path: root/net
2011-07-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits) sctp: fix missing send up SCTP_SENDER_DRY_EVENT when subscribe it net: refine {udp|tcp|sctp}_mem limits vmxnet3: round down # of queues to power of two net: sh_eth: fix the parameter for the ETHER of SH7757 net: sh_eth: fix cannot work half-duplex mode net: vlan: enable soft features regardless of underlying device vmxnet3: fix starving rx ring whenoc_skb kb fails bridge: Always flood broadcast packets greth: greth_set_mac_add would corrupt the MAC address. net: bind() fix error return on wrong address family natsemi: silence dma-debug warnings net: 8139too: Initial necessary vlan_features to support vlan Fix call trace when interrupts are disabled while sleeping function kzalloc is called qlge:Version change to v1.00.00.29 qlge: Fix printk priority so chip fatal errors are always reported. qlge:Fix crash caused by mailbox execution on wedged chip. xfrm4: Don't call icmp_send on local error ipv4: Don't use ufo handling on later transformed packets xfrm: Remove family arg from xfrm_bundle_ok ipv6: Don't put artificial limit on routing table size. ...
2011-07-07sctp: fix missing send up SCTP_SENDER_DRY_EVENT when subscribe itWei Yongjun
We forgot to send up SCTP_SENDER_DRY_EVENT notification when user app subscribes to this event, and there is no data to be sent or retransmit. This is required by the Socket API and used by the DTLS/SCTP implementation. Reported-by: Michael Tüxen <Michael.Tuexen@lurchi.franken.de> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Tested-by: Robin Seggelmann <seggelmann@fh-muenster.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07net: refine {udp|tcp|sctp}_mem limitsEric Dumazet
Current tcp/udp/sctp global memory limits are not taking into account hugepages allocations, and allow 50% of ram to be used by buffers of a single protocol [ not counting space used by sockets / inodes ...] Lets use nr_free_buffer_pages() and allow a default of 1/8 of kernel ram per protocol, and a minimum of 128 pages. Heavy duty machines sysadmins probably need to tweak limits anyway. References: https://bugzilla.stlinux.com/show_bug.cgi?id=38032 Reported-by: starlight <starlight@binnacle.cx> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05net: vlan: enable soft features regardless of underlying deviceShan Wei
If gso/gro feature of underlying device is turned off, then new created vlan device never can turn gso/gro on. Although underlying device don't support TSO, we still should use software segments for vlan device. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05bridge: Always flood broadcast packetsHerbert Xu
As is_multicast_ether_addr returns true on broadcast packets as well, we need to explicitly exclude broadcast packets so that they're always flooded. This wasn't an issue before as broadcast packets were considered to be an unregistered multicast group, which were always flooded. However, as we now only flood such packets to router ports, this is no longer acceptable. Reported-by: Michael Guntsche <mike@it-loops.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: fix sync and dio writes across stripe boundaries libceph: fix page calculation for non-page-aligned io ceph: fix page alignment corrections
2011-07-04net: bind() fix error return on wrong address familyMarcus Meissner
Hi, Reinhard Max also pointed out that the error should EAFNOSUPPORT according to POSIX. The Linux manpages have it as EINVAL, some other OSes (Minix, HPUX, perhaps BSD) use EAFNOSUPPORT. Windows uses WSAEFAULT according to MSDN. Other protocols error values in their af bind() methods in current mainline git as far as a brief look shows: EAFNOSUPPORT: atm, appletalk, l2tp, llc, phonet, rxrpc EINVAL: ax25, bluetooth, decnet, econet, ieee802154, iucv, netlink, netrom, packet, rds, rose, unix, x25, No check?: can/raw, ipv6/raw, irda, l2tp/l2tp_ip Ciao, Marcus Signed-off-by: Marcus Meissner <meissner@suse.de> Cc: Reinhard Max <max@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01xfrm4: Don't call icmp_send on local errorSteffen Klassert
Calling icmp_send() on a local message size error leads to an incorrect update of the path mtu. So use ip_local_error() instead to notify the socket about the error. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01ipv4: Don't use ufo handling on later transformed packetsSteffen Klassert
We might call ip_ufo_append_data() for packets that will be IPsec transformed later. This function should be used just for real udp packets. So we check for rt->dst.header_len which is only nonzero on IPsec handling and call ip_ufo_append_data() just if rt->dst.header_len is zero. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01xfrm: Remove family arg from xfrm_bundle_okSteffen Klassert
The family arg is not used any more, so remove it. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01ipv6: Don't put artificial limit on routing table size.David S. Miller
