path: root/scripts/checkpatch.pl
2008-07-24checkpatch: version 0.21Andy Whitcroft
Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: types cannot start mid word for pointer testsAndy Whitcroft
When checking spacing for pointer checks the type cannot start in the middle of a word, ie. this is not 'int * bar': x = fooint * bar; Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: complex macros need to ignore commentsAndy Whitcroft
Ensure we ignore comments in complex macro detection else we incorrectly report this: #define PFM_GROUP_PERM_ANY -1 /* any user/group */ Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: variants -- move the main unary/binary operators to use variantsAndy Whitcroft
Now that we have a variants system, move to using that to carry the unary/binary designation for +, -, &, and *. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: add checks for question mark and colon spacingAndy Whitcroft
Add checks for the question mark colon operator spacing, and also check the other uses of colon. Colon means a number of things: - it introduces the else part of the ?: operator, - it terminates a goto label, - it terminates the case value, - it separates the identifier from the bit size on bit fields, and - it is used to introduce option types in asm(). Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: possible modifiers -- handle multiple modifiers and trailingAndy Whitcroft
Add support for multiple modifiers such as: int __one __two foo; Also handle trailing known modifiers when defecting modifiers: int __one foo __read_mostly; Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: possible types -- known modifiers cannot be typesAndy Whitcroft
Ensure we do not inadvertantly load known modifiers up as possible types. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: handle return types of pointers to functionsAndy Whitcroft
Make sure we correctly mark the return type of the pointer to a function declaration. const void *(*sb_tag)(struct sysfs_tag_info *info); Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: macro complexity checks are meaningless in linker scriptsAndy Whitcroft
Exclude vmlinux.lds.h from the macro complexity checks. They will never apply sanely here. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: possible modifiers are not being correctly matchedAndy Whitcroft
Although we are finding the added modifier in the declaration below we are not correctly matching it as a type. Fix the declaration. static void __ref *vmem_alloc_pages(unsigned int order) { } Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: improve type matcher debugAndy Whitcroft
Improve type matcher debug so we can see what it does match. As part of this move us to to using the common debug framework. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: allow for type modifiers on multiple declarationsAndy Whitcroft
Allow for type modifiers mid declaration on multiple declarations: struct mxser_mstatus ms, __user *msu = argp; Reported by Jiri Slaby. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: correct spelling in kfree checksWolfram Sang
Correct spelling in the kfree reports. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: usb_free_urb() can take NULLGreg Kroah-Hartman
usb_free_urb() can take a NULL, so let's check and warn about that. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: condition/loop indent checksAndy Whitcroft
Check to see if the block/statement which a condition or loop introduces is indented correctly. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: toughen trailing if statement checks and extend them to while ↵Andy Whitcroft
and for Extend the trailing statement checks to report a trailing semi-colon ';' as we really want it on the next line and indented so it is really really obvious. Also extend the tests to include while and for. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: check spacing for square bracketsAndy Whitcroft
Check on the spacing before square brackets. We should only allow spaces there if this is part of a type definition or an initialialiser. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: switch -- report trailing statements on case and defaultAndy Whitcroft
Report trailing statements on case and default lines. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: allow printk strings to exceed 80 characters to maintain their ↵Andy Whitcroft
searchability Allow printk strings to break the 80 character width limits, thus keeping them complete and searchable. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: trailing statement indent: fix end of statement locationAndy Whitcroft
Fix end of statement location. Where the last line of the statement is replaced we are miss reporting the newly added replacement an incorrectly indented trailing statement for the negative context. We are also incorrectly reporting negative statements generally. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: macros: fix statement counting block end detectionAndy Whitcroft
We are incorrectly counting the lines in a block while accumulating the trailing lines in a macro statement, leading to false positives. Fix end of block handling and general counting for negative context lines. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: types: unary -- goto introduces unary contextAndy Whitcroft
When we see a goto we enter unary context. For example: goto *h; Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: comment detection: ignore macro continuation when detecting ↵Andy Whitcroft
