path: root/scripts/dtc
2016-07-22scripts/dtc: dt_to_config - kernel config options for a devicetreeGaurav Minocha
Determining which kernel config options need to be enabled for a given devicetree can be a painful process. Create a new tool to find the drivers that may match a devicetree node compatible, find the kernel config options that enable the driver, and optionally report whether the kernel config option is enabled. Signed-off-by: Gaurav Minocha <gaurav.minocha.os@gmail.com> Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-03-29scripts/dtc: Update to upstream version 53bf130b1cddRob Herring
Sync to upstream dtc commit 53bf130b1cdd ("libfdt: simplify fdt_node_check_compatible()"). This adds the following commits from upstream: 53bf130 libfdt: simplify fdt_node_check_compatible() c9d9121 Warn on node name unit-address presence/absence mismatch 2e53f9d Catch unsigned 32bit overflow when parsing flattened device tree offsets Signed-off-by: Rob Herring <robh@kernel.org>
2016-02-11scripts/dtc: Update to upstream commit b06e55c88b9bRob Herring
Sync to upstream dtc commit b06e55c88b9b ("Prevent crash on modulo by zero"). This adds the following commits from upstream: b06e55c Prevent crash on modulo by zero b433450 Fix some bugs in processing of line directives d728ad5 Fix crash on nul character in string escape sequence 1ab2205 Gracefully handle bad octal literals 1937095 Prevent crash on division by zero d0b3ab0 libfdt: Fix undefined behaviour in fdt_offset_ptr() d4c7c25 libfdt: check for potential overrun in _fdt_splice() f58799b libfdt: Add some missing symbols to version.lds af9f26d Remove duplicated -Werror in dtc Makefile 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings 554fde2 libfdt: fix comment block of fdt_get_property_namelen() e5e6df7 fdtdump: Fix bug printing bytestrings with negative values 067829e Remove redundant fdtdump test code 897a429 Move fdt_path_offset alias tests to right tests section 2d1417c Add simple .travis.yml f6dbc6c guess output file format 5e78dff guess input file format based on file content or file name 8b927bf tests: convert `echo -n` to `printf` 64c46b0 Fix crash with poorly defined #size-cells Cc: Grant Likely <grant.likely@linaro.org> Tested-by: Frank Rowand <frank.rowand@sonymobile.com> Reviewed-by: Frank Rowand <frank.rowand@sonymobile.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-02-11scripts/dtc: dtx_diff - add info to error messageFrank Rowand
If kernel config options are not properly set, "make scripts" will not compile dtc. Update the unable to find dtc error message to check the kernel config and give better advice on how to create dtc. Reword another error message to increase clarity. Signed-off-by: Frank Rowand <frank.rowand@sonymobile.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-01-25dtc: create tool to diff device treesFrank Rowand
Create script to diff device trees. The device tree can be in any of the forms recognized by the dtc compiler: - source - binary blob - file system tree (from /proc/devicetree) If the device tree is a source file, then it is pre-processed in the same way as it would be when built in the linux kernel source tree before diffing. Signed-off-by: Frank Rowand <frank.rowand@sonymobile.com> Signed-off-by: Rob Herring <robh@kernel.org>
2015-04-29scripts/dtc: Update to upstream version 9d3649bd3be245c9Rob Herring
Sync dtc with upstream as of commit 9d3649bd3be2 (Add testcases for fdt_path_offset_namelen()). Signed-off-by: Rob Herring <robh@kernel.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: devicetree@vger.kernel.org
2015-04-29scripts/dtc: add missing libfdt and fixups to import scriptGaurav Minocha
The following script is used to import dtc upstream into kernel. It was missing import of dtc/libfdt, with this commit it will include the same. Also, currently in arch and driver code that needs early access to the flattened device tree it is necessary to add specific CFLAGS so that when scripts/dtc/libfdt/libfdt.h is included the C preprocessor is able to locate the libfdt versions of libfdt_env.h and fdt.h without generating an error. So, this script replaces angular brackets with quotation used to include header files fdt.h and libfdt_env.h Signed-off-by: Gaurav Minocha <gaurav.minocha.os@gmail.com> [robh: reword commit headline and add 'git add'] Signed-off-by: Rob Herring <robh@kernel.org>
2014-06-10kbuild: trivial - remove trailing empty linesMasahiro Yamada
2014-01-21scripts/dtc: Add a script to update to mainline dtc sourceGrant Likely
A very simple script that automates pulling in a newer version of DTC. Not particularly robust, but a whole lot better than doing it by hand every time. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2014-01-21scripts/dtc: Update to upstream version v1.4.0Grant Likely
Update to the latest version of dtc with the following notable enhancements and bug fixes: * fdtput: expand fdt if value does not fit * dtc/fdt{get, put}/convert-dtsv0-lexer: convert to new usage helpers * libfdt: Add fdt_next_subnode() to permit easy subnode iteration * utilfdt_read: pass back up the length of data read * util_version: new helper for displaying version info * die: constify format string arg * utilfdt_read_err: use xmalloc funcs * Export fdt_stringlist_contains() * dtc: Drop the '-S is deprecated' warning * dtc/libfdt: sparse fixes * dtc/libfdt: introduce fdt types for annotation by endian checkers * Fix util_is_printable_string * dtc: srcpos_verror() should print to stderr * libfdt: Added missing functions to shared library Shipped bison/flex generated files were built on an Ubuntu 13.10 system. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2014-01-21scripts/dtc: Update shipped files to build with bison 2.7.12Grant Likely