IPV6, unlike IPV4, doesn't have a routing cache. Routing table entries, as well as clones made in response to route lookup requests, all live in the same table. And all of these things are together collected in the destination cache table for ipv6. This means that routing table entries count against the garbage collection limits, even though such entries cannot ever be reclaimed and are added explicitly by the administrator (rather than being created in response to lookups). Therefore it makes no sense to count ipv6 routing table entries against the GC limits. Add a DST_NOCOUNT destination cache entry flag, and skip the counting if it is set. Use this flag bit in ipv6 when adding routing table entries. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01ipv6: Don't change dst->flags using assignments.David S. Miller
This blows away any flags already set in the entry. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01Merge branch 'for-davem' of ↵David S. Miller
2011-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits) usbnet: Remove over-broad module alias from zaurus. MAINTAINERS: drop Michael from bfin_mac driver net/can: activate bit-timing calculation and netlink based drivers by default rionet: fix NULL pointer dereference in rionet_remove net+crypto: Use vmalloc for zlib inflate buffers. netfilter: Fix ip_route_me_harder triggering ip_rt_bug ipv4: Fix IPsec slowpath fragmentation problem ipv4: Fix packet size calculation in __ip_append_data cxgb3: skb_record_rx_queue now records the queue index relative to the net_device. bridge: Only flood unregistered groups to routers qlge: Add maintainer. MAINTAINERS: mark socketcan-core lists as subscribers-only MAINTAINERS: Remove Sven Eckelmann from BATMAN ADVANCED r8169: fix wrong register use. net/usb/kalmia: signedness bug in kalmia_bind() net/usb: kalmia: Various fixes for better support of non-x86 architectures. rtl8192cu: Fix missing firmware load udp/recvmsg: Clear MSG_TRUNC flag when starting over for a new packet ipv6/udp: Use the correct variable to determine non-blocking condition netconsole: fix build when CONFIG_NETCONSOLE_DYNAMIC is turned on ...
2011-06-30Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into for-davem
2011-06-29netfilter: Fix ip_route_me_harder triggering ip_rt_bugJulian Anastasov
Avoid creating input routes with ip_route_me_harder. It does not work for locally generated packets. Instead, restrict sockets to provide valid saddr for output route (or unicast saddr for transparent proxy). For other traffic allow saddr to be unicast or local but if callers forget to check saddr type use 0 for the output route. The resulting handling should be: - REJECT TCP: - in INPUT we can provide addr_type = RTN_LOCAL but better allow rejecting traffic delivered with local route (no IP address => use RTN_UNSPEC to allow also RTN_UNICAST). - FORWARD: RTN_UNSPEC => allow RTN_LOCAL/RTN_UNICAST saddr, add fix to ignore RTN_BROADCAST and RTN_MULTICAST - OUTPUT: RTN_UNSPEC - NAT, mangle, ip_queue, nf_ip_reroute: RTN_UNSPEC in LOCAL_OUT - IPVS: - use RTN_LOCAL in LOCAL_OUT and FORWARD after SNAT to restrict saddr to be local Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-27ipv4: Fix IPsec slowpath fragmentation problemSteffen Klassert
ip_append_data() builds packets based on the mtu from dst_mtu(rt->dst.path). On IPsec the effective mtu is lower because we need to add the protocol headers and trailers later when we do the IPsec transformations. So after the IPsec transformations the packet might be too big, which leads to a slowpath fragmentation then. This patch fixes this by building the packets based on the lower IPsec mtu from dst_mtu(&rt->dst) and adapts the exthdr handling to this. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-27ipv4: Fix packet size calculation in __ip_append_dataSteffen Klassert
Git commit 59104f06 (ip: take care of last fragment in ip_append_data) added a check to see if we exceed the mtu when we add trailer_len. However, the mtu is already subtracted by the trailer length when the xfrm transfomation bundles are set up. So IPsec packets with mtu size get fragmented, or if the DF bit is set the packets will not be send even though they match the mtu perfectly fine. This patch actually reverts commit 59104f06. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-27mac80211: fix rx->key NULL dereference during mic failureArik Nemtsov
Sometimes when reporting a MIC failure rx->key may be unset. This code path is hit when receiving a packet meant for a multicast address, and decryption is performed in HW. Fortunately, the failing key_idx is not used for anything up to (and including) usermode, so we allow ourselves to drop it on the way up when a key cannot be retrieved. Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-24bridge: Only flood unregistered groups to routersHerbert Xu