associated comments When looking for an associated comment they may be suffixed by a macro continuation. Ignore this. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: possible types: __asm__ is never a typeAndy Whitcroft
We are false matching __asm__ as a type, and then tripping the external function checks. Squash. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: add a checkpatch warning for new uses of __initcall().Michael Ellerman
[apw@shadowen.org: generalise pattern and add tests] Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: types: some types may also be identifiersAndy Whitcroft
Some types such as typedefs may overlap real identifiers. Be more targetted about when a type can really exist. Where it cannot let it be an identifier. This prevents false reporting of the minus '-' in unary context in the following: foo[bar->bool - 1]; Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: return is not a function -- parentheses for casts are ok tooAndy Whitcroft
Casts require parentheses so it is possible to have something like this: return (int)(*a); This miss trips the complexity function. Ensure that the two separate parenthesised sections are not coelesced. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24checkpatch: Version: 0.20Andy Whitcroft
2008-06-06update checkpatch.pl to version 0.19Andy Whitcroft
This version is a bit of a whopper. This version brings a few new checks, improvements to a number of checks mostly through modifications to the way types are parsed, several fixes to quote/comment handling, as well as the usual slew of fixes for false positives. Of note: - return is not a function and is now reported, - preprocessor directive detection is loosened to match C99 standard, - we now intuit new type modifiers, and - comment handling is much improved Andy Whitcroft (18): Version: 0.19 fix up a couple of missing newlines in reports colon to parenthesis spacing varies on asm values: #include is a preprocessor statement quotes: fix single character quotes at line end add typedef exception for the non-pointer "function types" kerneldoc parameters must be on one line, relax line length types: word boundary is not always required improved #define bracketing reports uninitialized_var is an annotation not a function name possible types: add possible modifier handling possible types: fastcall is a type modifier types: unsigned is not a modifier on all types static/external initialisation to zero should allow modifiers checkpatch: fix recognition of preprocessor directives -- part 2 comments: fix inter-hunk comment tracking return is not a function do not report include/asm/foo.h use in include/linux/foo.h return is not a function -- tighten test [jengelh@computergmbh.de: fix recognition of preprocessor directives] Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29update checkpatch.pl to version 0.18Andy Whitcroft
This version brings a few fixes for the extern checks, and a couple of new checks. Of note: - false is now recognised as a 0 assignment in static/external assignments, - printf format strings including %L are reported, - a number of fixes for the extern in .c file detector which had temporarily lost its ability to detect variables; undetected due to the loss of its test. Andy Whitcroft (8): Version: 0.18 false should trip 0 assignment checks tests: reinstate missing tests tests: allow specification of the file extension for a test fix extern checks for variables check for and report %Lu, %Ld, and %Li ensure we only start a statement on lines with some content extern spacing Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29update checkpatch.pl to version 0.17Andy Whitcroft
This version brings improvements to external declaration detection, fixes to quote tracking, fixes to unary tracking, some clarification of wording, and the usual slew of fixes for false positives. Of note: - much better unary tracking across preprocessor directives - UTF8 checks highlight the character at fault - widening of mutex detection Andy Whitcroft (17): Version: 0.17 values: __attribute__ carries through the previous type quotes: should only follow "positive" lines clarify the indent tabs over spaces wording loosen NR_CPUS check for array range initialisers detect external function declarations without an extern prefix function declaration arguments should be with the identifier DEFINE_MUTEX should report in line with struct mutex NR_CPUS is valid in preprocessor statements comment detection should not start on the @@ line types: add support for #undef tighten mutex/completion reports to usage allow export of function pointers values: preprocessor #define is out of line maintain values values: #define does not always have parentheses unary '*' may be const utf8 checks should report location of the invalid character Wolfram Sang (1): make checkpatch.pl really skip <asm/irq.h> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24checkpatch: usb_free_urb() can take NULLGreg Kroah-Hartman
2008-03-28update checkpatch.pl to version 0.16Andy Whitcroft
