since the driver ignores events unrelated to its ports and their
uppers, it's possible to engineer situations in which the device's data
path differs from the kernel's.
One example to such a situation is when a port is enslaved to a bond
that is already enslaved to a bridge. When the bond was enslaved the
driver ignored the event - as the bond wasn't one of its uppers - and
therefore a bridge port instance isn't created in the device.
Until such configurations are supported forbid them by checking that the
upper device doesn't have uppers of its own.
Fixes: 0d65fc13042f ("mlxsw: spectrum: Implement LAG port join/leave")
Reported-by: Nogah Frankel <nogahf@mellanox.com>
Tested-by: Nogah Frankel <nogahf@mellanox.com>
[ Upstream commit 499350a5a6e7512d9ed369ed63a4244b6536f4f8 ]
When tcp_disconnect() is called, inet_csk_delack_init() sets
icsk->icsk_ack.rcv_mss to 0.
This could potentially cause tcp_recvmsg() => tcp_cleanup_rbuf() =>
__tcp_select_window() call path to have division by 0 issue.
So this patch initializes rcv_mss to TCP_MIN_MSS instead of 0.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Wei Wang <weiwan@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 351050ecd6523374b370341cc29fe61e2201556b ]
syzkaller had no problem to trigger a deadlock, attaching a KCM socket
to another one (or itself). (original syzkaller report was a very
confusing lockdep splat during a sendmsg())
It seems KCM claims to only support TCP, but no enforcement is done,
so we might need to add additional checks.
Fixes: ab7ac4eb9832 ("kcm: Kernel Connection Multiplexor module")
Acked-by: Tom Herbert <tom@quantonium.net>
[ Upstream commit edbd58be15a957f6a760c4a514cd475217eb97fd ]
... which may happen with certain values of tp_reserve and maclen.
Fixes: 58d19b19cd99 ("packet: vnet_hdr support for tpacket_rcv")
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
Cc: Willem de Bruijn <willemb@google.com>
Acked-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit ee6c88bb754e3d363e568da78086adfedb692447 ]
inet_diag_msg_sctp{,l}addr_fill() and sctp_get_sctp_info() copy
sizeof(sockaddr_storage) bytes to fill in sockaddr structs used
to export diagnostic information to userspace.
However, the memory allocated to store sockaddr information is
smaller than that and depends on the address family, so we leak
up to 100 uninitialized bytes to userspace. Just use the size of
the source structs instead, in all the three cases this is what
userspace expects. Zero out the remaining memory.
Unused bytes (i.e. when IPv4 addresses are used) in source
structs sctp_sockaddr_entry and sctp_transport are already
cleared by sctp_add_bind_addr() and sctp_transport_new(),
respectively.
Noticed while testing KASAN-enabled kernel with 'ss':
[ 2326.885243] BUG: KASAN: slab-out-of-bounds in inet_sctp_diag_fill+0x42c/0x6c0 [sctp_diag] at addr ffff881be8779800