The bridge currently floods packets to groups that we have never seen before to all ports. This is not required by RFC4541 and in fact it is not desirable in environment where traffic to unregistered group is always present. This patch changes the behaviour so that we only send traffic to unregistered groups to ports marked as routers. The user can always force flooding behaviour to any given port by marking it as a router. Note that this change does not apply to traffic to 224.0.0.X as traffic to those groups must always be flooded to all ports. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-24Merge branch 'master' of ↵John W. Linville
2011-06-21udp/recvmsg: Clear MSG_TRUNC flag when starting over for a new packetXufeng Zhang
Consider this scenario: When the size of the first received udp packet is bigger than the receive buffer, MSG_TRUNC bit is set in msg->msg_flags. However, if checksum error happens and this is a blocking socket, it will goto try_again loop to receive the next packet. But if the size of the next udp packet is smaller than receive buffer, MSG_TRUNC flag should not be set, but because MSG_TRUNC bit is not cleared in msg->msg_flags before receive the next packet, MSG_TRUNC is still set, which is wrong. Fix this problem by clearing MSG_TRUNC flag when starting over for a new packet. Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21ipv6/udp: Use the correct variable to determine non-blocking conditionXufeng Zhang
udpv6_recvmsg() function is not using the correct variable to determine whether or not the socket is in non-blocking operation, this will lead to unexpected behavior when a UDP checksum error occurs. Consider a non-blocking udp receive scenario: when udpv6_recvmsg() is called by sock_common_recvmsg(), MSG_DONTWAIT bit of flags variable in udpv6_recvmsg() is cleared by "flags & ~MSG_DONTWAIT" in this call: err = sk->sk_prot->recvmsg(iocb, sk, msg, size, flags & MSG_DONTWAIT, flags & ~MSG_DONTWAIT, &addr_len); i.e. with udpv6_recvmsg() getting these values: int noblock = flags & MSG_DONTWAIT int flags = flags & ~MSG_DONTWAIT So, when udp checksum error occurs, the execution will go to csum_copy_err, and then the problem happens: csum_copy_err: ............... if (flags & MSG_DONTWAIT) return -EAGAIN; goto try_again; ............... But it will always go to try_again as MSG_DONTWAIT has been cleared from flags at call time -- only noblock contains the original value of MSG_DONTWAIT, so the test should be: if (noblock) return -EAGAIN; This is also consistent with what the ipv4/udp code does. Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Fix decode_secinfo_maxsz NFSv4.1: Fix an off-by-one error in pnfs_generic_pg_test NFSv4.1: Fix some issues with pnfs_generic_pg_test NFSv4.1: file layout must consider pg_bsize for coalescing pnfs-obj: No longer needed to take an extra ref at add_device SUNRPC: Ensure the RPC client only quits on fatal signals NFSv4: Fix a readdir regression nfs4.1: mark layout as bad on error path in _pnfs_return_layout nfs4.1: prevent race that allowed use of freed layout in _pnfs_return_layout NFSv4.1: need to put_layout_hdr on _pnfs_return_layout error path NFS: (d)printks should use %zd for ssize_t arguments NFSv4.1: fix break condition in pnfs_find_lseg nfs4.1: fix several problems with _pnfs_return_layout NFSv4.1: allow zero fh array in filelayout decode layout NFSv4.1: allow nfs_fhget to succeed with mounted on fileid NFSv4.1: Fix a refcounting issue in the pNFS device id cache NFSv4.1: deprecate headerpadsz in CREATE_SESSION NFS41: do not update isize if inode needs layoutcommit NLM: Don't hang forever on NLM unlock requests NFS: fix umount of pnfs filesystems
2011-06-20Merge branch 'for-2.6.40' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.40' of git://linux-nfs.org/~bfields/linux: nfsd4: fix break_lease flags on nfsd open nfsd: link returns nfserr_delay when breaking lease nfsd: v4 support requires CRYPTO nfsd: fix dependency of nfsd on auth_rpcgss
2011-06-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) pxa168_eth: fix race in transmit path. ipv4, ping: Remove duplicate icmp.h include netxen: fix race in skb->len access sgi-xp: fix a use after free hp100: fix an skb->len race netpoll: copy dev name of slaves to struct netpoll ipv4: fix multicast losses r8169: fix static initializers. inet_diag: fix inet_diag_bc_audit() gigaset: call module_put before restart of if_open() farsync: add module_put to error path in fst_open() net: rfs: enable RFS before first data packet is received fs_enet: fix freescale FCC ethernet dp buffer alignment netdev: bfin_mac: fix memory leak when freeing dma descriptors vlan: don't call ndo_vlan_rx_register on hardware that doesn't have vlan support caif: Bugfix - XOFF removed channel from caif-mux tun: teach the tun/tap driver to support netpoll dp83640: drop PHY status frames in the driver. dp83640: fix phy status frame event parsing phylib: Allow BCM63XX PHY to be selected only on BCM63XX. ...
