path: root/scripts/Makefile.asm-generic
2012-10-17uapi: Allow automatic generation of uapi/asm/ header filesCatalin Marinas
Several arch/*/include/uapi/asm/* header simply include the corresponding <asm-generic/*> file. This patch allows such files to be specified in uapi/asm/Kbuild via "generic-y += ..." to be automatically generated (similar to asm/Kbuild). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Arnd Bergmann <arnd@arndb.de>
2011-06-09kbuild: silence Nothing to be done for 'all' messagePeter Foley
This patch silences a Makefile.asm-generic message by defining a dummy rule for all. make -f /usr/src/git/scripts/Makefile.asm-generic \ obj=arch/x86/include/generated/asm make[1]: Nothing to be done for `all'. Signed-off-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-02kbuild: Fix Makefile.asm-generic for umMichal Marek
Do nothing if arch/$(SRCARCH)/include/asm/Kbuild does not exist, which is the case of um. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2011-04-28kbuild: asm-generic supportSam Ravnborg
There is an increasing amount of header files shared between individual architectures in asm-generic. To avoid a lot of dummy wrapper files that just include the corresponding file in asm-generic provide some basic support in kbuild for this. With the following patch an architecture can maintain a list of files in the file arch/$(ARCH)/include/asm/Kbuild To use a generic file just add: generic-y += <name-of-header-file.h> For each file listed kbuild will generate the necessary wrapper in arch/$(ARCH)/include/generated/asm. When installing userspace headers a wrapper is likewise created. The original inspiration for this came from the unicore32 patchset - although a different method is used. The patch includes several improvements from Arnd Bergmann. Michael Marek contributed Makefile.asm-generic. Remis Baima did an intial implementation along to achive the same - see https://patchwork.kernel.org/patch/13352/ Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn> Tested-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
