path: root/scripts/basic
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-21trivial: kbuild: remove extraneous blank line after declaration of usage()Trevor Keith
Signed-off-by: Trevor Keith <tsrk@tsrk.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: remove references to non-existent include/linux/config.hMarkus Heidelberg
Ignore drivers/staging/ since it is very likely that new drivers introduce it again. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-20kbuild: add static to prototypesTrevor Keith
Warnings found via gcc -Wmissing-prototypes. Signed-off-by: Trevor Keith <tsrk@tsrk.net> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-20kbuild: fix build error during make htmldocsAmerigo Wang
Fix the following build error when do 'make htmldocs': DOCPROC Documentation/DocBook/debugobjects.xml exec /scripts/kernel-doc: No such file or directory exec /scripts/kernel-doc: No such file or directory Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-14kbuild: fix a compile warningAmerigo Wang
gcc-4.4.1: HOSTCC scripts/basic/fixdep scripts/basic/fixdep.c: In function 'traps': scripts/basic/fixdep.c:377: warning: dereferencing type-punned pointer will break strict-aliasing rules scripts/basic/fixdep.c:379: warning: dereferencing type-punned pointer will break strict-aliasing rules (Apparently -fno-strict-aliasing will fix this too) Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09kbuild: allow docproc invocation from externalJiri Slaby
- getcwd returns path without a slash at the end, add the slash - add KBUILD_SRC env support, so that we can specify path for kernel (to know where scripts/kernel-doc resides) and SRCTREE (for searching files referenced in .tmpl) separately [v2] - use KBUILD_SRC instead of a newly introduced environment variable Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-10-20Update .gitignore files for generated targetsLinus Torvalds
The generated 'capflags.c' file wasn't properly ignored, and the list of files in scripts/basic/ wasn't up-to-date. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16driver core: basic infrastructure for per-module dynamic debug messagesJason Baron
Base infrastructure to enable per-module debug messages. I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes control of debugging statements on a per-module basis in one /proc file, currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG, is not set, debugging statements can still be enabled as before, often by defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set. The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls can be dynamically enabled/disabled on a per-module basis. Future plans include extending this functionality to subsystems, that define their own debug levels and flags. Usage: Dynamic debugging is controlled by the debugfs file, <debugfs>/dynamic_printk/modules. This file contains a list of the modules that can be enabled. The format of the file is as follows: <module_name> <enabled=0/1> . . . <module_name> : Name of the module in which the debug call resides <enabled=0/1> : whether the messages are enabled or not For example: snd_hda_intel enabled=0 fixup enabled=1 driver enabled=0 Enable a module: $echo "set enabled=1 <module_name>" > dynamic_printk/modules Disable a module: $echo "set enabled=0 <module_name>" > dynamic_printk/modules Enable all modules: $echo "set enabled=1 all" > dynamic_printk/modules Disable all modules: $echo "set enabled=0 all" > dynamic_printk/modules Finally, passing "dynamic_printk" at the command line enables debugging for all modules. This mode can be turned off via the above disable command. [gkh: minor cleanups and tweaks to make the build work quietly] Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-28kernel-doc: new P directive for DOC: sectionsJohannes Berg
The !P directive includes the contents of a DOC: section given by title, e.g. !Pfilename Title of the section Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kernel-doc: use no-doc optionJohannes Berg
When asked by a template to include all functions from a file, it will also include DOC: sections wreaking havoc in the generated docbook file. This patch makes it use the new -no-doc-sections flag for kernel-doc to avoid this. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-18kbuild: stop docproc segfaulting when SRCTREE isn't set.Rob Landley
Prevent docproc from segfaulting when SRCTREE isn't set. Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12docproc: style & typo cleanupsRandy Dunlap
- fix typos/spellos in docproc.c and Makefile - add a little whitespace {while, switch} (coding style) - use NULL instead of 0 for pointer testing Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-02kbuild: scripts/basic/fixdep segfault on pathological string-o-deathAndy Green
build scripts: fixdep blows segfault on string CONFIG_MODULE seen The string "CONFIG_MODULE" appearing anywhere in a source file causes fixdep to segfault. This string appeared in the wild in the current mISDN sources (I think they meant CONFIG_MODULES). But it shouldn't segfault (esp as CONFIG_MODULE appeared in a quoted string). Signed-off-by: Andy Green <andy@warmcat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-04-01[PATCH] kbuild: fix dependency generationJan Beulich
Commit 2e3646e51b2d6415549b310655df63e7e0d7a080 changed the way the split config tree is built, but failed to also adjust fixdep accordingly - if changing a config option from or to m, files referencing the respective CONFIG_..._MODULE (but not the corresponding CONFIG_...) didn't get rebuilt. The problem is that trisate symbol are represent with three different symbols: SYMBOL=n => no symbol defined SYMBOL=y => CONFIG_SYMBOL defined to '1' SYMBOL=m => CONFIG_SYMBOL_MODULE defined to '1' But conf_split_config do not distingush between the =y and =m case, so only the =y case is honoured. This is fixed in fixdep so when a CONFIG symbol with _MODULE is found we skip that part and only look for the CONFIG_SYMBOL version. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-03[PATCH] update some docbook commentsRandy Dunlap
Correct a few comments in kernel-doc Doc and source files. (akpm: note: the patch removes a non-ascii character and might have to be applied by hand..) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] docbook: fix segfault in docproc.cHenrik Kretzschmar
Adds a missing exit, if the file that should be parsed couldn't be opened. Without it crashes with a segfault, cause the filedescriptor is accessed even if the file could not be opened. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09kconfig: integrate split config into silentoldconfigRoman Zippel
Now that kconfig can load multiple configurations, it becomes simple to integrate the split config step, by simply comparing the new .config file with the old auto.conf (and then saving the new auto.conf). A nice side effect is that this saves a bit of disk space and cache, as no data needs to be read from or saved into the splitted config files anymore (e.g. include/config is now 648KB instead of 5.2MB). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-19kbuild: consolidate command line escapingJan Beulich
While the recent change to also escape # symbols when storing C-file compilation command lines was helpful, it should be in effect for all command lines, as much as the dollar escaping should be in effect for C-source compilation commands. Additionally, for better readability and maintenance, consolidating all the escaping (single quotes, dollars, and now sharps) was also desirable. Signed-Off-By: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-25kbuild: escape '#' in .target.cmd filesSam Ravnborg
Commandlines are contained in the .<target>.cmd files and in case they contain a '#' char make see this as start of comment. Teach fixdep to escape the '#' char so make will assing the full commandline. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-10-18Add some basic .gitignore filesLinus Torvalds
This still leaves driver and architecture-specific subdirectories alone, but gets rid of the bulk of the "generic" generated files that we should ignore. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Kill signed charsJ.A. Magallon
scripts/ is full of mismatches between char* params an signed char* arguments, and viceversa. gcc4 now complaints loud about this. Patch below deletes all those 'signed'. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
