path: root/scripts/Lindent
2007-07-20Fix Lindent to not indent preprocessor comments so farMatthew Wilcox
I recently ran Lindent over the AdvanSys driver and it moved the comments on #else and #endif lines way over to the right: #else /* ADVANSYS_DEBUG */ This doesn't match what I expect from kernel style, but it is documented. We just need another flag to indent to make this look like: #else /* ADVANSYS_DEBUG */ Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-07-13[PATCH] Lindent: ignore .indent.proJeff Mahoney
When I recently submitted a Lindent patch, it turned out that my .indent.pro options were also applied to the tree. This patch directs indent(1) to ignore the .indent.pro directives and only use options specified on the command line. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
