path: root/scripts/basic
2016-08-24fixdep: faster CONFIG_ searchAlexey Dobriyan
Do you think kernel build is 100% dominated by gcc? You are wrong! One small utility called "fixdep" consistently manages to sneak into profile's first page (unless you have small monitor of course). The choke point is this clever code: for (; m < end; m++) { if (*m == INT_CONF) { p = (char *) m ; goto conf; } if (*m == INT_ONFI) { p = (char *) m-1; goto conf; } if (*m == INT_NFIG) { p = (char *) m-2; goto conf; } if (*m == INT_FIG_) { p = (char *) m-3; goto conf; } 4 branches per 4 characters is not fast. Use strstr(3), so that SSE2 etc can be used. With this patch, fixdep is so deep at the bottom, it is hard to find it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-07-22scripts: Fix size mismatch of kexec_purgatory_sizeTautschnig, Michael
bin2c is used to create a valid C file out of a binary file where two symbols will be globally defined: <name> and <name>_size. <name> is passed as the first parameter of the host binary. Building using goto-cc reported that the purgatory binary code (the only current user of this utility) declares kexec_purgatory_size as 'size_t' where bin2c generate <name>_size to be 'int' so in a 64-bit host where sizeof(size_t) > sizeof(int) this type mismatch will always yield the wrong value for big-endian architectures while for little-endian it will be wrong if the object laid in memory directly after kexec_purgatory_size contains non-zero value at the time of reading. This commit changes <name>_size to be size_t instead. Note: Another way to fix the problem is to change the type of kexec_purgatory_size to be 'int' as there's this check in code: (kexec_purgatory_size <= 0) Signed-off-by: Michael Tautschnig <tautschn@amazon.com> Cc: Vivek Goyal <vgoyal@redhat.com> Acked-by: Dave Young <dyoung@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-03-29kbuild: add fine grained build dependencies for exported symbolsNicolas Pitre
Like with kconfig options, we now have the ability to compile in and out individual EXPORT_SYMBOL() declarations based on the content of include/generated/autoksyms.h. However we don't want the entire world to be rebuilt whenever that file is touched. Let's apply the same build dependency trick used for CONFIG_* symbols where the time stamp of empty files whose paths matching those symbols is used to trigger fine grained rebuilds. In our case the key is the symbol name passed to EXPORT_SYMBOL(). However, unlike config options, we cannot just use fixdep to parse the source code for EXPORT_SYMBOL(ksym) because several variants exist and parsing them all in a separate tool, and keeping it in synch, is not trivially maintainable. Furthermore, there are variants such as EXPORT_SYMBOL_GPL(pci_user_read_config_##size); that are instanciated via a macro for which we can't easily determine the actual exported symbol name(s) short of actually running the preprocessor on them. Storing the symbol name string in a special ELF section doesn't work for targets that output assembly or preprocessed source. So the best way is really to leverage the preprocessor by having it output actual symbol names anchored by a special sequence that can be easily filtered out. Then the list of symbols is simply fed to fixdep to be merged with the other dependencies. That implies the preprocessor is executed twice for each source file. A previous attempt relied on a warning pragma for each EXPORT_SYMBOL() instance that was filtered apart from stderr by the build system with a sed script during the actual compilation pass. Unfortunately the preprocessor/compiler diagnostic output isn't stable between versions and this solution, although more efficient, was deemed too fragile. Because of the lowercasing performed by fixdep, there might be name collisions triggering spurious rebuilds for similar symbols. But this shouldn't be a big issue in practice. (This is the case for CONFIG_* symbols and I didn't want to be different here, whatever the original reason for doing so.) To avoid needless build overhead, the exported symbol name gathering is performed only when CONFIG_TRIM_UNUSED_KSYMS is selected. Signed-off-by: Nicolas Pitre <nico@linaro.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au>
2016-03-29fixdep: accept extra dependencies on stdinNicolas Pitre
... and merge them in the list of parsed dependencies. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2016-02-17kbuild: fixdep: Check fstat(2) return valueTom Rini
Coverity has recently added a check that will find when we don't check the return code from fstat(2). Copy/paste the checking logic that print_deps() has with an appropriate re-wording of the perror() message. Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2015-12-07fixdep: constify strrcmp argumentsNicolas Iooss
strrcmp only performs read access to the memory addressed by its arguments so make them const pointers. Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Signed-off-by: Michal Marek <mmarek@suse.com>
2015-08-24kbuild: fixdep: drop meaningless hash table initializationMasahiro Yamada
The clear_config() is called just once at the beginning of this program, but the global variable hashtab[] is already zero-filled at the start-up. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2015-08-24kbuild: fixdep: optimize code slightlyMasahiro Yamada
If the target string matches "CONFIG_", move the pointer p forward. This saves several 7-chars adjustments. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2014-08-08kernel: build bin2c based on config option CONFIG_BUILD_BIN2CVivek Goyal
currently bin2c builds only if CONFIG_IKCONFIG=y. But bin2c will now be used by kexec too. So make it compilation dependent on CONFIG_BUILD_BIN2C and this config option can be selected by CONFIG_KEXEC and CONFIG_IKCONFIG. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Dave Young <dyoung@redhat.com> Cc: WANG Chao <chaowang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08bin2c: move bin2c in scripts/basicVivek Goyal
