path: root/scripts/docproc.c
2011-06-16docproc: cleanup brace placementJesper Juhl
The placement of the opening brace "{" after 'if' statements in scripts/docproc.c is inconsistent. Most are placed on the same line as the 'if' statement itself as per CodingStyle, but a few are not. This patch cleans up the inconsistency. We save a few source lines and the file then uses the same style throughout, which is nice. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-02kbuild: move scripts/basic/docproc.c to scripts/docproc.cPeter Foley
Move docproc from scripts/basic to scripts so it is only built for *doc targets instead of every time the kernel is built.
