path: root/scripts/bloat-o-meter
2016-11-11scripts/bloat-o-meter: fix SIGPIPEAlexey Dobriyan
Fix piping output to a program which quickly exits (read: head -n1) $ ./scripts/bloat-o-meter ../vmlinux-000 ../obj/vmlinux | head -n1 add/remove: 0/0 grow/shrink: 9/60 up/down: 124/-305 (-181) close failed in file object destructor: sys.excepthook is missing lost sys.stderr Link: http://lkml.kernel.org/r/20161028204618.GA29923@avx2 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26scripts/bloat-o-meter: fix percent on <1% changesRiku Voipio
Python divisions are integer divisions unless at least one parameter is a float. The current bloat-o-meter fails to print sub-percentage changes: Total: Before=10515408, After=10604060, chg 0.000000% Force float division by using one float and pretty the print to two significant decimals: Total: Before=10515408, After=10604060, chg +0.84% Link: http://lkml.kernel.org/r/1465980311-23814-1-git-send-email-riku.voipio@linaro.org Signed-off-by: Riku Voipio <riku.voipio@linaro.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19scripts/bloat-o-meter: print percent changeVineet Gupta
This adds an additional line of output (to reduce the chances of breaking any existing output parsers) which prints the total size before and after and the relative difference. add/remove: 39/0 grow/shrink: 12408/55 up/down: 362227/-1430 (360797) function old new delta ext4_fill_super 10556 12590 +2034 _fpadd_parts - 1186 +1186 ntfs_fill_super 5340 6164 +824 ... ... __divdf3 752 386 -366 unlzma 3682 3274 -408 Total: Before=5023101, After=5383898, chg 7.000000% ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Link: http://lkml.kernel.org/r/1463124110-30314-1-git-send-email-vgupta@synopsys.com Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14scripts/bloat-o-meter: fix python3 syntax errorSergey Senozhatsky
In Python3+ print is a function so the old syntax is not correct anymore: $ ./scripts/bloat-o-meter vmlinux.o vmlinux.o.old File "./scripts/bloat-o-meter", line 61 print "add/remove: %s/%s grow/shrink: %s/%s up/down: %s/%s (%s)" % \ ^ SyntaxError: invalid syntax Fix by calling print as a function. Tested on python 2.7.11, 3.5.1 Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-23bloat-o-meter: Ignore syscall aliases SyS_ and compat_SyS_Josh Triplett
This avoids double-counting size changes in syscall implementations. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2013-11-07scripts/bloat-o-meter: use .startswith rather than fragile slicingJosh Triplett
str.startswith has existed since at least Python 2.0, in 2000; use it rather than a fragile comparison against an initial slice of a string, which requires hard-coding the length of the string to compare against. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-11-07scripts/bloat-o-meter: ignore changes in the size of linux_bannerJosh Triplett
linux_banner can change size due to changes in the compiler, build number, or the user@host the system was compiled on; ignore size changes in linux_banner entirely. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-11-06kbuild, bloat-o-meter: fix static detectionAndi Kleen
Disable static detection: the static currently drops a lot of useful information including clones generated by gcc. Drop this. The statics will appear now without static. prefix. But remove the LTO .NUMBER postfixes that look ugly Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-22bloat-o-meter: include read-only data section in reportJean Delvare
I'm not sure why the read-only data section is excluded from the report, it seems as relevant as the other data sections (b and d). I've stripped the symbols starting with __mod_ as they can have their names dynamically generated and thus comparison between binaries is not possible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17fix bloat-o-meter for ppc64Nathan Lynch
bloat-o-meter assumes that a '.' anywhere in a symbol's name means that it is static and prepends 'static.' to the first part of the symbol name, discarding the portion of the name that follows the '.'. However, the names of function entry points begin with '.' in the ppc64 ABI. This causes all function text size changes to be accounted to a single 'static.' entry in the output when comparing ppc64 kernels. Change getsizes() to ignore the first character of the symbol name when searching for '.'. Signed-off-by: Nathan Lynch <ntl@pobox.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-25[PATCH] bloat-o-meter: gcc-4 fixRob Landley
Upgrade scripts/bloat-o-meter to handle the names gcc 4 gives static symbols. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11kbuild: fix mode of checkstack.pl and other files.Paolo 'Blaisorblade' Giarrusso
Make it executable like it should be. Do the same for other files intended to be executed by the user - the ones called by the build process needn't be executable as they already work (as argument to their interpreter). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-08[PATCH] tiny: Add bloat-o-meter to scriptsMatt Mackall
This is a rewrite of Andi Kleen's bloat-o-meter with sorting and reporting of gainers/decliners. Sample output: add/remove: 0/8 grow/shrink: 2/0 up/down: 88/-4424 (-4336) function old new delta __copy_to_user_ll 59 103 +44 __copy_from_user_ll 59 103 +44 fill_note 32 - -32 maydump 58 - -58 dump_seek 67 - -67 writenote 180 - -180 elf_dump_thread_status 274 - -274 fill_psinfo 308 - -308 fill_prstatus 466 - -466 elf_core_dump 3039 - -3039 The summary line says: no functions added, 8 removed two functions grew, none shrunk we gained 88 bytes and lost 4424 (or -4336 net) This work was sponsored in part by CE Linux Forum Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
