This is the 4.19.23 stable release
commit c4a46acf1db3ce547d290c29e55b3476c78dd76c upstream.
The device was moved from misc device to character devices
to support multiple mei devices.
Cc: <stable@vger.kernel.org> #v4.9+
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
[ Upstream commit 5f30b2e823484ce6a79f2b59901b6351c15effa6 ]
kzalloc() return should always be checked - notably in example code
where this may be seen as reference. On failure of allocation in
livepatch_fix1_dummy_alloc() respectively dummy_alloc() previous
allocation is freed (thanks to Petr Mladek <pmladek@suse.com> for
catching this) and NULL returned.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Fixes: 439e7271dc2b ("livepatch: introduce shadow variable API")
Acked-by: Joe Lawrence <joe.lawrence@redhat.com>
Reviewed-by: Petr Mladek <pmladek@suse.com>
Acked-by: Miroslav Benes <mbenes@suse.cz>
[ Upstream commit 5a863813216ce79e16a8c1503b2543c528b778b6 ]
Currently, kprobe_events failure won't be handled properly.
Due to calling system() indirectly to write to kprobe_events,
it can't be identified whether an error is derived from kprobe or system.
// buf = "echo '%c:%s %s' >> /s/k/d/t/kprobe_events"
err = system(buf);
if (err < 0) {
printf("failed to create kprobe ..");
return -1;
For example, running ./tracex7 sample in ext4 partition,
"echo p:open_ctree open_ctree >> /s/k/d/t/kprobe_events"
gets 256 error code system() failure.
=> The error comes from kprobe, but it's not handled correctly.
According to man of system(3), it's return value
just passes the termination status of the child shell
rather than treating the error as -1. (don't care success)
Which means, currently it's not working as desired.
(According to the upper code snippet)
ex) running ./tracex7 with ext4 env.
# Current Output
sh: echo: I/O error
failed to open event open_ctree
# Desired Output
failed to create kprobe 'open_ctree' error 'No such file or directory'
The problem is, error can't be verified whether from child ps
or system. But using write() directly can verify the command
failure, and it will treat all error as -1. So I suggest using
write() directly to 'kprobe_events' rather than calling system().
Signed-off-by: Daniel T. Lee <danieltimlee@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
In commit 4b53a3412d66 ("sched/core: Remove the tsk_nr_cpus_allowed()
wrapper") the tsk_nr_cpus_allowed() wrapper was removed. There was not
much difference in !RT but in RT we used this to implement
migrate_disable(). Within a migrate_disable() section the CPU mask is
restricted to single CPU while the "normal" CPU mask remains untouched.
As an alternative implementation Ingo suggested to use
struct task_struct {
const cpumask_t *cpus_ptr;
cpumask_t cpus_mask;
with
t->cpus_allowed_ptr = &t->cpus_allowed;
In -RT we then can switch the cpus_ptr to
t->cpus_allowed_ptr = &cpumask_of(task_cpu(p));
in a migration disabled region. The rules are simple:
- Code that 'uses' ->cpus_allowed would use the pointer.
- Code that 'modifies' ->cpus_allowed would use the direct mask.
While converting the existing users I tried to stick with the rules
above however… well mostly CPUFREQ tries to temporary switch the CPU
mask to do something on a certain CPU and then switches the mask back it
its original value. So in theory `cpus_ptr' could or should be used.
However if this is invoked in a migration disabled region (which is not
the case because it would require something like preempt_disable() and
set_cpus_allowed_ptr() might sleep so it can't be) then the "restore"
part would restore the wrong mask. So it only looks strange and I go for
the pointer…
Some drivers copy the cpumask without cpumask_copy() and others use
cpumask_copy but without alloc_cpumask_var(). I did not fix those as
part of this, could do this as a follow up…
So is this the way we want it?
Is the usage of `cpus_ptr' vs `cpus_mask' for the set + restore part
(see cpufreq users) what we want? At some point it looks like they
should use a different interface for their doing. I am not sure why
switching to certain CPU is important but maybe it could be done via a
workqueue from the CPUFREQ core (so we have a comment desribing why are
doing this and a get_online_cpus() to ensure that the CPU does not go
offline too early).
