path: root/net
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-09net: adding memory barrier to the poll and receive callbacksJiri Olsa
Adding memory barrier after the poll_wait function, paired with receive callbacks. Adding fuctions sock_poll_wait and sk_has_sleeper to wrap the memory barrier. Without the memory barrier, following race can happen. The race fires, when following code paths meet, and the tp->rcv_nxt and __add_wait_queue updates stay in CPU caches. CPU1 CPU2 sys_select receive packet ... ... __add_wait_queue update tp->rcv_nxt ... ... tp->rcv_nxt check sock_def_readable ... { schedule ... if (sk->sk_sleep && waitqueue_active(sk->sk_sleep)) wake_up_interruptible(sk->sk_sleep) ... } If there was no cache the code would work ok, since the wait_queue and rcv_nxt are opposit to each other. Meaning that once tp->rcv_nxt is updated by CPU2, the CPU1 either already passed the tp->rcv_nxt check and sleeps, or will get the new value for tp->rcv_nxt and will return with new data mask. In both cases the process (CPU1) is being added to the wait queue, so the waitqueue_active (CPU2) call cannot miss and will wake up CPU1. The bad case is when the __add_wait_queue changes done by CPU1 stay in its cache, and so does the tp->rcv_nxt update on CPU2 side. The CPU1 will then endup calling schedule and sleep forever if there are no more data on the socket. Calls to poll_wait in following modules were ommited: net/bluetooth/af_bluetooth.c net/irda/af_irda.c net/irda/irnet/irnet_ppp.c net/mac80211/rc80211_pid_debugfs.c net/phonet/socket.c net/rds/af_rds.c net/rfkill/core.c net/sunrpc/cache.c net/sunrpc/rpc_pipe.c net/tipc/socket.c Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08netpoll: Fix carrier detection for drivers that are using phylibAnton Vorontsov
Using early netconsole and gianfar driver this error pops up: netconsole: timeout waiting for carrier It appears that net/core/netpoll.c:netpoll_setup() is using cond_resched() in a loop waiting for a carrier. The thing is that cond_resched() is a no-op when system_state != SYSTEM_RUNNING, and so drivers/net/phy/phy.c's state_queue is never scheduled, therefore link detection doesn't work. I belive that the main problem is in cond_resched()[1], but despite how the cond_resched() story ends, it might be a good idea to call msleep(1) instead of cond_resched(), as suggested by Andrew Morton. [1] http://lkml.org/lkml/2009/7/7/463 Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08Merge branch 'master' of ↵David S. Miller
2009-07-08ipv4: Fix fib_trie rebalancing, part 4 (root thresholds)Jarek Poplawski
Pawel Staszewski wrote: <blockquote> Some time ago i report this: http://bugzilla.kernel.org/show_bug.cgi?id=6648 and now with 2.6.29 / 2.6.29.1 / 2.6.29.3 and 2.6.30 it back dmesg output: oprofile: using NMI interrupt. Fix inflate_threshold_root. Now=15 size=11 bits ... Fix inflate_threshold_root. Now=15 size=11 bits cat /proc/net/fib_triestat Basic info: size of leaf: 40 bytes, size of tnode: 56 bytes. Main: Aver depth: 2.28 Max depth: 6 Leaves: 276539 Prefixes: 289922 Internal nodes: 66762 1: 35046 2: 13824 3: 9508 4: 4897 5: 2331 6: 1149 7: 5 9: 1 18: 1 Pointers: 691228 Null ptrs: 347928 Total size: 35709 kB </blockquote> It seems, the current threshold for root resizing is too aggressive, and it causes misleading warnings during big updates, but it might be also responsible for memory problems, especially with non-preempt configs, when RCU freeing is delayed long after call_rcu. It should be also mentioned that because of non-atomic changes during resizing/rebalancing the current lookup algorithm can miss valid leaves so it's additional argument to shorten these activities even at a cost of a minimally longer searching. This patch restores values before the patch "[IPV4]: fib_trie root node settings", commit: 965ffea43d4ebe8cd7b9fee78d651268dd7d23c5 from v2.6.22. Pawel's report: <blockquote> I dont see any big change of (cpu load or faster/slower routing/propagating routes from bgpd or something else) - in avg there is from 2% to 3% more of CPU load i