This version brings proper quote tracking across lines, and brings the handling of comments into the same mechanism ensuring nesting is correctly handled. It brings the usual flurry of fixes for false positives. It also brings a number of new checks. The most contentious change will likely be the checks for NR_CPUS as this throws some new warnings in kernel/sched.c. Of note: - all new quote tracking across lines - all new comment tracking - new more direct, less ambigious wording for some warnings - recommends mutexes and completions over semaphores - recommends strict_strto* over simple_strto* - report on direct use of NR_CPUS Andy Whitcroft (22): Version: 0.16 string quote tracking should cross line boundaries check spacing round -> correctly across newlines checks for linux/ against asm/ include files should be warnings standardise on 'required' and 'prohibited' take the first end of condition when parsing statements values: cope with unbalanced brackets preprocessor #elif is not a function preprocessor #if should not trigger trailing statement checks test: allow us to limit output to a single error recommend real mutexes over semaphores asm checks should mirror those for __asm__ warn on semaphores being used in place of completions trailing ; on control structure should ignore do {} while (); recommend strict_strtoX over simple_strtoX redo comment handling as a quote type use of NR_CPUS is normally wrong consistant spacing should only be about spaces if brace check suppression should only apply to the top-levels use tr/// to align spacing for operators move to using four parameter form of substr check and report modifications to include/asm Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04update checkpatch.pl to version 0.15Andy Whitcroft
This version brings a number of minor fixes updating the type detector and the unary tracker. It also brings a few small fixes for false positives. It also reverts the --file warning. Of note: - limit CVS checks to added lines - improved type detections - fixes to the unary tracker Andy Whitcroft (13): Version: 0.15 EXPORT_SYMBOL checks need to accept array variables export checks must match DECLARE_foo and LIST_HEAD possible types: cleanup debugging missing line values: track values through preprocessor conditional paths typeof is actually a type possible types: detect definitions which cross lines values: include line numbers on value debug information values: ensure we find correctly record pending brackets values: simplify the brace history stack CVS keyword checks should only apply to added lines loosen spacing for comments allow braces for single statement blocks with multiline conditionals Harvey Harrison (1): checkpatch: remove fastcall Ingo Molnar (1): checkpatch.pl: revert wrong --file message Uwe Kleine-Koenig (1): fix typo "goot" -> "good" Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Joel Schopp <jschopp@austin.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08update checkpatch.pl to version 0.14Andy Whitcroft
This version brings the remainder of the queued fixes. A number of fixes for items missed reported by Andrew Morton and others. Also a handful of new checks and fixes for false positives. Of note: - new warning associated with --file to try and avoid cleanup only patches, - corrected handling of completly empty files, - corrected report handling with multiple files, - handling of possible types in the face of multiple declarations, - detection of unnessary braces on complex if statements (where present), and - all new comment spacing handling. Andi Kleen (1): Introduce a warning when --file mode is used Andy Whitcroft (14): Version: 0.14 clean up some space violations in checkpatch.pl a completly empty file should not provoke a whinge reset report lines buffers between files unary ++/-- may abutt close braces __typeof__ is also unary comments: revamp comment handling add --summary-file option adding filename to summary line trailing backslashes are not trailing statements handle operators passed as parameters such as to ASSERTCMP possible types -- enhance debugging check for boolean operations with constants possible types: handle multiple declarations detect and report if statements where all branches are single statements Arjan van de Ven (1): quiet option should not print the summary on no errors Bartlomiej Zolnierkiewicz (1): warn about using __FUNCTION__ Timur Tabi (1): loosen spacing checks for __asm__ Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08update checkpatch.pl to version 0.13Andy Whitcroft
This version brings a large number of fixes which have built up over the Christmas period. Mostly these are fixes for false positives, both through improvments to unary checks and possible type detection. It also brings new checks for while location and CVS keywords. Of note: - a number of fixes to unary detection - detection of a number of new forms of types to improve type matching - better inline handling - recognision of '%' as an operator Andy Whitcroft (28): Version: 0.13 unary detection: maintain bracket state across lines move to pre-sanitising the entire file the text of a #error statement should be treated like it is in quotes line sanitisation needs to target double backslash correctly tighten comment guestimation for lines starting ' * ' debug: add a debug framework prevent unclosed single quotes from spreading add % as an operator the text of a #warning statement should be treated like it is in quotes possible matching applies in typedefs single statement block checks must not trigger when two or more statements possible types: local variables may also be const treat inline as a type attribute to even when out of place possible types: sparse annotations are valid indicators possible types: beef up the possible type testing check for hanging while statements on the wrong line utf8 checks need to occur against the raw lines function brace checks should use any whitespece matches comments should take up space in the line when sanitised remove debugging from if assignment checks possible types -- ensure we detect all pointer casts fix tests for function spacing in the presence of #define clean up the UTF-8 error message to be clearer test-lib: invert the status report, output success counts detect and report CVS keywords tests: break out tests Add $Id$ to the CVS keyword checks Benny Halevy (1): checkpatch.pl: recognize the #elif preprocessor directive Geert Uytterhoeven (1): print the filenames of patches where available Mauro Carvalho Chehab (1): Fix missing \n in checkpatch.pl Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29update checkpatch.pl to version 0.12Andy Whitcroft
