path: root/samples
2010-08-20kfifo: add explicit error checking in all the examplesAndrea Righi
Provide a check in all the kfifo examples to validate the correct execution of each testcase. Signed-off-by: Andrea Righi <arighi@develer.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20kfifo: fix a memory leak in dma exampleAndrea Righi
We use a dynamically allocated kfifo in the dma example, so we need to free it when unloading the module. Signed-off-by: Andrea Righi <arighi@develer.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20kfifo: fix kernel BUG in dma exampleAndrea Righi
The scatterlist is used uninitialized in kfifo_dma_in_prepare(). This triggers the following bug if CONFIG_DEBUG_SG=y: ------------[ cut here ]------------ kernel BUG at include/linux/scatterlist.h:65! invalid opcode: 0000 [#1] PREEMPT SMP ... Call Trace: [<ffffffff810a1eab>] setup_sgl+0x6b/0xe0 [<ffffffffa03d7000>] ? example_init+0x0/0x265 [dma_example] [<ffffffff810a2021>] __kfifo_dma_in_prepare+0x21/0x30 [<ffffffffa03d7124>] example_init+0x124/0x265 [dma_example] [<ffffffff810f9c55>] ? trace_module_notify+0x25/0x370 [<ffffffff81110c6e>] ? free_pages_prepare+0x11e/0x1e0 [<ffffffff8106f2b1>] ? get_parent_ip+0x11/0x50 [<ffffffff810f9c55>] ? trace_module_notify+0x25/0x370 [<ffffffff810b65fd>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff814beade>] ? mutex_unlock+0xe/0x10 [<ffffffff810f9c71>] ? trace_module_notify+0x41/0x370 [<ffffffff810a77d5>] ? __blocking_notifier_call_chain+0x45/0x80 [<ffffffff81137b7a>] ? vfree+0x2a/0x30 [<ffffffff810a6ac3>] ? up_read+0x23/0x40 [<ffffffff810a77f5>] ? __blocking_notifier_call_chain+0x65/0x80 [<ffffffff810001e3>] do_one_initcall+0x43/0x180 [<ffffffff810c577a>] sys_init_module+0xba/0x200 [<ffffffff8103819b>] system_call_fastpath+0x16/0x1b RIP [<ffffffff810a1e31>] setup_sgl_buf+0x1a1/0x1b0 RSP <ffff88006720dc98> ---[ end trace a72b979fd3c1d3a5 ]--- Add the proper initialization to avoid the bug. Signed-off-by: Andrea Righi <arighi@develer.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20kfifo: add explicit error checking in byte stream exampleAndrea Righi
Provide a static array of expected items that kfifo should contain at the end of the test to validate it. Signed-off-by: Andrea Righi <arighi@develer.com> Cc: Stefani Seibold <stefani@seibold.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20kfifo: add kfifo_skip() testcaseAndrea Righi
Add a testcase for kfifo_skip() to the byte stream fifo example. Signed-off-by: Andrea Righi <arighi@develer.com> Cc: Greg KH <greg@kroah.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11kfifo: add example files to the kernel sample directoryStefani Seibold
Add four examples to the kernel sample directory. It shows how to handle: - a byte stream fifo - a integer type fifo - a dynamic record sized fifo - the fifo DMA functions [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05SAMPLES: kprobe_example: Make it print something on MIPS.David Daney
This KProbes example is a little useless if it doesn't print anything. For MIPS print similar messages to those produced on x86 and PPC. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org To: ananth@in.ibm.com To: anil.s.keshavamurthy@intel.com To: davem@davemloft.net To: masami.hiramatsu.pt@hitachi.com Cc: linux-kernel@vger.kernel.org Cc: hschauhan@nulltrace.org Patchwork: https://patchwork.linux-mips.org/patch/1528/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-14tracing: Let tracepoints have data passed to tracepoint callbacksSteven Rostedt
This patch adds data to be passed to tracepoint callbacks. The created functions from DECLARE_TRACE() now need a mandatory data parameter. For example: DECLARE_TRACE(mytracepoint, int value, value) Will create the register function: int register_trace_mytracepoint((void(*)(void *data, int value))probe, void *data); As the first argument, all callbacks (probes) must take a (void *data) parameter. So a callback for the above tracepoint will look like: void myprobe(void *data, int value) { } The callback may choose to ignore the data parameter. This change allows callbacks to register a private data pointer along with the function probe. void mycallback(void *data, int value); register_trace_mytracepoint(mycallback, mydata); Then the mycallback() will receive the "mydata" as the first parameter before the args. A more detailed example: DECLARE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status)); /* In the C file */ DEFINE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status)); [...] trace_mytracepoint(status); /* In a file registering this tracepoint */ int my_callback(void *data, int status) { struct my_struct my_data = data; [...] } [...] my_data = kmalloc(sizeof(*my_data), GFP_KERNEL); init_my_data(my_data); register_trace_mytracepoint(my_callback, my_data); The same callback can also be registered to the same tracepoint as long as the data registered is different. Note, the data must also be used to unregister the callback: unregister_trace_mytracepoint(my_callback, my_data); Because of the data parameter, tracepoints declared this way can not have no args. That is: DECLARE_TRACE(mytracepoint, TP_PROTO(void), TP_ARGS()); will cause an error. If no arguments are needed, a new macro can be used instead: DECLARE_TRACE_NOARGS(mytracepoint); Since there are no arguments, the proto and args fields are left out. This is part of a series to make the tracepoint footprint smaller: text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4914025 1088868 861512 6864405 68be15 vmlinux.class 4918492 1084612 861512 6864616 68bee8 vmlinux.tracepoint Again, this patch also increases the size of the kernel, but lays the ground work for decreasing it. v5: Fixed net/core/drop_monitor.c to handle these updates. v4: Moved the DECLARE_TRACE() DECLARE_TRACE_NOARGS out of the #ifdef CONFIG_TRACE_POINTS, since the two are the same in both cases. The __DECLARE_TRACE() is what changes. Thanks to Frederic Weisbecker for pointing this out. v3: Made all register_* functions require data to be passed and all callbacks to take a void * parameter as its first argument. This makes the calling functions comply with C standards. Also added more comments to the modifications of DECLARE_TRACE(). v2: Made the DECLARE_TRACE() have the ability to pass arguments and added a new DECLARE_TRACE_NOARGS() for tracepoints that do not need any arguments. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-09Merge commit 'v2.6.34-rc1' into perf/urgentIngo Molnar