dont know why but it is - i change from "preempt" to "no preempt" 3 times and check this my "mpstat -P ALL 1 30" always avg cpu load was from 2 to 3% more compared to "no preempt" [...] cat /proc/net/fib_triestat Basic info: size of leaf: 20 bytes, size of tnode: 36 bytes. Main: Aver depth: 2.44 Max depth: 6 Leaves: 277814 Prefixes: 291306 Internal nodes: 66420 1: 32737 2: 14850 3: 10332 4: 4871 5: 2313 6: 942 7: 371 8: 3 17: 1 Pointers: 599098 Null ptrs: 254865 Total size: 18067 kB </blockquote> According to this and other similar reports average depth is slightly increased (~0.2), and root nodes are shorter (log 17 vs. 18), but there is no visible performance decrease. So, until memory handling is improved or added parameters for changing this individually, this patch resets to safer defaults. Reported-by: Pawel Staszewski <pstaszewski@itcare.pl> Reported-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Pawel Staszewski <pstaszewski@itcare.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-07mac80211: minstrel: avoid accessing negative indices in rix_to_ndx()Luciano Coelho
If rix is not found in mi->r[], i will become -1 after the loop. This value is eventually used to access arrays, so we were accessing arrays with a negative index, which is obviously not what we want to do. This patch fixes this potential problem. Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com> Acked-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-07cfg80211: fix refcount leakJohannes Berg
The code in cfg80211's cfg80211_bss_update erroneously grabs a reference to the BSS, which means that it will never be freed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org [2.6.29, 2.6.30] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-07mac80211: fix allocation in mesh_queue_preqAndrey Yurovsky
We allocate a PREQ queue node in mesh_queue_preq, however the allocation may cause us to sleep. Use GFP_ATOMIC to prevent this. [ 1869.126498] BUG: scheduling while atomic: ping/1859/0x10000100 [ 1869.127164] Modules linked in: ath5k mac80211 ath [ 1869.128310] Pid: 1859, comm: ping Not tainted 2.6.30-wl #1 [ 1869.128754] Call Trace: [ 1869.129293] [<c1023a2b>] __schedule_bug+0x48/0x4d [ 1869.129866] [<c13b5533>] __schedule+0x77/0x67a [ 1869.130544] [<c1026f2e>] ? release_console_sem+0x17d/0x185 [ 1869.131568] [<c807cf47>] ? mesh_queue_preq+0x2b/0x165 [mac80211] [ 1869.132318] [<c13b5b3e>] schedule+0x8/0x1f [ 1869.132807] [<c1023c12>] __cond_resched+0x16/0x2f [ 1869.133478] [<c13b5bf0>] _cond_resched+0x27/0x32 [ 1869.134191] [<c108a370>] kmem_cache_alloc+0x1c/0xcf [ 1869.134714] [<c10273ae>] ? printk+0x15/0x17 [ 1869.135670] [<c807cf47>] mesh_queue_preq+0x2b/0x165 [mac80211] [ 1869.136731] [<c807d1f8>] mesh_nexthop_lookup+0xee/0x12d [mac80211] [ 1869.138130] [<c807417e>] ieee80211_xmit+0xe6/0x2b2 [mac80211] [ 1869.138935] [<c80be46d>] ? ath5k_hw_setup_rx_desc+0x0/0x66 [ath5k] [ 1869.139831] [<c80c97bc>] ? ath5k_tasklet_rx+0xba/0x506 [ath5k] [ 1869.140863] [<c8075191>] ieee80211_subif_start_xmit+0x6c9/0x6e4 [mac80211] [ 1869.141665] [<c105cf1c>] ? handle_level_irq+0x78/0x9d [ 1869.142390] [<c12e3f93>] dev_hard_start_xmit+0x168/0x1c7 [ 1869.143092] [<c12f1f17>] __qdisc_run+0xe1/0x1b7 [ 1869.143612] [<c12e25ff>] qdisc_run+0x18/0x1a [ 1869.144248] [<c12e62f4>] dev_queue_xmit+0x16a/0x25a [ 1869.144785] [<c13b6dcc>] ? _read_unlock_bh+0xe/0x10 [ 1869.145465] [<c12eacdb>] neigh_resolve_output+0x19c/0x1c7 [ 1869.146182] [<c130e2da>] ? ip_finish_output+0x0/0x51 [ 1869.146697] [<c130e2a0>] ip_finish_output2+0x182/0x1bc [ 1869.147358] [<c130e327>] ip_finish_output+0x4d/0x51 [ 1869.147863] [<c130e9d5>] ip_output+0x80/0x85 [ 1869.148515] [<c130cc49>] dst_output+0x9/0xb [ 1869.149141] [<c130dec6>] ip_local_out+0x17/0x1a [ 1869.149632] [<c130e0bc>] ip_push_pending_frames+0x1f3/0x255 [ 1869.150343] [<c13247ff>] raw_sendmsg+0x5e6/0x667 [ 1869.150883] [<c1033c55>] ? insert_work+0x6a/0x73 [ 1869.151834] [<c8071e00>] ? ieee80211_invoke_rx_handlers+0x17da/0x1ae8 [mac80211] [ 1869.152630] [<c132bd68>] inet_sendmsg+0x3b/0x48 [ 1869.153232] [<c12d7deb>] __sock_sendmsg+0x45/0x4e [ 1869.153740] [<c12d8537>] sock_sendmsg+0xb8/0xce [ 1869.154519] [<c80be46d>] ? ath5k_hw_setup_rx_desc+0x0/0x66 [ath5k] [ 1869.155289] [<c1036b25>] ? autoremove_wake_function+0x0/0x30 [ 1869.155859] [<c115992b>] ? __copy_from_user_ll+0x11/0xce [ 1869.156573] [<c1159d99>] ? copy_from_user+0x31/0x54 [ 1869.157235] [<c12df646>] ? verify_iovec+0x40/0x6e [ 1869.157778] [<c12d869a>] sys_sendmsg+0x14d/0x1a5 [ 1869.158714] [<c8072c40>] ? __ieee80211_rx+0x49e/0x4ee [mac80211] [ 1869.159641] [<c80c83fe>] ? ath5k_rxbuf_setup+0x6d/0x8d [ath5k] [ 1869.160543] [<c80be46d>] ? ath5k_hw_setup_rx_desc+0x0/0x66 [ath5k] [ 1869.161434] [<c80beba4>] ? ath5k_hw_get_rxdp+0xe/0x10 [ath5k] [ 1869.162319] [<c80c97bc>] ? ath5k_tasklet_rx+0xba/0x506 [ath5k] [ 1869.163063] [<c1005627>] ? enable_8259A_irq+0x40/0x43 [ 1869.163594] [<c101edb8>] ? __dequeue_entity+0x23/0x27 [ 1869.164793] [<c100187a>] ? __switch_to+0x2b/0x105 [ 1869.165442] [<c1021d5f>] ? finish_task_switch+0x5b/0x74 [ 1869.166129] [<c12d963a>] sys_socketcall+0x14b/0x17b [ 1869.166612] [<c1002b95>] syscall_call+0x7/0xb Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-07Wireless: nl80211, fix lock imbalanceJiri Slaby
Don't forget to unlock cfg80211_mutex in one fail path of nl80211_set_wiphy. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-06sctp: fix warning at inet_sock_destruct() while release sctp socketWei Yongjun
Commit 'net: Move rx skb_orphan call to where needed' broken sctp protocol with warning at inet_sock_destruct(). Actually, sctp can do this right with sctp_sock_rfree_frag() and sctp_skb_set_owner_r_frag() pair. sctp_sock_rfree_frag(skb); sctp_skb_set_owner_r_frag(skb, newsk); This patch not revert the commit d55d87fdff8252d0e2f7c28c2d443aee17e9d70f, instead remove the sctp_sock_rfree_frag() function. ------------[ cut here ]------------ WARNING: at net/ipv4/af_inet.c:151 inet_sock_destruct+0xe0/0x142() Modules linked in: sctp ipv6 dm_mirror dm_region_hash dm_log dm_multipath scsi_mod ext3 jbd uhci_hcd ohci_hcd ehci_hcd [last unloaded: scsi_wait_scan] Pid: 1808, comm: sctp_test Not tainted 2.6.31-rc2 #40 Call Trace: [<c042dd06>] warn_slowpath_common+0x6a/0x81 [<c064a39a>] ? inet_sock_destruct+0xe0/0x142 [<c042dd2f>] warn_slowpath_null+0x12/0x15 [<c064a39a>] inet_sock_destruct+0xe0/0x142 [<c05fde44>] __sk_free+0x19/0xcc [<c05fdf50>] sk_free+0x18/0x1a [<ca0d14ad>] sctp_close+0x192/0x1a1 [sctp] [<c0649f7f>] inet_release+0x47/0x4d [<c05fba4d>] sock_release+0x19/0x5e [<c05fbab3>] sock_close+0x21/0x25 [<c049c31b>] __fput+0xde/0x189 [<c049c3de>] fput+0x18/0x1a [<c049988f>] filp_close+0x56/0x60 [<c042f422>] put_files_struct+0x5d/0xa1 [<c042f49f>] exit_files+0x39/0x3d [<c043086a>] do_exit+0x1a5/0x5dd [<c04a86c2>] ? d_kill+0x35/0x3b [<c0438fa4>] ? dequeue_signal+0xa6/0x115 [<c0430d05>] do_group_exit+0x63/0x8a [<c0439504>] get_signal_to_deliver+0x2e1/0x2f9 [<c0401d9e>] do_notify_resume+0x7c/0x6b5 [<c043f601>] ? autoremove_wake_function+0x0/0x34 [<c04a864e>] ? __d_free+0x3d/0x40 [<c04a867b>] ? d_free+0x2a/0x3c [<c049ba7e>] ? vfs_write+0x103/0x117 [<c05fc8fa>] ? sys_socketcall+0x178/0x182 [<c0402a56>] work_notifysig+0x13/0x19 ---[ end trace 9db92c463e789fba ]--- Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05dsa: fix 88e6xxx statistics counter snapshottingStephane Contri
The bit that tells us whether a statistics counter snapshot operation has completed is located in the GLOBAL register block, not in the GLOBAL2 register block, so fix up mv88e6xxx_stats_wait() to poll the right register address. Signed-off-by: Stephane Contri <Stephane.Contri@grassvalley.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-03IPv6: preferred lifetime of address not getting updatedBrian Haley
