[ Upstream commit 84aeb437ab98a2bce3d4b2111c79723aedfceb33 ]
The early call to br_stp_change_bridge_id in bridge's newlink can cause
a memory leak if an error occurs during the newlink because the fdb
entries are not cleaned up if a different lladdr was specified, also
another minor issue is that it generates fdb notifications with
ifindex = 0. Another unrelated memory leak is the bridge sysfs entries
which get added on NETDEV_REGISTER event, but are not cleaned up in the
newlink error path. To remove this special case the call to
br_stp_change_bridge_id is done after netdev register and we cleanup the
bridge on changelink error via br_dev_delete to plug all leaks.
This patch makes netlink bridge destruction on newlink error the same as
dellink and ioctl del which is necessary since at that point we have a
fully initialized bridge device.
To reproduce the issue:
$ ip l add br0 address 00:11:22:33:44:55 type bridge group_fwd_mask 1
RTNETLINK answers: Invalid argument
$ rmmod bridge
[ 1822.142525] =============================================================================
[ 1822.143640] BUG bridge_fdb_cache (Tainted: G O ): Objects remaining in bridge_fdb_cache on __kmem_cache_shutdown()
[ 1822.144821] -----------------------------------------------------------------------------
[ 1822.145990] Disabling lock debugging due to kernel taint
[ 1822.146732] INFO: Slab 0x0000000092a844b2 objects=32 used=2 fp=0x00000000fef011b0 flags=0x1ffff8000000100
[ 1822.147700] CPU: 2 PID: 13584 Comm: rmmod Tainted: G B O 4.15.0-rc2+ #87
[ 1822.148578] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 1822.150008] Call Trace:
[ 1822.150510] dump_stack+0x78/0xa9
[ 1822.151156] slab_err+0xb1/0xd3
[ 1822.151834] ? __kmalloc+0x1bb/0x1ce
[ 1822.152546] __kmem_cache_shutdown+0x151/0x28b
[ 1822.153395] shutdown_cache+0x13/0x144
[ 1822.154126] kmem_cache_destroy+0x1c0/0x1fb
[ 1822.154669] SyS_delete_module+0x194/0x244
[ 1822.155199] ? trace_hardirqs_on_thunk+0x1a/0x1c
[ 1822.155773] entry_SYSCALL_64_fastpath+0x23/0x9a
[ 1822.156343] RIP: 0033:0x7f929bd38b17
[ 1822.156859] RSP: 002b:00007ffd160e9a98 EFLAGS: 00000202 ORIG_RAX: 00000000000000b0
[ 1822.157728] RAX: ffffffffffffffda RBX: 00005578316ba090 RCX: 00007f929bd38b17
[ 1822.158422] RDX: 00007f929bd9ec60 RSI: 0000000000000800 RDI: 00005578316ba0f0
[ 1822.159114] RBP: 0000000000000003 R08: 00007f929bff5f20 R09: 00007ffd160e8a11
[ 1822.159808] R10: 00007ffd160e9860 R11: 0000000000000202 R12: 00007ffd160e8a80
[ 1822.160513] R13: 0000000000000000 R14: 0000000000000000 R15: 00005578316ba090
[ 1822.161278] INFO: Object 0x000000007645de29 @offset=0
[ 1822.161666] INFO: Object 0x00000000d5df2ab5 @offset=128
Fixes: 30313a3d5794 ("bridge: Handle IFLA_ADDRESS correctly when creating bridge device")
Fixes: 5b8d5429daa0 ("bridge: netlink: register netdevice before executing changelink")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit b4681c2829e24943aadd1a7bb3a30d41d0a20050 ]
Since commit 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse") the
local table uses the same trie allocated for the main table when custom
rules are not in use.
When a net namespace is dismantled, the main table is flushed and freed
(via an RCU callback) before the local table. In case the callback is
invoked before the local table is iterated, a use-after-free can occur.
Fix this by iterating over the FIB tables in reverse order, so that the
main table is always freed after the local table.
v3: Reworded comment according to Alex's suggestion.
v2: Add a comment to make the fix more explicit per Dave's and Alex's
feedback.
Fixes: 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit 74c4b656c3d92ec4c824ea1a4afd726b7b6568c8 ]
commit 8d79266bc48c ("ip6_tunnel: add collect_md mode to IPv6 tunnels")
introduced new exit point in ipxip6_rcv. however rcu_read_unlock is
missing there. this diff is fixing this
v1->v2:
instead of doing rcu_read_unlock in place, we are going to "drop"
section (to prevent skb leakage)
Fixes: 8d79266bc48c ("ip6_tunnel: add collect_md mode to IPv6 tunnels")
Signed-off-by: Nikita V. Shirokov <tehnerd@fb.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 8cb38a602478e9f806571f6920b0a3298aabf042 ]
The patch(180d8cd942ce) replaces all uses of struct sock fields'
memory_pressure, memory_allocated, sockets_allocated, and sysctl_mem
to accessor macros. But the sockets_allocated field of sctp sock is
not replaced at all. Then replace it now for unifying the code.
Fixes: 180d8cd942ce ("foundations of per-cgroup memory pressure controlling.")
Cc: Glauber Costa <glommer@parallels.com>
Signed-off-by: Tonghao Zhang <zhangtonghao@didichuxing.com>
[ Upstream commit 8f659a03a0ba9289b9aeb9b4470e6fb263d6f483 ]
inet->hdrincl is racy, and could lead to uninitialized stack pointer
usage, so its value should be read only once.
Fixes: c008ba5bdc9f ("ipv4: Avoid reading user iov twice after raw_probe_proto_opt")
Signed-off-by: Mohamed Ghannam <simo.ghannam@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 30791ac41927ebd3e75486f9504b6d2280463bf0 ]
The MD5-key that belongs to a connection is identified by the peer's
IP-address. When we are in tcp_v4(6)_reqsk_send_ack(), we are replying
to an incoming segment from tcp_check_req() that failed the seq-number
checks.
Thus, to find the correct key, we need to use the skb's saddr and not
the daddr.
This bug seems to have been there since quite a while, but probably got
unnoticed because the consequences are not catastrophic. We will call
tcp_v4_reqsk_send_ack only to send a challenge-ACK back to the peer,
thus the connection doesn't really fail.
Fixes: 9501f9722922 ("tcp md5sig: Let the caller pass appropriate key for tcp_v{4,6}_do_calc_md5_hash().")
Signed-off-by: Christoph Paasch <cpaasch@apple.com>
[ Upstream commit c589e69b508d29ed8e644dfecda453f71c02ec27 ]
This commit records the "full bw reached" decision in a new
full_bw_reached bit. This is a pure refactor that does not change the
current behavior, but enables subsequent fixes and improvements.
In particular, this enables simple and clean fixes because the full_bw
and full_bw_cnt can be unconditionally zeroed without worrying about
forgetting that we estimated we filled the pipe in Startup. And it
enables future improvements because multiple code paths can be used
for estimating that we filled the pipe in Startup; any new code paths
only need to set this bit when they think the pipe is full.
Note that this fix intentionally reduces the width of the full_bw_cnt
counter, since we have never used the most significant bit.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Reviewed-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit 14e138a86f6347c6199f610576d2e11c03bec5f0 ]
RDS currently doesn't check if the length of the control message is
large enough to hold the required data, before dereferencing the control
message data. This results in following crash:
BUG: KASAN: stack-out-of-bounds in rds_rdma_bytes net/rds/send.c:1013
[inline]
BUG: KASAN: stack-out-of-bounds in rds_sendmsg+0x1f02/0x1f90
net/rds/send.c:1066
Read of size 8 at addr ffff8801c928fb70 by task syzkaller455006/3157
CPU: 0 PID: 3157 Comm: syzkaller455006 Not tainted 4.15.0-rc3+ #161
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:430
rds_rdma_bytes net/rds/send.c:1013 [inline]
rds_sendmsg+0x1f02/0x1f90 net/rds/send.c:1066
sock_sendmsg_nosec net/socket.c:628 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:638
___sys_sendmsg+0x320/0x8b0 net/socket.c:2018
__sys_sendmmsg+0x1ee/0x620 net/socket.c:2108
SYSC_sendmmsg net/socket.c:2139 [inline]
SyS_sendmmsg+0x35/0x60 net/socket.c:2134
entry_SYSCALL_64_fastpath+0x1f/0x96
RIP: 0033:0x43fe49
RSP: 002b:00007fffbe244ad8 EFLAGS: 00000217 ORIG_RAX: 0000000000000133
RAX: ffffffffffffffda RBX: 00000000004002c8 RCX: 000000000043fe49
RDX: 0000000000000001 RSI: 000000002020c000 RDI: 0000000000000003
RBP: 00000000006ca018 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000217 R12: 00000000004017b0
R13: 0000000000401840 R14: 0000000000000000 R15: 0000000000000000
To fix this, we verify that the cmsg_len is large enough to hold the
data to be read, before proceeding further.