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Some samples require headers installation, so commit 3fca1700c4c3
("kbuild: make samples really depend on headers_install") added
such dependency in the top Makefile. However, UML fails to build
with CONFIG_SAMPLES=y because UML does not support headers_install.
Fixes: 3fca1700c4c3 ("kbuild: make samples really depend on headers_install")
Reported-by: Kees Cook <keescook@chromium.org>
It is common XDP practice to unload/deattach the XDP bpf program,
when the XDP sample program is Ctrl-C interrupted (SIGINT) or
killed (SIGTERM).
The samples/bpf programs xdp_redirect_cpu and xdp_rxq_info,
forgot to trap signal SIGTERM (which is the default signal used
by the kill command).
This was discovered by Red Hat QA, which automated scripts depend
on killing the XDP sample program after a timeout period.
Fixes: fad3917e361b ("samples/bpf: add cpumap sample program xdp_redirect_cpu")
Fixes: 0fca931a6f21 ("samples/bpf: program demonstrating access to xdp_rxq_info")
Reported-by: Jean-Tsung Hsiao <jhsiao@redhat.com>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Yonghong Song <yhs@fb.com>
Pull networking updates from David Miller:
"Highlights:
- Gustavo A. R. Silva keeps working on the implicit switch fallthru
changes.
- Support 802.11ax High-Efficiency wireless in cfg80211 et al, From
Luca Coelho.
- Re-enable ASPM in r8169, from Kai-Heng Feng.
- Add virtual XFRM interfaces, which avoids all of the limitations of
existing IPSEC tunnels. From Steffen Klassert.
- Convert GRO over to use a hash table, so that when we have many
flows active we don't traverse a long list during accumluation.
- Many new self tests for routing, TC, tunnels, etc. Too many
contributors to mention them all, but I'm really happy to keep
seeing this stuff.
- Hardware timestamping support for dpaa_eth/fsl-fman from Yangbo Lu.
- Lots of cleanups and fixes in L2TP code from Guillaume Nault.
- Add IPSEC offload support to netdevsim, from Shannon Nelson.
- Add support for slotting with non-uniform distribution to netem
packet scheduler, from Yousuk Seung.
- Add UDP GSO support to mlx5e, from Boris Pismenny.
- Support offloading of Team LAG in NFP, from John Hurley.
- Allow to configure TX queue selection based upon RX queue, from
Amritha Nambiar.
- Support ethtool ring size configuration in aquantia, from Anton
Mikaev.
- Support DSCP and flowlabel per-transport in SCTP, from Xin Long.
- Support list based batching and stack traversal of SKBs, this is
very exciting work. From Edward Cree.
- Busyloop optimizations in vhost_net, from Toshiaki Makita.
- Introduce the ETF qdisc, which allows time based transmissions. IGB
can offload this in hardware. From Vinicius Costa Gomes.
- Add parameter support to devlink, from Moshe Shemesh.
- Several multiplication and division optimizations for BPF JIT in
nfp driver, from Jiong Wang.
- Lots of prepatory work to make more of the packet scheduler layer
lockless, when possible, from Vlad Buslov.
- Add ACK filter and NAT awareness to sch_cake packet scheduler, from
Toke Høiland-Jørgensen.
- Support regions and region snapshots in devlink, from Alex Vesker.
- Allow to attach XDP programs to both HW and SW at the same time on
a given device, with initial support in nfp. From Jakub Kicinski.
- Add TLS RX offload and support in mlx5, from Ilya Lesokhin.
- Use PHYLIB in r8169 driver, from Heiner Kallweit.
- All sorts of changes to support Spectrum 2 in mlxsw driver, from
Ido Schimmel.
- PTP support in mv88e6xxx DSA driver, from Andrew Lunn.
- Make TCP_USER_TIMEOUT socket option more accurate, from Jon
Maxwell.
- Support for templates in packet scheduler classifier, from Jiri
Pirko.
- IPV6 support in RDS, from Ka-Cheong Poon.
- Native tproxy support in nf_tables, from Máté Eckl.
- Maintain IP fragment queue in an rbtree, but optimize properly for
in-order frags. From Peter Oskolkov.