There's a bug in addrconf_prefix_rcv() where it won't update the preferred lifetime of an IPv6 address if the current valid lifetime of the address is less than 2 hours (the minimum value in the RA). For example, If I send a router advertisement with a prefix that has valid lifetime = preferred lifetime = 2 hours we'll build this address: 3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qlen 1000 inet6 2001:1890:1109:a20:217:8ff:fe7d:4718/64 scope global dynamic valid_lft 7175sec preferred_lft 7175sec If I then send the same prefix with valid lifetime = preferred lifetime = 0 it will be ignored since the minimum valid lifetime is 2 hours: 3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qlen 1000 inet6 2001:1890:1109:a20:217:8ff:fe7d:4718/64 scope global dynamic valid_lft 7161sec preferred_lft 7161sec But according to RFC 4862 we should always reset the preferred lifetime even if the valid lifetime is invalid, which would cause the address to immediately get deprecated. So with this patch we'd see this: 5: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qlen 1000 inet6 2001:1890:1109:a20:21f:29ff:fe5a:ef04/64 scope global deprecated dynamic valid_lft 7163sec preferred_lft 0sec The comment winds-up being 5x the size of the code to fix the problem. Update the preferred lifetime of IPv6 addresses derived from a prefix info option in a router advertisement even if the valid lifetime in the option is invalid, as specified in RFC 4862 Section 5.5.3e. Fixes an issue where an address will not immediately become deprecated. Reported by Jens Rosenboom. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-03xfrm6: fix the proto and ports decode of sctp protocolWei Yongjun
The SCTP pushed the skb above the sctp chunk header, so the check of pskb_may_pull(skb, nh + offset + 1 - skb->data) in _decode_session6() will never return 0 and the ports decode of sctp will always fail. (nh + offset + 1 - skb->data < 0) Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-03xfrm4: fix the ports decode of sctp protocolWei Yongjun
The SCTP pushed the skb data above the sctp chunk header, so the check of pskb_may_pull(skb, xprth + 4 - skb->data) in _decode_session4() will never return 0 because xprth + 4 - skb->data < 0, the ports decode of sctp will always fail. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-02net/9p: Fix crash due to bad mount parameters.Abhishek Kulkarni
It is not safe to use match_int without checking the token type returned by match_token (especially when the token type returned is Opt_err and args is empty). Fix it. Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30Revert "ipv4: arp announce, arp_proxy and windows ip conflict verification"Eric W. Biederman
This reverts commit 73ce7b01b4496a5fbf9caf63033c874be692333f. After discovering that we don't listen to gratuitious arps in 2.6.30 I tracked the failure down to this commit. The patch makes absolutely no sense. RFC2131 RFC3927 and RFC5227. are all in agreement that an arp request with sip == 0 should be used for the probe (to prevent learning) and an arp request with sip == tip should be used for the gratitous announcement that people can learn from. It appears the author of the broken patch got those two cases confused and modified the code to drop all gratuitous arp traffic. Ouch! Cc: stable@kernel.org Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30ipv4: Fix fib_trie rebalancing, part 3Jarek Poplawski
Alas current delaying of freeing old tnodes by RCU in trie_rebalance is still not enough because we can free a top tnode before updating a t->trie pointer. Reported-by: Pawel Staszewski <pstaszewski@itcare.pl> Tested-by: Pawel Staszewski <pstaszewski@itcare.pl> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-29sctp: xmit sctp packet always return no route errorWei Yongjun
Commit 'net: skb->dst accessors'(adf30907d63893e4208dfe3f5c88ae12bc2f25d5) broken the sctp protocol stack, the sctp packet can never be sent out after Eric Dumazet's patch, which have typo in the sctp code. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Vlad Yasevich <vladisalv.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-29xfrm: use xfrm_addr_cmp() instead of compare addresses directlyWei Yongjun
Clean up to use xfrm_addr_cmp() instead of compare addresses directly. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-29tcp: Do not tack on TSO data to non-TSO packetHerbert Xu
