[ Upstream commit fad9dfefea6405039491e7e4fc21fb6e59e7d26c ]
tcp_get_info() can be called without holding socket lock,
so any socket fields can change under us.
Use READ_ONCE() to fetch sk_pacing_rate and sk_max_pacing_rate
Fixes: 977cb0ecf82e ("tcp: add pacing_rate information into tcp_info")
[ Upstream commit 092a29a40bab8bb4530bb3e58a0597001cdecdef ]
When the kernel deleted a vti6 interface, this interface was not removed from
the tunnels list. Thus, when the ip6_vti module was removed, this old interface
was found and the kernel tried to delete it again. This was leading to a kernel
panic.
Fixes: 61220ab34948 ("vti6: Enable namespace changing")
Signed-off-by: Yao Xiwei <xiwei.yao@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit afb7718016fcb0370ac29a83b2839c78b76c2960 ]
While originally only being intended for outgoing traffic, commit
a00e76349f35 ("netfilter: x_tables: allow to use cgroup match for
LOCAL_IN nf hooks") enabled xt_cgroups for the NF_INET_LOCAL_IN hook
as well, in order to allow for nfacct accounting.
Besides being currently limited to early demuxes only, commit
a00e76349f35 forgot to add a check if we deal with full sockets,
i.e. in this case not with time wait sockets. TCP time wait sockets
do not have the same memory layout as full sockets, a lower memory
footprint and consequently also don't have a sk_classid member;
probing for sk_classid member there could potentially lead to a
crash.
Fixes: a00e76349f35 ("netfilter: x_tables: allow to use cgroup match for LOCAL_IN nf hooks")
Cc: Alexey Perevalov <a.perevalov@samsung.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 41f97028969e4c88efa5fcf58bc6125210413a6d ]
If a provider advertizes a zero max_fast_reg_page_list_len, FRWR
depth detection loops forever. Instead of just failing the mount,
try other memory registration modes.
Fixes: 0fc6c4e7bb28 ("xprtrdma: mind the device's max fast . . .")
Reported-by: Devesh Sharma <Devesh.Sharma@Emulex.Com>
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Devesh Sharma <Devesh.Sharma@Emulex.Com>
Tested-by: Meghana Cheripady <Meghana.Cheripady@Emulex.Com>
Tested-by: Veeresh U. Kokatnur <veereshuk@chelsio.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit 7bc7972cdd1f137552ca979caa11c8acbe119ae8 ]
Device attributes are large, and are used in more than one place.
Stash a copy in dynamically allocated memory.
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
[ Upstream commit 45002267e8d2699bf9b022315bee3dd13b044843 ]
Crush temporary buffers are allocated as per replica size configured
by the user. When there are more final osds (to be selected as per
rule) than the replicas, buffer overlaps and it causes crash. Now, it
ensures that at most num-rep osds are selected even if more number of
osds are allowed by the rule.
Reflects ceph.git commits 6b4d1aa99718e3b367496326c1e64551330fabc0,
234b066ba04976783d15ff2abc3e81b6cc06fb10.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
[ Upstream commit c4c832f89dc468cf11dc0dd17206bace44526651 ]
br_fdb_update() can be called in process context in the following way:
br_fdb_add() -> __br_fdb_add() -> br_fdb_update() (if NTF_USE flag is set)
so we need to disable softirqs because there are softirq users of the
hash_lock. One easy way to reproduce this is to modify the bridge utility
to set NTF_USE, enable stp and then set maxageing to a low value so
br_fdb_cleanup() is called frequently and then just add new entries in
a loop. This happens because br_fdb_cleanup() is called from timer/softirq
context. The spin locks in br_fdb_update were _bh before commit f8ae737deea1
("[BRIDGE]: forwarding remove unneeded preempt and bh diasables")
and at the time that commit was correct because br_fdb_update() couldn't be
called from process context, but that changed after commit:
292d1398983f ("bridge: add NTF_USE support")
Using local_bh_disable/enable around br_fdb_update() allows us to keep
using the spin_lock/unlock in br_fdb_update for the fast-path.
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Fixes: 292d1398983f ("bridge: add NTF_USE support")
[ Upstream commit 6e540309326188f769e03bb4c6dd8ff6752930c2 ]
421b3885bf6d56391297844f43fb7154a6396e12 "udp: ipv4: Add udp early
demux" introduced a regression that allowed sockets bound to INADDR_ANY
to receive packets from multicast groups that the socket had not joined.
For example a socket that had joined 224.168.2.9 could also receive
packets from 225.168.2.9 despite not having joined that group if
ip_early_demux is enabled.
Fix this by calling ip_check_mc_rcu() in udp_v4_early_demux() to verify
that the multicast packet is indeed ours.
Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Reported-by: Yurij M. Plotnikov <Yurij.Plotnikov@oktetlabs.ru>
[ Upstream commit 9f950415e4e28e7cfae2e416b43e862e8101d996 ]
Linux 3.17 and earlier are explicitly engineered so that if the app
doesn't specifically request a CC module on a listener before the SYN
arrives, then the child gets the system default CC when the connection
is established. See tcp_init_congestion_control() in 3.17 or earlier,
which says "if no choice made yet assign the current value set as
default". The change ("net: tcp: assign tcp cong_ops when tcp sk is
created") altered these semantics, so that children got their parent
listener's congestion control even if the system default had changed
after the listener was created.