[ 2326.896800] Read of size 128 by task ss/9527
[ 2326.901564] CPU: 0 PID: 9527 Comm: ss Not tainted 4.11.0-22.el7a.x86_64 #1
[ 2326.909236] Hardware name: Dell Inc. PowerEdge R730/072T6D, BIOS 2.4.3 01/17/2017
[ 2326.917585] Call Trace:
[ 2326.920312] dump_stack+0x63/0x8d
[ 2326.924014] kasan_object_err+0x21/0x70
[ 2326.928295] kasan_report+0x288/0x540
[ 2326.932380] ? inet_sctp_diag_fill+0x42c/0x6c0 [sctp_diag]
[ 2326.938500] ? skb_put+0x8b/0xd0
[ 2326.942098] ? memset+0x31/0x40
[ 2326.945599] check_memory_region+0x13c/0x1a0
[ 2326.950362] memcpy+0x23/0x50
[ 2326.953669] inet_sctp_diag_fill+0x42c/0x6c0 [sctp_diag]
[ 2326.959596] ? inet_diag_msg_sctpasoc_fill+0x460/0x460 [sctp_diag]
[ 2326.966495] ? __lock_sock+0x102/0x150
[ 2326.970671] ? sock_def_wakeup+0x60/0x60
[ 2326.975048] ? remove_wait_queue+0xc0/0xc0
[ 2326.979619] sctp_diag_dump+0x44a/0x760 [sctp_diag]
[ 2326.985063] ? sctp_ep_dump+0x280/0x280 [sctp_diag]
[ 2326.990504] ? memset+0x31/0x40
[ 2326.994007] ? mutex_lock+0x12/0x40
[ 2326.997900] __inet_diag_dump+0x57/0xb0 [inet_diag]
[ 2327.003340] ? __sys_sendmsg+0x150/0x150
[ 2327.007715] inet_diag_dump+0x4d/0x80 [inet_diag]
[ 2327.012979] netlink_dump+0x1e6/0x490
[ 2327.017064] __netlink_dump_start+0x28e/0x2c0
[ 2327.021924] inet_diag_handler_cmd+0x189/0x1a0 [inet_diag]
[ 2327.028045] ? inet_diag_rcv_msg_compat+0x1b0/0x1b0 [inet_diag]
[ 2327.034651] ? inet_diag_dump_compat+0x190/0x190 [inet_diag]
[ 2327.040965] ? __netlink_lookup+0x1b9/0x260
[ 2327.045631] sock_diag_rcv_msg+0x18b/0x1e0
[ 2327.050199] netlink_rcv_skb+0x14b/0x180
[ 2327.054574] ? sock_diag_bind+0x60/0x60
[ 2327.058850] sock_diag_rcv+0x28/0x40
[ 2327.062837] netlink_unicast+0x2e7/0x3b0
[ 2327.067212] ? netlink_attachskb+0x330/0x330
[ 2327.071975] ? kasan_check_write+0x14/0x20
[ 2327.076544] netlink_sendmsg+0x5be/0x730
[ 2327.080918] ? netlink_unicast+0x3b0/0x3b0
[ 2327.085486] ? kasan_check_write+0x14/0x20
[ 2327.090057] ? selinux_socket_sendmsg+0x24/0x30
[ 2327.095109] ? netlink_unicast+0x3b0/0x3b0
[ 2327.099678] sock_sendmsg+0x74/0x80
[ 2327.103567] ___sys_sendmsg+0x520/0x530
[ 2327.107844] ? __get_locked_pte+0x178/0x200
[ 2327.112510] ? copy_msghdr_from_user+0x270/0x270
[ 2327.117660] ? vm_insert_page+0x360/0x360
[ 2327.122133] ? vm_insert_pfn_prot+0xb4/0x150
[ 2327.126895] ? vm_insert_pfn+0x32/0x40
[ 2327.131077] ? vvar_fault+0x71/0xd0
[ 2327.134968] ? special_mapping_fault+0x69/0x110
[ 2327.140022] ? __do_fault+0x42/0x120
[ 2327.144008] ? __handle_mm_fault+0x1062/0x17a0
[ 2327.148965] ? __fget_light+0xa7/0xc0
[ 2327.153049] __sys_sendmsg+0xcb/0x150
[ 2327.157133] ? __sys_sendmsg+0xcb/0x150
[ 2327.161409] ? SyS_shutdown+0x140/0x140
[ 2327.165688] ? exit_to_usermode_loop+0xd0/0xd0
[ 2327.170646] ? __do_page_fault+0x55d/0x620
[ 2327.175216] ? __sys_sendmsg+0x150/0x150
[ 2327.179591] SyS_sendmsg+0x12/0x20
[ 2327.183384] do_syscall_64+0xe3/0x230
[ 2327.187471] entry_SYSCALL64_slow_path+0x25/0x25