Reported-by: syzbot <syzkaller-bugs@googlegroups.com>
Signed-off-by: Avinash Repaka <avinash.repaka@oracle.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com>
[ Upstream commit 513674b5a2c9c7a67501506419da5c3c77ac6f08 ]
sysctl.ip6.auto_flowlabels is default 1. In our hosts, we set it to 2.
If sockopt doesn't set autoflowlabel, outcome packets from the hosts are
supposed to not include flowlabel. This is true for normal packet, but
not for reset packet.
The reason is ipv6_pinfo.autoflowlabel is set in sock creation. Later if
we change sysctl.ip6.auto_flowlabels, the ipv6_pinfo.autoflowlabel isn't
changed, so the sock will keep the old behavior in terms of auto
flowlabel. Reset packet is suffering from this problem, because reset
packet is sent from a special control socket, which is created at boot
time. Since sysctl.ipv6.auto_flowlabels is 1 by default, the control
socket will always have its ipv6_pinfo.autoflowlabel set, even after
user set sysctl.ipv6.auto_flowlabels to 1, so reset packset will always
have flowlabel. Normal sock created before sysctl setting suffers from
the same issue. We can't even turn off autoflowlabel unless we kill all
socks in the hosts.
To fix this, if IPV6_AUTOFLOWLABEL sockopt is used, we use the
autoflowlabel setting from user, otherwise we always call
ip6_default_np_autolabel() which has the new settings of sysctl.
Note, this changes behavior a little bit. Before commit 42240901f7c4
(ipv6: Implement different admin modes for automatic flow labels), the
autoflowlabel behavior of a sock isn't sticky, eg, if sysctl changes,
existing connection will change autoflowlabel behavior. After that
commit, autoflowlabel behavior is sticky in the whole life of the sock.
With this patch, the behavior isn't sticky again.
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Tom Herbert <tom@quantonium.net>
Signed-off-by: Shaohua Li <shli@fb.com>
[ Upstream commit 93c647643b48f0131f02e45da3bd367d80443291 ]
Currently, a nlmon link inside a child namespace can observe systemwide
netlink activity. Filter the traffic so that nlmon can only sniff
netlink messages from its own netns.
Test case:
vpnns -- bash -c "ip link add nlmon0 type nlmon; \
ip link set nlmon0 up; \
tcpdump -i nlmon0 -q -w /tmp/nlmon.pcap -U" &
sudo ip xfrm state add src 10.1.1.1 dst 10.1.1.2 proto esp \
spi 0x1 mode transport \
auth sha1 0x6162633132330000000000000000000000000000 \
enc aes 0x00000000000000000000000000000000
grep --binary abc123 /tmp/nlmon.pcap
Signed-off-by: Kevin Cernekee <cernekee@chromium.org>
[ Upstream commit a46182b00290839fa3fa159d54fd3237bd8669f0 ]
Closing a multicast socket after the final IPv4 address is deleted
from an interface can generate a membership report that uses the
source IP from a different interface. The following test script, run
from an isolated netns, reproduces the issue:
#!/bin/bash
ip link add dummy0 type dummy
ip link add dummy1 type dummy
ip link set dummy0 up
ip link set dummy1 up
ip addr add 10.1.1.1/24 dev dummy0
ip addr add 192.168.99.99/24 dev dummy1
tcpdump -U -i dummy0 &
socat EXEC:"sleep 2" \
UDP4-DATAGRAM:239.101.1.68:8889,ip-add-membership=239.0.1.68:10.1.1.1 &
sleep 1
ip addr del 10.1.1.1/24 dev dummy0
sleep 5
kill %tcpdump
RFC 3376 specifies that the report must be sent with a valid IP source
address from the destination subnet, or from address 0.0.0.0. Add an
extra check to make sure this is the case.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit b9b312a7a451e9c098921856e7cfbc201120e1a7 ]
syzkaller reported crashes in IPv6 stack [1]
Xin Long found that lo MTU was set to silly values.
IPv6 stack reacts to changes to small MTU, by disabling itself under
RTNL.
But there is a window where threads not using RTNL can see a wrong
device mtu. This can lead to surprises, in mld code where it is assumed
the mtu is suitable.
Fix this by reading device mtu once and checking IPv6 minimal MTU.
[1]
skbuff: skb_over_panic: text:0000000010b86b8d len:196 put:20
head:000000003b477e60 data:000000000e85441e tail:0xd4 end:0xc0 dev:lo
kernel BUG at net/core/skbuff.c:104!
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.15.0-rc2-mm1+ #39
Google 01/01/2011
RIP: 0010:skb_panic+0x15c/0x1f0 net/core/skbuff.c:100
RSP: 0018:ffff8801db307508 EFLAGS: 00010286
RAX: 0000000000000082 RBX: ffff8801c517e840 RCX: 0000000000000000
RDX: 0000000000000082 RSI: 1ffff1003b660e61 RDI: ffffed003b660e95
RBP: ffff8801db307570 R08: 1ffff1003b660e23 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffff85bd4020
R13: ffffffff84754ed2 R14: 0000000000000014 R15: ffff8801c4e26540
FS: 0000000000000000(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000
CR2: 0000000000463610 CR3: 00000001c6698000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
<IRQ>
skb_over_panic net/core/skbuff.c:109 [inline]
skb_put+0x181/0x1c0 net/core/skbuff.c:1694
add_grhead.isra.24+0x42/0x3b0 net/ipv6/mcast.c:1695
add_grec+0xa55/0x1060 net/ipv6/mcast.c:1817
mld_send_cr net/ipv6/mcast.c:1903 [inline]
mld_ifc_timer_expire+0x4d2/0x770 net/ipv6/mcast.c:2448
call_timer_fn+0x23b/0x840 kernel/time/timer.c:1320
expire_timers kernel/time/timer.c:1357 [inline]
__run_timers+0x7e1/0xb60 kernel/time/timer.c:1660
run_timer_softirq+0x4c/0xb0 kernel/time/timer.c:1686
__do_softirq+0x29d/0xbb2 kernel/softirq.c:285
invoke_softirq kernel/softirq.c:365 [inline]
irq_exit+0x1d3/0x210 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:540 [inline]
smp_apic_timer_interrupt+0x16b/0x700 arch/x86/kernel/apic/apic.c:1052
apic_timer_interrupt+0xa9/0xb0 arch/x86/entry/entry_64.S:920
Reported-by: syzbot <syzkaller@googlegroups.com>
Tested-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit b5476022bbada3764609368f03329ca287528dc8 ]
IPv4 stack reacts to changes to small MTU, by disabling itself under
RTNL.
device mtu. This can lead to surprises, in igmp code where it is
assumed the mtu is suitable.
Fix this by reading device mtu once and checking IPv4 minimal MTU.
This patch adds missing IPV4_MIN_MTU define, to not abuse
ETH_MIN_MTU anymore.
[ Upstream commit cf5d74b85ef40c202c76d90959db4d850f301b95 ]
With the commit 76174004a0f19785 (tcp: do not slow start when cwnd equals
ssthresh), the comparison to the reduced cwnd in tcp_vegas_ssthresh() would
under-evaluate the ssthresh.
Signed-off-by: Hoang Tran <hoang.tran@uclouvain.be>
[ Upstream commit 1f372c7bfb23286d2bf4ce0423ab488e86b74bb2 ]
The NS for DAD are sent on admin up as long as a valid qdisc is found.
A race condition exists by which these packets will not egress the
interface if the operational state of the lower device is not yet up.