Conflicts: tools/perf/util/probe-event.c Merge reason: Pick up -rc1 and resolve the conflict as well. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07kset-example: Spelling fixes.Radu Voicilas
No change in functionality. Signed-off-by: Radu Voicilas <rvoicilas@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07kobject-example: Spelling fixes.Radu Voicilas
2010-02-27percpu: Add __percpu sparse annotations to hw_breakpointTejun Heo
Add __percpu sparse annotations to hw_breakpoint. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. In kernel/hw_breakpoint.c, per_cpu(nr_task_bp_pinned, cpu)'s will trigger spurious noderef related warnings from sparse. Changing it to &per_cpu(nr_task_bp_pinned[0], cpu) will work around the problem but deemed to ugly by the maintainer. Leave it alone until better solution can be found. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: K.Prasad <prasad@linux.vnet.ibm.com> LKML-Reference: <4B7B4B7A.9050902@kernel.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-12-11Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (57 commits) x86, perf events: Check if we have APIC enabled perf_event: Fix variable initialization in other codepaths perf kmem: Fix unused argument build warning perf symbols: perf_header__read_build_ids() offset'n'size should be u64 perf symbols: dsos__read_build_ids() should read both user and kernel buildids perf tools: Align long options which have no short forms perf kmem: Show usage if no option is specified sched: Mark sched_clock() as notrace perf sched: Add max delay time snapshot perf tools: Correct size given to memset perf_event: Fix perf_swevent_hrtimer() variable initialization perf sched: Fix for getting task's execution time tracing/kprobes: Fix field creation's bad error handling perf_event: Cleanup for cpu_clock_perf_event_update() perf_event: Allocate children's perf_event_ctxp at the right time perf_event: Clean up __perf_event_init_context() hw-breakpoints: Modify breakpoints without unregistering them perf probe: Update perf-probe document perf probe: Support --del option trace-kprobe: Support delete probe syntax ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-06hw-breakpoints: Use overflow handler instead of the event callbackFrederic Weisbecker
struct perf_event::event callback was called when a breakpoint triggers. But this is a rather opaque callback, pretty tied-only to the breakpoint API and not really integrated into perf as it triggers even when we don't overflow. We prefer to use overflow_handler() as it fits into the perf events rules, being called only when we overflow. Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "K. Prasad" <prasad@linux.vnet.ibm.com>
2009-11-27hw-breakpoints: Use struct perf_event_attr to define kernel breakpointsFrederic Weisbecker
Kernel breakpoints are created using functions in which we pass breakpoint parameters as individual variables: address, length and type. Although it fits well for x86, this just does not scale across architectures that may support this api later as these may have more or different needs. Pass in a perf_event_attr structure instead because it is meant to evolve as much as possible into a generic hardware breakpoint parameter structure. Reported-by: K.Prasad <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1259294154-5197-2-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-26hw-breakpoints: Simplify error handling in breakpoint creation requestsFrederic Weisbecker
This simplifies the error handling when we create a breakpoint. We don't need to check the NULL return value corner case anymore since we have improved perf_event_create_kernel_counter() to always return an error code in the failure case. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Prasad <prasad@linux.vnet.ibm.com> LKML-Reference: <1259210142-5714-3-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-23hw-breakpoint: Attribute authorship of hw-breakpoint related filesK.Prasad
Attribute authorship to developers of hw-breakpoint related files. Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091123154713.GA5593@in.ibm.com> [ v2: moved it to latest -tip ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10hw-breakpoints: Fix broken hw-breakpoint sample moduleFrederic Weisbecker
The hw-breakpoint sample module has been broken during the hw-breakpoint internals refactoring. Propagate the changes to it. Reported-by: "K. Prasad" <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-11-09Kconfig: Remove useless and sometimes wrong commentsMichael Roth
Additionally, some excessive newlines removed. Signed-off-by: Michael Roth <mroth@nessie.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-18Merge commit 'perf/core' into perf/hw-breakpointFrederic Weisbecker
Conflicts: kernel/Makefile kernel/trace/Makefile kernel/trace/trace.h samples/Makefile Merge reason: We need to be uptodate with the perf events development branch because we plan to rewrite the breakpoints API on top of perf events.