[ 2327.192622] RIP: 0033:0x7f41d18fa3b0
[ 2327.196608] RSP: 002b:00007ffc3b731218 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[ 2327.205055] RAX: ffffffffffffffda RBX: 00007ffc3b731380 RCX: 00007f41d18fa3b0
[ 2327.213017] RDX: 0000000000000000 RSI: 00007ffc3b731340 RDI: 0000000000000003
[ 2327.220978] RBP: 0000000000000002 R08: 0000000000000004 R09: 0000000000000040
[ 2327.228939] R10: 00007ffc3b730f30 R11: 0000000000000246 R12: 0000000000000003
[ 2327.236901] R13: 00007ffc3b731340 R14: 00007ffc3b7313d0 R15: 0000000000000084
[ 2327.244865] Object at ffff881be87797e0, in cache kmalloc-64 size: 64
[ 2327.251953] Allocated:
[ 2327.254581] PID = 9484
[ 2327.257215] save_stack_trace+0x1b/0x20
[ 2327.261485] save_stack+0x46/0xd0
[ 2327.265179] kasan_kmalloc+0xad/0xe0
[ 2327.269165] kmem_cache_alloc_trace+0xe6/0x1d0
[ 2327.274138] sctp_add_bind_addr+0x58/0x180 [sctp]
[ 2327.279400] sctp_do_bind+0x208/0x310 [sctp]
[ 2327.284176] sctp_bind+0x61/0xa0 [sctp]
[ 2327.288455] inet_bind+0x5f/0x3a0
[ 2327.292151] SYSC_bind+0x1a4/0x1e0
[ 2327.295944] SyS_bind+0xe/0x10
[ 2327.299349] do_syscall_64+0xe3/0x230
[ 2327.303433] return_from_SYSCALL_64+0x0/0x6a
[ 2327.308194] Freed:
[ 2327.310434] PID = 4131
[ 2327.313065] save_stack_trace+0x1b/0x20
[ 2327.317344] save_stack+0x46/0xd0
[ 2327.321040] kasan_slab_free+0x73/0xc0
[ 2327.325220] kfree+0x96/0x1a0
[ 2327.328530] dynamic_kobj_release+0x15/0x40
[ 2327.333195] kobject_release+0x99/0x1e0
[ 2327.337472] kobject_put+0x38/0x70
[ 2327.341266] free_notes_attrs+0x66/0x80
[ 2327.345545] mod_sysfs_teardown+0x1a5/0x270
[ 2327.350211] free_module+0x20/0x2a0
[ 2327.354099] SyS_delete_module+0x2cb/0x2f0
[ 2327.358667] do_syscall_64+0xe3/0x230
[ 2327.362750] return_from_SYSCALL_64+0x0/0x6a
[ 2327.367510] Memory state around the buggy address:
[ 2327.372855] ffff881be8779700: fc fc fc fc 00 00 00 00 00 00 00 00 fc fc fc fc
[ 2327.380914] ffff881be8779780: fb fb fb fb fb fb fb fb fc fc fc fc 00 00 00 00
[ 2327.388972] >ffff881be8779800: 00 00 00 00 fc fc fc fc fb fb fb fb fb fb fb fb
[ 2327.397031] ^
[ 2327.401792] ffff881be8779880: fc fc fc fc fb fb fb fb fb fb fb fb fc fc fc fc
[ 2327.409850] ffff881be8779900: 00 00 00 00 00 04 fc fc fc fc fc fc 00 00 00 00
[ 2327.417907] ==================================================================
This fixes CVE-2017-7558.
References: https://bugzilla.redhat.com/show_bug.cgi?id=1480266
Fixes: 8f840e47f190 ("sctp: add the sctp_diag.c file")
Cc: Xin Long <lucien.xin@gmail.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit fd6055a806edc4019be1b9fb7d25262599bca5b1 ]
When peeking, if a bad csum is discovered, the skb is unlinked from
the queue with __sk_queue_drop_skb and the peek operation restarted.
__sk_queue_drop_skb only drops packets that match the queue head.
This fails if the skb was found after the head, using SO_PEEK_OFF
socket option. This causes an infinite loop.