The solution is to delay DAD until the link is operationally up
according to RFC2863. Rather than only doing this, follow the existing
code checks by deferring IPv6 device initialization altogether. The fix
allows DAD on devices like tunnels that are controlled by userspace
control plane. The fix has no impact on regular deployments, but means
that there is no IPv6 connectivity until the port has been opened in
the case of port-based network access control, which should be
desirable.
Signed-off-by: Mike Manning <mmanning@brocade.com>
[ Upstream commit 77c1c03c5b8ef28e55bb0aff29b1e006037ca645 ]
We must call security_release_secctx to free the memory returned by
security_secid_to_secctx, otherwise memory may be leaked forever.
Fixes: ef493bd930ae ("netfilter: nfnetlink_queue: add security context information")
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
[ Upstream commit ffefb6f4d6ad699a2b5484241bc46745a53235d0 ]
Our chosen ic_dev may be anywhere in our list of ic_devs, and we may
free it before attempting to close others. When we compare d->dev and
ic_dev->dev, we're potentially dereferencing memory returned to the
allocator. This causes KASAN to scream for each subsequent ic_dev we
check.
As there's a 1-1 mapping between ic_devs and netdevs, we can instead
compare d and ic_dev directly, which implicitly handles the !ic_dev
case, and avoids the use-after-free. The ic_dev pointer may be stale,
but we will not dereference it.
Original splat:
[ 6.487446] ==================================================================
[ 6.494693] BUG: KASAN: use-after-free in ic_close_devs+0xc4/0x154 at addr ffff800367efa708
[ 6.503013] Read of size 8 by task swapper/0/1
[ 6.507452] CPU: 5 PID: 1 Comm: swapper/0 Not tainted 4.11.0-rc3-00002-gda42158 #8
[ 6.514993] Hardware name: AppliedMicro Mustang/Mustang, BIOS 3.05.05-beta_rc Jan 27 2016
[ 6.523138] Call trace:
[ 6.525590] [<ffff200008094778>] dump_backtrace+0x0/0x570
[ 6.530976] [<ffff200008094d08>] show_stack+0x20/0x30
[ 6.536017] [<ffff200008bee928>] dump_stack+0x120/0x188
[ 6.541231] [<ffff20000856d5e4>] kasan_object_err+0x24/0xa0
[ 6.546790] [<ffff20000856d924>] kasan_report_error+0x244/0x738
[ 6.552695] [<ffff20000856dfec>] __asan_report_load8_noabort+0x54/0x80
[ 6.559204] [<ffff20000aae86ac>] ic_close_devs+0xc4/0x154
[ 6.564590] [<ffff20000aaedbac>] ip_auto_config+0x2ed4/0x2f1c
[ 6.570321] [<ffff200008084b04>] do_one_initcall+0xcc/0x370
[ 6.575882] [<ffff20000aa31de8>] kernel_init_freeable+0x5f8/0x6c4
[ 6.581959] [<ffff20000a16df00>] kernel_init+0x18/0x190
[ 6.587171] [<ffff200008084710>] ret_from_fork+0x10/0x40
[ 6.592468] Object at ffff800367efa700, in cache kmalloc-128 size: 128
[ 6.598969] Allocated:
[ 6.601324] PID = 1
[ 6.603427] save_stack_trace_tsk+0x0/0x418
[ 6.607603] save_stack_trace+0x20/0x30
[ 6.611430] kasan_kmalloc+0xd8/0x188
[ 6.615087] ip_auto_config+0x8c4/0x2f1c
[ 6.619002] do_one_initcall+0xcc/0x370
[ 6.622832] kernel_init_freeable+0x5f8/0x6c4
[ 6.627178] kernel_init+0x18/0x190
[ 6.630660] ret_from_fork+0x10/0x40
[ 6.634223] Freed:
[ 6.636233] PID = 1
[ 6.638334] save_stack_trace_tsk+0x0/0x418
[ 6.642510] save_stack_trace+0x20/0x30
[ 6.646337] kasan_slab_free+0x88/0x178
[ 6.650167] kfree+0xb8/0x478
[ 6.653131] ic_close_devs+0x130/0x154
[ 6.656875] ip_auto_config+0x2ed4/0x2f1c
[ 6.660875] do_one_initcall+0xcc/0x370
[ 6.664705] kernel_init_freeable+0x5f8/0x6c4
[ 6.669051] kernel_init+0x18/0x190
[ 6.672534] ret_from_fork+0x10/0x40
[ 6.676098] Memory state around the buggy address:
[ 6.680880] ffff800367efa600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.688078] ffff800367efa680: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 6.695276] >ffff800367efa700: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 6.702469] ^
[ 6.705952] ffff800367efa780: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 6.713149] ffff800367efa800: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 6.720343] ==================================================================
[ 6.727536] Disabling lock debugging due to kernel taint
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: netdev@vger.kernel.org
[ Upstream commit 75c689dca98851d65ef5a27e5ce26b625b68751c ]
In the commit 93557f53e1fb ("netfilter: nf_conntrack: nf_conntrack snmp
helper"), the snmp_helper is replaced by nf_nat_snmp_hook. So the
snmp_helper is never registered. But it still tries to unregister the
snmp_helper, it could cause the panic.
Now remove the useless snmp_helper and the unregister call in the
error handler.
Fixes: 93557f53e1fb ("netfilter: nf_conntrack: nf_conntrack snmp helper")
Signed-off-by: Gao Feng <fgao@ikuai8.com>
[ Upstream commit 83d90219a5df8d950855ce73229a97b63605c317 ]
The nf_ct_helper_hash table is protected by nf_ct_helper_mutex, while
nfct_helper operation is protected by nfnl_lock(NFNL_SUBSYS_CTHELPER).
So it's possible that one CPU is walking the nf_ct_helper_hash for
cthelper add/get/del, another cpu is doing nf_conntrack_helpers_unregister
at the same time. This is dangrous, and may cause use after free error.
Note, delete operation will flush all cthelpers added via nfnetlink, so
using rcu to do protect is not easy.
Now introduce a dummy list to record all the cthelpers added via
nfnetlink, then we can walk the dummy list instead of walking the
nf_ct_helper_hash. Also, keep nfnl_cthelper_dump_table unchanged, it
may be invoked without nfnl_lock(NFNL_SUBSYS_CTHELPER) held.
[ Upstream commit 95f255211396958c718aef8c45e3923b5211ea7b ]
This change basically codifies what I think was already the limitations on
the busy_poll and busy_read sysctl interfaces. We weren't checking the
lower bounds and as such could input negative values. The behavior when
that was used was dependent on the architecture. In order to prevent any
issues with that I am just disabling support for values less than 0 since
this way we don't have to worry about any odd behaviors.
By limiting the sysctl values this way it also makes it consistent with how
we handle the SO_BUSY_POLL socket option since the value appears to be
reported as a signed integer value and negative values are rejected.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit ec4fbd64751de18729eaa816ec69e4b504b5a7a2 ]
Dmitry reported a lockdep splat [1] (false positive) that we can fix
by releasing the spinlock before calling icmp_send() from ip_expire()
This is a false positive because sending an ICMP message can not
possibly re-enter the IP frag engine.