2011-06-20ipv4, ping: Remove duplicate icmp.h includeJesper Juhl
Remove the duplicate inclusion of net/icmp.h from net/ipv4/ping.c Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20Merge branch 'master' of ↵John W. Linville
master.kernel.org:/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
2011-06-19netpoll: copy dev name of slaves to struct netpollWANG Cong
Otherwise we will not see the name of the slave dev in error message: [ 388.469446] (null): doesn't support polling, aborting. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-18ipv4: fix multicast lossesEric Dumazet
Knut Tidemann found that first packet of a multicast flow was not correctly received, and bisected the regression to commit b23dd4fe42b4 (Make output route lookup return rtable directly.) Special thanks to Knut, who provided a very nice bug report, including sample programs to demonstrate the bug. Reported-and-bisectedby: Knut Tidemann <knut.andre.tidemann@jotron.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-17inet_diag: fix inet_diag_bc_audit()Eric Dumazet
A malicious user or buggy application can inject code and trigger an infinite loop in inet_diag_bc_audit() Also make sure each instruction is aligned on 4 bytes boundary, to avoid unaligned accesses. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-17net: rfs: enable RFS before first data packet is receivedEric Dumazet
Le jeudi 16 juin 2011 à 23:38 -0400, David Miller a écrit : > From: Ben Hutchings <bhutchings@solarflare.com> > Date: Fri, 17 Jun 2011 00:50:46 +0100 > > > On Wed, 2011-06-15 at 04:15 +0200, Eric Dumazet wrote: > >> @@ -1594,6 +1594,7 @@ int tcp_v4_do_rcv(struct sock *sk, struct sk_buff *skb) > >> goto discard; > >> > >> if (nsk != sk) { > >> + sock_rps_save_rxhash(nsk, skb->rxhash); > >> if (tcp_child_process(sk, nsk, skb)) { > >> rsk = nsk; > >> goto reset; > >> > > > > I haven't tried this, but it looks reasonable to me. > > > > What about IPv6? The logic in tcp_v6_do_rcv() looks very similar. > > Indeed ipv6 side needs the same fix. > > Eric please add that part and resubmit. And in fact I might stick > this into net-2.6 instead of net-next-2.6 > OK, here is the net-2.6 based one then, thanks ! [PATCH v2] net: rfs: enable RFS before first data packet is received First packet received on a passive tcp flow is not correctly RFS steered. One sock_rps_record_flow() call is missing in inet_accept() But before that, we also must record rxhash when child socket is setup. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Tom Herbert <therbert@google.com> CC: Ben Hutchings <bhutchings@solarflare.com> CC: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-17Merge branch 'master' of ↵John W. Linville
2011-06-17SUNRPC: Ensure the RPC client only quits on fatal signalsTrond Myklebust
Fix a couple of instances where we were exiting the RPC client on arbitrary signals. We should only do so on fatal signals. Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-06-17vlan: don't call ndo_vlan_rx_register on hardware that doesn't have vlan supportAntoine Reversat
This patch removes the call to ndo_vlan_rx_register if the underlying device doesn't have hardware support for VLAN. Signed-off-by: Antoine Reversat <a.reversat@gmail.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-16caif: Bugfix - XOFF removed channel from caif-muxsjur.brandeland@stericsson.com
XOFF was mixed up with DOWN indication, causing causing CAIF channel to be removed from mux and all incoming traffic to be lost after receiving flow-off. Fix this by replacing FLOW_OFF with DOWN notification. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-16IGMP snooping: set mrouters_only flag for IPv6 traffic properlyFernando Luis Vázquez Cao
Upon reception of a MGM report packet the kernel sets the mrouters_only flag in a skb that is a clone of the original skb, which means that the bridge loses track of MGM packets (cb buffers are tied to a specific skb and not shared) and it ends up forwading join requests to the bridge interface. This can cause unexpected membership timeouts and intermitent/permanent loss of connectivity as described in RFC 4541 [2.1.1. IGMP Forwarding Rules]: A snooping switch should forward IGMP Membership Reports only to those ports where multicast routers are attached. [...] Sending membership reports to other hosts can result, for IGMPv1 and IGMPv2, in unintentionally preventing a host from joining a specific multicast group. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-16IGMP snooping: set mrouters_only flag for IPv4 traffic properlyFernando Luis Vázquez Cao
