path: root/samples
2009-11-09Kconfig: Remove useless and sometimes wrong commentsMichael Roth
Additionally, some excessive newlines removed. Signed-off-by: Michael Roth <mroth@nessie.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-18tracing: Remove markersChristoph Hellwig
Now that the last users of markers have migrated to the event tracer we can kill off the (now orphan) support code. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090917173527.GA1699@lst.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-15debugfs: Change debuhgfs directory of trace-events-sample.hGeunSik Lim
Default directory of debug filesystem for ftrace is /sys/kernel/debug/. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-16sparc64: cheaper asm/uaccess.h inclusionAlexey Dobriyan
sched.h inclusion is definitely not needed like in 32-bit version, remove it, fixup compilation. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-13tracing/events: Move TRACE_SYSTEM outside of include guardLi Zefan
If TRACE_INCLDUE_FILE is defined, <trace/events/TRACE_INCLUDE_FILE.h> will be included and compiled, otherwise it will be <trace/events/TRACE_SYSTEM.h> So TRACE_SYSTEM should be defined outside of #if proctection, just like TRACE_INCLUDE_FILE. Imaging this scenario: #include <trace/events/foo.h> -> TRACE_SYSTEM == foo ... #include <trace/events/bar.h> -> TRACE_SYSTEM == bar ... #define CREATE_TRACE_POINTS #include <trace/events/foo.h> -> TRACE_SYSTEM == bar !!! and then bar.h will be included and compiled. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A5A9CF1.2010007@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-20Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) tracing/urgent: warn in case of ftrace_start_up inbalance tracing/urgent: fix unbalanced ftrace_start_up function-graph: add stack frame test function-graph: disable when both x86_32 and optimize for size are configured ring-buffer: have benchmark test print to trace buffer ring-buffer: do not grab locks in nmi ring-buffer: add locks around rb_per_cpu_empty ring-buffer: check for less than two in size allocation ring-buffer: remove useless compile check for buffer_page size ring-buffer: remove useless warn on check ring-buffer: use BUF_PAGE_HDR_SIZE in calculating index tracing: update sample event documentation tracing/filters: fix race between filter setting and module unload tracing/filters: free filter_string in destroy_preds() ring-buffer: use commit counters for commit pointer accounting ring-buffer: remove unused variable ring-buffer: have benchmark test handle discarded events ring-buffer: prevent adding write in discarded area tracing/filters: strloc should be unsigned short tracing/filters: operand can be negative ... Fix up kmemcheck-induced conflict in kernel/trace/ring_buffer.c manually
2009-06-16tracing: update sample event documentationSteven Rostedt
The comments in the sample code is a bit confusing. This patch cleans them up a little. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-06-15firmware: remove broken example filesGreg Kroah-Hartman
The firmware example files are beyond broken, and will not work, and should not be used as an example at all. So lets remove them and hope someone writes new files sometime in the future. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15kobject: samples: make SAMPLE_KOBJECT module-onlyMichal Marek
With SAMPLE_KOBJECT=y, it isn't even linked into the kernel image. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-06tracing: update sample with TRACE_INCLUDE_FILESteven Rostedt
When creating trace events for ftrace, the header file with the TRACE_EVENT macros must also have a macro called TRACE_SYSTEM. This macro describes the name of the system the TRACE_EVENTS are defined for. It also doubles as a way for the define_trace.h file to include the file that included it. For example: in irq.h #define TRACE_SYSTEM irq [...] #include <trace/define_trace.h> The define_trace will use TRACE_SYSTEM to include irq.h. But if the name of the trace system does not match the name of the trace header file, one can override it with: Which will change define_trace.h to inclued foo_trace.h instead of foo.h The sample comments this, but people that use the sample code will more likely use the code and not read the comments. This patch changes the sample code to use the TRACE_INCLUDE_FILE to better show developers how to use it. [ Impact: make sample less confusing to developers ] Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-06tracing: small trave_events sample Makefile cleanupChristoph Hellwig
Use -I$(src) to add the current directory the include path. [ Impact: cleanup ] Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-06tracing/events: make SAMPLE_TRACE_EVENTS default to nLi Zefan