This patch series does not do kernel signature verification yet. I plan to post another patch series for that. Now distributions are already signing PE/COFF bzImage with PKCS7 signature I plan to parse and verify those signatures. Primary goal of this patchset is to prepare groundwork so that kernel image can be signed and signatures be verified during kexec load. This should help with two things. - It should allow kexec/kdump on secureboot enabled machines. - In general it can help even without secureboot. By being able to verify kernel image signature in kexec, it should help with avoiding module signing restrictions. Matthew Garret showed how to boot into a custom kernel, modify first kernel's memory and then jump back to old kernel and bypass any policy one wants to. This patch (of 15): Kexec wants to use bin2c and it wants to use it really early in the build process. See arch/x86/purgatory/ code in later patches. So move bin2c in scripts/basic so that it can be built very early and be usable by arch/x86/purgatory/ Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Dave Young <dyoung@redhat.com> Cc: WANG Chao <chaowang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-10kbuild: trivial - use tabs for code indent where possibleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-05kbuild: fixdep: support concatenated dep filesStephen Warren
The current use-case for fixdep is: a source file is run through a single processing step, which creates a single dependency file as a side-effect, which fixdep transforms into the file used by the kernel build process. In order to transparently run the C pre-processor on device-tree files, we wish to run both gcc -E and dtc on a source file in a single rule. This generates two dependency files, which must be transformed together into the file used by the kernel build process. This change modifies fixdep so it can process the concatenation of multiple separate input dependency files, and produce a correct unified output. The code changes have the slight benefit of transforming the loop in parse_dep_file() into more of a lexer/tokenizer, with the loop body being more of a parser. Previously, some of this logic was mixed together before the loop. I also added some comments, which I hope are useful. Benchmarking shows that on a cross-compiled ARM tegra_defconfig build, there is less than 0.5 seconds speed decrease with this change, on top of a build time of ~2m24s. This is probably within the noise. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Rob Herring <rob.herring@calxeda.com>
2013-01-09treewide: Fix typo in various driversMasanari Iida
Correct spelling typo in printk within various drivers. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-09fixdep: fix extraneous dependenciesPeter Foley
The introduction of include/linux/kconfig.h created 3 extraneous dependencies: include/config/.h include/config/h.h include/config/foo.h Fix this by excluding kconfig.h from fixdep calculations. Signed-off-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-02kbuild: move scripts/basic/docproc.c to scripts/docproc.cPeter Foley
Move docproc from scripts/basic to scripts so it is only built for *doc targets instead of every time the kernel is built.
2011-03-13kbuild: Fix computing srcversion for modulesMichal Marek
Recent change to fixdep: commit b7bd182176960fdd139486cadb9962b39f8a2b50 Author: Michal Marek <mmarek@suse.cz> Date: Thu Feb 17 15:13:54 2011 +0100 fixdep: Do not record dependency on the source file itself changed the format of the *.cmd files without realizing that it is also used by modpost. Put the path to the source file to the file back, in a special variable, so that modpost sees all source files when calculating srcversion for modules. Reported-and-tested-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-21fixdep: Do not record dependency on the source file itselfMichal Marek
The dependency is already expressed by the Makefiles, storing it in the .cmd file breaks build if a .c file is replaced by .S or vice versa, because the .cmd file contains foo/bar.o: foo/bar.c ... foo/bar.c ... : so the foo/bar.c -> foo/bar.o rule triggers even if there is no foo/bar.c anymore. Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-22Make fixdep error handling more explicitBen Gamari
Also add missing error handling to fstat call Signed-off-by: Ben Gamari <bgamari.foss@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-14Merge commit 'v2.6.37-rc1' into kbuild/kbuildMichal Marek
2010-11-11fixdep: use hash table instead of a single arrayEric Dumazet
I noticed fixdep uses ~2% of cpu time in kernel build, in function use_config() fixdep spends a lot of cpu cycles in linear searches in its internal string array. With about 400 stored strings per dep file, this begins to be noticeable. Convert fixdep to use a hash table. kbuild results on my x86_64 allmodconfig Before patch : real 10m30.414s user 61m51.456s sys 8m28.200s real 10m12.334s user 61m50.236s sys 8m30.448s real 10m42.947s user 61m50.028s sys 8m32.380s After: real 10m8.180s user 61m22.506s sys 8m32.384s real 10m35.039s user 61m21.654s sys 8m32.212s real 10m14.487s user 61m23.498s sys 8m32.312s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-28Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (39 commits) Revert "namespace: add source file location exceptions" Coccinelle: Add contextual message Coccinelle: Fix documentation Coccinelle: Find doubled arguments to boolean or bit operators. Coccinelle: Find nested lock+irqsave functions that use the same flags variables. namespace: add source file location exceptions scripts/extract-ikconfig: add support for bzip2, lzma and lzo kbuild: check return value of asprintf() scripts/namespace.pl: improve to get more correct results scripts/namespace.pl: some bug fixes scripts/namespace.pl: update file exclusion list scripts/namespace.pl: fix wrong source path Coccinelle: Use the -no_show_diff option for org and report mode Coccinelle: Add a new mode named 'chain' Coccinelle: Use new comment format to explain kfree.cocci Coccinelle: Improve user information with a new kind of comment Coccinelle: Update documentation MAINTAINERS: Coccinelle: Update email address Documentation/kbuild: modules.txt cleanup Documentation/kbuild: major edit of modules.txt sections 5-8 ...