[1]
[ INFO: possible circular locking dependency detected ]
4.10.0+ #29 Not tainted
modprobe/12392 is trying to acquire lock:
(_xmit_ETHER#2){+.-...}, at: [<ffffffff837a8182>] spin_lock
include/linux/spinlock.h:299 [inline]
(_xmit_ETHER#2){+.-...}, at: [<ffffffff837a8182>] __netif_tx_lock
include/linux/netdevice.h:3486 [inline]
sch_direct_xmit+0x282/0x6d0 net/sched/sch_generic.c:180
but task is already holding lock:
(&(&q->lock)->rlock){+.-...}, at: [<ffffffff8389a4d1>] spin_lock
ip_expire+0x51/0x6c0 net/ipv4/ip_fragment.c:201
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&(&q->lock)->rlock){+.-...}:
validate_chain kernel/locking/lockdep.c:2267 [inline]
__lock_acquire+0x2149/0x3430 kernel/locking/lockdep.c:3340
lock_acquire+0x2a1/0x630 kernel/locking/lockdep.c:3755
__raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline]
_raw_spin_lock+0x33/0x50 kernel/locking/spinlock.c:151
spin_lock include/linux/spinlock.h:299 [inline]
ip_defrag+0x3a2/0x4130 net/ipv4/ip_fragment.c:669
ip_check_defrag+0x4e3/0x8b0 net/ipv4/ip_fragment.c:713
packet_rcv_fanout+0x282/0x800 net/packet/af_packet.c:1459
deliver_skb net/core/dev.c:1834 [inline]
dev_queue_xmit_nit+0x294/0xa90 net/core/dev.c:1890
xmit_one net/core/dev.c:2903 [inline]
dev_hard_start_xmit+0x16b/0xab0 net/core/dev.c:2923
sch_direct_xmit+0x31f/0x6d0 net/sched/sch_generic.c:182
__dev_xmit_skb net/core/dev.c:3092 [inline]
__dev_queue_xmit+0x13e5/0x1e60 net/core/dev.c:3358
dev_queue_xmit+0x17/0x20 net/core/dev.c:3423
neigh_resolve_output+0x6b9/0xb10 net/core/neighbour.c:1308
neigh_output include/net/neighbour.h:478 [inline]
ip_finish_output2+0x8b8/0x15a0 net/ipv4/ip_output.c:228
ip_do_fragment+0x1d93/0x2720 net/ipv4/ip_output.c:672
ip_fragment.constprop.54+0x145/0x200 net/ipv4/ip_output.c:545
ip_finish_output+0x82d/0xe10 net/ipv4/ip_output.c:314
NF_HOOK_COND include/linux/netfilter.h:246 [inline]
ip_output+0x1f0/0x7a0 net/ipv4/ip_output.c:404
dst_output include/net/dst.h:486 [inline]
ip_local_out+0x95/0x170 net/ipv4/ip_output.c:124
ip_send_skb+0x3c/0xc0 net/ipv4/ip_output.c:1492
ip_push_pending_frames+0x64/0x80 net/ipv4/ip_output.c:1512
raw_sendmsg+0x26de/0x3a00 net/ipv4/raw.c:655
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:761
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
___sys_sendmsg+0x4a3/0x9f0 net/socket.c:1985
__sys_sendmmsg+0x25c/0x750 net/socket.c:2075
SYSC_sendmmsg net/socket.c:2106 [inline]
SyS_sendmmsg+0x35/0x60 net/socket.c:2101
do_syscall_64+0x2e8/0x930 arch/x86/entry/common.c:281
return_from_SYSCALL_64+0x0/0x7a
-> #0 (_xmit_ETHER#2){+.-...}:
check_prev_add kernel/locking/lockdep.c:1830 [inline]
check_prevs_add+0xa8f/0x19f0 kernel/locking/lockdep.c:1940
__netif_tx_lock include/linux/netdevice.h:3486 [inline]
neigh_hh_output include/net/neighbour.h:468 [inline]
neigh_output include/net/neighbour.h:476 [inline]
ip_finish_output2+0xf6c/0x15a0 net/ipv4/ip_output.c:228
ip_finish_output+0xa29/0xe10 net/ipv4/ip_output.c:316
icmp_push_reply+0x372/0x4d0 net/ipv4/icmp.c:394
icmp_send+0x156c/0x1c80 net/ipv4/icmp.c:754
ip_expire+0x40e/0x6c0 net/ipv4/ip_fragment.c:239
call_timer_fn+0x241/0x820 kernel/time/timer.c:1268
expire_timers kernel/time/timer.c:1307 [inline]
__run_timers+0x960/0xcf0 kernel/time/timer.c:1601
run_timer_softirq+0x21/0x80 kernel/time/timer.c:1614
__do_softirq+0x31f/0xbe7 kernel/softirq.c:284
invoke_softirq kernel/softirq.c:364 [inline]
irq_exit+0x1cc/0x200 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:657 [inline]
smp_apic_timer_interrupt+0x76/0xa0 arch/x86/kernel/apic/apic.c:962
apic_timer_interrupt+0x93/0xa0 arch/x86/entry/entry_64.S:707
__read_once_size include/linux/compiler.h:254 [inline]
atomic_read arch/x86/include/asm/atomic.h:26 [inline]
rcu_dynticks_curr_cpu_in_eqs kernel/rcu/tree.c:350 [inline]
__rcu_is_watching kernel/rcu/tree.c:1133 [inline]
rcu_is_watching+0x83/0x110 kernel/rcu/tree.c:1147
rcu_read_lock_held+0x87/0xc0 kernel/rcu/update.c:293
radix_tree_deref_slot include/linux/radix-tree.h:238 [inline]
filemap_map_pages+0x6d4/0x1570 mm/filemap.c:2335
do_fault_around mm/memory.c:3231 [inline]
do_read_fault mm/memory.c:3265 [inline]
do_fault+0xbd5/0x2080 mm/memory.c:3370
handle_pte_fault mm/memory.c:3600 [inline]
__handle_mm_fault+0x1062/0x2cb0 mm/memory.c:3714
handle_mm_fault+0x1e2/0x480 mm/memory.c:3751
__do_page_fault+0x4f6/0xb60 arch/x86/mm/fault.c:1397
do_page_fault+0x54/0x70 arch/x86/mm/fault.c:1460
page_fault+0x28/0x30 arch/x86/entry/entry_64.S:1011
Possible unsafe locking scenario:
CPU0 CPU1
lock(&(&q->lock)->rlock);
lock(_xmit_ETHER#2);
*** DEADLOCK ***
10 locks held by modprobe/12392:
#0: (&mm->mmap_sem){++++++}, at: [<ffffffff81329758>]
__do_page_fault+0x2b8/0xb60 arch/x86/mm/fault.c:1336
#1: (rcu_read_lock){......}, at: [<ffffffff8188cab6>]
filemap_map_pages+0x1e6/0x1570 mm/filemap.c:2324
#2: (&(ptlock_ptr(page))->rlock#2){+.+...}, at: [<ffffffff81984a78>]
pte_alloc_one_map mm/memory.c:2944 [inline]
alloc_set_pte+0x13b8/0x1b90 mm/memory.c:3072
#3: (((&q->timer))){+.-...}, at: [<ffffffff81627e72>]
lockdep_copy_map include/linux/lockdep.h:175 [inline]
call_timer_fn+0x1c2/0x820 kernel/time/timer.c:1258
#4: (&(&q->lock)->rlock){+.-...}, at: [<ffffffff8389a4d1>] spin_lock
#5: (rcu_read_lock){......}, at: [<ffffffff8389a633>]
ip_expire+0x1b3/0x6c0 net/ipv4/ip_fragment.c:216
#6: (slock-AF_INET){+.-...}, at: [<ffffffff839b3313>] spin_trylock
include/linux/spinlock.h:309 [inline]
#6: (slock-AF_INET){+.-...}, at: [<ffffffff839b3313>] icmp_xmit_lock
net/ipv4/icmp.c:219 [inline]
icmp_send+0x803/0x1c80 net/ipv4/icmp.c:681
#7: (rcu_read_lock_bh){......}, at: [<ffffffff838ab9a1>]
ip_finish_output2+0x2c1/0x15a0 net/ipv4/ip_output.c:198
#8: (rcu_read_lock_bh){......}, at: [<ffffffff836d1dee>]
__dev_queue_xmit+0x23e/0x1e60 net/core/dev.c:3324
#9: (dev->qdisc_running_key ?: &qdisc_running_key){+.....}, at:
[<ffffffff836d3a27>] dev_queue_xmit+0x17/0x20 net/core/dev.c:3423
stack backtrace:
CPU: 0 PID: 12392 Comm: modprobe Not tainted 4.10.0+ #29
BIOS Google 01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x2ee/0x3ef lib/dump_stack.c:52
print_circular_bug+0x307/0x3b0 kernel/locking/lockdep.c:1204
RIP: 0010:__read_once_size include/linux/compiler.h:254 [inline]
RIP: 0010:atomic_read arch/x86/include/asm/atomic.h:26 [inline]
RIP: 0010:rcu_dynticks_curr_cpu_in_eqs kernel/rcu/tree.c:350 [inline]
RIP: 0010:__rcu_is_watching kernel/rcu/tree.c:1133 [inline]
RIP: 0010:rcu_is_watching+0x83/0x110 kernel/rcu/tree.c:1147
RSP: 0000:ffff8801c391f120 EFLAGS: 00000a03 ORIG_RAX: ffffffffffffff10
RAX: dffffc0000000000 RBX: ffff8801c391f148 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 000055edd4374000 RDI: ffff8801dbe1ae0c
RBP: ffff8801c391f1a0 R08: 0000000000000002 R09: 0000000000000000
R10: dffffc0000000000 R11: 0000000000000002 R12: 1ffff10038723e25
R13: ffff8801dbe1ae00 R14: ffff8801c391f680 R15: dffffc0000000000
</IRQ>
RIP: 0033:0x7f83172f2786
RSP: 002b:00007fffe859ae80 EFLAGS: 00010293
RAX: 000055edd4373040 RBX: 00007f83175111c8 RCX: 000055edd4373238
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 00007f8317510970
RBP: 00007fffe859afd0 R08: 0000000000000009 R09: 0000000000000000
R10: 0000000000000064 R11: 0000000000000000 R12: 000055edd4373040
R13: 0000000000000000 R14: 00007fffe859afe8 R15: 0000000000000000
[ Upstream commit 557d054c01da0337ca81de9e9d9206d57245b57e ]
Until now, tipc_nametbl_unsubscribe() is called at subscriptions
reference count cleanup. Usually the subscriptions cleanup is
called at subscription timeout or at subscription cancel or at
subscriber delete.
