path: root/scripts/extract-ikconfig
2011-02-10scripts/extract-ikconfig: add xz compression supportDick Streefland
Add support for kernels compressed with xz to the extract-ikconfig script. Signed-off-by: Dick Streefland <dick@streefland.net> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-28scripts/extract-ikconfig: add support for bzip2, lzma and lzoDick Streefland
Add support for kernels compressed with bzip2, lzma or lzo to the extract-ikconfig script. Fixes kernel bugzilla #19852: https://bugzilla.kernel.org/show_bug.cgi?id=19852 Signed-off-by: Dick Streefland <dick@streefland.net> Tested-by: Justin <jlec@gentoo.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-10-07kconfig: simplification of scripts/extract-ikconfigDick Streefland
I've rewritten the extract-ikconfig script to extract the kernel configuration from a kernel compiled with CONFIG_IKCONFIG. The main motivation for the rewrite was to remove the dependency on the external C program binoffset.c, which is compiled on the initial run. The binoffset executable is invoked with a relative path, which means that the old script can only be run from the top of the kernel tree, and only when you have write permission in the scripts directory. The new script uses tr/grep/tail/zcat only, and can be invoked from anywhere. The binoffset.c program has been removed. This script requires GNU grep 2.5 (released 2002-03-13) or higher, because the -o option was introduced in that version. Signed-off-by: Dick Streefland <dick@streefland.net> LKML-Reference: <20091006203540.GA14634@streefland.net> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-08-18kconfig: have extract-ikconfig read ELF filesSteven Rostedt
It would be nice to use extract-ikconfig to find the congfig.gz in either vmlinux (not vmlinuz) or configs.ko. This patch changes the script to also be able to read ELF files directly. [ Impact: find config.gz in vmlinux and configs.ko ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-08-18kconfig: add check if end exists in extract-ikconfigSteven Rostedt
Both start and end should be tested for existence before continuing to parse the config.gz file. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2008-12-03remove bashisms from scripts/extract-ikconfigWerner Almesberger
unbashify-extract-ikconfig.patch scripts/extract-ikconfig contains a lot of gratuituous bashisms, which make it fail if /bin/sh isn't bash. This patch replaces them with regular Bourne shell constructs. Signed-off-by: Werner Almesberger <werner@openmoko.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> # as file author Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-24[PATCH] extract-ikconfig: don't use --long-optionsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] extract-ikconfig: be sure binoffset exists before extractingAlexey Dobriyan
2006-03-24[PATCH] extract-ikconfig: use mktemp(1)Alexey Dobriyan
