path: root/samples/hw_breakpoint
2010-02-27percpu: Add __percpu sparse annotations to hw_breakpointTejun Heo
Add __percpu sparse annotations to hw_breakpoint. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. In kernel/hw_breakpoint.c, per_cpu(nr_task_bp_pinned, cpu)'s will trigger spurious noderef related warnings from sparse. Changing it to &per_cpu(nr_task_bp_pinned[0], cpu) will work around the problem but deemed to ugly by the maintainer. Leave it alone until better solution can be found. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: K.Prasad <prasad@linux.vnet.ibm.com> LKML-Reference: <4B7B4B7A.9050902@kernel.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-12-06hw-breakpoints: Use overflow handler instead of the event callbackFrederic Weisbecker
struct perf_event::event callback was called when a breakpoint triggers. But this is a rather opaque callback, pretty tied-only to the breakpoint API and not really integrated into perf as it triggers even when we don't overflow. We prefer to use overflow_handler() as it fits into the perf events rules, being called only when we overflow. Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "K. Prasad" <prasad@linux.vnet.ibm.com>
2009-11-27hw-breakpoints: Use struct perf_event_attr to define kernel breakpointsFrederic Weisbecker
Kernel breakpoints are created using functions in which we pass breakpoint parameters as individual variables: address, length and type. Although it fits well for x86, this just does not scale across architectures that may support this api later as these may have more or different needs. Pass in a perf_event_attr structure instead because it is meant to evolve as much as possible into a generic hardware breakpoint parameter structure. Reported-by: K.Prasad <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1259294154-5197-2-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-26hw-breakpoints: Simplify error handling in breakpoint creation requestsFrederic Weisbecker
This simplifies the error handling when we create a breakpoint. We don't need to check the NULL return value corner case anymore since we have improved perf_event_create_kernel_counter() to always return an error code in the failure case. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Prasad <prasad@linux.vnet.ibm.com> LKML-Reference: <1259210142-5714-3-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-23hw-breakpoint: Attribute authorship of hw-breakpoint related filesK.Prasad
Attribute authorship to developers of hw-breakpoint related files. Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091123154713.GA5593@in.ibm.com> [ v2: moved it to latest -tip ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10hw-breakpoints: Fix broken hw-breakpoint sample moduleFrederic Weisbecker
The hw-breakpoint sample module has been broken during the hw-breakpoint internals refactoring. Propagate the changes to it. Reported-by: "K. Prasad" <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-06-02hw-breakpoints: sample HW breakpoint over kernel data addressK.Prasad
This patch introduces a sample kernel module to demonstrate the use of Hardware Breakpoint feature. It places a breakpoint over the kernel variable 'pid_max' to monitor all write operations and emits a function-backtrace when done. Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