We have ignored the possibility of this being called from other
locations, which causes deadlock as we try to grab the
tn->nametbl_lock while holding it already.
CPU1: CPU2:
tipc_nametbl_publish
spin_lock_bh(&tn->nametbl_lock)
tipc_nametbl_insert_publ
tipc_nameseq_insert_publ
tipc_subscrp_report_overlap
tipc_subscrp_get
tipc_subscrp_send_event
tipc_close_conn
tipc_subscrb_release_cb
tipc_subscrb_delete
tipc_subscrp_put
tipc_subscrp_put
tipc_subscrp_kref_release
<<grab nametbl_lock again>>
CPU1: CPU2:
tipc_nametbl_stop
tipc_purge_publications
tipc_nameseq_remove_publ
tipc_subscrp_get
tipc_close_conn
tipc_subscrb_delete
tipc_subscrp_put
tipc_subscrp_put
In this commit, we advance the calling of tipc_nametbl_unsubscribe()
from the refcount cleanup to the intended callers.
Fixes: d094c4d5f5c7 ("tipc: add subscription refcount to avoid invalid delete")
Reported-by: John Thompson <thompa.atl@gmail.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
[ Upstream commit f83bf8da1135ca635aac8f062cad3f001fcf3a26 ]
We have memory leaks of nf_conntrack_helper & expect_policy.
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
[ Upstream commit 2c422257550f123049552b39f7af6e3428a60f43 ]
We only allow runtime updates of expectation policies for timeout and
maximum number of expectations, otherwise reject the update.
Acked-by: Liping Zhang <zlpnobody@gmail.com>
[ Upstream commit 23bb09cfbe04076ef647da3889a5a5ab6cbe6f15 ]
This patch is to fix the issue that sctp_prsctp_prune_sent forgot
to update q->out_qlen when removing a chunk from unsent queue.
Fixes: 8dbdf1f5b09c ("sctp: implement prsctp PRIO policy")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit aea92fb2e09e29653b023d4254ac9fbf94221538 ]
skb_cow(skb, sizeof(ip header)) is not very helpful in this context.
First we need to use pskb_may_pull() to make sure the ip header
is in skb linear part, then use skb_try_make_writable() to
address clones issues.
Fixes: 4c30719f4f55 ("[PKT_SCHED] dsmark: handle cloned and non-linear skb's")
[ Upstream commit 380feae0def7e6a115124a3219c3ec9b654dca32 ]
Otherwise we'll leave the packets queued until releasing vsock device.
E.g., if guest is slow to start up, resulting ETIMEDOUT on connect, guest
will get the connect requests from failed host sockets.
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
Reviewed-by: Jorgen Hansen <jhansen@vmware.com>
Signed-off-by: Peng Tao <bergwolf@gmail.com>
[ Upstream commit 36d277bac8080202684e67162ebb157f16631581 ]
So that we can cancel a queued pkt later if necessary.
[ Upstream commit 8a0f5ccfb33b0b8b51de65b7b3bf342ba10b4fb6 ]
On Tue, Mar 14, 2017 at 10:44:10AM +0100, Dmitry Vyukov wrote:
> Yes, please.
> Disregarding some reports is not a good way long term.
Please try this patch.
---8<---
Subject: netlink: Annotate nlk cb_mutex by protocol
Currently all occurences of nlk->cb_mutex are annotated by lockdep
as a single class. This causes a false lcokdep cycle involving
genl and crypto_user.
This patch fixes it by dividing cb_mutex into individual classes
based on the netlink protocol. As genl and crypto_user do not
use the same netlink protocol this breaks the false dependency
loop.
[ Upstream commit 258bbb1b0e594ad5f5652cb526b3c63e6a7fad3d ]
The ICMP implementation currently replies to an ICMP time exceeded message
(type 11) with an ICMP host unreachable message (type 3, code 1).
However, time exceeded messages can either represent "time to live exceeded
in transit" (code 0) or "fragment reassembly time exceeded" (code 1).
Unconditionally replying to "fragment reassembly time exceeded" with
host unreachable messages might cause unjustified connection resets
which are now easily triggered as UFO has been removed, because, in turn,
sending large buffers triggers IP fragmentation.
The issue can be easily reproduced by running a lot of UDP streams
which is likely to trigger IP fragmentation:
# start netserver in the test namespace
ip netns add test
ip netns exec test netserver
# create a VETH pair
ip link add name veth0 type veth peer name veth0 netns test
ip link set veth0 up
ip -n test link set veth0 up
for i in $(seq 20 29); do
# assign addresses to both ends
ip addr add dev veth0 192.168.$i.1/24
ip -n test addr add dev veth0 192.168.$i.2/24
# start the traffic
netperf -L 192.168.$i.1 -H 192.168.$i.2 -t UDP_STREAM -l 0 &
done
# wait
send_data: data send error: No route to host (errno 113)
netperf: send_omni: send_data failed: No route to host
We need to differentiate instead: if fragment reassembly time exceeded
is reported, we need to silently drop the packet,
if time to live exceeded is reported, maintain the current behaviour.
In both cases increment the related error count "icmpInTimeExcds".
While at it, fix a typo in a comment, and convert the if statement
into a switch to mate it more readable.
Signed-off-by: Matteo Croce <mcroce@redhat.com>
[ Upstream commit 4dc12ffeaeac939097a3f55c881d3dc3523dff0c ]
l2tp_tunnel_delete does not return anything since commit 62b982eeb458
("l2tp: fix race condition in l2tp_tunnel_delete"). But call sites of
l2tp_tunnel_delete still do casts to void to avoid unused return value
warnings.
Kill these now useless casts.
Cc: Sabrina Dubroca <sd@queasysnail.net>
Cc: Guillaume Nault <g.nault@alphalink.fr>
Acked-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit c5504f724c86ee925e7ffb80aa342cfd57959b13 ]
Information about ipvs in different network namespace can be seen via procfs.
How to reproduce:
# ip netns add ns01
# ip netns add ns02
# ip netns exec ns01 ip a add dev lo 127.0.0.1/8
# ip netns exec ns02 ip a add dev lo 127.0.0.1/8
# ip netns exec ns01 ipvsadm -A -t 10.1.1.1:80
# ip netns exec ns02 ipvsadm -A -t 10.1.1.2:80
The ipvsadm displays information about its own network namespace only.
# ip netns exec ns01 ipvsadm -Ln
IP Virtual Server version 1.2.1 (size=4096)
Prot LocalAddress:Port Scheduler Flags
-> RemoteAddress:Port Forward Weight ActiveConn InActConn
TCP 10.1.1.1:80 wlc
# ip netns exec ns02 ipvsadm -Ln
TCP 10.1.1.2:80 wlc
But I can see information about other network namespace via procfs.
# ip netns exec ns01 cat /proc/net/ip_vs
TCP 0A010101:0050 wlc
TCP 0A010102:0050 wlc
# ip netns exec ns02 cat /proc/net/ip_vs
Signed-off-by: KUWAZAWA Takuya <albatross0@gmail.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit 4d4a6ac73e7466c2085c307fac41f74ce4568a45 ]
If we receive a BUSY packet for a call we think we've just completed, the
packet is handed off to the connection processor to deal with - but the
connection processor doesn't expect a BUSY packet and so flags a protocol
error.