This commit returns to those original semantics from 3.17 and earlier,
since they are the original semantics from 2007 in 4d4d3d1e8 ("[TCP]:
Congestion control initialization."), and some Linux congestion
control workflows depend on that.
In summary, if a listener socket specifically sets TCP_CONGESTION to
"x", or the route locks the CC module to "x", then the child gets
"x". Otherwise the child gets current system default from
net.ipv4.tcp_congestion_control. That's the behavior in 3.17 and
earlier, and this commit restores that.
Fixes: 55d8694fa82c ("net: tcp: assign tcp cong_ops when tcp sk is created")
Cc: Florian Westphal <fw@strlen.de>
Cc: Daniel Borkmann <dborkman@redhat.com>
Cc: Glenn Judd <glenn.judd@morganstanley.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit beb39db59d14990e401e235faf66a6b9b31240b0 ]
We have two problems in UDP stack related to bogus checksums :
1) We return -EAGAIN to application even if receive queue is not empty.
This breaks applications using edge trigger epoll()
2) Under UDP flood, we can loop forever without yielding to other
processes, potentially hanging the host, especially on non SMP.
This patch is an attempt to make things better.
We might in the future add extra support for rt applications
wanting to better control time spent doing a recv() in a hostile
environment. For example we could validate checksums before queuing
packets in socket receive queue.
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit 71d9f6149cac8fc6646adfb2a6f3b0de6ddd23f6 ]
br_multicast_query_expired() querier argument is a pointer to
a struct bridge_mcast_querier :
struct bridge_mcast_querier {
struct br_ip addr;
struct net_bridge_port __rcu *port;
Intent of the code was to clear port field, not the pointer to querier.
Fixes: 2cd4143192e8 ("bridge: memorize and export selected IGMP/MLD querier port")
Acked-by: Thadeu Lima de Souza Cascardo <cascardo@redhat.com>
Acked-by: Linus Lüssing <linus.luessing@c0d3.blue>
Cc: Linus Lüssing <linus.luessing@web.de>
Cc: Steinar H. Gunderson <sesse@samfundet.no>
[ Upstream commit 86e363dc3b50bfd50a1f315934583fbda673ab8d ]
For mq qdisc, we add per tx queue qdisc to root qdisc
for display purpose, however, that happens too early,
before the new dev->qdisc is finally set, this causes
q->list points to an old root qdisc which is going to be
freed right before assigning with a new one.
Fix this by moving ->attach() after setting dev->qdisc.
For the record, this fixes the following crash:
WARNING: CPU: 1 PID: 975 at lib/list_debug.c:59 __list_del_entry+0x5a/0x98()
list_del corruption. prev->next should be ffff8800d1998ae8, but was 6b6b6b6b6b6b6b6b
CPU: 1 PID: 975 Comm: tc Not tainted 4.1.0-rc4+ #1019
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
0000000000000009 ffff8800d73fb928 ffffffff81a44e7f 0000000047574756
ffff8800d73fb978 ffff8800d73fb968 ffffffff810790da ffff8800cfc4cd20
ffffffff814e725b ffff8800d1998ae8 ffffffff82381250 0000000000000000
Call Trace:
[<ffffffff81a44e7f>] dump_stack+0x4c/0x65
[<ffffffff810790da>] warn_slowpath_common+0x9c/0xb6
[<ffffffff814e725b>] ? __list_del_entry+0x5a/0x98
[<ffffffff81079162>] warn_slowpath_fmt+0x46/0x48
[<ffffffff81820eb0>] ? dev_graft_qdisc+0x5e/0x6a
[<ffffffff814e725b>] __list_del_entry+0x5a/0x98
[<ffffffff814e72a7>] list_del+0xe/0x2d
[<ffffffff81822f05>] qdisc_list_del+0x1e/0x20
[<ffffffff81820cd1>] qdisc_destroy+0x30/0xd6
[<ffffffff81822676>] qdisc_graft+0x11d/0x243
[<ffffffff818233c1>] tc_get_qdisc+0x1a6/0x1d4
[<ffffffff810b5eaf>] ? mark_lock+0x2e/0x226
[<ffffffff817ff8f5>] rtnetlink_rcv_msg+0x181/0x194
[<ffffffff817ff72e>] ? rtnl_lock+0x17/0x19
[<ffffffff817ff774>] ? __rtnl_unlock+0x17/0x17
[<ffffffff81855dc6>] netlink_rcv_skb+0x4d/0x93
[<ffffffff817ff756>] rtnetlink_rcv+0x26/0x2d
[<ffffffff818544b2>] netlink_unicast+0xcb/0x150
[<ffffffff81161db9>] ? might_fault+0x59/0xa9
[<ffffffff81854f78>] netlink_sendmsg+0x4fa/0x51c
[<ffffffff817d6e09>] sock_sendmsg_nosec+0x12/0x1d
[<ffffffff817d8967>] sock_sendmsg+0x29/0x2e
[<ffffffff817d8cf3>] ___sys_sendmsg+0x1b4/0x23a
[<ffffffff8100a1b8>] ? native_sched_clock+0x35/0x37
[<ffffffff810a1d83>] ? sched_clock_local+0x12/0x72
[<ffffffff810a1fd4>] ? sched_clock_cpu+0x9e/0xb7
[<ffffffff810def2a>] ? current_kernel_time+0xe/0x32
[<ffffffff810b4bc5>] ? lock_release_holdtime.part.29+0x71/0x7f
[<ffffffff810ddebf>] ? read_seqcount_begin.constprop.27+0x5f/0x76
[<ffffffff810b6292>] ? trace_hardirqs_on_caller+0x17d/0x199
[<ffffffff811b14d5>] ? __fget_light+0x50/0x78
[<ffffffff817d9808>] __sys_sendmsg+0x42/0x60
[<ffffffff817d9838>] SyS_sendmsg+0x12/0x1c
[<ffffffff81a50e97>] system_call_fastpath+0x12/0x6f
---[ end trace ef29d3fb28e97ae7 ]---
For long term, we probably need to clean up the qdisc_graft() code
in case it hides other bugs like this.
