path: root/samples/firmware_class
2008-07-21Firmware: fix typo in example codeGreg Kroah-Hartman
It's not like this stuff even builds right now, but this will make Randy's scripts happy :) Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits) DOC: A couple corrections and clarifications in USB doc. Generate a slightly more informative error msg for bad HZ fix typo "is" -> "if" in Makefile ext*: spelling fix prefered -> preferred DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs. KEYS: Fix the comment to match the file name in rxrpc-type.h. RAID: remove trailing space from printk line DMA engine: typo fixes Remove unused MAX_NODES_SHIFT MAINTAINERS: Clarify access to OCFS2 development mailing list. V4L: Storage class should be before const qualifier (sn9c102) V4L: Storage class should be before const qualifier sonypi: Storage class should be before const qualifier intel_menlow: Storage class should be before const qualifier DVB: Storage class should be before const qualifier arm: Storage class should be before const qualifier ALSA: Storage class should be before const qualifier acpi: Storage class should be before const qualifier firmware_sample_driver.c: fix coding style MAINTAINERS: Add ati_remote2 driver ... Fixed up trivial conflicts in firmware_sample_driver.c
2008-04-19firmware: clean up samples for coding style issuesGreg Kroah-Hartman
This fixes up a number of coding style issues in the firmware sample files. Yeah, it still doesn't build properly yet, that's next... Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19firmware: move firmware_class from Documentation/ to samples/Randy Dunlap
Move the firmware_class sample drivers to samples/ so that they are buildable and can be maintained. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