Fix this by simply ignoring the BUSY packet for the moment.
The symptom of this may appear as a system call failing with EPROTO. This
may be triggered by pressing ctrl-C under some circumstances.
This comes about we abort calls due to interruption by a signal (which we
shouldn't do, but that's going to be a large fix and mostly in fs/afs/).
What happens is that we abort the call and may also abort follow up calls
too (this needs offloading somehoe). So we see a transmission of something
like the following sequence of packets:
DATA for call N
ABORT call N
DATA for call N+1
ABORT call N+1
in very quick succession on the same channel. However, the peer may have
deferred the processing of the ABORT from the call N to a background thread
and thus sees the DATA message from the call N+1 coming in before it has
cleared the channel. Thus it sends a BUSY packet[*].
[*] Note that some implementations (OpenAFS, for example) mark the BUSY
packet with one plus the callNumber of the call prior to call N.
Ordinarily, this would be call N, but there's no requirement for the
calls on a channel to be numbered strictly sequentially (the number is
required to increase).
This is wrong and means that the callNumber in the BUSY packet should
be ignored (it really ought to be N+1 since that's what it's in
response to).
[ Upstream commit 61733c91c454a61be0ffc93fe46a5d5f2f048c1c ]
Alive tracking of nexthops can account for a link twice if the carrier
goes down followed by an admin down of the same link rendering multipath
routes useless. This is similar to 79099aab38c8 for UNREGISTER events and
DOWN events.
Fix by tracking number of alive nexthops in mpls_ifdown similar to the
logic in mpls_ifup. Checking the flags per nexthop once after all events
have been processed is simpler than trying to maintian a running count
through all event combinations.
Also, WRITE_ONCE is used instead of ACCESS_ONCE to set rt_nhn_alive
per a comment from checkpatch:
WARNING: Prefer WRITE_ONCE(<FOO>, <BAR>) over ACCESS_ONCE(<FOO>) = <BAR>
Fixes: c89359a42e2a4 ("mpls: support for dead routes")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Acked-by: Robert Shearman <rshearma@brocade.com>
[ Upstream commit 37c343b4f4e70e9dc328ab04903c0ec8d154c1a4 ]
When we notify peers of potential changes, it's also good to update
IGMP memberships. For example, during VM migration, updating IGMP
memberships will redirect existing multicast streams to the VM at the
new location.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 4ca60d08cbe65f501baad64af50fceba79c19fbb ]
consider a bridge with mtu 9000, but end host sending smaller
packets to another host with mtu < 9000.
In this case, after reassembly, bridge+defrag would refragment,
and then attempt to send the reassembled packet as long as it
was below 9k.
Instead we have to cap by the largest fragment size seen.
[ Upstream commit 702f2ac87a9a8da23bf8506466bc70175fc970b2 ]
The RxRPC ACK packet may contain an extension that includes the peer's
current Rx window size for this call. We adjust the local Tx window size
to match. However, the transmitter can stall if the receive window is
reduced to 0 by the peer and then reopened.
This is because the normal way that the transmitter is re-energised is by
dropping something out of our Tx queue and thus making space. When a
single gap is made, the transmitter is woken up. However, because there's
nothing in the Tx queue at this point, this doesn't happen.
To fix this, perform a wake_up() any time we see the peer's Rx window size
increasing.
The observable symptom is that calls start failing on ETIMEDOUT and the
following:
kAFS: SERVER DEAD state=-62
appears in dmesg.
[ Upstream commit 9f138fa609c47403374a862a08a41394be53d461 ]
KMSAN reports a use of uninitialized memory in put_cmsg() because
msg.msg_flags in recvfrom haven't been initialized properly.
The flag values don't affect the result on this path, but it's still a
good idea to initialize them explicitly.
Signed-off-by: Alexander Potapenko <glider@google.com>
commit 57629915d568c522ac1422df7bba4bee5b5c7a7c upstream.
The code was setting the capabilities byte to zero,
after it was already properly set previously. Fix it.
The bug was found while debugging hwsim mesh tests failures
that happened since the commit mentioned below.
Fixes: 76f43b4c0a93 ("mac80211: Remove invalid flag operations in mesh TSF synchronization")
Signed-off-by: Ilan Peer <ilan.peer@intel.com>
Reviewed-by: Masashi Honma <masashi.honma@gmail.com>
Cc: Richard Schütz <rschuetz@uni-koblenz.de>
Cc: Mathias Kretschmer <mathias.kretschmer@fit.fraunhofer.de>
commit a5739435b5a3b8c449f8844ecd71a3b1e89f0a33 upstream.
1) it's fput() or sock_release(), not both
2) don't do fd_install() until the last failure exit.
3) not a bug per se, but... don't attach socket to struct file
until it's set up.
Take reserving descriptor into the caller, move fd_install() to the
caller, sanitize failure exits and calling conventions.
Acked-by: Tom Herbert <tom@herbertland.com>
[This fix is only needed for v4.9 stable since v4.10+ does not have the issue]
A verdict of NF_STOLEN after NF_QUEUE will cause an incorrect return value
and a potential kernel panic via double free of skb's
This was broken by commit 7034b566a4e7 ("netfilter: fix nf_queue handling")
and subsequently fixed in v4.10 by commit c63cbc460419 ("netfilter:
use switch() to handle verdict cases from nf_hook_slow()"). However that
commit cannot be cleanly cherry-picked to v4.9
Signed-off-by: Debabrata Banerjee <dbanerje@akamai.com>
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
[ Upstream commit c7799c067c2ae33e348508c8afec354f3257ff25 ]
Remove the second tipc_rcv() call in tipc_udp_recv(). We have just
checked that the bearer is not up, and calling tipc_rcv() with a bearer
that is not up leads to a TIPC div-by-zero crash in
tipc_node_calculate_timer(). The crash is rare in practice, but can
happen like this:
We're enabling a bearer, but it's not yet up and fully initialized.
At the same time we receive a discovery packet, and in tipc_udp_recv()
we end up calling tipc_rcv() with the not-yet-initialized bearer,
causing later the div-by-zero crash in tipc_node_calculate_timer().
Jon Maloy explains the impact of removing the second tipc_rcv() call:
"link setup in the worst case will be delayed until the next arriving
discovery messages, 1 sec later, and this is an acceptable delay."
As the tipc_rcv() call is removed, just leave the function via the
rcu_out label, so that we will kfree_skb().