Fixes: 95dc19299f74 ("pkt_sched: give visibility to mq slave qdiscs")
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit b48732e4a48d80ed4a14812f0bab09560846514e ]
got a rare NULL pointer dereference in clear_bit
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
v2: switch to sock_flag(sk, SOCK_DEAD) and added net/caif/caif_socket.c
v3: return -ECONNRESET in upstream caller of wait function for SOCK_DEAD
[ Upstream commit 47cc84ce0c2fe75c99ea5963c4b5704dd78ead54 ]
When more than a multicast address is present in a MLDv2 report, all but
the first address is ignored, because the code breaks out of the loop if
there has not been an error adding that address.
This has caused failures when two guests connected through the bridge
tried to communicate using IPv6. Neighbor discoveries would not be
transmitted to the other guest when both used a link-local address and a
static address.
This only happens when there is a MLDv2 querier in the network.
The fix will only break out of the loop when there is a failure adding a
multicast address.
The mdb before the patch:
dev ovirtmgmt port vnet0 grp ff02::1:ff7d:6603 temp
dev ovirtmgmt port vnet1 grp ff02::1:ff7d:6604 temp
dev ovirtmgmt port bond0.86 grp ff02::2 temp
After the patch:
dev ovirtmgmt port bond0.86 grp ff02::fb temp
dev ovirtmgmt port bond0.86 grp ff02::d temp
dev ovirtmgmt port vnet0 grp ff02::1:ff00:76 temp
dev ovirtmgmt port bond0.86 grp ff02::16 temp
dev ovirtmgmt port vnet1 grp ff02::1:ff00:77 temp
dev ovirtmgmt port bond0.86 grp ff02::1:ff00:def temp
dev ovirtmgmt port bond0.86 grp ff02::1:ffa1:40bf temp
Fixes: 08b202b67264 ("bridge br_multicast: IPv6 MLD support.")
Reported-by: Rik Theys <Rik.Theys@esat.kuleuven.be>
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@redhat.com>
Tested-by: Rik Theys <Rik.Theys@esat.kuleuven.be>
[ Upstream commit 381c759d9916c42959515ad34a6d467e24a88e93 ]
ip_error does not check if in_dev is NULL before dereferencing it.
IThe following sequence of calls is possible:
CPU A CPU B
ip_rcv_finish
ip_route_input_noref()
ip_route_input_slow()
inetdev_destroy()
dst_input()
With the result that a network device can be destroyed while processing
an input packet.
A crash was triggered with only unicast packets in flight, and
forwarding enabled on the only network device. The error condition
was created by the removal of the network device.
As such it is likely the that error code was -EHOSTUNREACH, and the
action taken by ip_error (if in_dev had been accessible) would have
been to not increment any counters and to have tried and likely failed
to send an icmp error as the network device is going away.
Therefore handle this weird case by just dropping the packet if
!in_dev. It will result in dropping the packet sooner, and will not
result in an actual change of behavior.
Fixes: 251da4130115b ("ipv4: Cache ip_error() routes even when not forwarding.")
Reported-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Tested-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Signed-off-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
[ Upstream commit c78e1746d3ad7d548bdf3fe491898cc453911a49 ]
Vijay reported that a loop as simple as ...
while true; do
tc qdisc add dev foo root handle 1: prio
tc filter add dev foo parent 1: u32 match u32 0 0 flowid 1
tc qdisc del dev foo root
rmmod cls_u32
done
... will panic the kernel. Moreover, he bisected the change
apparently introducing it to 78fd1d0ab072 ("netlink: Re-add
locking to netlink_lookup() and seq walker").
The removal of synchronize_net() from the netlink socket
triggering the qdisc to be removed, seems to have uncovered
an RCU resp. module reference count race from the tc API.
Given that RCU conversion was done after e341694e3eb5 ("netlink:
Convert netlink_lookup() to use RCU protected hash table")
which added the synchronize_net() originally, occasion of
hitting the bug was less likely (not impossible though):
When qdiscs that i) support attaching classifiers and,
ii) have at least one of them attached, get deleted, they
invoke tcf_destroy_chain(), and thus call into ->destroy()
handler from a classifier module.
After RCU conversion, all classifier that have an internal
prio list, unlink them and initiate freeing via call_rcu()
deferral.
Meanhile, tcf_destroy() releases already reference to the
tp->ops->owner module before the queued RCU callback handler
has been invoked.
Subsequent rmmod on the classifier module is then not prevented
since all module references are already dropped.