2010-10-28kbuild: check return value of asprintf()Namhyung Kim
Check return value of asprintf() in docsect() and exit if error occurs. This removes following warning: HOSTCC scripts/basic/docproc scripts/basic/docproc.c: In function ‘docsect’: scripts/basic/docproc.c:336: warning: ignoring return value of ‘asprintf’, declared with attribute warn_unused_result Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-09-22jump label: Convert dynamic debug to use jump labelsJason Baron
Convert the 'dynamic debug' infrastructure to use jump labels. Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <b77627358cea3e27d7be4386f45f66219afb8452.1284733808.git.jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-09-11docbook: warn on unused doc entriesJohannes Berg
When you don't use !E or !I but only !F, then it's very easy to miss including some functions, structs etc. in documentation. To help finding which ones were missed, allow printing out the unused ones as warnings. For example, using this on mac80211 yields a lot of warnings like this: Warning: didn't use docs for DOC: mac80211 workqueue Warning: didn't use docs for ieee80211_max_queues Warning: didn't use docs for ieee80211_bss_change Warning: didn't use docs for ieee80211_bss_conf when generating the documentation for it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12kbuild: move autoconf.h to include/generatedSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-21trivial: kbuild: remove extraneous blank line after declaration of usage()Trevor Keith
Signed-off-by: Trevor Keith <tsrk@tsrk.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: remove references to non-existent include/linux/config.hMarkus Heidelberg
Ignore drivers/staging/ since it is very likely that new drivers introduce it again. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-20kbuild: add static to prototypesTrevor Keith
Warnings found via gcc -Wmissing-prototypes. Signed-off-by: Trevor Keith <tsrk@tsrk.net> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-20kbuild: fix build error during make htmldocsAmerigo Wang
Fix the following build error when do 'make htmldocs': DOCPROC Documentation/DocBook/debugobjects.xml exec /scripts/kernel-doc: No such file or directory exec /scripts/kernel-doc: No such file or directory Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-14kbuild: fix a compile warningAmerigo Wang
gcc-4.4.1: HOSTCC scripts/basic/fixdep scripts/basic/fixdep.c: In function 'traps': scripts/basic/fixdep.c:377: warning: dereferencing type-punned pointer will break strict-aliasing rules scripts/basic/fixdep.c:379: warning: dereferencing type-punned pointer will break strict-aliasing rules (Apparently -fno-strict-aliasing will fix this too) Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09kbuild: allow docproc invocation from externalJiri Slaby
- getcwd returns path without a slash at the end, add the slash - add KBUILD_SRC env support, so that we can specify path for kernel (to know where scripts/kernel-doc resides) and SRCTREE (for searching files referenced in .tmpl) separately [v2] - use KBUILD_SRC instead of a newly introduced environment variable Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-10-20Update .gitignore files for generated targetsLinus Torvalds
The generated 'capflags.c' file wasn't properly ignored, and the list of files in scripts/basic/ wasn't up-to-date. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16driver core: basic infrastructure for per-module dynamic debug messagesJason Baron
Base infrastructure to enable per-module debug messages. I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes control of debugging statements on a per-module basis in one /proc file, currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG, is not set, debugging statements can still be enabled as before, often by defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set. The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls can be dynamically enabled/disabled on a per-module basis. Future plans include extending this functionality to subsystems, that define their own debug levels and flags. Usage: Dynamic debugging is controlled by the debugfs file, <debugfs>/dynamic_printk/modules. This file contains a list of the modules that can be enabled. The format of the file is as follows: <module_name> <enabled=0/1> . . . <module_name> : Name of the module in which the debug call resides <enabled=0/1> : whether the messages are enabled or not For example: snd_hda_intel enabled=0 fixup enabled=1 driver enabled=0 Enable a module: $echo "set enabled=1 <module_name>" > dynamic_printk/modules Disable a module: $echo "set enabled=0 <module_name>" > dynamic_printk/modules Enable all modules: $echo "set enabled=1 all" > dynamic_printk/modules Disable all modules: $echo "set enabled=0 all" > dynamic_printk/modules Finally, passing "dynamic_printk" at the command line enables debugging for all modules. This mode can be turned off via the above disable command. [gkh: minor cleanups and tweaks to make the build work quietly] Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-28kernel-doc: new P directive for DOC: sectionsJohannes Berg