If a socket starts out on a non-TSO route, and then switches to a TSO route, then we will tack on data to the tail of the tx queue even if it started out life as non-TSO. This is suboptimal because all of it will then be copied and checksummed unnecessarily. This patch fixes this by ensuring that skb->ip_summed is set to CHECKSUM_PARTIAL before appending extra data beyond the MSS. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-29tcp: Stop non-TSO packets morphing into TSOHerbert Xu
If a socket starts out on a non-TSO route, and then switches to a TSO route, then the tail on the tx queue can morph into a TSO packet, causing mischief because the rest of the stack does not expect a partially linear TSO packet. This patch fixes this by ensuring that skb->ip_summed is set to CHECKSUM_PARTIAL before declaring a packet as TSO. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-29Merge branch 'for-linus' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/lowpan/lowpan
2009-06-29Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2009-06-29nl802154: add module license and descriptionDmitry Eremin-Solenikov
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-06-29nl802154: fix Oops in ieee802154_nl_get_devDmitry Eremin-Solenikov
ieee802154_nl_get_dev() lacks check for the existance of the device that was returned by dev_get_XXX, thus resulting in Oops for non-existing devices. Fix it. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-06-29netfilter: xtables: conntrack match revision 2Jan Engelhardt
As reported by Philip, the UNTRACKED state bit does not fit within the 8-bit state_mask member. Enlarge state_mask and give status_mask a few more bits too. Reported-by: Philip Craig <philipc@snapgear.com> References: http://markmail.org/thread/b7eg6aovfh4agyz7 Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-29netfilter: tcp conntrack: fix unacknowledged data detection with NATPatrick McHardy
When NAT helpers change the TCP packet size, the highest seen sequence number needs to be corrected. This is currently only done upwards, when the packet size is reduced the sequence number is unchanged. This causes TCP conntrack to falsely detect unacknowledged data and decrease the timeout. Fix by updating the highest seen sequence number in both directions after packet mangling. Tested-by: Krzysztof Piotr Oledzki <ole@ans.pl> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-26gro: Flush GRO packets in napi_disable_pending pathHerbert Xu
When NAPI is disabled while we're in net_rx_action, we end up calling __napi_complete without flushing GRO packets. This is a bug as it would cause the GRO packets to linger, of course it also literally BUGs to catch error like this :) This patch changes it to napi_complete, with the obligatory IRQ reenabling. This should be safe because we've only just disabled IRQs and it does not materially affect the test conditions in between. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26inet: Call skb_orphan before tproxy activatesHerbert Xu
As transparent proxying looks up the socket early and assigns it to the skb for later processing, we must drop any existing socket ownership prior to that in order to distinguish between the case where tproxy is active and where it is not. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26mac80211: Use rcu_barrier() on unload.Jesper Dangaard Brouer
The mac80211 module uses rcu_call() thus it should use rcu_barrier() on module unload. The rcu_barrier() is placed in mech.c ieee80211_stop_mesh() which is invoked from ieee80211_stop() in case vif.type == NL80211_IFTYPE_MESH_POINT. Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26sunrpc: Use rcu_barrier() on unload.Jesper Dangaard Brouer
The sunrpc module uses rcu_call() thus it should use rcu_barrier() on module unload. Have not verified that the possibility for new call_rcu() callbacks has been disabled. As a hint for checking, the functions calling call_rcu() (unx_destroy_cred and generic_destroy_cred) are registered as crdestroy function pointer in struct rpc_credops. Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26bridge: Use rcu_barrier() instead of syncronize_net() on unload.Jesper Dangaard Brouer
