path: root/scripts/genksyms/keywords.gperf
2009-12-12genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}()Jan Beulich
Despite being unused these should also get a CRC calculated. Primarily I view this as a consistency thing. But I also think this is one of the reasons why __crc_* need to be weak (which I think should be avoided, and hence we should have the goal to eliminate this so that failure to calculate a proper CRC for a symbol causes the build to fail). Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Anibal Monsalve Salazar <anibal@debian.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-11-15genksyms: Mark is_reserved_word staticJosh Triplett
The genksyms keyword gperf hash provides a function is_reserved_word. genksyms #includes the resulting generated file keywords.c, so the function gets used only in the same source file that defines it. Mark is_reserved_word static, and regenerate the corresponding generated file. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-01-14Revert "kbuild: strip generated symbols from *.ko"Sam Ravnborg
This reverts commit ad7a953c522ceb496611d127e51e278bfe0ff483. And commit: ("allow stripping of generated symbols under CONFIG_KALLSYMS_ALL") 9bb482476c6c9d1ae033306440c51ceac93ea80c These stripping patches has caused a set of issues: 1) People have reported compatibility issues with binutils due to lack of support for `--strip-unneeded-symbols' with objcopy 2.15.92.0.2 Reported by: Wenji 2) ccache and distcc no longer works as expeced Reported by: Ted, Roland, + others 3) The installed modules increased a lot in size Reported by: Ted, Davej + others Reported-by: Wenji Huang <wenji.huang@oracle.com> Reported-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Dave Jones <davej@redhat.com> Reported-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-19allow stripping of generated symbols under CONFIG_KALLSYMS_ALLJan Beulich
Building upon parts of the module stripping patch, this patch introduces similar stripping for vmlinux when CONFIG_KALLSYMS_ALL=y. Using CONFIG_KALLSYMS_STRIP_GENERATED reduces the overhead of CONFIG_KALLSYMS_ALL from 245k/310k to 65k/80k for the (i386/x86-64) kernels I tested with. The patch also does away with the need to special case the kallsyms- internal symbols by making them available even in the first linking stage. While it is a generated file, the patch includes the changes to scripts/genksyms/keywords.c_shipped, as I'm unsure what the procedure here is. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: __extension__ support in genksyms (fix unknown CRC warning)Sam Ravnborg
Recently the __extension__ keyword has been introduced in the kernel. Teach genksyms about this keyword so it can generate correct CRC for exported symbols that uses a symbol marked __extension__. For now only the typedef variant: __extension__ typedef ... is supported. Later we may add more variants as needed. This patch contains the actual source file changes. The following patch will hold modifications to the generated files (*_shipped) and only after the second patch the fix has effect. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-20[PATCH] add EXPORT_SYMBOL_GPL_FUTURE()Greg Kroah-Hartman
This patch adds the ability to mark symbols that will be changed in the future, so that kernel modules that don't include MODULE_LICENSE("GPL") and use the symbols, will be flagged and printed out to the system log. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