By the time, the kernel invokes the RCU callback handler from
the module, that function address is then invalid.
One way to fix it would be to add an rcu_barrier() to
unregister_tcf_proto_ops() to wait for all pending call_rcu()s
to complete.
synchronize_rcu() is not appropriate as under heavy RCU
callback load, registered call_rcu()s could be deferred
longer than a grace period. In case we don't have any pending
call_rcu()s, the barrier is allowed to return immediately.
Since we came here via unregister_tcf_proto_ops(), there
are no users of a given classifier anymore. Further nested
call_rcu()s pointing into the module space are not being
done anywhere.
Only cls_bpf_delete_prog() may schedule a work item, to
unlock pages eventually, but that is not in the range/context
of cls_bpf anymore.
Fixes: 25d8c0d55f24 ("net: rcu-ify tcf_proto")
Fixes: 9888faefe132 ("net: sched: cls_basic use RCU")
Reported-by: Vijay Subramanian <subramanian.vijay@gmail.com>
Cc: John Fastabend <john.r.fastabend@intel.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Tested-by: Vijay Subramanian <subramanian.vijay@gmail.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
[ Upstream commit 33b4b015e1a1ca7a8fdce40af5e71642a8ea355c ]
Commit <5cf3d46192fc> ("udp: Simplify__udp*_lib_mcast_deliver")
simplified the filter for incoming IPv6 multicast but removed
the check of the local socket address and the UDP destination
address.
This patch restores the filter to prevent sockets bound to a IPv6
multicast IP to receive other UDP traffic link unicast.
Signed-off-by: Henning Rogge <hrogge@gmail.com>
Fixes: 5cf3d46192fc ("udp: Simplify__udp*_lib_mcast_deliver")
[ Upstream commit 21858cd02dabcf290564cbf4769b101eba54d7bb ]
commit 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages
send from TIME_WAIT") added the flow label in the last TCP packets.
Unfortunately, it was not casted properly.
This patch replace the buggy shift with be32_to_cpu/cpu_to_be32.
Fixes: 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages")
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
[ Upstream commit ed2a80ab7b76f11af0b2c6255709c4ebf164b667 ]
Before the patch, the command 'ip link add bond2 type bond mode 802.3ad'
causes the kernel to send a rtnl message for the bond2 interface, with an
ifindex 0.
'ip monitor' shows:
0: bond2: <BROADCAST,MULTICAST,MASTER> mtu 1500 state DOWN group default
link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
9: bond2@NONE: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN group default
link/ether ea:3e:1f:53:92:7b brd ff:ff:ff:ff:ff:ff
[snip]
The patch fixes the spotted bug by checking in bond driver if the interface
is registered before calling the notifier chain.
It also adds a check in rtmsg_ifinfo() to prevent this kind of bug in the
future.
Fixes: d4261e565000 ("bonding: create netlink event when bonding option is changed")
CC: Jiri Pirko <jiri@resnulli.us>
Reported-by: Julien Meunier <julien.meunier@6wind.com>
[ Upstream commit d66bf7dd27573ee5ea90484899ee952c19ccb194 ]
The code in __netdev_upper_dev_link() has an over-stringent
loop detection logic that actually prevents valid configurations
from working correctly.
In particular, the logic returns an error if an upper device
is already in the list of all upper devices for a given dev.
This particular check seems to be a overzealous as it disallows
perfectly valid configurations. For example:
# ip l a link eth0 name eth0.10 type vlan id 10
# ip l a dev br0 typ bridge
# ip l s eth0.10 master br0
# ip l s eth0 master br0 <--- Will fail
If you switch the last two commands (add eth0 first), then both
will succeed. If after that, you remove eth0 and try to re-add
it, it will fail!
It appears to be enough to simply check adj_list to keeps things
safe.
I've tried stacking multiple devices multiple times in all different
combinations, and either rx_handler registration prevented the stacking
of the device linking cought the error.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Acked-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Veaceslav Falico <vfalico@gmail.com>
[ Upstream commit ac37e2515c1a89c477459a2020b6bfdedabdb91b ]
dst_orig should be released on error. Function like __xfrm_route_forward()
expects that behavior.
Since a recent commit, xfrm_lookup() may also be called by xfrm_lookup_route(),
which expects the opposite.
Let's introduce a new flag (XFRM_LOOKUP_KEEP_DST_REF) to tell what should be
done in case of error.
Fixes: f92ee61982d("xfrm: Generate blackhole routes only from route lookup functions")
Signed-off-by: huaibin Wang <huaibin.wang@6wind.com>
[ Upstream commit 9507271d960a1911a51683888837d75c171cd91f ]
In an environment where the KDC is running Active Directory, the
exported composite name field returned in the context could be large
enough to span a page boundary. Attaching a scratch buffer to the
decoding xdr_stream helps deal with those cases.
The case where we saw this was actually due to behavior that's been
fixed in newer gss-proxy versions, but we're fixing it here too.
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
Cc: stable@vger.kernel.org
Reviewed-by: Simo Sorce <simo@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit 22d3a3c829fa9ecdb493d1f1f2838d543f8d86a3 ]
No matter how the driver manages its NAPI context, there's no way
sending frames to it from a timer can be correct, since it would
corrupt the internal GRO lists.