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-18tracing: Remove markersChristoph Hellwig
Now that the last users of markers have migrated to the event tracer we can kill off the (now orphan) support code. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090917173527.GA1699@lst.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-15debugfs: Change debuhgfs directory of trace-events-sample.hGeunSik Lim
Default directory of debug filesystem for ftrace is /sys/kernel/debug/. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15Merge branch 'linus' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/x86/kernel/process_64.c Semantic conflict fixed in: arch/x86/kvm/x86.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-07Merge branch 'tracing/core' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/Kconfig kernel/trace/trace.h Merge reason: resolve the conflicts, plus adopt to the new ring-buffer APIs. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-16sparc64: cheaper asm/uaccess.h inclusionAlexey Dobriyan
sched.h inclusion is definitely not needed like in 32-bit version, remove it, fixup compilation. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-13tracing/events: Move TRACE_SYSTEM outside of include guardLi Zefan
If TRACE_INCLDUE_FILE is defined, <trace/events/TRACE_INCLUDE_FILE.h> will be included and compiled, otherwise it will be <trace/events/TRACE_SYSTEM.h> So TRACE_SYSTEM should be defined outside of #if proctection, just like TRACE_INCLUDE_FILE. Imaging this scenario: #include <trace/events/foo.h> -> TRACE_SYSTEM == foo ... #include <trace/events/bar.h> -> TRACE_SYSTEM == bar ... #define CREATE_TRACE_POINTS #include <trace/events/foo.h> -> TRACE_SYSTEM == bar !!! and then bar.h will be included and compiled. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A5A9CF1.2010007@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-20Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) tracing/urgent: warn in case of ftrace_start_up inbalance tracing/urgent: fix unbalanced ftrace_start_up function-graph: add stack frame test function-graph: disable when both x86_32 and optimize for size are configured ring-buffer: have benchmark test print to trace buffer ring-buffer: do not grab locks in nmi ring-buffer: add locks around rb_per_cpu_empty ring-buffer: check for less than two in size allocation ring-buffer: remove useless compile check for buffer_page size ring-buffer: remove useless warn on check ring-buffer: use BUF_PAGE_HDR_SIZE in calculating index tracing: update sample event documentation tracing/filters: fix race between filter setting and module unload tracing/filters: free filter_string in destroy_preds() ring-buffer: use commit counters for commit pointer accounting ring-buffer: remove unused variable ring-buffer: have benchmark test handle discarded events ring-buffer: prevent adding write in discarded area tracing/filters: strloc should be unsigned short tracing/filters: operand can be negative ... Fix up kmemcheck-induced conflict in kernel/trace/ring_buffer.c manually
2009-06-17Merge branch 'linus' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/x86/Kconfig arch/x86/kernel/traps.c arch/x86/power/cpu.c arch/x86/power/cpu_32.c kernel/Makefile Semantic conflict: arch/x86/kernel/hw_breakpoint.c Merge reason: Resolve the conflicts, move from put_cpu_no_sched() to put_cpu() in arch/x86/kernel/hw_breakpoint.c. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-16tracing: update sample event documentationSteven Rostedt
The comments in the sample code is a bit confusing. This patch cleans them up a little. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-06-15firmware: remove broken example filesGreg Kroah-Hartman
The firmware example files are beyond broken, and will not work, and should not be used as an example at all. So lets remove them and hope someone writes new files sometime in the future. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15kobject: samples: make SAMPLE_KOBJECT module-onlyMichal Marek
With SAMPLE_KOBJECT=y, it isn't even linked into the kernel image. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-02hw-breakpoints: sample HW breakpoint over kernel data addressK.Prasad
This patch introduces a sample kernel module to demonstrate the use of Hardware Breakpoint feature. It places a breakpoint over the kernel variable 'pid_max' to monitor all write operations and emits a function-backtrace when done. Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-05-06tracing: update sample with TRACE_INCLUDE_FILESteven Rostedt