We MUST drop this problematic skb, and we can simply check if skb was
already removed by another thread, by looking at skb->next :
This pointer is set to NULL by the __skb_unlink() operation, that might
have happened only under the spinlock protection.
Many thanks to syzkaller team (and particularly Dmitry Vyukov who
provided us nice C reproducers exhibiting the lockup) and Willem de
Bruijn who provided first version for this patch and a test program.
Fixes: 627d2d6b5500 ("udp: enable MSG_PEEK at non-zero offset")
Acked-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 4e587ea71bf924f7dac621f1351653bd41e446cb ]
Commit c5cff8561d2d adds rcu grace period before freeing fib6_node. This
generates a new sparse warning on rt->rt6i_node related code:
net/ipv6/route.c:1394:30: error: incompatible types in comparison
expression (different address spaces)
./include/net/ip6_fib.h:187:14: error: incompatible types in comparison
This commit adds "__rcu" tag for rt6i_node and makes sure corresponding
rcu API is used for it.
After this fix, sparse no longer generates the above warning.
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit c5cff8561d2d0006e972bd114afd51f082fee77c ]
We currently keep rt->rt6i_node pointing to the fib6_node for the route.
And some functions make use of this pointer to dereference the fib6_node
from rt structure, e.g. rt6_check(). However, as there is neither
refcount nor rcu taken when dereferencing rt->rt6i_node, it could
potentially cause crashes as rt->rt6i_node could be set to NULL by other
CPUs when doing a route deletion.
This patch introduces an rcu grace period before freeing fib6_node and
makes sure the functions that dereference it takes rcu_read_lock().
Note: there is no "Fixes" tag because this bug was there in a very
early stage.
[ Upstream commit 3de33e1ba0506723ab25734e098cf280ecc34756 ]
A packet length of exactly IPV6_MAXPLEN is allowed, we should
refuse parsing options only if the size is 64KiB or more.
While at it, remove one extra variable and one assignment which
were also introduced by the commit that introduced the size
check. Checking the sum 'offset + len' and only later adding
'len' to 'offset' doesn't provide any advantage over directly
summing to 'offset' and checking it.
Fixes: 6399f1fae4ec ("ipv6: avoid overflow of offset in ip6_find_1stfragopt")
commit e860d2c904d1a9f38a24eb44c9f34b8f915a6ea3 upstream.
Validate the output buffer length for L2CAP config requests and responses
to avoid overflowing the stack buffer used for building the option blocks.
Signed-off-by: Ben Seri <ben@armis.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 7bab09631c2a303f87a7eb7e3d69e888673b9b7e upstream.
The 'dir' parameter in xfrm_migrate() is a user-controlled byte which is used
as an array index. This can lead to an out-of-bound access, kernel lockup and
DoS. Add a check for the 'dir' value.
This fixes CVE-2017-11600.
References: https://bugzilla.redhat.com/show_bug.cgi?id=1474928
Fixes: 80c9abaabf42 ("[XFRM]: Extension for dynamic update of endpoint address(es)")
Reported-by: "bo Zhang" <zhangbo5891001@gmail.com>
commit 25717382c1dd0ddced2059053e3ca5088665f7a5 upstream.
It looks like bnep_session has same pattern as the issue reported in
old rfcomm:
while (1) {
set_current_state(TASK_INTERRUPTIBLE);
if (condition)
break;
// may call might_sleep here
schedule();
__set_current_state(TASK_RUNNING);
Which fixed at:
dfb2fae Bluetooth: Fix nested sleeps
So let's fix it at the same way, also follow the suggestion of:
https://lwn.net/Articles/628628/
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
Reviewed-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: AL Yu-Chen Cho <acho@suse.com>
Cc: Jiri Slaby <jslaby@suse.cz>
commit f06d977309d09253c744e54e75c5295ecc52b7b4 upstream.
It looks like cmtp_session has same pattern as the issue reported in
old rfcomm:
while (1) {
if (condition)
break;
schedule();
Which fixed at:
commit 5da8e47d849d3d37b14129f038782a095b9ad049 upstream.