- Improvde handling of ACKs on hole repairs, from Yuchung Cheng"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1996 commits)
bpf: test: fix spelling mistake "REUSEEPORT" -> "REUSEPORT"
hv/netvsc: Fix NULL dereference at single queue mode fallback
net: filter: mark expected switch fall-through
xen-netfront: fix warn message as irq device name has '/'
cxgb4: Add new T5 PCI device ids 0x50af and 0x50b0
net: dsa: mv88e6xxx: missing unlock on error path
rds: fix building with IPV6=m
inet/connection_sock: prefer _THIS_IP_ to current_text_addr
net: dsa: mv88e6xxx: bitwise vs logical bug
net: sock_diag: Fix spectre v1 gadget in __sock_diag_cmd()
ieee802154: hwsim: using right kind of iteration
net: hns3: Add vlan filter setting by ethtool command -K
net: hns3: Set tx ring' tc info when netdev is up
net: hns3: Remove tx ring BD len register in hns3_enet
net: hns3: Fix desc num set to default when setting channel
net: hns3: Fix for phy link issue when using marvell phy driver
net: hns3: Fix for information of phydev lost problem when down/up
net: hns3: Fix for command format parsing error in hclge_is_all_function_id_zero
net: hns3: Add support for serdes loopback selftest
bnxt_en: take coredump_record structure off stack
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild updates from Masahiro Yamada:
- verify depmod is installed before modules_install
- support build salt in case build ids must be unique between builds
- allow users to specify additional host compiler flags via HOST*FLAGS,
and rename internal variables to KBUILD_HOST*FLAGS
- update buildtar script to drop vax support, add arm64 support
- update builddeb script for better debarch support
- document the pit-fall of if_changed usage
- fix parallel build of UML with O= option
- make 'samples' target depend on headers_install to fix build errors
- remove deprecated host-progs variable
- add a new coccinelle script for refcount_t vs atomic_t check
- improve double-test coccinelle script
- misc cleanups and fixes
* tag 'kbuild-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (41 commits)
coccicheck: return proper error code on fail
Coccinelle: doubletest: reduce side effect false positives
kbuild: remove deprecated host-progs variable
um: clean up archheaders recipe
kbuild: add %asm-generic to no-dot-config-targets
um: fix parallel building with O= option
scripts: Add Python 3 support to tracing/draw_functrace.py
builddeb: Add automatic support for sh{3,4}{,eb} architectures
builddeb: Add automatic support for riscv* architectures
builddeb: Add automatic support for m68k architecture
builddeb: Add automatic support for or1k architecture
builddeb: Add automatic support for sparc64 architecture
builddeb: Add automatic support for mips{,64}r6{,el} architectures
builddeb: Add automatic support for mips64el architecture
builddeb: Add automatic support for ppc64 and powerpcspe architectures
builddeb: Introduce functions to simplify kconfig tests in set_debarch
builddeb: Drop check for 32-bit s390
builddeb: Change architecture detection fallback to use dpkg-architecture
builddeb: Skip architecture detection when KBUILD_DEBARCH is set
Daniel Borkmann says:
pull-request: bpf-next 2018-08-13
The following pull-request contains BPF updates for your *net-next* tree.
The main changes are:
1) Add driver XDP support for veth. This can be used in conjunction with
redirect of another XDP program e.g. sitting on NIC so the xdp_frame
can be forwarded to the peer veth directly without modification,
from Toshiaki.
2) Add a new BPF map type REUSEPORT_SOCKARRAY and prog type SK_REUSEPORT
in order to provide more control and visibility on where a SO_REUSEPORT
sk should be located, and the latter enables to directly select a sk
from the bpf map. This also enables map-in-map for application migration
use cases, from Martin.
3) Add a new BPF helper bpf_skb_ancestor_cgroup_id() that returns the id
of cgroup v2 that is the ancestor of the cgroup associated with the
skb at the ancestor_level, from Andrey.
4) Implement BPF fs map pretty-print support based on BTF data for regular
hash table and LRU map, from Yonghong.