This version brings a new terse output mode as well as many improvements to the unary detection and bare type regcognition. It also brings the usual updates for false positives, though these seem to be slowing markedly now that the unary detector is no longer just putting its finger in the air and guessing. Of note: - new --terse mode producing a single line per report - loosening of the block brace checks - new checks for enum/union/struch brace placements - hugely expanded "bare type" detection - checks for inline usage - better handling of already open comment blocks - handle patches which introduce or remove lines without newlines Andy Whitcroft (19): Version: 0.12 style fixes as spotted by checkpatch add a --terse options of a single line of output per report block brace checks should only apply for single line blocks all new bare type detector check spacing for open braces with enum, union and struct check for LINUX_VERSION_CODE macros definition bracketing checks need to ignore -ve context clean up the mail-back mode, -q et al expand possible type matching to declarations allow const and sparse annotations on possible types handle possible types as regular types everywhere prefer plain inline over __inline__ and __inline all new open comment detection fix up conditional extraction for if assignment checks add const to the possible type matcher unary checks: a for loop is a conditional too possible types: detect function pointer definitions handle missind newlines at end of file, report addition Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18update checkpatch.pl to version 0.11Andy Whitcroft
This version brings a more cautious checkpatch.pl by default. The more subjective checks are only applied with the --strict option. It also brings the usual slew of corrections for false positives. Of note: - new tree detection, the source tree will be found via the executable - a major revamp of the unary detection to make it more parser like - a new summary at the bottom of the report - --strict option for subjective checks - --file to enable checking on complete files - support for use in emacs "compile" window Andy Whitcroft (27): Version: 0.11 fix up cat_vet for the case where there are no control characters any cast to a pointer introduces a type cpp unary operator detection needs to float attributes are also valid in type definitions sizeof may be a bareword and makes its argument unary unary checks for #ifdef et al need to find end of line add new --file mode to handle raw source files add --strict/--subjective which enables the subjective tests add some additional standard type suffixes cpp #elif is also a unary prefix case is not a function name widen asm volatile exceptions __kprobes is a type attribute typeof is a unary operator function open parenthesis checks should check all occurances expand sizeof() binary exceptions linux/irq.h should not be recommended work harder to find the kernel root and add --root= fix --emacs mode line numbers and string concatenation warnings add a summary to the bottom of the main report loosen assignment in if checks update operator spacing to maintain tabs in output revamp unary detection corruption/line wrapped patches need only reporting once revamp s/u/be/le 8/16/32/64 bit types handle missing ,1 in uni-diff header Mike D. Day (2): Adds support to checkpatch.pl for running in the emacs compile window. checkpatch: Fix line number reporting Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17update checkpatch.pl to version 0.10Andy Whitcroft
This version brings a number of new checks, and a number of bug fixes. Of note: - better categorisation and space checks for dual use unary/binary operators - warn on deprecated use of {SPIN,RW}_LOCK_UNLOCKED - check if/for/while with trailing ';' for hanging statements - detect DOS line endings - detect redundant casts for kalloc() Andy Whitcroft (18): Version: 0.10 asmlinkage is also a storage type pull out inline specifiers allow only some operators before a unary operator parenthesised values may span line ends add additional attribute matching handle sparse annotations within pointer type space checks support alternative function definition syntax for typedefs check if/for/while with trailing ';' for hanging statements fix output format for case checks deprecate SPIN_LOCK_UNLOCKED and RW_LOCK_UNLOCKED allow complex macros with bracketing braces detect and report DOS line endings fastcall is a valid function attribute bracket spacing is ok for 'for' categorise operators into unary/binary/definitions add heuristic to pick up on unannotated types remove spurious warnings from cat_vet Dave Jones (1): Make checkpatch warn about pointless casting of kalloc returns. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11update checkpatch.pl to version 0.09Andy Whitcroft