It looks like hidp_session_thread has same pattern as the issue reported in
old rfcomm:
while (1) {
if (condition)
break;
schedule();
Which fixed at:
Tested-by: AL Yu-Chen Cho <acho@suse.com>
Tested-by: Rohit Vaswani <rvaswani@nvidia.com>
commit 97772bcd56efa21d9d8976db6f205574ea602f51 upstream.
When doing initial conversion to rhashtable I replaced the bucket
walk with a single rhashtable_lookup_fast().
When moving to rhlist I failed to properly walk the list of identical
tuples, but that is what is needed for this to work correctly.
The table contains the original tuples, so the reply tuples are all
distinct.
We currently decide that mapping is (not) in range only based on the
first entry, but in case its not we need to try the reply tuple of the
next entry until we either find an in-range mapping or we checked
all the entries.
This bug makes nat core attempt collision resolution while it might be
able to use the mapping as-is.
Fixes: 870190a9ec90 ("netfilter: nat: convert nat bysrc hash to rhashtable")
Reported-by: Jaco Kroon <jaco@uls.co.za>
Tested-by: Jaco Kroon <jaco@uls.co.za>
commit eebe53e87f97975ee58a21693e44797608bf679c upstream.
While running nfs/connectathon tests kernel NULL-pointer exception
has been observed due to races in svcsock.c.
Race is appear when kernel accepts connection by kernel_accept
(which creates new socket) and start queuing ingress packets
to new socket. This happens in ksoftirq context which could run
concurrently on a different core while new socket setup is not done yet.
The fix is to re-order socket user data init sequence and add
write/read barrier calls to be sure that we got proper values
for callback pointers before actually calling them.
Test results: nfs/connectathon reports '0' failed tests for about 200+ iterations.
Crash log:
---<-snip->---
[ 6708.638984] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 6708.647093] pgd = ffff0000094e0000
[ 6708.650497] [00000000] *pgd=0000010ffff90003, *pud=0000010ffff90003, *pmd=0000010ffff80003, *pte=0000000000000000
[ 6708.660761] Internal error: Oops: 86000005 [#1] SMP
[ 6708.665630] Modules linked in: nfsv3 nfnetlink_queue nfnetlink_log nfnetlink rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache overlay xt_CONNSECMARK xt_SECMARK xt_conntrack iptable_security ip_tables ah4 xfrm4_mode_transport sctp tun binfmt_misc ext4 jbd2 mbcache loop tcp_diag udp_diag inet_diag rpcrdma ib_isert iscsi_target_mod ib_iser rdma_cm iw_cm libiscsi scsi_transport_iscsi ib_srpt target_core_mod ib_srp scsi_transport_srp ib_ipoib ib_ucm ib_uverbs ib_umad ib_cm ib_core nls_koi8_u nls_cp932 ts_kmp nf_conntrack_ipv4 nf_defrag_ipv4 nf_conntrack vfat fat ghash_ce sha2_ce sha1_ce cavium_rng_vf i2c_thunderx sg thunderx_edac i2c_smbus edac_core cavium_rng nfsd auth_rpcgss nfs_acl lockd grace sunrpc xfs libcrc32c nicvf nicpf ast i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops
[ 6708.736446] ttm drm i2c_core thunder_bgx thunder_xcv mdio_thunder mdio_cavium dm_mirror dm_region_hash dm_log dm_mod [last unloaded: stap_3c300909c5b3f46dcacd49aab3334af_87021]