5) Decouple the ability to attach BTF for a map from the key and value
pretty-printer in BPF fs, and enable further support of BTF for maps for
percpu and LPM trie, from Daniel.
6) Implement a better BPF sample of using XDP's CPU redirect feature for
load balancing SKB processing to remote CPU. The sample implements the
same XDP load balancing as Suricata does which is symmetric hash based
on IP and L4 protocol, from Jesper.
7) Revert adding NULL pointer check with WARN_ON_ONCE() in __xdp_return()'s
critical path as it is ensured that the allocator is present, from Björn.
This implement XDP CPU redirection load-balancing across available
CPUs, based on the hashing IP-pairs + L4-protocol. This equivalent to
xdp-cpu-redirect feature in Suricata, which is inspired by the
Suricata 'ippair' hashing code.
An important property is that the hashing is flow symmetric, meaning
that if the source and destination gets swapped then the selected CPU
will remain the same. This is helps locality by placing both directions
of a flows on the same CPU, in a forwarding/routing scenario.
The hashing INITVAL (15485863 the 10^6th prime number) was fairly
arbitrary choosen, but experiments with kernel tree pktgen scripts
(pktgen_sample04_many_flows.sh +pktgen_sample05_flow_per_thread.sh)
showed this improved the distribution.
This patch also change the default loaded XDP program to be this
load-balancer. As based on different user feedback, this seems to be
the expected behavior of the sample xdp_redirect_cpu.
Link: https://github.com/OISF/suricata/commit/796ec08dd7a63
Adjusted function call API to take an initval. This allow the API
user to set the initial value, as a seed. This could also be used for
inputting the previous hash.
The teardown race in cpumap is really hard to reproduce. These changes
makes it easier to reproduce, for QA.
The --stress-mode now have a case of a very small queue size of 8, that helps
to trigger teardown flush to encounter a full queue, which results in calling
xdp_return_frame API, in a non-NAPI protect context.
Also increase MAX_CPUS, as my QA department have larger machines than me.
Tested-by: Jean-Tsung Hsiao <jhsiao@redhat.com>
The test_cgrp2_attach test covers bpf cgroup attachment code well,
so let's re-use it for testing allocation/releasing of cgroup storage.
The extension is pretty straightforward: the bpf program will use
the cgroup storage to save the number of transmitted bytes.
Expected output:
$ ./test_cgrp2_attach2
Attached DROP prog. This ping in cgroup /foo should fail...
ping: sendmsg: Operation not permitted
Attached DROP prog. This ping in cgroup /foo/bar should fail...
Attached PASS prog. This ping in cgroup /foo/bar should pass...
Detached PASS from /foo/bar while DROP is attached to /foo.
Attached PASS from /foo/bar and detached DROP from /foo.
### override:PASS
### multi:PASS
Signed-off-by: Roman Gushchin <guro@fb.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Convert xdpsock_user.c to use libbpf instead of bpf_load.o.
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Reviewed-by: Quentin Monnet <quentin.monnet@netronome.com>
Convert xdp_fwd_user.c to use libbpf instead of bpf_load.o.
To smoothly test BTF supported binary on samples/bpf,
let samples/bpf/Makefile probe llc, pahole and
llvm-objcopy for BPF support and use them
like tools/testing/selftests/bpf/Makefile
changed from the commit c0fa1b6c3efc ("bpf: btf:
Add BTF tests").
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Reviewed-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Define u_smp_rmb() and u_smp_wmb() to respective barrier instructions.
This ensures the processor will order accesses to queue indices against
accesses to queue ring entries.
Signed-off-by: Brian Brooks <brian.brooks@linaro.org>
Acked-by: Björn Töpel <bjorn.topel@intel.com>
pull-request: bpf-next 2018-07-20
1) Add sharing of BPF objects within one ASIC: this allows for reuse of
the same program on multiple ports of a device, and therefore gains
better code store utilization. On top of that, this now also enables
sharing of maps between programs attached to different ports of a
device, from Jakub.
2) Cleanup in libbpf and bpftool's Makefile to reduce unneeded feature
detections and unused variable exports, also from Jakub.
3) First batch of RCU annotation fixes in prog array handling, i.e.
there are several __rcu markers which are not correct as well as
some of the RCU handling, from Roman.