This version brings a number of new checks, and a number of bug fixes. Of note: - checks for spacing on round and square bracket combinations - loosening of the single statement brace checks, to allow them when they contain comments or where other blocks in a compound statement have them. - parks the multple declaration support - allows architecture defines in architecture specific headers Andy Whitcroft (21): Version: 0.09 loosen single statement brace checks fix up multiple declaration to avoid function arguments add some function space parenthesis check exceptions handle EXPORT_'s with parentheses in their names clean up some warnings in multi-line macro bracketing support park the multiple declaration checks make block brace checks count comments as a statement __volatile__ and __extension__ are not functions allow architecture specific defined within architecture includes check spacing on square brackets check spacing on parentheses ensure we apply checks to the part before start comment check #ifdef conditional spacing handle __init_refok and __must_check add noinline to inline checks prevent email addresses from tripping spacing checks handle typed initialiser spacing handle line contination as end of line add bool to the type matcher refine EXPORT_SYMBOL checks to handle pointers Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19update checkpatch.pl to version 0.08Andy Whitcroft
This version brings a number of new checks, and a number of bug fixes. Of note: - warnings for multiple assignments per line - warnings for multiple declarations per line - checks for single statement blocks with braces This patch includes an update for feature-removal-schedule.txt to better target checks. Andy Whitcroft (12): Version: 0.08 only apply printk checks where there is a string literal allow suppression of errors for when no patch is found warn about multiple assignments warn on declaration of multiple variables check for kfree() with needless null check check for single statement braced blocks check for aggregate initialisation on the next line handle the => operator check for spaces between function name and open parenthesis move to explicit Check: entries in feature-removal-schedule.txt handle pointer attributes Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16update checkpatch.pl to version 0.07Andy Whitcroft
This version brings a number of new checks, fixes for flase positives, plus a clarification of the output to better guide use. Of note: - checks for documentation for new __setup calls - clearer reporting where braces and parenthesis are involved - reports for closing brace and semi-colon spacing - reports on unwanted externs This patch includes an update to the documentation on checkpatch.pl itself to clarify when it should be used and to indicate that it is not intended as the final arbitor of style. Full changelog: Andy Whitcroft (19): Version: 0.07 ensure we do not apply control brace checks to preprocesor directives add {u,s}{8,16,32,64} to the type matcher accept lack of spacing after the semicolons in for (;;) report new externs in .c files fix up typedef exclusion for function prototypes else trailing statements check need to account for \ at end of line add enums to the type matcher add missing check descriptions suppress double reporting of ** spacing report on do{ spacing issues include an example of the brace/parenthesis in output check for spacing after closing braces prevent double reports on pointer spacing issues handle blank continuation lines on macros classify all reports error, warning, or check revamp hanging { checks and apply in context no spaces after the last ; in a for is ok check __setup has a corresponding addition to documentation David Woodhouse (1): limit character set used in patches and descriptions to UTF-8 Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24update checkpatch.pl to version 0.06Andy Whitcroft
Update to checkpatch.pl v0.06. Of note: - do { and else handled correctly as control structures for { matching - trailing whitespace correctly tripped when line otherwise empty - support for const, including const foo * const bar - multiline macros defining values correctly reported This version of checkpatch.pl can be found at the following URL: http://www.kernel.org/pub/linux/kernel/people/apw/checkpatch/checkpatch.pl-0.06 Full Changelog: Andy Whitcroft (14): Version: 0.06 cleanup the Type regular expression declarations fix up block counting end of line counts as a space for ++ and -- do { needs the same checks as if, for et al handle "const foo * const a" as a valid type add spacing checks following ; complete whitespace lines should trip trailing whitespace check else is also a block control structure badly formatted else can trip function declaration detect and report trailing statements after else types need to be terminated by a boundary multiline macros defining values should be surrounded by parentheses soften the wording of the Signed-off-by: warnings Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24update checkpatch.pl to version 0.05Andy Whitcroft