When unloading modules that uses call_rcu() callbacks, then we must use rcu_barrier(). This module uses syncronize_net() which is not enough to be sure that all callback has been completed. Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26ipv6: Use rcu_barrier() on module unload.Jesper Dangaard Brouer
The ipv6 module uses rcu_call() thus it should use rcu_barrier() on module unload. Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26decnet: Use rcu_barrier() on module unload.Jesper Dangaard Brouer
The decnet module unloading as been disabled with a '#if 0' statement, because it have had issues. We add a rcu_barrier() anyhow for correctness. The maintainer (Chrissie Caulfield) will look into the unload issue when time permits. Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Chrissie Caulfield <christine.caulfield@googlemail.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25ipv6: avoid wraparound for expired preferred lifetimeJens Rosenboom
Avoid showing wrong high values when the preferred lifetime of an address is expired. Signed-off-by: Jens Rosenboom <me@jayr.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25tcp: missing check ACK flag of received segment in FIN-WAIT-2 stateWei Yongjun
RFC0793 defined that in FIN-WAIT-2 state if the ACK bit is off drop the segment and return[Page 72]. But this check is missing in function tcp_timewait_state_process(). This cause the segment with FIN flag but no ACK has two diffent action: Case 1: Node A Node B <------------- FIN,ACK (enter FIN-WAIT-1) ACK -------------> (enter FIN-WAIT-2) FIN -------------> discard (move sk to tw list) Case 2: Node A Node B <------------- FIN,ACK (enter FIN-WAIT-1) ACK -------------> (enter FIN-WAIT-2) (move sk to tw list) FIN -------------> <------------- ACK This patch fixed the problem. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25nf_conntrack: Use rcu_barrier()Jesper Dangaard Brouer
RCU barriers, rcu_barrier(), is inserted two places. In nf_conntrack_expect.c nf_conntrack_expect_fini() before the kmem_cache_destroy(). Firstly to make sure the callback to the nf_ct_expect_free_rcu() code is still around. Secondly because I'm unsure about the consequence of having in flight nf_ct_expect_free_rcu/kmem_cache_free() calls while doing a kmem_cache_destroy() slab destroy. And in nf_conntrack_extend.c nf_ct_extend_unregister(), inorder to wait for completion of callbacks to __nf_ct_ext_free_rcu(), which is invoked by __nf_ct_ext_add(). It might be more efficient to call rcu_barrier() in nf_conntrack_core.c nf_conntrack_cleanup_net(), but thats make it more difficult to read the code (as the callback code in located in nf_conntrack_extend.c). Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-25Phonet: generate Netlink RTM_DELADDR when destroying a deviceRémi Denis-Courmont
Netlink address deletion events were not sent when a network device vanished neither when Phonet was unloaded. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25Phonet: publicize the Netlink notification functionRémi Denis-Courmont
2009-06-24ipsec: Fix name of CAST algorithmHerbert Xu
Our CAST algorithm is called cast5, not cast128. Clearly nobody has ever used it :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: bnx2: Fix the behavior of ethtool when ONBOOT=no qla3xxx: Don't sleep while holding lock. qla3xxx: Give the PHY time to come out of reset. ipv4 routing: Ensure that route cache entries are usable and reclaimable with caching is off net: Move rx skb_orphan call to where needed ipv6: Use correct data types for ICMPv6 type and code net: let KS8842 driver depend on HAS_IOMEM can: let SJA1000 driver depend on HAS_IOMEM netxen: fix firmware init handshake netxen: fix build with without CONFIG_PM netfilter: xt_rateest: fix comparison with self netfilter: xt_quota: fix incomplete initialization netfilter: nf_log: fix direct userspace memory access in proc handler netfilter: fix some sparse endianess warnings netfilter: nf_conntrack: fix conntrack lookup race netfilter: nf_conntrack: fix confirmation race condition netfilter: nf_conntrack: death_by_timeout() fix