4) Two fixes in BPF sample files related to checking of the prog_cnt
upper limit from sample loader, from Dan.
5) Minor cleanup in sockmap to remove a set but not used variable,
from Colin.
All conflicts were trivial overlapping changes, so reasonably
easy to resolve.
Pull networking fixes from David Miller:
"Lots of fixes, here goes:
1) NULL deref in qtnfmac, from Gustavo A. R. Silva.
2) Kernel oops when fw download fails in rtlwifi, from Ping-Ke Shih.
3) Lost completion messages in AF_XDP, from Magnus Karlsson.
4) Correct bogus self-assignment in rhashtable, from Rishabh
Bhatnagar.
5) Fix regression in ipv6 route append handling, from David Ahern.
6) Fix masking in __set_phy_supported(), from Heiner Kallweit.
7) Missing module owner set in x_tables icmp, from Florian Westphal.
8) liquidio's timeouts are HZ dependent, fix from Nicholas Mc Guire.
9) Link setting fixes for sh_eth and ravb, from Vladimir Zapolskiy.
10) Fix NULL deref when using chains in act_csum, from Davide Caratti.
11) XDP_REDIRECT needs to check if the interface is up and whether the
MTU is sufficient. From Toshiaki Makita.
12) Net diag can do a double free when killing TCP_NEW_SYN_RECV
connections, from Lorenzo Colitti.
13) nf_defrag in ipv6 can unnecessarily hold onto dst entries for a
full minute, delaying device unregister. From Eric Dumazet.
14) Update MAC entries in the correct order in ixgbe, from Alexander
Duyck.
15) Don't leave partial mangles bpf program in jit_subprogs, from
Daniel Borkmann.
16) Fix pfmemalloc SKB state propagation, from Stefano Brivio.
17) Fix ACK handling in DCTCP congestion control, from Yuchung Cheng.
18) Use after free in tun XDP_TX, from Toshiaki Makita.
19) Stale ipv6 header pointer in ipv6 gre code, from Prashant Bhole.
20) Don't reuse remainder of RX page when XDP is set in mlx4, from
Saeed Mahameed.
21) Fix window probe handling of TCP rapair sockets, from Stefan
Baranoff.
22) Missing socket locking in smc_ioctl(), from Ursula Braun.
23) IPV6_ILA needs DST_CACHE, from Arnd Bergmann.
24) Spectre v1 fix in cxgb3, from Gustavo A. R. Silva.
25) Two spots in ipv6 do a rol32() on a hash value but ignore the
result. Fixes from Colin Ian King"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (176 commits)
tcp: identify cryptic messages as TCP seq # bugs
ptp: fix missing break in switch
hv_netvsc: Fix napi reschedule while receive completion is busy
MAINTAINERS: Drop inactive Vitaly Bordug's email
net: cavium: Add fine-granular dependencies on PCI
net: qca_spi: Fix log level if probe fails
net: qca_spi: Make sure the QCA7000 reset is triggered
net: qca_spi: Avoid packet drop during initial sync
ipv6: fix useless rol32 call on hash
ipv6: sr: fix useless rol32 call on hash
net: sched: Using NULL instead of plain integer
net: usb: asix: replace mii_nway_restart in resume path
net: cxgb3_main: fix potential Spectre v1
lib/rhashtable: consider param->min_size when setting initial table size
net/smc: reset recv timeout after clc handshake
net/smc: add error handling for get_user()
net/smc: optimize consumer cursor updates
net/nfc: Avoid stalls when nfc_alloc_send_skb() returned NULL.
ipv6: ila: select CONFIG_DST_CACHE
net: usb: rtl8150: demote allmulti message to dev_dbg()
In preparation for enabling command line LDLIBS, re-name HOST_LOADLIBES
to KBUILD_HOSTLDLIBS as the internal use only flags. Also rename
existing usage to HOSTLDLIBS for consistency. This should not have any
visible effects.
Signed-off-by: Laura Abbott <labbott@redhat.com>
In preparation for enabling command line CFLAGS, re-name HOSTCFLAGS to
KBUILD_HOSTCFLAGS as the internal use only flags. This should not have
any visible effects.
