path: root/scripts/dtc/dtc-parser.tab.c_shipped
2011-01-03of/flattree: Update dtc to current mainline.John Bonesio
Pull in recent changes from the main dtc repository. These changes primarily allow multiple device trees to be declared which are merged by dtc. This feature allows us to include a basic dts file and then provide more information for the specific system through the merging functionality. Changes pulled from git://git.jdl.com/software/dtc.git commit id: 37c0b6a0, "dtc: Add code to make diffing trees easier" Signed-off-by: John Bonesio <bones@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