2009-06-23ipv4 routing: Ensure that route cache entries are usable and reclaimable ↵Neil Horman
with caching is off When route caching is disabled (rt_caching returns false), We still use route cache entries that are created and passed into rt_intern_hash once. These routes need to be made usable for the one call path that holds a reference to them, and they need to be reclaimed when they're finished with their use. To be made usable, they need to be associated with a neighbor table entry (which they currently are not), otherwise iproute_finish2 just discards the packet, since we don't know which L2 peer to send the packet to. To do this binding, we need to follow the path a bit higher up in rt_intern_hash, which calls arp_bind_neighbour, but not assign the route entry to the hash table. Currently, if caching is off, we simply assign the route to the rp pointer and are reutrn success. This patch associates us with a neighbor entry first. Secondly, we need to make sure that any single use routes like this are known to the garbage collector when caching is off. If caching is off, and we try to hash in a route, it will leak when its refcount reaches zero. To avoid this, this patch calls rt_free on the route cache entry passed into rt_intern_hash. This places us on the gc list for the route cache garbage collector, so that when its refcount reaches zero, it will be reclaimed (Thanks to Alexey for this suggestion). I've tested this on a local system here, and with these patches in place, I'm able to maintain routed connectivity to remote systems, even if I set /proc/sys/net/ipv4/rt_cache_rebuild_count to -1, which forces rt_caching to return false. Signed-off-by: Neil Horman <nhorman@redhat.com> Reported-by: Jarek Poplawski <jarkao2@gmail.com> Reported-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23net: Move rx skb_orphan call to where neededHerbert Xu
In order to get the tun driver to account packets, we need to be able to receive packets with destructors set. To be on the safe side, I added an skb_orphan call for all protocols by default since some of them (IP in particular) cannot handle receiving packets destructors properly. Now it seems that at least one protocol (CAN) expects to be able to pass skb->sk through the rx path without getting clobbered. So this patch attempts to fix this properly by moving the skb_orphan call to where it's actually needed. In particular, I've added it to skb_set_owner_[rw] which is what most users of skb->destructor call. This is actually an improvement for tun too since it means that we only give back the amount charged to the socket when the skb is passed to another socket that will also be charged accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Oliver Hartkopp <olver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-22Merge branch 'for-2.6.31' of git://fieldses.org/git/linux-nfsdLinus Torvalds
* 'for-2.6.31' of git://fieldses.org/git/linux-nfsd: (60 commits) SUNRPC: Fix the TCP server's send buffer accounting nfsd41: Backchannel: minorversion support for the back channel nfsd41: Backchannel: cleanup nfs4.0 callback encode routines nfsd41: Remove ip address collision detection case nfsd: optimise the starting of zero threads when none are running. nfsd: don't take nfsd_mutex twice when setting number of threads. nfsd41: sanity check client drc maxreqs nfsd41: move channel attributes from nfsd4_session to a nfsd4_channel_attr struct NFS: kill off complicated macro 'PROC' sunrpc: potential memory leak in function rdma_read_xdr nfsd: minor nfsd_vfs_write cleanup nfsd: Pull write-gathering code out of nfsd_vfs_write nfsd: track last inode only in use_wgather case sunrpc: align cache_clean work's timer nfsd: Use write gathering only with NFSv2 NFSv4: kill off complicated macro 'PROC' NFSv4: do exact check about attribute specified knfsd: remove unreported filehandle stats counters knfsd: fix reply cache memory corruption knfsd: reply cache cleanups ...