"prog_cnt" is the number of elements which are filled out in prog_fd[]
so the test should be >= instead of >.
Reviewed-by: David Ahern <dsahern@gmail.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
I can't see that we check prog_cnt to ensure it doesn't go over
MAX_PROGS.
People noticed that the code match on IEEE 802.1ad (ETH_P_8021AD) ethertype,
and this implies Q-in-Q or double tagged VLANs. Thus, we better parse
the next VLAN header too. It is even marked as a TODO.
This is relevant for real world use-cases, as XDP cpumap redirect can be
used when the NIC RSS hashing is broken. E.g. the ixgbe driver HW cannot
handle double tagged VLAN packets, and places everything into a single
RX queue. Using cpumap redirect, users can redistribute traffic across
CPUs to solve this, which is faster than the network stacks RPS solution.
It is left as an exerise how to distribute the packets across CPUs. It
would be convenient to use the RX hash, but that is not _yet_ exposed
to XDP programs. For now, users can code their own hash, as I've demonstrated
in the Suricata code (where Q-in-Q is handled correctly).
Reported-by: Florian Maury <florian.maury-cv@x-cli.eu>
Reported-by: Marek Majkowski <marek@cloudflare.com>
mdev_access() calls mbochs_get_page() with mdev_state->ops_lock held,
while mbochs_get_page() locks the mutex by itself.
It leads to unavoidable deadlock.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
The below path error can occur:
# ./xdp2skb_meta.sh --dev eth0 --list
./xdp2skb_meta.sh: line 61: /usr/sbin/tc: No such file or directory
So just use command names instead of absolute paths of tc and ip.
In addition, it allow callers to redefine $TC and $IP paths
Fixes: 36e04a2d78d9 ("samples/bpf: xdp2skb_meta shows transferring info from XDP to SKB")
Reviewed-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Pull VFIO fixes from Alex Williamson:
- Make vfio-pci IGD extensions optional via Kconfig (Alex Williamson)
- Remove unused and soon to be removed map_atomic callback from mbochs
sample driver, add unmap callback to avoid dmabuf leaks (Gerd
Hoffmann)
- Fix usage of get_user_pages_longterm() (Jason Gunthorpe)
- Fix sample mbochs driver vm_operations_struct.fault return type
(Souptick Joarder)
* tag 'vfio-v4.18-rc4' of git://github.com/awilliam/linux-vfio:
sample/vfio-mdev: Change return type to vm_fault_t
vfio: Use get_user_pages_longterm correctly
sample/mdev/mbochs: add mbochs_kunmap_dmabuf
sample/mdev/mbochs: remove mbochs_kmap_atomic_dmabuf
vfio/pci: Make IGD support a configurable option
For untracked executables of samples/bpf, add this.
Untracked files:
(use "git add <file>..." to include in what will be committed)
samples/bpf/cpustat
samples/bpf/fds_example
samples/bpf/lathist
samples/bpf/load_sock_ops
test_task_rename() and test_urandom_read()
can be failed during write() and read(),
So check the result of them.
Reviewed-by: David Laight <David.Laight@ACULAB.COM>
To avoid the below build warning message,
use new generate_load() checking the return value.
ignoring return value of ‘system’, declared with attribute warn_unused_result
And it also refactors the duplicate code of both
test_perf_event_all_cpu() and test_perf_event_task()
Cc: Teng Qin <qinteng@fb.com>
This fixes build error regarding redefinition:
CLANG-bpf samples/bpf/parse_varlen.o
samples/bpf/parse_varlen.c:111:8: error: redefinition of 'vlan_hdr'
struct vlan_hdr {
./include/linux/if_vlan.h:38:8: note: previous definition is here
So remove duplicate 'struct vlan_hdr' in sample code and include if_vlan.h
convert mbochs_region_vm_fault and mbochs_dmabuf_vm_fault
to return vm_fault_t type.
Signed-off-by: Souptick Joarder <jrdr.linux@gmail.com>
pull-request: bpf-next 2018-07-03
1) Various improvements to bpftool and libbpf, that is, bpftool build
speed improvements, missing BPF program types added for detection
by section name, ability to load programs from '.text' section is
made to work again, and better bash completion handling, from Jakub.