To avoid that, always use the non-NAPI path when releasing frames
from the timer.
Reported-by: Jean Trivelly <jean.trivelly@intel.com>
[ Upstream commit 47b4e1fc4972cc43a19121bc2608a60aef3bf216 ]
Remove checking tailroom when adding IV as it uses only
headroom, and move the check to the ICV generation that
actually needs the tailroom.
In other case I hit such warning and datapath don't work,
when testing:
- IBSS + WEP
- ath9k with hw crypt enabled
- IPv6 data (ping6)
WARNING: CPU: 3 PID: 13301 at net/mac80211/wep.c:102 ieee80211_wep_add_iv+0x129/0x190 [mac80211]()
Call Trace:
[<ffffffff817bf491>] dump_stack+0x45/0x57
[<ffffffff8107746a>] warn_slowpath_common+0x8a/0xc0
[<ffffffff8107755a>] warn_slowpath_null+0x1a/0x20
[<ffffffffc09ae109>] ieee80211_wep_add_iv+0x129/0x190 [mac80211]
[<ffffffffc09ae7ab>] ieee80211_crypto_wep_encrypt+0x6b/0xd0 [mac80211]
[<ffffffffc09d3fb1>] invoke_tx_handlers+0xc51/0xf30 [mac80211]
Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com>
[ Upstream commit 521a04d06a729e5971cdee7f84080387ed320527 ]
This reverts commit ba9d114ec5578e6e99a4dfa37ff8ae688040fd64.
.. which introduced a regression that prevented all lingering requests
requeued in kick_requests() from ever being sent to the OSDs, resulting
in a lot of missed notifies. In retrospect it's pretty obvious that
r_req_lru_item item in the case of lingering requests can be used not
only for notarget, but also for unsent linkage due to how tightly
actual map and enqueue operations are coupled in __map_request().
The assertion that was being silenced is taken care of in the previous
("libceph: request a new osdmap if lingering request maps to no osd")
commit: by always kicking homeless lingering requests we ensure that
none of them ends up on the notarget list outside of the critical
section guarded by request_mutex.
Cc: stable@vger.kernel.org # 3.18+, needs b0494532214b "libceph: request a new osdmap if lingering request maps to no osd"
Reviewed-by: Sage Weil <sage@redhat.com>
[ Upstream commit 0b67c43ce36a9964f1d5e3f973ee19eefd3f9f8f ]
We also need to save/store in forward, else br_parse_ip_options call
will zero frag_max_size as well.
Fixes: 93fdd47e5 ('bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING')
[ Upstream commit 2ea2f62c8bda242433809c7f4e9eae1c52c40bbe ]
When I added pfmemalloc support in build_skb(), I forgot netlink
was using build_skb() with a vmalloc() area.
In this patch I introduce __build_skb() for netlink use,
and build_skb() is a wrapper handling both skb->head_frag and
skb->pfmemalloc
This means netlink no longer has to hack skb->head_frag
[ 1567.700067] kernel BUG at arch/x86/mm/physaddr.c:26!
[ 1567.700067] invalid opcode: 0000 [#1] PREEMPT SMP KASAN
[ 1567.700067] Dumping ftrace buffer:
[ 1567.700067] (ftrace buffer empty)
[ 1567.700067] Modules linked in:
[ 1567.700067] CPU: 9 PID: 16186 Comm: trinity-c182 Not tainted 4.0.0-next-20150424-sasha-00037-g4796e21 #2167
[ 1567.700067] task: ffff880127efb000 ti: ffff880246770000 task.ti: ffff880246770000
[ 1567.700067] RIP: __phys_addr (arch/x86/mm/physaddr.c:26 (discriminator 3))
[ 1567.700067] RSP: 0018:ffff8802467779d8 EFLAGS: 00010202
[ 1567.700067] RAX: 000041000ed8e000 RBX: ffffc9008ed8e000 RCX: 000000000000002c
[ 1567.700067] RDX: 0000000000000004 RSI: 0000000000000000 RDI: ffffffffb3fd6049
[ 1567.700067] RBP: ffff8802467779f8 R08: 0000000000000019 R09: ffff8801d0168000
[ 1567.700067] R10: ffff8801d01680c7 R11: ffffed003a02d019 R12: ffffc9000ed8e000
[ 1567.700067] R13: 0000000000000f40 R14: 0000000000001180 R15: ffffc9000ed8e000
[ 1567.700067] FS: 00007f2a7da3f700(0000) GS:ffff8801d1000000(0000) knlGS:0000000000000000
[ 1567.700067] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1567.700067] CR2: 0000000000738308 CR3: 000000022e329000 CR4: 00000000000007e0
[ 1567.700067] Stack:
[ 1567.700067] ffffc9000ed8e000 ffff8801d0168000 ffffc9000ed8e000 ffff8801d0168000
[ 1567.700067] ffff880246777a28 ffffffffad7c0a21 0000000000001080 ffff880246777c08
[ 1567.700067] ffff88060d302e68 ffff880246777b58 ffff880246777b88 ffffffffad9a6821
[ 1567.700067] Call Trace:
[ 1567.700067] build_skb (include/linux/mm.h:508 net/core/skbuff.c:316)
[ 1567.700067] netlink_sendmsg (net/netlink/af_netlink.c:1633 net/netlink/af_netlink.c:2329)
[ 1567.774369] ? sched_clock_cpu (kernel/sched/clock.c:311)
[ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273)
[ 1567.774369] sock_sendmsg (net/socket.c:614 net/socket.c:623)