[ 12.590450] Own node address <1.1.1>, network identity 1
[ 12.668088] divide error: 0000 [#1] SMP
[ 12.676952] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.14.2-dirty #1
[ 12.679225] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-2.fc27 04/01/2014
[ 12.682095] task: ffff8c2a761edb80 task.stack: ffffa41cc0cac000
[ 12.684087] RIP: 0010:tipc_node_calculate_timer.isra.12+0x45/0x60 [tipc]
[ 12.686486] RSP: 0018:ffff8c2a7fc838a0 EFLAGS: 00010246
[ 12.688451] RAX: 0000000000000000 RBX: ffff8c2a5b382600 RCX: 0000000000000000
[ 12.691197] RDX: 0000000000000000 RSI: ffff8c2a5b382600 RDI: ffff8c2a5b382600
[ 12.693945] RBP: ffff8c2a7fc838b0 R08: 0000000000000001 R09: 0000000000000001
[ 12.696632] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8c2a5d8949d8
[ 12.699491] R13: ffffffff95ede400 R14: 0000000000000000 R15: ffff8c2a5d894800
[ 12.702338] FS: 0000000000000000(0000) GS:ffff8c2a7fc80000(0000) knlGS:0000000000000000
[ 12.705099] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 12.706776] CR2: 0000000001bb9440 CR3: 00000000bd009001 CR4: 00000000003606e0
[ 12.708847] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 12.711016] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 12.712627] Call Trace:
[ 12.713390] <IRQ>
[ 12.714011] tipc_node_check_dest+0x2e8/0x350 [tipc]
[ 12.715286] tipc_disc_rcv+0x14d/0x1d0 [tipc]
[ 12.716370] tipc_rcv+0x8b0/0xd40 [tipc]
[ 12.717396] ? minmax_running_min+0x2f/0x60
[ 12.718248] ? dst_alloc+0x4c/0xa0
[ 12.718964] ? tcp_ack+0xaf1/0x10b0
[ 12.719658] ? tipc_udp_is_known_peer+0xa0/0xa0 [tipc]
[ 12.720634] tipc_udp_recv+0x71/0x1d0 [tipc]
[ 12.721459] ? dst_alloc+0x4c/0xa0
[ 12.722130] udp_queue_rcv_skb+0x264/0x490
[ 12.722924] __udp4_lib_rcv+0x21e/0x990
[ 12.723670] ? ip_route_input_rcu+0x2dd/0xbf0
[ 12.724442] ? tcp_v4_rcv+0x958/0xa40
[ 12.725039] udp_rcv+0x1a/0x20
[ 12.725587] ip_local_deliver_finish+0x97/0x1d0
[ 12.726323] ip_local_deliver+0xaf/0xc0
[ 12.726959] ? ip_route_input_noref+0x19/0x20
[ 12.727689] ip_rcv_finish+0xdd/0x3b0
[ 12.728307] ip_rcv+0x2ac/0x360
[ 12.728839] __netif_receive_skb_core+0x6fb/0xa90
[ 12.729580] ? udp4_gro_receive+0x1a7/0x2c0
[ 12.730274] __netif_receive_skb+0x1d/0x60
[ 12.730953] ? __netif_receive_skb+0x1d/0x60
[ 12.731637] netif_receive_skb_internal+0x37/0xd0
[ 12.732371] napi_gro_receive+0xc7/0xf0
[ 12.732920] receive_buf+0x3c3/0xd40
[ 12.733441] virtnet_poll+0xb1/0x250
[ 12.733944] net_rx_action+0x23e/0x370
[ 12.734476] __do_softirq+0xc5/0x2f8
[ 12.734922] irq_exit+0xfa/0x100
[ 12.735315] do_IRQ+0x4f/0xd0
[ 12.735680] common_interrupt+0xa2/0xa2
[ 12.736126] </IRQ>
[ 12.736416] RIP: 0010:native_safe_halt+0x6/0x10
[ 12.736925] RSP: 0018:ffffa41cc0cafe90 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff4d
[ 12.737756] RAX: 0000000000000000 RBX: ffff8c2a761edb80 RCX: 0000000000000000
[ 12.738504] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[ 12.739258] RBP: ffffa41cc0cafe90 R08: 0000014b5b9795e5 R09: ffffa41cc12c7e88
[ 12.740118] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000002
[ 12.740964] R13: ffff8c2a761edb80 R14: 0000000000000000 R15: 0000000000000000
[ 12.741831] default_idle+0x2a/0x100
[ 12.742323] arch_cpu_idle+0xf/0x20
[ 12.742796] default_idle_call+0x28/0x40
[ 12.743312] do_idle+0x179/0x1f0
[ 12.743761] cpu_startup_entry+0x1d/0x20
[ 12.744291] start_secondary+0x112/0x120
[ 12.744816] secondary_startup_64+0xa5/0xa5
[ 12.745367] Code: b9 f4 01 00 00 48 89 c2 48 c1 ea 02 48 3d d3 07 00
00 48 0f 47 d1 49 8b 0c 24 48 39 d1 76 07 49 89 14 24 48 89 d1 31 d2 48
89 df <48> f7 f1 89 c6 e8 81 6e ff ff 5b 41 5c 5d c3 66 90 66 2e 0f 1f
[ 12.747527] RIP: tipc_node_calculate_timer.isra.12+0x45/0x60 [tipc] RSP: ffff8c2a7fc838a0
[ 12.748555] ---[ end trace 1399ab83390650fd ]---
[ 12.749296] Kernel panic - not syncing: Fatal exception in interrupt
[ 12.750123] Kernel Offset: 0x13200000 from 0xffffffff82000000
(relocation range: 0xffffffff80000000-0xffffffffbfffffff)
[ 12.751215] Rebooting in 60 seconds..
Fixes: c9b64d492b1f ("tipc: add replicast peer discovery")
Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com>
Cc: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit cfac7f836a715b91f08c851df915d401a4d52783 ]
Maciej Żenczykowski reported some panics in tcp_twsk_destructor()
that might be caused by the following bug.
timewait timer is pinned to the cpu, because we want to transition
timwewait refcount from 0 to 4 in one go, once everything has been
initialized.
At the time commit ed2e92394589 ("tcp/dccp: fix timewait races in timer
handling") was merged, TCP was always running from BH habdler.
After commit 5413d1babe8f ("net: do not block BH while processing
socket backlog") we definitely can run tcp_time_wait() from process
context.
We need to block BH in the critical section so that the pinned timer
has still its purpose.
This bug is more likely to happen under stress and when very small RTO
are used in datacenter flows.
Fixes: 5413d1babe8f ("net: do not block BH while processing socket backlog")
Reported-by: Maciej Żenczykowski <maze@google.com>
Acked-by: Maciej Żenczykowski <maze@google.com>
[ Upstream commit 15fe076edea787807a7cdc168df832544b58eba6 ]
syzbot reported crashes [1] and provided a C repro easing bug hunting.
When/if packet_do_bind() calls __unregister_prot_hook() and releases
po->bind_lock, another thread can run packet_notifier() and process an
NETDEV_UP event.
This calls register_prot_hook() and hooks again the socket right before
first thread is able to grab again po->bind_lock.
Fixes this issue by temporarily setting po->num to 0, as suggested by
David Miller.
[1]
dev_remove_pack: ffff8801bf16fa80 not found
kernel BUG at net/core/dev.c:7945! ( BUG_ON(!list_empty(&dev->ptype_all)); )
Modules linked in:
device syz0 entered promiscuous mode
CPU: 0 PID: 3161 Comm: syzkaller404108 Not tainted 4.14.0+ #190
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
task: ffff8801cc57a500 task.stack: ffff8801cc588000
RIP: 0010:netdev_run_todo+0x772/0xae0 net/core/dev.c:7945
RSP: 0018:ffff8801cc58f598 EFLAGS: 00010293
RAX: ffff8801cc57a500 RBX: dffffc0000000000 RCX: ffffffff841f75b2
RDX: 0000000000000000 RSI: 1ffff100398b1ede RDI: ffff8801bf1f8810
RBP: ffff8801cc58f898 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801bf1f8cd8
R13: ffff8801cc58f870 R14: ffff8801bf1f8780 R15: ffff8801cc58f7f0
FS: 0000000001716880(0000) GS:ffff8801db400000(0000) knlGS:0000000000000000
CR2: 0000000020b13000 CR3: 0000000005e25000 CR4: 00000000001406f0
Call Trace:
rtnl_unlock+0xe/0x10 net/core/rtnetlink.c:106
tun_detach drivers/net/tun.c:670 [inline]
tun_chr_close+0x49/0x60 drivers/net/tun.c:2845
__fput+0x333/0x7f0 fs/file_table.c:210
____fput+0x15/0x20 fs/file_table.c:244
task_work_run+0x199/0x270 kernel/task_work.c:113
exit_task_work include/linux/task_work.h:22 [inline]
do_exit+0x9bb/0x1ae0 kernel/exit.c:865
do_group_exit+0x149/0x400 kernel/exit.c:968
SYSC_exit_group kernel/exit.c:979 [inline]
SyS_exit_group+0x1d/0x20 kernel/exit.c:977
RIP: 0033:0x44ad19
Fixes: 30f7ea1c2b5f ("packet: race condition in packet_bind")
Cc: Francesco Ruggeri <fruggeri@aristanetworks.com>
syzkaller found a race condition fanout_demux_rollover() while removing
a packet socket from a fanout group.
po->rollover is read and operated on during packet_rcv_fanout(), via
fanout_demux_rollover(), but the pointer is currently cleared before the
synchronization in packet_release(). It is safer to delay the cleanup
until after synchronize_net() has been called, ensuring all calls to
packet_rcv_fanout() for this socket have finished.
To further simplify synchronization around the rollover structure, set
po->rollover in fanout_add() only if there are no errors. This removes
the need for rcu in the struct and in the call to
packet_getsockopt(..., PACKET_ROLLOVER_STATS, ...).