Upon reception of a IGMP/IGMPv2 membership report the kernel sets the mrouters_only flag in a skb that may be a clone of the original skb, which means that sometimes the bridge loses track of membership report packets (cb buffers are tied to a specific skb and not shared) and it ends up forwading join requests to the bridge interface. This can cause unexpected membership timeouts and intermitent/permanent loss of connectivity as described in RFC 4541 [2.1.1. IGMP Forwarding Rules]: A snooping switch should forward IGMP Membership Reports only to those ports where multicast routers are attached. [...] Sending membership reports to other hosts can result, for IGMPv1 and IGMPv2, in unintentionally preventing a host from joining a specific multicast group. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Tested-by: Hayato Kakuta <kakuta.hayato@oss.ntt.co.jp> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-16Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2011-06-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: AFS: Use i_generation not i_version for the vnode uniquifier AFS: Set s_id in the superblock to the volume name vfs: Fix data corruption after failed write in __block_write_begin() afs: afs_fill_page reads too much, or wrong data VFS: Fix vfsmount overput on simultaneous automount fix wrong iput on d_inode introduced by e6bc45d65d Delay struct net freeing while there's a sysfs instance refering to it afs: fix sget() races, close leak on umount ubifs: fix sget races ubifs: split allocation of ubifs_info into a separate function fix leak in proc_set_super()
2011-06-16netfilter: nf_nat: avoid double seq_adjust for loopbackJulian Anastasov
Avoid double seq adjustment for loopback traffic because it causes silent repetition of TCP data. One example is passive FTP with DNAT rule and difference in the length of IP addresses. This patch adds check if packet is sent and received via loopback device. As the same conntrack is used both for outgoing and incoming direction, we restrict seq adjustment to happen only in POSTROUTING. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-06-16netfilter: fix looped (broad|multi)cast's MAC handlingNicolas Cavallari
By default, when broadcast or multicast packet are sent from a local application, they are sent to the interface then looped by the kernel to other local applications, going throught netfilter hooks in the process. These looped packet have their MAC header removed from the skb by the kernel looping code. This confuse various netfilter's netlink queue, netlink log and the legacy ip_queue, because they try to extract a hardware address from these packets, but extracts a part of the IP header instead. This patch prevent NFQUEUE, NFLOG and ip_QUEUE to include a MAC header if there is none in the packet. Signed-off-by: Nicolas Cavallari <cavallar@lri.fr> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-06-16netfilter: ipt_ecn: fix inversion for IP header ECN matchPatrick McHardy
Userspace allows to specify inversion for IP header ECN matches, the kernel silently accepts it, but doesn't invert the match result. Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-06-16netfilter: ipt_ecn: fix protocol check in ecn_mt_check()Patrick McHardy
Check for protocol inversion in ecn_mt_check() and remove the unnecessary runtime check for IPPROTO_TCP in ecn_mt(). Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-06-16netfilter: ip_tables: fix compile with debugSebastian Andrzej Siewior
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-06-16Merge branch 'master' of ↵Patrick McHardy
git://git.kernel.org/pub/scm/linux/kernel/git/horms/ipvs-2.6
2011-06-15Bluetooth: Fix L2CAP connection establishmentIlia Kolomisnky
In hci_conn_security ( which is used during L2CAP connection establishment ) test for HCI_CONN_ENCRYPT_PEND state also sets this state, which is bogus and leads to connection time-out on L2CAP sockets in certain situations (especially when using non-ssp devices ) Signed-off-by: Ilia Kolomisnky <iliak@ti.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-06-15NLM: Don't hang forever on NLM unlock requestsTrond Myklebust
If the NLM daemon is killed on the NFS server, we can currently end up hanging forever on an 'unlock' request, instead of aborting. Basically, if the rpcbind request fails, or the server keeps returning garbage, we really want to quit instead of retrying. Tested-by: Vasily Averin <vvs@sw.ru> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2011-06-14Bluetooth: Fix accepting connect requests for defer_setupJohan Hedberg
When authentication completes we shouldn't blindly accept any pending L2CAP connect requests. If the socket has the defer_setup feature enabled it should still wait for user space acceptance of the connect request. The issue only happens for non-SSP connections since with SSP the L2CAP Connect request may not be sent for non-SDP PSMs before authentication has completed successfully. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-06-13libceph: fix page calculation for non-page-aligned ioSage Weil
Set the page count correctly for non-page-aligned IO. We were already doing this correctly for alignment, but not the page count. Fixes DIRECT_IO writes from unaligned pages. Signed-off-by: Sage Weil <sage@newdream.net>
