path: root/scripts/gdb/Makefile
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-17scripts/gdb: add infrastructureJan Kiszka
This provides the basic infrastructure to load kernel-specific python helper scripts when debugging the kernel in gdb. The loading mechanism is based on gdb loading for <objfile>-gdb.py when opening <objfile>. Therefore, this places a corresponding link to the main helper script into the output directory that contains vmlinux. The main scripts will pull in submodules containing Linux specific gdb commands and functions. To avoid polluting the source directory with compiled python modules, we link to them from the object directory. Due to gdb.parse_and_eval and string redirection for gdb.execute, we depend on gdb >= 7.2. This feature is enabled via CONFIG_GDB_SCRIPTS. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Michal Marek <mmarek@suse.cz> [kbuild stuff] Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ben Widawsky <ben@bwidawsk.net> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