Preparation patch before updating to upstream dtc version 1.4.0. This change only contains the changes caused by a new version of bison on the shipped files. There are no functional changes. The shipped files were build on an Ubuntu 13.10 system Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-13dtc: ensure #line directives don't consume data from the next lineGrant Likely
Previously, the #line parsing regex ended with ({WS}+[0-9]+)?. The {WS} could match line-break characters. If the #line directive did not contain the optional flags field at the end, this could cause any integer data on the next line to be consumed as part of the #line directive parsing. This could cause syntax errors (i.e. #line parsing consuming the leading 0 from a hex literal 0x1234, leaving x1234 to be parsed as cell data, which is a syntax error), or invalid compilation results (i.e. simply consuming literal 1234 as part of the #line processing, thus removing it from the cell data). Fix this by replacing {WS} with [ \t] so that it can't match line-breaks. Convert all instances of {WS}, even though the other instances should be irrelevant for any well-formed #line directive. This is done for consistency and ultimate safety. [Cherry picked from DTC commit a1ee6f068e1c8dbc62873645037a353d7852d5cc] Reported-by: Ian Campbell <Ian.Campbell@citrix.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-06-13dtc: Update generated files to output from Bison 2.5Grant Likely
This patch merely updates the generated dtc parser and lexer files to the output generated by Bison 2.5. The previous versions were generated from version 2.4.1. The only reason for this commit is to minimize the diff on the next commit which fixes a bug in the DTC #line directive parsing. Otherwise the Bison changes would be intermingled with the functional changes. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-11-21script: dtc: clean generated filesMagnus Damm
Fix "make distclean" to clean up generated dtc files. Without this patch the following files are left around: - dtc-lexer.lex.c - dtc-parser.tab.c - dtc-parser.tab.h Signed-off-by: Magnus Damm <damm@opensource.se> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-10-17dtc: fix for_each_*() to skip first object if deletedStephen Warren
The previous definition of for_each_*() would always include the very first object within the list, irrespective of whether it was marked deleted, since the deleted flag was not checked on the first object, but only on any "next" object. Fix for_each_*() to check the deleted flag in the loop body every iteration to correct this. (upstream dtc commit 1762ab42ef77db7ab2776d0d6cba3515150f518a) Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-10-01dtc: import latest upstream dtcStephen Warren
This updates scripts/dtc to commit 317a5d9 "dtc: zero out new label objects" from git://git.jdl.com/software/dtc.git. This adds features such as: * /bits/ syntax for cell data. * Math expressions within cell data. * The ability to delete properties or nodes. * Support for #line directives in the input file, which allows the use of cpp on *.dts. * -i command-line option (/include/ path) * -W/-E command-line options for error/warning control. * Removal of spew to STDOUT containing the filename being compiled. * Many additions to the libfdt API. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Jon Loeliger <jdl@jdl.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-24scripts: dtc: fix compile warningsFelipe Balbi
Fix following compile warnings: scripts/dtc/flattree.c: In function ‘flat_read_mem_reserve’: scripts/dtc/flattree.c:700:14: warning: variable ‘p’ set but not used [-Wunused-but-set-variable] scripts/dtc/dtc.c: In function ‘main’: scripts/dtc/dtc.c:104:17: warning: variable ‘check’ set but not used [-Wunused-but-set-variable] Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14dtc: Implement -d option to write out a dependency fileStephen Warren
This will allow callers to rebuild .dtb files when any of the /include/d .dtsi files are modified, not just the top-level .dts file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-09dtc: regen parserArnaud Lacombe
Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09dtc: migrate parser to implicit rulesArnaud Lacombe
2011-01-03of/flattree: Update dtc to current mainline.John Bonesio
Pull in recent changes from the main dtc repository. These changes primarily allow multiple device trees to be declared which are merged by dtc. This feature allows us to include a basic dts file and then provide more information for the specific system through the merging functionality. Changes pulled from git://git.jdl.com/software/dtc.git commit id: 37c0b6a0, "dtc: Add code to make diffing trees easier" Signed-off-by: John Bonesio <bones@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-02scripts/dtc: Fix a resource leakMartin Ettl
during a check of the current git head of the linux kernel with the static code analysis tool cppcheck (http://sourceforge.net/apps/mediawiki/cppcheck/index.php?title=Main_Page) the tool discovered a resource leak in linux-2.6/scripts/dtc/fstree.c. Please refer the attached patch, that fixes the issue. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=15363 Signed-off-by: Martin Ettl <ettl.martin@gmx.de> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-11-15dtc: Mark various internal functions staticJosh Triplett
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-15dtc: Set "noinput" in the lexer to avoid an unused functionJosh Triplett
Regenerate the corresponding generated lexer. Regenerating the lexer with current flex also provides prototypes for various yy* functions, making some -Wmissing-prototypes warnings go away as well. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-06-26powerpc: Have git ignore generated files from dtc compileJon Smirl
Have git ignore generated files from dtc compile Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