[ 6708.752275] CPU: 84 PID: 0 Comm: swapper/84 Tainted: G W OE 4.11.0-4.el7.aarch64 #1
[ 6708.760787] Hardware name: www.cavium.com CRB-2S/CRB-2S, BIOS 0.3 Mar 13 2017
[ 6708.767910] task: ffff810006842e80 task.stack: ffff81000689c000
[ 6708.773822] PC is at 0x0
[ 6708.776739] LR is at svc_data_ready+0x38/0x88 [sunrpc]
[ 6708.781866] pc : [<0000000000000000>] lr : [<ffff0000029d7378>] pstate: 60000145
[ 6708.789248] sp : ffff810ffbad3900
[ 6708.792551] x29: ffff810ffbad3900 x28: ffff000008c73d58
[ 6708.797853] x27: 0000000000000000 x26: ffff81000bbe1e00
[ 6708.803156] x25: 0000000000000020 x24: ffff800f7410bf28
[ 6708.808458] x23: ffff000008c63000 x22: ffff000008c63000
[ 6708.813760] x21: ffff800f7410bf28 x20: ffff81000bbe1e00
[ 6708.819063] x19: ffff810012412400 x18: 00000000d82a9df2
[ 6708.824365] x17: 0000000000000000 x16: 0000000000000000
[ 6708.829667] x15: 0000000000000000 x14: 0000000000000001
[ 6708.834969] x13: 0000000000000000 x12: 722e736f622e676e
[ 6708.840271] x11: 00000000f814dd99 x10: 0000000000000000
[ 6708.845573] x9 : 7374687225000000 x8 : 0000000000000000
[ 6708.850875] x7 : 0000000000000000 x6 : 0000000000000000
[ 6708.856177] x5 : 0000000000000028 x4 : 0000000000000000
[ 6708.861479] x3 : 0000000000000000 x2 : 00000000e5000000
[ 6708.866781] x1 : 0000000000000000 x0 : ffff81000bbe1e00
[ 6708.872084]
[ 6708.873565] Process swapper/84 (pid: 0, stack limit = 0xffff81000689c000)
[ 6708.880341] Stack: (0xffff810ffbad3900 to 0xffff8100068a0000)
[ 6708.886075] Call trace:
[ 6708.888513] Exception stack(0xffff810ffbad3710 to 0xffff810ffbad3840)
[ 6708.894942] 3700: ffff810012412400 0001000000000000
[ 6708.902759] 3720: ffff810ffbad3900 0000000000000000 0000000060000145 ffff800f79300000
[ 6708.910577] 3740: ffff000009274d00 00000000000003ea 0000000000000015 ffff000008c63000
[ 6708.918395] 3760: ffff810ffbad3830 ffff800f79300000 000000000000004d 0000000000000000
[ 6708.926212] 3780: ffff810ffbad3890 ffff0000080f88dc ffff800f79300000 000000000000004d
[ 6708.934030] 37a0: ffff800f7930093c ffff000008c63000 0000000000000000 0000000000000140
[ 6708.941848] 37c0: ffff000008c2c000 0000000000040b00 ffff81000bbe1e00 0000000000000000
[ 6708.949665] 37e0: 00000000e5000000 0000000000000000 0000000000000000 0000000000000028
[ 6708.957483] 3800: 0000000000000000 0000000000000000 0000000000000000 7374687225000000
[ 6708.965300] 3820: 0000000000000000 00000000f814dd99 722e736f622e676e 0000000000000000
[ 6708.973117] [< (null)>] (null)
[ 6708.977824] [<ffff0000086f9fa4>] tcp_data_queue+0x754/0xc5c
[ 6708.983386] [<ffff0000086fa64c>] tcp_rcv_established+0x1a0/0x67c
[ 6708.989384] [<ffff000008704120>] tcp_v4_do_rcv+0x15c/0x22c
[ 6708.994858] [<ffff000008707418>] tcp_v4_rcv+0xaf0/0xb58
[ 6709.000077] [<ffff0000086df784>] ip_local_deliver_finish+0x10c/0x254
[ 6709.006419] [<ffff0000086dfea4>] ip_local_deliver+0xf0/0xfc
[ 6709.011980] [<ffff0000086dfad4>] ip_rcv_finish+0x208/0x3a4
[ 6709.017454] [<ffff0000086e018c>] ip_rcv+0x2dc/0x3c8
[ 6709.022328] [<ffff000008692fc8>] __netif_receive_skb_core+0x2f8/0xa0c