[ 1567.774369] sock_write_iter (net/socket.c:823)
[ 1567.774369] ? sock_sendmsg (net/socket.c:806)
[ 1567.774369] __vfs_write (fs/read_write.c:479 fs/read_write.c:491)
[ 1567.774369] ? get_lock_stats (kernel/locking/lockdep.c:249)
[ 1567.774369] ? default_llseek (fs/read_write.c:487)
[ 1567.774369] ? vtime_account_user (kernel/sched/cputime.c:701)
[ 1567.774369] ? rw_verify_area (fs/read_write.c:406 (discriminator 4))
[ 1567.774369] vfs_write (fs/read_write.c:539)
[ 1567.774369] SyS_write (fs/read_write.c:586 fs/read_write.c:577)
[ 1567.774369] ? SyS_read (fs/read_write.c:577)
[ 1567.774369] ? __this_cpu_preempt_check (lib/smp_processor_id.c:63)
[ 1567.774369] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2594 kernel/locking/lockdep.c:2636)
[ 1567.774369] ? trace_hardirqs_on_thunk (arch/x86/lib/thunk_64.S:42)
[ 1567.774369] system_call_fastpath (arch/x86/kernel/entry_64.S:261)
Fixes: 79930f5892e ("net: do not deplete pfmemalloc reserve")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
[ Upstream commit 79930f5892e134c6da1254389577fffb8bd72c66 ]
build_skb() should look at the page pfmemalloc status.
If set, this means page allocator allocated this page in the
expectation it would help to free other pages. Networking
stack can do that only if skb->pfmemalloc is also set.
Also, we must refrain using high order pages from the pfmemalloc
reserve, so __page_frag_refill() must also use __GFP_NOMEMALLOC for
them. Under memory pressure, using order-0 pages is probably the best
strategy.
[ Upstream commit 845704a535e9b3c76448f52af1b70e4422ea03fd ]
Presence of an unbound loop in tcp_send_fin() had always been hard
to explain when analyzing crash dumps involving gigantic dying processes
with millions of sockets.
Lets try a different strategy :
In case of memory pressure, try to add the FIN flag to last packet
in write queue, even if packet was already sent. TCP stack will
be able to deliver this FIN after a timeout event. Note that this
FIN being delivered by a retransmit, it also carries a Push flag
given our current implementation.
By checking sk_under_memory_pressure(), we anticipate that cooking
many FIN packets might deplete tcp memory.
In the case we could not allocate a packet, even with __GFP_WAIT
allocation, then not sending a FIN seems quite reasonable if it allows
to get rid of this socket, free memory, and not block the process from
eventually doing other useful work.
[ Upstream commit d83769a580f1132ac26439f50068a29b02be535e ]
Using sk_stream_alloc_skb() in tcp_send_fin() is dangerous in
case a huge process is killed by OOM, and tcp_mem[2] is hit.
To be able to free memory we need to make progress, so this
patch allows FIN packets to not care about tcp_mem[2], if
skb allocation succeeded.
In a follow-up patch, we might abort tcp_send_fin() infinite loop
in case TIF_MEMDIE is set on this thread, as memory allocator
did its best getting extra memory already.
This patch reverts d22e15371811 ("tcp: fix tcp fin memory accounting")
Fixes: d22e15371811 ("tcp: fix tcp fin memory accounting")
[ Upstream commit 2ab957492d13bb819400ac29ae55911d50a82a13 ]
Initial discussion was:
[FYI] xfrm: Don't lookup sk_policy for timewait sockets
Forwarded frames should not have a socket attached. Especially
tw sockets will lead to panics later-on in the stack.
This was observed with TPROXY assigning a tw socket and broken
policy routing (misconfigured). As a result frame enters
forwarding path instead of input. We cannot solve this in
TPROXY as it cannot know that policy routing is broken.
v2:
Remove useless comment
Signed-off-by: Sebastian Poehn <sebastian.poehn@gmail.com>
[ Upstream commit a134f083e79fb4c3d0a925691e732c56911b4326 ]
If we don't do that, then the poison value is left in the ->pprev
backlink.
This can cause crashes if we do a disconnect, followed by a connect().
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Reported-by: Wen Xu <hotdog3645@gmail.com>
[ Upstream commit b736a623bd099cdf5521ca9bd03559f3bc7fa31c ]
handle_offloads() calls skb_reset_inner_headers() to store
the layer pointers to the encapsulated packet. However, we
currently push the vlag tag (if there is one) onto the packet
afterwards. This changes the MAC header for the encapsulated
packet but it is not reflected in skb->inner_mac_header, which
breaks GSO and drivers which attempt to use this for encapsulation
offloads.
Fixes: 1eaa8178 ("vxlan: Add tx-vlan offload support.")
