path: root/scripts/dtc
2013-06-13dtc: ensure #line directives don't consume data from the next lineGrant Likely
Previously, the #line parsing regex ended with ({WS}+[0-9]+)?. The {WS} could match line-break characters. If the #line directive did not contain the optional flags field at the end, this could cause any integer data on the next line to be consumed as part of the #line directive parsing. This could cause syntax errors (i.e. #line parsing consuming the leading 0 from a hex literal 0x1234, leaving x1234 to be parsed as cell data, which is a syntax error), or invalid compilation results (i.e. simply consuming literal 1234 as part of the #line processing, thus removing it from the cell data). Fix this by replacing {WS} with [ \t] so that it can't match line-breaks. Convert all instances of {WS}, even though the other instances should be irrelevant for any well-formed #line directive. This is done for consistency and ultimate safety. [Cherry picked from DTC commit a1ee6f068e1c8dbc62873645037a353d7852d5cc] Reported-by: Ian Campbell <Ian.Campbell@citrix.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-06-13dtc: Update generated files to output from Bison 2.5Grant Likely
This patch merely updates the generated dtc parser and lexer files to the output generated by Bison 2.5. The previous versions were generated from version 2.4.1. The only reason for this commit is to minimize the diff on the next commit which fixes a bug in the DTC #line directive parsing. Otherwise the Bison changes would be intermingled with the functional changes. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-11-21script: dtc: clean generated filesMagnus Damm
Fix "make distclean" to clean up generated dtc files. Without this patch the following files are left around: - dtc-lexer.lex.c - dtc-parser.tab.c - dtc-parser.tab.h Signed-off-by: Magnus Damm <damm@opensource.se> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-10-17dtc: fix for_each_*() to skip first object if deletedStephen Warren
The previous definition of for_each_*() would always include the very first object within the list, irrespective of whether it was marked deleted, since the deleted flag was not checked on the first object, but only on any "next" object. Fix for_each_*() to check the deleted flag in the loop body every iteration to correct this. (upstream dtc commit 1762ab42ef77db7ab2776d0d6cba3515150f518a) Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-10-01dtc: import latest upstream dtcStephen Warren
This updates scripts/dtc to commit 317a5d9 "dtc: zero out new label objects" from git://git.jdl.com/software/dtc.git. This adds features such as: * /bits/ syntax for cell data. * Math expressions within cell data. * The ability to delete properties or nodes. * Support for #line directives in the input file, which allows the use of cpp on *.dts. * -i command-line option (/include/ path) * -W/-E command-line options for error/warning control. * Removal of spew to STDOUT containing the filename being compiled. * Many additions to the libfdt API. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Jon Loeliger <jdl@jdl.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-24scripts: dtc: fix compile warningsFelipe Balbi
Fix following compile warnings: scripts/dtc/flattree.c: In function ‘flat_read_mem_reserve’: scripts/dtc/flattree.c:700:14: warning: variable ‘p’ set but not used [-Wunused-but-set-variable] scripts/dtc/dtc.c: In function ‘main’: scripts/dtc/dtc.c:104:17: warning: variable ‘check’ set but not used [-Wunused-but-set-variable] Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14dtc: Implement -d option to write out a dependency fileStephen Warren
This will allow callers to rebuild .dtb files when any of the /include/d .dtsi files are modified, not just the top-level .dts file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-09dtc: regen parserArnaud Lacombe
Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09dtc: migrate parser to implicit rulesArnaud Lacombe
2011-01-03of/flattree: Update dtc to current mainline.John Bonesio
Pull in recent changes from the main dtc repository. These changes primarily allow multiple device trees to be declared which are merged by dtc. This feature allows us to include a basic dts file and then provide more information for the specific system through the merging functionality. Changes pulled from git://git.jdl.com/software/dtc.git commit id: 37c0b6a0, "dtc: Add code to make diffing trees easier" Signed-off-by: John Bonesio <bones@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-02scripts/dtc: Fix a resource leakMartin Ettl
during a check of the current git head of the linux kernel with the static code analysis tool cppcheck (http://sourceforge.net/apps/mediawiki/cppcheck/index.php?title=Main_Page) the tool discovered a resource leak in linux-2.6/scripts/dtc/fstree.c. Please refer the attached patch, that fixes the issue. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=15363 Signed-off-by: Martin Ettl <ettl.martin@gmx.de> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-11-15dtc: Mark various internal functions staticJosh Triplett
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-15dtc: Set "noinput" in the lexer to avoid an unused functionJosh Triplett
Regenerate the corresponding generated lexer. Regenerating the lexer with current flex also provides prototypes for various yy* functions, making some -Wmissing-prototypes warnings go away as well. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-06-26powerpc: Have git ignore generated files from dtc compileJon Smirl
Have git ignore generated files from dtc compile Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