The !P directive includes the contents of a DOC: section given by title, e.g. !Pfilename Title of the section Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kernel-doc: use no-doc optionJohannes Berg
When asked by a template to include all functions from a file, it will also include DOC: sections wreaking havoc in the generated docbook file. This patch makes it use the new -no-doc-sections flag for kernel-doc to avoid this. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-18kbuild: stop docproc segfaulting when SRCTREE isn't set.Rob Landley
Prevent docproc from segfaulting when SRCTREE isn't set. Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12docproc: style & typo cleanupsRandy Dunlap
- fix typos/spellos in docproc.c and Makefile - add a little whitespace {while, switch} (coding style) - use NULL instead of 0 for pointer testing Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-02kbuild: scripts/basic/fixdep segfault on pathological string-o-deathAndy Green
build scripts: fixdep blows segfault on string CONFIG_MODULE seen The string "CONFIG_MODULE" appearing anywhere in a source file causes fixdep to segfault. This string appeared in the wild in the current mISDN sources (I think they meant CONFIG_MODULES). But it shouldn't segfault (esp as CONFIG_MODULE appeared in a quoted string). Signed-off-by: Andy Green <andy@warmcat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-04-01[PATCH] kbuild: fix dependency generationJan Beulich
Commit 2e3646e51b2d6415549b310655df63e7e0d7a080 changed the way the split config tree is built, but failed to also adjust fixdep accordingly - if changing a config option from or to m, files referencing the respective CONFIG_..._MODULE (but not the corresponding CONFIG_...) didn't get rebuilt. The problem is that trisate symbol are represent with three different symbols: SYMBOL=n => no symbol defined SYMBOL=y => CONFIG_SYMBOL defined to '1' SYMBOL=m => CONFIG_SYMBOL_MODULE defined to '1' But conf_split_config do not distingush between the =y and =m case, so only the =y case is honoured. This is fixed in fixdep so when a CONFIG symbol with _MODULE is found we skip that part and only look for the CONFIG_SYMBOL version. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-03[PATCH] update some docbook commentsRandy Dunlap
Correct a few comments in kernel-doc Doc and source files. (akpm: note: the patch removes a non-ascii character and might have to be applied by hand..) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] docbook: fix segfault in docproc.cHenrik Kretzschmar
Adds a missing exit, if the file that should be parsed couldn't be opened. Without it crashes with a segfault, cause the filedescriptor is accessed even if the file could not be opened. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09kconfig: integrate split config into silentoldconfigRoman Zippel
Now that kconfig can load multiple configurations, it becomes simple to integrate the split config step, by simply comparing the new .config file with the old auto.conf (and then saving the new auto.conf). A nice side effect is that this saves a bit of disk space and cache, as no data needs to be read from or saved into the splitted config files anymore (e.g. include/config is now 648KB instead of 5.2MB). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-19kbuild: consolidate command line escapingJan Beulich
While the recent change to also escape # symbols when storing C-file compilation command lines was helpful, it should be in effect for all command lines, as much as the dollar escaping should be in effect for C-source compilation commands. Additionally, for better readability and maintenance, consolidating all the escaping (single quotes, dollars, and now sharps) was also desirable. Signed-Off-By: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-25kbuild: escape '#' in .target.cmd filesSam Ravnborg
Commandlines are contained in the .<target>.cmd files and in case they contain a '#' char make see this as start of comment. Teach fixdep to escape the '#' char so make will assing the full commandline. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-10-18Add some basic .gitignore filesLinus Torvalds
This still leaves driver and architecture-specific subdirectories alone, but gets rid of the bulk of the "generic" generated files that we should ignore. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Kill signed charsJ.A. Magallon
scripts/ is full of mismatches between char* params an signed char* arguments, and viceversa. gcc4 now complaints loud about this. Patch below deletes all those 'signed'. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