Signed-off-by: Jesse Gross <jesse@nicira.com>
[ Upstream commit 5968250c868ceee680aa77395b24e6ddcae17d36 ]
Use them to push skb->vlan_tci into the payload and avoid code
duplication.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
[ Upstream commit 62749e2cb3c4a7da3eaa5c01a7e787aebeff8536 ]
Name fits better. Plus there's going to be introduced
__vlan_insert_tag later on.
[ Upstream commit 213dd74aee765d4e5f3f4b9607fef0cf97faa2af ]
On Wed, Apr 15, 2015 at 05:41:26PM +0200, Nicolas Dichtel wrote:
> Le 15/04/2015 15:57, Herbert Xu a écrit :
> >On Wed, Apr 15, 2015 at 06:22:29PM +0800, Herbert Xu wrote:
> [snip]
> >Subject: skbuff: Do not scrub skb mark within the same name space
> >The commit ea23192e8e577dfc51e0f4fc5ca113af334edff9 ("tunnels:
> Maybe add a Fixes tag?
> Fixes: ea23192e8e57 ("tunnels: harmonize cleanup done on skb on rx path")
> >harmonize cleanup done on skb on rx path") broke anyone trying to
> >use netfilter marking across IPv4 tunnels. While most of the
> >fields that are cleared by skb_scrub_packet don't matter, the
> >netfilter mark must be preserved.
> >This patch rearranges skb_scurb_packet to preserve the mark field.
> nit: s/scurb/scrub
> Else it's fine for me.
Sure.
PS I used the wrong email for James the first time around. So
let me repeat the question here. Should secmark be preserved
or cleared across tunnels within the same name space? In fact,
do our security models even support name spaces?
---8<---
This patch rearranges skb_scrub_packet to preserve the mark field.
Acked-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit 4c0ee414e877b899f7fc80aafb98d9425c02797f ]
This patch reverts commit b8fb4e0648a2ab3734140342002f68fb0c7d1602
because the secmark must be preserved even when a packet crosses
namespace boundaries. The reason is that security labels apply to
the system as a whole and is not per-namespace.
[ Upstream commit b50edd7812852d989f2ef09dcfc729690f54a42d ]
I noticed tcpdump was giving funky timestamps for locally
generated SYNACK messages on loopback interface.
11:42:46.938990 IP 127.0.0.1.48245 > 127.0.0.2.23850: S
945476042:945476042(0) win 43690 <mss 65495,nop,nop,sackOK,nop,wscale 7>
20:28:58.502209 IP 127.0.0.2.23850 > 127.0.0.1.48245: S
3160535375:3160535375(0) ack 945476043 win 43690 <mss
This is because we need to clear skb->tstamp before
entering lower stack, otherwise net_timestamp_check()
does not set skb->tstamp.
Fixes: 7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when")
[ Upstream commit f60e5990d9c1424af9dbca60a23ba2a1c7c1ce90 ]
We should not consult skb->sk for output decisions in xmit recursion
levels > 0 in the stack. Otherwise local socket settings could influence
the result of e.g. tunnel encapsulation process.
ipv6 does not conform with this in three places:
1) ip6_fragment: we do consult ipv6_npinfo for frag_size
2) sk_mc_loop in ipv6 uses skb->sk and checks if we should
loop the packet back to the local socket
3) ip6_skb_dst_mtu could query the settings from the user socket and
force a wrong MTU
Furthermore:
In sk_mc_loop we could potentially land in WARN_ON(1) if we use a
PF_PACKET socket ontop of an IPv6-backed vxlan device.
Reuse xmit_recursion as we are currently only interested in protecting
tunnel devices.
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 666b805150efd62f05810ff0db08f44a2370c937 ]
On processing cumulative ACKs, the FRTO code was not checking the
SACKed bit, meaning that there could be a spurious FRTO undo on a
cumulative ACK of a previously SACKed skb.
The FRTO code should only consider a cumulative ACK to indicate that
an original/unretransmitted skb is newly ACKed if the skb was not yet
SACKed.
The effect of the spurious FRTO undo would typically be to make the
connection think that all previously-sent packets were in flight when
they really weren't, leading to a stall and an RTO.
Fixes: e33099f96d99c ("tcp: implement RFC5682 F-RTO")
[ Upstream commit 4ad19de8774e2a7b075b3e8ea48db85adcf33fa6 ]
tcp_v6_fill_cb() will be called twice if socket's state changes from
TCP_TIME_WAIT to TCP_LISTEN. That can result in control buffer data
corruption because in the second tcp_v6_fill_cb() call it's not copying
IP6CB(skb) anymore, but 'seq', 'end_seq', etc., so we can get weird and
unpredictable results. Performance loss of up to 1200% has been observed
in LTP/vxlan03 test.
This can be fixed by copying inet6_skb_parm to the beginning of 'cb'
only if xfrm6_policy_check() and tcp_v6_fill_cb() are going to be
called again.
Fixes: 2dc49d1680b53 ("tcp6: don't move IP6CB before xfrm6_policy_check()")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
[ Upstream commit 6fd99094de2b83d1d4c8457f2c83483b2828e75a ]
A local route may have a lower hop_limit set than global routes do.
RFC 3756, Section 4.2.7, "Parameter Spoofing"
> 1. The attacker includes a Current Hop Limit of one or another small
> number which the attacker knows will cause legitimate packets to
> be dropped before they reach their destination.
> As an example, one possible approach to mitigate this threat is to
> ignore very small hop limits. The nodes could implement a
> configurable minimum hop limit, and ignore attempts to set it below
> said limit.