2) Improvements to nfp JIT's map read handling which allows for optimizing
memcpy from map to packet, from Jiong.
3) New BPF sample is added which demonstrates XDP in combination with
bpf_perf_event_output() helper to sample packets on all CPUs, from Toke.
4) Add a new BPF kselftest case for tracking connect(2) BPF hooks
infrastructure in combination with TFO, from Andrey.
5) Extend the XDP/BPF xdp_rxq_info sample code with a cmdline option to
read payload from packet data in order to use it for benchmarking.
Also for '--action XDP_TX' option implement swapping of MAC addresses
to avoid drops on some hardware seen during testing, from Jesper.
Sendmsg in the SKB path of AF_XDP can now return EBUSY when a packet
was discarded and completed by the driver. Just ignore this message
in the sample application.
Fixes: b4b8faa1ded7 ("samples/bpf: sample application and documentation for AF_XDP sockets")
Signed-off-by: Magnus Karlsson <magnus.karlsson@intel.com>
Reported-by: Pavel Odintsov <pavel@fastnetmon.com>
For ACLs implemented using either FIB rules or FIB entries, the BPF
program needs the FIB lookup status to be able to drop the packet.
Since the bpf_fib_lookup API has not reached a released kernel yet,
change the return code to contain an encoding of the FIB lookup
result and return the nexthop device index in the params struct.
In addition, inform the BPF program of any post FIB lookup reason as
to why the packet needs to go up the stack.
The fib result for unicast routes must have an egress device, so remove
the check that it is non-NULL.
Signed-off-by: David Ahern <dsahern@gmail.com>
XDP_TX requires also changing the MAC-addrs, else some hardware
may drop the TX packet before reaching the wire. This was
observed with driver mlx5.
If xdp_rxq_info select --action XDP_TX the swapmac functionality
is activated. It is also possible to manually enable via cmdline
option --swapmac. This is practical if wanting to measure the
overhead of writing/updating payload for other action types.
Signed-off-by: Toke Høiland-Jørgensen <toke@toke.dk>
Acked-by: Song Liu <songliubraving@fb.com>
There is a cost associated with reading the packet data payload
that this test ignored. Add option --read to allow enabling
reading part of the payload.
This sample/tool helps us analyse an issue observed with a NIC
mlx5 (ConnectX-5 Ex) and an Intel(R) Xeon(R) CPU E5-1650 v4.
With no_touch of data:
Running XDP on dev:mlx5p1 (ifindex:8) action:XDP_DROP options:no_touch
XDP stats CPU pps issue-pps
XDP-RX CPU 0 14,465,157 0
XDP-RX CPU 1 14,464,728 0
XDP-RX CPU 2 14,465,283 0
XDP-RX CPU 3 14,465,282 0
XDP-RX CPU 4 14,464,159 0
XDP-RX CPU 5 14,465,379 0
XDP-RX CPU total 86,789,992
When not touching data, we observe that the CPUs have idle cycles.
When reading data the CPUs are 100% busy in softirq.
With reading data:
Running XDP on dev:mlx5p1 (ifindex:8) action:XDP_DROP options:read
XDP-RX CPU 0 9,620,639 0
XDP-RX CPU 1 9,489,843 0
XDP-RX CPU 2 9,407,854 0
XDP-RX CPU 3 9,422,289 0
XDP-RX CPU 4 9,321,959 0
XDP-RX CPU 5 9,395,242 0
XDP-RX CPU total 56,657,828
The effect seen above is a result of cache-misses occuring when
more RXQs are being used. Based on perf-event observations, our
conclusion is that the CPUs DDIO (Direct Data I/O) choose to
deliver packet into main memory, instead of L3-cache. We also
found, that this can be mitigated by either using less RXQs or by
reducing NICs the RX-ring size.
Add an example program showing how to sample packets from XDP using the
perf event buffer. The example userspace program just prints the ethernet
header for every packet sampled.
There is no default implementation for dma_buf_ops->unmap.