[ 6709.028758] [<ffff000008696068>] __netif_receive_skb+0x38/0x84
[ 6709.034580] [<ffff00000869611c>] netif_receive_skb_internal+0x68/0xdc
[ 6709.041010] [<ffff000008696bc0>] napi_gro_receive+0xcc/0x1a8
[ 6709.046690] [<ffff0000014b0fc4>] nicvf_cq_intr_handler+0x59c/0x730 [nicvf]
[ 6709.053559] [<ffff0000014b1380>] nicvf_poll+0x38/0xb8 [nicvf]
[ 6709.059295] [<ffff000008697a6c>] net_rx_action+0x2f8/0x464
[ 6709.064771] [<ffff000008081824>] __do_softirq+0x11c/0x308
[ 6709.070164] [<ffff0000080d14e4>] irq_exit+0x12c/0x174
[ 6709.075206] [<ffff00000813101c>] __handle_domain_irq+0x78/0xc4
[ 6709.081027] [<ffff000008081608>] gic_handle_irq+0x94/0x190
[ 6709.086501] Exception stack(0xffff81000689fdf0 to 0xffff81000689ff20)
[ 6709.092929] fde0: 0000810ff2ec0000 ffff000008c10000
[ 6709.100747] fe00: ffff000008c70ef4 0000000000000001 0000000000000000 ffff810ffbad9b18
[ 6709.108565] fe20: ffff810ffbad9c70 ffff8100169d3800 ffff810006843ab0 ffff81000689fe80
[ 6709.116382] fe40: 0000000000000bd0 0000ffffdf979cd0 183f5913da192500 0000ffff8a254ce4
[ 6709.124200] fe60: 0000ffff8a254b78 0000aaab10339808 0000000000000000 0000ffff8a0c2a50
[ 6709.132018] fe80: 0000ffffdf979b10 ffff000008d6d450 ffff000008c10000 ffff000008d6d000
[ 6709.139836] fea0: 0000000000000054 ffff000008cd3dbc 0000000000000000 0000000000000000
[ 6709.147653] fec0: 0000000000000000 0000000000000000 0000000000000000 ffff81000689ff20
[ 6709.155471] fee0: ffff000008085240 ffff81000689ff20 ffff000008085244 0000000060000145
[ 6709.163289] ff00: ffff81000689ff10 ffff00000813f1e4 ffffffffffffffff ffff00000813f238
[ 6709.171107] [<ffff000008082eb4>] el1_irq+0xb4/0x140
[ 6709.175976] [<ffff000008085244>] arch_cpu_idle+0x44/0x11c
[ 6709.181368] [<ffff0000087bf3b8>] default_idle_call+0x20/0x30
[ 6709.187020] [<ffff000008116d50>] do_idle+0x158/0x1e4
[ 6709.191973] [<ffff000008116ff4>] cpu_startup_entry+0x2c/0x30
[ 6709.197624] [<ffff00000808e7cc>] secondary_start_kernel+0x13c/0x160
[ 6709.203878] [<0000000001bc71c4>] 0x1bc71c4
[ 6709.207967] Code: bad PC value
[ 6709.211061] SMP: stopping secondary CPUs
[ 6709.218830] Starting crashdump kernel...
[ 6709.222749] Bye!
---<-snip>---
Signed-off-by: Vadim Lomovtsev <vlomovts@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
[ Upstream commit 4f8a881acc9d1adaf1e552349a0b1df28933a04c ]
As we know in some target's checkentry it may dereference par.entryinfo
to check entry stuff inside. But when sched action calls xt_check_target,
par.entryinfo is set with NULL. It would cause kernel panic when calling
some targets.
It can be reproduce with:
# tc qd add dev eth1 ingress handle ffff:
# tc filter add dev eth1 parent ffff: u32 match u32 0 0 action xt \
-j ECN --ecn-tcp-remove
It could also crash kernel when using target CLUSTERIP or TPROXY.
By now there's no proper value for par.entryinfo in ipt_init_target,
but it can not be set with NULL. This patch is to void all these
panics by setting it with an ipt_entry obj with all members = 0.
Note that this issue has been there since the very beginning.
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