Signed-off-by: D.S. Ljungmark <ljungmark@modio.se>
[ Upstream commit d0c294c53a771ae7e84506dfbd8c18c30f078735 ]
On s390x, gcc 4.8 compiles this part of tcp_v6_early_demux()
struct dst_entry *dst = sk->sk_rx_dst;
if (dst)
dst = dst_check(dst, inet6_sk(sk)->rx_dst_cookie);
to code reading sk->sk_rx_dst twice, once for the test and once for
the argument of ip6_dst_check() (dst_check() is inline). This allows
ip6_dst_check() to be called with null first argument, causing a crash.
Protect sk->sk_rx_dst access by READ_ONCE() both in IPv4 and IPv6
TCP early demux code.
Fixes: 41063e9dd119 ("ipv4: Early TCP socket demux.")
Fixes: c7109986db3c ("ipv6: Early TCP socket demux")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit 788211d81bfdf9b6a547d0530f206ba6ee76b107 ]
There's an issue with the way the RX A-MPDU reorder timer is
deleted that can cause a kernel crash like this:
* tid_rx is removed - call_rcu(ieee80211_free_tid_rx)
* station is destroyed
* reorder timer fires before ieee80211_free_tid_rx() runs,
accessing the station, thus potentially crashing due to
the use-after-free
The station deletion is protected by synchronize_net(), but
that isn't enough -- ieee80211_free_tid_rx() need not have
run when that returns (it deletes the timer.) We could use
rcu_barrier() instead of synchronize_net(), but that's much
more expensive.
Instead, to fix this, add a field tracking that the session
is being deleted. In this case, the only re-arming of the
timer happens with the reorder spinlock held, so make that
code not rearm it if the session is being deleted and also
delete the timer after setting that field. This ensures the
timer cannot fire after ___ieee80211_stop_rx_ba_session()
returns, which fixes the problem.
[ Upstream commit 6d7fdb0ab351b33d4c12d53fe44be030b90fc9d4 ]
This reverts commit 89baaa570ab0b476db09408d209578cfed700e9f.
Dirty page throttling should be sufficient for us in the general case
so there is no need to use __GFP_MEMALLOC - it would be needed only in
the swap-over-rbd case, which we currently don't support. (It would
probably take approximately the commit that is being reverted to add
that support, but we would also need the "swap" option to distinguish
from the general case and make sure swap ceph_client-s aren't shared
with anything else.) See ceph-devel threads [1] and [2] for the
details of why enabling pfmemalloc reserves for all cases is a bad
thing.
On top of potential system lockups related to drained emergency
reserves, this turned out to cause ceph lockups in case peers are on
the same host and communicating via loopback due to sk_filter()
dropping pfmemalloc skbs on the receiving side because the receiving
loopback socket is not tagged with SOCK_MEMALLOC.
[1] "SOCK_MEMALLOC vs loopback"
http://www.spinics.net/lists/ceph-devel/msg22998.html
[2] "[PATCH] libceph: don't set memalloc flags in loopback case"
http://www.spinics.net/lists/ceph-devel/msg23392.html
net/ceph/messenger.c [ context: tcp_nodelay option ]
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Sage Weil <sage@redhat.com>
Cc: stable@vger.kernel.org # 3.18+, needs backporting
Acked-by: Mike Christie <michaelc@cs.wisc.edu>
[idryomov@gmail.com: backport to 3.18, 3.19: context]
[ Upstream commit 0f611d28fc2e13cfec64e1c544c16a086886805a ]
Since moving the interface combination checks to mac80211, it's
broken because it now only considers interfaces with an assigned
channel context, so for example any interface that isn't active
can still be up, which is clearly an issue; also, in particular
P2P-Device wdevs are an issue since they never have a chanctx.
Fix this by counting running interfaces instead the ones with a
channel context assigned.
Cc: stable@vger.kernel.org [3.16+]
Fixes: 73de86a38962b ("cfg80211/mac80211: move interface counting for combination check to mac80211")
Signed-off-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[rewrite commit message, dig out the commit it fixes]
[ Upstream commit d0c22119f574b851e63360c6b8660fe9593bbc3c ]
The mesh forwarding path was not checking that data
frames were protected when running an encrypted network;
add the necessary check.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
[ Upstream commit aa75ebc275b2a91b193654a177daf900ad6703f0 ]
Some APs experience problems when working with
U-APSD. Decreasing the probability of that
happening by using legacy mode for all ACs but VO
isn't enough.
Cisco 4410N originally forced us to enable VO by
default only because it treated non-VO ACs as
legacy.
However some APs (notably Netgear R7000) silently
reclassify packets to different ACs. Since u-APSD
ACs require trigger frames for frame retrieval
clients would never see some frames (e.g. ARP
responses) or would fetch them accidentally after
a long time.
It makes little sense to enable u-APSD queues by
default because it needs userspace applications to
be aware of it to actually take advantage of the
possible additional powersavings. Implicitly
depending on driver autotrigger frame support
doesn't make much sense.
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
[ Upstream commit 496fcc294daab18799e190c0264863d653588d1f ]
As HT/VHT depend heavily on QoS/WMM, it's not a good idea to
let userspace add clients that have HT/VHT but not QoS/WMM.
Since it does so in certain cases we've observed (client is
using HT IEs but not QoS/WMM) just ignore the HT/VHT info at
this point and don't pass it down to the drivers which might
unconditionally use it.