When creating trace events for ftrace, the header file with the TRACE_EVENT macros must also have a macro called TRACE_SYSTEM. This macro describes the name of the system the TRACE_EVENTS are defined for. It also doubles as a way for the define_trace.h file to include the file that included it. For example: in irq.h #define TRACE_SYSTEM irq [...] #include <trace/define_trace.h> The define_trace will use TRACE_SYSTEM to include irq.h. But if the name of the trace system does not match the name of the trace header file, one can override it with: Which will change define_trace.h to inclued foo_trace.h instead of foo.h The sample comments this, but people that use the sample code will more likely use the code and not read the comments. This patch changes the sample code to use the TRACE_INCLUDE_FILE to better show developers how to use it. [ Impact: make sample less confusing to developers ] Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-06tracing: small trave_events sample Makefile cleanupChristoph Hellwig
Use -I$(src) to add the current directory the include path. [ Impact: cleanup ] Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-06tracing/events: make SAMPLE_TRACE_EVENTS default to nLi Zefan
Normally a config should be default to n. This patch also makes the sample module-only, like SAMPLE_MARKERS and SAMPLE_TRACEPOINTS. [ Impact: don't build trace event sample by default ] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A00F6C0.8090803@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-06tracing/events: don't say hi when loading the trace event sampleLi Zefan
The sample is useful for testing, and I'm using it. But after loading the module, it keeps saying hi every 10 seconds, this may be disturbing. Also Steven said commenting out the "hi" helped in causing races. :) [ Impact: make testing a bit easier ] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A00F6AD.2070008@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/events: add trace-events-sampleSteven Rostedt
This patch adds a sample to the samples directory on how to create and use TRACE_EVENT trace points. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-03-24tracing: Documentation / sample code fixes for tracepointsJody McIntyre
Fix the tracepoint documentation to refer to "tracepoint-sample" instead of "tracepoint-example" to match what actually exists; fix the directory, and clarify how to compile. Change every instance of "example" in the sample tracepoint code to "sample" for consistency. Signed-off-by: Jody McIntyre <scjody@sun.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: torvalds@linux-foundation.org LKML-Reference: <20090324200027.GH8294@clouds> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-10tracing: replace TP<var> with TP_<var>Steven Rostedt
Impact: clean up The macros TPPROTO, TPARGS, TPFMT, TPRAWFMT, and TPCMD all look a bit ugly. This patch adds an underscore to their names. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-01-06samples: mark {static|__init|__exit} for {init|exit} functionsQinghuang Feng
None of these (init|exit) functions is called from other functions which is outside the kernel module mechanism or kernel itself, so mark them as {static|__init|__exit}. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-16tracepoints: add DECLARE_TRACE() and DEFINE_TRACE()Mathieu Desnoyers
Impact: API *CHANGE*. Must update all tracepoint users. Add DEFINE_TRACE() to tracepoints to let them declare the tracepoint structure in a single spot for all the kernel. It helps reducing memory consumption, especially when declaring a lot of tracepoints, e.g. for kmalloc tracing. *API CHANGE WARNING*: now, DECLARE_TRACE() must be used in headers for tracepoint declarations rather than DEFINE_TRACE(). This is the sane way to do it. The name previously used was misleading. Updates scheduler instrumentation to follow this API change. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16tracepoints: samples, fix teardownMathieu Desnoyers
Impact: fix a bug in sample tracepoints Need a tracepoint_synchronize_unregister() before the end of exit() to make sure every probe callers have exited the non preemptible section and thus are not executing the probe code anymore. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14markers: probe example, fix teardownMathieu Desnoyers
Need a marker_synchronize_unregister() before the end of exit() to make sure every probe callers have exited the non preemptible section and thus are not executing the probe code anymore. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracing: tracepoints, samplesMathieu Desnoyers
Tracepoint example code under samples/. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: 'Peter Zijlstra' <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-21kobject: should use kobject_put() in kset-exampleLi Zefan
We should call kobject_put() instead of kfree() if kobject_init_and_add() returns an error, shouldn't we? Don't set up a bad example ;) Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21Firmware: fix typo in example codeGreg Kroah-Hartman
It's not like this stuff even builds right now, but this will make Randy's scripts happy :) Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