Normally a config should be default to n. This patch also makes the sample module-only, like SAMPLE_MARKERS and SAMPLE_TRACEPOINTS. [ Impact: don't build trace event sample by default ] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A00F6C0.8090803@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-06tracing/events: don't say hi when loading the trace event sampleLi Zefan
The sample is useful for testing, and I'm using it. But after loading the module, it keeps saying hi every 10 seconds, this may be disturbing. Also Steven said commenting out the "hi" helped in causing races. :) [ Impact: make testing a bit easier ] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A00F6AD.2070008@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/events: add trace-events-sampleSteven Rostedt
This patch adds a sample to the samples directory on how to create and use TRACE_EVENT trace points. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-03-24tracing: Documentation / sample code fixes for tracepointsJody McIntyre
Fix the tracepoint documentation to refer to "tracepoint-sample" instead of "tracepoint-example" to match what actually exists; fix the directory, and clarify how to compile. Change every instance of "example" in the sample tracepoint code to "sample" for consistency. Signed-off-by: Jody McIntyre <scjody@sun.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: torvalds@linux-foundation.org LKML-Reference: <20090324200027.GH8294@clouds> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-10tracing: replace TP<var> with TP_<var>Steven Rostedt
Impact: clean up The macros TPPROTO, TPARGS, TPFMT, TPRAWFMT, and TPCMD all look a bit ugly. This patch adds an underscore to their names. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-01-06samples: mark {static|__init|__exit} for {init|exit} functionsQinghuang Feng
None of these (init|exit) functions is called from other functions which is outside the kernel module mechanism or kernel itself, so mark them as {static|__init|__exit}. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-16tracepoints: add DECLARE_TRACE() and DEFINE_TRACE()Mathieu Desnoyers
Impact: API *CHANGE*. Must update all tracepoint users. Add DEFINE_TRACE() to tracepoints to let them declare the tracepoint structure in a single spot for all the kernel. It helps reducing memory consumption, especially when declaring a lot of tracepoints, e.g. for kmalloc tracing. *API CHANGE WARNING*: now, DECLARE_TRACE() must be used in headers for tracepoint declarations rather than DEFINE_TRACE(). This is the sane way to do it. The name previously used was misleading. Updates scheduler instrumentation to follow this API change. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16tracepoints: samples, fix teardownMathieu Desnoyers
Impact: fix a bug in sample tracepoints Need a tracepoint_synchronize_unregister() before the end of exit() to make sure every probe callers have exited the non preemptible section and thus are not executing the probe code anymore. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14markers: probe example, fix teardownMathieu Desnoyers
Need a marker_synchronize_unregister() before the end of exit() to make sure every probe callers have exited the non preemptible section and thus are not executing the probe code anymore. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracing: tracepoints, samplesMathieu Desnoyers
Tracepoint example code under samples/. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: 'Peter Zijlstra' <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-21kobject: should use kobject_put() in kset-exampleLi Zefan
We should call kobject_put() instead of kfree() if kobject_init_and_add() returns an error, shouldn't we? Don't set up a bad example ;) Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21Firmware: fix typo in example codeGreg Kroah-Hartman
It's not like this stuff even builds right now, but this will make Randy's scripts happy :) Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-29samples: use non-racy method for /proc/marker-example creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits) DOC: A couple corrections and clarifications in USB doc. Generate a slightly more informative error msg for bad HZ fix typo "is" -> "if" in Makefile ext*: spelling fix prefered -> preferred DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs. KEYS: Fix the comment to match the file name in rxrpc-type.h. RAID: remove trailing space from printk line DMA engine: typo fixes Remove unused MAX_NODES_SHIFT MAINTAINERS: Clarify access to OCFS2 development mailing list. V4L: Storage class should be before const qualifier (sn9c102) V4L: Storage class should be before const qualifier sonypi: Storage class should be before const qualifier intel_menlow: Storage class should be before const qualifier DVB: Storage class should be before const qualifier arm: Storage class should be before const qualifier ALSA: Storage class should be before const qualifier acpi: Storage class should be before const qualifier firmware_sample_driver.c: fix coding style MAINTAINERS: Add ati_remote2 driver ... Fixed up trivial conflicts in firmware_sample_driver.c
