path: root/scripts/gcc-version.sh
2008-01-28kbuild: fix buglet in gcc-version.shSam Ravnborg
Greg Schafer <gschafer@zip.com.au> reported: ==== $make mrproper scripts/gcc-version.sh: [[: command not found This is on a very old host with an ancient bash as /bin/sh. But I have CONFIG_SHELL set and pointing to a modern bash. Something is wrong. This doesn't happen with 2.6.23 ==== Fixed using a more common string equality test. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Schafer <gschafer@zip.com.au> Cc: Jesper Juhl <jesper.juhl@gmail.com>
2007-10-12kbuild: improve scripts/gcc-version.sh output a bit when called without argsJesper Juhl
Currently, if you call scripts/gcc-version.sh without arguments it will generate this output : $ sh scripts/gcc-version.sh scripts/gcc-version.sh: line 12: [: =: unary operator expected scripts/gcc-version.sh: line 16: -E: command not found scripts/gcc-version.sh: line 17: -E: command not found 0000 Not too pretty. I believe this is an improvement : $ sh scripts/gcc-version.sh Error: No compiler specified. Usage: scripts/gcc-version.sh <gcc-command> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: New 'cc-fullversion' macroSegher Boessenkool
Prints a six-digit string including the GCC patchlevel. Also fix the 'usage' comment for cc-version. Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