So add a function unmapping the page, otherwise we'll leak them.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Atomic mapping interface for dmabufs will be removed.
Pull VFIO updates from Alex Williamson:
- Bind type1 task tracking to group_leader to facilitate vCPU hotplug
in QEMU (Alex Williamson)
- Sample mdev display drivers, including region-based host and guest
Linux drivers and bochs compatible dmabuf device
(Gerd Hoffmann)
- Fix vfio-platform reset module leak (Geert Uytterhoeven)
- vfio-platform error message consistency (Geert Uytterhoeven)
- Global checking for mdev uuid collisions rather than per parent
device (Alex Williamson)
- Use match_string() helper (Yisheng Xie)
- vfio-platform PM domain fixes (Geert Uytterhoeven)
- Fix sample mbochs driver build dependency (Arnd Bergmann)
* tag 'vfio-v4.18-rc1' of git://github.com/awilliam/linux-vfio:
samples: mbochs: add DMA_SHARED_BUFFER dependency
vfio: platform: Fix using devices in PM Domains
vfio: use match_string() helper
vfio/mdev: Re-order sysfs attribute creation
vfio/mdev: Check globally for duplicate devices
vfio: platform: Make printed error messages more consistent
vfio: platform: Fix reset module leak in error path
sample: vfio bochs vbe display (host device for bochs-drm)
sample: vfio mdev display - guest driver
sample: vfio mdev display - host device
vfio/type1: Fix task tracking for QEMU vCPU hotplug
The new bochs vbe sample fails to link when DMA_SHARED_BUFFER is
disabled:
ERROR: "dma_buf_export" [samples/vfio-mdev/mbochs.ko] undefined!
ERROR: "dma_buf_fd" [samples/vfio-mdev/mbochs.ko] undefined!
This uses a 'select' statement to enable that framework, like all
other users do.
Fixes: a5e6e6505f38 ("sample: vfio bochs vbe display (host device for bochs-drm)")
Display device, demo-ing the vfio dmabuf display interface
(VFIO_GFX_PLANE_TYPE_DMABUF). Compatible enough to qemu stdvga
that bochs-drm.ko can be used as guest driver.
Guest fbdev driver for CONFIG_SAMPLE_VFIO_MDEV_MDPY.
Simple framebuffer display, demo-ing the vfio region display interface
(VFIO_GFX_PLANE_TYPE_REGION).
Pull auxdisplay updates from Miguel Ojeda:
"Mostly small fixes and cleanups, plus a non-trivial fix for charlcd
- charlcd: fixes and cleanups (Robert Abel and Sean Young)
- Kconfig fixes (Randy Dunlap, Corentin Labbe and Ulf Magnusson)
- cfag12864bfb: const cleanup (Gustavo A. R. Silva)
- Docs/licenses/warnings cleanups"
* tag 'auxdisplay-for-linus-v4.18-rc1' of git://github.com/ojeda/linux:
auxdisplay: Replace licenses with SPDX identifiers
auxdisplay: make PANEL a menuconfig
auxdisplay: fix broken menu
auxdisplay: charlcd: Fix and clean up handling of x/y commands
auxdisplay: charlcd: fix hex literal ranges for graphics command
auxdisplay: charlcd: fix two-line command ^[[LN not marked as processed
auxdisplay: charlcd: replace octal literal with form-feed escape sequence
auxdisplay: charlcd: use null character instead of zero literal to terminate strings
auxdisplay: charlcd: no need to call charlcd_gotoxy() if nothing changes
auxdisplay: cfag12864bfb: constify fb_fix_screeninfo and fb_var_screeninfo structures
auxdisplay: img-ascii-lcd: fix typo on select SYSCON/MFD_SYSCON
auxdisplay: img-ascii-lcd: kconfig: Remove MIPS_SEAD3 reference
auxdisplay: arm-charlcd: Fix struct charlcd doc line
MAINTAINERS: auxdisplay: remove obsolete webpages
Doc: misc-devices: move lcd-panel-cgram.txt to auxdisplay/
Make sure that XDP_SKB also uses the skb Tx path.
Signed-off-by: Björn Töpel <bjorn.topel@intel.com>