2008-04-19firmware: clean up samples for coding style issuesGreg Kroah-Hartman
This fixes up a number of coding style issues in the firmware sample files. Yeah, it still doesn't build properly yet, that's next... Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19firmware: move firmware_class from Documentation/ to samples/Randy Dunlap
Move the firmware_class sample drivers to samples/ so that they are buildable and can be maintained. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04Kprobes: move kprobe examples to samples/Ananth N Mavinakayanahalli
Move kprobes examples from Documentation/kprobes.txt to under samples/. Patch originally by Randy Dunlap. o Updated the patch to apply on 2.6.25-rc3 o Modified examples code to build on multiple architectures. Currently, the kprobe and jprobe examples code works for x86 and powerpc o Cleaned up unneeded #includes o Cleaned up Kconfig per Sam Ravnborg's suggestions to fix build break on archs that don't have kretprobes o Implemented suggestions by Mathieu Desnoyers on CONFIG_KRETPROBES o Included Andrew Morton's cleanup based on x86-git o Modified kretprobe_example to act as a arch-agnostic module to determine routine execution times: Use 'modprobe kretprobe_example func=<func_name>' to determine execution time of func_name in nanoseconds. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Linux Kernel Markers: support multiple probesMathieu Desnoyers
RCU style multiple probes support for the Linux Kernel Markers. Common case (one probe) is still fast and does not require dynamic allocation or a supplementary pointer dereference on the fast path. - Move preempt disable from the marker site to the callback. Since we now have an internal callback, move the preempt disable/enable to the callback instead of the marker site. Since the callback change is done asynchronously (passing from a handler that supports arguments to a handler that does not setup the arguments is no arguments are passed), we can safely update it even if it is outside the preempt disable section. - Move probe arm to probe connection. Now, a connected probe is automatically armed. Remove MARK_MAX_FORMAT_LEN, unused. This patch modifies the Linux Kernel Markers API : it removes the probe "arm/disarm" and changes the probe function prototype : it now expects a va_list * instead of a "...". If we want to have more than one probe connected to a marker at a given time (LTTng, or blktrace, ssytemtap) then we need this patch. Without it, connecting a second probe handler to a marker will fail. It allow us, for instance, to do interesting combinations : Do standard tracing with LTTng and, eventually, to compute statistics with SystemTAP, or to have a special trigger on an event that would call a systemtap script which would stop flight recorder tracing. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Christoph Hellwig <hch@infradead.org> Cc: Mike Mason <mmlnx@us.ibm.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: David Smith <dsmith@redhat.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24kobject: add sample code for how to use ksets/ktypes/kobjectsGreg Kroah-Hartman
This is a more complex example showing how to create a kset and a ktype and some default attributes for a group of kobjects. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: add sample code for how to use kobjects in a simple manner.Greg Kroah-Hartman
This is a simple kobject module, showing how to use kobj_attributes in basic and more complex ways. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-14Linux Kernel Markers: fix samples to follow format string standardMathieu Desnoyers
Add the field names to marker example format string. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Linux Kernel Markers - SamplesMathieu Desnoyers
Module example showing how to use the Linux Kernel Markers. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19markers: Add samples subdirMathieu Desnoyers
Begin infrastructure for kernel code samples in the samples/ directory. Add its Kconfig and Kbuild files. Source its Kconfig file in all arch/ Kconfigs. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