2009-06-22Merge branch 'for-2.6.31' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'for-2.6.31' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (128 commits) nfs41: sunrpc: xprt_alloc_bc_request() should not use spin_lock_bh() nfs41: Move initialization of nfs4_opendata seq_res to nfs4_init_opendata_res nfs: remove unnecessary NFS_INO_INVALID_ACL checks NFS: More "sloppy" parsing problems NFS: Invalid mount option values should always fail, even with "sloppy" NFS: Remove unused XDR decoder functions NFS: Update MNT and MNT3 reply decoding functions NFS: add XDR decoder for mountd version 3 auth-flavor lists NFS: add new file handle decoders to in-kernel mountd client NFS: Add separate mountd status code decoders for each mountd version NFS: remove unused function in fs/nfs/mount_clnt.c NFS: Use xdr_stream-based XDR encoder for MNT's dirpath argument NFS: Clean up MNT program definitions lockd: Don't bother with RPC ping for NSM upcalls lockd: Update NSM state from SM_MON replies NFS: Fix false error return from nfs_callback_up() if ipv6.ko is not available NFS: Return error code from nfs_callback_up() to user space NFS: Do not display the setting of the "intr" mount option NFS: add support for splice writes nfs41: Backchannel: CB_SEQUENCE validation ...
2009-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (43 commits) via-velocity: Fix velocity driver unmapping incorrect size. mlx4_en: Remove redundant refill code on RX mlx4_en: Removed redundant check on lso header size mlx4_en: Cancel port_up check in transmit function mlx4_en: using stop/start_all_queues mlx4_en: Removed redundant skb->len check mlx4_en: Counting all the dropped packets on the TX side usbnet cdc_subset: fix issues talking to PXA gadgets Net: qla3xxx, remove sleeping in atomic ipv4: fix NULL pointer + success return in route lookup path isdn: clean up documentation index cfg80211: validate station settings cfg80211: allow setting station parameters in mesh cfg80211: allow adding/deleting stations on mesh ath5k: fix beacon_int handling MAINTAINERS: Fix Atheros pattern paths ath9k: restore PS mode, before we put the chip into FULL SLEEP state. ath9k: wait for beacon frame along with CAB acer-wmi: fix rfkill conversion ath5k: avoid PCI FATAL interrupts by restoring RETRY_TIMEOUT disabling ...
2009-06-22netfilter: xt_rateest: fix comparison with selfPatrick McHardy
As noticed by Török Edwin <edwintorok@gmail.com>: Compiling the kernel with clang has shown this warning: net/netfilter/xt_rateest.c:69:16: warning: self-comparison always results in a constant value ret &= pps2 == pps2; ^ Looking at the code: if (info->flags & XT_RATEEST_MATCH_BPS) ret &= bps1 == bps2; if (info->flags & XT_RATEEST_MATCH_PPS) ret &= pps2 == pps2; Judging from the MATCH_BPS case it seems to be a typo, with the intention of comparing pps1 with pps2. http://bugzilla.kernel.org/show_bug.cgi?id=13535 Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-22netfilter: xt_quota: fix incomplete initializationJan Engelhardt
Commit v2.6.29-rc5-872-gacc738f ("xtables: avoid pointer to self") forgot to copy the initial quota value supplied by iptables into the private structure, thus counting from whatever was in the memory kmalloc returned. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-22netfilter: nf_log: fix direct userspace memory access in proc handlerPatrick McHardy