Crashing stack trace:
fanout_demux_rollover+0xb6/0x4d0 net/packet/af_packet.c:1392
packet_rcv_fanout+0x649/0x7c8 net/packet/af_packet.c:1487
dev_queue_xmit_nit+0x835/0xc10 net/core/dev.c:1953
xmit_one net/core/dev.c:2975 [inline]
dev_hard_start_xmit+0x16b/0xac0 net/core/dev.c:2995
__dev_queue_xmit+0x17a4/0x2050 net/core/dev.c:3476
dev_queue_xmit+0x17/0x20 net/core/dev.c:3509
neigh_connected_output+0x489/0x720 net/core/neighbour.c:1379
neigh_output include/net/neighbour.h:482 [inline]
ip6_finish_output2+0xad1/0x22a0 net/ipv6/ip6_output.c:120
ip6_finish_output+0x2f9/0x920 net/ipv6/ip6_output.c:146
NF_HOOK_COND include/linux/netfilter.h:239 [inline]
ip6_output+0x1f4/0x850 net/ipv6/ip6_output.c:163
dst_output include/net/dst.h:459 [inline]
NF_HOOK.constprop.35+0xff/0x630 include/linux/netfilter.h:250
mld_sendpack+0x6a8/0xcc0 net/ipv6/mcast.c:1660
mld_send_initial_cr.part.24+0x103/0x150 net/ipv6/mcast.c:2072
mld_send_initial_cr net/ipv6/mcast.c:2056 [inline]
ipv6_mc_dad_complete+0x99/0x130 net/ipv6/mcast.c:2079
addrconf_dad_completed+0x595/0x970 net/ipv6/addrconf.c:4039
addrconf_dad_work+0xac9/0x1160 net/ipv6/addrconf.c:3971
process_one_work+0xbf0/0x1bc0 kernel/workqueue.c:2113
worker_thread+0x223/0x1990 kernel/workqueue.c:2247
kthread+0x35e/0x430 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:432
Fixes: 0648ab70afe6 ("packet: rollover prepare: per-socket state")
Fixes: 509c7a1ecc860 ("packet: avoid panic in packet_getsockopt()")
Signed-off-by: Mike Maloney <maloney@google.com>
[ Upstream commit f859b4af1c52493ec21173ccc73d0b60029b5b88 ]
After parsing the sit netlink change info, we forget to update frag_off in
ipip6_tunnel_update(). Fix it by assigning frag_off with new value.
Reported-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit f3069c6d33f6ae63a1668737bc78aaaa51bff7ca ]
This is a fix for syzkaller719569, where memory registration was
attempted without any underlying transport being loaded.
Analysis of the case reveals that it is the setsockopt() RDS_GET_MR
(2) and RDS_GET_MR_FOR_DEST (7) that are vulnerable.
Here is an example stack trace when the bug is hit:
BUG: unable to handle kernel NULL pointer dereference at 00000000000000c0
IP: __rds_rdma_map+0x36/0x440 [rds]
PGD 2f93d03067 P4D 2f93d03067 PUD 2f93d02067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: bridge stp llc tun rpcsec_gss_krb5 nfsv4
dns_resolver nfs fscache rds binfmt_misc sb_edac intel_powerclamp
coretemp kvm_intel kvm irqbypass crct10dif_pclmul c rc32_pclmul
ghash_clmulni_intel pcbc aesni_intel crypto_simd glue_helper cryptd
iTCO_wdt mei_me sg iTCO_vendor_support ipmi_si mei ipmi_devintf nfsd
shpchp pcspkr i2c_i801 ioatd ma ipmi_msghandler wmi lpc_ich mfd_core
auth_rpcgss nfs_acl lockd grace sunrpc ip_tables ext4 mbcache jbd2
mgag200 i2c_algo_bit drm_kms_helper ixgbe syscopyarea ahci sysfillrect
sysimgblt libahci mdio fb_sys_fops ttm ptp libata sd_mod mlx4_core drm
crc32c_intel pps_core megaraid_sas i2c_core dca dm_mirror
dm_region_hash dm_log dm_mod
CPU: 48 PID: 45787 Comm: repro_set2 Not tainted 4.14.2-3.el7uek.x86_64 #2
Hardware name: Oracle Corporation ORACLE SERVER X5-2L/ASM,MOBO TRAY,2U, BIOS 31110000 03/03/2017
task: ffff882f9190db00 task.stack: ffffc9002b994000
RIP: 0010:__rds_rdma_map+0x36/0x440 [rds]
RSP: 0018:ffffc9002b997df0 EFLAGS: 00010202
RAX: 0000000000000000 RBX: ffff882fa2182580 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffffc9002b997e40 RDI: ffff882fa2182580
RBP: ffffc9002b997e30 R08: 0000000000000000 R09: 0000000000000002
R10: ffff885fb29e3838 R11: 0000000000000000 R12: ffff882fa2182580
R13: ffff882fa2182580 R14: 0000000000000002 R15: 0000000020000ffc
FS: 00007fbffa20b700(0000) GS:ffff882fbfb80000(0000) knlGS:0000000000000000
CR2: 00000000000000c0 CR3: 0000002f98a66006 CR4: 00000000001606e0
Call Trace:
rds_get_mr+0x56/0x80 [rds]
rds_setsockopt+0x172/0x340 [rds]
? __fget_light+0x25/0x60
? __fdget+0x13/0x20
SyS_setsockopt+0x80/0xe0
do_syscall_64+0x67/0x1b0
entry_SYSCALL64_slow_path+0x25/0x25
RIP: 0033:0x7fbff9b117f9
RSP: 002b:00007fbffa20aed8 EFLAGS: 00000293 ORIG_RAX: 0000000000000036
RAX: ffffffffffffffda RBX: 00000000000c84a4 RCX: 00007fbff9b117f9
RDX: 0000000000000002 RSI: 0000400000000114 RDI: 000000000000109b
RBP: 00007fbffa20af10 R08: 0000000000000020 R09: 00007fbff9dd7860
R10: 0000000020000ffc R11: 0000000000000293 R12: 0000000000000000
R13: 00007fbffa20b9c0 R14: 00007fbffa20b700 R15: 0000000000000021
Code: 41 56 41 55 49 89 fd 41 54 53 48 83 ec 18 8b 87 f0 02 00 00 48
89 55 d0 48 89 4d c8 85 c0 0f 84 2d 03 00 00 48 8b 87 00 03 00 00 <48>
83 b8 c0 00 00 00 00 0f 84 25 03 00 0 0 48 8b 06 48 8b 56 08
The fix is to check the existence of an underlying transport in
__rds_rdma_map().
Signed-off-by: Håkon Bugge <haakon.bugge@oracle.com>
[ Upstream commit a7d5f107b4978e08eeab599ee7449af34d034053 ]
When the function tipc_accept_from_sock() fails to create an instance of
struct tipc_subscriber it omits to free the already created instance of
struct tipc_conn instance before it returns.
We fix that with this commit.
Reported-by: David S. Miller <davem@davemloft.net>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit 0e74aa1d79a5bbc663e03a2804399cae418a0321 ]
The syzbot found an ancient bug in the IPsec code. When we cloned
a socket policy (for example, for a child TCP socket derived from a
listening socket), we did not copy the family field. This results
in a live policy with a zero family field. This triggers a BUG_ON
check in the af_key code when the cloned policy is retrieved.
This patch fixes it by copying the family field over.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit cea0cc80a6777beb6eb643d4ad53690e1ad1d4ff ]
Commit dfcb9f4f99f1 ("sctp: deny peeloff operation on asocs with threads
sleeping on it") fixed the race between peeloff and wait sndbuf by
checking waitqueue_active(&asoc->wait) in sctp_do_peeloff().
But it actually doesn't work, as even if waitqueue_active returns false
the waiting sndbuf thread may still not yet hold sk lock. After asoc is
peeled off, sk is not asoc->base.sk any more, then to hold the old sk
lock couldn't make assoc safe to access.
This patch is to fix this by changing to hold the new sk lock if sk is
not asoc->base.sk, meanwhile, also set the sk in sctp_sendmsg with the
new sk.
With this fix, there is no more race between peeloff and waitbuf, the
check 'waitqueue_active' in sctp_do_peeloff can be removed.
Thanks Marcelo and Neil for making this clear.
v1->v2:
fix it by changing to lock the new sock instead of adding a flag in asoc.
Suggested-by: Neil Horman <nhorman@tuxdriver.com>