This version brings a some new tests, and a host of changes to fix false positives, of particular note: - detect 'var ++;' and 'var --;' as a bad combination - multistatement #defines are now checked based on statement count - multistatement #defines with initialisation correctly reported - checks the location of the inline keywords - EXPORT_SYMBOL for variables are now understood - typedefs are loosened to handle sparse etc This version of checkpatch.pl can be found at the following URL: http://www.shadowen.org/~apw/public/checkpatch/checkpatch.pl-0.05 Full Changelog: Andy Whitcroft (18): Version: 0.05 macro definition checks should be for a single statement avoid assignements only in if conditionals declarations of function pointers need no space multiline macros which are purely initialisation cannot be wrapped EXPORT_SYMBOL can also directly follow a variable definition check on the location of the inline keyword EXPORT_SYMBOL needs to allow for attributes ensure we do not find C99 // in strings handle malformed #include lines accept the {0,} form typedefs are sensible for defining function pointer parameters ensure { handling correctly handles nested switch() statements trailing whitespace checks are not anchored typedefs for sparse bitwise annotations make sense update the type matcher to include sparse annotations clean up indent and spacing Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08update checkpatch.pl to version 0.04Andy Whitcroft
This version brings a some new tests, and a host of changes to fix false positives, of particular note: - check for and report #if 0 - extend checking of line lengths and spacing for .pl, .sh etc - extends the pointer type checks to multiple levels - updates printk handling to track newlines - adds a wrapped patch detector - drops the leading component of the filenames - extends switch indent handling to switch statmentes rooted in the context - adds foo * bar single pointer checks This version of checkpatch.pl can be found at the following URL: http://www.shadowen.org/~apw/public/checkpatch/checkpatch.pl-0.04 Full Changelog: Andy Whitcroft (16): allow checking line lengths and spacing on other source files clean up that whitespace sanitise the input line standardising the content of quotes clean up pointer type * and space checks fix up the sanitiser so it maintains the line length apply the printk facility checks only to the first printk in a set switch/case indent checks may anchor in the context add a wrapped patch detector put the #ifdef in C file checks on ice asm volatile is acceptable check for and report #if 0 drop the leading component of the filename as patches are -p1 use the original line when reporting operator errors correct spelling of Joel's name Version: 0.04 add support for struct foo * bar checks Geert Uytterhoeven (1): Fix checkpatch.pl name in usage template Randy Dunlap (1): checkpatch: produce fewer lines of output Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08checkpatch: produce fewer lines of outputRandy Dunlap
Produce one less line of output per flagged incident. Change this: use tabs not spaces PATCH: /home/rddunlap/arcmsr1200014.patch4:756: FILE: b/drivers/scsi/arcmsr/arcmsr_hba.c:1843: + return PCI_ERS_RESULT_NEED_RESET;$ to this: use tabs not spaces #756: FILE: b/drivers/scsi/arcmsr/arcmsr_hba.c:1843: + return PCI_ERS_RESULT_NEED_RESET;$ Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08update checkpatch.pl to version 0.03Andy Whitcroft
This version brings a host of changes to cure false positives and bugs detected on patches submitted to lkml and -mm. It also brings a number of new tests in response to reviews, of particular note: - catch use of volatile - allow deprecated functions to be listed in feature-removal-schedule.txt - warn about #ifdef's in c files - check that spinlock_t and struct mutex use is commented - report on architecture specific defines being used - report memory barriers without an associated comment Full changelog: catch use of volatile convert other quoted string checks to common routine alloc deprecated functions to be listed in feature-removal-schedule.txt split out the line length and indent for each line improve switch block handling handle GNU diff context lines with no leading space warn about #ifdef's in c files tidy up tests for signed-off-by using raw mode check that spinlock_t and struct mutex use is commented syntax checks for open brace placement may drop off the bottom of hunk report memory barriers without an associated comment when a sign off is present but ugly do not report it missing do not mistake bitfield definitions for indented labels report on architecture specific defines being used major update to the operator checks prevent switch/if/while etc matching foo_switch generify assignement in condition error message introduce an operator context marker Version: 0.03 Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-07checkpatch.pl: should be executableAndy Whitcroft
scripts/checkpatch.pl should be executable, make it so. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01add a trivial patch style checkerAndy Whitcroft
We are seeing increasing levels of minor patch style violations in submissions to the mailing lists as well as making it into the tree. These detract from the quality of the submission and cause unnessary work for reviewers. As a first step package up the current state of the patch style checker and include it in the kernel tree. Add instructions suggesting running it on submissions. This adds version v0.01 of the checkpatch.pl script. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Joel Schopp <jschopp@austin.ibm.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
